[GRASS-SVN] r40188 - in grass/trunk/vector: v.buffer v.build
v.category v.extract v.out.ogr v.overlay v.select v.split
v.surf.idw v.surf.rst v.to.3d v.to.db v.to.points v.to.rast
v.to.rast3 v.transform v.type v.univar v.what
svn_grass at osgeo.org
Sat Jan 2 09:08:18 EST 2010
Author: martinl
Date: 2010-01-02 09:08:18 -0500 (Sat, 02 Jan 2010)
New Revision: 40188
grass/trunk/vector/v.buffer/main.c
grass/trunk/vector/v.build/main.c
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.out.ogr/main.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.select/args.c
grass/trunk/vector/v.split/main.c
grass/trunk/vector/v.surf.idw/main.c
grass/trunk/vector/v.surf.idw/proto.h
grass/trunk/vector/v.surf.idw/read_sites.c
grass/trunk/vector/v.surf.rst/main.c
grass/trunk/vector/v.to.3d/args.c
grass/trunk/vector/v.to.3d/local_proto.h
grass/trunk/vector/v.to.3d/main.c
grass/trunk/vector/v.to.3d/trans2.c
grass/trunk/vector/v.to.3d/trans3.c
grass/trunk/vector/v.to.db/main.c
grass/trunk/vector/v.to.db/parse.c
grass/trunk/vector/v.to.points/main.c
grass/trunk/vector/v.to.rast/local.h
grass/trunk/vector/v.to.rast/main.c
grass/trunk/vector/v.to.rast/vect2rast.c
grass/trunk/vector/v.to.rast3/main.c
grass/trunk/vector/v.transform/creat_trans.c
grass/trunk/vector/v.transform/local_proto.h
grass/trunk/vector/v.transform/main.c
grass/trunk/vector/v.transform/trans_digit.c
grass/trunk/vector/v.type/main.c
grass/trunk/vector/v.univar/main.c
grass/trunk/vector/v.what/main.c
grass/trunk/vector/v.what/what.c
grass/trunk/vector/v.what/what.h
OGR support (read)
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.buffer/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -150,16 +150,17 @@
_("Creates a buffer around vector features of given type.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
- out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ field_opt->guisection = _("Selection");
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,area";
type_opt->answer = "point,line,area";
type_opt->guisection = _("Selection");
- field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
- field_opt->guisection = _("Selection");
+ out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
dista_opt = G_define_option();
dista_opt->key = "distance";
dista_opt->type = TYPE_DOUBLE;
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.build/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -34,7 +34,7 @@
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("topology"));
- module->description = _("Creates topology for GRASS vector map.");
+ module->description = _("Creates topology for vector map.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.category/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -75,6 +75,17 @@
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->multiple = YES;
+ type_opt = G_define_standard_option(G_OPT_V3_TYPE);
+ type_opt->guisection = _("Selection");
+ id_opt = G_define_standard_option(G_OPT_V_IDS);
+ id_opt->label = _("Feature ids (by default all features are processed)");
+ id_opt->guisection = _("Selection");
out_opt->required = NO;
@@ -91,18 +102,7 @@
"sum;add the value specified by cat option to the current category value;"
"report;print report (statistics), in shell style: layer type count min max;"
"print;print category values, more cats in the same layer are separated by '/'");
- type_opt = G_define_standard_option(G_OPT_V3_TYPE);
- type_opt->guisection = _("Selection");
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
- field_opt->multiple = YES;
- id_opt = G_define_standard_option(G_OPT_V_IDS);
- id_opt->label = _("Feature ids (by default all features are processed)");
- id_opt->guisection = _("Selection");
cat_opt = G_define_standard_option(G_OPT_V_CAT);
cat_opt->answer = "1";
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.extract/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -109,24 +109,24 @@
inopt = G_define_standard_option(G_OPT_V_INPUT);
- outopt = G_define_standard_option(G_OPT_V_OUTPUT);
+ fieldopt = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ fieldopt->guisection = _("Selection");
typopt = G_define_standard_option(G_OPT_V_TYPE);
typopt->answer = "point,line,boundary,centroid,area,face";
typopt->options = "point,line,boundary,centroid,area,face";
typopt->label = _("Types to be extracted");
typopt->guisection = _("Selection");
- fieldopt = G_define_standard_option(G_OPT_V_FIELD_ALL);
- fieldopt->guisection = _("Selection");
listopt = G_define_standard_option(G_OPT_V_CATS);
listopt->key = "list";
listopt->guisection = _("Selection");
whereopt = G_define_standard_option(G_OPT_DB_WHERE);
whereopt->guisection = _("Selection");
+ outopt = G_define_standard_option(G_OPT_V_OUTPUT);
fileopt = G_define_standard_option(G_OPT_F_INPUT);
fileopt->key = "file";
fileopt->required = NO;
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.out.ogr/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -302,22 +302,34 @@
/* check if the map is 3d */
if (Vect_is_3d(&In)) {
- /* specific check for shp */
+ /* specific check for ESRI ShapeFile */
if (strcmp(options.format->answer, "ESRI_Shapefile") == 0) {
const char *shpt;
shpt = CSLFetchNameValue(papszLCO, "SHPT");
if (!shpt || shpt[strlen(shpt) - 1] != 'Z') {
G_warning(_("Vector map <%s> is 3D. "
- "Use format specific layer creation options (parameter 'lco') "
+ "Use format specific layer creation options SHPT (parameter 'lco') "
"to export in 3D rather than 2D (default)"),
options.input->answer);
+ /* specific check for PostgreSQL */
+ else if (strcmp(options.format->answer, "PostgreSQL") == 0) {
+ const char *dim;
+ dim = CSLFetchNameValue(papszLCO, "DIM");
+ if (!dim || strcmp(dim, "3") != 0) {
+ G_warning(_("Vector map <%s> is 3D. "
+ "Use format specific layer creation options DIM (parameter 'lco') "
+ "to export in 3D rather than 2D (default)."),
+ options.input->answer);
else {
- "to export in 3D rather than 2D (default)"),
@@ -578,7 +590,6 @@
Points->z[0]);
else { /* GV_LINE or GV_BOUNDARY */
Ogr_geometry = OGR_G_CreateGeometry(wkbLineString);
for (j = 0; j < Points->n_points; j++) {
OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.overlay/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -63,30 +63,30 @@
in_opt[0]->label = _("Name of input vector map (A)");
in_opt[0]->key = "ainput";
+ field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt[0]->label = _("Layer number or name (vector map A)");
+ field_opt[0]->key = "alayer";
type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
type_opt[0]->label = _("Feature type (vector map A)");
type_opt[0]->key = "atype";
type_opt[0]->options = "line,area";
type_opt[0]->answer = "area";
- field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
- field_opt[0]->label = _("Layer number or name (vector map A)");
- field_opt[0]->key = "alayer";
in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
in_opt[1]->label = _("Name of input vector map (B)");
in_opt[1]->key = "binput";
+ field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt[1]->label = _("Layer number or name (vector map B)");
+ field_opt[1]->key = "blayer";
type_opt[1] = G_define_standard_option(G_OPT_V_TYPE);
type_opt[1]->label = _("Feature type (vector map B)");
type_opt[1]->key = "btype";
type_opt[1]->options = "area";
type_opt[1]->answer = "area";
- field_opt[1] = G_define_standard_option(G_OPT_V_FIELD);
- field_opt[1]->label = _("Layer number or name (vector map B)");
- field_opt[1]->key = "blayer";
operator_opt = G_define_option();
operator_opt->key = "operator";
operator_opt->type = TYPE_STRING;
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.select/args.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -10,30 +10,30 @@
parm->input[0]->description = _("Name of input vector map (A)");
parm->input[0]->key = "ainput";
+ parm->field[0] = G_define_standard_option(G_OPT_V_FIELD);
+ parm->field[0]->label = _("Layer number (vector map A)");
