[GRASS-SVN] r40216 - in grass/trunk/lib: gpde ogsf rst/interp_float
svn_grass at osgeo.org
Mon Jan 4 09:47:50 EST 2010
Author: glynn
Date: 2010-01-04 09:47:50 -0500 (Mon, 04 Jan 2010)
New Revision: 40216
grass/trunk/lib/gpde/N_arrays_io.c
grass/trunk/lib/ogsf/Gs3.c
grass/trunk/lib/rst/interp_float/output2d.c
grass/trunk/lib/rst/interp_float/resout2d.c
No need to check return value from Rast_open_* - part 2 - libraries
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c 2010-01-04 14:39:31 UTC (rev 40215)
+++ grass/trunk/lib/gpde/N_arrays_io.c 2010-01-04 14:47:50 UTC (rev 40216)
@@ -53,9 +53,6 @@
struct Cell_head region;
N_array_2d *data = array;
- if (NULL == G_find_raster2(name, ""))
- G_fatal_error(_("Raster map <%s> not found"), name);
/* Get the active region */
G_get_set_window(®ion);
@@ -64,9 +61,7 @@
cols = region.cols;
/*open the raster map */
- map = Rast_open_old(name, G_find_raster2(name, ""));
- if (map < 0)
- G_fatal_error(_("Unable to open raster map <%s>"), name);
+ map = Rast_open_old(name, "");
type = Rast_get_map_type(map);
@@ -200,8 +195,6 @@
/*Open the new map */
map = Rast_open_new(name, type);
- if (map < 0)
- G_fatal_error(_("Unable to create raster map <%s>"), name);
if (type == CELL_TYPE)
rast = Rast_allocate_buf(type);
Modified: grass/trunk/lib/ogsf/Gs3.c
--- grass/trunk/lib/ogsf/Gs3.c 2010-01-04 14:39:31 UTC (rev 40215)
+++ grass/trunk/lib/ogsf/Gs3.c 2010-01-04 14:47:50 UTC (rev 40216)
@@ -134,9 +134,7 @@
G_fatal_error(_("Unable to allocate memory for a null buffer"));
- if ((cellfile = Rast_open_old(map_name, map_set)) == -1) {
- G_fatal_error(_("Unable to open raster map <%s>"), map_name);
+ cellfile = Rast_open_old(map_name, map_set);
G_message(_("Loading raster map <%s>..."),
G_fully_qualified_name(map_name, map_set));
@@ -209,9 +207,7 @@
@@ -367,9 +363,7 @@
tmp_buf = (int *)G_malloc(wind->cols * sizeof(int)); /* G_fatal_error */
if (!tmp_buf) {
@@ -483,9 +477,7 @@
if (!tmp_buf) {
@@ -574,9 +566,7 @@
return -1;
if (!tmp_buf) {
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c 2010-01-04 14:39:31 UTC (rev 40215)
+++ grass/trunk/lib/rst/interp_float/output2d.c 2010-01-04 14:47:50 UTC (rev 40216)
@@ -61,58 +61,23 @@
* G_set_embedded_null_value_mode(1);
- if (params->elev != NULL) {
+ if (params->elev)
cf1 = Rast_open_fp_new(params->elev);
- if (cf1 < 0) {
- G_warning(_("Unable to create raster map <%s>"), params->elev);
- return -1;
- if (params->slope != NULL) {
+ if (params->slope)
cf2 = Rast_open_fp_new(params->slope);
- if (cf2 < 0) {
- params->slope);
- return -1;
- if (params->aspect != NULL) {
+ if (params->aspect)
cf3 = Rast_open_fp_new(params->aspect);
- if (cf3 < 0) {
- params->aspect);
- return -1;
- if (params->pcurv != NULL) {
+ if (params->pcurv)
cf4 = Rast_open_fp_new(params->pcurv);
- if (cf4 < 0) {
- params->pcurv);
- return -1;
- if (params->tcurv != NULL) {
+ if (params->tcurv)
cf5 = Rast_open_fp_new(params->tcurv);
- if (cf5 < 0) {
- params->tcurv);
- return -1;
- if (params->mcurv != NULL) {
+ if (params->mcurv)
cf6 = Rast_open_fp_new(params->mcurv);
- if (cf6 < 0) {
- params->mcurv);
- return -1;
nrows = cellhd->rows;
if (nrows != params->nsizr) {
Modified: grass/trunk/lib/rst/interp_float/resout2d.c
--- grass/trunk/lib/rst/interp_float/resout2d.c 2010-01-04 14:39:31 UTC (rev 40215)
+++ grass/trunk/lib/rst/interp_float/resout2d.c 2010-01-04 14:47:50 UTC (rev 40216)
@@ -66,59 +66,23 @@
cell1 = Rast_allocate_f_buf();
+ if (params->elev)
- if (cf1 < 0) {
- params->elev);
- return -1;
- if (cf2 < 0) {
- params->elev);
- return -1;
- if (cf3 < 0) {
- params->elev);
- return -1;
- if (cf4 < 0) {
- params->elev);
- return -1;
- if (cf5 < 0) {
- params->elev);
- return -1;
- if (cf6 < 0) {
- params->elev);
- return -1;
nrows = outhd->rows;
