[GRASS-SVN] r40557 - in grass/trunk: general/g.setproj lib/proj
svn_grass at osgeo.org
Tue Jan 19 12:02:37 EST 2010
Author: glynn
Date: 2010-01-19 12:02:36 -0500 (Tue, 19 Jan 2010)
New Revision: 40557
Added:
grass/trunk/lib/proj/proj-desc.table
grass/trunk/lib/proj/proj-parms.table
grass/trunk/lib/proj/proj-units.table
Removed:
grass/trunk/general/g.setproj/proj-desc.table
grass/trunk/general/g.setproj/proj-parms.table
grass/trunk/general/g.setproj/proj-units.table
grass/trunk/lib/proj/Makefile
Move proj-*.table from general/g.setproj to lib/proj
Deleted: grass/trunk/general/g.setproj/proj-desc.table
--- grass/trunk/general/g.setproj/proj-desc.table 2010-01-19 15:48:30 UTC (rev 40556)
+++ grass/trunk/general/g.setproj/proj-desc.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -1,43 +0,0 @@
-ALPHA:lon:alpha:Azimuth angle at Cartesian Origin
-AZIM:float:azi:Azimuth Angle of Tilt in Decimal degrees
-GUAM:bool:guam:
-HEIGH:float:h:Height of Viewing Point in Meters
-KFACT:float:k_0:Scale Factor at the Central Meridian
-LAT0:lat:lat_0:Central Parallel
-LAT1:lat:lat_1:First Standard Parallel
-LAT2:lat:lat_2:Second Standard Parallel
-LAT3:lat:lat_3:Third Standard Parallel
-LATB:lat:lat_b:Angular Distance from Tangency Point
-LATTS:lat:lat_ts:Latitude of True Scale
-LON0:lon:lon_0:Central Meridian
-LON1:lon:lon_1:First Standard Meridian
-LON2:lon:lon_2:Second Standard Meridian
-LON3:lon:lon_3:Third Standard Meridian
-LONC:lon:lon_c:Longitude of Cartesian Origin
-LOTSA:bool:lotsa:LOTSA
-MFACT:float:m:m factor
-MSFACT:float:M:M factor
-NFACT:float:n:n factor
-NOCUT:bool:no_cut:Both Hemispheres
-NOROT:bool:no_rot:Suppress Rotation
-NOSKEW:bool:ns:Suppress Skew
-NOUOFF:bool:no_uoff:Suppress Offset from Pre-Rotated Axis
-OALPHA:lat:o_alpha:
-OLAT1:lat:o_lat_1:
-OLAT2:lat:o_lat_2:
-OLATP:float:o_lat_p:Latitude of New Pole
-OLON1:lon:o_lon_1:
-OLON2:lon:o_lon_2:
-OLONC:lon:o_lon_c:
-OLONP:lon:o_lon_p:Longitude of New Pole
-QFACT:float:q:q factor
-ROTCONV:bool:rot_conv:Origin Convergence Angle
-SNUM:int:lsat:Satellite Number
-SOUTH:bool:south:Southern Hemisphere
-SPATH:int:path:Satellite Path Number
-THETA:lon:theta:Theta Angle
-TILT:float:tilt:Tilt Angle in Decimal Degrees
-WFACT:float:W:W factor
-X0:float:x_0:False Easting
-Y0:float:y_0:False Northing
-ZONE:zone:zone:Projection Zone
Deleted: grass/trunk/general/g.setproj/proj-parms.table
--- grass/trunk/general/g.setproj/proj-parms.table 2010-01-19 15:48:30 UTC (rev 40556)
+++ grass/trunk/general/g.setproj/proj-parms.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -1,123 +0,0 @@
-AEA:Albers Equal Area:LAT0=ask,23.0;LAT1=ask,29.5;LAT2=ask,45.5;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
-AEQD:Azimuthal Equidistant:LAT0=ask,0.0;LON0=ask,20.0
-AIRY:Airy:LAT0=ask,0.0;LATB=ask,90.0;LON0=ask,20.0;NOCUT=ask,nodfl
-AITOFF:Aitoff:LAT0=ask,0.0;LON0=ask,20.0
-ALSK:Mod. Stererographics of Alaska:LAT0=noask,64.0;LON0=noask,-152.0
