[GRASS-SVN] r40328 - in grass/trunk/visualization: . wximgview
Fri Jan 8 16:44:51 EST 2010
Author: glynn
Date: 2010-01-08 16:44:51 -0500 (Fri, 08 Jan 2010)
New Revision: 40328
Added:
   grass/trunk/visualization/wximgview/
   grass/trunk/visualization/wximgview/Makefile
   grass/trunk/visualization/wximgview/main.cc
   grass/trunk/visualization/wximgview/wximgview.h
   grass/trunk/visualization/wximgview/wximgview.html
   grass/trunk/visualization/Makefile
wxWidgets version of ximgview
Modified: grass/trunk/visualization/Makefile
--- grass/trunk/visualization/Makefile	2010-01-08 21:14:44 UTC (rev 40327)
+++ grass/trunk/visualization/Makefile	2010-01-08 21:44:51 UTC (rev 40328)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ..
-SUBDIRS = nviz nviz2 xganim ximgview
+SUBDIRS = nviz nviz2 xganim ximgview wximgview
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass/trunk/visualization/wximgview/Makefile
--- grass/trunk/visualization/wximgview/Makefile	                        (rev 0)
+++ grass/trunk/visualization/wximgview/Makefile	2010-01-08 21:44:51 UTC (rev 40328)
@@ -0,0 +1,18 @@
+MODULE_TOPDIR = ../..
+PGM = wximgview
+EXTRA_CFLAGS = $(WXWIDGETSCXXFLAGS) -DWXINTL_NO_GETTEXT_MACRO
+LIBES = $(RASTERLIB) $(GISLIB) $(WXWIDGETSLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+LINK = $(CXX)
+ifneq ($(USE_WXWIDGETS),)
+ifneq ($(strip $(CXX)),)
+default: cmd
+endif
+endif
Added: grass/trunk/visualization/wximgview/main.cc
--- grass/trunk/visualization/wximgview/main.cc	                        (rev 0)
+++ grass/trunk/visualization/wximgview/main.cc	2010-01-08 21:44:51 UTC (rev 40328)
@@ -0,0 +1,274 @@
+ * MODULE:       wximgview
+ * AUTHOR(S):    Glynn Clements
+ * PURPOSE:      View BMP images from the PNG/cairo drivers
+ * COPYRIGHT:    (C) 2010 Glynn Clements
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <string.h>
+#include <signal.h>
+#include <errno.h>
+#ifdef __MINGW32__
+#include <Windows.h>
+#else
+#include <sys/mman.h>
+#endif
+#include <fcntl.h>
+#include <sys/stat.h>
+#include <sys/time.h>
+#include <sys/types.h>
+#include <wx/wx.h>
+extern "C" {
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "wximgview.h"
+#define HEADER_SIZE 54
+IMPLEMENT_APP_NO_MAIN(MyApp)
+BEGIN_EVENT_TABLE(MyFrame, wxFrame)
+EVT_ERASE_BACKGROUND(MyFrame::erase)
+EVT_PAINT(MyFrame::redraw)
+EVT_TIMER(wxID_ANY, MyFrame::tick)
+END_EVENT_TABLE()
+const wxString MyFrame::title = wxString::FromAscii("Image Viewer");
+static const char *filename;
+static double fraction;
+void MyFrame::Create()
+    timer = new wxTimer(this);
+    timer->Start(100, true);
+void MyFrame::erase(wxEraseEvent &ev)
+    ev.GetDC();
+void MyFrame::draw()
+    MyApp &app = wxGetApp();
+    wxSize size = GetSize();
+    int x0 = (size.GetWidth()  - app.i_width) / 2;
+    int y0 = (size.GetHeight() - app.i_height) / 2;
+    wxPaintDC dc(this);
+    wxImage image(app.i_width, app.i_height);
+    const unsigned char *p = app.imgbuf;
+    for (int y = 0; y < app.i_height; y++)
+	for (int x = 0; x < app.i_width; x++, p += 4)
+	    image.SetRGB(x, y, p[2], p[1], p[0]);
+    dc.DrawBitmap(wxBitmap(image), x0, y0, false);
+void MyFrame::redraw(wxPaintEvent &ev)
+    if (::fraction > 0.001) {
+	struct timeval tv0;
+	gettimeofday(&tv0, NULL);
+	draw();
+	struct timeval tv1;
+	gettimeofday(&tv1, NULL);
+	double last = (tv1.tv_sec - tv0.tv_sec) * 1e3 + (tv1.tv_usec - tv0.tv_usec) * 1e-3;
+	double delay = last / ::fraction;
+	timer->Start((int) delay, true);
+    else
+	draw();
+void MyFrame::tick(wxTimerEvent &ev)
+    Refresh();
+static unsigned int get_2(const unsigned char **q)
+    const unsigned char *p = *q;
+    unsigned int n = (p[0] << 0) | (p[1] << 8);
+    *q += 2;
+    return n;
+static unsigned int get_4(const unsigned char **q)
+    unsigned int n = (p[0] << 0) | (p[1] << 8) | (p[2] << 16) | (p[3] << 24);
+    *q += 4;
+    return n;
+int MyApp::read_bmp_header(const unsigned char *p)
+    int size;
+    if (*p++ != 'B')
+	return 0;
+    if (*p++ != 'M')
+	return 0;
+    size = get_4(&p);
+    get_4(&p);
+    if (get_4(&p) != HEADER_SIZE)
+	return 0;
+    if (get_4(&p) != 40)
+	return 0;
+    i_width = get_4(&p);
+    i_height = -get_4(&p);
+    get_2(&p);
+    if (get_2(&p) != 32)
+	return 0;
+    if (get_4(&p) != 0)
+	return 0;
+    if (get_4(&p) != (unsigned int) i_width * i_height * 4)
+	return 0;
+    if (size != HEADER_SIZE + i_width * i_height * 4)
