[GRASS-SVN] r40374 - grass/trunk/raster/r.out.bin
    svn_grass at osgeo.org
    Tue Jan 12 02:47:38 EST 2010
Author: glynn
Date: 2010-01-12 02:47:37 -0500 (Tue, 12 Jan 2010)
New Revision: 40374
Removed:
   grass/trunk/raster/r.out.bin/swab.h
   grass/trunk/raster/r.out.bin/tif_swab.c
   grass/trunk/raster/r.out.bin/main.c
Add size=, order= options
Add -f (float output) flag
Change null= to accept FP values
Refactor
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c	2010-01-12 01:38:31 UTC (rev 40373)
+++ grass/trunk/raster/r.out.bin/main.c	2010-01-12 07:47:37 UTC (rev 40374)
@@ -1,8 +1,9 @@
  *   r.out.bin
- *   Copyright (C) 2000 by the GRASS Development Team
+ *   Copyright (C) 2000,2010 by the GRASS Development Team
  *   Author: Bob Covill <bcovill at tekmap.ns.ca>
+ *   Modified by Glynn Clements, 2010-01-10
  *   This program is free software under the GPL (>=v2)
  *   Read the file COPYING coming with GRASS for details.
@@ -16,47 +17,262 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
-#include "./gmt_grd.h"
-#include "./swab.h"
+#include "gmt_grd.h"
-int main(int argc, char *argv[])
+static void swap_2(void *p)
-    void *raster, *ptr;
-    RASTER_MAP_TYPE out_type, map_type;
-    char *name;
-    char outfile[GNAME_MAX];
-    int null_str = 0;
-    char buf[128];
-    int fd;
-    int row, col;
-    int nrows, ncols;
-    short number_i;
-    int do_stdout = 0;
-    int swapFlag;
-    FILE *fp;
-    struct GRD_HEADER header;
+    unsigned char *q = p;
+    unsigned char t;
+    t = q[0]; q[0] = q[1]; q[1] = t;
+static void swap_4(void *p)
+    unsigned char t;
+    t = q[0]; q[0] = q[3]; q[3] = t;
+    t = q[1]; q[1] = q[2]; q[2] = t;
+static void swap_8(void *p)
+    unsigned char t;
+    t = q[0]; q[0] = q[7]; q[7] = t;
+    t = q[1]; q[1] = q[6]; q[6] = t;
+    t = q[2]; q[2] = q[5]; q[5] = t;
+    t = q[3]; q[3] = q[4]; q[4] = t;
+static void write_int(FILE *fp, int swap_flag, int x)
+    if (swap_flag)
+	swap_4(&x);
+    if (fwrite(&x, 4, 1, fp) != 1)
+	G_fatal_error(_("Error writing data"));
+static void write_double(FILE *fp, int swap_flag, double x)
+    if (swap_flag)
+	swap_8(&x);
+    if (fwrite(&x, 8, 1, fp) != 1)
+static void make_gmt_header(
+    struct GRD_HEADER *header,
+    const char *name, const char *outfile,
+    const struct Cell_head *region, double null_val)
     struct FPRange range;
-    DCELL Z_MIN, Z_MAX;
+    DCELL z_min, z_max;
-    float number_f;
-    double number_d;
-    short null_val_i;
-    float null_val_f;
-    double null_val_d;
-    struct Cell_head region;
+    Rast_read_fp_range(name, "", &range);
+    Rast_get_fp_range_min_max(&range, &z_min, &z_max);
+    header->nx = region->cols;
+    header->ny = region->rows;
+    header->node_offset = 1;	/* 1 is pixel registration */
+    header->x_min = region->west;
+    header->x_max = region->east;
+    header->y_min = region->south;
+    header->y_max = region->north;
+    header->z_min = (double) z_min;
+    header->z_max = (double) z_max;
+    header->x_inc = region->ew_res;
+    header->y_inc = region->ns_res;
+    header->z_scale_factor = 1.0;
+    header->z_add_offset = 0.0;
+    if (region->proj == PROJECTION_LL) {
+	strcpy(header->x_units, "degrees");
+	strcpy(header->y_units, "degrees");
+    else {
+	strcpy(header->x_units, "Meters");
+	strcpy(header->y_units, "Meters");
+    strcpy(header->z_units, "elevation");
+    strcpy(header->title, name);
+    sprintf(header->command, "r.out.bin -h input=%s output=%s", name, outfile);
+    sprintf(header->remark, "%g used for NULL", null_val);
+static void write_gmt_header(const struct GRD_HEADER *header, int swap_flag, FILE *fp)
+    /* Write Values 1 at a time if byteswapping */
+    write_int(fp, swap_flag, header->nx);
+    write_int(fp, swap_flag, header->ny);
+    write_int(fp, swap_flag, header->node_offset);
+    write_double(fp, swap_flag, header->x_min);
