[GRASS-SVN] r40400 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jan 12 16:43:42 EST 2010
Author: glynn
Date: 2010-01-12 16:43:41 -0500 (Tue, 12 Jan 2010)
New Revision: 40400
grass/trunk/gui/wxpython/gui_modules/menudata.py
Allow explicit path to menudata.xml
Add "dump" action
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2010-01-12 21:41:31 UTC (rev 40399)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2010-01-12 21:43:41 UTC (rev 40400)
@@ -30,6 +30,7 @@
import os
import sys
+import pprint
try:
import xml.etree.ElementTree as etree
except ImportError:
@@ -37,10 +38,10 @@
class Data:
'''!Data object that returns menu descriptions to be used in wxgui.py.'''
- def __init__(self, gisbase=None):
- if not gisbase:
+ def __init__(self, filename=None):
+ if not filename:
gisbase = os.getenv('GISBASE')
- filename = os.path.join(gisbase, 'etc', 'wxpython', 'xml', 'menudata.xml')
+ filename = os.path.join(gisbase, 'etc', 'wxpython', 'xml', 'menudata.xml')
self.tree = etree.parse(filename)
def getMenuItem(self, mi):
@@ -159,7 +160,7 @@
fh.write(menuSep.join(menuItems))
fh.write('%s%s' % (menuSep, eachItem[0]))
fh.write('\n')
def GetModules(self):
"""!Create dictionary of modules used to search module by
keywords, description, etc."""
@@ -212,5 +213,7 @@
data.PrintTree(sys.stdout)
elif action == 'commands':
data.PrintCommands(sys.stdout)
+ elif action == 'dump':
+ pprint.pprint(data.GetMenu(), stream = sys.stdout, indent = 2)
sys.exit(0)
