[GRASS-SVN] r41215 - grass/trunk/raster/r.out.png
Sun Feb 28 02:30:28 EST 2010
Author: hamish
Date: 2010-02-28 02:30:25 -0500 (Sun, 28 Feb 2010)
New Revision: 41215
   grass/trunk/raster/r.out.png/main.c
   grass/trunk/raster/r.out.png/pngfunc.h
   grass/trunk/raster/r.out.png/r.out.png.html
new -t flag for transpatency; new compression= option;
i18n and msg cleanup, EXIT_SUCCESS, G_define_standard_option();
think about bgcolor= option
   (trac #967, merge from devbr6)
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c	2010-02-28 07:10:50 UTC (rev 41214)
+++ grass/trunk/raster/r.out.png/main.c	2010-02-28 07:30:25 UTC (rev 41215)
@@ -4,8 +4,9 @@
  * MODULE:       r.out.png
  * AUTHOR(S):    Bill Brown - USA-CERL
  *               Alex Shevlakov - sixote at yahoo.com
+ *		 Hamish Bowman
  * PURPOSE:      Export GRASS raster as non-georeferenced PNG image.
- * COPYRIGHT:    (C) 2000 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2000-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -14,18 +15,15 @@
+ * Alex Shevlakov, sixote at yahoo.com, 03/2000
  * based on r.out.ppm by
  * Written by Bill Brown, USA-CERL March 21, 1994
-/* Use to convert grass raster map to PNG
+ * Use to convert grass raster map to PNG
  * uses currently selected region
-/*              Alex Shevlakov, sixote at yahoo.com, 03/2000
 #include <string.h>
 #include <stdlib.h>
@@ -38,48 +36,50 @@
 #include <grass/gis.h>
 #include <grass/raster.h>
+#include <grass/colors.h>
 #include <grass/glocale.h>
-#define DEF_RED 255
-#define DEF_GRN 255
-#define DEF_BLU 255
 typedef int FILEDESC;
 int main(int argc, char *argv[])
     struct GModule *module;
-    struct Option *rast, *png_file;
+    struct Option *rast, *png_file, *compr; /* , *bgcolor; */
+    struct Flag *alpha;
     char *rastermap;
     char *basename = NULL, *ofile;
     unsigned char *set, *ored, *ogrn, *oblu;
+    int def_red, def_grn, def_blu;
     CELL *cell_buf;
     FCELL *fcell_buf;
     DCELL *dcell_buf;
     void *voidc;
     int rtype, row, col, do_stdout = 0;
+    size_t rsize;
+    int png_compr, ret, do_alpha;
     struct Cell_head w;
     FILEDESC cellfile = 0;
     FILE *fp;
     /* now goes from pnmtopng.c* -A.Sh */
-     * ** pnmtopng.c -
-     * ** read a portable anymap and produce a Portable Network Graphics file
-     * ** derived from pnmtorast.c (c) 1990,1991 by Jef Poskanzer and some
-     * ** parts derived from ppmtogif.c by Marcel Wijkstra <wijkstra at fwi.uva.nl>
-     * ** thanks to Greg Roelofs <newt at pobox.com> for contributions and bug-fixes
-     * ** Copyright (C) 1995-1998 by Alexander Lehmann <alex at hal.rhein-main.de>
-     * **                        and Willem van Schaik <willem at schaik.com>
-     * ** Permission to use, copy, modify, and distribute this software and its
-     * ** documentation for any purpose and without fee is hereby granted, provided
-     * ** that the above copyright notice appear in all copies and that both that
-     * ** copyright notice and this permission notice appear in supporting
-     * ** documentation.  This software is provided "as is" without express or
-     * ** implied warranty.
+     * * pnmtopng.c -
+     * * read a portable anymap and produce a Portable Network Graphics file
+     * * derived from pnmtorast.c (c) 1990,1991 by Jef Poskanzer and some
+     * * parts derived from ppmtogif.c by Marcel Wijkstra <wijkstra at fwi.uva.nl>
+     * * thanks to Greg Roelofs <newt at pobox.com> for contributions and bug-fixes
+     * * Copyright (C) 1995-1998 by Alexander Lehmann <alex at hal.rhein-main.de>
+     * *			and Willem van Schaik <willem at schaik.com>
+     * * Permission to use, copy, modify, and distribute this software and its
+     * * documentation for any purpose and without fee is hereby granted, provided
+     * * that the above copyright notice appear in all copies and that both that
+     * * copyright notice and this permission notice appear in supporting
+     * * documentation.  This software is provided "as is" without express or
+     * * implied warranty.
