[GRASS-SVN] r40254 - grass-addons/raster/r.stream.basins
Tue Jan 5 09:10:20 EST 2010
Author: jarekj71
Date: 2010-01-05 09:10:20 -0500 (Tue, 05 Jan 2010)
New Revision: 40254
Added:
   grass-addons/raster/r.stream.basins/main.c
Removed:
update
Deleted: grass-addons/raster/r.stream.basins/main.c
--- grass-addons/raster/r.stream.basins/main.c	2010-01-05 13:59:11 UTC (rev 40253)
+++ grass-addons/raster/r.stream.basins/main.c	2010-01-05 14:10:20 UTC (rev 40254)
@@ -1,128 +0,0 @@
- * MODULE:       r.stream.basins
- * AUTHOR(S):    Jarek Jasiewicz jarekj amu.edu.pl
- * PURPOSE:      Calculate basins according user' input data.
- *               It uses r.stream.order or r.watershed stream  map
- *               and r.watershed  direction map.
- *               Stream input map shall contains streams or points outlels
- *               with or without unique own categories
- *               If input stream comes from r..stream.exteract direction map
- *               from r.stream.extract must be patched with that of r.watersheed.
- * COPYRIGHT:    (C) 2002,2009 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 	  for details.
-#define MAIN
-#include <grass/glocale.h>
-#include "global.h"
- * main function
-int main(int argc, char *argv[])
-    struct GModule *module;	/* GRASS module for parsing arguments */
-    struct Option *in_dir_opt, *in_stm_opt, *out_opt;	/* options */
-    struct Flag *out_back, *out_cat, *out_last;	/* flags */
-    int link_max;
-    /* initialize GIS environment */
-    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
-    /* initialize module */
-    module = G_define_module();
-    module->keywords = _("stream, order, catchments");
-    module->description = _("Calculate basins according user' input");
-    in_stm_opt = G_define_option();	/* input stream mask file - optional */
-    in_stm_opt->key = "stream";
-    in_stm_opt->type = TYPE_STRING;
-    in_stm_opt->required = YES;	/* for now; TO DO: is planned to be optional */
-    in_stm_opt->gisprompt = "old,cell,raster";
-    in_stm_opt->description = "Name of stream mask input map";
-    in_dir_opt = G_define_option();	/* input directon file */
-    in_dir_opt->key = "dir";
-    in_dir_opt->type = TYPE_STRING;
-    in_dir_opt->required = YES;
-    in_dir_opt->gisprompt = "old,cell,raster";
-    in_dir_opt->description = "Name of flow direction input map";
-    /*  output option - at least one is reqired  */
-    out_opt = G_define_option();
-    out_opt->key = "basins";
-    out_opt->type = TYPE_STRING;
-    out_opt->required = YES;
-    out_opt->answer = NULL;
-    out_opt->gisprompt = "new,cell,raster";
-    out_opt->description = "Output basin map";
-    /* Define the different flags */
-    out_back = G_define_flag();
-    out_back->key = 'z';
-    out_back->description = _("Create zero-value background instead of NULL");
-    out_cat = G_define_flag();
-    out_cat->key = 'c';
-    out_cat->description =
-	_("Use unique category sequence instead of input streams");
-    out_last = G_define_flag();
-    out_last->key = 'l';
-    out_last->description = _("Create basins only for last stream links");
-    if (G_parser(argc, argv))	/* parser */
-	exit(EXIT_FAILURE);
-    /* stores input options to variables */
-    in_dirs = in_dir_opt->answer;
-    in_streams = in_stm_opt->answer;
-    name_catchments = out_opt->answer;
-    zeros = (out_back->answer != 0);
-    cats = (out_cat->answer != 0);
-    lasts = (out_last->answer != 0);
-    if (G_legal_filename(name_catchments) < 0)
-	G_fatal_error(_("<%s> is an illegal file name"), name_catchments);
-    G_get_window(&window);
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    create_maps();
-    link_max = max_link();
-    find_outlets();
-	int j;
-	reset_catchments();
-	G_message(_("Calculate basins..."));
-	fifo_max = 4 * (nrows + ncols);
-	fifo_outlet = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
-	/* fifo queue for contributing cell */
-	for (j = 0; j < outlets_num; ++j) {
-	    fill_catchments(outlets[j]);
-	G_free(fifo_outlet);
-	if (!zeros)
-	    set_null();
-	write_chatchment();
-    exit(EXIT_SUCCESS);
Added: grass-addons/raster/r.stream.basins/main.c
--- grass-addons/raster/r.stream.basins/main.c	                        (rev 0)
@@ -0,0 +1,185 @@
+ * MODULE:       r.stream.basins
+ * AUTHOR(S):    Jarek Jasiewicz jarekj amu.edu.pl
+ * PURPOSE:      Calculate basins according user' input data.
+ *               It uses r.stream.order or r.watershed stream  map
+ *               and r.watershed  direction map.
+ *               Stream input map shall contains streams or points outlels
+ *               with or without unique own categories
+ *               If input stream comes from r..stream.exteract direction map
+ *               from r.stream.extract must be patched with that of r.watersheed.
+ * COPYRIGHT:    (C) 2002,2009 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 	  for details.
