[GRASS-SVN] r40209 - in grass/trunk: include lib/raster
svn_grass at osgeo.org
Sun Jan 3 14:45:51 EST 2010
Author: glynn
Date: 2010-01-03 14:45:51 -0500 (Sun, 03 Jan 2010)
New Revision: 40209
grass/trunk/include/rasterdefs.h
grass/trunk/lib/raster/opencell.c
Generate fatal errors instead of returning status
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2010-01-03 19:45:04 UTC (rev 40208)
+++ grass/trunk/include/rasterdefs.h 2010-01-03 19:45:51 UTC (rev 40209)
@@ -390,14 +390,14 @@
int Rast_get_cell_format(CELL);
int Rast_open_fp_new(const char *);
int Rast_open_fp_new_uncompressed(const char *);
-int Rast_set_fp_type(RASTER_MAP_TYPE);
+void Rast_set_fp_type(RASTER_MAP_TYPE);
int Rast_map_is_fp(const char *, const char *);
RASTER_MAP_TYPE Rast_map_type(const char *, const char *);
RASTER_MAP_TYPE Rast__check_fp_type(const char *, const char *);
RASTER_MAP_TYPE Rast_get_map_type(int);
int Rast_open_new(const char *, RASTER_MAP_TYPE);
int Rast_open_new_uncompressed(const char *, RASTER_MAP_TYPE);
-int Rast_set_quant_rules(int, struct Quant *);
+void Rast_set_quant_rules(int, struct Quant *);
/* put_cellhd.c */
int Rast_put_cellhd(const char *, struct Cell_head *);
Modified: grass/trunk/lib/raster/opencell.c
--- grass/trunk/lib/raster/opencell.c 2010-01-03 19:45:04 UTC (rev 40208)
+++ grass/trunk/lib/raster/opencell.c 2010-01-03 19:45:51 UTC (rev 40209)
@@ -74,11 +74,10 @@
* \param map_type map type (CELL, FCELL, DCELL)
* \return open file descriptor ( >= 0) if successful
- * \return negative integer if error
-static int G__open_raster_new(const char *name, int open_mode,
- RASTER_MAP_TYPE map_type);
+static int open_raster_new(const char *name, int open_mode,
+ RASTER_MAP_TYPE map_type);
\brief Open an existing integer raster map (cell)
@@ -104,17 +103,11 @@
\param mapset mapset name where raster map <i>name</i> lives
\return nonnegative file descriptor (int)
- \return -1 on failure
int Rast_open_old(const char *name, const char *mapset)
- int fd;
+ int fd = Rast__open_old(name, mapset);
- if ((fd = Rast__open_old(name, mapset)) < 0) {
- G_warning(_("Unable to open raster map <%s>"), G_fully_qualified_name(name, mapset));
- return fd;
/* turn on auto masking, if not already on */
Rast__check_for_auto_masking();
@@ -150,7 +143,6 @@
\param mapset mapset of cell file to be opened
- \return -1 if error
int Rast__open_old(const char *name, const char *mapset)
@@ -175,10 +167,8 @@
name = xname;
mapset = xmapset;
- if (!G_find_raster2(name, mapset)) {
- G_warning(_("Unable to find <%s>"), G_fully_qualified_name(name, mapset));
- return -1;
+ if (!G_find_raster2(name, mapset))
+ G_fatal_error(_("Unable to find <%s>"), G_fully_qualified_name(name, mapset));
/* Check for reclassification */
reclass_flag = Rast_get_reclass(name, mapset, &reclass);
@@ -191,56 +181,52 @@
case 1:
r_name = reclass.name;
r_mapset = reclass.mapset;
- if (G_find_raster2(r_name, r_mapset) == NULL) {
- G_warning(_("Unable to open raster map <%s@%s> since it is a reclass "
- "of raster map <%s@%s> which does not exist"), name,
- mapset, r_name, r_mapset);
- return -1;
+ if (!G_find_raster2(r_name, r_mapset))
+ G_fatal_error(_("Unable to open raster map <%s@%s> since it is a reclass "
+ "of raster map <%s@%s> which does not exist"),
+ name, mapset, r_name, r_mapset);
break;
default: /* Error reading cellhd/reclass file */
- return -1;
+ G_fatal_error(_("Error reading reclass file for <%s>"),
+ G_fully_qualified_name(name, mapset));
+ break;
/* read the cell header */
if (Rast_get_cellhd(r_name, r_mapset, &cellhd) < 0)
- return -1;
+ G_fatal_error(_("Error reading cellhd file for <%s>"),
/* now check the type */
MAP_TYPE = Rast_map_type(r_name, r_mapset);
if (MAP_TYPE < 0)
- return -1;
+ G_fatal_error(_("Error reading map type for <%s>"),
if (MAP_TYPE == CELL_TYPE)
/* set the number of bytes for CELL map */
CELL_nbytes = cellhd.format + 1;
- if (CELL_nbytes < 1) {
- G_warning(_("Raster map <%s@%s>: format field in header file invalid"),
- r_name, r_mapset);
- return -1;
+ if (CELL_nbytes < 1)
+ G_fatal_error(_("Raster map <%s@%s>: format field in header file invalid"),
+ r_name, r_mapset);
- if (cellhd.proj != G__.window.proj) {
