[GRASS-SVN] r41229 - in grass/trunk/raster: . r.in.png
svn_grass at osgeo.org
Sun Feb 28 13:41:51 EST 2010
Author: glynn
Date: 2010-02-28 13:41:50 -0500 (Sun, 28 Feb 2010)
New Revision: 41229
Added:
grass/trunk/raster/r.in.png/
grass/trunk/raster/r.in.png/Makefile
grass/trunk/raster/r.in.png/r.in.png.c
grass/trunk/raster/r.in.png/r.in.png.html
Resurrect r.in.png from 5.3
Property changes on: grass/trunk/raster/r.in.png
___________________________________________________________________
Added: svn:ignore
+ OBJ.*
Added: grass/trunk/raster/r.in.png/Makefile
--- grass/trunk/raster/r.in.png/Makefile (rev 0)
+++ grass/trunk/raster/r.in.png/Makefile 2010-02-28 18:41:50 UTC (rev 41229)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ../..
+EXTRA_CFLAGS=$(PNGINC)
+LIBES = $(RASTERLIB) $(GISLIB) $(PNGLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(strip $(PNGLIB)),)
+default: cmd
+endif
Added: grass/trunk/raster/r.in.png/r.in.png.c
--- grass/trunk/raster/r.in.png/r.in.png.c (rev 0)
+++ grass/trunk/raster/r.in.png/r.in.png.c 2010-02-28 18:41:50 UTC (rev 41229)
@@ -0,0 +1,559 @@
+ * $Id: r.in.png.c,v 1.11 2002/05/08 10:42:01 glynn Exp $
+ * MODULE: r.in.png
+ * AUTHOR(S): Michael Shapiro - CERL
+ * Alex Shevlakov - sixote at yahoo.com
+ * Glynn Clements
+ * PURPOSE: Import non-georeferenced Images in PNG format.
+ * COPYRIGHT: (C) 2000-2002,2010 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <png.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+typedef struct
+ const char suffix[4];
+ int active;
+ int fd;
+ CELL *buf;
+ FCELL *fbuf;
+ CELL maxval;
+ char name[256];
+} channel;
+#define C_Y 0
+#define C_P 1
+#define C_R 2
+#define C_G 3
+#define C_B 4
+#define C_A 5
+static channel channels[6] = {
+ {".r"},
+ {".g"},
+ {".b"},
+ {".a"}
+static int Header;
+static int Float;
+static char *input, *output, *title;
+static double d_gamma, alpha, t_gamma;
+static int ialpha;
+static png_structp png_ptr;
+static png_infop info_ptr;
+static double gamma_correct(double k)
+ return pow(k, 1.0 / t_gamma);
+static int intensity(double k)
+ return (int) (gamma_correct(k) * 255 + 0.5);
+static int get_byte(png_bytep *pp)
+ return *(*pp)++;
+static int get_png_val(png_bytep *pp, int bit_depth)
+ return (bit_depth == 16)
+ ? (get_byte(pp) << 8) | get_byte(pp)
+ : get_byte(pp);
+static void init_channel(channel *c)
+ sprintf(c->name, "%s%s", output, c->suffix);
+ if (Float)
+ c->fd = Rast_open_fp_new(c->name);
+ c->fbuf = Rast_allocate_f_buf();
+ else
+ c->fd = Rast_open_c_new(c->name);
+ c->buf = Rast_allocate_c_buf();
+ c->active = 1;
+static void write_row_int(png_bytep p)
+ int x, c;
+ channel *ch;
+ for (x = 0; x < info_ptr->width; x++)
+ for (c = 0; c < 6; c++)
+ ch = &channels[c];
+ if (ch->active)
+ ch->buf[x] = (CELL) get_png_val(&p, info_ptr->bit_depth);