-APIAN:Apian Globular I:LAT0=ask,0.0;LON0=ask,20.0
-AUGUST:August Epicycloidal:LAT0=ask,0.0;LON0=ask,20.0
-BACON:Bacon Globular:LAT0=ask,0.0;LON0=ask,20.0
-BIPC:Bipolar conic of western hemisphere:LAT0=ask,0.0;LON0=ask,-90.0;NOSKEW=ask,nodfl
-BOGGS:Boggs Eumorphic:LAT0=ask,0.0;LON0=ask,20.0
-BONNE:Bonne (Werner lat_1=90):LAT1=ask,40.0;LON0=ask,20.0
-CASS:Cassini:LAT0=ask,0.0;LON0=ask,20.0
-CC:Central Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
-CEA:Equal Area Cylindrical:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
-CHAMB:Chamberlin Trimetric:LAT0=ask,55.0;LAT1=ask,40.0;LAT2=ask,20.0;LAT3=ask,35.0;LON0=ask,20.0;LON1=ask,5.0;LON2=ask,55.0;LON3=ask,65.0
-COLLG:Collignon:LAT0=ask,0.0;LON0=ask,20.0
-CRAST:Craster Parabolic (Putnins P4):LAT0=ask,0.0;LON0=ask,20.0
-DENOY:Denoyer Semi-Elliptical:LAT0=ask,0.0;LON0=ask,20.0
-ECK1:Eckert I:LAT0=ask,0.0;LON0=ask,20.0
-ECK2:Eckert II:LAT0=ask,0.0;LON0=ask,20.0
-ECK3:Eckert III:LAT0=ask,0.0;LON0=ask,20.0
-ECK4:Eckert IV:LAT0=ask,0.0;LON0=ask,20.0
-ECK5:Eckert V:LAT0=ask,0.0;LON0=ask,20.0
-ECK6:Eckert VI:LAT0=ask,0.0;LON0=ask,20.0
-EQC:Equidistant Cylindrical (Plate Caree):LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,0.0
-EQDC:Equidistant Conic:LAT0=ask,40.0;LAT1=ask,20.0;LAT2=ask,60.0;LON0=ask,20.0
-EULER:Euler:LAT0=ask,55.0;LAT1=ask,45.0;LAT2=ask,65.0;LON0=ask,20.0
-FAHEY:Fahey:LAT0=ask,0.0;LON0=ask,20.0
-FOUC:Foucaut:LAT0=ask,0.0;LON0=ask,20.0
-FOUC_S:Foucaut Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0
-GALL:Gall (Gall Stereographic):LAT0=ask,0.0;LON0=ask,20.0
-GEOS:Geostationary Satellite View:HEIGH=ask,35800000.0;LON0=ask,20.0;X0=ask,0.0;Y0=ask,0.0
-GINS8:Ginsburg VIII (TsNIIGAiK):LAT0=ask,0.0;LON0=ask,20.0
-GNOM:Gnomonic:LAT0=ask,0.0;LON0=ask,20.0
-GN_SINU:General Sinusoidal Series:LAT0=ask,0.0;LON0=ask,20.0;MFACT=ask,1.0;NFACT=ask,1.0
-GOODE:Goode Homolosine:LAT0=ask,0.0;LON0=ask,20.0
-GS48:Mod. Stererographics of 48 U.S.:LAT0=noask,45.0;LON0=noask,-120.0
-GS50:Mod. Stererographics of 50 U.S.:LAT0=noask,45.0;LON0=noask,-120.0
-HAMMER:Hammer & Eckert-Greifendorff:LAT0=ask,0.0;LON0=ask,20.0;MSFACT=ask,1.0;WFACT=ask,0.5
-HATANO:Hatano Asymmetrical Equal Area:LAT0=ask,0.0;LON0=ask,20.0
-IMW_P:International Map of the World Polyconic:LAT0=ask,0.0;LAT1=ask,20.0;LAT2=ask,60.0;LON0=ask,20.0;LON1=ask,20.0
-KAV5:Kavraisky V:LAT0=ask,0.0;LON0=ask,20.0
-KAV7:Kavraisky VII:LAT0=ask,0.0;LON0=ask,20.0
-KROVAK:Krovak:LAT0=noask,0.0;LON0=noask,0
-LABRD:Laborde:AZIM=noask,18.9;KFACT=noask,0.9995;LAT0=noask,18.9;LON0=noask,46.437208333;X0=noask,400000.0;Y0=noask,800000.0
-LAEA:Lambert Azimuthal Equal Area:LAT0=ask,55.0;LON0=ask,20.0;X0=ask,0.0;Y0=ask,0.0
-LAGRNG:Lagrange:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0;WFACT=ask,2.0
-LARR:Larrivee:LAT0=ask,0.0;LON0=ask,20.0
-LASK:Laskowski:LAT0=ask,0.0;LON0=ask,20.0
-LCC:Lambert Conformal Conic:LAT0=ask,23.0;LAT1=ask,33.0;LAT2=ask,45.0;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