- G_warning(_("Raster map <%s@%s> is in different projection than current region. "
- "Found raster map <%s@%s>, should be <%s>."), name, mapset,
- name, G__projection_name(cellhd.proj),
- G__projection_name(G__.window.proj));
- return -1;
- if (cellhd.zone != G__.window.zone) {
- G_warning(_("Raster map <%s@%s> is in different zone (%d) than current region (%d)"),
- name, mapset, cellhd.zone, G__.window.zone);
- return -1;
+ if (cellhd.proj != G__.window.proj)
+ G_fatal_error(_("Raster map <%s> is in different projection than current region. "
+ "Found <%s>, should be <%s>."),
+ G_fully_qualified_name(name, mapset),
+ G__projection_name(cellhd.proj),
+ G__projection_name(G__.window.proj));
+ if (cellhd.zone != G__.window.zone)
+ G_fatal_error(_("Raster map <%s> is in different zone (%d) than current region (%d)"),
+ G_fully_qualified_name(name, mapset), cellhd.zone, G__.window.zone);
/* when map is int warn if too large cell size */
- if (MAP_TYPE == CELL_TYPE && (unsigned int)CELL_nbytes > sizeof(CELL)) {
- G_warning(_("Raster map <%s@%s>: bytes per cell (%d) too large"),
- name, mapset, CELL_nbytes);
- return -1;
+ if (MAP_TYPE == CELL_TYPE && (unsigned int)CELL_nbytes > sizeof(CELL))
+ G_fatal_error(_("Raster map <%s>: bytes per cell (%d) too large"),
+ G_fully_qualified_name(name, mapset), CELL_nbytes);
/* record number of bytes per cell */
if (MAP_TYPE == FCELL_TYPE) {
@@ -254,7 +240,6 @@
MAP_NBYTES = XDR_DOUBLE_NBYTES;
else { /* integer */
cell_dir = "cell";
INTERN_SIZE = sizeof(CELL);
MAP_NBYTES = CELL_nbytes;
@@ -266,9 +251,8 @@
/* dummy descriptor to reserve the fileinfo slot */
fd = open(G_DEV_NULL, O_RDONLY);
#else
- G_warning(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
- return -1;
+ G_fatal_error(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
#endif
else
@@ -276,7 +260,8 @@
fd = G_open_old(cell_dir, r_name, r_mapset);
if (fd < 0)
- return -1;
+ G_fatal_error(_("Unable to open %s file for map <%s@%s>"),
+ cell_dir, r_name, r_mapset);
fcb = new_fileinfo(fd);
@@ -309,7 +294,8 @@
/* check for compressed data format, making initial reads if necessary */
if (Rast__check_format(fd) < 0) {
close(fd); /* warning issued by check_format() */
- return -1;
+ G_fatal_error(_("Error reading format for <%s@%s>"),
/* create the mapping from cell file to window */
@@ -386,7 +372,7 @@
int Rast_open_c_new(const char *name)
- return G__open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
@@ -401,7 +387,7 @@
int Rast_open_c_new_uncompressed(const char *name)
- return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
@@ -472,11 +458,10 @@
\param name map name
- \return -1 on error
int Rast_open_fp_new(const char *name)
- return G__open_raster_new(name, OPEN_NEW_COMPRESSED, R__.fp_type);
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, R__.fp_type);
@@ -487,24 +472,23 @@
int Rast_open_fp_new_uncompressed(const char *name)
- return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, R__.fp_type);
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, R__.fp_type);
#ifdef HAVE_GDAL
-static int G__open_raster_new_gdal(char *map, char *mapset,
+static int open_raster_new_gdal(char *map, char *mapset,
int fd;
struct fileinfo *fcb;
- fd = open("/dev/null", O_RDONLY);
+ fd = open(G_DEV_NULL, O_RDONLY);
if (fd < 0)
- return -1;
+ G_fatal_error(_("Unable to open null device"));
@@ -514,7 +498,7 @@
fcb->gdal = Rast_create_gdal_link(map, map_type);
if (!fcb->gdal)
- return -1;
+ G_fatal_error(_("Unable to create GDAL link"));
fcb->cellhd = G__.window;
fcb->cellhd.compressed = 0;
@@ -557,8 +541,8 @@
#endif /* HAVE_GDAL */
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
@@ -596,25 +580,22 @@
mapset = G_store(xmapset);
/* check for legal grass name */
- if (G_legal_filename(map) < 0) {
- G_warning(_("<%s> is an illegal file name"), map);
- return -1;
+ if (G_legal_filename(map) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), map);
#ifdef HAVE_GDAL
if (G_find_file2("", "GDAL", G_mapset()))
- return G__open_raster_new_gdal(map, mapset, map_type);
+ return open_raster_new_gdal(map, mapset, map_type);
#endif
/* open a tempfile name */
tempname = G_tempfile();
fd = creat(tempname, 0666);
if (fd < 0) {