+ if (channels[C_A].active && ialpha > 0)
+ if (c != C_A && ch->active)
+ if (channels[C_A].buf[x] <= ialpha)
+ Rast_set_c_null_value(&ch->buf[x], 1);
+ if (ch->active)
+ Rast_put_c_row(ch->fd, ch->buf);
+static void write_row_float(png_bytep p)
+ int x, c;
+ channel *ch;
+ if (ch->active)
+ ch->fbuf[x] = (FCELL) get_png_val(&p, info_ptr->bit_depth)
+ / ch->maxval;
+ if (t_gamma != 1.0)
+ ch->fbuf[x] = gamma_correct(ch->fbuf[x]);
+ if (channels[C_A].fbuf[x] <= alpha)
+ Rast_set_f_null_value(&ch->fbuf[x], 1);
+ if (ch->active)
+ Rast_put_f_row(ch->fd, ch->fbuf);
+static void write_colors_int(int c)
+ channel *ch = &channels[c];
+ CELL i0 = 0;
+ CELL i1 = ch->maxval;
+ struct Colors colors;
+ int i;
+ Rast_init_colors(&colors);
+ if (info_ptr->color_type == PNG_COLOR_TYPE_PALETTE)
+ for (i = 0; i < info_ptr->num_palette; i++)
+ png_colorp col = &info_ptr->palette[i];
+ Rast_set_c_color((CELL) i, col->red, col->green, col->blue, &colors);
+ else if (c == C_A || t_gamma == 1.0)
+ Rast_add_c_color_rule(&i0, 0, 0, 0,
+ &i1, 255, 255, 255,
+ &colors);
+ else
+ for (i = 0; i <= i1; i++)
+ int v = intensity((double) i / i1);
+ Rast_set_c_color((CELL) i, v, v, v, &colors);
+ Rast_write_colors(ch->name, G_mapset(), &colors);
+static void write_colors_float(int c)
+ FCELL i0 = 0.0;
+ FCELL i1 = 1.0;
+ Rast_add_f_color_rule(&i0, 0, 0, 0,
+ &colors);
+static void print_header(void)
+ char gamma_string[80] = "";
+ const char *type_string = "";
+ const char *alpha_string = "";
+ switch (info_ptr->color_type)
+ case PNG_COLOR_TYPE_GRAY:
+ type_string = "gray";
+ alpha_string = "";
+ break;
+ case PNG_COLOR_TYPE_GRAY_ALPHA:
+ alpha_string = "+alpha";
+ break;
+ case PNG_COLOR_TYPE_PALETTE:
+ type_string = "palette";
+ break;
+ case PNG_COLOR_TYPE_RGB:
+ type_string = "truecolor";
+ break;
+ case PNG_COLOR_TYPE_RGB_ALPHA:
+ break;
+ if (info_ptr->valid & PNG_INFO_tRNS)
+ alpha_string = "+transparency";
+ if (info_ptr->valid & PNG_INFO_gAMA)
+ sprintf(gamma_string, ", image gamma = %4.2f", info_ptr->gamma);
+ fprintf(stderr, "%ld x %ld image, %d bit%s %s%s%s%s\n",
+ info_ptr->width, info_ptr->height,
+ info_ptr->bit_depth, info_ptr->bit_depth > 1 ? "s" : "",
+ type_string, alpha_string,
+ gamma_string,
+ info_ptr->interlace_type ? ", Adam7 interlaced" : "");
+static void read_png(void)
+ char sig_buf[8];
+ png_bytep png_buffer;
+ png_bytep *png_rows;
+ int linesize;
+ struct Cell_head cellhd;
+ int y, c;
+ png_color_8p sig_bit;
+ int sbit, interlace;
+ double f_gamma;
+ FILE *ifp;
+ /* initialize input stream and PNG library */
+ ifp = fopen(input, "rb");
+ if (!ifp)
+ G_fatal_error("unable to open PNG file %s", input);
+ if (fread(sig_buf, sizeof(sig_buf), 1, ifp) != 1)
+ G_fatal_error("input file empty or too short");
+ if (png_sig_cmp(sig_buf, 0, sizeof(sig_buf)) != 0)
