[GRASS-SVN] r40537 - grass/trunk/lib/gpde
Mon Jan 18 14:39:54 EST 2010
Author: huhabla
Date: 2010-01-18 14:39:53 -0500 (Mon, 18 Jan 2010)
New Revision: 40537
   grass/trunk/lib/gpde/N_gwflow.c
Water budget for 3d groundwater flow implemented.
Modified: grass/trunk/lib/gpde/N_gwflow.c
--- grass/trunk/lib/gpde/N_gwflow.c	2010-01-18 19:37:18 UTC (rev 40536)
+++ grass/trunk/lib/gpde/N_gwflow.c	2010-01-18 19:39:53 UTC (rev 40537)
@@ -385,7 +385,7 @@
         for (y = 0; y < rows; y++) {
             G_percent(y, rows - 1, 10);
             for (x = 0; x < cols; x++) {
-                stat = (int)N_get_array_3d_d_value(data->status, x, y);
+                stat = (int)N_get_array_3d_d_value(data->status, x, y, z);
                 val = 0.0;
@@ -394,7 +394,7 @@
                     /* Compute the flow parameter */
                     dstar = N_callback_gwflow_3d(data, geom, x, y, z);
                     /* Compute the gradient in each direction pointing from the center */
-                    hc = N_get_array_3d_d_value(data->phead, x, y);
+                    hc = N_get_array_3d_d_value(data->phead, x, y, z);
                     if((int)N_get_array_3d_d_value(data->status, x + 1, y, z ) != N_CELL_INACTIVE) {
                         h = N_get_array_3d_d_value(data->phead,  x + 1, y, z );
@@ -408,8 +408,8 @@
                         h = N_get_array_3d_d_value(data->phead,  x    , y + 1, z);
                         val += dstar->S * (hc - h);
-                    if((int)N_get_array_3d_d_value(data->status, x    , y - 1) != N_CELL_INACTIVE) {
-                        h = N_get_array_3d_d_value(data->phead,  x    , y - 1);
+                    if((int)N_get_array_3d_d_value(data->status, x    , y - 1, z) != N_CELL_INACTIVE) {
+                        h = N_get_array_3d_d_value(data->phead,  x    , y - 1, z);
                         val += dstar->N * (hc - h);
                     if((int)N_get_array_3d_d_value(data->status, x    , y, z + 1) != N_CELL_INACTIVE) {
