[GRASS-SVN] r40357 - grass/trunk/gui/wxpython/xml
Sat Jan 9 09:41:54 EST 2010
Author: hamish
Date: 2010-01-09 09:41:54 -0500 (Sat, 09 Jan 2010)
New Revision: 40357
   grass/trunk/gui/wxpython/xml/menudata.xml
add v.in.lines to gui menu (merge from devbr6)
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2010-01-09 14:40:08 UTC (rev 40356)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2010-01-09 14:41:54 UTC (rev 40357)
@@ -196,6 +196,13 @@
 	      <command>v.in.ascii</command>
 	    </menuitem>
 	    <menuitem>
+	      <label>ASCII points as a vector lines</label>
+	      <help>Creates a lines vector map from an ASCII x,y points file.</help>
+	      <keywords>vector,import</keywords>
+	      <handler>self.OnMenuCmd</handler>
+	      <command>v.in.lines</command>
+	    </menuitem>
+	    <menuitem>
 	      <label>Old GRASS vector import</label>
 	      <help>Imports older versions of GRASS vector maps.</help>
 	      <keywords>vector,import,conversion</keywords>