+    write_double(fp, swap_flag, header->x_max);
+    write_double(fp, swap_flag, header->y_min);
+    write_double(fp, swap_flag, header->y_max);
+    write_double(fp, swap_flag, header->z_min);
+    write_double(fp, swap_flag, header->z_max);
+    write_double(fp, swap_flag, header->x_inc);
+    write_double(fp, swap_flag, header->y_inc);
+    write_double(fp, swap_flag, header->z_scale_factor);
+    write_double(fp, swap_flag, header->z_add_offset);
+    fwrite(header->x_units, sizeof(char[GRD_UNIT_LEN]),    1, fp);
+    fwrite(header->y_units, sizeof(char[GRD_UNIT_LEN]),    1, fp);
+    fwrite(header->z_units, sizeof(char[GRD_UNIT_LEN]),    1, fp);
+    fwrite(header->title,   sizeof(char[GRD_TITLE_LEN]),   1, fp);
+    fwrite(header->command, sizeof(char[GRD_COMMAND_LEN]), 1, fp);
+    fwrite(header->remark,  sizeof(char[GRD_REMARK_LEN]),  1, fp);
+static void write_bil_hdr(
+    const char *outfile, const struct Cell_head *region,
+    int size, int order, int header, double null_val)
+    char out_tmp[GPATH_MAX];
+    FILE *fp;
+    sprintf(out_tmp, "%s.hdr", outfile);
+    G_verbose_message(_("Header File = %s"), out_tmp);
+    /* Open Header File */
+    fp = fopen(out_tmp, "w");
+    if (!fp)
+	G_fatal_error(_("Unable to create file <%s>"), out_tmp);
+    fprintf(fp, "nrows %d\n", region->rows);
+    fprintf(fp, "ncols %d\n", region->cols);
+    fprintf(fp, "nbands 1\n");
+    fprintf(fp, "nbits %d\n", size * 8);
+    fprintf(fp, "byteorder %s\n", order == 0 ? "M" : "I");
+    fprintf(fp, "layout bil\n");
+    fprintf(fp, "skipbytes %d\n", header ? 892 : 0);
+    fprintf(fp, "nodata %g\n", null_val);
+    fclose(fp);
+static void convert_cell(
+    unsigned char *out_cell, const DCELL in_cell,
+    int is_fp, int size, int swap_flag)
+    if (is_fp) {
+	switch (size) {
+	case 4:
+	    *(float *) out_cell = (float) in_cell;
+	    break;
+	case 8:
+	    *(double *) out_cell = (double) in_cell;
+	    break;
+    else {
+	switch (size) {
+	case 1:
+	    *(unsigned char *) out_cell = (unsigned char) in_cell;
+	    break;
+	case 2:
+	    *(short *) out_cell = (short) in_cell;
+	    break;
+	case 4:
+	    *(int *) out_cell = (int) in_cell;
+	    break;
+#ifdef HAVE_LONG_LONG_INT
+	case 8:
+	    *(long long *) out_cell = (long long) in_cell;
+	    break;
+#endif
+    if (swap_flag) {
+	switch (size) {
+	case 1:				break;
+	case 2:	swap_2(out_cell);	break;
+	case 4:	swap_4(out_cell);	break;
+	case 8:	swap_8(out_cell);	break;
+static void convert_row(
+    unsigned char *out_buf, const DCELL *raster, int ncols,
+    int is_fp, int size, int swap_flag, double null_val)
+    unsigned char *ptr = out_buf;
+    int i;
+    for (i = 0; i < ncols; i++) {
+	DCELL x = Rast_is_d_null_value(&raster[i])
+	    ? null_val
+	    : raster[i];
+	convert_cell(ptr, x, is_fp, size, swap_flag);
+	ptr += size;
+static void write_bil_wld(const char *outfile, const struct Cell_head *region)
+    FILE *fp;
+    sprintf(out_tmp, "%s.wld", outfile);
+    G_verbose_message(_("World File = %s"), out_tmp);
+    /* Open World File */
+    if (!fp)
+    fprintf(fp, "%f\n", region->ew_res);
+    fprintf(fp, "0.0\n");
+    fprintf(fp, "-%f\n", region->ns_res);
+    fprintf(fp, "%f\n", region->west + (region->ew_res / 2));
+    fprintf(fp, "%f\n", region->north - (region->ns_res / 2));
+    fclose(fp);
+int main(int argc, char *argv[])
     struct GModule *module;
     struct
 	struct Option *input;
 	struct Option *output;
 	struct Option *null;
+	struct Option *size;
+	struct Option *order;
     } parm;
     struct
-	struct Flag *int_out, *gmt_hd, *BIL_hd, *swap;
+	struct Flag *int_out;
+	struct Flag *float_out;
+	struct Flag *gmt_hd;
+	struct Flag *bil_hd;
+	struct Flag *swap;
     } flag;
+    char *name;
+    char *outfile;
+    double null_val;
+    int do_stdout;
+    int is_fp;
+    int size;
+    int order;
+    int swap_flag;
