[GRASS-SVN] r40337 - grass/trunk/scripts/v.db.addtable
Fri Jan 8 23:40:06 EST 2010
Author: hamish
Date: 2010-01-08 23:40:05 -0500 (Fri, 08 Jan 2010)
New Revision: 40337
   grass/trunk/scripts/v.db.addtable/v.db.addtable.html
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
use the mapset's default DB instead of being locked to the one that layer 1 has used. (bug #809)
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.html
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.html	2010-01-09 04:30:49 UTC (rev 40336)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.html	2010-01-09 04:40:05 UTC (rev 40337)
@@ -18,8 +18,8 @@
 <em><a href="wxGUI.Vector_Digitizing_Tool.html">wxGUI vector digitizer</a></em> to add the relevant lines to the table.
 The supported types of columns depend on the database backend. However, all
-backends should support VARCHAR, INT, DOUBLE PRECISION and DATE. The default
-dbf backend supports only these types.
+backends should support VARCHAR, INT, DOUBLE PRECISION and DATE.
+The dbf backend supports only these types.
 The existing database connection(s) can be verified with <em>v.db.connect</em>.
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2010-01-09 04:30:49 UTC (rev 40336)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2010-01-09 04:40:05 UTC (rev 40337)
@@ -15,7 +15,7 @@
 #%Module
-#%  description: Creates and adds a new attribute table to a given layer of an existing vector map.
+#%  description: Creates and connects a new attribute table to a given layer of an existing vector map.
 #%  keywords: vector
 #%  keywords: database
 #%  keywords: attribute table
@@ -83,21 +83,13 @@
     # check if DB parameters are set, and if not set them.
     grass.run_command('db.connect', flags = 'c')
-    #check if anything is connected:
-    nuldev = file(os.devnull, 'w')
-    db = grass.vector_db(map, stderr = nuldev)
-    if db:
-	f = db[min(db.keys())]
-	database = f['database']
-	driver = f['driver']
-    else:
-	# nothing defined
-	grass.message(_("Creating new DB connection based on default mapset settings..."))
-	kv = grass.db_connection()
-	database = kv['database']
-	driver = kv['driver']
+    grass.message(_("Creating new DB connection based on default mapset settings..."))
+    kv = grass.db_connection()
+    database = kv['database']
+    driver = kv['driver']
     # maybe there is already a table linked to the selected layer?
+    nuldev = file(os.devnull, 'w')
     try:
         grass.vector_db(map, stderr = nuldev)[int(layer)]
 	grass.fatal(_("There is already a table linked to layer <%s>") % layer)
