[GRASS-SVN] r41204 - grass/trunk/vector/v.delaunay
svn_grass at osgeo.org
Sat Feb 27 12:35:59 EST 2010
Author: hamish
Date: 2010-02-27 12:35:59 -0500 (Sat, 27 Feb 2010)
New Revision: 41204
Removed:
grass/trunk/vector/v.delaunay/v_delaunay_spearfish60_archsites.png
grass/trunk/vector/v.delaunay/v.delaunay.html
go back to 3-pane graphic (merge from devbr6)
Modified: grass/trunk/vector/v.delaunay/v.delaunay.html
--- grass/trunk/vector/v.delaunay/v.delaunay.html 2010-02-27 17:33:14 UTC (rev 41203)
+++ grass/trunk/vector/v.delaunay/v.delaunay.html 2010-02-27 17:35:59 UTC (rev 41204)
@@ -5,12 +5,13 @@
<P>
<BR>
-Delaunay triangulation example:
+Delaunay triangulation and Voronoi diagram example:
<center>
-<img src=v_delaunay_spearfish60_archsites.png border=1><BR>
+<img src=v_voronoi_delaunay.png border=1><BR> <!-- installed by v.voronoi -->
<table border=0 width=590>
<tr><td><center>
-<i>Delaunay Triangulation</i>
+<i>Delaunay Triangulation (left pane), Voronoi diagram (center pane),
+and both (right pane)</i>
</center></td></tr>
</table>
</center>
@@ -20,9 +21,25 @@
Commands used with the Spearfish dataset to create the above figure.
<div class="code"><pre>
- g.region n=4927250 s=4920000 w=588650 e=605850
+ g.region n=4927250 s=4919400 w=588650 e=594850
+ d.frame -c fr=one at=0,100,0,33.3333
+ d.frame -c fr=two at=0,100,33.3333,66.6667
+ d.frame -c fr=three at=0,100,66.6667,100
v.delaunay -lr in=archsites out=arch_delaunay
- d.vect map=arch_delaunay color=0:0:255
+ d.frame -s one
+ d.vect arch_delaunay
+ d.vect archsites color=red fcolor=red size=5 icon=basic/circle
+ v.voronoi -l in=archsites out=arch_voronoi
+ d.frame -s two
+ d.vect arch_voronoi type=line
+ d.frame -s three
+ d.vect arch_delaunay color=blue
</pre></div>
@@ -34,6 +51,7 @@
April 1985, Pages 74-123
</EM>
<H2>SEE ALSO</H2>
<EM>
<A HREF="v.voronoi.html">v.voronoi</A>,
@@ -47,6 +65,5 @@
Based on "dct" by Geoff Leach, Department of Computer Science, RMIT.<br>
<p>
<i>Last changed: $Date: (Mon, 18 Aug 2008) $</i></p>
Deleted: grass/trunk/vector/v.delaunay/v_delaunay_spearfish60_archsites.png
(Binary files differ)
