[GRASS-SVN] r40456 - in grass/branches/develbranch_6:
display/d.nviz display/drivers/HTMLMAP lib/init
raster/r.in.gdal raster/r.out.vtk raster/r.profile
raster/r.sun raster3d/r3.out.vtk scripts/r.tileset
vector/v.surf.idw vector/v.to.points
svn_grass at osgeo.org
Fri Jan 15 10:02:44 EST 2010
Author: neteler
Date: 2010-01-15 10:02:44 -0500 (Fri, 15 Jan 2010)
New Revision: 40456
grass/branches/develbranch_6/display/d.nviz/description.html
grass/branches/develbranch_6/display/drivers/HTMLMAP/description.html
grass/branches/develbranch_6/lib/init/variables.html
grass/branches/develbranch_6/raster/r.in.gdal/description.html
grass/branches/develbranch_6/raster/r.out.vtk/description.html
grass/branches/develbranch_6/raster/r.profile/description.html
grass/branches/develbranch_6/raster/r.sun/description.html
grass/branches/develbranch_6/raster3d/r3.out.vtk/description.html
grass/branches/develbranch_6/scripts/r.tileset/description.html
grass/branches/develbranch_6/vector/v.surf.idw/description.html
grass/branches/develbranch_6/vector/v.to.points/description.html
Fix spelling errors (trac #872)
Modified: grass/branches/develbranch_6/display/d.nviz/description.html
--- grass/branches/develbranch_6/display/d.nviz/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/display/d.nviz/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -75,7 +75,7 @@
number 2000.
<DT><B>route</B>
-<DD>The comma seperated geographic coordinates for keyframe locations.
+<DD>The comma separated geographic coordinates for keyframe locations.
<DD>The interactive flag (<EM>-i</EM>) overrides this option.
</DL>
@@ -102,7 +102,7 @@
<p>
If the GRASS region is changed the <EM>d.nviz</EM> command must be re-run.
<p>
-The current GRASS region and the user supplied paramters are included
+The current GRASS region and the user supplied parameters are included
as a comment at the top of the output script. This information can be
used to easily re-create the animation.
<p>
Modified: grass/branches/develbranch_6/display/drivers/HTMLMAP/description.html
--- grass/branches/develbranch_6/display/drivers/HTMLMAP/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/display/drivers/HTMLMAP/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -92,7 +92,7 @@
</LI><BR>
<LI><B>GRASS_HTMLMAXPOINTS=n</B><BR>specifies the maximum number of
vertices included in a polygon's clickable area.
- The default is <tt>99</tt>. Some browsers can only accomodate polygons of
+ The default is <tt>99</tt>. Some browsers can only accommodate polygons of
100 vertices or less. The HTMLMAP driver automatically ensures that a
polygon is closed by making the last point the same as the first
point.</LI><BR>
Modified: grass/branches/develbranch_6/lib/init/variables.html
--- grass/branches/develbranch_6/lib/init/variables.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/lib/init/variables.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -481,7 +481,7 @@
This variable is automatically created
by <em><a href="g.parser.html">g.parser</a></em> so that the
<tt>--overwrite</tt> option will
- be inherited by dependant modules as the script runs. Setting either the
+ be inherited by dependent modules as the script runs. Setting either the
GRASS_OVERWRITE environment variable or the OVERWRITE gisenv variable detailed
below will cause maps with identical names to be overwritten.</dd>
@@ -497,7 +497,7 @@
</ul>
This variable is automatically created by <em><a href="g.parser.html">g.parser</a></em>
so that the <tt>--verbose</tt> or <tt>--quiet</tt> flags will be inherited
- by dependant modules as the script runs.</dd>
+ by dependent modules as the script runs.</dd>
<br>
<dt>GRASS_REGION</dt>
@@ -587,7 +587,7 @@
</dl>
Modified: grass/branches/develbranch_6/raster/r.in.gdal/description.html
--- grass/branches/develbranch_6/raster/r.in.gdal/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/raster/r.in.gdal/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -117,7 +117,7 @@
reporting everything known about a dataset if the <b>output</b> parameter is not set.
<p>
-The <em>r.in.gdal</em> comand does support the following features, as long as
+The <em>r.in.gdal</em> command does support the following features, as long as
the underlying format driver supports it:
<p>
Modified: grass/branches/develbranch_6/raster/r.out.vtk/description.html
--- grass/branches/develbranch_6/raster/r.out.vtk/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/raster/r.out.vtk/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -44,9 +44,9 @@
<em><a href="http://mayavi.sourceforge.net">MayaVi</a></em> which are based on VTK.