+    struct Cell_head region;
+    int nrows, ncols;
+    DCELL *in_buf;
+    unsigned char *out_buf;
+    int fd;
+    FILE *fp;
+    struct GRD_HEADER header;
+    int row;
     G_gisinit(argv[0]);
     module = G_define_module();
@@ -81,23 +297,41 @@
     parm.null = G_define_option();
     parm.null->key = "null";
-    parm.null->type = TYPE_INTEGER;
+    parm.null->type = TYPE_DOUBLE;
     parm.null->required = NO;
     parm.null->answer = "0";
     parm.null->description = _("Value to write out for null");
+    parm.size = G_define_option();
+    parm.size->key = "size";
+    parm.size->type = TYPE_INTEGER;
+    parm.size->required = NO;
+    parm.size->options = "1,2,4,8";
+    parm.size->description = _("Number of bytes per cell");
+    parm.order = G_define_option();
+    parm.order->key = "order";
+    parm.order->type = TYPE_STRING;
+    parm.order->required = NO;
+    parm.order->options = "big,little,native,swap";
+    parm.order->description = _("Output byte order");
+    parm.order->answer = "native";
     flag.int_out = G_define_flag();
     flag.int_out->key = 'i';
-    flag.int_out->description =
-	_("Output integer category values, not cell values");
+    flag.int_out->description = _("Generate integer output");
+    flag.float_out = G_define_flag();
+    flag.float_out->key = 'f';
+    flag.float_out->description = _("Generate floating-point output");
     flag.gmt_hd = G_define_flag();
     flag.gmt_hd->key = 'h';
     flag.gmt_hd->description = _("Export array with GMT compatible header");
-    flag.BIL_hd = G_define_flag();
-    flag.BIL_hd->key = 'b';
-    flag.BIL_hd->description = _("Generate BIL world and header files");
+    flag.bil_hd = G_define_flag();
+    flag.bil_hd->key = 'b';
+    flag.bil_hd->description = _("Generate BIL world and header files");
     flag.swap = G_define_flag();
     flag.swap->key = 's';
@@ -106,305 +340,132 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (sscanf(parm.null->answer, "%d", &null_str) != 1)
+    if (sscanf(parm.null->answer, "%lf", &null_val) != 1)
 	G_fatal_error(_("Invalid value for null (integers only)"));
     name = parm.input->answer;
     if (parm.output->answer)
-	strncpy(outfile, parm.output->answer, sizeof(outfile) - 1);
+	outfile = parm.output->answer;
     else {
-	strncpy(outfile, name, sizeof(outfile) - 1 - 4);
-	strcat(outfile, ".bin");
+	outfile = G_malloc(strlen(name) + 4 + 1);
+	sprintf(outfile, "%s.bin", name);
-    if ((strcmp("-", outfile)) == 0)
-	do_stdout = 1;
+    if (G_strcasecmp(parm.order->answer, "big") == 0)
+	order = 0;
+    else if (G_strcasecmp(parm.order->answer, "little") == 0)
+	order = 1;
+    else if (G_strcasecmp(parm.order->answer, "native") == 0)
+	order = G_is_little_endian() ? 1 : 0;
+    else if (G_strcasecmp(parm.order->answer, "swap") == 0)
+	order = G_is_little_endian() ? 0 : 1;
-    G_get_window(®ion);
+    if (flag.swap->answer) {
+	if (strcmp(parm.order->answer, "native") != 0)
+	    G_fatal_error(_("order= and -s are mutually exclusive"));
+    swap_flag = order == (G_is_little_endian() ? 0 : 1);
+    do_stdout = strcmp("-", outfile) == 0;
+    if (flag.int_out->answer && flag.float_out->answer)
+	G_fatal_error(_("-i and -f are mutually exclusive"));
     fd = Rast_open_old(name, "");
-    map_type = Rast_get_map_type(fd);
-    if (!flag.int_out->answer)
-	out_type = map_type;
+    if (flag.int_out->answer)
+	is_fp = 0;
+    else if (flag.float_out->answer)
+	is_fp = 1;
     else
-	out_type = CELL_TYPE;
+	is_fp = Rast_get_map_type(fd) != CELL_TYPE;
+    if (parm.size->answer)
+	size = atoi(parm.size->answer);
+    else if (is_fp)
+	size = 4;
+    else
+	size = 2;
+    if (is_fp && size < 4)
+	G_fatal_error(_("Floating-point output requires size=4 or size=8"));
+#ifndef HAVE_LONG_LONG_INT
+    if (!is_fp && size > 4)
+	G_fatal_error(_("Integer output doesn't support size=8 in this build"));
+#endif
