[GRASS-SVN] r41222 - grass/trunk/raster/r.surf.contour
Sun Feb 28 08:12:08 EST 2010
Author: martinl
Date: 2010-02-28 08:12:08 -0500 (Sun, 28 Feb 2010)
New Revision: 41222
   grass/trunk/raster/r.surf.contour/contour.h
   grass/trunk/raster/r.surf.contour/main.c
   grass/trunk/raster/r.surf.contour/read_cell.c
r.surf.contour: use standard options (eliminate G_find_raster())
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h	2010-02-28 13:02:49 UTC (rev 41221)
+++ grass/trunk/raster/r.surf.contour/contour.h	2010-02-28 13:12:08 UTC (rev 41222)
@@ -38,5 +38,5 @@
 int find_con(int, int, double *, double *, CELL *, CELL *);
 /* read_cell.c */
-CELL **read_cell(const char *, const char *);
+CELL **read_cell(const char *);
 void free_cell(CELL **);
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c	2010-02-28 13:02:49 UTC (rev 41221)
+++ grass/trunk/raster/r.surf.contour/main.c	2010-02-28 13:12:08 UTC (rev 41222)
@@ -46,7 +46,7 @@
     CELL con1, con2;
     double d1, d2;
     CELL *alt_row;
-    const char *con_name, *alt_name, *con_mapset;
+    const char *con_name, *alt_name;
     int file_fd;
     CELL value;
     struct History history;
@@ -62,35 +62,21 @@
     module->description =
 	_("Generates surface raster map from rasterized contours.");
-    opt1 = G_define_option();
-    opt1->key = "input";
-    opt1->type = TYPE_STRING;
-    opt1->required = YES;
-    opt1->gisprompt = "old,cell,raster";
-    opt1->description = _("Name of existing raster map containing contours");
+    opt1 = G_define_standard_option(G_OPT_R_INPUT);
+    opt1->description = _("Name of input raster map containing contours");
-    opt2 = G_define_option();
-    opt2->key = "output";
-    opt2->type = TYPE_STRING;
-    opt2->required = YES;
-    opt2->gisprompt = "new,cell,raster";
-    opt2->description = _("Output elevation raster map");
+    opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     con_name = opt1->answer;
     alt_name = opt2->answer;
-    con_mapset = G_find_raster2(con_name, "");
-    if (!con_mapset)
-	G_fatal_error("Contour raster map [%s] not found", con_name);
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
     i_val_l_f = nrows + ncols;
-    con = read_cell(con_name, con_mapset);
+    con = read_cell(con_name);
     alt_row = (CELL *) G_malloc(ncols * sizeof(CELL));
     seen = flag_create(nrows, ncols);
     mask = flag_create(nrows, ncols);
@@ -129,12 +115,13 @@
 	Rast_put_row(file_fd, alt_row, CELL_TYPE);
-    G_percent(r, nrows, 1);
+    G_percent(1, 1, 1);
     free_cell(con);
     flag_destroy(seen);
     flag_destroy(mask);
     Rast_close(file_fd);
     Rast_short_history(alt_name, "raster", &history);
     Rast_command_history(&history);
     Rast_write_history(alt_name, &history);
Modified: grass/trunk/raster/r.surf.contour/read_cell.c
--- grass/trunk/raster/r.surf.contour/read_cell.c	2010-02-28 13:02:49 UTC (rev 41221)
+++ grass/trunk/raster/r.surf.contour/read_cell.c	2010-02-28 13:12:08 UTC (rev 41222)
@@ -2,7 +2,7 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
-CELL **read_cell(const char *name, const char *mapset)
+CELL **read_cell(const char *name)
     int nrows = Rast_window_rows();
     int ncols = Rast_window_cols();
@@ -10,19 +10,19 @@
     int fd;
     int row;
-    fd = Rast_open_old(name, mapset);
+    fd = Rast_open_old(name, "");
     buf = G_malloc((size_t) nrows * ncols * sizeof(CELL));
     idx = G_malloc(nrows * sizeof(CELL *));
     for (row = 0; row < nrows; row++) {
 	idx[row] = &buf[row * ncols];
 	Rast_get_c_row(fd, idx[row], row);
     Rast_close(fd);
     return idx;
@@ -31,4 +31,3 @@
     G_free(idx[0]);
     G_free(idx);
