[GRASS-SVN] r41157 - grass/trunk/lib/raster
svn_grass at osgeo.org
Mon Feb 22 05:35:54 EST 2010
Author: martinl
Date: 2010-02-22 05:35:53 -0500 (Mon, 22 Feb 2010)
New Revision: 41157
grass/trunk/lib/raster/quant.c
grass/trunk/lib/raster/quant_io.c
grass/trunk/lib/raster/range.c
librast: Rast__quant_import() works with fully qualified names
message clean up
Modified: grass/trunk/lib/raster/quant.c
--- grass/trunk/lib/raster/quant.c 2010-02-22 07:28:21 UTC (rev 41156)
+++ grass/trunk/lib/raster/quant.c 2010-02-22 10:35:53 UTC (rev 41157)
@@ -3,17 +3,16 @@
* \brief Raster Library - Quantization rules.
- * The quantization table is stored as a linear array. rules are added
- * starting from index 0. redundant rules are not eliminated. rules
- * are tested from the highest index downto 0. there are two
- * "infinite" rules. support is provided to reverse the order of the
+ * The quantization table is stored as a linear array. Rules are added
+ * starting from index 0. Redundant rules are not eliminated. Rules
+ * are tested from the highest index downto 0. There are two
+ * "infinite" rules. Support is provided to reverse the order of the
* rules.
* (C) 1999-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
* \author USACERL and many others
Modified: grass/trunk/lib/raster/quant_io.c
--- grass/trunk/lib/raster/quant_io.c 2010-02-22 07:28:21 UTC (rev 41156)
+++ grass/trunk/lib/raster/quant_io.c 2010-02-22 10:35:53 UTC (rev 41157)
@@ -1,82 +1,34 @@
- * int
- * Rast__quant_import (name, mapset, quant)
- * char *name;
- * char *mapset;
- * struct Quant *quant;
+ * \file raster/quant_io.c
- * reads quantization rules for "name" in "mapset" and stores them
- * in the quantization structure "quant". If the map is in another
- * mapset, first checks for quant2 table for this map in current
- * mapset.
- * returns: -2 if raster map is of type integer.
- * -1 if (! G_name_is_fully_qualified ()).
- * 0 if quantization file does not exist, or the file is empty,
- * 1 if non-empty quantization file exists.
- * read.
- * note: in the case of negative return value, the result of using the
- * quantization structure is not defined.
- * in case of return value 0, calls to Rast_quant_perform_d ()
- * and Rast_quant_perform_f () return NO_DATA (see description of
- * Rast_quant_perform_d () for more details). in case of
- * return values 2 and 3, the explicit rule for quant is set:
- * floating range is mapped to integer range.
+ * \brief Raster Library - Quantization rules (input / output)
- * note: use Rast_quant_init () to allocate and initialize the quantization
- * staructure quant before the first usage of G_quant_import ().
+ * (C) 1999-2010 by the GRASS Development Team
- * note: this function uses Rast_quant_free () to clear all previously
- * stored rules in quant.
- * int
- * Rast__quant_export (name, mapset, quant)
+ * \author USACERL and many others
- * char *name, *mapset;
- * writes the quantization rules stored in "quant" for "name" . if the
- * mapset is the same as the current mapset, the quant file is created
- * in cell_misc/name directory, otherwise it is created in quant2/mapset
- * directory, much like writing colors for map in another mapset.
- * The rules are written in decreasing order
- * of priority (i.e. rules added earlier are written later).
- * returns: -1 if (! G_name_is_fully_qualified) or file could not be
- * opened.
- * 1 otherwise.
- * note: if no rules are defined an empty file is created.