-LEAC:Lambert Equal Area Conic:LAT0=ask,55.0;LAT1=ask,0.0;LON0=ask,20.0;SOUTH=ask,nodfl
-LEE_OS:Lee Oblated Stereographic:LAT0=noask,-10.0;LON0=noask,-165.0
-LL:Latitude/Longitude (pseudo-projection):LAT0=noask,0.0;LON0=noask,0.0
-LOXIM:Loximuthal:LAT0=ask,0.0;LAT1=ask,45.0;LON0=ask,20.0
-LSAT:Space oblique for LANDSAT:LAT0=ask,0.0;LON0=ask,20.0;SNUM=ask,1;SPATH=ask,1
-MBTFPP:McBride-Thomas Flat-Polar Parabolic:LAT0=ask,0.0;LON0=ask,20.0
-MBTFPQ:McBryde-Thomas Flat-Polar Quartic:LAT0=ask,0.0;LON0=ask,20.0
-MBTFPS:McBryde-Thomas Flat-Polar Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0
-MBT_FPS:McBryde-Thomas Flat-Pole Sine (No. 2):LAT0=ask,0.0;LON0=ask,20.0
-MBT_S:McBryde-Thomas Flat-Polar Sine (No. 1):LAT0=ask,0.0;LON0=ask,20.0
-MERC:Mercator:KFACT=ask,1.0;LATTS=ask,0.;LON0=ask,-96.0
-MILL:Miller Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
-MIL_OS:Miller Oblated Stereographic:LAT0=noask,18.0;LON0=noask,20.0
-MOLL:Mollweide:LAT0=ask,0.0;LON0=ask,20.0
-MPOLY:Modified Polyconic:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0;LOTSA=ask,nodfl
-MURD1:Murdoch I:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
-MURD2:Murdoch II:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
-MURD3:Murdoch III:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
-NELL:Nell:LAT0=ask,0.0;LON0=ask,20.0
-NELL_H:Nell-Hammer:LAT0=ask,0.0;LON0=ask,20.0
-NICOL:Nicolosi Globular:LAT0=ask,0.0;LON0=ask,20.0
-NSPER:Near-sided perspective:HEIGH=ask,50000000.0;LAT0=ask,55.0;LON0=ask,20.0
-NZMG:New Zealand Map Grid:LAT0=noask,-41.0;LON0=noask,173.0;X0=noask,2510000.0;Y0=noask,6023150.0
-OB_TRAN:General Oblique Transformation:LAT0=ask,0.0;LON0=ask,0.0;OLATP=ask,90.0;OLONP=ask,0.0
-OCEA:Oblique Cylindrical Equal Area:LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-20.0;LON2=ask,60.0
-OEA:Oblated Equal Area:LAT0=ask,0.0;LON0=ask,20.0;MFACT=ask,1.0;NFACT=ask,1.0;THETA=ask,0.0
-OMERC:Oblique Mercator:KFACT=ask,1.0;LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-40.0;LON2=ask,40.0;NOROT=ask,nodfl;NOUOFF=ask,nodfl;ROTCONV=ask,nodfl
-ORTEL:Ortelius Oval:LAT0=ask,0.0;LON0=ask,20.0
-ORTHO:Orthographic:LAT0=ask,0.0;LON0=ask,20.0
-PCONIC:Perspective Conic:LAT0=ask,0.0;LAT1=ask,33.0;LAT2=ask,45.0;LON0=ask,20.0
-POLY:Polyconic (American):LAT0=ask,0.0;LON0=ask,-90.0
-PUTP1:Putnins P1:LAT0=ask,0.0;LON0=ask,20.0
-PUTP2:Putnins P2:LAT0=ask,0.0;LON0=ask,20.0
-PUTP3:Putnins P3:LAT0=ask,0.0;LON0=ask,20.0
-PUTP3P:Putnins P3':LAT0=ask,0.0;LON0=ask,20.0
-PUTP4P:Putnins P4':LAT0=ask,0.0;LON0=ask,20.0
-PUTP5:Putnins P5:LAT0=ask,0.0;LON0=ask,20.0
-PUTP5P:Putnins P5':LAT0=ask,0.0;LON0=ask,20.0
-PUTP6:Putnins P6:LAT0=ask,0.0;LON0=ask,20.0
-PUTP6P:Putnins P6':LAT0=ask,0.0;LON0=ask,20.0
-QUA_AUT:Quartic Authalic:LAT0=ask,0.0;LON0=ask,20.0
-ROBIN:Robinson:LAT0=ask,0.0;LON0=ask,20.0
-RPOLY:Rectangular Polyconic:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
