[GRASS-SVN] r40251 - grass-addons/raster/r.stream.basins
svn_grass at osgeo.org
Tue Jan 5 08:50:07 EST 2010
Author: jarekj71
Date: 2010-01-05 08:50:07 -0500 (Tue, 05 Jan 2010)
New Revision: 40251
grass-addons/raster/r.stream.basins/catchment.c
update
Modified: grass-addons/raster/r.stream.basins/catchment.c
--- grass-addons/raster/r.stream.basins/catchment.c 2010-01-05 13:45:10 UTC (rev 40250)
+++ grass-addons/raster/r.stream.basins/catchment.c 2010-01-05 13:50:07 UTC (rev 40251)
@@ -25,20 +25,24 @@
int nextr[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int nextc[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
- G_message(_("Finding nodes..."));
+ G_message("Finding nodes...");
outlets = (OUTLET *) G_malloc((out_max) * sizeof(OUTLET));
outlets_num = 0;
for (r = 0; r < nrows; ++r) {
for (c = 0; c < ncols; ++c) {
- if (streams[r][c] > 0) {
- if (outlets_num > (out_max - 1)) {
- outlets =
- (OUTLET *) G_realloc(outlets,
- out_max * 2 * sizeof(OUTLET));
+ if (streams[r][c] > 0) {
+ if (outlets_num > 2*(out_max - 1))
+ G_fatal_error("Stream and direction maps probably do not match");
+ if (outlets_num > (out_max - 1))
+ outlets = (OUTLET *) G_realloc(outlets,
+ out_max * 2 * sizeof(OUTLET));
d = abs(dirs[r][c]); /* abs */
if (r + nextr[d] < 0 || r + nextr[d] > (nrows - 1) ||
c + nextc[d] < 0 || c + nextc[d] > (ncols - 1)) {
@@ -51,10 +55,16 @@
if (d == 0)
next_stream = -1;
cur_stream = streams[r][c];
if (lasts) {
if (cur_stream != next_stream && next_stream < 0) { /* is outlet! */
+ if (categories) { /* but not in list */
+ if (categories[streams[r][c]]==-1)
+ continue;
outlets[outlets_num].r = r;
outlets[outlets_num].c = c;
outlets[outlets_num].val =
@@ -64,6 +74,12 @@
else {
if (cur_stream != next_stream) { /* is outlet or node! */
+ continue;
@@ -90,19 +106,22 @@
int reset_catchments(void)
- int r, c, i;
+ int r, c, i;
- streams[r][c] = 0;
+ streams[r][c] = 0;
- for (i = 0; i < outlets_num; ++i) {
+ if (in_streams) {
+ for (i = 0; i < outlets_num; ++i)
streams[outlets[i].r][outlets[i].c] = outlets[i].val;
return 0;
algorithm uses fifo queue for determining basins area.
