[GRASS-SVN] r40286 - grass/trunk/vector/v.voronoi
svn_grass at osgeo.org
Wed Jan 6 09:08:56 EST 2010
Author: mmetz
Date: 2010-01-06 09:08:56 -0500 (Wed, 06 Jan 2010)
New Revision: 40286
grass/trunk/vector/v.voronoi/main.c
grass/trunk/vector/v.voronoi/sw_edgelist.c
grass/trunk/vector/v.voronoi/sw_geometry.c
grass/trunk/vector/v.voronoi/sw_heap.c
grass/trunk/vector/v.voronoi/sw_main.c
grass/trunk/vector/v.voronoi/sw_memory.c
grass/trunk/vector/v.voronoi/sw_output.c
grass/trunk/vector/v.voronoi/sw_voronoi.c
much less memory, a bit faster
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/main.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -55,19 +55,18 @@
COOR *ca = (COOR *) a;
COOR *cb = (COOR *) b;
- double thresh = 1e-10;
double ma, mb;
/* calculate measure */
ma = mb = 0.0;
- if (fabs(ca->y - Box.S) < thresh) { /* bottom */
+ if (fabs(ca->y - Box.S) < GRASS_EPSILON) { /* bottom */
ma = ca->x - Box.W;
- else if (fabs(ca->x - Box.E) < thresh) { /* right */
+ else if (fabs(ca->x - Box.E) < GRASS_EPSILON) { /* right */
ma = (Box.E - Box.W) + (ca->y - Box.S);
- else if (fabs(ca->y - Box.N) < thresh) { /* top */
+ else if (fabs(ca->y - Box.N) < GRASS_EPSILON) { /* top */
ma = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - ca->x);
else { /* left */
@@ -75,13 +74,13 @@
- if (fabs(cb->y - Box.S) < thresh) { /* bottom */
+ if (fabs(cb->y - Box.S) < GRASS_EPSILON) { /* bottom */
mb = cb->x - Box.W;
- else if (fabs(cb->x - Box.E) < thresh) { /* right */
+ else if (fabs(cb->x - Box.E) < GRASS_EPSILON) { /* right */
mb = (Box.E - Box.W) + (cb->y - Box.S);
- else if (fabs(cb->y - Box.N) < thresh) { /* top */
+ else if (fabs(cb->y - Box.N) < GRASS_EPSILON) { /* top */
mb = (Box.E - Box.W) + (Box.N - Box.S) + (Box.E - cb->x);
else { /* left */
@@ -164,8 +163,9 @@
G_get_window(&Window);
Vect_region_box(&Window, &Box);
- freeinit(&sfl, sizeof *sites);
+ freeinit(&sfl, sizeof(struct Site));
+ G_message(_("Reading sites..."));
readsites();
siteidx = 0;
@@ -174,9 +174,11 @@
triangulate = 0;
plot = 0;
debug = 0;
+ G_message(_("Voronoi triangulation..."));
voronoi(triangulate, nextone);
- /* Close free ends by cyrrent region */
+ /* Close free ends by current region */
Vect_build_partial(&Out, GV_BUILD_BASE);
ncoor = 0;
@@ -249,12 +251,21 @@
if (1) {
- int line, nlines, type;
+ int line, nlines, type, ctype;
+ if (line_flag->answer)
+ ctype = GV_POINT;
+ else
+ ctype = GV_CENTROID;
nlines = Vect_get_num_lines(&In);
+ G_message(_("Writing sites to output..."));
for (line = 1; line <= nlines; line++) {
+ G_percent(line, nlines, 2);
type = Vect_read_line(&In, Points, Cats, line);
if (!(type & GV_POINTS))
continue;
@@ -262,7 +273,7 @@
if (!Vect_point_in_box(Points->x[0], Points->y[0], 0.0, &Box))
continue;
- Vect_write_line(&Out, GV_CENTROID, Points, Cats);
+ Vect_write_line(&Out, ctype, Points, Cats);
for (i = 0; i < Cats->n_cats; i++) {
@@ -339,7 +350,6 @@
Vect_map_add_dblink(&Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
- G_done_msg(" ");
@@ -350,5 +360,6 @@
Vect_build(&Out);
Vect_close(&Out);
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.voronoi/sw_edgelist.c