+ parm->field[0]->key = "alayer";
+ parm->field[0]->guisection = _("Selection");
parm->type[0] = G_define_standard_option(G_OPT_V_TYPE);
parm->type[0]->label = _("Feature type (vector map A)");
parm->type[0]->key = "atype";
parm->type[0]->guisection = _("Selection");
- parm->field[0] = G_define_standard_option(G_OPT_V_FIELD);
- parm->field[0]->label = _("Layer number (vector map A)");
- parm->field[0]->key = "alayer";
- parm->field[0]->guisection = _("Selection");
parm->input[1] = G_define_standard_option(G_OPT_V_INPUT);
parm->input[1]->description = _("Name of input vector map (B)");
parm->input[1]->key = "binput";
+ parm->field[1] = G_define_standard_option(G_OPT_V_FIELD);
+ parm->field[1]->label = _("Layer number (vector map B)");
+ parm->field[1]->key = "blayer";
+ parm->field[1]->guisection = _("Selection");
parm->type[1] = G_define_standard_option(G_OPT_V_TYPE);
parm->type[1]->label = _("Feature type (vector map B)");
parm->type[1]->key = "btype";
parm->type[1]->guisection = _("Selection");
- parm->field[1] = G_define_standard_option(G_OPT_V_FIELD);
- parm->field[1]->label = _("Layer number (vector map B)");
- parm->field[1]->key = "blayer";
- parm->field[1]->guisection = _("Selection");
parm->output = G_define_standard_option(G_OPT_V_OUTPUT);
parm->operator = G_define_option();
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.split/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -4,19 +4,21 @@
* MODULE: v.split
* AUTHOR(S): Radim Blazek
+ * OGR support by Martin Landa <landa.martin gmail.com>
* PURPOSE: Split lines to segments
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
#include <stdlib.h>
#include <math.h>
#include <grass/gis.h>
#include <grass/vector.h>
#include <grass/glocale.h>
@@ -24,15 +26,13 @@
int main(int argc, char *argv[])
struct GModule *module;
- struct Option *in_opt, *out_opt, *length_opt, *vertices_opt;
- /* struct Option *layer_opt; */
+ struct Option *in_opt, *layer_opt, *out_opt, *length_opt, *vertices_opt;
struct Map_info In, Out;
struct line_pnts *Points, *Points2;
struct line_cats *Cats;
- /* int layer; */
- int line, nlines;
+ int line, nlines, layer;
double length;
int vertices;
@@ -41,34 +41,34 @@
G_add_keyword(_("geometry"));
- module->description = "Split lines to shorter segments.";
+ module->description = _("Splits vector lines to shorter segments.");
+ in_opt = G_define_standard_option(G_OPT_V_INPUT);
- in_opt = G_define_standard_option(G_OPT_V_INPUT);
+ layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
- /* layer_opt = G_define_standard_option(G_OPT_V_FIELD); */
length_opt = G_define_option();
length_opt->key = "length";
length_opt->type = TYPE_DOUBLE;
length_opt->required = NO;
length_opt->multiple = NO;
- length_opt->description = "Maximum segment length.";
+ length_opt->description = _("Maximum segment length");
vertices_opt = G_define_option();
vertices_opt->key = "vertices";
vertices_opt->type = TYPE_INTEGER;
vertices_opt->required = NO;
vertices_opt->multiple = NO;
- vertices_opt->description = "Maximum number of vertices in segment.";
+ vertices_opt->description = _("Maximum number of vertices in segment");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* layer = atoi ( layer_opt->answer ); */
if ((length_opt->answer && vertices_opt->answer) ||
!(length_opt->answer || vertices_opt->answer))
- G_fatal_error("Use either length or vertices");
+ G_fatal_error(_("Use either length or vertices"));
if (length_opt->answer)
length = atof(length_opt->answer);
@@ -76,16 +76,19 @@
if (vertices_opt->answer) {
vertices = atoi(vertices_opt->answer);
if (vertices < 2)
- G_fatal_error("Number of vertices must be at least 2");
+ G_fatal_error(_("Number of vertices must be at least 2"));
Vect_set_open_level(2);
- Vect_open_old(&In, in_opt->answer, "");
- Vect_open_new(&Out, out_opt->answer, 0);
+ Vect_open_old2(&In, in_opt->answer, "", layer_opt->answer);
+ layer = Vect_get_field_number(&In, layer_opt->answer);
+ Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In));
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
Points = Vect_new_line_struct();
Points2 = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -99,6 +102,9 @@
ltype = Vect_read_line(&In, Points, Cats, line);
+ if (layer != -1 && !Vect_cat_get(Cats, layer, NULL))
+ continue;
if (ltype & GV_LINES) {
if (length_opt->answer) {
double l, from, to, step;
@@ -128,9 +134,8 @@
ret = Vect_line_segment(Points, from, to, Points2);
if (ret == 0) {
- G_warning
- ("Cannot make line segment: %f - %f (line length = %f)",
- from, to, l);
+ G_warning(_("Unable to make line segment: %f - %f (line length = %f)"),
+ from, to, l);
continue;
@@ -186,6 +191,6 @@
Vect_close(&In);
Vect_build(&Out);
Vect_close(&Out);
- exit(0);
+ exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.surf.idw/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -7,12 +7,14 @@
* points outside current region) by Paul Kelly
* further: Radim Blazek <radim.blazek gmail.com>, Huidae Cho <grass4u gmail.com>,
* Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
- * PURPOSE:
- * COPYRIGHT: (C) 2003-2006 by the GRASS Development Team
+ * PURPOSE: Surface interpolation from vector point data by Inverse
+ * Distance Squared Weighting
+ * COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
#include <stdlib.h>
@@ -20,6 +22,7 @@
#include <grass/raster.h>
+#include "proto.h"
int search_points = 12;
@@ -43,12 +46,7 @@
struct Point *noidxpoints = NULL;
struct list_Point *list;
static struct Cell_head window;
-void calculate_distances(int, int, double, double, int *);
-void calculate_distances_noindex(double, double);
-/* read_sites.c */
-void read_sites(char *, int, char *, int);
int fd, maskfd;
@@ -63,7 +61,7 @@
double north, east;
double dist;
double sum1, sum2, interp_value;
- int n, field;
+ int n;
struct
struct Option *input, *npoints, *output, *dfield, *col;
@@ -85,6 +83,7 @@
+ G_add_keyword(_("surface"));
G_add_keyword(_("interpolation"));
_("Surface interpolation from vector point data by Inverse "
@@ -92,6 +91,12 @@
parm.input = G_define_standard_option(G_OPT_V_INPUT);
+ parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
+ parm.col = G_define_standard_option(G_OPT_DB_COLUMN);
+ parm.col->required = NO;
+ parm.col->description = _("Name of attribute column with values to interpolate");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.npoints = G_define_option();
@@ -102,44 +107,32 @@
parm.npoints->description = _("Number of interpolation points");
parm.npoints->answer = "12";
- parm.dfield = G_define_standard_option(G_OPT_V_FIELD);
- parm.dfield->answer = "1";
- parm.col = G_define_option();
- parm.col->key = "column";
- parm.col->type = TYPE_STRING;
- parm.col->required = NO;
- parm.col->description = _("Attribute table column with values to interpolate");
flag.noindex = G_define_flag();
flag.noindex->key = 'n';
flag.noindex->label = _("Don't index points by raster cell");
flag.noindex->description = _("Slower but uses"
- " less memory and includes points from outside region"
- " in the interpolation");
+ " less memory and includes points from outside region"
+ " in the interpolation");
flag.withz = G_define_flag();
flag.withz->key = 'z';
- flag.withz->description = _("Use z coordinates for approximation");
+ flag.withz->description = _("Use z coordinates for approximation (3D vector maps only)");
exit(EXIT_FAILURE);
if (sscanf(parm.npoints->answer, "%d", &search_points) != 1 ||
search_points < 1)
- G_fatal_error(_("%s=%s - illegal number of interpolation points"),
+ G_fatal_error(_("Illegal number of interpolation points"),
parm.npoints->key, parm.npoints->answer);
- sscanf(parm.dfield->answer, "%d", &field);
if (!flag.withz->answer && !parm.col->answer)
G_fatal_error(_("No attribute column specified"));
list =
- (struct list_Point *)G_calloc((size_t) search_points,
- sizeof(struct list_Point));
+ (struct list_Point *) G_calloc((size_t) search_points,