-SINU:Sinusoidal (Sanson-Flamsteed):LAT0=ask,0.0;LON0=ask,20.0
-SOMERC:Swiss. Obl. Mercator:KFACT=noask,1.0;LAT0=noask,46.952405556;LON0=noask,7.4395833333;X0=noask,600000.0;Y0=noask,200000.0
-STERE:Stereographic:KFACT=ask,1.0;LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
-STEREA:Oblique Stereographic Alternative:KFACT=ask,1.0;LAT0=ask,0.0;LON0=ask,20.0
-STP:State Plane (pseudo-projection):LAT0=noask,0.0;LON0=noask,0.0
-TCC:Transverse Central Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
-TCEA:Transverse Cylindrical Equal Area:KFACT=ask,1.0;LAT0=ask,0.0;LON0=ask,20.0
-TISSOT:Tissot:LAT0=ask,0.0;LAT1=ask,-30.0;LAT2=ask,45.0;LON0=ask,20.0
-TMERC:Transverse Mercator:KFACT=ask,1.0;LAT0=ask,23.0;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
-TPEQD:Two Point Equidistant:LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-20.0;LON2=ask,60.0
-TPERS:Tilted perspective:AZIM=ask,0.0;HEIGH=ask,10000.0;LAT0=ask,0.0;LON0=ask,20.0;TILT=ask,0.0
-UPS:Universal Polar Stereographic:SOUTH=ask,nodfl
-URM5:Urmaev V:ALPHA=ask,0.0;LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0;QFACT=ask,1.0
-URMFPS:Urmaev Flat-Polar Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0
-UTM:Universal Transverse Mercator (UTM):ZONE=ask,nodfl;SOUTH=ask,nodfl
-VANDG2:van der Grinten II:LAT0=ask,0.0;LON0=ask,20.0
-VANDG3:van der Grinten III:LAT0=ask,0.0;LON0=ask,20.0
-VANDG4:van der Grinten IV:LAT0=ask,0.0;LON0=ask,20.0
-VANDG:van der Grinten (I):LAT0=ask,0.0;LON0=ask,20.0
-WAG1:Wagner I (Kavraisky VI):LAT0=ask,0.0;LON0=ask,20.0
-WAG2:Wagner II:LAT0=ask,0.0;LON0=ask,20.0
-WAG3:Wagner III:LAT0=ask,0.0;LON0=ask,20.0
-WAG4:Wagner IV:LAT0=ask,0.0;LON0=ask,20.0
-WAG5:Wagner V:LAT0=ask,0.0;LON0=ask,20.0
-WAG6:Wagner VI:LAT0=ask,0.0;LON0=ask,20.0
-WAG7:Wagner VII:LAT0=ask,0.0;LON0=ask,20.0
-WEREN:Werenskiold I:LAT0=ask,0.0;LON0=ask,20.0
-WINK1:Winkel I:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
-WINK2:Winkel II:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0
-WINTRI:Winkel Tripel:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0
Deleted: grass/trunk/general/g.setproj/proj-units.table
--- grass/trunk/general/g.setproj/proj-units.table 2010-01-19 15:48:30 UTC (rev 40556)
+++ grass/trunk/general/g.setproj/proj-units.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -1,16 +0,0 @@
-meters:meter:1.0
-feet:foot:0.3048
-miles:mile:1609.344
-inches:inch:2.540000e-02
-centimeters:centimeter:0.01
-nanometers:nanometer:1.000000e-09
-microns:micron:1.000000e-06
-angstroms:angstrom:1.000000e-10
-decinanometers:decinanometer:1.000000e-10
-yards:yard:0.9144
-rods:rod:5.0292
-lightyears:lightyear:9.460530e+15
-USfeet:USfoot:0.30480060960121920243
-USinches:USinch:.02540005080010160020
-USyards:USyard:.91440182880365760731
-USmiles:USmile:1609.34721869443738887477
Modified: grass/trunk/lib/proj/Makefile
--- grass/trunk/lib/proj/Makefile 2010-01-19 15:48:30 UTC (rev 40556)