--- grass/trunk/vector/v.voronoi/sw_edgelist.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_edgelist.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -1,4 +1,5 @@
#include <stdlib.h>
+#include <grass/gis.h>
#include "sw_defs.h"
int ntry, totalsearch;
@@ -7,10 +8,10 @@
int i;
- freeinit(&hfl, sizeof **ELhash);
+ freeinit(&hfl, sizeof(struct Halfedge));
ELhashsize = 2 * sqrt_nsites;
- ELhash = (struct Halfedge **)myalloc(sizeof *ELhash * ELhashsize);
- for (i = 0; i < ELhashsize; i += 1)
+ ELhash = (struct Halfedge **)G_malloc(ELhashsize * sizeof(struct Halfedge *));
+ for (i = 0; i < ELhashsize; i++)
ELhash[i] = (struct Halfedge *)NULL;
ELleftend = HEcreate((struct Edge *)NULL, 0);
ELrightend = HEcreate((struct Edge *)NULL, 0);
@@ -62,7 +63,7 @@
/* Hash table points to deleted half edge. Patch as necessary. */
ELhash[b] = (struct Halfedge *)NULL;
- if ((he->ELrefcnt -= 1) == 0)
+ if (--(he->ELrefcnt) == 0)
makefree((struct Freenode *)he, &hfl);
return ((struct Halfedge *)NULL);
@@ -80,15 +81,15 @@
bucket = ELhashsize - 1;
he = ELgethash(bucket);
if (he == (struct Halfedge *)NULL) {
- for (i = 1; 1; i += 1) {
+ for (i = 1; 1; i++) {
if ((he = ELgethash(bucket - i)) != (struct Halfedge *)NULL)
break;
if ((he = ELgethash(bucket + i)) != (struct Halfedge *)NULL)
break;
totalsearch += i;
- ntry += 1;
+ ntry++;
/* Now search linear list of halfedges for the corect one */
if (he == ELleftend || (he != ELrightend && right_of(he, p))) {
do {
@@ -104,10 +105,10 @@
/* Update hash table and reference counts */
if (bucket > 0 && bucket < ELhashsize - 1) {
if (ELhash[bucket] != (struct Halfedge *)NULL)
- ELhash[bucket]->ELrefcnt -= 1;
+ ELhash[bucket]->ELrefcnt--;
ELhash[bucket] = he;
- ELhash[bucket]->ELrefcnt += 1;
+ ELhash[bucket]->ELrefcnt++;
return (he);
Modified: grass/trunk/vector/v.voronoi/sw_geometry.c
--- grass/trunk/vector/v.voronoi/sw_geometry.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_geometry.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -4,10 +4,9 @@
int geominit(void)
- struct Edge e;
double sn;
- freeinit(&efl, sizeof e);
+ freeinit(&efl, sizeof(struct Edge));
nvertices = 0;
nedges = 0;
sn = nsites + 4;
@@ -48,11 +47,11 @@
newedge->b = 1.0;
newedge->a = dx / dy;
newedge->c /= dy;
newedge->edgenbr = nedges;
out_bisector(newedge);
- nedges += 1;
+ nedges++;
return (newedge);
@@ -88,7 +87,7 @@
else {
el = el2;
e = e2;
right_of_site = xint >= e->reg[1]->coord.x;
if ((right_of_site && el->ELpm == le) ||
(!right_of_site && el->ELpm == re))
@@ -131,14 +130,14 @@
above = !above;
if (!above)
fast = 1;
if (!fast) {
dxs = topsite->coord.x - (e->reg[0])->coord.x;
above = e->b * (dxp * dxp - dyp * dyp) <
dxs * dyp * (1.0 + 2.0 * dxp / dxs + e->b * e->b);
if (e->b < 0.0)
above = !above;
else { /*e->b==1.0 */
yl = e->c - e->a * p->x;
@@ -146,7 +145,7 @@
t2 = p->x - topsite->coord.x;
t3 = yl - topsite->coord.y;
above = t1 * t1 > t2 * t2 + t3 * t3;
return (el->ELpm == le ? above : !above);
@@ -177,7 +176,7 @@
int makevertex(struct Site *v)
v->sitenbr = nvertices;
- nvertices += 1;
+ nvertices++;
out_vertex(v);
return 0;
@@ -185,7 +184,7 @@
int deref(struct Site *v)
- v->refcnt -= 1;
+ v->refcnt--;
if (v->refcnt == 0)
makefree((struct Freenode *)v, &sfl);
return 0;
@@ -193,6 +192,6 @@