+ G_fatal_error("input file not a PNG file");
+ png_ptr = png_create_read_struct(PNG_LIBPNG_VER_STRING, NULL, NULL, NULL);
+ if (!png_ptr)
+ G_fatal_error("cannot allocate PNG structure");
+ info_ptr = png_create_info_struct(png_ptr);
+ if (!info_ptr)
+ G_fatal_error("cannot allocate PNG structures");
+ if (setjmp(png_jmpbuf(png_ptr)))
+ G_fatal_error("PNG error");
+ png_init_io(png_ptr, ifp);
+ png_set_sig_bytes(png_ptr, sizeof(sig_buf));
+ png_read_info(png_ptr, info_ptr);
+ if (Header || G_verbose() == G_verbose_max())
+ print_header();
+ if (Header)
+ fclose(ifp);
+ exit(0);
+ /* read image parameters and set up data conversions */
+ if (png_get_bit_depth(png_ptr, info_ptr) < 8)
+ png_set_packing(png_ptr);
+ sbit = png_get_sBIT(png_ptr, info_ptr, &sig_bit);
+ if (sbit)
+ png_set_shift(png_ptr, sig_bit);
+ if (!png_get_gAMA(png_ptr, info_ptr, &f_gamma))
+ f_gamma = 0.0;
+ if (png_get_valid(png_ptr, info_ptr, PNG_INFO_tRNS))
+ png_set_tRNS_to_alpha(png_ptr);
+ if (Float && info_ptr->color_type == PNG_COLOR_TYPE_PALETTE)
+ png_set_palette_to_rgb(png_ptr);
+ png_read_update_info(png_ptr, info_ptr);
+ interlace = (info_ptr->interlace_type != PNG_INTERLACE_NONE);
+ ialpha = (int) (alpha * channels[C_A].maxval);
+ t_gamma = (f_gamma != 0.0 && d_gamma != 0.0)
+ ? f_gamma * d_gamma
+ : 1.0;
+ /* allocate input buffer */
+ linesize = png_get_rowbytes(png_ptr, info_ptr);
+ png_buffer = G_malloc(interlace
+ ? info_ptr->height * linesize
+ : linesize);
+ if (interlace)
+ png_rows = G_malloc(info_ptr->height * sizeof(png_bytep));
+ for (y = 0; y < info_ptr->height; y++)
+ png_rows[y] = png_buffer + y * linesize;
+ /* initialize cell header */
+ Rast_get_window(&cellhd);
+ cellhd.rows = info_ptr->height;
+ cellhd.cols = info_ptr->width;
+ cellhd.north = cellhd.rows;
+ cellhd.south = 0.0;
+ cellhd.east = cellhd.cols;
+ cellhd.west = 0.0;
+ cellhd.ns_res = 1;
+ cellhd.ew_res = 1;
+ Rast_set_window(&cellhd);
+ /* initialize channel information */
+ init_channel(&channels[C_Y]);
+ break;
+ init_channel(&channels[C_A]);
+ break;
+ init_channel(&channels[C_P]);
+ break;
+ init_channel(&channels[C_R]);
+ init_channel(&channels[C_G]);
+ init_channel(&channels[C_B]);
+ break;
+ break;
+ if (sbit)
+ channels[C_R].maxval = (1 << sig_bit->red ) - 1;
+ channels[C_G].maxval = (1 << sig_bit->green) - 1;
+ channels[C_B].maxval = (1 << sig_bit->blue ) - 1;
+ channels[C_Y].maxval = (1 << sig_bit->gray ) - 1;
+ channels[C_A].maxval = (1 << sig_bit->alpha) - 1;
+ else
+ channels[C_R].maxval = (1 << info_ptr->bit_depth) - 1;
+ channels[C_G].maxval = (1 << info_ptr->bit_depth) - 1;
+ channels[C_B].maxval = (1 << info_ptr->bit_depth) - 1;
+ channels[C_Y].maxval = (1 << info_ptr->bit_depth) - 1;
+ channels[C_A].maxval = (1 << info_ptr->bit_depth) - 1;
+ /* read image and write raster layers */