+++ grass/trunk/lib/proj/Makefile 2010-01-19 17:02:36 UTC (rev 40557)
@@ -21,8 +21,11 @@
NT_DSTFILES := $(patsubst %,$(NAD_DIR)/%,$(NT_TABLES))
CSV_DSTFILES := $(patsubst %,$(CSV_DIR)/%,$(CSV_FILES))
+PROJ_TABLES := proj-desc.table proj-parms.table proj-units.table
+PROJ_DSTFILES := $(patsubst %,$(ETC)/%,$(PROJ_TABLES))
default: lib
- $(MAKE) $(NAD_DSTFILES) $(CSV_DSTFILES)
+ $(MAKE) $(NAD_DSTFILES) $(CSV_DSTFILES) $(PROJ_DSTFILES)
$(NAD_DIR)/%: %.lla | $(NAD_DIR)
$(NAD2BIN) < $< $@
@@ -33,6 +36,9 @@
$(CSV_DIR)/%.csv: %.csv | $(CSV_DIR)
$(INSTALL_DATA) $< $@
+$(ETC)/proj-%.table: proj-%.table
+ $(INSTALL_DATA) $< $@
$(NAD_DIR):
$(MKDIR) $@
Copied: grass/trunk/lib/proj/proj-desc.table (from rev 40542, grass/trunk/general/g.setproj/proj-desc.table)
--- grass/trunk/lib/proj/proj-desc.table (rev 0)
+++ grass/trunk/lib/proj/proj-desc.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -0,0 +1,43 @@
+ALPHA:lon:alpha:Azimuth angle at Cartesian Origin
+AZIM:float:azi:Azimuth Angle of Tilt in Decimal degrees
+GUAM:bool:guam:
+HEIGH:float:h:Height of Viewing Point in Meters
+KFACT:float:k_0:Scale Factor at the Central Meridian
+LAT0:lat:lat_0:Central Parallel
+LAT1:lat:lat_1:First Standard Parallel
+LAT2:lat:lat_2:Second Standard Parallel
+LAT3:lat:lat_3:Third Standard Parallel
+LATB:lat:lat_b:Angular Distance from Tangency Point
+LATTS:lat:lat_ts:Latitude of True Scale
+LON0:lon:lon_0:Central Meridian
+LON1:lon:lon_1:First Standard Meridian
+LON2:lon:lon_2:Second Standard Meridian
+LON3:lon:lon_3:Third Standard Meridian
+LONC:lon:lon_c:Longitude of Cartesian Origin
+LOTSA:bool:lotsa:LOTSA
+MFACT:float:m:m factor
+MSFACT:float:M:M factor
+NFACT:float:n:n factor
+NOCUT:bool:no_cut:Both Hemispheres
+NOROT:bool:no_rot:Suppress Rotation
+NOSKEW:bool:ns:Suppress Skew
+NOUOFF:bool:no_uoff:Suppress Offset from Pre-Rotated Axis
+OALPHA:lat:o_alpha:
+OLAT1:lat:o_lat_1:
+OLAT2:lat:o_lat_2:
+OLATP:float:o_lat_p:Latitude of New Pole
+OLON1:lon:o_lon_1:
+OLON2:lon:o_lon_2:
+OLONC:lon:o_lon_c:
+OLONP:lon:o_lon_p:Longitude of New Pole
+QFACT:float:q:q factor
+ROTCONV:bool:rot_conv:Origin Convergence Angle
+SNUM:int:lsat:Satellite Number
+SOUTH:bool:south:Southern Hemisphere
+SPATH:int:path:Satellite Path Number
+THETA:lon:theta:Theta Angle
+TILT:float:tilt:Tilt Angle in Decimal Degrees
+WFACT:float:W:W factor
+X0:float:x_0:False Easting
+Y0:float:y_0:False Northing
+ZONE:zone:zone:Projection Zone
Copied: grass/trunk/lib/proj/proj-parms.table (from rev 40542, grass/trunk/general/g.setproj/proj-parms.table)
--- grass/trunk/lib/proj/proj-parms.table (rev 0)
+++ grass/trunk/lib/proj/proj-parms.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -0,0 +1,123 @@
+AEA:Albers Equal Area:LAT0=ask,23.0;LAT1=ask,29.5;LAT2=ask,45.5;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
+AEQD:Azimuthal Equidistant:LAT0=ask,0.0;LON0=ask,20.0
+AIRY:Airy:LAT0=ask,0.0;LATB=ask,90.0;LON0=ask,20.0;NOCUT=ask,nodfl
