[GRASS-SVN] r40262 - in grass/trunk: include lib/vector/Vlib
svn_grass at osgeo.org
Tue Jan 5 15:14:53 EST 2010
Author: martinl
Date: 2010-01-05 15:14:52 -0500 (Tue, 05 Jan 2010)
New Revision: 40262
grass/trunk/include/vector.h
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/Vlib/write.c
grass/trunk/lib/vector/Vlib/write_nat.c
grass/trunk/lib/vector/Vlib/write_ogr.c
libvect: implement V1_read_line_ogr and V1/V2_rewrite_line()
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h 2010-01-05 16:33:06 UTC (rev 40261)
+++ grass/trunk/include/vector.h 2010-01-05 20:14:52 UTC (rev 40262)
@@ -475,6 +475,8 @@
/* Read/write lines */
int V1_read_line_nat(struct Map_info *, struct line_pnts *,
struct line_cats *, off_t);
+int V1_read_line_ogr(struct Map_info *, struct line_pnts *,
+ struct line_cats *, off_t);
int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
struct line_cats *);
int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
@@ -503,12 +505,12 @@
const struct line_cats *);
off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
const struct line_pnts *, const struct line_cats *);
+off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
+ const struct line_pnts *, const struct line_cats *);
int V2_rewrite_line_nat(struct Map_info *, int, int,
-#if 0
-off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
- struct line_pnts *, struct line_cats *);
-#endif
+int V2_rewrite_line_ogr(struct Map_info *, int, int,
/* Build topology */
int Vect_build_nat(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2010-01-05 16:33:06 UTC (rev 40261)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2010-01-05 20:14:52 UTC (rev 40262)
@@ -1,16 +1,17 @@
- \file read_ogr.c
+ \file lib/vector/Vlib/read_ogr.c
\brief Vector library - reading data (OGR format)
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2010 by the GRASS Development Team
This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author Radim Blazek, Piero Cavalieri
+ \author Martin Landa <landa.martin gmail.com>
#include <grass/config.h>
@@ -24,14 +25,14 @@
* \brief Recursively read feature and add all elements to points_cache and types_cache.
- * ftype : if > 0 use this type (because parts of Polygon are read as wkbLineString)
+ * ftype: if > 0 use this type (because parts of Polygon are read as wkbLineString)
- * \param Map vector map layer
+ * \param Map pointer to Map_info structure
* \param[out] hGeom OGR geometry
* \param ftype feature type
- * \return 0 OK
- * \return 1 error
+ * \return 0 on success
+ * \return 1 on error
static int cache_feature(struct Map_info *Map, OGRGeometryH hGeom, int ftype)
@@ -39,7 +40,7 @@
OGRwkbGeometryType type;
OGRGeometryH hGeom2;
- G_debug(4, "cache_feature");
+ G_debug(4, "cache_feature() ftype = %d", ftype);
/* Alloc space */
line = Map->fInfo.ogr.lines_num;
@@ -54,8 +55,7 @@
(int *)G_realloc(Map->fInfo.ogr.lines_types,
Map->fInfo.ogr.lines_alloc * sizeof(int));
- for (i = Map->fInfo.ogr.lines_num; i < Map->fInfo.ogr.lines_alloc;
- i++)
+ for (i = Map->fInfo.ogr.lines_num; i < Map->fInfo.ogr.lines_alloc; i++)
Map->fInfo.ogr.lines[i] = Vect_new_line_struct();
@@ -121,24 +121,23 @@
- * \brief Read next line from OGR layer. Skip empty features.
+ * \brief Read next feature from OGR layer. Skip empty features. (level 1)
* The action of this routine can be modified by:
* - Vect_read_constraint_region()
* - Vect_read_constraint_type()
* - Vect_remove_constraints()
* \param[out] line_p container used to store line points within
* \param[out] line_c container used to store line categories within
- * \return line type
- * \return -2 no more features (EOF)
- * \return -1 out of memory
+ * \return feature type
+ * \return -2 no more features (EOF)
+ * \return -1 out of memory
-int
-V1_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
- struct line_cats *line_c)
+int V1_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
+ struct line_cats *line_c)
int itype;
struct bound_box lbox, mbox;
@@ -219,21 +218,22 @@
Map->fInfo.ogr.lines_next++;
G_debug(4, "next line read, type = %d", itype);
- return (itype);
+ return itype;
return -2; /* not reached */
+ * \brief Read next feature from OGR layer (topology level).