int ref(struct Site *v)
- v->refcnt += 1;
+ v->refcnt++;
return 0;
Modified: grass/trunk/vector/v.voronoi/sw_heap.c
--- grass/trunk/vector/v.voronoi/sw_heap.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_heap.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -1,4 +1,5 @@
#include <stdlib.h>
@@ -15,10 +16,10 @@
(he->ystar == next->ystar && v->coord.x > next->vertex->coord.x)))
last = next;
he->PQnext = last->PQnext;
last->PQnext = he;
- PQcount += 1;
+ PQcount++;
return 0;
@@ -31,10 +32,10 @@
while (last->PQnext != he)
last = last->PQnext;
last->PQnext = he->PQnext;
- PQcount -= 1;
+ PQcount--;
deref(he->vertex);
he->vertex = (struct Site *)NULL;
return 0;
@@ -65,10 +66,11 @@
struct Point answer;
while (PQhash[PQmin].PQnext == (struct Halfedge *)NULL) {
- PQmin += 1;
+ PQmin++;
answer.x = PQhash[PQmin].PQnext->vertex->coord.x;
answer.y = PQhash[PQmin].PQnext->ystar;
+ answer.z = PQhash[PQmin].PQnext->vertex->coord.z;
return (answer);
@@ -78,7 +80,7 @@
curr = PQhash[PQmin].PQnext;
PQhash[PQmin].PQnext = curr->PQnext;
- PQcount -= 1;
+ PQcount--;
return (curr);
@@ -90,8 +92,8 @@
PQcount = 0;
PQmin = 0;
PQhashsize = 4 * sqrt_nsites;
- PQhash = (struct Halfedge *)myalloc(PQhashsize * sizeof *PQhash);
- for (i = 0; i < PQhashsize; i += 1)
+ PQhash = (struct Halfedge *)G_malloc(PQhashsize * sizeof(struct Halfedge));
+ for (i = 0; i < PQhashsize; i++)
PQhash[i].PQnext = (struct Halfedge *)NULL;
return 0;
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_main.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -56,7 +56,7 @@
if (siteidx < nsites) {
s = &sites[siteidx];
- siteidx += 1;
+ siteidx++;
return (s);
else
@@ -98,7 +98,7 @@
if (j != nsites) {
nsites = j;
- sites = (struct Site *)G_realloc(sites, nsites * sizeof(*sites));
+ sites = (struct Site *)G_realloc(sites, nsites * sizeof(struct Site));
@@ -106,7 +106,7 @@
/* read all sites, sort, and compute xmin, xmax, ymin, ymax */
int readsites(void)
- int i, nlines, line;
+ int nlines, line;
struct line_pnts *Points;
Points = Vect_new_line_struct();
@@ -114,11 +114,13 @@
nsites = 0;
- sites = (struct Site *)myalloc(nlines * sizeof(*sites));
+ sites = (struct Site *)G_malloc(nlines * sizeof(struct Site));
int type;
type = Vect_read_line(&In, Points, NULL, line);
continue;
@@ -134,28 +136,33 @@
G_debug(3, "Points->z[0]: %f", Points->z[0]);
sites[nsites].coord.z = Points->z[0];
+ else
+ sites[nsites].coord.z = 0.0;
- sites[nsites].sitenbr = nsites;
- sites[nsites].refcnt = 0;
- nsites += 1;
- if (nsites % 4000 == 0)
- sites =
- (struct Site *)G_realloc(sites,
- (nsites + 4000) * sizeof(*sites));
+ if (nsites > 1) {
+ if (xmin > sites[nsites].coord.x)
+ xmin = sites[nsites].coord.x;
+ if (xmax < sites[nsites].coord.x)
+ xmax = sites[nsites].coord.x;
+ if (ymin > sites[nsites].coord.y)
+ ymin = sites[nsites].coord.y;
+ if (ymax < sites[nsites].coord.y)
+ ymax = sites[nsites].coord.y;
+ else {
+ xmin = xmax = sites[nsites].coord.x;
+ ymin = ymax = sites[nsites].coord.y;
+ nsites++;
+ if (nsites < nlines)
+ sites =
+ (struct Site *)G_realloc(sites,
+ (nsites) * sizeof(struct Site));
- qsort(sites, nsites, sizeof(*sites), scomp);
+ qsort(sites, nsites, sizeof(struct Site), scomp);