+ sizeof(struct list_Point));
/* get the window, dimension arrays */
G_get_window(&window);
@@ -164,11 +157,11 @@
/* read the elevation points from the input sites file */
- read_sites(parm.input->answer, flag.withz->answer ? 0 : field,
- parm.col->answer, flag.noindex->answer);
+ read_sites(parm.input->answer, parm.dfield->answer,
+ parm.col->answer, flag.noindex->answer, flag.withz->answer);
if (npoints == 0)
- G_fatal_error(_("No data points found"));
+ G_fatal_error(_("No points found"));
nsearch = npoints < search_points ? npoints : search_points;
if (!flag.noindex->answer) {
@@ -258,7 +251,7 @@
north = window.north + window.ns_res / 2.0;
for (row = 0; row < window.rows; row++) {
- G_percent(row, window.rows - 1, 1);
+ G_percent(row, window.rows, 1);
if (mask) {
if (Rast_get_c_row(maskfd, mask, row) < 0)
@@ -397,12 +390,15 @@
Rast_put_d_row(fd, dcell);
+ G_percent(1, 1, 1);
Rast_close(fd);
/* writing history file */
Rast_short_history(parm.output->answer, "raster", &history);
Rast_command_history(&history);
Rast_write_history(parm.output->answer, &history);
G_done_msg(" ");
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.surf.idw/proto.h
--- grass/trunk/vector/v.surf.idw/proto.h 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.surf.idw/proto.h 2010-01-02 14:08:18 UTC (rev 40188)
@@ -1 +1,6 @@
+/* read_sites.c */
+void read_sites(const char *, const char *, const char *, int, int);
void newpoint(double, double, double, int);
+void calculate_distances(int, int, double, double, int *);
+void calculate_distances_noindex(double, double);
Modified: grass/trunk/vector/v.surf.idw/read_sites.c
--- grass/trunk/vector/v.surf.idw/read_sites.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.surf.idw/read_sites.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -13,10 +13,10 @@
* mccauley
-void read_sites(char *name, int field, char *col, int noindex)
+void read_sites(const char *name, const char *field_name, const char *col, int noindex, int with_z)
extern long npoints;
- int nrec, ctype = 0, type;
+ int nrec, ctype = 0, type, field;
struct Map_info Map;
struct field_info *Fi;
dbDriver *Driver;
@@ -24,15 +24,16 @@
struct line_pnts *Points;
- Vect_open_old(&Map, name, "");
- if (field > 0) {
+ Vect_open_old2(&Map, name, "", field_name);
+ field = Vect_get_field_number(&Map, field_name);
+ if (!with_z) {
db_CatValArray_init(&cvarr);
Fi = Vect_get_field(&Map, field);
if (Fi == NULL)
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
+ G_fatal_error(_("Database connection not defined for layer %s"),
+ field_name);
Driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (Driver == NULL)
@@ -51,7 +52,7 @@
if (nrec < 0)
G_fatal_error(_("Unable to select data from table"));
- G_message(_("%d records selected from table"), nrec);
+ G_verbose_message(_("%d records selected from table"), nrec);
db_close_database_shutdown_driver(Driver);
@@ -66,7 +67,7 @@
if (!(type & GV_POINTS))
continue;
- if (field > 0) {
+ if (!with_z) {
int cat, ival, ret;
/* TODO: what to do with multiple cats */
@@ -93,7 +94,7 @@
newpoint(dval, Points->x[0], Points->y[0], noindex);
- if (field > 0)
+ if (!with_z)
db_CatValArray_free(&cvarr);
Vect_set_release_support(&Map);
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.surf.rst/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -1,31 +1,25 @@
- * Written by H. Mitasova, I. Kosinovsky, D. Gerdes Fall 1993
- * University of Illinois
- * US Army Construction Engineering Research Lab
- * Copyright 1993, H. Mitasova (University of Illinois),
- * I. Kosinovsky, (USA-CERL), and D.Gerdes (USA-CERL)
- * This program is free software; you can redistribute it and/or
- * modify it under the terms of the GNU General Public License
- * as published by the Free Software Foundation; either version 2
- * of the License, or (at your option) any later version.
+ * MODULE: v.surf.rst
+ * AUTHOR(S): H. Mitasova, I. Kosinovsky, D. Gerdes Fall 1993
+ * University of Illinois
+ * I. Kosinovsky, (USA-CERL), and D.Gerdes (USA-CERL)
+ * Michael Shapiro, U.S. Army Construction Engineering Research Laboratory
+ * modified by McCauley in August 1995
+ * modified by Mitasova in August 1995
+ * modified by Mitasova in November 1999 (dmax, timestamp update)
+ * dnorm independent tension - -t flag
+ * cross-validation -v flag by Jaro Hofierka 2004
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
+ * PURPOSE: Surface interpolation from vector point data by splines
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
- * modified by McCauley in August 1995
- * modified by Mitasova in August 1995
- * modified by Mitasova in November 1999 (dmax, timestamp update)
- * dnorm independent tension - -t flag
- * cross-validation -v flag by Jaro Hofierka 2004
#include <stdio.h>
#include <stdlib.h>
@@ -42,10 +36,10 @@
#include <grass/interpf.h>
#include <grass/qtree.h>
-#include "surf.h"
#include <grass/dataquad.h>
#include <grass/gmath.h>
+#include "surf.h"
#define SCIK1 1 /*100000 */
#define SCIK2 1 /*100000 */
@@ -116,7 +110,7 @@
- int per, npmin;
+ int npmin;
int ii;
double x_orig, y_orig, dnorm, deltx, delty, xm, ym;
char dmaxchar[200];
@@ -146,6 +140,8 @@
+ G_add_keyword(_("interpolation"));
_("Spatial approximation and topographic analysis from given "
"point or isoline data in vector format to floating point "
@@ -170,7 +166,7 @@
flag.withz->guisection = _("Parameters");
@@ -179,88 +175,85 @@
parm.field->answer = "1";
parm.field->guisection = _("Selection");
+ parm.zcol = G_define_standard_option(G_OPT_DB_COLUMN);
+ parm.zcol->key = "zcolumn";
+ parm.zcol->required = NO;
+ parm.zcol->description =
+ _("Name of the attribute column with values to be used for approximation");
+ parm.zcol->guisection = _("Parameters");
parm.wheresql = G_define_standard_option(G_OPT_DB_WHERE);
parm.wheresql->guisection = _("Selection");
parm.elev = G_define_standard_option(G_OPT_R_OUTPUT);
parm.elev->key = "elev";
parm.elev->required = NO;
- parm.elev->description = _("Output surface raster map (elevation)");
+ parm.elev->description = _("Name for output surface raster map (elevation)");
parm.elev->guisection = _("Outputs");
parm.slope = G_define_standard_option(G_OPT_R_OUTPUT);
parm.slope->key = "slope";
parm.slope->required = NO;
- parm.slope->description = _("Output slope raster map");
+ parm.slope->description = _("Name for output slope raster map");
parm.slope->guisection = _("Outputs");
parm.aspect = G_define_standard_option(G_OPT_R_OUTPUT);
parm.aspect->key = "aspect";
parm.aspect->required = NO;
- parm.aspect->description = _("Output aspect raster map");
+ parm.aspect->description = _("Name for output aspect raster map");
parm.aspect->guisection = _("Outputs");
parm.pcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.pcurv->key = "pcurv";
parm.pcurv->required = NO;
- parm.pcurv->description = _("Output profile curvature raster map");
+ parm.pcurv->description = _("Name for output profile curvature raster map");
parm.pcurv->guisection = _("Outputs");
parm.tcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.tcurv->key = "tcurv";
parm.tcurv->required = NO;
- parm.tcurv->description = _("Output tangential curvature raster map");
+ parm.tcurv->description = _("Name for output tangential curvature raster map");
parm.tcurv->guisection = _("Outputs");
parm.mcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.mcurv->key = "mcurv";
parm.mcurv->required = NO;
- parm.mcurv->description = _("Output mean curvature raster map");
+ parm.mcurv->description = _("Name for output mean curvature raster map");
parm.mcurv->guisection = _("Outputs");
- parm.devi = G_define_option();
+ parm.devi = G_define_standard_option(G_OPT_V_OUTPUT);
parm.devi->key = "devi";
- parm.devi->type = TYPE_STRING;
parm.devi->required = NO;
- parm.devi->gisprompt = "new,vector,vector";
- parm.devi->description = _("Output deviations vector point file");
+ parm.devi->description = _("Name for output deviations vector point map");