+AITOFF:Aitoff:LAT0=ask,0.0;LON0=ask,20.0
+ALSK:Mod. Stererographics of Alaska:LAT0=noask,64.0;LON0=noask,-152.0
+APIAN:Apian Globular I:LAT0=ask,0.0;LON0=ask,20.0
+AUGUST:August Epicycloidal:LAT0=ask,0.0;LON0=ask,20.0
+BACON:Bacon Globular:LAT0=ask,0.0;LON0=ask,20.0
+BIPC:Bipolar conic of western hemisphere:LAT0=ask,0.0;LON0=ask,-90.0;NOSKEW=ask,nodfl
+BOGGS:Boggs Eumorphic:LAT0=ask,0.0;LON0=ask,20.0
+BONNE:Bonne (Werner lat_1=90):LAT1=ask,40.0;LON0=ask,20.0
+CASS:Cassini:LAT0=ask,0.0;LON0=ask,20.0
+CC:Central Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
+CEA:Equal Area Cylindrical:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
+CHAMB:Chamberlin Trimetric:LAT0=ask,55.0;LAT1=ask,40.0;LAT2=ask,20.0;LAT3=ask,35.0;LON0=ask,20.0;LON1=ask,5.0;LON2=ask,55.0;LON3=ask,65.0
+COLLG:Collignon:LAT0=ask,0.0;LON0=ask,20.0
+CRAST:Craster Parabolic (Putnins P4):LAT0=ask,0.0;LON0=ask,20.0
+DENOY:Denoyer Semi-Elliptical:LAT0=ask,0.0;LON0=ask,20.0
+ECK1:Eckert I:LAT0=ask,0.0;LON0=ask,20.0
+ECK2:Eckert II:LAT0=ask,0.0;LON0=ask,20.0
+ECK3:Eckert III:LAT0=ask,0.0;LON0=ask,20.0
+ECK4:Eckert IV:LAT0=ask,0.0;LON0=ask,20.0
+ECK5:Eckert V:LAT0=ask,0.0;LON0=ask,20.0
+ECK6:Eckert VI:LAT0=ask,0.0;LON0=ask,20.0
+EQC:Equidistant Cylindrical (Plate Caree):LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,0.0
+EQDC:Equidistant Conic:LAT0=ask,40.0;LAT1=ask,20.0;LAT2=ask,60.0;LON0=ask,20.0
+EULER:Euler:LAT0=ask,55.0;LAT1=ask,45.0;LAT2=ask,65.0;LON0=ask,20.0
+FAHEY:Fahey:LAT0=ask,0.0;LON0=ask,20.0
+FOUC:Foucaut:LAT0=ask,0.0;LON0=ask,20.0
+FOUC_S:Foucaut Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0
+GALL:Gall (Gall Stereographic):LAT0=ask,0.0;LON0=ask,20.0
+GEOS:Geostationary Satellite View:HEIGH=ask,35800000.0;LON0=ask,20.0;X0=ask,0.0;Y0=ask,0.0
+GINS8:Ginsburg VIII (TsNIIGAiK):LAT0=ask,0.0;LON0=ask,20.0
+GNOM:Gnomonic:LAT0=ask,0.0;LON0=ask,20.0
+GN_SINU:General Sinusoidal Series:LAT0=ask,0.0;LON0=ask,20.0;MFACT=ask,1.0;NFACT=ask,1.0
+GOODE:Goode Homolosine:LAT0=ask,0.0;LON0=ask,20.0
+GS48:Mod. Stererographics of 48 U.S.:LAT0=noask,45.0;LON0=noask,-120.0
+GS50:Mod. Stererographics of 50 U.S.:LAT0=noask,45.0;LON0=noask,-120.0
+HAMMER:Hammer & Eckert-Greifendorff:LAT0=ask,0.0;LON0=ask,20.0;MSFACT=ask,1.0;WFACT=ask,0.5
+HATANO:Hatano Asymmetrical Equal Area:LAT0=ask,0.0;LON0=ask,20.0
+IMW_P:International Map of the World Polyconic:LAT0=ask,0.0;LAT1=ask,20.0;LAT2=ask,60.0;LON0=ask,20.0;LON1=ask,20.0
+KAV5:Kavraisky V:LAT0=ask,0.0;LON0=ask,20.0
+KAV7:Kavraisky VII:LAT0=ask,0.0;LON0=ask,20.0
+KROVAK:Krovak:LAT0=noask,0.0;LON0=noask,0
+LABRD:Laborde:AZIM=noask,18.9;KFACT=noask,0.9995;LAT0=noask,18.9;LON0=noask,46.437208333;X0=noask,400000.0;Y0=noask,800000.0
+LAEA:Lambert Azimuthal Equal Area:LAT0=ask,55.0;LON0=ask,20.0;X0=ask,0.0;Y0=ask,0.0
+LAGRNG:Lagrange:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0;WFACT=ask,2.0
+LARR:Larrivee:LAT0=ask,0.0;LON0=ask,20.0