If you have a raster map with partly no data, use the threshold filter in paraview to
visualize the valid data. Just filter all data which is greater/lesser than the
-choosen null value in the VTK-ASCII file.
+chosen null value in the VTK-ASCII file.
<br>
-If elevation map is choosen, a polygonal grid is created with <i>quads</i>,
+If elevation map is chosen, a polygonal grid is created with <i>quads</i>,
but the user can choose also <i>triangle strips</i> or <i>vertices</i>.
These dataformats a documented at <em><a href="http://www.vtk.org">VTK Toolkit</a></em>.
<br>
Modified: grass/branches/develbranch_6/raster/r.profile/description.html
--- grass/branches/develbranch_6/raster/r.profile/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/raster/r.profile/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -87,7 +87,7 @@
The advantage of this method is that the same profile points can be piped into
different GRASS rasters by changing the input parameter.
<p>
-With this method the coordinates must be given as space or tab seperated easting
+With this method the coordinates must be given as space or tab separated easting
and northing. Labels after these values are ignored.
<p>
Another example using d.where:
Modified: grass/branches/develbranch_6/raster/r.sun/description.html
--- grass/branches/develbranch_6/raster/r.sun/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/raster/r.sun/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -52,7 +52,7 @@
and defined projection/coordinate system (check it with the <a href="g.proj.html">
g.proj</a>
command). If you have undefined projection, (x,y) system, etc. then the latitude
-can be defined explicitely for large areas by input raster map <i>latin</i>
+can be defined explicitly for large areas by input raster map <i>latin</i>
with interpolated latitude values or, for smaller areas, a single region
latitude value <i>lat</i> can be used instead. All input raster maps must
be floating point (FCELL) raster maps. Null data in maps are excluded from
Modified: grass/branches/develbranch_6/raster3d/r3.out.vtk/description.html
--- grass/branches/develbranch_6/raster3d/r3.out.vtk/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/raster3d/r3.out.vtk/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -20,7 +20,7 @@
<EM><A HREF="http://mayavi.sourceforge.net">MayaVi</A></EM> which are based on VTK.
If you have a 3D raster map with partly no data, use the threshold filter in paraview to
<BR><BR>
The top and bottom region settings are expected in meters.
Modified: grass/branches/develbranch_6/scripts/r.tileset/description.html
--- grass/branches/develbranch_6/scripts/r.tileset/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/scripts/r.tileset/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -24,7 +24,7 @@
<H2>OUTPUT FORMAT</H2>
-Each tile is listed on a seperate line in the output. The lines are
+Each tile is listed on a separate line in the output. The lines are
formatted as follows:
<dl>
@@ -36,8 +36,8 @@
<dd>
This is the default output format. It is the tile's minimum x coordinate,
minimum y coordinate, maximum x coordinate, maximum y coordinate, width
-in cells, and height in cells seperated by the "|" character. The fields
-can be seperated by a different character by changing the fs option.
+in cells, and height in cells separated by the "|" character. The fields
+can be separated by a different character by changing the fs option.
<p>
@@ -73,7 +73,7 @@
</pre></div>
<dd> Generates tiles in latitude longitude that cover the current region,
each tile will be less than 1024 cells high and 2048 cells across.
-The bounds and sizes of tiles in the output are seperated by "|"
+The bounds and sizes of tiles in the output are separated by "|"
<p>
Modified: grass/branches/develbranch_6/vector/v.surf.idw/description.html
--- grass/branches/develbranch_6/vector/v.surf.idw/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/vector/v.surf.idw/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -48,7 +48,7 @@
<p>
If more than <EM>count</EM> points fall into one target raster cell,
the mean of all the site values will determine the cell value (unless
-the -n flag is specifed, in which case only the <EM>count</EM>
+the -n flag is specified, in which case only the <EM>count</EM>
points closest to the centre of the cell will be interpolated).</p>
<P>
Modified: grass/branches/develbranch_6/vector/v.to.points/description.html
--- grass/branches/develbranch_6/vector/v.to.points/description.html 2010-01-15 14:57:25 UTC (rev 40455)
+++ grass/branches/develbranch_6/vector/v.to.points/description.html 2010-01-15 15:02:44 UTC (rev 40456)
@@ -36,7 +36,7 @@
adjoining polygons share a topological boundary, the boundary only
gets converted to points once.</li>
<li>
-If the <em>type</em> paramter is set to <em>area</em>, the boundary of
+If the <em>type</em> parameter is set to <em>area</em>, the boundary of
each area is converted to points <i>regardless</i> of whether or not
there is a topological boundary between adjacent areas. In other
words, the common boundary of two adjoining areas, for example, gets