parm.devi->guisection = _("Outputs");
parm.cvdev = G_define_standard_option(G_OPT_V_OUTPUT);
parm.cvdev->key = "cvdev";
parm.cvdev->required = NO;
parm.cvdev->description =
- _("Output cross-validation errors vector point file");
+ _("Name for output cross-validation errors vector point map");
parm.cvdev->guisection = _("Outputs");
parm.treefile = G_define_standard_option(G_OPT_V_OUTPUT);
parm.treefile->key = "treefile";
parm.treefile->required = NO;
parm.treefile->description =
- _("Output vector map showing quadtree segmentation");
+ _("Name for output vector map showing quadtree segmentation");
parm.treefile->guisection = _("Outputs");
parm.overfile = G_define_standard_option(G_OPT_V_OUTPUT);
parm.overfile->key = "overfile";
parm.overfile->required = NO;
parm.overfile->description =
- _("Output vector map showing overlapping windows");
+ _("Name for output vector map showing overlapping windows");
parm.overfile->guisection = _("Outputs");
parm.maskmap = G_define_standard_option(G_OPT_R_INPUT);
parm.maskmap->key = "maskmap";
parm.maskmap->required = NO;
- parm.maskmap->description = _("Name of the raster map used as mask");
+ parm.maskmap->description = _("Name of raster map used as mask");
parm.maskmap->guisection = _("Parameters");
- parm.zcol = G_define_option();
- parm.zcol->key = "zcolumn";
- parm.zcol->type = TYPE_STRING;
- parm.zcol->required = NO;
- parm.zcol->description =
- _("Name of the attribute column with values to be used for approximation");
- parm.zcol->guisection = _("Parameters");
parm.fi = G_define_option();
parm.fi->key = "tension";
parm.fi->type = TYPE_DOUBLE;
@@ -363,14 +356,20 @@
sprintf(dmaxchar, "%f", dmin * 5);
sprintf(dminchar, "%f", dmin);
- if (!parm.dmin->answer)
- parm.dmin->answer = dminchar;
- if (!parm.dmax->answer)
- parm.dmax->answer = dmaxchar;
- per = 1;
+ if (!parm.dmin->answer) {
+ parm.dmin->answer = G_store(dminchar);
+ parm.dmin->answers = (char **) G_malloc(2 * sizeof(char *));
+ parm.dmin->answers[0] = G_store(dminchar);
+ parm.dmin->answers[1] = NULL;
+ if (!parm.dmax->answer) {
+ parm.dmax->answer = G_store(dmaxchar);
+ parm.dmax->answers = (char **) G_malloc(2 * sizeof(char *));
+ parm.dmax->answers[0] = G_store(dmaxchar);
+ parm.dmax->answers[1] = NULL;
input = parm.input->answer;
- field = atoi(parm.field->answer);
zcol = parm.zcol->answer;
scol = parm.scol->answer;
wheresql = parm.wheresql->answer;
@@ -526,7 +525,11 @@
if ((info = MT_tree_info_new(root, functions, dmin, KMAX)) == NULL)
G_fatal_error(_("Cannot create tree info"));
- open_check = Vect_open_old(&Map, input, "");
+ open_check = Vect_open_old2(&Map, input, "", parm.field->answer);
+ field = Vect_get_field_number(&Map, parm.field->answer);
+ if (!flag.withz->answer && field < 1)
+ G_fatal_error(_("Layer <%s> not found"), parm.field->answer);
if (open_check < 1)
G_fatal_error(_("Unable to open vector map <%s>"), input);
/* if (open_check < 2)
@@ -580,9 +583,7 @@
ertot = 0.;
- if (per)
- G_message(_("Percent complete: "));
create_temp_files();
IL_init_params_2d(¶ms, NULL, 1, 1, zmult, KMIN, KMAX, maskmap, n_rows,
@@ -598,7 +599,7 @@
IL_crstg, IL_write_temp_2d);
totsegm =
- IL_vector_input_data_2d(¶ms, &Map, flag.withz ? 0 : field,
+ IL_vector_input_data_2d(¶ms, &Map, flag.withz->answer ? 0 : field,
zcol, scol,
info, &xmin, &xmax,
&ymin, &ymax, &zmin, &zmax, &NPOINT, &dmax);
@@ -643,8 +644,8 @@
if (mcurv != NULL)
ddisk += disk;
ddisk += sddisk;
- G_message(_("Processing all selected output files\n"
- "will require %d bytes of disk space for temp files"), ddisk);
+ G_verbose_message(_("Processing all selected output files "
+ "will require %d bytes of disk space for temp files"), ddisk);
deltx = xmax - xmin;
delty = ymax - ymin;
@@ -652,18 +653,18 @@
if (dtens) {
params.fi = params.fi * dnorm / 1000.;
- G_message("dnorm = %f, rescaled tension = %f", dnorm, params.fi);
+ G_debug(1, "dnorm = %f, rescaled tension = %f", dnorm, params.fi);
bitmask = IL_create_bitmask(¶ms);
if (totsegm <= 0) {
clean();
G_fatal_error(_("Input failed"));
ertot = 0.;
- if (per)
+ G_message(_("Processing segments..."));
if (IL_interp_segments_2d(¶ms, info, info->root, bitmask,
zmin, zmax, &zminac, &zmaxac, &gmin, &gmax,
&c1min, &c1max, &c2min, &c2max, &ertot, totsegm,
@@ -687,7 +688,7 @@
dtens, 1, NPOINT);
if (ii < 0) {
clean();
- G_fatal_error(_("Cannot write raster maps -- try to increase resolution"));
+ G_fatal_error(_("Unable to write raster maps - try to increase resolution"));
G_free(zero_array_cell);
@@ -707,7 +708,7 @@
if (overfile != NULL) {
if (0 > Vect_open_new(&OverMap, overfile, 0)) {
clean();
- G_fatal_error(_("Unable to open vector map <%s>"), overfile);
+ G_fatal_error(_("Unable to create vector map <%s>"), overfile);
Vect_hist_command(&OverMap);
@@ -742,7 +743,7 @@
Vect_close(&Map2);
- G_done_msg("\n");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.to.3d/args.c
--- grass/trunk/vector/v.to.3d/args.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.3d/args.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -16,12 +16,22 @@
opt->input = G_define_standard_option(G_OPT_V_INPUT);
- opt->output = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt->field = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ opt->field->guisection = _("Selection");
opt->type = G_define_standard_option(G_OPT_V_TYPE);
opt->type->options = "point,line,boundary,centroid";
opt->type->answer = "point,line,boundary,centroid";
+ opt->type->guisection = _("Selection");
+ opt->output = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt->column = G_define_standard_option(G_OPT_DB_COLUMN);
+ opt->column->label = _("Name of attribute column used for height");
+ opt->column->description =
+ _("Can be used for reverse transformation, to store height of points");
+ opt->column->guisection = _("Height");
opt->height = G_define_option();
opt->height->key = "height";
opt->height->type = TYPE_DOUBLE;
@@ -29,16 +39,6 @@
opt->height->multiple = NO;
opt->height->description = _("Fixed height for 3D vector features");
opt->height->guisection = _("Height");
- opt->field = G_define_standard_option(G_OPT_V_FIELD);
- opt->field->guisection = _("Height");
- opt->column = G_define_standard_option(G_OPT_DB_COLUMN);
- opt->column->label = _("Name of attribute column used for height");
- opt->column->description =
- _("Can be used for reverse transformation, to store height of points");
- opt->column->guisection = _("Height");
return;
Modified: grass/trunk/vector/v.to.3d/local_proto.h
--- grass/trunk/vector/v.to.3d/local_proto.h 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.3d/local_proto.h 2010-01-02 14:08:18 UTC (rev 40188)
@@ -15,8 +15,8 @@
/* trans2.c */
int trans2d(struct Map_info *, struct Map_info *, int,
- double, int, const char *);
+ double, const char *, const char *);
/* trans3.c */
int trans3d(struct Map_info *, struct Map_info *, int,
- int, const char *);
+ const char *, const char *);
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.3d/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -7,7 +7,7 @@
* PURPOSE: Performs transformation of 2D vector features to 3D
- * COPYRIGHT: (C) 2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008-2010 by the GRASS Development Team
@@ -28,14 +28,14 @@
struct opts opt;
struct bound_box box;
- int field, type;
+ int type;
int ret;
G_gisinit(argv[0]);
- G_add_keyword(_("transformation"));
+ G_add_keyword(_("geometry"));
G_add_keyword(_("3D"));
_("Performs transformation of 2D vector features to 3D.");
@@ -44,8 +44,7 @@
exit(EXIT_FAILURE);
- field = atoi(opt.field->answer);
type = Vect_option_to_types(opt.type);
if (!opt.reverse->answer) {
@@ -67,12 +66,12 @@
Vect_check_input_output_name(opt.input->answer, opt.output->answer,
GV_FATAL_EXIT);
/* open input vector, topology not needed */
Vect_set_open_level(1);
- if (Vect_open_old(&In, opt.input->answer, "") < 1)
+ if (Vect_open_old2(&In, opt.input->answer, "", opt.field->answer) < 1)