     png_struct *png_ptr;
@@ -103,42 +103,53 @@
     G_gisinit(argv[0]);
-    rast = G_define_option();
-    rast->key = "input";
-    rast->type = TYPE_STRING;
-    rast->required = YES;
-    rast->multiple = NO;
-    rast->gisprompt = "old,cell,Raster";
-    rast->description = _("Raster file to be converted.");
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("export"));
+    G_add_keyword("PNG");
+    module->description =
+	_("Export a GRASS raster map as a non-georeferenced PNG image.");
-    png_file = G_define_option();
-    png_file->key = "output";
-    png_file->type = TYPE_STRING;
+    rast = G_define_standard_option(G_OPT_R_INPUT);
+    png_file = G_define_standard_option(G_OPT_F_OUTPUT);
     png_file->required = YES;
-    png_file->multiple = NO;
-    png_file->description = _("Name for new PNG file. (use out=- for stdout)");
+    png_file->description = _("Name for new PNG file (use out=- for stdout)");
+    compr = G_define_option();
+    compr->key = "compression";
+    compr->type = TYPE_INTEGER;
+    compr->required = NO;
+    compr->multiple = NO;
+    compr->options = "0-9";
+    compr->label = _("Compression level of PNG file");
+    compr->description = _("(0 = none, 1 = fastest, 9 = best)");
+    compr->answer = "6";
+/*    bgcolor = G_define_standard_option(G_OPT_C_BG); */
+    alpha = G_define_flag();
+    alpha->key = 't';
+    alpha->description = _("Make NULL cells transparent");
     /* see what can be done to convert'em -A.Sh.
      * gscale = G_define_flag ();
-     * gscale->key = 'G';
+     * gscale->key = 'g';
      * gscale->description = "Output greyscale instead of color";
-    module = G_define_module();
-    G_add_keyword(_("raster"));
-    G_add_keyword(_("export"));
-    module->description =
-	_("Export a GRASS raster map as non-georeferenced PNG image format.");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     rastermap = rast->answer;
+    do_alpha = alpha->answer ? TRUE : FALSE;
     if (strcmp(png_file->answer, "-") != 0)
 	basename = G_store(png_file->answer);
     else
-	do_stdout = 1;
+	do_stdout = TRUE;
     if (basename) {
 	G_basename(basename, "png");
@@ -147,10 +158,25 @@
 	G_free(basename);
+    png_compr = atoi(compr->answer);
+#ifdef MAYBE_LATER
+    /* ... if at all */
+    ret = G_str_to_color(bgcolor->answer, &def_red, &def_grn, &def_blu);
+    if (ret == 0)
+	G_fatal_error(_("[%s]: No such color"), bgcolor->answer);
+    else if (ret == 2) {  /* (ret==2) is "none" */
+	if(!do_alpha)
+	    do_alpha = TRUE;
+#else
+    ret = G_str_to_color(DEFAULT_BG_COLOR, &def_red, &def_grn, &def_blu);
+#endif
     /*G_get_set_window (&w); *//* 10/99 MN: check for current region */
     G_get_window(&w);
-    G_message(_("rows = %d, cols = %d"), w.rows, w.cols);
+    G_debug(1, "rows = %d, cols = %d", w.rows, w.cols);
     /* open raster map for reading */
     cellfile = Rast_open_old(rast->answer, "");
@@ -169,7 +195,7 @@
 	if (do_stdout)
 	    fp = stdout;
 	else if (NULL == (fp = fopen(ofile, "w")))
-	    G_fatal_error("Not able to open file for [%s]", ofile);
+	    G_fatal_error(_("Unable to open output file <%s>"), ofile);
 	else
 	    G_free(ofile);
@@ -211,14 +237,18 @@
 	png_set_filter(png_ptr, 0, filter);
-    /* zlib compression-level (or none) required */
-    /* ((compression >= -1) && (compression <= 9)) */
-    png_set_compression_level(png_ptr, Z_DEFAULT_COMPRESSION);
+    png_set_compression_level(png_ptr, png_compr);
-    G_message(_("Converting %s..."), rast->answer);
+/* FIXME: this should be set
+    if(do_alpha) {
+	png_color_16p bgcolor *background_color;
+	png_set_background(png_ptr, png_color_16p background_color,