#include <string.h>
#include <grass/gis.h>
#include <grass/raster.h>
#include <grass/glocale.h>
#define QUANT_FILE_NAME "f_quant"
static int quant_parse_file(FILE *, struct Quant *);
#if 0
-static int
/* redundant: integer range doesn't exist now: it is defined by
the quant rules */
-quant_load_range(struct Quant *quant, const char *name, const char *mapset)
+static int quant_load_range(struct Quant *quant, const char *name, const char *mapset)
struct FPRange fprange;
struct Range range;
@@ -88,8 +40,8 @@
return 0;
Rast_get_fp_range_min_max(&fprange, &dMin, &dMax);
if (Rast_is_d_null_value(&dMin) || Rast_is_d_null_value(&dMax)) {
- G_warning(_("The floating data range for %s@%s is empty"),
- name, mapset);
+ G_warning(_("Floating data range for raster map <%s> is empty"),
+ G_fully_qualified_name(name, mapset));
return -3;
@@ -97,8 +49,8 @@
return 0;
Rast_get_range_min_max(&range, &min, &max);
if (Rast_is_c_null_value(&min) && Rast_is_c_null_value(&max)) {
- G_warning(_("The integer data range for %s@%s is empty"),
- name, mapset);
+ G_warning(_("Integer data range for raster map <%s> is empty"),
return -3;
@@ -108,13 +60,41 @@
#endif
+ \brief Reads quantization rules (internal use only)
+ Reads quantization rules for raster map <i>name</i> in <i>mapset</i>
+ and stores them in the quantization structure "quant". If the map is
+ in another mapset, first checks for quant2 table for this map in
+ current mapset.
+ Note: in the case of negative return value, the result of using the
+ quantization structure is not defined.
+ in case of return value 0, calls to Rast_quant_perform_d()
+ and Rast_quant_perform_f() return NO_DATA (see description of
+ Rast_quant_perform_d() for more details). in case of
+ return values 2 and 3, the explicit rule for quant is set:
+ floating range is mapped to integer range.
+ Note: use Rast_quant_init() to allocate and initialize the quantization
+ staructure quant before the first usage of G_quant_import().
+ Note: this function uses Rast_quant_free () to clear all previously
+ stored rules in quant.
+ \param name map name
+ \param mapset mapset name
+ \param[out] quant pointer to Quant structure
+ \return -2 if raster map is of type integer.
+ \return -1 if map name is fully qualified and mapset is not the current one
+ \return 0 if quantization file does not exist, or the file is empty,
+ \return 1 if non-empty quantization file exists.
int Rast__quant_import(const char *name, const char *mapset,
struct Quant *quant)
char buf[1024];
- char *err;
char xname[GNAME_MAX], xmapset[GMAPSET_MAX], element[GNAME_MAX + 7];
int parsStat;
FILE *fd;
@@ -122,14 +102,16 @@
Rast_quant_free(quant);
if (Rast_map_type(name, mapset) == CELL_TYPE) {
- G_warning(_("Rast__quant_import: attempt to open quantization"
- " table for CELL_TYPE file [%s] in mapset {%s]"),
- name, mapset);
+ G_warning(_("Attempt to open quantization"
+ " table for CELL raster map <%s>"),
return -2;
if (G_name_is_fully_qualified(name, xname, xmapset)) {
- if (strcmp(xmapset, mapset) != 0)
+ if (strlen(mapset) == 0)
+ mapset = xmapset;
+ else if (strcmp(xmapset, mapset) != 0)
return -1;
name = xname;
@@ -142,16 +124,16 @@
if (parsStat)
return 1;
sprintf(buf,
- "quantization file in quant2 for [%s] in mapset [%s] is empty",
- name, mapset);
+ "quantization file in quant2 for raster map <%s> is empty",
/* now try reading regular : cell_misc/name/quant file */
if (!(fd = G_fopen_old_misc("cell_misc", QUANT_FILE_NAME, name, mapset))) {
/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 3; */
- err = "missing";
+ G_warning(_("Quantization file for raster map <%s> is missing"),
else {
parsStat = quant_parse_file(fd, quant);
@@ -160,33 +142,27 @@
if (parsStat)
return 1;
/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 2; */
- err = "empty";
+ G_warning(_("Quantization file for raster map <%s> is empty"),
- G_warning(_("quantization file [%s] in mapset [%s] %s"),
- name, mapset, err);
return 0;
-/* parse input lines with the following formats
- * d_high:d_low:c_high:c_low
- * d_high:d_low:c_val (i.e. c_high == c_low)
- * *:d_val:c_val (interval [inf, d_val]) (**)
- * d_val:*:c_val (interval [d_val, inf]) (**)
- * all other lines are ignored
- * (**) only the first appearances in the file are considered.
