[GRASS-SVN] r40527 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Jan 18 08:46:36 EST 2010
Author: martinl
Date: 2010-01-18 08:46:36 -0500 (Mon, 18 Jan 2010)
New Revision: 40527
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location_wizard: some clean up
(merge r40526 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-01-18 13:44:39 UTC (rev 40526)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-01-18 13:46:36 UTC (rev 40527)
@@ -22,11 +22,11 @@
- LocationWizard
- SelectTransformDialog
-COPYRIGHT: (C) 2007-2009 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+(C) 2007-2010 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
@author Michael Barton
@author Jachym Cepicky
@author Martin Landa <landa.martin gmail.com>
@@ -672,196 +672,182 @@
def __init__(self, wizard, parent):
TitledPage.__init__(self, wizard, _("Choose projection parameters"))
global coordsys
- self.utmzone = ''
- self.utmhemisphere = ''
- self.hemischoices = ["north","south"]
self.parent = parent
- self.panel = ''
- self.prjparamsizer = ''
- self.pentry = {}
- self.pdesc = {}
- self.ptype = {}
- self.pval = {}
- self.proj4param = {}
- self.pcount = 0
- self.paramlist = []
+ self.panel = None
+ self.prjParamSizer = None
+ self.pparam = dict()
self.p4projparams = ''
self.projdesc = ''
- radioSBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Select datum or ellipsoid (next page)"))
+ radioSBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("Select datum or ellipsoid (next page)"))
radioSBSizer = wx.StaticBoxSizer(radioSBox)
- self.sizer.Add(radioSBSizer, pos=(0,1), span=(1,2),
- flag=wx.EXPAND | wx.ALIGN_TOP | wx.TOP, border=10)
+ self.sizer.Add(item = radioSBSizer, pos = (0, 1),
+ flag = wx.EXPAND | wx.ALIGN_TOP | wx.TOP, border = 10)
self.radio1 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Datum with associated ellipsoid"),
- style = wx.RB_GROUP)
+ label=_("Datum with associated ellipsoid"),
+ style = wx.RB_GROUP)
self.radio2 = wx.RadioButton(parent=self, id=wx.ID_ANY,
- label=_("Ellipsoid only"))
+ label=_("Ellipsoid only"))
# default button setting
if self.radio1.GetValue() == False and self.radio2.GetValue() == False:
self.radio1.SetValue(True)
self.SetNext(self.parent.datumpage)
-# self.parent.sumpage.SetPrev(self.parent.datumpage)
+ # self.parent.sumpage.SetPrev(self.parent.datumpage)
radioSBSizer.Add(item=self.radio1,
flag=wx.ALIGN_LEFT | wx.RIGHT, border=20)
radioSBSizer.Add(item=self.radio2,
flag=wx.ALIGN_LEFT)
# bindings
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio1.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio2.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChange)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
def OnParamEntry(self, event):
- num = 0
- # deal with weird spin control text event behavior, sending dup. event with negative number
- if event.GetId() >= 2000:
- num = event.GetId() - 2000
- else:
- pass
+ """!Parameter value changed"""
+ id = event.GetId()
val = event.GetString()
- if self.ptype[num] == 'zone':
+ if not self.pparam.has_key(id):
+ event.Skip()
+ return
+ param = self.pparam[id]
+ win = self.FindWindowById(id)
+ if param['type'] == 'zone':
if val.isdigit():
- if int(val) < 1: self.pentry[num].SetValue(1)
- if int(val) > 60: self.pentry[num].SetValue(60)
+ if int(val) < 1:
+ win.SetValue(1)
+ if int(val) > 60:
+ win.SetValue(60)
else:
- self.pentry[num].SetValue(1)
- self.pval[num] = val
+ win.SetValue(1)
+ param['value'] = val
event.Skip()
def OnPageChange(self,event=None):
+ """!Go to next page"""
if event.GetDirection():
- for num in range(self.pcount + 1):
- if self.ptype[num] == 'bool':
- if self.pval[num] == 'No':
+ for id, param in self.pparam.iteritems():
+ if param['type'] == 'bool':
+ if param['value'] == False:
continue
else:
- self.p4projparams += (' +' + self.proj4param[num])
+ self.p4projparams += (' +' + param['proj4'])
else:
- if self.pval[num] == '':
- wx.MessageBox('You must enter a value for %s' % self.pdesc[num],
- 'Something is missing!', wx.ICON_ERROR)
+ if param['value'] is None:
+ wx.MessageBox(parent = self,
+ message = _('You must enter a value for %s') % param['desc'],
+ caption = _('Error'), style = wx.ICON_ERROR | wx.CENTRE)
event.Veto()
else:
- self.p4projparams += (' +' + self.proj4param[num] + '=' + self.pval[num])
+ self.p4projparams += (' +' + param['proj4'] + '=' + param['value'])
def OnEnterPage(self,event):
+ """!Page entered"""
self.projdesc = self.parent.projections[self.parent.projpage.proj][0]
- try:
- # page already formatted
- if self.pagesizer.GetItem(self.panel) != '':
- pass
- except:
+ if self.prjParamSizer is None:
