[GRASS-SVN] r40174 - grass/trunk/visualization/nviz/scripts
svn_grass at osgeo.org
Fri Jan 1 11:37:46 EST 2010
Author: hamish
Date: 2010-01-01 11:37:45 -0500 (Fri, 01 Jan 2010)
New Revision: 40174
grass/trunk/visualization/nviz/scripts/config.tcl
grass/trunk/visualization/nviz/scripts/widgets.tcl
less saturated ui colors (merge from devbr6)
Modified: grass/trunk/visualization/nviz/scripts/config.tcl
--- grass/trunk/visualization/nviz/scripts/config.tcl 2010-01-01 16:35:40 UTC (rev 40173)
+++ grass/trunk/visualization/nviz/scripts/config.tcl 2010-01-01 16:37:45 UTC (rev 40174)
@@ -83,7 +83,7 @@
option add *font -*-helvetica-medium-r-normal-*-12-*-iso8859-1 widgetDefault
option add *Label.font -*-helvetica-bold-r-normal-*-12-*-iso8859-1
option add *label.font -*-helvetica-medium-r-normal-*-12-*-iso8859-1
-option add *Label.foreground "medium blue"
+option add *Label.foreground "#226333"
option add *label.foreground "black"
option add *Radiobutton.relief flat
option add *Checkbutton.relief flat
@@ -106,6 +106,3 @@
option add *menubutton.borderwidth 1
option add *button.borderWidth 1
Modified: grass/trunk/visualization/nviz/scripts/widgets.tcl
--- grass/trunk/visualization/nviz/scripts/widgets.tcl 2010-01-01 16:35:40 UTC (rev 40173)
+++ grass/trunk/visualization/nviz/scripts/widgets.tcl 2010-01-01 16:37:45 UTC (rev 40174)
@@ -29,7 +29,7 @@
set y [$c canvasy $y]
if { $item == "puck"} {
$c delete line
- $c create line $x $y [expr $w/2] [expr $h/2] -fill green3 -arrow last -tags line
+ $c create line $x $y [expr $w/2] [expr $h/2] -fill gray70 -arrow last -tags line
$c move $item [expr $x-$lastx] [expr $y-$lasty]
St_set $info lastx $x
@@ -72,14 +72,14 @@
$C create text [expr $width/2] 2 -text N -fill black -anchor n
$C create text [expr $width/2] $height -text S -fill black -anchor s
$C create line $x $y [expr $width/2] [expr $height/2] -tags line \
- -fill green3 -arrow last
- $C create oval $x1 $y1 $x2 $y2 -width 1 -outline green3 -fill green3 \
+ -fill gray70 -arrow last
+ $C create oval $x1 $y1 $x2 $y2 -width 1 -outline gray70 -fill LightGoldenrod \
-tags puck
} else {
$C create line [expr 0 -$width] $x [expr 2 * $width] $x \
- -width 1 -tags cross -fill green3
+ -width 1 -tags cross -fill gray70
$C create line $y [expr 0 - $height] $y [expr 2*$height] \
if {[string compare $name null] == 0} {set name $C.item}
set Nv_($name) [St_create {item lastx lasty width height} $type $x $y $width $height]