- G_warning(_("G__open_raster_new(): no temp files available"));
G_free(mapset);
G_free(tempname);
G_free(map);
- return -1;
+ G_fatal_error(_("No temp files available"));
@@ -678,13 +659,12 @@
fcb->null_fd = creat(tempname, 0666);
if (fcb->null_fd < 0) {
G_free(tempname);
G_free(fcb->name);
G_free(fcb->mapset);
G_free(fcb->temp_name);
close(fd);
- return -1;
+ G_fatal_error(_("no temp files available"));
fcb->null_temp_name = tempname;
@@ -725,10 +705,9 @@
\param type raster data type
- \return 1 on success
+ \return void
-int Rast_set_fp_type(RASTER_MAP_TYPE map_type)
+void Rast_set_fp_type(RASTER_MAP_TYPE map_type)
Rast__init();
@@ -736,10 +715,10 @@
case FCELL_TYPE:
case DCELL_TYPE:
R__.fp_type = map_type;
- return 1;
+ break;
default:
- G_warning(_("Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
- return -1;
+ G_fatal_error(_("Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
+ break;
@@ -761,13 +740,14 @@
const char *xmapset;
xmapset = G_find_raster2(name, mapset);
- if (!xmapset) {
- G_warning(_("Unable to find <%s@%s>"), name, mapset);
- return -1;
+ if (!xmapset)
G__file_name(path, "fcell", name, xmapset);
if (access(path, 0) == 0)
return 1;
G__file_name(path, "g3dcell", name, xmapset);
return 1;
@@ -795,12 +775,12 @@
if (!xmapset) {
if (mapset && *mapset)
- G_warning(_("Raster map <%s> not found in mapset <%s>"), name,
- mapset);
+ G_fatal_error(_("Raster map <%s> not found in mapset <%s>"),
+ name, mapset);
else
- G_warning(_("Raster map <%s> not found"), name);
- return -1;
+ G_fatal_error(_("Raster map <%s> not found"), name);
@@ -850,35 +830,32 @@
- if (!xmapset) {
- return -1;
+ if (!xmapset)
G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
- if (access(path, 0) != 0) {
- G_warning(_("Unable to find '%s'"), path);
- return -1;
+ if (access(path, 0) != 0)
+ G_fatal_error(_("Unable to find '%s'"), path);
format_keys = G_read_key_value_file(path, &in_stat);
- if (in_stat != 0) {
- G_warning(_("Unable to open '%s'"), path);
- return -1;
+ if (in_stat != 0)
+ G_fatal_error(_("Unable to open '%s'"), path);
if ((str = G_find_key_value("type", format_keys)) != NULL) {
if (strcmp(str, "double") == 0)
map_type = DCELL_TYPE;
else if (strcmp(str, "float") == 0)
map_type = FCELL_TYPE;
else {
- G_warning(_("Invalid type: field '%s' in file '%s'"), str, path);
G_free_key_value(format_keys);
- return -1;
+ G_fatal_error(_("Invalid type: field '%s' in file '%s'"), str, path);
else {
- return -1;
+ G_fatal_error(_("Missing type: field in file '%s'"), path);
if ((str1 = G_find_key_value("byte_order", format_keys)) != NULL) {
@@ -909,11 +886,10 @@
\param wr_type raster data type
int Rast_open_new(const char *name, RASTER_MAP_TYPE wr_type)
- return G__open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
+ return open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
@@ -925,11 +901,10 @@
int Rast_open_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
- return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
+ return open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
@@ -944,27 +919,26 @@
\param fd file descriptor (cell file)
\param q pointer to Quant structure
- \return 0 success
- \return -1 failure
+ \return void
-int Rast_set_quant_rules(int fd, struct Quant *q)
+void Rast_set_quant_rules(int fd, struct Quant *q)
struct fileinfo *fcb = &R__.fileinfo[fd];
CELL cell;
DCELL dcell;
struct Quant_table *p;
- if (fcb->open_mode != OPEN_OLD) {
- G_warning(_("Rast_set_quant_rules() can be called only for "
- "raster maps opened for reading"));
- return -1;
+ if (fcb->open_mode != OPEN_OLD)
+ G_fatal_error(_("Rast_set_quant_rules() can be called only for "
+ "raster maps opened for reading"));
/* copy all info from q to fcb->quant) */
Rast_quant_init(&fcb->quant);
if (q->truncate_only) {
Rast_quant_truncate(&fcb->quant);
- return 0;
+ return;
for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--)
Rast_quant_add_rule(&fcb->quant, p->dLow, p->dHigh, p->cLow,
p->cHigh);
@@ -972,6 +946,4 @@
Rast_quant_set_neg_infinite_rule(&fcb->quant, dcell, cell);
if (Rast_quant_get_pos_infinite_rule(q, &dcell, &cell) > 0)
Rast_quant_set_pos_infinite_rule(&fcb->quant, dcell, cell);
- return 0;