+ if (interlace)
+ png_read_image(png_ptr, png_rows);
+ png_bytep p;
+ if (interlace)
+ p = png_rows[y];
+ else
+ png_read_row(png_ptr, png_buffer, NULL);
+ p = png_buffer;
+ if (Float)
+ write_row_float(p);
+ else
+ write_row_int(p);
+ png_read_end(png_ptr, NULL);
+ fclose(ifp);
+ /* close output files */
+ if (!ch->active)
+ continue;
+ Rast_close(ch->fd);
+ if (Float)
+ G_free(ch->fbuf);
+ else
+ G_free(ch->buf);
+ /* write title and color table */
+ G_verbose_message(_("Creating support files for <%s>"), output);
+ if (!ch->active)
+ continue;
+ if (title && *title)
+ Rast_put_cell_title(ch->name, title);
+ if (Float)
+ write_colors_float(c);
+ else
+ write_colors_int(c);
+ G_free(png_buffer);
+ if (interlace)
+ G_free(png_rows);
+ png_destroy_read_struct(&png_ptr, &info_ptr, NULL);
+int main(int argc, char *argv[])
+ struct Option *inopt, *outopt, *titleopt, *gammaopt, *alphaopt;
+ struct Flag *fflag, *hflag;
+ struct GModule *module;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description = "Import non-georeferenced PNG format image.";
+ inopt = G_define_standard_option(G_OPT_F_INPUT);
+ outopt = G_define_standard_option(G_OPT_R_OUTPUT);
+ titleopt = G_define_option();
+ titleopt->key = "title";
+ titleopt->type = TYPE_STRING;
+ titleopt->required = NO;
+ titleopt->description = _("Title for new raster file.");
+ gammaopt = G_define_option();
+ gammaopt->key = "gamma";
+ gammaopt->type = TYPE_DOUBLE;
+ gammaopt->required = NO;
+ gammaopt->description = _("Display gamma.");
+ alphaopt = G_define_option();
+ alphaopt->key = "alpha";
+ alphaopt->type = TYPE_DOUBLE;
+ alphaopt->required = NO;
+ alphaopt->description = _("Alpha threshold.");
+ fflag = G_define_flag();
+ fflag->key = 'f';
+ fflag->description = _("Create floating-point maps (0.0 - 1.0).");
+ hflag = G_define_flag();
+ hflag->key = 'h';
+ hflag->description = _("Output image file header only.");
+ if(G_parser(argc, argv))
+ exit(1);
+ input = inopt->answer;
+ output = outopt->answer;
+ title = titleopt->answer;
+ d_gamma = gammaopt->answer ? atof(gammaopt->answer) : 0.0;
+ alpha = alphaopt->answer ? atof(alphaopt->answer) : -1.0;
+ Float = fflag->answer;
+ Header = hflag->answer;
+ read_png();
+ return 0;
Added: grass/trunk/raster/r.in.png/r.in.png.html
--- grass/trunk/raster/r.in.png/r.in.png.html (rev 0)
+++ grass/trunk/raster/r.in.png/r.in.png.html 2010-02-28 18:41:50 UTC (rev 41229)
@@ -0,0 +1,20 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.png</em> imports a PNG image as a GRASS raster map.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.out.gdal.html">r.in.gdal</a>,
+<a href="r.out.tiff.html">r.out.png</a>,
+</em>
+<h2>AUTHORS</h2>
+Michael Shapiro
+Alex Shevlakov
+Glynn Clements
+<p>
+<i>Last changed: $Date: 2010-02-28 07:30:25 +0000 (Sun, 28 Feb 2010) $</i>
