[GRASS-SVN] r40504 - grass/branches/releasebranch_6_4/mswindows
svn_grass at osgeo.org
Sun Jan 17 08:50:27 EST 2010
Author: martinl
Date: 2010-01-17 08:50:27 -0500 (Sun, 17 Jan 2010)
New Revision: 40504
grass/branches/releasebranch_6_4/mswindows/README.html
instructions moved to the trac wiki
(merge r40502 from trunk)
Modified: grass/branches/releasebranch_6_4/mswindows/README.html
--- grass/branches/releasebranch_6_4/mswindows/README.html 2010-01-17 13:49:57 UTC (rev 40503)
+++ grass/branches/releasebranch_6_4/mswindows/README.html 2010-01-17 13:50:27 UTC (rev 40504)
@@ -1,311 +1,14 @@
<html>
<head>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
-<meta http-equiv="Content-Language" content="en" />
-<meta name="Author" content="Marco Pasetti" />
-<meta name="Description" content="SVN mswindows README" />
-<title>SVN mswindows README</title>
-<style type="text/css" />
-/* Wiki Pages Styles */
-/* TableOfContents */
-.table-of-contents {
- border: 1px solid #bbbbbb;
- color: black; background-color: #eeeeee;
- font-size: small;
- text-align:left;
- margin: 0.5em; padding-left: 1em;
- width: 360;
-/* Contents */
-html {
- background-color: white;
- color: black;
- font-family: Arial, Lucida Grande, sans-serif;
- font-size: 10pt;
-body {
- margin: 30;
-ol {
- font-size: 10pt;
- margin-top: 0;
- margin-bottom: 0;
- margin-left: 0;
-h1 {
- font-size: 18pt;
- margin-top: 0;
- margin-bottom: 50;
-h2 {
- font-size: 16pt;
- margin-top: 60;
- margin-bottom: 20;
-h3 {
- font-size: 14pt;
- margin-top: 60;
-h4 {
- font-size: 11pt;
- margin-top: 0;
- margin-bottom: 0;
-p {
- font-size: 10pt;
- margin-top: 10;
- margin-bottom: 10;
-code {
- font-family: Courier-new, monospace;
- font-size: 10pt;
- margin-top: 10;
-pre {
- padding: 1em;
- border: 1px dashed #2f6fab;
- color: black;
- background-color: #f9f9f9;
- line-height: 1.1em;
-/* Tables */
-table
- margin: 0.5em 0 0 0.5em;
- border-collapse: collapse;
-td
- padding: 0.25em 0.5em 0.25em 0.5em;
- border: 0pt solid #ADB9CC;
- font-size: 10pt;
-/* Links */
-a {
- text-decoration: none;
- color: #002bb8;
- background: none;
-a:hover {
- text-decoration: underline;
- color: green;
-a:visited:hover {
- color: red;
-</style>
+<title>WinGRASS package installer</title>
</head>
<body>
-<h1>How to prepare a WinGRASS Release</h1>
-<div class="table-of-contents">
-<p><strong>Table of Contents</strong></p>
-<p><a href="#Introduction">Introduction</a></p>
-<p><ol>
-<li><a href="#Install OSGeo4w Tree and Compile Grass">Install OSGeo4w Tree and Compile Grass</a></li>
-<li><a href="#Create a GRASS self-contained Package">Create a GRASS self-contained Package</a></li>
-<li><a href="#Remove OSGeo4W Traces from Package">Remove OSGeo4W Traces from Package</a></li>
-<li><a href="#Install NSIS">Install NSIS</a></li>
-<li><a href="#Install NSIS: Untgz Plugin">Install NSIS: Untgz Plugin</a></li>
-<li><a href="#Create the WinGRASS Installer">Create the WinGRASS Installer</a></li>
-</ol></p>
-<p><a href="#Credits and Contacts">Credits and Contacts</a></p>
-<br>
-</div>
-<div id="Introduction">
-<p><h3>Introduction</h3></p>
-<p>This document explains how to prepare a WinGRASS release (as a
-self-contained package installer) using the scripts contained
-in the mswindows folder. In order to avoid mistakes or misunderstandings,
-we highly recommend to follow each step and command
-exactly as they are written in this document.</p>
-</div>
-<div id="Install OSGeo4w Tree and Compile Grass">
-<p><h3>1. Install OSGeo4w Tree and Compile Grass</h3></p>
-<p>Follow the instructions
- <a target="_blank" href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">here</a>
