[GRASS-SVN] r40207 - in grass/trunk: include/Make tools
svn_grass at osgeo.org
Sun Jan 3 13:49:09 EST 2010
Author: glynn
Date: 2010-01-03 13:49:08 -0500 (Sun, 03 Jan 2010)
New Revision: 40207
Added:
grass/trunk/tools/g.echo.c
grass/trunk/include/Make/Rules.make
grass/trunk/tools/
grass/trunk/tools/Makefile
Add, use tools/g.echo (g.dirseps is built too late)
Modified: grass/trunk/include/Make/Rules.make
--- grass/trunk/include/Make/Rules.make 2010-01-03 13:08:19 UTC (rev 40206)
+++ grass/trunk/include/Make/Rules.make 2010-01-03 18:49:08 UTC (rev 40207)
@@ -22,7 +22,7 @@
$(INSTALL_DATA) $< $@
ifneq ($(MINGW),)
-mkpath = $(shell PATH="$(GISBASE)/bin:$(ARCH_LIBDIR):$$PATH" GISRC=$(RUN_GISRC) $(BIN)/g.dirseps$(EXE) -h $(1));$(2)
+mkpath = $(shell $(TOOLSDIR)/g.echo$(EXE) $(1));$(2)
else
mkpath = $(1):$(2)
endif
Property changes on: grass/trunk/tools
___________________________________________________________________
Added: svn:ignore
+ *OBJ*
Modified: grass/trunk/tools/Makefile
--- grass/trunk/tools/Makefile 2010-01-03 13:08:19 UTC (rev 40206)
+++ grass/trunk/tools/Makefile 2010-01-03 18:49:08 UTC (rev 40207)
@@ -3,8 +3,12 @@
SUBDIRS = timer g.html2man
include $(MODULE_TOPDIR)/include/Make/Dir.make
+include $(MODULE_TOPDIR)/include/Make/Compile.make
-default: parsubdirs $(TOOLSDIR)/mkhtml.py
+default: parsubdirs $(TOOLSDIR)/mkhtml.py $(TOOLSDIR)/g.echo$(EXE)
$(TOOLSDIR)/mkhtml.py: mkhtml.py
$(INSTALL) $< $@
+$(TOOLSDIR)/g.echo$(EXE): $(OBJDIR)/g.echo.o
+ $(CC) $(LDFLAGS) $(EXTRA_LDFLAGS) -o $@ $^
Added: grass/trunk/tools/g.echo.c
--- grass/trunk/tools/g.echo.c (rev 0)
+++ grass/trunk/tools/g.echo.c 2010-01-03 18:49:08 UTC (rev 40207)
@@ -0,0 +1,9 @@
+#include <stdio.h>
+int main(int argc, char **argv)
+ if (argc != 2)
+ return 1;
+ fputs(argv[1], stdout);
+ return 0;