+    G_get_window(®ion);
     /* open bin file for writing */
     if (do_stdout)
 	fp = stdout;
     else if (NULL == (fp = fopen(outfile, "w")))
 	G_fatal_error(_("Unable to create file <%s>"), outfile);
-    /* Check Endian State of Host Computer */
-    if (G_is_little_endian()) {
-	swapFlag = 1;		/*true: little endian */
-	if (flag.swap->answer)
-	    swapFlag = 0;	/* Swapping enabled */
-    else {
-	swapFlag = 0;
-	    swapFlag = 1;	/* Swapping enabled */
     /* Set up Parameters for GMT header */
     if (flag.gmt_hd->answer) {
-	Rast_read_fp_range(name, "", &range);
-	Rast_get_fp_range_min_max(&range, &Z_MIN, &Z_MAX);
-	header.nx = region.cols;
-	header.ny = region.rows;
-	header.node_offset = 1;	/* 1 is pixel registration */
-	header.x_min = (double)region.west;
-	header.x_max = (double)region.east;
-	header.y_min = (double)region.south;
-	header.y_max = (double)region.north;
-	header.z_min = (double)Z_MIN;
-	header.z_max = (double)Z_MAX;
-	header.x_inc = (double)region.ew_res;
-	header.y_inc = (double)region.ns_res;
-	header.z_scale_factor = (double)1.0;
-	header.z_add_offset = (double)0.0;
-	/* Swap Header if Required */
-	if (flag.swap->answer) {
-	    G_message(_("Swapping header data"));
-	    TIFFSwabLong((uint32 *) & header.nx);
-	    TIFFSwabLong((uint32 *) & header.ny);
-	    TIFFSwabLong((uint32 *) & header.node_offset);
-	    TIFFSwabDouble((double *)&header.x_min);
-	    TIFFSwabDouble((double *)&header.x_max);
-	    TIFFSwabDouble((double *)&header.y_min);
-	    TIFFSwabDouble((double *)&header.y_max);
-	    TIFFSwabDouble((double *)&header.z_min);
-	    TIFFSwabDouble((double *)&header.z_max);
-	    TIFFSwabDouble((double *)&header.x_inc);
-	    TIFFSwabDouble((double *)&header.y_inc);
-	    TIFFSwabDouble((double *)&header.z_scale_factor);
-	    TIFFSwabDouble((double *)&header.z_add_offset);
-	if (region.proj == PROJECTION_LL) {
-	    strcpy(header.x_units, "degrees");
-	    strcpy(header.y_units, "degrees");
-	else {
-	    strcpy(header.x_units, "Meters");
-	    strcpy(header.y_units, "Meters");
-	strcpy(header.z_units, "elevation");
-	strcpy(header.title, name);
-	strcpy(header.command, "r.out.bin -h input=");
-	strcat(header.command, name);
-	strcat(header.command, " output=");
-	strcat(header.command, outfile);
-	    TIFFSwabLong((uint32 *) & null_str);
-	sprintf(buf, "%d", null_str);
-	strcpy(header.remark, buf);
-	strcat(header.remark, " used for NULL");
+	    G_fatal_error(_("GMT grid doesn't support 64-bit integers"));
+	make_gmt_header(&header, name, outfile, ®ion, null_val);
     /* Write out BIL support files compatible with Arc-View */
-    if (flag.BIL_hd->answer) {
-	char out_tmp1[GPATH_MAX], out_tmp2[GPATH_MAX];
-	FILE *fp_1, *fp_2;
-	strcpy(out_tmp1, outfile);
-	strcat(out_tmp1, ".hdr");
-	strcpy(out_tmp2, outfile);
-	strcat(out_tmp2, ".wld");
-	/* Open Header File */
-	if (NULL == (fp_1 = fopen(out_tmp1, "w")))
-	    G_fatal_error(_("Unable to create file <%s>"), out_tmp1);
-	/* Open World File */
-	if (NULL == (fp_2 = fopen(out_tmp2, "w")))
-	    G_fatal_error(_("Unable to create file <%s>"), out_tmp2);
+    if (flag.bil_hd->answer) {
 	G_message(_("Creating BIL support files..."));
-	G_message(_("Header File = %s"), out_tmp1);
-	G_message(_("World File = %s"), out_tmp2);
-	fprintf(fp_1, "nrows %d\n", region.rows);
-	fprintf(fp_1, "ncols %d\n", region.cols);
-	fprintf(fp_1, "nbands 1\n");
-	if (out_type == CELL_TYPE)
-	    fprintf(fp_1, "nbits 16\n");
-	if (out_type == FCELL_TYPE)
-	    fprintf(fp_1, "nbits 32\n");
-	if (out_type == DCELL_TYPE)
-	    fprintf(fp_1, "nbits 64\n");
-	if (swapFlag == 1)
-	    fprintf(fp_1, "byteorder I\n");	/* Intel - little endian */
-	if (swapFlag == 0)
-	    fprintf(fp_1, "byteorder M\n");	/* Motorola - big endian */
-	fprintf(fp_1, "layout bil\n");
-	if (flag.gmt_hd->answer) {
-		fprintf(fp_1, "skipbytes 892\n");	/* Real size of struct - little endian */