-to download the OSGeo4W installer, install the required dependencies, and
-build Grass from source.</p>
-<p>Do not move on to step two until you have successfully
- <a target="_blank" href="http://trac.osgeo.org/grass/wiki/HowToTestGrass6">tested</a>
-your new version of Grass.</p>
-</div>
-<div id="Create a GRASS self-contained Package">
-<p><h3>2. Create a GRASS self-contained Package</h3></p>
-<p>Copy all the content of the mswindows folder to a temporary directory, for
-example <code>c:\temp</code>.</p>
-<p>Edit lines 11-15 in the file <code>c:\temp\GRASS-Packager.bat</code> to
-reflect the paths to your OSGeo4W tree (eg. <code>c:\OSGeo4W</code>) and
-the GRASS version being packaged (eg. <code>grass-6.4.0RC4</code>).</p>
-<p>Launch the file <code>c:\temp\GRASS-Packager.bat</code> and select
-the option number 1.</p>
-<p>When finished, you should have a GRASS self-contained release package
-in <code>c:\temp\GRASS-Release-Package</code>.</p>
-<p>Download README.html from <a href="http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw">here</a>,
-place in <code>c:\temp\GRASS-Release-Package</code> (update version numbers as necessary).</p>
-</div>
-<div id="Remove OSGeo4W Traces from Package">
-<p><h3>3. Remove OSGeo4W Traces from Package</h3></p>
-<p>Open <code>c:\temp\GRASS-Release-Package\msys\msys.bat</code> and remove
-lines 11-16.</p>
-<p>At the end of line 88 (also in msys.bat) change:
-<pre><code>start %WD%rxvt -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
-To:
-<pre><code>if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
-</code></pre>
-</div>
-<div id="Install NSIS">
-<p><h3>4. Install NSIS (2.45)</h3></p>
-<p>Download the <a target="_blank" href="http://prdownloads.sourceforge.net/nsis/nsis-2.45-setup.exe">NSIS installer</a></p>
-<p>Install to <code>c:\DevTools</code></p>
-</div>
-<div id="Install NSIS: Untgz Plugin">
-<p><h3>5. Install NSIS: Untgz Plugin (1.0.16)</h3></p>
-<p>Download the <a target="_blank" href="http://www.fdos.org/win32/nsis/plugins/untgz.1.0.16.zip">NSIS Untgz Plugin</a></p>
-<p>Unzip to <code>c:\DevTools\Plugins\</code></p>
-</div>
-<div id="Create the WinGRASS Installer">
-<p><h3>6. Create the WinGRASS Installer</h3></p>
-<p>Open the the file <code>c:\temp\GRASS-Installer.nsi</code>.</p>
-<p>At line 13 set the <code>DEMOLOCATION_PATH</code> varibale to the
-demolocation folder in the source tree.
-For example, <code>c:\msys\local\src\grass-6.4.0RC4\demolocation</code>
-<p>At line 18 set the <code>INSTALLER_TYPE</code> variable to <code>"Release"</code>,
-then, at lines 24-26, set the <code>RELEASE_VERSION_NUMBER</code>, the
-<code>RELEASE_SVN_REVISION</code> and the <code>RELEASE_BINARY_REVISION</code>
-variables.</p>
-<p>Finally, right click on the file <code>c:\temp\GRASS-Installer.nsi</code>
-and select <code>Compile NSIS Script</code>.</p>
-<p>When finished, you should have the WinGRASS release installer in
-<code>c:\temp</code>.</p>
-</div>
-<div id="Credits and Contacts">
-<p><h3>Credits and Contacts</h3></p>
-<p>The GRASS MSYS Environment and the GRASS Packager and Installer scripts
-were created by Marco Pasetti, and updated for use on the
-osgeo4w tree by Colin Nielsen</p>
-<p>To contact them, e-mail to: GRASS Development Mailing List
-(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
-<p>Last edited by Colin Nielsen on 1 Nov 2009.</p>
-</div>
+Instructions how to prepare a WinGRASS package installer has been
+moved to
+the <a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows#CreatingaWinGRASSInstaller">wiki
+page</a>.
</body>
</html>
