[GRASS-SVN] r41144 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Sun Feb 21 02:12:14 EST 2010
Author: cmbarton
Date: 2010-02-21 02:12:08 -0500 (Sun, 21 Feb 2010)
New Revision: 41144
grass/trunk/gui/wxpython/xml/menudata.xml
Fix imagery menus
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2010-02-21 07:00:23 UTC (rev 41143)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2010-02-21 07:12:08 UTC (rev 41144)
@@ -768,7 +768,6 @@
<handler>self.OnMenuCmd</handler>
<command>g.proj</command>
</menuitem>
<menuitem>
<label>Convert coordinates</label>
<help>Converts coordinates from one projection to another (cs2cs frontend).</help>
@@ -792,7 +791,6 @@
<menu>
<label>Develop raster map</label>
<items>
<menuitem>
<label>Compress/decompress</label>
<help>Compresses and decompresses raster maps.</help>
@@ -2093,7 +2091,6 @@
<command>v.net.path</command>
</menuitem>
<menuitem>
<label>Split net</label>
<help>Splits net by cost isolines.</help>
@@ -2416,7 +2413,6 @@
<command>i.rectify</command>
</menuitem>
<menuitem>
<label>Brovey sharpening</label>
<help>Brovey transform to merge multispectral and high-res panchromatic channels</help>
@@ -2449,7 +2445,6 @@
<command>i.smap</command>
</menuitem>
<menuitem>
<label>Input for supervised MLC</label>
<help>Generates statistics for i.maxlik from raster map.</help>
@@ -2549,7 +2544,7 @@
<label>Evapotranspiration calculation</label>
<items>
<menuitem>
- <label>Bit pattern comparison </label>
+ <label>Evapotranspiration</label>
<help>actual evapotranspiration for diurnal period (Bastiaanssen, 1995)</help>
<keywords>imagery,actual evapotranspiration,energy balance,SEBAL</keywords>
@@ -2557,56 +2552,56 @@
</menuitem>
<separator />
<menuitem>
- <help>Compares bit patterns with a raster map.</help>
+ <label>Albedo</label>
+ <help>Broad band albedo from surface reflectance.</help>
<keywords>raster</keywords>
<command>i.albedo:</command>
</menuitem>
<menuitem>
+ <label>Evaporative fraction</label>
<help>Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)</help>
<keywords>imagery,evaporative fraction,soil moisture,energy balance,SEBAL</keywords>
<command>i.eb.evapfr</command>
</menuitem>
<menuitem>
- <help>Computes sensible Heat Flux iteration SEBAL 01</help>
+ <label>Sensible heat flux</label>
+ <help>Computes sensible heat flux iteration SEBAL 01</help>
<command>i.eb.h_SEBAL01</command>
</menuitem>
<menuitem>
+ <label>Soil heat flux</label>
<help>Soil heat flux approximation (Bastiaanssen, 1995)</help>
<keywords>imagery,soil heat flux,energy balance,SEBAL</keywords>
<command>i.eb.soilheatflux</command>
</menuitem>
<menuitem>
- <help>Emissivity from NDVI, generic method for spares land.</help>
+ <label>Emissivity</label>
+ <help>Emissivity from NDVI, generic method for sparse land.</help>
<keywords>emissivity,land flux,energy balance</keywords>
<command>i.emissivity</command>
</menuitem>
<menuitem>
+ <label>Temporal integration of ETa</label>
<help>Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)</help>
<keywords>imagery,evapotranspiration,temporal,integration</keywords>
<command>i.evapo.time_integration</command>
</menuitem>
<menuitem>
+ <label>LatLong map</label>
<help>creates a latitude/longitude map</help>
<keywords>imagery,latitude,longitude,projection</keywords>
<command>i.latlong</command>
</menuitem>
<menuitem>
+ <label>Vegetation indices</label>
<help>Calculates different types of vegetation indices.</help>
<keywords>imagery,vegetation index,biophysical parameters</keywords>
@@ -2615,21 +2610,21 @@
</items>
</menu>
<menuitem>
- <label>Atmospheric correction</label>
+ <label>Biomass growth</label>
<help>Computes biomass growth, precursor of crop yield calculation</help>
<keywords>imagery,biomass,fpar,yield</keywords>
<command>i.biomass</command>
</menuitem>
<menuitem>
+ <label>Modis quality control</label>
<help>Extract quality control parameters from Modis QC layers</help>
<keywords>QC,Quality Control,surface reflectance,Modis</keywords>
<command>i.modis.qc</command>
</menuitem>
<menuitem>
+ <label>Sunshine hours</label>
<help>creates a sunshine hours map</help>
<keywords>sunshine,hours,daytime</keywords>
