[GRASS-SVN] r40477 - in grass/trunk:
imagery/i.evapo.time_integration raster/r.cost
raster/r.in.mat raster/r.in.xyz raster/r.li/r.li.patchdensity
raster/r.statistics raster3d/r3.cross.rast raster3d/r3.gwflow
raster3d/r3.out.vtk vector/v.hull
svn_grass at osgeo.org
Sat Jan 16 18:18:55 EST 2010
Author: hamish
Date: 2010-01-16 18:18:54 -0500 (Sat, 16 Jan 2010)
New Revision: 40477
grass/trunk/imagery/i.evapo.time_integration/i.evapo.time_integration.html
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.in.mat/r.in.mat.html
grass/trunk/raster/r.in.xyz/r.in.xyz.html
grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
grass/trunk/raster/r.statistics/r.statistics.html
grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html
grass/trunk/vector/v.hull/v.hull.html
add spaces around '=' for r.mapcalc examples
Modified: grass/trunk/imagery/i.evapo.time_integration/i.evapo.time_integration.html
--- grass/trunk/imagery/i.evapo.time_integration/i.evapo.time_integration.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/imagery/i.evapo.time_integration/i.evapo.time_integration.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -28,7 +28,7 @@
n=0
for ETo_val in Eto[1] Eto[2] ...
do
- r.mapcalc eto$n=$ETo_val
+ r.mapcalc "eto$n = $ETo_val"
`expr n = n + 1'
done
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster/r.cost/r.cost.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -221,13 +221,13 @@
<div class="code"><pre>
g.region rast=roads -p
- r.mapcalc "area.one=1"
+ r.mapcalc "area.one = 1"
r.cost -k input=area.one output=distance start_rast=roads
d.rast distance
d.rast.num distance
#transform to metric distance from cell distance using the raster resolution:
- r.mapcalc "dist_meters=distance * (ewres()+nsres())/2."
+ r.mapcalc "dist_meters = distance * (ewres()+nsres())/2."
d.rast dist_meters
</pre></div>
Modified: grass/trunk/raster/r.in.mat/r.in.mat.html
--- grass/trunk/raster/r.in.mat/r.in.mat.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster/r.in.mat/r.in.mat.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -51,7 +51,7 @@
map is loaded into GRASS you can convert it back to an integer map with the
following command:
-r.mapcalc int_map="int(MATFile_map)"
+r.mapcalc "int_map = int(MATFile_map)"
</pre></div>
<tt>NaN</tt> values in either floating point or double-precision floating point
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -227,7 +227,7 @@
<li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
differ slightly (point will fall above/below the segmentation line)
- <br>Investigate with "<tt>r.mapcalc diff=bin_n.100 - bin_n.33</tt>" etc.
+ <br>Investigate with "<tt>r.mapcalc diff = bin_n.100 - bin_n.33</tt>" etc.
<br>Cause unknown.
<li> "<tt>nan</tt>" can leak into <em>coeff_var</em> maps.