+LASK:Laskowski:LAT0=ask,0.0;LON0=ask,20.0
+LCC:Lambert Conformal Conic:LAT0=ask,23.0;LAT1=ask,33.0;LAT2=ask,45.0;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
+LEAC:Lambert Equal Area Conic:LAT0=ask,55.0;LAT1=ask,0.0;LON0=ask,20.0;SOUTH=ask,nodfl
+LEE_OS:Lee Oblated Stereographic:LAT0=noask,-10.0;LON0=noask,-165.0
+LL:Latitude/Longitude (pseudo-projection):LAT0=noask,0.0;LON0=noask,0.0
+LOXIM:Loximuthal:LAT0=ask,0.0;LAT1=ask,45.0;LON0=ask,20.0
+LSAT:Space oblique for LANDSAT:LAT0=ask,0.0;LON0=ask,20.0;SNUM=ask,1;SPATH=ask,1
+MBTFPP:McBride-Thomas Flat-Polar Parabolic:LAT0=ask,0.0;LON0=ask,20.0
+MBTFPQ:McBryde-Thomas Flat-Polar Quartic:LAT0=ask,0.0;LON0=ask,20.0
+MBTFPS:McBryde-Thomas Flat-Polar Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0
+MBT_FPS:McBryde-Thomas Flat-Pole Sine (No. 2):LAT0=ask,0.0;LON0=ask,20.0
+MBT_S:McBryde-Thomas Flat-Polar Sine (No. 1):LAT0=ask,0.0;LON0=ask,20.0
+MERC:Mercator:KFACT=ask,1.0;LATTS=ask,0.;LON0=ask,-96.0
+MILL:Miller Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
+MIL_OS:Miller Oblated Stereographic:LAT0=noask,18.0;LON0=noask,20.0
+MOLL:Mollweide:LAT0=ask,0.0;LON0=ask,20.0
+MPOLY:Modified Polyconic:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0;LOTSA=ask,nodfl
+MURD1:Murdoch I:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
+MURD2:Murdoch II:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
+MURD3:Murdoch III:LAT0=ask,0.0;LAT1=ask,-20.0;LAT2=ask,20.0;LON0=ask,20.0
+NELL:Nell:LAT0=ask,0.0;LON0=ask,20.0
+NELL_H:Nell-Hammer:LAT0=ask,0.0;LON0=ask,20.0
+NICOL:Nicolosi Globular:LAT0=ask,0.0;LON0=ask,20.0
+NSPER:Near-sided perspective:HEIGH=ask,50000000.0;LAT0=ask,55.0;LON0=ask,20.0
+NZMG:New Zealand Map Grid:LAT0=noask,-41.0;LON0=noask,173.0;X0=noask,2510000.0;Y0=noask,6023150.0
+OB_TRAN:General Oblique Transformation:LAT0=ask,0.0;LON0=ask,0.0;OLATP=ask,90.0;OLONP=ask,0.0
+OCEA:Oblique Cylindrical Equal Area:LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-20.0;LON2=ask,60.0
+OEA:Oblated Equal Area:LAT0=ask,0.0;LON0=ask,20.0;MFACT=ask,1.0;NFACT=ask,1.0;THETA=ask,0.0
+OMERC:Oblique Mercator:KFACT=ask,1.0;LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-40.0;LON2=ask,40.0;NOROT=ask,nodfl;NOUOFF=ask,nodfl;ROTCONV=ask,nodfl
+ORTEL:Ortelius Oval:LAT0=ask,0.0;LON0=ask,20.0
+ORTHO:Orthographic:LAT0=ask,0.0;LON0=ask,20.0
+PCONIC:Perspective Conic:LAT0=ask,0.0;LAT1=ask,33.0;LAT2=ask,45.0;LON0=ask,20.0
+POLY:Polyconic (American):LAT0=ask,0.0;LON0=ask,-90.0
+PUTP1:Putnins P1:LAT0=ask,0.0;LON0=ask,20.0
+PUTP2:Putnins P2:LAT0=ask,0.0;LON0=ask,20.0
+PUTP3:Putnins P3:LAT0=ask,0.0;LON0=ask,20.0
+PUTP3P:Putnins P3':LAT0=ask,0.0;LON0=ask,20.0
+PUTP4P:Putnins P4':LAT0=ask,0.0;LON0=ask,20.0
+PUTP5:Putnins P5:LAT0=ask,0.0;LON0=ask,20.0
+PUTP5P:Putnins P5':LAT0=ask,0.0;LON0=ask,20.0
+PUTP6:Putnins P6:LAT0=ask,0.0;LON0=ask,20.0
+PUTP6P:Putnins P6':LAT0=ask,0.0;LON0=ask,20.0
+QUA_AUT:Quartic Authalic:LAT0=ask,0.0;LON0=ask,20.0