+	return 0;
+    get_4(&p);
+    get_4(&p);
+    get_4(&p);
+    get_4(&p);
+    return 1;
+void MyApp::map_file()
+    unsigned char header[HEADER_SIZE];
+    size_t size;
+    void *ptr;
+    int fd;
+    fd = open(::filename, O_RDONLY);
+    if (fd < 0)
+	G_fatal_error(_("Unable to open image file"));
+    if (read(fd, (char *) header, sizeof(header)) != sizeof(header))
+	G_fatal_error(_("Unable to read BMP header"));
+    if (!read_bmp_header(header))
+	G_fatal_error(_("Invalid BMP header"));
+    size = HEADER_SIZE + i_width * i_height * 4;
+#ifdef __MINGW32__
+    ptr = MapViewOfFile((HANDLE) _get_osfhandle(fd),
+			FILE_MAP_READ, 0, 0, size);
+#else
+    ptr = mmap(NULL, size, PROT_READ, MAP_SHARED, fd, (off_t) 0);
+#endif
+    if (ptr == MAP_FAILED)
+	G_fatal_error(_("Unable to map image file"));
+    imgbuf = (unsigned char *)ptr + HEADER_SIZE;
+    close(fd);
+static void dummy_handler(int sig)
+    wxTimerEvent ev = wxTimerEvent();
+    wxPostEvent(wxGetApp().mainwin, ev);
+static void set_handler(void)
+    struct sigaction act;
+    act.sa_handler = &dummy_handler;
+    sigemptyset(&act.sa_mask);
+    act.sa_flags = 0;
+    sigaction(SIGUSR1, &act, NULL);
+bool MyApp::OnInit()
+    map_file();
+    wxSize size(i_width, i_height);
+    mainwin = new MyFrame(size);
+    mainwin->Show();
+    SetTopWindow(mainwin);
+    set_handler();
+    return true;
+int main(int argc, char **argv)
+    struct GModule *module;
+    struct
+	struct Option *image, *percent;
+    } opt;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("display"));
+    module->description = _("View BMP images from the PNG driver.");
+    opt.image = G_define_option();
+    opt.image->key = "image";
+    opt.image->type = TYPE_STRING;
+    opt.image->required = YES;
+    opt.image->multiple = NO;
+    opt.image->gisprompt = "old_file,file,input";
+    opt.image->description = _("Image file");
+    opt.percent = G_define_option();
+    opt.percent->key = "percent";
+    opt.percent->type = TYPE_INTEGER;
+    opt.percent->required = NO;
+    opt.percent->multiple = NO;
+    opt.percent->description = _("Percentage of CPU time to use");
+    opt.percent->answer = "10";
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    ::filename = opt.image->answer;
+    ::fraction = atoi(opt.percent->answer) / 100.0;
+    return wxEntry(argc, argv);
+    return EXIT_SUCCESS;
Added: grass/trunk/visualization/wximgview/wximgview.h
--- grass/trunk/visualization/wximgview/wximgview.h	                        (rev 0)
+++ grass/trunk/visualization/wximgview/wximgview.h	2010-01-08 21:44:51 UTC (rev 40328)
@@ -0,0 +1,48 @@
+// -*- c++ -*-
+#include <wx/wx.h>
+#ifndef WXIMGVIEW_H_
+#define WXIMGVIEW_H_
+class MyFrame: public wxFrame
+private:
+    wxTimer *timer;
+    void draw();
+    static const wxString title;
+public:
+    MyFrame(const wxSize &size)
+	: wxFrame((wxFrame *)0, wxID_ANY, title, wxDefaultPosition, size)
+    { Create(); }
+    void redraw(wxPaintEvent &ev);
+    void erase(wxEraseEvent &ev);
+    void tick(wxTimerEvent &ev);
+private:
+    void Create();
+    DECLARE_EVENT_TABLE()
+class MyApp: public wxApp
+public:
+    virtual bool OnInit();
+public:
+    MyFrame *mainwin;
+    int i_width, i_height;
+    unsigned char *imgbuf;
+    double last;
+    int read_bmp_header(const unsigned char *p);
+    void map_file();
+#endif // WXIMGVIEW_H_
Added: grass/trunk/visualization/wximgview/wximgview.html
--- grass/trunk/visualization/wximgview/wximgview.html	                        (rev 0)
+++ grass/trunk/visualization/wximgview/wximgview.html	2010-01-08 21:44:51 UTC (rev 40328)
@@ -0,0 +1,26 @@
+<h2>DESCRIPTION</h2>
+<i>wximgview</i> is a simple wxWidgets image viewer for 32-bpp BMP images, as
+can be created with the <em><a href="pngdriver.html">PNG</a></em> and
+<em><a href="cairodriver.html">cairo</a></em> drivers. The display is
+continually refreshed.
+<h2>NOTES</h2>
+The display driver must be configure to map the file, with
+<em>GRASS_PNG_MAPPED=TRUE</em>. This ensures that the file will remain
+a constant size, rather than being truncated whenever it is updated.
+<h2>SEE ALSO</h2>
+<em>
+<a href="pngdriver.html">PNG driver</a>
+<a href="cairodriver.html">cairo driver</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p>
+<i>Last changed: $Date: 2008-08-15 07:16:42 +0100 (Fri, 15 Aug 2008) $</i>