+	    PNG_BACKGROUND_GAMMA_FILE, int need_expand, double background_gamma);
+    G_verbose_message(_("Converting <%s>..."), rast->answer);
 	struct Colors colors;
@@ -232,14 +262,18 @@
 	else if (rtype == DCELL_TYPE)
 	    voidc = (DCELL *) dcell_buf;
 	else
-	    exit(EXIT_FAILURE);
+	    G_fatal_error(_("Raster <%s> type mismatch"), rast->answer);
+	rsize = Rast_cell_size(rtype);
 	/*if(!gscale->answer){ *//* 24BIT COLOR IMAGE */
-	if (1) {
+	if (TRUE) {
+	    if (do_alpha)
+		info_ptr->color_type = PNG_COLOR_TYPE_RGB_ALPHA;
+	    else
+		info_ptr->color_type = PNG_COLOR_TYPE_RGB;
-	    info_ptr->color_type = PNG_COLOR_TYPE_RGB;
 	    /* write the png-info struct */
 	    png_write_info(png_ptr, info_ptr);
@@ -264,20 +298,33 @@
 			*pp++ = ored[col];
 			*pp++ = ogrn[col];
 			*pp++ = oblu[col];
+			if (do_alpha) {
+			    if (Rast_is_null_value(
+				   G_incr_void_ptr(voidc, col * rsize), rtype))
+				*pp++ = 0;
+			    else
+				*pp++ = 255;
 		    else {
-			*pp++ = DEF_RED;
-			*pp++ = DEF_GRN;
-			*pp++ = DEF_BLU;
+			if (do_alpha) {
+			    *pp++ = ored[col];
+			    *pp++ = ogrn[col];
+			    *pp++ = oblu[col];
+			    *pp++ = 0;
+			else {
+			    *pp++ = (unsigned char)def_red;
+			    *pp++ = (unsigned char)def_grn;
+			    *pp++ = (unsigned char)def_blu;
 		png_write_row(png_ptr, line);
+	    G_percent(row, w.rows, 5); /* finish it off */
 	else {			/* GREYSCALE IMAGE */
@@ -288,7 +335,7 @@
 	    /* pm_message ("don't know yet how to write grey - yumm!!"); */
-	    G_warning("don't know how to write grey scale!\n");
+	    G_warning("don't know how to write grey scale!");
 	Rast_free_colors(&colors);
@@ -304,7 +351,6 @@
     Rast_close(cellfile);
     png_write_end(png_ptr, info_ptr);
     /* png_write_destroy (png_ptr); this is no longer supported with libpng, al 11/2000 */
     /* flush first because G_free (png_ptr) can segfault due to jmpbuf problems
@@ -317,9 +363,10 @@
     fclose(fp);
-    return (0);
+    exit(EXIT_SUCCESS);
 #ifdef __STDC__
 static void pnmtopng_error_handler(png_structp png_ptr, png_const_charp msg)
 #else
@@ -339,7 +386,7 @@
      * regardless of whether _BSD_SOURCE or anything else has (or has not)
      * been defined. */
-    G_warning("pnmtopng:  fatal libpng error: %s", msg);
+    G_warning("pnmtopng:  fatal libpng error: [%s]", msg);
     jmpbuf_ptr = png_get_error_ptr(png_ptr);
     if (jmpbuf_ptr == NULL) {	/* we are completely hosed now */
Modified: grass/trunk/raster/r.out.png/pngfunc.h
--- grass/trunk/raster/r.out.png/pngfunc.h	2010-02-28 07:10:50 UTC (rev 41214)
+++ grass/trunk/raster/r.out.png/pngfunc.h	2010-02-28 07:30:25 UTC (rev 41215)
@@ -24,7 +24,6 @@
 #if 0
 /* unused */
 static int filter = -1;
-static int compression = Z_DEFAULT_COMPRESSION;
 #endif
 static jmpbuf_wrapper pnmtopng_jmpbuf_struct;
Modified: grass/trunk/raster/r.out.png/r.out.png.html
--- grass/trunk/raster/r.out.png/r.out.png.html	2010-02-28 07:10:50 UTC (rev 41214)
+++ grass/trunk/raster/r.out.png/r.out.png.html	2010-02-28 07:30:25 UTC (rev 41215)
@@ -1,16 +1,21 @@
 <h2>DESCRIPTION</h2>
+<em>r.out.png</em> exports a GRASS raster map in non-georeferenced PNG image
+format, respecting the current region resolution and bounds.
-<em>r.out.png</em> exports a GRASS raster map as non-georeferenced PNG image
-format
 <h2>SEE ALSO</h2>
-<em><a href="r.out.tiff.html">r.out.tiff</a>,</em>
-<em><a href="r.out.ascii.html">r.out.ascii</a></em>
+<em>
+<a href="r.out.gdal.html">r.out.gdal</a>,
+<a href="r.out.tiff.html">r.out.tiff</a>,
+<a href="r.out.ascii.html">r.out.ascii</a>
+</em>
 <h2>AUTHOR</h2>
 Alex Shevlakov
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
