[GRASS-SVN] r40378 - grass/trunk/db/drivers/ogr
svn_grass at osgeo.org
Tue Jan 12 03:19:06 EST 2010
Author: neteler
Date: 2010-01-12 03:19:05 -0500 (Tue, 12 Jan 2010)
New Revision: 40378
grass/trunk/db/drivers/ogr/describe.c
grass/trunk/db/drivers/ogr/fetch.c
activate OFTDate, OFTTime, OFTDateTime (treat as strings as in DBF driver)
Modified: grass/trunk/db/drivers/ogr/describe.c
--- grass/trunk/db/drivers/ogr/describe.c 2010-01-12 08:17:34 UTC (rev 40377)
+++ grass/trunk/db/drivers/ogr/describe.c 2010-01-12 08:19:05 UTC (rev 40378)
@@ -111,7 +111,8 @@
fieldName = OGR_Fld_GetNameRef(hFieldDefn);
if (ogrType != OFTInteger && ogrType != OFTReal &&
- ogrType != OFTString) {
+ ogrType != OFTString && ogrType != OFTDate &&
+ ogrType != OFTTime && ogrType != OFTDateTime ) {
G_warning(_("OGR driver: column '%s', OGR type %d is not supported"),
fieldName, ogrType);
cols[i] = 0;
@@ -186,6 +187,9 @@
break;
case OFTString:
+ case OFTDate:
+ case OFTTime:
+ case OFTDateTime:
sqlType = DB_SQL_TYPE_CHARACTER;
size = OGR_Fld_GetWidth(hFieldDefn);
if (size == 0) {
Modified: grass/trunk/db/drivers/ogr/fetch.c
--- grass/trunk/db/drivers/ogr/fetch.c 2010-01-12 08:17:34 UTC (rev 40377)
+++ grass/trunk/db/drivers/ogr/fetch.c 2010-01-12 08:19:05 UTC (rev 40378)
@@ -152,6 +152,9 @@
break;
case OFTString:
+ case OFTDate:
+ case OFTTime:
+ case OFTDateTime:
db_set_string(&(value->s),
(char *)OGR_F_GetFieldAsString(c->hFeature, i));
break;