-	    else
-		fprintf(fp_1, "skipbytes 896\n");	/* Pad size of struct - big endian */
-	else
-	    fprintf(fp_1, "skipbytes 0\n");
-	fprintf(fp_1, "nodata %d\n", null_str);
-	fclose(fp_1);
-	fprintf(fp_2, "%f\n", region.ew_res);
-	fprintf(fp_2, "0.0\n");
-	fprintf(fp_2, "-%f\n", region.ns_res);
-	fprintf(fp_2, "%f\n", region.west + (region.ew_res / 2));
-	fprintf(fp_2, "%f\n", region.north - (region.ns_res / 2));
-	fclose(fp_2);
+	write_bil_hdr(outfile, ®ion,
+		      size, order, flag.gmt_hd->answer, null_val);
+	write_bil_wld(outfile, ®ion);
-    raster = Rast_allocate_buf(out_type);
     /* Write out GMT Header if required */
-	/* Write Values 1 at a time if byteswapping */
-	fwrite(&header.nx, sizeof(int), 1, fp);
-	fwrite(&header.ny, sizeof(int), 1, fp);
-	fwrite(&header.node_offset, sizeof(int), 1, fp);
-	if (swapFlag == 0)	/* Padding needed for big-endian */
+    if (flag.gmt_hd->answer)
+	write_gmt_header(&header, swap_flag, fp);
-	fwrite(&header.x_min, sizeof(double), 1, fp);
-	fwrite(&header.x_max, sizeof(double), 1, fp);
-	fwrite(&header.y_min, sizeof(double), 1, fp);
-	fwrite(&header.y_max, sizeof(double), 1, fp);
-	fwrite(&header.z_min, sizeof(double), 1, fp);
-	fwrite(&header.z_max, sizeof(double), 1, fp);
-	fwrite(&header.x_inc, sizeof(double), 1, fp);
-	fwrite(&header.y_inc, sizeof(double), 1, fp);
-	fwrite(&header.z_scale_factor, sizeof(double), 1, fp);
-	fwrite(&header.z_add_offset, sizeof(double), 1, fp);
-	fwrite(&header.x_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
-	fwrite(&header.y_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
-	fwrite(&header.z_units, sizeof(char[GRD_UNIT_LEN]), 1, fp);
-	fwrite(&header.title, sizeof(char[GRD_TITLE_LEN]), 1, fp);
-	fwrite(&header.command, sizeof(char[GRD_COMMAND_LEN]), 1, fp);
-	fwrite(&header.remark, sizeof(char[GRD_REMARK_LEN]), 1, fp);
     nrows = G_window_rows();
     ncols = G_window_cols();
-    if (out_type == CELL_TYPE) {
-	G_message(_("Exporting raster as integer values (bytes=%d)"),
-		  sizeof(short));
+    in_buf = Rast_allocate_d_buf();
+    out_buf = G_malloc(ncols * size);
+    if (is_fp) {
+	G_message(_("Exporting raster as floating values (bytes=%d)"), size);
-	    G_message(_("Writing GMT integer format ID=2"));
+	    G_message(_("Writing GMT float format ID=1"));
-    if (out_type == FCELL_TYPE) {
-	G_message(_("Exporting raster as floating values (bytes=%d)"),
-		  sizeof(float));
+    else {
+	G_message(_("Exporting raster as integer values (bytes=%d)"), size);
-	    G_message(_("Writing GMT float format ID=1"));
+	    G_message(_("Writing GMT integer format ID=2"));
-	G_message(_("Exporting raster as double values (bytes=%d)"),
-		  sizeof(double));
-    G_message(_("Using the current region settings..."));
-    G_message(_("north=%f"), region.north);
-    G_message(_("south=%f"), region.south);
-    G_message(_("east=%f"), region.east);
-    G_message(_("west=%f"), region.west);
-    G_message(_("r=%d"), region.rows);
-    G_message(_("c=%d"), region.cols);
+    G_verbose_message(_("Using the current region settings..."));
+    G_verbose_message(_("north=%f"), region.north);
+    G_verbose_message(_("south=%f"), region.south);
+    G_verbose_message(_("east=%f"), region.east);
+    G_verbose_message(_("west=%f"), region.west);
+    G_verbose_message(_("r=%d"), region.rows);
+    G_verbose_message(_("c=%d"), region.cols);
     for (row = 0; row < nrows; row++) {
-	Rast_get_row(fd, raster, row, out_type);
 	G_percent(row, nrows, 2);
-	for (col = 0, ptr = raster; col < ncols; col++,
-	     ptr = G_incr_void_ptr(ptr, Rast_cell_size(out_type))) {
-	    if (!Rast_is_null_value(ptr, out_type)) {
-		    number_i = *((CELL *) ptr);
-			TIFFSwabShort((uint16 *) & number_i);
-		    fwrite(&number_i, sizeof(short), 1, fp);
-		else if (out_type == FCELL_TYPE) {
-		    number_f = *((FCELL *) ptr);