# entering page for the first time
- paramSBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=_(" Enter parameters for %s projection ") % self.projdesc)
+ paramSBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=_(" Enter parameters for %s projection ") % self.projdesc)
paramSBSizer = wx.StaticBoxSizer(paramSBox)
- self.panel = scrolled.ScrolledPanel(self, wx.ID_ANY)
- self.prjparamsizer = wx.GridBagSizer(vgap=0, hgap=0)
+ self.panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
self.panel.SetupScrolling()
-# this ought to work but it doesn't
-# self.sizer.Add(paramSBSizer, pos=(2,1), span=(3,2),
-# flag=wx.EXPAND )
- self.pagesizer.Add(paramSBSizer, proportion=1,
- flag=wx.EXPAND | wx.ALIGN_TOP | wx.ALL, border=10)
- paramSBSizer.Add(self.panel, proportion=1,
- flag=wx.ALIGN_CENTER|wx.EXPAND)
+ self.prjParamSizer = wx.GridBagSizer(vgap=0, hgap=0)
+ self.pagesizer.Add(item = paramSBSizer, proportion = 1,
+ flag = wx.EXPAND | wx.ALIGN_TOP | wx.ALL, border = 10)
+ paramSBSizer.Add(item = self.panel, proportion = 1,
+ flag = wx.ALIGN_CENTER | wx.EXPAND)
paramSBSizer.Fit(self.panel)
- self.panel.SetSizer(self.prjparamsizer)
+ self.panel.SetSizer(self.prjParamSizer)
- self.pcount = 0
- self.prjparamsizer.Clear(True)
- num = 0
+ self.prjParamSizer.Clear(True)
+ row = 0
for paramgrp in self.parent.projections[self.parent.projpage.proj][1]:
# get parameters
- self.pcount = num
- self.ptype[num] = self.parent.paramdesc[paramgrp[0]][0]
- self.proj4param[num] = self.parent.paramdesc[paramgrp[0]][1]
- self.pdesc[num] = self.parent.paramdesc[paramgrp[0]][2]
+ id = wx.ID_ANY
+ param = self.pparam[id] = { 'type' : self.parent.paramdesc[paramgrp[0]][0],
+ 'proj4': self.parent.paramdesc[paramgrp[0]][1],
+ 'desc' : self.parent.paramdesc[paramgrp[0]][2] }
# default values
- if self.ptype[num] == 'bool': self.pval[num] = 'No'
- elif self.ptype[num] == 'zone':
- self.pval[num] = '30'
- self.pdesc[num] += ' (1-60)'
- else: self.pval[num] = paramgrp[2]
- label = wx.StaticText(self.panel, id=1000+num, label=self.pdesc[num],
- style=wx.ALIGN_RIGHT | wx.ST_NO_AUTORESIZE)
- self.pentry[num] = wx.Choice(self.panel, id=2000+num, size=(100,-1),
- choices = ['No','Yes'])
- self.pentry[num].SetStringSelection(self.pval[num])
- self.Bind(wx.EVT_CHOICE, self.OnParamEntry)
- self.pentry[num] = wx.SpinCtrl(self.panel, id=2000+num,
- value='30',
- size=(100,-1),
- style=wx.SP_ARROW_KEYS | wx.SP_WRAP,
- min=1, max=60, initial=30)
- self.pentry[num].SetValue(int(self.pval[num]))
- self.Bind(wx.EVT_TEXT, self.OnParamEntry)
+ param['value'] = 0
+ elif param['type'] == 'zone':
+ param['value'] = 30
+ param['desc'] += ' (1-60)'
else:
- self.pentry[num] = wx.TextCtrl(self.panel, id=2000+num, value=self.pval[num],
- size=(100,-1))
- if paramgrp[1] == 'noask':
- self.pentry[num].SetEditable(False)
- self.pentry[num].SetBackgroundColour(wx.LIGHT_GREY)
- self.prjparamsizer.Add(item=label, pos=(num, 1),
- flag=wx.ALIGN_RIGHT |
- wx.ALIGN_CENTER_VERTICAL |
- wx.RIGHT, border=5)
- self.prjparamsizer.Add(item=self.pentry[num], pos=(num, 2),
- flag=wx.ALIGN_LEFT |
- wx.LEFT, border=5)
- num += 1
+ param['value'] = paramgrp[2]
+ label = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = param['desc'],
+ style = wx.ALIGN_RIGHT | wx.ST_NO_AUTORESIZE)
+ win = wx.Choice(parent = self.panel, id = id, size = (100,-1),
+ choices = [_('No'), _('Yes')])
+ win.SetSelection(param['value'])
+ win.Bind(wx.EVT_CHOICE, self.OnParamEntry)
+ win = wx.SpinCtrl(parent = self.panel, id = id,
+ size = (100, -1),
+ style = wx.SP_ARROW_KEYS | wx.SP_WRAP,
+ min = 1, max = 60, initial = 30)
+ win.SetValue(param['value'])
+ win.Bind(wx.EVT_TEXT, self.OnParamEntry)
+ else:
+ win = wx.TextCtrl(parent = self.panel, id = id,
+ value = param['value'],
+ size=(100, -1))
+ if paramgrp[1] == 'noask':
+ win.Enable(False)
+ self.prjParamSizer.Add(item = label, pos = (row, 1),
+ flag = wx.ALIGN_RIGHT |
+ wx.ALIGN_CENTER_VERTICAL |
+ wx.RIGHT, border = 5)
+ self.prjParamSizer.Add(item = win, pos = (row, 2),
+ flag = wx.ALIGN_LEFT |
+ wx.LEFT, border = 5)
+ row += 1
self.panel.SetSize(self.panel.GetBestSize())
self.panel.Layout()
self.Layout()
self.Update()
if not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
wx.FindWindowById(wx.ID_FORWARD).Enable()
event.Skip()
def SetVal(self, event):
+ """!Set value"""
if event.GetId() == self.radio1.GetId():
elif event.GetId() == self.radio2.GetId():
self.SetNext(self.parent.ellipsepage)
self.parent.sumpage.SetPrev(self.parent.ellipsepage)
- def GetUTM(self, event):
- self.utmzone = event.GetString()
- def OnHemisphere(self, event):
- self.utmhemisphere = event.GetString()
class DatumPage(TitledPage):
Wizard page for selecting datum (with associated ellipsoid)
