[GRASS-SVN] r40183 - grass-addons/vector/v.in.mbsys_fnv
Sat Jan 2 07:12:55 EST 2010
Author: hamish
Date: 2010-01-02 07:12:54 -0500 (Sat, 02 Jan 2010)
New Revision: 40183
   grass-addons/vector/v.in.mbsys_fnv/description.html
   grass-addons/vector/v.in.mbsys_fnv/v.in.mbsys_fnv
ready for testing
Modified: grass-addons/vector/v.in.mbsys_fnv/description.html
--- grass-addons/vector/v.in.mbsys_fnv/description.html	2010-01-02 11:21:13 UTC (rev 40182)
+++ grass-addons/vector/v.in.mbsys_fnv/description.html	2010-01-02 12:12:54 UTC (rev 40183)
@@ -1,23 +1,60 @@
 <H2>DESCRIPTION</H2>
+This module will import <tt>.fnv</tt> format navigation files generated
+by <a href="http://www.ldeo.columbia.edu/res/pi/MB-System/">MB-System</a>.
+Ship's track and swath coverage information may be imported in a number
+of different ways.
 <H2>NOTES</H2>
+Geodesic line length/swath width (in meters) is provided for the <i>track</i>
+line and <i>scanline</i> types, and geodesic area (in square meters) is given
+for the swath coverage type.
+<P>
+The databases for <i>port_trk</i> and <i>stbd_trk</i> line maps contain
+the ship's <i>center track line</i> lat/lon starting and ending position,
+not the starting and ending position of the outward beams. Positions
+for the start and end points of the outward beams are encoded in the
+map data and may be extracted with e.g. the <em>v.to.db</em> module.
+<H2>EXAMPLE</H2>
+The <em>v.patch</em> module can be used to group many scan lines together
+into the same map.
+<div class="code"><pre>
+COUNT=0
+for TRACK in `cut -f1 survey-datalines.txt` ; do
+   COUNT=`expr $COUNT + 1`
+   v.in.mbsys_fnv in="${TRACK}.fnv" out=trk_"`basename $TRACK`" type=track cat=$COUNT
+done
+v.patch -e in=`g.mlist vect=trk_* sep=,` out=all_tracks bbox=all_tracks_bbox
+</pre></div>
 <H2>SEE ALSO</H2>
 <em>
 <A HREF="v.in.ascii.html">v.in.ascii</A><br>
 <A HREF="v.in.mapgen.html">v.in.mapgen</A><br>
-<A HREF="r.in.xyz.html">r.in.xyz</A>
+<A HREF="r.in.xyz.html">r.in.xyz</A><br>
+<A HREF="v.patch.html">v.patch</A><br>
+<A HREF="v.to.db.html">v.to.db</A>
 </em>
+<BR><BR>
+<a href="http://www.ldeo.columbia.edu/res/pi/MB-System/">MB-System</a>
+ software for multibeam and sidescan sonar processing
 <H2>AUTHOR</H2>
 Hamish Bowman<BR>
-Dunedin, New Zealand
+<i>Dept. Marine Science<br>
+University of Otago<br>
+Dunedin, New Zealand</i>
+<BR>
 <p>
 <i>Last changed: $Date$</i>
Modified: grass-addons/vector/v.in.mbsys_fnv/v.in.mbsys_fnv
--- grass-addons/vector/v.in.mbsys_fnv/v.in.mbsys_fnv	2010-01-02 11:21:13 UTC (rev 40182)
+++ grass-addons/vector/v.in.mbsys_fnv/v.in.mbsys_fnv	2010-01-02 12:12:54 UTC (rev 40183)
@@ -130,6 +130,22 @@
 trap 'cleanup' 2 3 15
+SCAN_COLUMN_DEF="timestamp VARCHAR(30), unix_time DOUBLE PRECISION, \
+    center_lon DOUBLE PRECISION, center_lat DOUBLE PRECISION, \
+    headng_deg DOUBLE PRECISION, velo_km_hr DOUBLE PRECISION, \
+    tdrdepth_m DOUBLE PRECISION, roll_degr DOUBLE PRECISION, \
+    pitch_degr DOUBLE PRECISION, heave_m DOUBLE PRECISION"
+PT_COLUMN_DEF="port_lon DOUBLE PRECISION, port_lat DOUBLE PRECISION, \
+    stbd_lon DOUBLE PRECISION, stbd_lat DOUBLE PRECISION"
+LINE_COLUMN_DEF="cat INTEGER, filename VARCHAR(255), start_time VARCHAR(30), \
+    end_time VARCHAR(30), start_lat DOUBLE PRECISION, \
+    start_lon DOUBLE PRECISION, end_lat DOUBLE PRECISION, \
+    end_lon DOUBLE PRECISION"
 cat "$GIS_OPT_INPUT" | cut -f3-4 > "$TMP.trk"
 cat "$GIS_OPT_INPUT" | cut -f12,14 > "$TMP.port.trk"
 cat "$GIS_OPT_INPUT" | cut -f16,18 > "$TMP.stbd.trk"
@@ -137,9 +153,14 @@
 if [ -z "$GRASS_VERBOSE" ] ; then
     GRASS_VERBOSE=0
     export GRASS_VERBOSE
+    VERBOSE_PRESET=false
+else
+    VERBOSE_PRESET=true
 fi
-# import vector coordinates
+#### import vector coordinates ####
 case "$GIS_OPT_TYPE" in
     track)
 	v.in.mapgen -f in="$TMP.trk" out="tmp_v_in_fnv_$$_1"