-			TIFFSwabLong((uint32 *) & number_f);
-		    fwrite(&number_f, sizeof(float), 1, fp);
-		else if (out_type == DCELL_TYPE) {
-		    number_d = *((DCELL *) ptr);
-			TIFFSwabDouble((double *)&number_d);
-		    fwrite(&number_d, sizeof(double), 1, fp);
-	    else {
-		    null_val_i = (int)null_str;
-			TIFFSwabShort((uint16 *) & null_val_i);
-		    fwrite(&null_val_i, sizeof(short), 1, fp);
-		    null_val_f = (float)null_str;
-			TIFFSwabLong((uint32 *) & null_val_f);
-		    fwrite(&null_val_f, sizeof(float), 1, fp);
-		if (out_type == DCELL_TYPE) {
-		    null_val_d = (double)null_str;
-			TIFFSwabDouble((double *)&null_val_d);
-		    fwrite(&null_val_d, sizeof(double), 1, fp);
+	Rast_get_d_row(fd, in_buf, row);
+	convert_row(out_buf, in_buf, ncols, is_fp, size, swap_flag, null_val);
+	if (fwrite(out_buf, size, ncols, fp) != ncols)
     G_percent(row, nrows, 2);	/* finish it off */
     Rast_close(fd);
     fclose(fp);
-    exit(EXIT_SUCCESS);
+    return EXIT_SUCCESS;
-#ifdef UNUSED
-int set_type(char *str, RASTER_MAP_TYPE * out_type)
-    char *ch;
-    ch = str;
-    if (*ch != '%')
-	G_fatal_error("wrong format: %s", str);
-    while (*(++ch)) ;
-    ch--;
-    if (*ch == 'd' || *ch == 'i' || *ch == 'o' || *ch == 'u' || *ch == 'x' ||
-	*ch == 'X')
-	*out_type = CELL_TYPE;
-    else if (*ch == 'f' || *ch == 'e' || *ch == 'E' || *ch == 'g' ||
-	     *ch == 'G')
-	*out_type = DCELL_TYPE;
-    /*      *out_type = FCELL_TYPE; */
-    return 0;
-#endif
Deleted: grass/trunk/raster/r.out.bin/swab.h
--- grass/trunk/raster/r.out.bin/swab.h	2010-01-12 01:38:31 UTC (rev 40373)
+++ grass/trunk/raster/r.out.bin/swab.h	2010-01-12 07:47:37 UTC (rev 40374)
@@ -1,21 +0,0 @@
-typedef signed char int8;	/* NB: non-ANSI compilers may not grok */
-typedef unsigned char uint8;
-typedef short int16;
-typedef unsigned short uint16;	/* sizeof (uint16) must == 2 */
-#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64)
-typedef int int32;
-typedef unsigned int uint32;	/* sizeof (uint32) must == 4 */
-#else
-typedef long int32;
-typedef unsigned long uint32;	/* sizeof (uint32) must == 4 */
-#endif
-extern void TIFFSwabShort(uint16 *);
-extern void TIFFSwabLong(uint32 *);
-extern void TIFFSwabDouble(double *);
-extern void TIFFSwabArrayOfShort(uint16 *, unsigned long);
-extern void TIFFSwabArrayOfLong(uint32 *, unsigned long);
-extern void TIFFSwabArrayOfDouble(double *, unsigned long);
-extern void TIFFReverseBits(unsigned char *, unsigned long);
-extern const unsigned char *TIFFGetBitRevTable(int);
Deleted: grass/trunk/raster/r.out.bin/tif_swab.c
--- grass/trunk/raster/r.out.bin/tif_swab.c	2010-01-12 01:38:31 UTC (rev 40373)
+++ grass/trunk/raster/r.out.bin/tif_swab.c	2010-01-12 07:47:37 UTC (rev 40374)
@@ -1,235 +0,0 @@
-/* $Header$ */
- * Copyright (c) 1988-1997 Sam Leffler
- * Copyright (c) 1991-1997 Silicon Graphics, Inc.
- * Permission to use, copy, modify, distribute, and sell this software and
- * its documentation for any purpose is hereby granted without fee, provided
- * that (i) the above copyright notices and this permission notice appear in
- * all copies of the software and related documentation, and (ii) the names of
- * Sam Leffler and Silicon Graphics may not be used in any advertising or
- * publicity relating to the software without the specific, prior written
- * permission of Sam Leffler and Silicon Graphics.
- * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
- * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
- * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
- * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
- * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
- * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
- * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
- * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
- * OF THIS SOFTWARE.
- * TIFF Library Bit & Byte Swapping Support.