G_fatal_error(_("Unable to open vector map <%s>"), opt.input->answer);
if (opt.reverse->answer && !Vect_is_3d(&In)) {
Vect_close(&In);
G_fatal_error(_("Vector map <%s> is 2D"), opt.input->answer);
@@ -106,7 +105,7 @@
ret = 0;
if (opt.reverse->answer) {
/* 3d -> 2d */
- ret = trans3d(&In, &Out, type, field, opt.column->answer);
+ ret = trans3d(&In, &Out, type, opt.field->answer, opt.column->answer);
else {
/* 2d -> 3d */
@@ -115,7 +114,7 @@
if (opt.height->answer) {
height = atof(opt.height->answer);
- ret = trans2d(&In, &Out, type, height, field, opt.column->answer);
+ ret = trans2d(&In, &Out, type, height, opt.field->answer, opt.column->answer);
if (ret < 0) {
Modified: grass/trunk/vector/v.to.3d/trans2.c
--- grass/trunk/vector/v.to.3d/trans2.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.3d/trans2.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -19,9 +19,9 @@
\return -1 on error
int trans2d(struct Map_info *In, struct Map_info *Out, int type,
- double height, int field, const char *column)
+ double height, const char *field_name, const char *column)
- int i, ltype, line;
+ int i, ltype, line, field;
int cat;
int ret, ctype;
@@ -35,6 +35,8 @@
+ field = Vect_get_field_number(In, field_name);
if (column) {
@@ -42,8 +44,8 @@
Fi = Vect_get_field(In, field);
if (!Fi) {
- G_warning(_("Database connection not defined for layer %d"),
- field);
+ G_warning(_("Database connection not defined for layer <%s>"),
+ field_name);
return -1;
@@ -92,6 +94,9 @@
if (!(ltype & type))
continue;
+ if (field != -1 && !Vect_cat_get(Cats, field, &cat))
+ continue;
if (column) {
Vect_cat_get(Cats, field, &cat);
if (cat < 0) {
Modified: grass/trunk/vector/v.to.3d/trans3.c
--- grass/trunk/vector/v.to.3d/trans3.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.3d/trans3.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -20,12 +20,12 @@
\return -1 on error
int trans3d(struct Map_info *In, struct Map_info *Out, int type,
- int field, const char *zcolumn)
+ const char *field_name, const char *zcolumn)
- int ltype;
- int line;
+ int ltype, line;
int ctype;
+ int field;
@@ -40,11 +40,13 @@
db_init_string(&stmt);
if (zcolumn) {
Fi = Vect_get_field(Out, field);
if (!Fi) {
- field);
+ field_name);
return -1;
@@ -92,7 +94,8 @@
continue;
- Vect_cat_get(Cats, field, &cat);
+ continue;
/* get first cat */
if (cat == -1) {
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.db/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -7,7 +7,7 @@
* Markus Neteler <neteler itc.it>
* PURPOSE: load values from vector to database
- * COPYRIGHT: (C) 2000-2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2000-2010 by the GRASS Development Team
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.db/parse.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -30,6 +30,9 @@
parms.vect = G_define_standard_option(G_OPT_V_MAP);
+ parms.field = G_define_standard_option(G_OPT_V_FIELD);
+ parms.field->label = _("Layer number or name (write to)");
parms.type = G_define_standard_option(G_OPT_V_TYPE);
parms.type->options = "point,line,boundary,centroid";
parms.type->answer = "point,line,boundary,centroid";
@@ -37,13 +40,10 @@
parms.type->description =
_("For coor valid point/centroid, "
"for length valid line/boundary");
- parms.field = G_define_standard_option(G_OPT_V_FIELD);
- parms.field->label = _("Layer number (write to)");
parms.qfield = G_define_standard_option(G_OPT_V_FIELD);
parms.qfield->key = "qlayer";
- parms.qfield->label = _("Query layer number (read from)");
+ parms.qfield->label = _("Query layer number or name (read from)");
parms.qfield->guisection = _("Query");
parms.option = G_define_option();
@@ -81,21 +81,18 @@
parms.units->required = NO;
parms.units->multiple = NO;
parms.units->options =
- "mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares,r,radians,d,degrees";
+ "miles,feet,meters,kilometers,acres,hectares,radians,degrees";
parms.units->label = _("Units");
parms.units->description =
- _("mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)");
+ _("miles,feet,meters,kilometers,acres,hectares,radians,degrees");
parms.col = G_define_standard_option(G_OPT_DB_COLUMNS);
- parms.qcol = G_define_option();
+ parms.qcol = G_define_standard_option(G_OPT_DB_COLUMN);
parms.qcol->key = "qcolumn";
parms.qcol->label = _("Name of attribute column used for 'query' option");
parms.qcol->description = _("E.g. 'cat', 'count(*)', 'sum(val)'");
- parms.qcol->type = TYPE_STRING;
- parms.qcol->key_desc = "name";
parms.qcol->required = NO;
- parms.qcol->multiple = NO;
parms.qcol->guisection = _("Query");
flags.p = G_define_flag();
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.points/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -4,15 +4,15 @@
* MODULE: v.to.points
* PURPOSE: Create points along lines
- * COPYRIGHT: (C) 2002 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2010 by the GRASS Development Team
- * for details.
#include <stdlib.h>
@@ -172,22 +172,24 @@
- _("Create points along input lines in new vector with 2 layers.");
+ _("Creates points along input lines in new vector map with 2 layers.");
- in_opt->description = _("Input vector map containing lines");
+ in_opt->label = _("Name of vector map containing lines");
- out_opt->description =
- _("Output vector map where points will be written");
+ lfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ lfield_opt->key = "llayer";
+ lfield_opt->answer = "1";
+ lfield_opt->label = "Line layer number or name";
+ lfield_opt->guisection = _("Selection");
type_opt->answer = "point,line,boundary,centroid";
- lfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- lfield_opt->key = "llayer";
- lfield_opt->answer = "1";
- lfield_opt->description = "Line layer";
+ out_opt->description =
+ _("Name for output vector map where points will be written");
node_flag = G_define_flag();
node_flag->key = 'n';
@@ -221,7 +223,6 @@
PPoints = Vect_new_line_struct();
- field = atoi(lfield_opt->answer);
type = Vect_option_to_types(type_opt);
dmax = atof(dmax_opt->answer);
@@ -240,8 +241,9 @@
/* Open input lines */
+ Vect_open_old2(&In, in_opt->answer, "", lfield_opt->answer);
+ field = Vect_get_field_number(&In, lfield_opt->answer);
/* Open output segments */
@@ -319,9 +321,9 @@
ltype = Vect_read_line(&In, LPoints, LCats, line);
continue;
+ if (!Vect_cat_get(LCats, field, &cat))
+ continue;
- Vect_cat_get(LCats, field, &cat);
if (LPoints->n_points <= 1) {
write_point(&Out, LPoints->x[0], LPoints->y[0], LPoints->z[0],
cat, 0.0, table_flag->answer);
@@ -345,7 +347,8 @@
cat = -1;
if (centroid > 0) {
Vect_read_line(&In, NULL, LCats, centroid);
+ continue;
Vect_get_area_points(&In, area, LPoints);
@@ -377,7 +380,7 @@
Vect_close(&In);
Vect_close(&Out);
- G_done_msg(_("%d points written to output vector map"), point_cat - 1);
+ G_done_msg(_("%d points written to output vector map."), point_cat - 1);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.to.rast/local.h
--- grass/trunk/vector/v.to.rast/local.h 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.rast/local.h 2010-01-02 14:08:18 UTC (rev 40188)
@@ -6,8 +6,6 @@
-#undef DEBUG
/* 2 * PI */
#define M_2PI 6.283185307179586232
@@ -52,7 +50,7 @@
int update_fcolors(const char *);
/* vect2rast.c */
-int vect_to_rast(const char *, const char *, int, const char *, int, int,
+int vect_to_rast(const char *, const char *, const char *, const char *, int, int,
double, int, const char *, const char *, int);
#endif
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.rast/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -7,8 +7,9 @@
* Radim Blazek <radim.blazek gmail.com> (GRASS 6 update)
* Brad Douglas <rez touchofmadness.com>, Glynn Clements <glynn gclements.plus.com>,
* Hamish Bowman <hamish_b yahoo.com>, Markus Neteler <neteler itc.it>
- * PURPOSE:
- * COPYRIGHT: (C) 2003-2009 by the GRASS Development Team
+ * PURPOSE: Converts vector map to raster map