removeDuplicates();
- xmin = sites[0].coord.x;
- xmax = sites[0].coord.x;
- for (i = 1; i < nsites; i += 1) {
- if (sites[i].coord.x < xmin)
- xmin = sites[i].coord.x;
- if (sites[i].coord.x > xmax)
- xmax = sites[i].coord.x;
- ymin = sites[0].coord.y;
- ymax = sites[nsites - 1].coord.y;
return 0;
@@ -167,7 +174,7 @@
s = (struct Site *)getfree(&sfl);
s->refcnt = 0;
s->sitenbr = siteidx;
- siteidx += 1;
+ siteidx++;
if (scanf("%lf %lf", &(s->coord.x), &(s->coord.y)) == EOF)
return ((struct Site *)NULL);
Modified: grass/trunk/vector/v.voronoi/sw_memory.c
--- grass/trunk/vector/v.voronoi/sw_memory.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_memory.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -16,10 +16,10 @@
struct Freenode *t;
if (fl->head == (struct Freenode *)NULL) {
- t = (struct Freenode *)myalloc(sqrt_nsites * fl->nodesize);
- for (i = 0; i < sqrt_nsites; i += 1)
+ t = (struct Freenode *)G_malloc(sqrt_nsites * fl->nodesize);
+ for (i = 0; i < sqrt_nsites; i++)
makefree((struct Freenode *)((char *)t + i * fl->nodesize), fl);
t = fl->head;
fl->head = (fl->head)->nextfree;
return ((char *)t);
@@ -31,18 +31,3 @@
fl->head = curr;
return 0;
-int total_alloc;
-char *myalloc(unsigned n)
- char *t;
- if ((t = G_malloc(n)) == (char *)0) {
- fprintf(stderr,
- "Insufficient memory processing site %d (%d bytes in use)\n",
- siteidx, total_alloc);
- exit(0);
- total_alloc += n;
- return (t);
Modified: grass/trunk/vector/v.voronoi/sw_output.c
--- grass/trunk/vector/v.voronoi/sw_output.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_output.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -146,7 +146,7 @@
else {
s1 = e->ep[0];
s2 = e->ep[1];
if (e->a == 1.0) {
y1 = pymin;
@@ -167,19 +167,19 @@
if (x1 > pxmax) {
x1 = pxmax;
y1 = (e->c - x1) / e->b;
if (x1 < pxmin) {
x1 = pxmin;
if (x2 > pxmax) {
x2 = pxmax;
y2 = (e->c - x2) / e->b;
if (x2 < pxmin) {
x2 = pxmin;
else {
x1 = pxmin;
@@ -200,20 +200,20 @@
if (y1 > pymax) {
y1 = pymax;
x1 = (e->c - y1) / e->a;
if (y1 < pymin) {
y1 = pymin;
if (y2 > pymax) {
y2 = pymax;
x2 = (e->c - y2) / e->a;
if (y2 < pymin) {
y2 = pymin;
line(x1, y1, x2, y2);
Modified: grass/trunk/vector/v.voronoi/sw_voronoi.c
--- grass/trunk/vector/v.voronoi/sw_voronoi.c 2010-01-06 13:56:41 UTC (rev 40285)
+++ grass/trunk/vector/v.voronoi/sw_voronoi.c 2010-01-06 14:08:56 UTC (rev 40286)
@@ -37,13 +37,13 @@
if ((p = intersect(lbnd, bisector)) != (struct Site *)NULL) {
PQdelete(lbnd);
PQinsert(lbnd, p, dist(p, newsite));
lbnd = bisector;
bisector = HEcreate(e, re);
ELinsert(lbnd, bisector);
if ((p = intersect(bisector, rbnd)) != (struct Site *)NULL) {
PQinsert(bisector, p, dist(p, newsite));
/* get next site, but ensure that it doesn't have the same
coordinates as the previous. If so, step over to the following
site. Andrea Aime 4/7/2001 */
@@ -87,19 +87,19 @@
if ((p = intersect(llbnd, bisector)) != (struct Site *)NULL) {
PQdelete(llbnd);
PQinsert(llbnd, p, dist(p, bot));
if ((p = intersect(bisector, rrbnd)) != (struct Site *)NULL) {
PQinsert(bisector, p, dist(p, bot));
else
break;
for (lbnd = ELright(ELleftend); lbnd != ELrightend; lbnd = ELright(lbnd)) {
e = lbnd->ELedge;
out_ep(e);
return 0;