+#define MAIN
+#include <grass/glocale.h>
+#include "global.h"
+ * main function
+int main(int argc, char *argv[])
+    struct GModule *module;	/* GRASS module for parsing arguments */
+    struct Option *in_dir_opt, *in_coor_opt, *in_stm_opt, *in_stm_cat_opt, * in_point_opt, *out_opt;	/* options */
+    struct Flag *out_back, *out_cat, *out_last;	/* flags */
+    int b_test=0; /* test which option have been choosed: like chmod */
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    module->keywords = _("stream, order, catchments");
+    module->description = _("Calculate basins according user' input");
+    in_dir_opt = G_define_option();	/* input directon file */
+    in_dir_opt->key = "dir";
+    in_dir_opt->type = TYPE_STRING;
+    in_dir_opt->required = YES;
+    in_dir_opt->gisprompt = "old,cell,raster";
+    in_dir_opt->description = "Name of flow direction input map";
+	  in_coor_opt = G_define_option();	/* input coordinates de outlet */
+    in_coor_opt->key = "coors";
+    in_coor_opt->type = TYPE_STRING;
+    in_coor_opt->key_desc = "x,y";
+    in_coor_opt->answers = NULL;
+    in_coor_opt->required = NO;
+    in_coor_opt->multiple = YES;
+    in_coor_opt->description = "Basin's outlet's coordinates: E,N";
+	  in_stm_opt = G_define_option();	/* input stream mask file - optional */
+    in_stm_opt->key = "stream";
+    in_stm_opt->type = TYPE_STRING;
+    in_stm_opt->required = NO;
+    in_stm_opt->gisprompt = "old,cell,raster";
+    in_stm_opt->description = "Name of stream mask input map";
+    in_stm_cat_opt = G_define_option();	/* input stream mask file - optional */
+    in_stm_cat_opt->key = "cats";
+    in_stm_cat_opt->type = TYPE_STRING;
+    in_stm_cat_opt->required = NO;
+    in_stm_cat_opt->multiple = YES;
+    in_stm_cat_opt->description = "Create basins only for that categories:";
+    in_point_opt = G_define_option();	/* input point outputs - optional */
+    in_point_opt->key = "points";
+    in_point_opt->type = TYPE_STRING;
+    in_point_opt->required = NO;
+    in_point_opt->answer = NULL;
+    in_point_opt->gisprompt = "old,vector,vector";
+    in_point_opt->description = "Name of vector points map";
+    /*  output option - at least one is reqired  */
+    out_opt = G_define_option();
+    out_opt->key = "basins";
+    out_opt->type = TYPE_STRING;
+    out_opt->required = YES;
+    out_opt->answer = NULL;
+    out_opt->gisprompt = "new,cell,raster";
+    out_opt->description = "Output basin map";
+    /* Define the different flags */
+    out_back = G_define_flag();
+    out_back->key = 'z';
+    out_back->description = _("Create zero-value background instead of NULL");
+    out_cat = G_define_flag();
+    out_cat->key = 'c';
+    out_cat->description =
+	_("Use unique category sequence instead of input streams");
+    out_last = G_define_flag();
+    out_last->key = 'l';
+    out_last->description = _("Create basins only for last stream links");
+    if (G_parser(argc, argv))	/* parser */
+	exit(EXIT_FAILURE);
+		if (!in_coor_opt->answers && !in_stm_opt->answer && !in_point_opt->answer)
+	G_fatal_error("Basin's outlet definition is required");
+		if (in_coor_opt->answers)
+	b_test += 1;
+		if (in_stm_opt->answer)
+	b_test += 2;
+		if (in_point_opt->answer)
+	b_test += 4;
+	if (b_test != 1 && b_test != 2 && b_test != 4)
+	G_fatal_error("Only one outlet definition is allowed");
+    /* stores input options to variables */
+    in_dirs = in_dir_opt->answer;
+    in_streams = in_stm_opt->answer;
+    name_catchments = out_opt->answer;
+    in_point = in_point_opt->answer;
+    zeros = (out_back->answer != 0);
+    cats = (out_cat->answer != 0);
+    lasts = (out_last->answer != 0);
+    if (G_legal_filename(name_catchments) < 0)
+	G_fatal_error(_("<%s> is an illegal basin name"), name_catchments);
+    G_get_window(&window);
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    create_maps();
+  switch (b_test) {
+		case 1:
+			G_message("Calculate basins using coordinates...");
+			process_coors (in_coor_opt->answers);
+			outlets_num=1;
+		break;
+		case 2:
+			G_message("Calculate basins using streams...");
+			categories=NULL;
+			process_cats (in_stm_cat_opt->answers);
+			find_outlets();
+		break;
+		case 4:
+			G_message("Calculate basins using point file...");
+			outlets_num=process_vector(in_point);
+		break;
+	int j;
+	reset_catchments();
+	fifo_max = 4 * (nrows + ncols);
+	fifo_outlet = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
+	for (j = 0; j < outlets_num; ++j) {
+	  fill_catchments(outlets[j]);
+	G_free(fifo_outlet);
+	if (!zeros)
+	    set_null();
+	write_chatchment();
+    exit(EXIT_SUCCESS);