+ \brief Parse input lines with the following formats
+ \code
+ d_high:d_low:c_high:c_low
+ d_high:d_low:c_val (i.e. c_high == c_low)
+ *:d_val:c_val (interval [inf, d_val]) (**)
+ d_val:*:c_val (interval [d_val, inf]) (**)
+ \endcode
+ All other lines are ignored
+ (**) only the first appearances in the file are considered.
static int quant_parse_file(FILE * fd, struct Quant *quant)
CELL cLow, cHigh;
@@ -241,10 +217,6 @@
(Rast_quant_get_pos_infinite_rule(quant, &dLow, &cLow) > 0));
static void quant_write(FILE * fd, const struct Quant *quant)
DCELL dLow, dHigh;
@@ -274,11 +246,27 @@
+ \brief Writes the quantization rules (internal use only)
-int
-Rast__quant_export(const char *name, const char *mapset,
- const struct Quant *quant)
+ Writes the quantization rules stored in <i>quant</i> for <i>name</i>
+ . If the mapset is the same as the current mapset, the quant file is
+ created in 'cell_misc/name' directory, otherwise it is created in
+ 'quant2/mapset' directory, much like writing colors for map in
+ another mapset. The rules are written in decreasing order of
+ priority (i.e. rules added earlier are written later).
+ Note: if no rules are defined an empty file is created.
+ \param quant pointer to Quant structure
+ \return -1 if map name is not fully qualified or file could not be opened.
+ \return 1 otherwise.
+int Rast__quant_export(const char *name, const char *mapset,
+ const struct Quant *quant)
char element[GNAME_MAX + 7];
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
@@ -303,17 +291,9 @@
if (!(fd = G_fopen_new(element, name)))
return -1;
quant_write(fd, quant);
fclose(fd);
return 1;
Modified: grass/trunk/lib/raster/range.c
--- grass/trunk/lib/raster/range.c 2010-02-22 07:28:21 UTC (rev 41156)
+++ grass/trunk/lib/raster/range.c 2010-02-22 10:35:53 UTC (rev 41157)
@@ -100,8 +100,8 @@
if (G_find_file2_misc("cell_misc", "f_range", name, mapset)) {
fd = G_open_old_misc("cell_misc", "f_range", name, mapset);
if (fd < 0) {
- G_warning(_("Unable to read fp range file for <%s@%s>"),
- name, mapset);
+ G_warning(_("Unable to read fp range file for <%s>"),
return -1;
@@ -115,8 +115,8 @@
if (!xdr_double(&xdr_str, &dcell1) || !xdr_double(&xdr_str, &dcell2)) {
if (fd)
close(fd);
- name, mapset);
return -1;
@@ -148,7 +148,7 @@
* \param name map name
* \param mapset mapset name
- * \param range pointer to Range structure which holds range info
+ * \param[out] range pointer to Range structure which holds range info
* \return -1 on error
* \return 1 on success
@@ -163,7 +163,6 @@
int n, count;
struct Quant quant;
struct FPRange drange;
Rast_init_range(range);
fd = NULL;
@@ -172,8 +171,8 @@
DCELL dmin, dmax;
if (Rast_read_quant(name, mapset, &quant) < 0) {
- G_warning(_("Unable to read quant rules for raster map <%s@%s>"),
- name, mapset);
+ G_warning(_("Unable to read quant rules for raster map <%s>"),
return -1;
if (Rast_quant_is_truncate(&quant) || Rast_quant_is_round(&quant)) {
@@ -209,8 +208,8 @@
if (G_find_file2_misc("cell_misc", "range", name, mapset)) {
fd = G_fopen_old_misc("cell_misc", "range", name, mapset);
if (!fd) {
- G_warning(_("Unable to read range file for <%s@%s>"),
- name, mapset);
+ G_warning(_("Unable to read range file for <%s>"),
return -1;
@@ -226,8 +225,8 @@
if (fd)
fclose(fd);
- name, mapset);
return -1;
