[GRASS-SVN] r41153 - grass/trunk/vector/v.in.dxf
svn_grass at osgeo.org
Sun Feb 21 22:27:30 EST 2010
Author: hcho
Date: 2010-02-21 22:27:29 -0500 (Sun, 21 Feb 2010)
New Revision: 41153
grass/trunk/vector/v.in.dxf/add_polyline.c
Removed old warnings
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c 2010-02-22 01:33:55 UTC (rev 41152)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c 2010-02-22 03:27:29 UTC (rev 41153)
@@ -12,7 +12,6 @@
int layer_flag = 0; /* indicates if a layer name has been found */
int polyline_flag = 0; /* indicates the type of polyline */
int warn_flag66 = 1; /* indicates if error message printed once */
- int warn_flag70 = 1; /* indicates if error message printed once */
int vert_flag; /* indicates that vertices are following */
int xflag = 0; /* indicates if a x value has been found */
int yflag = 0; /* indicates if a y value has been found */
@@ -65,16 +64,6 @@
128 = The linetype pattern is generated continuously around
the vertices of this polyline.
- /* NOTE: code only exists for flag = 1 (closed polyline) or 0 */
- G_debug(1, "polyline_flag: %d", polyline_flag);
- if (polyline_flag & (8 | 16 | 32))
- if (warn_flag70) {
- if (!flag_list)
- G_warning(_
- ("3-d data in dxf file. Polyline_flag: %d"),
- polyline_flag);
- warn_flag70 = 0;
break;
