[GRASS-SVN] r40298 - grass/trunk/lib/gpde
Thu Jan 7 08:47:12 EST 2010
Author: huhabla
Date: 2010-01-07 08:47:11 -0500 (Thu, 07 Jan 2010)
New Revision: 40298
   grass/trunk/lib/gpde/N_gwflow.c
   grass/trunk/lib/gpde/N_gwflow.h
Computation of water budged for 2d groundwater flow added
Modified: grass/trunk/lib/gpde/N_gwflow.c
--- grass/trunk/lib/gpde/N_gwflow.c	2010-01-07 11:32:23 UTC (rev 40297)
+++ grass/trunk/lib/gpde/N_gwflow.c	2010-01-07 13:47:11 UTC (rev 40298)
@@ -534,3 +534,87 @@
     return mat_pos;
+/* ****************** N_gwflow_2d_calc_water_balance************** */
+ * \brief This function computes the water balance of the entire groundwater
+ * The water balance is calculated for each active and dirichlet cell from
+ * its surrounding neighbours. This is based on the 5 star mass balance computation
+ * of N_callback_gwflow_2d and the gradient of the water heights in the cells.
+ * The sum of the water balance of each active/dirichlet cell must be near zero
+ * due the effect of numerical inaccuracy of cpu's.
+ * \param gwdata N_gwflow_data2d *
+ * \param geom N_geom_data *
+ * \param balance N_array_2d
+ * \returnvoid
+void
+N_gwflow_2d_calc_water_balance(N_gwflow_data2d * data, N_geom_data * geom, N_array_2d * balance)
+    int y, x, stat;
+    double h, hc;
+    double val;
+    double sum;
+    N_data_star *dstar;
+    int rows = data->status->rows;
+    int cols = data->status->cols;
+    sum = 0;
+    for (y = 0; y < rows; y++) {
+	G_percent(y, rows - 1, 10);
+	for (x = 0; x < cols; x++) {
+	    stat = (int)N_get_array_2d_d_value(data->status, x, y);
+            val = 0.0;
+	    if (stat != N_CELL_INACTIVE ) {	/*all active/dirichlet cells */
+                /* Compute the flow parameter */
+                dstar = N_callback_gwflow_2d(data, geom, x, y);
+                /* Compute the gradient in each direction pointing from the center */
+                hc = N_get_array_2d_d_value(data->phead, x, y);
+                if((int)N_get_array_2d_d_value(data->status, x + 1, y    ) != N_CELL_INACTIVE) {
+                    h = N_get_array_2d_d_value(data->phead,  x + 1, y);
+                    val += dstar->E * (hc - h);
+                if((int)N_get_array_2d_d_value(data->status, x - 1, y    ) != N_CELL_INACTIVE) {
+                    h = N_get_array_2d_d_value(data->phead,  x - 1, y);
+                    val += dstar->W * (hc - h);
+                if((int)N_get_array_2d_d_value(data->status, x    , y + 1) != N_CELL_INACTIVE) {
+                    h = N_get_array_2d_d_value(data->phead,  x    , y + 1);
+                    val += dstar->S * (hc - h);
+                if((int)N_get_array_2d_d_value(data->status, x    , y - 1) != N_CELL_INACTIVE) {
+                    h = N_get_array_2d_d_value(data->phead,  x    , y - 1);
+                    val += dstar->N * (hc - h);
+                sum += val;
+                G_free(dstar);
+	    else {
+		Rast_set_null_value(&val, 1, DCELL_TYPE);
+	    N_put_array_2d_d_value(balance, x, y, val);
+    if(fabs(sum) < 0.0000000001)
+        G_message("The total sum of the water balance: %g\n", sum);
+    else
+        G_warning("The total sum of the water balance is significant larger then 0: %g\n", sum);
+    return;
\ No newline at end of file
Modified: grass/trunk/lib/gpde/N_gwflow.h
--- grass/trunk/lib/gpde/N_gwflow.h	2010-01-07 11:32:23 UTC (rev 40297)
+++ grass/trunk/lib/gpde/N_gwflow.h	2010-01-07 13:47:11 UTC (rev 40298)
@@ -19,6 +19,7 @@
 #ifndef _N_GWFLOW_H_
 #define _N_GWFLOW_H_
 #include "N_pde.h"
+#include <math.h>
 #define N_GW_CONFINED 0		/*confined groundwater */
 #define N_GW_UNCONFINED 1	/*unconfined groundwater */
@@ -99,6 +100,8 @@
 					 int col, int row, int depth);
 extern N_data_star *N_callback_gwflow_2d(void *gwdata, N_geom_data * geom,
 					 int col, int row);
+extern void N_gwflow_2d_calc_water_balance(N_gwflow_data2d * data,
+        N_geom_data * geom, N_array_2d * balance);
 extern N_gwflow_data3d *N_alloc_gwflow_data3d(int cols, int rows, int depths,
 					      int river, int drain);
 extern N_gwflow_data2d *N_alloc_gwflow_data2d(int cols, int rows, int river,