int
V2_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
@@ -248,13 +248,13 @@
* \brief Recursively descend to feature and read the part
* \param hGeom OGR geometry
* \param offset given offset
* \param[out] Points container used to store line pointes within
- * \return 0 OK
- * \return 1 error
+ * \return -1 on error
static int read_line(const struct Map_info *Map, OGRGeometryH hGeom, long offset,
struct line_pnts *Points)
@@ -274,19 +274,23 @@
switch (eType) {
case wkbPoint:
G_debug(4, "Point");
- Vect_append_point(Points, OGR_G_GetX(hGeom, 0), OGR_G_GetY(hGeom, 0),
- OGR_G_GetZ(hGeom, 0));
- return 0;
+ if (Points) {
+ Vect_append_point(Points, OGR_G_GetX(hGeom, 0), OGR_G_GetY(hGeom, 0),
+ OGR_G_GetZ(hGeom, 0));
+ return GV_POINT;
break;
case wkbLineString:
- G_debug(4, "LineString");
- nPoints = OGR_G_GetPointCount(hGeom);
- for (i = 0; i < nPoints; i++) {
- Vect_append_point(Points, OGR_G_GetX(hGeom, i),
- OGR_G_GetY(hGeom, i), OGR_G_GetZ(hGeom, i));
+ G_debug(4, "LineString");
+ if (Points) {
+ nPoints = OGR_G_GetPointCount(hGeom);
+ for (i = 0; i < nPoints; i++) {
+ Vect_append_point(Points, OGR_G_GetX(hGeom, i),
+ OGR_G_GetY(hGeom, i), OGR_G_GetZ(hGeom, i));
- return 0;
+ return GV_LINE;
break;
case wkbPolygon:
@@ -303,99 +307,183 @@
G_warning(_("OGR feature type %d not supported"), eType);
break;
- return 1;
+ return -1;
- * \brief Read line from layer on given offset.
+ * \brief Recursively descend to feature and read the part
+ * \param hGeom OGR geometry
+ * \param offset given offset
+ * \param[out] Points container used to store line pointes within
+static int get_line_type(const struct Map_info *Map, long FID)
+ int eType;
+ OGRFeatureH hFeat;
+ OGRGeometryH hGeom;
+ G_debug(4, "get_line_type() fid = %ld", FID);
+ hFeat = OGR_L_GetFeature(Map->fInfo.ogr.layer, FID);
+ if (hFeat == NULL)
+ return -1;
+ hGeom = OGR_F_GetGeometryRef(hFeat);
+ if (hGeom == NULL)
+ return -1;
+ eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
+ OGR_F_Destroy(hFeat);
+ G_debug(4, "OGR Geometry of type: %d", eType);
+ switch (eType) {
+ case wkbPoint:
+ case wkbMultiPoint:
+ return GV_POINT;
+ break;
+ case wkbLineString:
+ case wkbMultiLineString:
+ return GV_LINE;
+ break;
+ case wkbPolygon:
+ case wkbMultiPolygon:
+ case wkbGeometryCollection:
+ return GV_BOUNDARY;
+ break;
+ default:
+ G_warning(_("OGR feature type %d not supported"), eType);
+ break;
+ return -1;
+ * \brief Read feature from OGR layer at given offset (level 1)
- * \param line line id
* \return line type
- * \return -2 end of table (last row)
+ * \return 0 dead line
-int
-V2_read_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
- struct line_cats *line_c, int line)
+int V1_read_line_ogr(struct Map_info *Map,
+ struct line_pnts *line_p, struct line_cats *line_c, off_t offset)
- int node;
- int offset;
long FID;
- struct P_line *Line;
- struct P_node *Node;
+ int type;
OGRGeometryH hGeom;
- G_debug(4, "V2_read_line_ogr() line = %d", line);
+ G_debug(4, "V1_read_line_ogr() offset = %lu", (long) offset);
+ if (offset >= Map->fInfo.ogr.offset_num)
+ return -2;
if (line_p != NULL)
Vect_reset_line(line_p);
if (line_c != NULL)
Vect_reset_cats(line_c);
- Line = Map->plus.Line[line];
- offset = (int)Line->offset;
if (Line->type == GV_CENTROID) {
G_debug(4, "Centroid");
node = Line->N1;
Node = Map->plus.Node[node];
- /* coordinates */
if (line_p != NULL) {
Vect_append_point(line_p, Node->x, Node->y, 0.0);
- /* category */
if (line_c != NULL) {
- /* cat = FID and offset = FID for centroid */
+ cat = FID and offset = FID for centroid
Vect_cat_set(line_c, 1, (int)offset);
return (GV_CENTROID);
- else {
- FID = Map->fInfo.ogr.offset[offset];
- G_debug(4, " FID = %ld", FID);
- /* coordinates */
- if (line_p != NULL) {
- /* Read feature to cache if necessary */
- if (Map->fInfo.ogr.feature_cache_id != FID) {
- G_debug(4, "Read feature (FID = %ld) to cache.", FID);
- if (Map->fInfo.ogr.feature_cache) {
- OGR_F_Destroy(Map->fInfo.ogr.feature_cache);
- Map->fInfo.ogr.feature_cache =
- OGR_L_GetFeature(Map->fInfo.ogr.layer, FID);
- if (Map->fInfo.ogr.feature_cache == NULL) {
- G_fatal_error(_("Unable to get feature geometry, FID %ld"),
- FID);
- Map->fInfo.ogr.feature_cache_id = FID;
+ FID = Map->fInfo.ogr.offset[offset];
+ G_debug(4, " FID = %ld", FID);