@@ -187,8 +208,9 @@
 	# and yet... something's wrong.
     track_pts)
-	v.in.ascii in="$GIS_OPT_INPUT" out="$GIS_OPT_OUTPUT" x=3 y=4 fs=tab \
-	    columns="$COLUMN_DEF"
+	tr -s '\t' '|' < "$GIS_OPT_INPUT" | v.in.ascii \
+	    out="$GIS_OPT_OUTPUT" x=3 y=4 fs='|' \
+	    columns="$SCAN_COLUMN_DEF, $PT_COLUMN_DEF"
     all_pts)
 	 awk 'BEGIN { R=0 }
@@ -196,14 +218,20 @@
            "$GIS_OPT_INPUT" > "${TMP}_all.pts"
 	v.in.ascii in="${TMP}_all.pts" out="$GIS_OPT_OUTPUT" x=3 y=4 fs=tab \
-	    columns='scanline integer, side varchar(6), lon double precision, lat double precision'
+	    columns='scanline INTEGER, side VARCHAR(6), lon DOUBLE PRECISION, lat DOUBLE PRECISION'
 esac
+if [ $? -ne 0 ] ; then
+    g.message -e "Import failed."
+    cleanup
+    exit 1
+fi
-#### attach attributes
-# see v.in.garmin for example
+#### attach attributes ####
 START_TIME=`head -n 1 "$GIS_OPT_INPUT" | cut -f1`
 END_TIME=`tail -n 1 "$GIS_OPT_INPUT" | cut -f1`
 START_LAT=`head -n 1 "$TMP.trk" | cut -f2`
@@ -211,11 +239,6 @@
 START_LON=`head -n 1 "$TMP.trk" | cut -f1`
 END_LON=`tail -n 1 "$TMP.trk" | cut -f1`
-SCAN_COLUMN_DEF='cat INTEGER, timestamp VARCHAR(21), unix_time DOUBLE PRECISION, center_lon DOUBLE PRECISION, center_lat DOUBLE PRECISION, headng_deg DOUBLE PRECISION, velo_km_hr DOUBLE PRECISION, trn_dept_m DOUBLE PRECISION, roll_degr DOUBLE PRECISION, pitch_degr DOUBLE PRECISION, heave_m DOUBLE PRECISION'
-PT_COLUMN_DEF='port_lon DOUBLE PRECISION, port_lat DOUBLE PRECISION, stbd_lon DOUBLE PRECISION, stbd_lat DOUBLE PRECISION'
-LINE_COLUMN_DEF='cat INTEGER, filename VARCHAR(255), start_time VARCHAR(30), end_time VARCHAR(30), start_lat DOUBLE PRECISION, start_lon DOUBLE PRECISION, end_lat DOUBLE PRECISION, end_lon DOUBLE PRECISION'