+ROBIN:Robinson:LAT0=ask,0.0;LON0=ask,20.0
+RPOLY:Rectangular Polyconic:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
+SINU:Sinusoidal (Sanson-Flamsteed):LAT0=ask,0.0;LON0=ask,20.0
+SOMERC:Swiss. Obl. Mercator:KFACT=noask,1.0;LAT0=noask,46.952405556;LON0=noask,7.4395833333;X0=noask,600000.0;Y0=noask,200000.0
+STERE:Stereographic:KFACT=ask,1.0;LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
+STEREA:Oblique Stereographic Alternative:KFACT=ask,1.0;LAT0=ask,0.0;LON0=ask,20.0
+STP:State Plane (pseudo-projection):LAT0=noask,0.0;LON0=noask,0.0
+TCC:Transverse Central Cylindrical:LAT0=ask,0.0;LON0=ask,20.0
+TCEA:Transverse Cylindrical Equal Area:KFACT=ask,1.0;LAT0=ask,0.0;LON0=ask,20.0
+TISSOT:Tissot:LAT0=ask,0.0;LAT1=ask,-30.0;LAT2=ask,45.0;LON0=ask,20.0
+TMERC:Transverse Mercator:KFACT=ask,1.0;LAT0=ask,23.0;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
+TPEQD:Two Point Equidistant:LAT0=ask,0.0;LAT1=ask,-45.0;LAT2=ask,45.0;LON0=ask,20.0;LON1=ask,-20.0;LON2=ask,60.0
+TPERS:Tilted perspective:AZIM=ask,0.0;HEIGH=ask,10000.0;LAT0=ask,0.0;LON0=ask,20.0;TILT=ask,0.0
+UPS:Universal Polar Stereographic:SOUTH=ask,nodfl
+URM5:Urmaev V:ALPHA=ask,0.0;LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0;QFACT=ask,1.0
+URMFPS:Urmaev Flat-Polar Sinusoidal:LAT0=ask,0.0;LON0=ask,20.0;NFACT=ask,1.0
+UTM:Universal Transverse Mercator (UTM):ZONE=ask,nodfl;SOUTH=ask,nodfl
+VANDG2:van der Grinten II:LAT0=ask,0.0;LON0=ask,20.0
+VANDG3:van der Grinten III:LAT0=ask,0.0;LON0=ask,20.0
+VANDG4:van der Grinten IV:LAT0=ask,0.0;LON0=ask,20.0
+VANDG:van der Grinten (I):LAT0=ask,0.0;LON0=ask,20.0
+WAG1:Wagner I (Kavraisky VI):LAT0=ask,0.0;LON0=ask,20.0
+WAG2:Wagner II:LAT0=ask,0.0;LON0=ask,20.0
+WAG3:Wagner III:LAT0=ask,0.0;LON0=ask,20.0
+WAG4:Wagner IV:LAT0=ask,0.0;LON0=ask,20.0
+WAG5:Wagner V:LAT0=ask,0.0;LON0=ask,20.0
+WAG6:Wagner VI:LAT0=ask,0.0;LON0=ask,20.0
+WAG7:Wagner VII:LAT0=ask,0.0;LON0=ask,20.0
+WEREN:Werenskiold I:LAT0=ask,0.0;LON0=ask,20.0
+WINK1:Winkel I:LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
+WINK2:Winkel II:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0
+WINTRI:Winkel Tripel:LAT0=ask,0.0;LAT1=ask,0.0;LON0=ask,20.0
Copied: grass/trunk/lib/proj/proj-units.table (from rev 40542, grass/trunk/general/g.setproj/proj-units.table)
--- grass/trunk/lib/proj/proj-units.table (rev 0)
+++ grass/trunk/lib/proj/proj-units.table 2010-01-19 17:02:36 UTC (rev 40557)
@@ -0,0 +1,16 @@
+meters:meter:1.0
+feet:foot:0.3048
+miles:mile:1609.344
+inches:inch:2.540000e-02
+centimeters:centimeter:0.01
+nanometers:nanometer:1.000000e-09
+microns:micron:1.000000e-06
+angstroms:angstrom:1.000000e-10
+decinanometers:decinanometer:1.000000e-10
+yards:yard:0.9144
+rods:rod:5.0292
+lightyears:lightyear:9.460530e+15
+USfeet:USfoot:0.30480060960121920243
+USinches:USinch:.02540005080010160020
+USyards:USyard:.91440182880365760731
+USmiles:USmile:1609.34721869443738887477