+ * COPYRIGHT: (C) 2003-2010 by the GRASS Development Team
@@ -30,7 +31,7 @@
struct Option *input, *output, *rows, *col, *field_opt, *use_opt,
*val_opt, *rgbcol_opt, *label_opt, *type_opt;
- int field, nrows, use, value_type, type;
+ int nrows, use, value_type, type;
double value;
G_gisinit(argv[0]);
@@ -39,19 +40,24 @@
G_add_keyword(_("raster"));
G_add_keyword(_("conversion"));
- module->description = _("Converts a binary GRASS vector map "
- "into a GRASS raster map .");
+ G_add_keyword(_("rasterization"));
+ module->description = _("Converts a vector map into a raster map.");
- output = G_define_standard_option(G_OPT_R_OUTPUT);
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->options = "point,line,area";
+ type_opt->answer = "point,line,area";
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
use_opt = G_define_option();
use_opt->key = "use";
use_opt->type = TYPE_STRING;
- use_opt->required = NO;
+ use_opt->required = YES;
use_opt->multiple = NO;
use_opt->options = "attr,cat,val,z,dir";
- use_opt->answer = "attr";
use_opt->description = _("Source of raster values");
use_opt->descriptions = _("attr;read values from attribute table;"
"cat;use category values;"
@@ -59,14 +65,8 @@
"z;use z coordinate (points or contours only);"
"dir;output as flow direction (lines only)");
- type_opt = G_define_standard_option(G_OPT_V_TYPE);
- type_opt->options = "point,line,area";
- type_opt->answer = "point,line,area";
- /* for GRASS 7, IMHO this should be changed to "attrcolumn" */
+ col->key = "attrcolumn";
col->description =
_("Name of column for attr parameter (data type must be numeric)");
col->guisection = _("Attributes");
@@ -79,14 +79,6 @@
val_opt->answer = "1";
val_opt->description = _("Raster value");
- rows = G_define_option();
- rows->key = "rows";
- rows->type = TYPE_INTEGER;
- rows->required = NO;
- rows->multiple = NO;
- rows->answer = "4096";
- rows->description = _("Number of rows to hold in memory");
rgbcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
rgbcol_opt->key = "rgbcolumn";
rgbcol_opt->description =
@@ -98,12 +90,19 @@
label_opt->description =
_("Name of column used as raster category labels");
label_opt->guisection = _("Attributes");
+ rows = G_define_option();
+ rows->key = "rows";
+ rows->type = TYPE_INTEGER;
+ rows->required = NO;
+ rows->multiple = NO;
+ rows->answer = "4096";
+ rows->description = _("Number of rows to hold in memory");
exit(EXIT_FAILURE);
- field = atoi(field_opt->answer);
nrows = atoi(rows->answer);
switch (use_opt->answer[0]) {
@@ -138,7 +137,7 @@
value = atof(val_opt->answer);
value_type = (strchr(val_opt->answer, '.')) ? USE_DCELL : USE_CELL;
- if (vect_to_rast(input->answer, output->answer, field,
+ if (vect_to_rast(input->answer, output->answer, field_opt->answer,
col->answer, nrows, use, value, value_type,
rgbcol_opt->answer, label_opt->answer, type))
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.rast/vect2rast.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -7,16 +7,14 @@
#include "local.h"
-int vect_to_rast(const char *vector_map, const char *raster_map, int field,
+int vect_to_rast(const char *vector_map, const char *raster_map, const char *field_name,
const char *column, int nrows, int use, double value,
int value_type, const char *rgbcolumn, const char *labelcolumn,
int ftype)
-#ifdef DEBUG
- int i;
-#endif
+ int i, field;
int fd; /* for raster map */
int nareas, nlines; /* number of converted features */
int nareas_all, nplines_all; /* number of all areas, points/lines */
@@ -34,9 +32,10 @@
nareas = 0;
- G_message(_("Loading data..."));
+ G_verbose_message(_("Loading data..."));
- Vect_open_old(&Map, vector_map, "");
+ Vect_open_old2(&Map, vector_map, "", field_name);
if ((use == USE_Z) && !(Vect_is_3d(&Map)))
G_fatal_error(_("Vector map <%s> is not 3D"),
@@ -46,8 +45,8 @@
case USE_ATTR:
if (!(Fi = Vect_get_field(&Map, field)))
- field);
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ field_name);
if ((Driver =
db_start_driver_open_database(Fi->driver, Fi->database)) == NULL)
@@ -75,7 +74,6 @@
-#ifdef DEBUG
for (i = 0; i < cvarr.n_values; i++) {
if (ctype == DB_C_TYPE_INT) {
G_debug(3, "cat = %d val = %d", cvarr.value[i].cat,
@@ -86,8 +84,7 @@
cvarr.value[i].val.d);
-#endif
switch (ctype) {
case DB_C_TYPE_INT:
format = USE_CELL;
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.to.rast3/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -5,12 +5,13 @@
* AUTHOR(S): Original s.to.rast3: Jaro Hofierka, Geomodel s.r.o. (original contributor)
* 9/2005 Upgrade to GRASS 6 by Radim Blazek
* Soeren Gebbert <soeren.gebbert gmx.de>
- * PURPOSE:
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * PURPOSE: Converts vector points to 3D raster
+ * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
- * for details.
#include <stdlib.h>
@@ -41,44 +42,39 @@
dbDriver *Driver;
dbCatValArray cvarr;
+ G_gisinit(argv[0]);
G_add_keyword(_("volume"));
- "(only points) layer into a 3D GRASS raster map layer.");
+ module->description = _("Converts a vector map "
+ "(only points) into a 3D raster map.");
- out_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
- col_opt = G_define_option();
- col_opt->key = "column";
- col_opt->type = TYPE_STRING;
- col_opt->key_desc = "name";
- col_opt->required = YES;
- col_opt->multiple = NO;
- col_opt->description = _("Column name (type must be numeric)");
- G_gisinit(argv[0]);
+ out_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+ col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+ col_opt->required = YES;
+ col_opt->description = _("Name or attrbitute column (data type must be numeric)");
exit(EXIT_FAILURE);
G3d_getWindow(®ion);
G3d_readWindow(®ion, NULL);
- Vect_open_old(&Map, in_opt->answer, "");
+ Vect_open_old2(&Map, in_opt->answer, "", field_opt->answer);
+ field = Vect_get_field_number(&Map, field_opt->answer);
if (Fi == NULL)
- G_fatal_error(_("Unable to get layer info for vector map"));
+ G_fatal_error(_("Database connection not defined for layer <%s>"), field_opt->answer);
if (Driver == NULL)
@@ -113,7 +109,9 @@
for (line = 1; line <= nlines; line++) {
int type, cat, depth, row, col, ret;
double value;
+ G_percent(line, nlines, 2);
type = Vect_read_line(&Map, Points, Cats, line);
if (!(type & GV_POINT))
continue;
@@ -159,7 +157,6 @@
if (!G3d_closeCell(map))
G_fatal_error(_("Unable to close new 3d raster map"));
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.transform/creat_trans.c
--- grass/trunk/vector/v.transform/creat_trans.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.transform/creat_trans.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -29,7 +29,7 @@
#include "trans.h"
#include "local_proto.h"
-int create_transform_from_file(struct file_info *Coord, int quiet)
+int create_transform_from_file(struct file_info *Coord)
int status;
int n_points;
@@ -50,7 +50,7 @@
G_fatal_error(_("Error creating transformation"));
- if (!quiet)
+ if (G_verbose() > G_verbose_std())
print_transform_resids(n_points);
return (0);
Modified: grass/trunk/vector/v.transform/local_proto.h
--- grass/trunk/vector/v.transform/local_proto.h 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.transform/local_proto.h 2010-01-02 14:08:18 UTC (rev 40188)
@@ -3,7 +3,7 @@
int set_default_options(struct file_info *, struct file_info *,
struct file_info *, struct command_flags *);
/* creat_trans.c */
-int create_transform_from_file(struct file_info *, int);
+int create_transform_from_file(struct file_info *);
/* get_coor.c */
int get_coor_from_file(FILE *);
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.transform/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -5,12 +5,12 @@
* AUTHOR(S): See below also.
* Eric G. Miller <egm2 at jps.net>
* Upgrade to 5.7 Radim Blazek
-* Column support added by Martin Landa (09/2007)
+* Column support & OGR support added by Martin Landa (09/2007)
* PURPOSE: To transform a vector map's coordinates via a set of tie
* points.