- * XXX We assume short = 16-bits and long = 32-bits XXX
-/* Headers from port.h */
-#include <sys/types.h>
-#include <stdio.h>
-#include <unistd.h>
-#include <string.h>
-#include <stdlib.h>
-#include <fcntl.h>
-/* Local header pulled from tiff.h and tiffio.h */
-#ifndef TIFFSwabShort
-void TIFFSwabShort(uint16 * wp)
-    uint8 *cp = (uint8 *) wp;
-    int t;
-    t = cp[1];
-    cp[1] = cp[0];
-    cp[0] = t;
-#endif
-#ifndef TIFFSwabLong
-void TIFFSwabLong(uint32 * lp)
-    uint8 *cp = (uint8 *) lp;
-    int t;
-    t = cp[3];
-    cp[3] = cp[0];
-    cp[0] = t;
-    t = cp[2];
-    cp[2] = cp[1];
-    cp[1] = t;
-#endif
-#ifndef TIFFSwabArrayOfShort
-void TIFFSwabArrayOfShort(uint16 * wp, unsigned long n)
-    uint8 *cp;
-    int t;
-    /* XXX unroll loop some */
-    while (n-- > 0) {
-	cp = (uint8 *) wp;
-	t = cp[1];
-	cp[1] = cp[0];
-	cp[0] = t;
-	wp++;
-#endif
-#ifndef TIFFSwabArrayOfLong
-void TIFFSwabArrayOfLong(uint32 * lp, unsigned long n)
-    unsigned char *cp;
-    int t;
-    while (n-- > 0) {
-	cp = (unsigned char *)lp;
-	t = cp[3];
-	cp[3] = cp[0];
-	cp[0] = t;
-	t = cp[2];
-	cp[2] = cp[1];
-	cp[1] = t;
-	lp++;
-#endif
-#ifndef TIFFSwabDouble
-void TIFFSwabDouble(double *dp)
-    uint32 *lp = (uint32 *) dp;
-    int t;
-    TIFFSwabArrayOfLong(lp, 2);
-    t = lp[0];
-    lp[0] = lp[1];
-    lp[1] = t;
-#endif
-#ifndef TIFFSwabArrayOfDouble
-void TIFFSwabArrayOfDouble(double *dp, unsigned long n)
-    uint32 t;
-    TIFFSwabArrayOfLong(lp, n + n);
-    while (n-- > 0) {
-	t = lp[0];
-	lp[0] = lp[1];
-	lp[1] = t;
-	lp += 2;
-#endif
- * Bit reversal tables.  TIFFBitRevTable[<byte>] gives
- * the bit reversed value of <byte>.  Used in various
- * places in the library when the FillOrder requires
- * bit reversal of byte values (e.g. CCITT Fax 3
- * encoding/decoding).  TIFFNoBitRevTable is provided
- * for algorithms that want an equivalent table that
- * do not reverse bit values.
-static const unsigned char TIFFBitRevTable[256] = {
-    0x00, 0x80, 0x40, 0xc0, 0x20, 0xa0, 0x60, 0xe0,
-    0x10, 0x90, 0x50, 0xd0, 0x30, 0xb0, 0x70, 0xf0,
-    0x08, 0x88, 0x48, 0xc8, 0x28, 0xa8, 0x68, 0xe8,
-    0x18, 0x98, 0x58, 0xd8, 0x38, 0xb8, 0x78, 0xf8,
-    0x04, 0x84, 0x44, 0xc4, 0x24, 0xa4, 0x64, 0xe4,
-    0x14, 0x94, 0x54, 0xd4, 0x34, 0xb4, 0x74, 0xf4,
-    0x0c, 0x8c, 0x4c, 0xcc, 0x2c, 0xac, 0x6c, 0xec,
-    0x1c, 0x9c, 0x5c, 0xdc, 0x3c, 0xbc, 0x7c, 0xfc,
-    0x02, 0x82, 0x42, 0xc2, 0x22, 0xa2, 0x62, 0xe2,
-    0x12, 0x92, 0x52, 0xd2, 0x32, 0xb2, 0x72, 0xf2,
-    0x0a, 0x8a, 0x4a, 0xca, 0x2a, 0xaa, 0x6a, 0xea,
-    0x1a, 0x9a, 0x5a, 0xda, 0x3a, 0xba, 0x7a, 0xfa,
-    0x06, 0x86, 0x46, 0xc6, 0x26, 0xa6, 0x66, 0xe6,
-    0x16, 0x96, 0x56, 0xd6, 0x36, 0xb6, 0x76, 0xf6,
-    0x0e, 0x8e, 0x4e, 0xce, 0x2e, 0xae, 0x6e, 0xee,
-    0x1e, 0x9e, 0x5e, 0xde, 0x3e, 0xbe, 0x7e, 0xfe,
-    0x01, 0x81, 0x41, 0xc1, 0x21, 0xa1, 0x61, 0xe1,
-    0x11, 0x91, 0x51, 0xd1, 0x31, 0xb1, 0x71, 0xf1,
-    0x09, 0x89, 0x49, 0xc9, 0x29, 0xa9, 0x69, 0xe9,
-    0x19, 0x99, 0x59, 0xd9, 0x39, 0xb9, 0x79, 0xf9,
-    0x05, 0x85, 0x45, 0xc5, 0x25, 0xa5, 0x65, 0xe5,
