[GRASS-SVN] r41155 - grass/branches/develbranch_6/vector/v.in.dxf
svn_grass at osgeo.org
Mon Feb 22 02:28:06 EST 2010
Author: neteler
Date: 2010-02-22 02:27:57 -0500 (Mon, 22 Feb 2010)
New Revision: 41155
grass/branches/develbranch_6/vector/v.in.dxf/add_polyline.c
Removed old warnings (merge from trunk, r41153)
Modified: grass/branches/develbranch_6/vector/v.in.dxf/add_polyline.c
--- grass/branches/develbranch_6/vector/v.in.dxf/add_polyline.c 2010-02-22 05:30:01 UTC (rev 41154)
+++ grass/branches/develbranch_6/vector/v.in.dxf/add_polyline.c 2010-02-22 07:27:57 UTC (rev 41155)
@@ -11,7 +11,6 @@
int layer_flag = 0; /* indicates if a layer name has been found */
int polyline_flag = 0; /* indicates the type of polyline */
int warn_flag66 = 1; /* indicates if error message printed once */
- int warn_flag70 = 1; /* indicates if error message printed once */
int vert_flag; /* indicates that vertices are following */
int xflag = 0; /* indicates if a x value has been found */
int yflag = 0; /* indicates if a y value has been found */
@@ -62,14 +61,6 @@
128 = The linetype pattern is generated continuously around
the vertices of this polyline.
- /* NOTE: code only exists for flag = 1 (closed polyline) or 0 */
- G_debug(1, "polyline_flag: %d", polyline_flag);
- if (polyline_flag & (8 | 16 | 32))
- if (warn_flag70) {
- G_warning(_("3-d data in dxf file. Polyline_flag: %d"),
- polyline_flag);
- warn_flag70 = 0;
break;
@@ -145,7 +136,7 @@
8 = Spline vertex created by spline-fitting
16 = Spline frame control point
32 = 3D polyline vertex
- 64 = 3D polygon mesh
+ 64 = 3D polygon mesh vertex
128 = Polyface mesh vertex
if (vertex_flag == 16) {