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -24,7 +24,7 @@
g.region rast=landcover.30m -p
# extract forested areas:
r.category landcover.30m
-r.mapcalc "forests=if(landcover.30m >= 41 && landcover.30m <=43,1,null())"
+r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <=43,1,null())"
# patch density (7x7 moving window defined in r.li.setup):
r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
Modified: grass/trunk/raster/r.statistics/r.statistics.html
--- grass/trunk/raster/r.statistics/r.statistics.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster/r.statistics/r.statistics.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -76,7 +76,7 @@
r.statistics base=fields cover=elevation.dem out=elevstats method=average
r.category elevstats
-r.mapcalc "fieldelev=@elevstats"
+r.mapcalc "fieldelev = @elevstats"
r.univar fieldelev
</pre></div>
Modified: grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html
--- grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster3d/r3.cross.rast/r3.cross.rast.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -51,7 +51,7 @@
g.region res=150 res3=150 t=1000 b=0 tbres=100
# synthetic data, could be geological structures:
-r3.mapcalc "map3d=sin(row())+sin(col())+sin(depth()*depth())"
+r3.mapcalc "map3d = sin(row())+sin(col())+sin(depth()*depth())"
#create a cutplane map
r.mapcalc "cutplane = col()*10"
Modified: grass/trunk/raster3d/r3.gwflow/r3.gwflow.html
--- grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster3d/r3.gwflow/r3.gwflow.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -67,12 +67,12 @@
g.region res=25 res3=25 t=100 b=0 n=1000 s=0 w=0 e=1000
#now create the input raster maps for a confined aquifer
-r3.mapcalc "phead=if(row() == 1 && depth() == 4, 50, 40)"
-r3.mapcalc "status=if(row() == 1 && depth() == 4, 2, 1)"
-r3.mapcalc "well=if(row() == 20 && col() == 20 , -0.00025, 0)"
-r3.mapcalc "hydcond=0.00025"
-r3.mapcalc "syield=0.0001"
-r.mapcalc "recharge=0.0"
+r3.mapcalc "phead = if(row() == 1 && depth() == 4, 50, 40)"
+r3.mapcalc "status = if(row() == 1 && depth() == 4, 2, 1)"
+r3.mapcalc "well = if(row() == 20 && col() == 20 , -0.00025, 0)"
+r3.mapcalc "hydcond = 0.00025"
+r3.mapcalc "syield = 0.0001"
+r.mapcalc "recharge = 0.0"
r3.gwflow --o -s solver=cg phead=phead status=status hc_x=hydcond hc_y=hydcond \
hc_z=hydcond q=well s=syield r=recharge output=gwresult dt=8640000 velocity=gwresult_velocity
Modified: grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html
--- grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/raster3d/r3.out.vtk/r3.out.vtk.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -75,10 +75,10 @@
g.region -d
g.region res=150 res3=150 t=80 b=0 tbres=10
-r.mapcalc "bottom=1800. - elevation.10m"
+r.mapcalc "bottom = 1800. - elevation.10m"
-r3.mapcalc "map3d=row()+col()+depth()"
+r3.mapcalc "map3d = row()+col()+depth()"
#export of volume to VTK:
r3.out.vtk -s input=map3d top=elevation.10m bottom=bottom output=/tmp/out.vtk
@@ -95,10 +95,10 @@
g.region n=4926970 s=4914857 w=591583 e=607793 res=50 res3=50 t=80 b=0 tbres=10
#create a bottom surface
#get some satellite images with r.in.onearth
r.in.onearth -l output=Sat tmband=Red
@@ -125,15 +125,15 @@
# create a bottom surface
# synthetic vector data, could be groundwater stream vectors
-r3.mapcalc "x_part =sin(row())"
-r3.mapcalc "y_part =cos(col())"
-r3.mapcalc "z_part =sin(depth())"
+r3.mapcalc "x_part = sin(row())"
+r3.mapcalc "y_part = cos(col())"
+r3.mapcalc "z_part = sin(depth())"
# export the stuff data to VTK:
@@ -150,7 +150,7 @@
#reduce resolution:
g.region -dp3 res=1000 res3=1000
-r.mapcalc "bottom=100"
+r.mapcalc "bottom = 100"
r3.out.vtk -s in=precip3d.500z50 top=dem500 bottom=bottom out=/tmp/slovakia3d.vtk
Modified: grass/trunk/vector/v.hull/v.hull.html
--- grass/trunk/vector/v.hull/v.hull.html 2010-01-16 22:57:02 UTC (rev 40476)
+++ grass/trunk/vector/v.hull/v.hull.html 2010-01-16 23:18:54 UTC (rev 40477)
@@ -27,7 +27,7 @@
Example of <em>v.hull</em> 3D output (using two random 3D point clouds):
g.region rural_1m -p
-r.mapcalc zero=0
+r.mapcalc "zero = 0"
v.random -z out=random3d_a n=10 zmin=0 zmax=200
v.random -z out=random3d_b n=15 zmin=400 zmax=600
v.hull random3d_a out=random3d_a_hull
