[GRASS-SVN] r40314 - grass/branches/develbranch_6/lib/db/dbmi_base
svn_grass at osgeo.org
Fri Jan 8 03:46:33 EST 2010
Author: hamish
Date: 2010-01-08 03:46:29 -0500 (Fri, 08 Jan 2010)
New Revision: 40314
grass/branches/develbranch_6/lib/db/dbmi_base/login.c
use G_getl2, add FIXME comment and debug msg formatting
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/login.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/login.c 2010-01-08 08:36:30 UTC (rev 40313)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/login.c 2010-01-08 08:46:29 UTC (rev 40314)
@@ -73,7 +73,7 @@
login->n = 0;
file = login_filename();
- G_debug(3, "file = %s", file);
+ G_debug(3, "file = <%s>", file);
if (stat(file, &info) != 0) {
G_debug(3, "login file does not exist");
@@ -84,13 +84,15 @@
if (fd == NULL)
return -1;
- while (fgets(buf, 2000, fd)) {
+ while (G_getl2(buf, 2000, fd)) {
G_chop(buf);
usr[0] = pwd[0] = '\0';
+ /* FIXME: not safe for spaces in DB path name */
ret = sscanf(buf, "%[^ ] %[^ ] %[^ ] %[^ ]", dr, db, usr, pwd);
- G_debug(3, "ret = %d : %s %s %s %s", ret, dr, db, usr, pwd);
+ G_debug(3, "ret = %d : dr=[%s] db=[%s] us=[%s] pw=[%s]",
+ ret, dr, db, usr, pwd);
if (ret < 2) {
G_warning("Login file corrupted");
