[GRASS-SVN] r40331 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jan 8 23:04:57 EST 2010
Author: hamish
Date: 2010-01-08 23:04:57 -0500 (Fri, 08 Jan 2010)
New Revision: 40331
grass/branches/develbranch_6/lib/vector/Vlib/field.c
deal with spaces in pathnames better (trac #809)
Modified: grass/branches/develbranch_6/lib/vector/Vlib/field.c
--- grass/branches/develbranch_6/lib/vector/Vlib/field.c 2010-01-09 03:41:20 UTC (rev 40330)
+++ grass/branches/develbranch_6/lib/vector/Vlib/field.c 2010-01-09 04:04:57 UTC (rev 40331)
@@ -430,7 +430,6 @@
int Vect_read_dblinks(struct Map_info *Map)
- int ndef;
FILE *fd;
char file[1024], buf[2001];
char tab[1024], col[1024], db[1024], drv[1024], fldstr[1024], *fldname;
@@ -438,6 +437,8 @@
char *c;
int row, rule;
struct dblinks *dbl;
+ char **tokens;
+ int ntok, i;
G_debug(1, "Vect_read_dblinks(): map = %s, mapset = %s", Map->name,
Map->mapset);
@@ -630,14 +631,32 @@
if (strlen(buf) == 0)
continue;
+ tokens = G_tokenize(buf, " ");
+ ntok = G_number_of_tokens(tokens);
- ndef = sscanf(buf, "%s %s %s %s %s", fldstr, tab, col, db, drv);
- if (ndef < 2 || (ndef < 5 && rule < 1)) {
+ if (ntok < 2 || (ntok < 5 && rule < 1)) {
G_warning(_("Error in rule on row %d in %s"), row, file);
continue;
+ strcpy(fldstr, tokens[0]);
+ strcpy(tab, tokens[1]);
+ if (ntok > 2) {
+ strcpy(col, tokens[2]);
+ if (ntok > 3) {
+ strcpy(db, tokens[3]);
+ /* allow for spaces in path names */
+ for (i=4; i < ntok-1; i++) {
+ strcat(db, " ");
+ strcat(db, tokens[i]);
+ strcpy(drv, tokens[ntok-1]);
+ G_free_tokens(tokens);
/* get field and field name */
fldname = strchr(fldstr, '/');
if (fldname != NULL) { /* field has name */
