[GRASS-SVN] r40219 - grass/trunk/lib/raster
svn_grass at osgeo.org
Mon Jan 4 13:49:33 EST 2010
Author: martinl
Date: 2010-01-04 13:49:33 -0500 (Mon, 04 Jan 2010)
New Revision: 40219
grass/trunk/lib/raster/opencell.c
message cosmetics
Modified: grass/trunk/lib/raster/opencell.c
--- grass/trunk/lib/raster/opencell.c 2010-01-04 16:34:50 UTC (rev 40218)
+++ grass/trunk/lib/raster/opencell.c 2010-01-04 18:49:33 UTC (rev 40219)
@@ -168,7 +168,8 @@
mapset = xmapset;
if (!G_find_raster2(name, mapset))
- G_fatal_error(_("Unable to find <%s>"), G_fully_qualified_name(name, mapset));
+ G_fatal_error(_("Raster map <%s> not found"),
+ G_fully_qualified_name(name, mapset));
/* Check for reclassification */
reclass_flag = Rast_get_reclass(name, mapset, &reclass);
@@ -187,7 +188,7 @@
name, mapset, r_name, r_mapset);
break;
default: /* Error reading cellhd/reclass file */
- G_fatal_error(_("Error reading reclass file for <%s>"),
+ G_fatal_error(_("Error reading reclass file for raster map <%s>"),
break;
@@ -198,7 +199,7 @@
/* now check the type */
MAP_TYPE = Rast_map_type(r_name, r_mapset);
if (MAP_TYPE < 0)
- G_fatal_error(_("Error reading map type for <%s>"),
+ G_fatal_error(_("Error reading map type for raster map <%s>"),
if (MAP_TYPE == CELL_TYPE)
@@ -249,7 +250,7 @@
/* dummy descriptor to reserve the fileinfo slot */
fd = open(G_DEV_NULL, O_RDONLY);
#else
- G_fatal_error(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
+ G_fatal_error(_("Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
r_name, r_mapset);
#endif
@@ -258,7 +259,7 @@
fd = G_open_old(cell_dir, r_name, r_mapset);
if (fd < 0)
- G_fatal_error(_("Unable to open %s file for map <%s@%s>"),
+ G_fatal_error(_("Unable to open %s file for raster map <%s@%s>"),
fcb = new_fileinfo(fd);
@@ -739,7 +740,7 @@
xmapset = G_find_raster2(name, mapset);
if (!xmapset)
G__file_name(path, "fcell", name, xmapset);
@@ -829,7 +830,7 @@
if (!xmapset)
G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