-    0x15, 0x95, 0x55, 0xd5, 0x35, 0xb5, 0x75, 0xf5,
-    0x0d, 0x8d, 0x4d, 0xcd, 0x2d, 0xad, 0x6d, 0xed,
-    0x1d, 0x9d, 0x5d, 0xdd, 0x3d, 0xbd, 0x7d, 0xfd,
-    0x03, 0x83, 0x43, 0xc3, 0x23, 0xa3, 0x63, 0xe3,
-    0x13, 0x93, 0x53, 0xd3, 0x33, 0xb3, 0x73, 0xf3,
-    0x0b, 0x8b, 0x4b, 0xcb, 0x2b, 0xab, 0x6b, 0xeb,
-    0x1b, 0x9b, 0x5b, 0xdb, 0x3b, 0xbb, 0x7b, 0xfb,
-    0x07, 0x87, 0x47, 0xc7, 0x27, 0xa7, 0x67, 0xe7,
-    0x17, 0x97, 0x57, 0xd7, 0x37, 0xb7, 0x77, 0xf7,
-    0x0f, 0x8f, 0x4f, 0xcf, 0x2f, 0xaf, 0x6f, 0xef,
-    0x1f, 0x9f, 0x5f, 0xdf, 0x3f, 0xbf, 0x7f, 0xff
-static const unsigned char TIFFNoBitRevTable[256] = {
-    0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
-    0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
-    0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
-    0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
-    0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27,
-    0x28, 0x29, 0x2a, 0x2b, 0x2c, 0x2d, 0x2e, 0x2f,
-    0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37,
-    0x38, 0x39, 0x3a, 0x3b, 0x3c, 0x3d, 0x3e, 0x3f,
-    0x40, 0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47,
-    0x48, 0x49, 0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f,
-    0x50, 0x51, 0x52, 0x53, 0x54, 0x55, 0x56, 0x57,
-    0x58, 0x59, 0x5a, 0x5b, 0x5c, 0x5d, 0x5e, 0x5f,
-    0x60, 0x61, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67,
-    0x68, 0x69, 0x6a, 0x6b, 0x6c, 0x6d, 0x6e, 0x6f,
-    0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77,
-    0x78, 0x79, 0x7a, 0x7b, 0x7c, 0x7d, 0x7e, 0x7f,
-    0x80, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, 0x87,
-    0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, 0x8f,
-    0x90, 0x91, 0x92, 0x93, 0x94, 0x95, 0x96, 0x97,
-    0x98, 0x99, 0x9a, 0x9b, 0x9c, 0x9d, 0x9e, 0x9f,
-    0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6, 0xa7,
-    0xa8, 0xa9, 0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf,
-    0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5, 0xb6, 0xb7,
-    0xb8, 0xb9, 0xba, 0xbb, 0xbc, 0xbd, 0xbe, 0xbf,
-    0xc0, 0xc1, 0xc2, 0xc3, 0xc4, 0xc5, 0xc6, 0xc7,
-    0xc8, 0xc9, 0xca, 0xcb, 0xcc, 0xcd, 0xce, 0xcf,
-    0xd0, 0xd1, 0xd2, 0xd3, 0xd4, 0xd5, 0xd6, 0xd7,
-    0xd8, 0xd9, 0xda, 0xdb, 0xdc, 0xdd, 0xde, 0xdf,
-    0xe0, 0xe1, 0xe2, 0xe3, 0xe4, 0xe5, 0xe6, 0xe7,
-    0xe8, 0xe9, 0xea, 0xeb, 0xec, 0xed, 0xee, 0xef,
-    0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, 0xf6, 0xf7,
-    0xf8, 0xf9, 0xfa, 0xfb, 0xfc, 0xfd, 0xfe, 0xff,
-const unsigned char *TIFFGetBitRevTable(int reversed)
-    return (reversed ? TIFFBitRevTable : TIFFNoBitRevTable);
-void TIFFReverseBits(uint8 * cp, unsigned long n)
-    for (; n > 8; n -= 8) {
-	cp[0] = TIFFBitRevTable[cp[0]];
-	cp[1] = TIFFBitRevTable[cp[1]];
-	cp[2] = TIFFBitRevTable[cp[2]];
-	cp[3] = TIFFBitRevTable[cp[3]];
-	cp[4] = TIFFBitRevTable[cp[4]];
-	cp[5] = TIFFBitRevTable[cp[5]];
-	cp[6] = TIFFBitRevTable[cp[6]];
-	cp[7] = TIFFBitRevTable[cp[7]];
-	cp += 8;
-    while (n-- > 0)
-	*cp = TIFFBitRevTable[*cp], cp++;