-* COPYRIGHT: (C) 2002-2007 by the GRASS Development Team
+* COPYRIGHT: (C) 2002-2010 by the GRASS Development Team
@@ -61,7 +61,7 @@
struct Option *vold, *vnew, *pointsfile, *xshift, *yshift, *zshift,
*xscale, *yscale, *zscale, *zrot, *columns, *table, *field;
- struct Flag *quiet_flag, *tozero_flag, *shift_flag, *print_mat_flag;
+ struct Flag *tozero_flag, *print_mat_flag;
char mon[4], date[40], buf[1000];
struct Map_info Old, New;
@@ -85,12 +85,7 @@
_("Performs an affine transformation (shift, scale and rotate, "
"or GPCs) on vector map.");
- quiet_flag = G_define_flag();
- quiet_flag->key = 'q';
- quiet_flag->description =
- _("Suppress display of residuals or other information");
tozero_flag = G_define_flag();
tozero_flag->key = 't';
tozero_flag->description = _("Shift all z values to bottom=0");
@@ -99,17 +94,12 @@
print_mat_flag->key = 'm';
print_mat_flag->description =
_("Print the transformation matrix to stdout");
- /* remove in GRASS7 */
- shift_flag = G_define_flag();
- shift_flag->key = 's';
- shift_flag->description =
- _("Instead of points use transformation parameters "
- "(xshift, yshift, zshift, xscale, yscale, zscale, zrot)");
- shift_flag->guisection = _("Custom");
vold = G_define_standard_option(G_OPT_V_INPUT);
+ field = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ field->guisection = _("Custom");
vnew = G_define_standard_option(G_OPT_V_OUTPUT);
pointsfile = G_define_standard_option(G_OPT_F_INPUT);
@@ -119,8 +109,6 @@
pointsfile->description = _("If not given, transformation parameters "
"(xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead");
- pointsfile->gisprompt = "old_file,file,points";
xshift = G_define_option();
xshift->key = "xshift";
xshift->type = TYPE_DOUBLE;
@@ -197,9 +185,6 @@
_("Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr");
columns->guisection = _("Custom");
- field = G_define_standard_option(G_OPT_V_FIELD);
- field->guisection = _("Custom");
exit(EXIT_FAILURE);
@@ -208,18 +193,6 @@
Vect_check_input_output_name(vold->answer, vnew->answer, GV_FATAL_EXIT);
- /* please remove in GRASS7 */
- if (shift_flag->answer)
- G_warning(_("The '%c' flag is deprecated and will be removed in future. "
- "Transformation parameters are used automatically when no pointsfile is given."),
- shift_flag->key);
- if (quiet_flag->answer) {
- "Please use '--quiet' instead."), quiet_flag->key);
- G_putenv("GRASS_VERBOSE", "0");
if (!table->answer && columns->answer) {
G_fatal_error(_("Table name is not defined. Please use '%s' parameter."),
table->key);
@@ -230,7 +203,7 @@
"Otherwise the table is overwritten."));
- if (pointsfile->answer != NULL && !shift_flag->answer) {
+ if (pointsfile->answer != NULL) {
strcpy(Coord.name, pointsfile->answer);
else {
@@ -245,7 +218,7 @@
/* open vector maps */
- Vect_open_old(&Old, vold->answer, "");
+ Vect_open_old2(&Old, vold->answer, "", field->answer);
Vect_open_new(&New, vnew->answer, Vect_is_3d(&Old) || zshift->answer);
@@ -271,7 +244,7 @@
/* points file */
if (Coord.name[0]) {
- create_transform_from_file(&Coord, quiet_flag->answer);
+ create_transform_from_file(&Coord);
if (Coord.name[0] != '\0')
fclose(Coord.fp);
@@ -335,26 +308,26 @@
transform_digit_file(&Old, &New, Coord.name[0] ? 1 : 0,
ztozero, trans_params,
- table->answer, columns_name, atoi(field->answer));
+ table->answer, columns_name, Vect_get_field_number(&Old, field->answer));
if (Vect_copy_tables(&Old, &New, 0))
G_warning(_("Failed to copy attribute table to output map"));
Vect_close(&Old);
Vect_build(&New);
- if (!quiet_flag->answer) {
+ if (G_verbose() > G_verbose_std()) {
Vect_get_map_box(&New, &box);
G_message(_("\nNew vector map <%s> boundary coordinates:"),
vnew->answer);
G_message(_(" N: %-10.3f S: %-10.3f"), box.N, box.S);
G_message(_(" E: %-10.3f W: %-10.3f"), box.E, box.W);
G_message(_(" B: %6.3f T: %6.3f"), box.B, box.T);
- /* print the transformation matrix if requested */
- if (print_mat_flag->answer)
- print_transform_matrix();
+ /* print the transformation matrix if requested */
+ if (print_mat_flag->answer)
+ print_transform_matrix();
Vect_close(&New);
G_done_msg(" ");
Modified: grass/trunk/vector/v.transform/trans_digit.c
--- grass/trunk/vector/v.transform/trans_digit.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.transform/trans_digit.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -74,6 +74,9 @@
if (type == -2) /* EOF */
return 1;
+ if (field != -1 && !Vect_cat_get(Cats, field, NULL))
+ continue;
/* get transformation parameters */
if (table) {
Vect_cat_get(Cats, field, &cat); /* get first category */
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.type/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -4,21 +4,19 @@
* MODULE: v.type
+ * PURPOSE: Feature type manipulations
- * PURPOSE: Category manipulations
+ * COPYRIGHT: (C) 2001-2010 by the GRASS Development Team
- * for details.
-#ifdef FOR_GRASS7
-#include <string.h>
-#endif
+#include <string.h>
#include <stdlib.h>
@@ -29,68 +27,44 @@
static struct line_pnts *Points;
- int type;
+ int type, field;
-#ifdef FOR_GRASS7
- struct Option *in_opt, *out_opt, *to_opt, *from_opt;
+ struct Option *in_opt, *out_opt, *to_opt, *from_opt, *field_opt;
int from_type, to_type;
-#else
- int i, j;
- struct Option *in_opt, *out_opt, *type_opt;
- int types[100]; /* array of input,output types */
- int ntypes; /* number of types (number of pairs * 2) */
-#endif
- module->description = _("Change the type of geometry elements.");
+ module->description = _("Changes type of vector features.");
-#ifdef FOR_GRASS7
- from_opt = G_define_option();
- from_opt->type = TYPE_STRING;
- from_opt->key = "from";
- from_opt->key_desc = "type";
+ from_opt = G_define_standard_option(G_OPT_V_TYPE);
+ from_opt->key = "from_type";
from_opt->options = "point,line,boundary,centroid,face,kernel";
- from_opt->answer = "boundary";
from_opt->required = YES;
- from_opt->multiple = NO;
from_opt->description = _("Feature type to convert from");
+ from_opt->answer = "line";
- to_opt = G_define_option();
- to_opt->type = TYPE_STRING;
- to_opt->key = "to";
- to_opt->key_desc = "type";
+ to_opt = G_define_standard_option(G_OPT_V_TYPE);
+ to_opt->key = "to_type";
to_opt->options = "point,line,boundary,centroid,face,kernel";
- to_opt->answer = "line";
to_opt->required = YES;
- to_opt->multiple = NO;
to_opt->description = _("Feature type to convert to");
-#else
- type_opt->options = "point,line,boundary,centroid,face,kernel";
- type_opt->answer = "line,boundary,point,centroid";
- type_opt->label = _("Pairs for input and output type separated by comma");
- type_opt->description =
- _("<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
- "\t\tExample1: line,boundary\n"
- "\t\tExample2: line,boundary,point,centroid");
-#endif
+ to_opt->answer = "boundary";
exit(EXIT_FAILURE);
-#ifdef FOR_GRASS7
- if (!strcmp(from_opt->answer, to_opt->answer))
- G_fatal_error(_("Nothing to do"));
+ Vect_check_input_output_name(in_opt->answer, out_opt->answer, GV_FATAL_EXIT);
switch (from_opt->answer[0]) {
case 'p':
from_type = GV_POINT;
@@ -140,57 +114,6 @@
G_fatal_error(_("Incompatible types"));
-#else
- i = 0;
- j = 0;
- while (type_opt->answers[i]) {
- switch (type_opt->answers[i][0]) {
- case 'p':
- types[i] = GV_POINT;
- break;
- case 'l':
- types[i] = GV_LINE;
- break;
- case 'b':
- types[i] = GV_BOUNDARY;
- break;
- case 'c':
- types[i] = GV_CENTROID;
- break;
- case 'f':
- types[i] = GV_FACE;
- break;
- case 'k':
- types[i] = GV_KERNEL;
- break;
- if (j == 1) { /* check type compatibility */
- if (((types[i - 1] & (GV_POINT | GV_CENTROID | GV_KERNEL)) &&
- (types[i] & (GV_LINE | GV_BOUNDARY | GV_FACE))
- ) || ((types[i - 1] & (GV_LINE | GV_BOUNDARY | GV_FACE)) &&
- (types[i] & (GV_POINT | GV_CENTROID | GV_KERNEL))
- G_fatal_error(_("Incompatible types"));
- j = 0;
- else {
- j++;
- i++;
- if (i < 2)
- G_fatal_error(_("Not enough types"));
- if (j == 1)
- G_fatal_error(_("Odd number of types"));
- ntypes = i;
-#endif
GV_FATAL_EXIT);
@@ -199,8 +122,9 @@
/* open input vector */
+ Vect_open_old2(&In, in_opt->answer, "", field_opt->answer);
+ field = Vect_get_field_number(&In, field_opt->answer);
Vect_set_fatal_error(GV_FATAL_PRINT);
if (0 > Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In))) {
Vect_close(&In);
@@ -212,22 +136,18 @@
while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
-#ifdef FOR_GRASS7
if (type == from_type)
type = to_type;
-#else
- for (i = 0; i < ntypes; i += 2) {
- if (type == types[i]) {
- type = types[i + 1];
- break;
-#endif
+ continue;
Vect_write_line(&Out, type, Points, Cats);
if (Vect_copy_tables(&In, &Out, 0))
Vect_build(&Out);
Vect_close(&Out);
Vect_close(&In);
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.univar/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -5,16 +5,15 @@
* Hamish Bowman, University of Otago, New Zealand (r.univar2)
- * Martin Landa (extended stats)
+ * Martin Landa (extended stats & OGR support)
* PURPOSE: Univariate Statistics for attribute
- * COPYRIGHT: (C) 2004-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2010 by the GRASS Development Team
- * for details.