 # Start/end points for port & stbd tracks refer to the ship's start/end points,
 #  not the outward beam's (that data is stored in the coords if you really
 #  want at it).
@@ -239,28 +262,14 @@
 esac
-case "$GIS_OPT_TYPE" in
-    scanlines | track_pts | all_pts)
-	v.db.addtable map="$GIS_OPT_OUTPUT" columns="$SCAN_COLUMN_DEF"
-	echo "DELETE FROM $GIS_OPT_OUTPUT" | db.execute
-	###cat "$GIS_OPT_INPUT" | awk '{print $1 $2 $3 ...}' | db.execute
+    cleanup
+    exit 1
+fi
-	#echo "INSERT INTO  $GIS_OPT_OUTPUT  VALUES \
-	#  ($GIS_OPT_CAT, '`basename $GIS_OPT_INPUT`', '$START_TIME', \
-	#   '$END_TIME', $START_LAT, $START_LON, $END_LAT, $END_LON)" \
-	#   | db.execute
-esac
-    track_pts | all_pts)
-	v.db.addcol map="$GIS_OPT_OUTPUT" columns="$PT_COLUMN_DEF"
-	# paste  "$TMP.port.trk" "$TMP.stbd.trk" | sed | db.execute
-esac
     track)
 	v.db.update map="$GIS_OPT_OUTPUT" column="side" value='center'
@@ -269,32 +278,48 @@
 	    units=meters column=length_m
 	TRK_LENGTH=`v.db.select -c map="$GIS_OPT_OUTPUT" col=length_m`
 	v.support -r map="$GIS_OPT_OUTPUT" \
-	    map_name="Ship's track began $START_TIME and travelled $TRK_LENGTH meters"
+	    map_name="Ship's track for `basename $GIS_OPT_INPUT`" \
+	    comment="Track began $START_TIME and travelled $TRK_LENGTH meters"
     port_trk)
 	v.db.update map="$GIS_OPT_OUTPUT" column="side" value='port'
-	    map_name="Outward end of port beam beginning $START_TIME"
+	    map_name="Port beam extent of `basename $GIS_OPT_INPUT`" \
+	    comment="Outward end of port beam beginning $START_TIME"
     stbd_trk)
 	v.db.update map="$GIS_OPT_OUTPUT" column="side" value='stbd'
-	    map_name="Outward end of stbd beam beginning $START_TIME"
+	    map_name="Starboard beam extent of `basename $GIS_OPT_INPUT`" \
+	    comment="Outward end of stbd beam beginning $START_TIME"
     scanlines)
 	# 1 entry per line of .fnv. No need for endpoints, already encoded.
-	# includes time, roll, pitch, etc, width!
+	# includes time, roll, pitch, etc, and we add line width with v.to.db.
+	v.db.addtable map="$GIS_OPT_OUTPUT" \
+	   columns="cat INTEGER, $SCAN_COLUMN_DEF"
+	echo "DELETE FROM $GIS_OPT_OUTPUT" | db.execute
+	awk -F'\t' -v NAME="$GIS_OPT_OUTPUT" 'BEGIN{ R = 0 }
+	   { R++;
+	     printf("INSERT INTO %s VALUES (%d, ^%s^, %.3f, %s, %s, %s, %s, %s, %s, %s, %s);\n",
+		    NAME, R, $1, $2, $3, $4, $5, $6, $7, $8, $9, $10) }' \
+	     "$GIS_OPT_INPUT" | tr '^' \' | db.execute
+	v.db.addcol map="$GIS_OPT_OUTPUT" columns="width_m DOUBLE PRECISION"
+	if [ "$VERBOSE_PRESET" = "true" ] ; then
+	    v.to.db map="$GIS_OPT_OUTPUT" type=line option=length \
+		units=meters column=width_m
+	else
+	    GRASS_VERBOSE=2 \
+	fi
-    	v.db.addcol map="$GIS_OPT_OUTPUT" \
-	    columns="width_m DOUBLE PRECISION"
-	v.to.db map="$GIS_OPT_OUTPUT" type=line option=length \
-	    units=meters column=width_m
-	    map_name="Scanlines for `basename $GIS_OPT_INPUT`"
+	    map_name="Scanlines for `basename $GIS_OPT_INPUT`" \
+	    comment="Track began at $START_TIME"
     swath)
 	v.db.addcol map="$GIS_OPT_OUTPUT" columns="area_sq_m DOUBLE PRECISION"
@@ -305,19 +330,23 @@
     track_pts)
-	#v.db.addcol map="$GIS_OPT_OUTPUT" columns="filename varchar(255)"
-	#  $COLUMN_DEF
-	    map_name="Ship's track for `basename $GIS_OPT_INPUT`"
     all_pts)
+	v.db.dropcol map="$GIS_OPT_OUTPUT" column="lat"
+	v.db.dropcol map="$GIS_OPT_OUTPUT" column="lon"
-	    map_name="Ship's track and beam ends for `basename $GIS_OPT_INPUT`"
+	    map_name="Ship's track & beam ends for `basename $GIS_OPT_INPUT`" \
 esac
+EXITCODE=$?
 cleanup
-exit
+exit $EXITCODE