+ /* coordinates */
+ if (line_p != NULL) {
+ /* Read feature to cache if necessary */
+ if (Map->fInfo.ogr.feature_cache_id != FID) {
+ G_debug(4, "Read feature (FID = %ld) to cache.", FID);
+ if (Map->fInfo.ogr.feature_cache) {
+ OGR_F_Destroy(Map->fInfo.ogr.feature_cache);
- hGeom = OGR_F_GetGeometryRef(Map->fInfo.ogr.feature_cache);
- if (hGeom == NULL) {
+ Map->fInfo.ogr.feature_cache =
+ OGR_L_GetFeature(Map->fInfo.ogr.layer, FID);
+ if (Map->fInfo.ogr.feature_cache == NULL) {
FID);
- read_line(Map, hGeom, Line->offset + 1, line_p);
+ Map->fInfo.ogr.feature_cache_id = FID;
- /* category */
- if (line_c != NULL) {
- Vect_cat_set(line_c, 1, (int)FID);
+ hGeom = OGR_F_GetGeometryRef(Map->fInfo.ogr.feature_cache);
+ if (hGeom == NULL) {
+ G_fatal_error(_("Unable to get feature geometry, FID %ld"),
+ FID);
+ type = read_line(Map, hGeom, offset + 1, line_p);
+ else {
+ type = get_line_type(Map, FID);
- return Line->type;
+ /* category */
+ if (line_c != NULL) {
+ Vect_cat_set(line_c, 1, (int) FID);
- return -2; /* not reached */
+ return type;
+ * \brief Reads feature from OGR layer (topology level)
+ * \param[out] line_p container used to store line points within
+ * \param[out] line_c container used to store line categories within
+ * \param line feature id
+int V2_read_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
+ struct line_cats *line_c, int line)
+ struct P_line *Line;
+ G_debug(4, "V2_read_line_ogr() line = %d", line);
+ Line = Map->plus.Line[line];
+ if (Line == NULL)
+ G_fatal_error("V2_read_line_ogr(): %s %d",
+ _("Attempt to read dead line"), line);
+ return V1_read_line_ogr(Map, line_p, line_c, Line->offset);
#endif
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c 2010-01-05 16:33:06 UTC (rev 40261)
+++ grass/trunk/lib/vector/Vlib/write.c 2010-01-05 20:14:52 UTC (rev 40262)
@@ -5,7 +5,7 @@
@@ -79,12 +79,12 @@
static int (*Vect_rewrite_line_array[][3]) () = {
- rewrite_dummy, rewrite_dummy, V2_rewrite_line_nat}
+ rewrite_dummy, V1_rewrite_line_nat, V2_rewrite_line_nat}
#ifdef HAVE_OGR
- rewrite_dummy, rewrite_dummy, rewrite_dummy}
+ rewrite_dummy, V1_rewrite_line_ogr, V2_rewrite_line_ogr}
#else
rewrite_dummy, format, format}
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2010-01-05 16:33:06 UTC (rev 40261)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2010-01-05 20:14:52 UTC (rev 40262)
@@ -77,7 +77,7 @@
- \brief Rewrites feature at the given offset.
+ \brief Rewrites feature at the given offset (level 1)
If the number of points or cats differs from the original one or
the type is changed: GV_POINTS -> GV_LINES or GV_LINES ->
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2010-01-05 16:33:06 UTC (rev 40261)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2010-01-05 20:14:52 UTC (rev 40262)
@@ -27,7 +27,7 @@
OGRLayerH, OGRFeatureH);
- \brief Writes feature on level 1 (OGR format)
+ \brief Writes feature on level 1
\param type feature type
@@ -117,7 +117,7 @@
- \brief Writes feature to 'coor' file (topology level)
+ \brief Writes feature (topology level)
@@ -174,13 +174,64 @@
return V2__delete_line(Map, line, V1_delete_line_ogr);
+ \param Map pointer to Map_info structure
+ \param offset feature offset
+ \param type feature type
+ \param points feature geometry
+ \param cats feature categories
+ \return feature offset (rewriten feature)
+ \return -1 on error
+off_t V1_rewrite_line_ogr(struct Map_info *Map,
+ off_t offset,
+ int type,
+ const struct line_pnts *points, const struct line_cats *cats)
+ if (type != V1_read_line_ogr(Map, NULL, NULL, offset)) {
+ G_warning(_("Unable to rewrite feature (incompatible feature types)"));
+ return -1;
+ /* delete old */
+ V1_delete_line_ogr(Map, offset);
+ return V1_write_line_ogr(Map, type, points, cats);
+ \brief Rewrites feature (topology level)
+ \param line feature id
+int V2_rewrite_line_ogr(struct Map_info *Map,
+ int line,
+ int type,
+ /* delete old */
+ V2_delete_line_ogr(Map, line);
+ return V2_write_line_ogr(Map, type, points, cats);
int write_attributes(int cat, const struct field_info *Fi,
OGRLayerH Ogr_layer, OGRFeatureH Ogr_feature)
int j, ogrfieldnum;
char buf[2000];
int ncol, colsqltype, colctype, more;
- char *fidcol;
+ const char *fidcol;
dbDriver *Driver;
dbTable *Table;
dbString dbstring;