#include <stdlib.h>
@@ -63,26 +62,23 @@
G_add_keyword(_("statistics"));
- _("Calculates univariate statistics for attribute. Variance and standard "
- "deviation is calculated only for points if specified.");
+ module->label =
+ _("Calculates univariate statistics for attribute.");
+ module->description = _("Variance and standard "
+ "deviation is calculated only for points if specified.");
- col_opt->description = _("Column name");
where_opt = G_define_standard_option(G_OPT_DB_WHERE);
percentile = G_define_option();
percentile->key = "percentile";
percentile->type = TYPE_INTEGER;
@@ -101,11 +97,11 @@
extended->description = _("Calculate extended statistics");
G_gisinit(argv[0]);
exit(EXIT_FAILURE);
otype = Vect_option_to_types(type_opt);
- ofield = atoi(field_opt->answer);
perc = atoi(percentile->answer);
@@ -113,7 +109,8 @@
- Vect_open_old(&Map, map_opt->answer, "");
+ Vect_open_old2(&Map, map_opt->answer, "", field_opt->answer);
+ ofield = Vect_get_field_number(&Map, field_opt->answer);
/* Check if types are compatible */
if ((otype & GV_POINTS) && ((otype & GV_LINES) || (otype & GV_AREA)))
@@ -134,7 +131,7 @@
db_CatValArray_init(&Cvarr);
Fi = Vect_get_field(&Map, ofield);
if (Fi == NULL) {
+ G_fatal_error(_(" Database connection not defined for layer <%s>"), field_opt->answer);
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.what/main.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -4,17 +4,18 @@
* MODULE: v.what
* AUTHOR(S): Trevor Wiens - derived from d.what.vect - 15 Jan 2006
* PURPOSE: To select and report attribute information for objects at a
* user specified location. This replaces d.what.vect by removing
* the interactive component to enable its use with the new
* gis.m and future GUI.
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2010 by the GRASS Development Team
- * for details.
@@ -36,11 +37,12 @@
int main(int argc, char **argv)
struct Flag *printattributes, *topo_flag, *shell_flag;
- struct Option *opt1, *coords_opt, *maxdistance;
+ struct Option *map_opt, *field_opt, *coords_opt, *maxdistance;
char buf[2000];
int i, level, ret;
+ int *field;
double xval, yval, xres, yres, maxd, x;
double EW_DIST1, EW_DIST2, NS_DIST1, NS_DIST2;
char nsres[30], ewres[30];
@@ -52,12 +54,12 @@
G_add_keyword(_("querying"));
- module->description = _("Queries a vector map layer at given locations.");
+ module->description = _("Queries a vector map at given locations.");
- opt1 = G_define_standard_option(G_OPT_V_MAP);
- opt1->multiple = YES;
- opt1->required = YES;
+ map_opt = G_define_standard_option(G_OPT_V_MAPS);
+ field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
coords_opt = G_define_option();
coords_opt->key = "east_north";
coords_opt->type = TYPE_DOUBLE;
@@ -65,7 +67,7 @@
coords_opt->required = NO;
coords_opt->multiple = YES;
coords_opt->label = _("Coordinates for query");
- coords_opt->description = _("If not given reads from standard input");
+ coords_opt->description = _("If not given read from standard input");
maxdistance = G_define_option();
maxdistance->type = TYPE_DOUBLE;
@@ -77,20 +79,23 @@
topo_flag = G_define_flag();
topo_flag->key = 'd';
topo_flag->description = _("Print topological information (debugging)");
+ topo_flag->guisection = _("Print");
printattributes = G_define_flag();
printattributes->key = 'a';
printattributes->description = _("Print attribute information");
+ printattributes->guisection = _("Print");
shell_flag = G_define_flag();
shell_flag->key = 'g';
shell_flag->description = _("Print the stats in shell script style");
+ shell_flag->guisection = _("Print");
exit(EXIT_FAILURE);
- if (opt1->answers && opt1->answers[0])
- vect = opt1->answers;
+ if (map_opt->answers && map_opt->answers[0])
+ vect = map_opt->answers;
maxd = atof(maxdistance->answer);
@@ -129,28 +134,39 @@
/* Look at maps given on command line */
if (vect) {
- for (i = 0; vect[i]; i++) ;
+ for (i = 0; vect[i]; i++)
nvects = i;
- Map = (struct Map_info *)G_malloc(nvects * sizeof(struct Map_info));
+ for (i = 0; field_opt->answers[i]; i++)
+ if (nvects != i)
+ G_fatal_error(_("Number of given vector maps (%d) differs from number of layers (%d)"),
+ nvects, i);
+ Map = (struct Map_info *) G_malloc(nvects * sizeof(struct Map_info));
+ field = (int *) G_malloc(nvects * sizeof(int));
for (i = 0; i < nvects; i++) {
- level = Vect_open_old(&Map[i], vect[i], "");
+ level = Vect_open_old2(&Map[i], vect[i], "", field_opt->answers[i]);
if (level < 2)
G_fatal_error(_("You must build topology on vector map <%s>"),
vect[i]);
+ field[i] = Vect_get_field_number(&Map[i], field_opt->answers[i]);
if (!coords_opt->answer) {
- /* if coords are not given on command line, read them from stdin */
+ /* read them from stdin */
setvbuf(stdin, NULL, _IOLBF, 0);
setvbuf(stdout, NULL, _IOLBF, 0);
while (fgets(buf, sizeof(buf), stdin) != NULL) {
ret = sscanf(buf, "%lf%c%lf", &xval, &ch, &yval);
if (ret == 3 && (ch == ',' || ch == ' ' || ch == '\t')) {
what(xval, yval, maxd, topo_flag->answer,
- printattributes->answer, shell_flag->answer);
+ printattributes->answer, shell_flag->answer, field);
else {
G_warning(_("Unknown input format, skipping: '%s'"), buf);
@@ -163,7 +179,8 @@
for (i = 0; coords_opt->answers[i] != NULL; i += 2) {
xval = atof(coords_opt->answers[i]);
yval = atof(coords_opt->answers[i + 1]);
- what(xval, yval, maxd, topo_flag->answer, printattributes->answer, shell_flag->answer);
+ what(xval, yval, maxd, topo_flag->answer,
Modified: grass/trunk/vector/v.what/what.c
--- grass/trunk/vector/v.what/what.c 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.what/what.c 2010-01-02 14:08:18 UTC (rev 40188)
@@ -102,7 +102,7 @@
db_free_string(&str);
-void what(double east, double north, double maxdist, int topo, int showextra, int script)
+void what(double east, double north, double maxdist, int topo, int showextra, int script, int *field)
int type;
char east_buf[40], north_buf[40];
@@ -199,6 +199,10 @@
if (line > 0) {
type = Vect_read_line(&Map[i], Points, Cats, line);
+ if (field[i] != -1 && !Vect_cat_get(Cats, field[i], NULL))
+ continue;
switch (type) {
case GV_POINT:
sprintf(buf, "Point\n");
Modified: grass/trunk/vector/v.what/what.h
--- grass/trunk/vector/v.what/what.h 2010-01-02 14:05:31 UTC (rev 40187)
+++ grass/trunk/vector/v.what/what.h 2010-01-02 14:08:18 UTC (rev 40188)
@@ -1,5 +1,5 @@
/* what.c */
-extern void what(double, double, double, int, int, int);
+extern void what(double, double, double, int, int, int, int*);
extern char **vect;
extern int nvects;
