[GRASS-SVN] r40514 - grass/trunk/mswindows
svn_grass at osgeo.org
Sun Jan 17 12:33:25 EST 2010
Author: martinl
Date: 2010-01-17 12:33:24 -0500 (Sun, 17 Jan 2010)
New Revision: 40514
grass/trunk/mswindows/GRASS-Installer.nsi
grass/trunk/mswindows/GRASS-Packager.bat
wingrass packager updated (needs some testing)
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2010-01-17 17:26:37 UTC (rev 40513)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2010-01-17 17:33:24 UTC (rev 40514)
@@ -2,43 +2,30 @@
;GRASS Installer for Windows
;Written by Marco Pasetti
-;Updated for OSGeo4W by Colin Nielsen
-;Last Update: 30 March 2009
+;Updated for OSGeo4W by Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+;Last Update: 17 Jan 2010
;Mail to: grass-dev at lists.osgeo.org
;Define the source path of the demolocation files
-!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass-7.0.svn\demolocation"
+!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass_trunk\demolocation"
;Select if you are building a "Development Version" or a "Release Version" of the GRASS Installer
-;Change the INSTALLER_TYPE variable to Release, Dev6 or Dev7
-!define INSTALLER_TYPE "Dev7"
+!define INSTALLER_TYPE "Dev70"
;Version variables
-!define RELEASE_VERSION_NUMBER "6.4.0RC5"
-!define RELEASE_SVN_REVISION "36599"
-!define RELEASE_BINARY_REVISION "1"
-!define RELEASE_GRASS_COMMAND "grass64"
-!define RELEASE_GRASS_BASE "GRASS"
+!define DEV70_VERSION_NUMBER "7.0.SVN"
+!define DEV70_SVN_REVISION "36599"
+!define DEV70_BINARY_REVISION "1"
+!define DEV70_GRASS_COMMAND "grass70svn"
+!define DEV70_GRASS_BASE "GRASS-70-SVN"
-!define DEV6_VERSION_NUMBER "6.5.SVN"
-!define DEV6_SVN_REVISION "36599"
-!define DEV6_BINARY_REVISION "1"
-!define DEV6_GRASS_COMMAND "grass65"
-!define DEV6_GRASS_BASE "GRASS-6-SVN"
-!define DEV7_VERSION_NUMBER "7.0.SVN"
-!define DEV7_SVN_REVISION ""
-!define DEV7_BINARY_REVISION "1"
-!define DEV7_GRASS_COMMAND "grass7"
-!define DEV7_GRASS_BASE"GRASS-7-SVN"
;Don't modify the following lines
@@ -54,36 +41,16 @@
;Set the installer variables, depending on the selected version to build
-!if ${INSTALLER_TYPE} == "Release"
- !define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
- !define SVN_REVISION "${RELEASE_SVN_REVISION}"
- !define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
- !define GRASS_COMMAND "${RELEASE_GRASS_COMMAND}"
- !define GRASS_BASE "${RELEASE_GRASS_BASE}"
- !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
- !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
- !define CHECK_INSTALL_NAME "GRASS"
- !define PACKAGE_FOLDER ".\GRASS-Release-Package"
-!else if ${INSTALLER_TYPE} == "Dev6"
- !define VERSION_NUMBER "${DEV6_VERSION_NUMBER}"
- !define SVN_REVISION "${DEV6_SVN_REVISION}"
- !define BINARY_REVISION "${DEV6_BINARY_REVISION}"
- !define GRASS_COMMAND "${DEV6_GRASS_COMMAND}"
- !define GRASS_BASE "${DEV6_GRASS_BASE}"
+!if ${INSTALLER_TYPE} == "Dev70"
+ !define VERSION_NUMBER "${DEV70_VERSION_NUMBER}"
+ !define SVN_REVISION "${DEV70_SVN_REVISION}"
+ !define BINARY_REVISION "${DEV70_BINARY_REVISION}"
+ !define GRASS_COMMAND "${DEV70_GRASS_COMMAND}"
+ !define GRASS_BASE "${DEV70_GRASS_BASE}"
!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
- !define CHECK_INSTALL_NAME "GRASS 6 SVN"
- !define PACKAGE_FOLDER ".\GRASS-6-Dev-Package"
-!else if ${INSTALLER_TYPE} == "Dev7"
- !define VERSION_NUMBER "${DV7_VERSION_NUMBER}"
- !define SVN_REVISION "${DV7_SVN_REVISION}"
- !define BINARY_REVISION "${DV7_BINARY_REVISION}"
- !define GRASS_COMMAND "${DEV7_GRASS_COMMAND}"
- !define GRASS_BASE "${DEV7_GRASS_BASE}"
- !define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
- !define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
- !define CHECK_INSTALL_NAME "GRASS 7 SVN"
- !define PACKAGE_FOLDER ".\GRASS-7-Dev-Package"
+ !define CHECK_INSTALL_NAME "GRASS 70 SVN"
+ !define PACKAGE_FOLDER ".\GRASS-70-Dev-Package"
!endif
@@ -105,7 +72,7 @@
OutFile "${INSTALLER_NAME}"
;Define installation folder
-InstallDir "C:\${GRASS_BASE}"
+InstallDir "$PROGRAMFILES\${GRASS_BASE}"
;Request application privileges for Windows Vista
RequestExecutionLevel user
@@ -321,34 +288,34 @@
;CheckInstDir Function
+;this is commented out, because the installation path should be in $PROGRAMFILES
;Check if GRASS is going to be installed in a directory containing spaces
;if yes, show a warning message
-Function CheckInstDir
+;Function CheckInstDir
+; Var /GLOBAL INSTDIR_TEST
+; Var /GLOBAL INSTDIR_LENGHT
+; Var /GLOBAL INSTDIR_TEST_LENGHT
+; Var /GLOBAL MESSAGE_CHKINST_
+; StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
+; StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
+; ${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
+; StrLen $INSTDIR_LENGHT "$INSTDIR"
+; StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
+; ${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
+; MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
+; ${EndIf}
+;FunctionEnd
- Var /GLOBAL INSTDIR_TEST
- Var /GLOBAL INSTDIR_LENGHT
- Var /GLOBAL INSTDIR_TEST_LENGHT
- Var /GLOBAL MESSAGE_CHKINST_
- StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
- StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
- StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
- StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
- StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
- StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
- ${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
- StrLen $INSTDIR_LENGHT "$INSTDIR"
- StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
- ${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
- MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
- ${EndIf}
-FunctionEnd
;Interface Settings
@@ -371,7 +338,7 @@
!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
!insertmacro MUI_PAGE_DIRECTORY
-Page custom CheckInstDir
+;Page custom CheckInstDir
!insertmacro MUI_PAGE_COMPONENTS
!insertmacro MUI_PAGE_INSTFILES
@@ -513,7 +480,7 @@
"$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
; FIXME: ship the WinGrass release notes .html file instead of URL
-; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw
+; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass70/binary/mswindows/native/README.html?format=raw
; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
@@ -544,7 +511,7 @@
FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
FileWrite $0 'set GRASSDIR=$INSTALL_DIR$\r$\n'
FileWrite $0 '$\r$\n'
- FileWrite $0 'rem Directory where your .grass7\rc file will be stored$\r$\n'
+ FileWrite $0 'rem Directory where your .grass7/rc file will be stored$\r$\n'
FileWrite $0 'set HOME=%USERPROFILE%$\r$\n'
FileWrite $0 'rem Name of the wish (Tk) executable$\r$\n'
@@ -705,7 +672,6 @@
;replace \ with / in $GIS_DATABASE
${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
- ;create $PROFILE\.grass7
;create $PROFILE\.grass7\rc
SetShellVarContext current
ClearErrors
@@ -860,7 +826,7 @@
;remove the .grass7\rc file
- RMDir \r "$PROFILE\.grass7"
+ Delete "$PROFILE\.grass7\rc"
;remove the Registry Entries
DeleteRegKey HKLM "Software\${GRASS_BASE}"
Modified: grass/trunk/mswindows/GRASS-Packager.bat
--- grass/trunk/mswindows/GRASS-Packager.bat 2010-01-17 17:26:37 UTC (rev 40513)
+++ grass/trunk/mswindows/GRASS-Packager.bat 2010-01-17 17:33:24 UTC (rev 40514)
@@ -1,3 +1,11 @@
+rem -----------------------------------------------------------------------------------------------------------------------
+rem Self Contained GRASS Automated Packager
+rem Edited by: Marco Pasetti
+rem Revised for OSGeo4W by: Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+rem Last Update: 17 Jan 2010
@echo off
rem --------------------------------------------------------------------------------------------------------------------------
@@ -4,56 +12,32 @@
rem Set the script variables
-set GRASS_RELEASE_PACKAGE_DIR=.\GRASS-Release-Package
-set GRASS_6_DEV_PACKAGE_DIR=.\GRASS-6-Dev-Package
-set GRASS_7_DEV_PACKAGE_DIR=.\GRASS-7-Dev-Package
+set GRASS_70_DEV_PACKAGE_DIR=.\GRASS-70-Dev-Package
set OSGEO4W_DIR=c:\osgeo4w
-set GRASS_RELEASE_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.4.0RC5
-set GRASS_6_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-6.5.svn
-set GRASS_7_DEV_INSTALL_FOLDER=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
+set GRASS_70_DEV_INSTALL_DIR=%OSGEO4W_DIR%\apps\grass\grass-7.0.svn
- at echo -----------------------------------------------------------------------------------------------------------------------
- at echo Self Contained GRASS Automated Packager
- at echo Edited by: Marco Pasetti
- at echo Revised for OSGeo4W by: Colin Nielsen
- at echo Last Update: 10 June 2009
- at echo Select the GRASS version to pack:
- at echo.
- at echo 1. Current GRASS Release Version
- at echo.
- at echo 2. Current GRASS-6 Development Version
- at echo.
- at echo 3. Current GRASS-7 Development Version
- at echo.
+rem @echo .
+rem @echo Select the GRASS version to pack:
+rem @echo.
+rem @echo 1. Current GRASS-70 Development Version
+rem @echo.
-set /p SELECTION=Enter your selection (1/2/3):
+rem set /p SELECTION=Enter your selection (1):
-if %SELECTION%==1 (
-set PACKAGE_DIR=%GRASS_RELEASE_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_RELEASE_INSTALL_FOLDER%
+rem if %SELECTION%==1 (
+set PACKAGE_DIR=%GRASS_70_DEV_PACKAGE_DIR%
+set GRASS_PREFIX=%GRASS_70_DEV_INSTALL_DIR%
+rem )
-if %SELECTION%==2 (
-set PACKAGE_DIR=%GRASS_6_DEV_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_6_DEV_INSTALL_FOLDER%
-if %SELECTION%==3 (
-set PACKAGE_DIR=%GRASS_7_DEV_PACKAGE_DIR%
-set GRASS_PREFIX=%GRASS_7_DEV_INSTALL_FOLDER%
@echo.
@echo -----------------------------------------------------------------------------------------------------------------------
@echo Remove the previous Selected Package and create a new PACKAGE_DIR
@echo.
-pause
+rem pause
if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
mkdir %PACKAGE_DIR%
@@ -75,6 +59,8 @@
mkdir %PACKAGE_DIR%\extralib
copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
+del %PACKAGE_DIR%\extralib\libgrass_*6.4*.dll
+del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
@echo.
