[GRASS-SVN] r40560 - grass/trunk/raster/r.proj
svn_grass at osgeo.org
Tue Jan 19 18:48:58 EST 2010
Author: hamish
Date: 2010-01-19 18:48:57 -0500 (Tue, 19 Jan 2010)
New Revision: 40560
grass/trunk/raster/r.proj/main.c
new flag to show reprojected bounds and exit (trac #845; merge from devbr6)
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2010-01-19 23:45:12 UTC (rev 40559)
+++ grass/trunk/raster/r.proj/main.c 2010-01-19 23:48:57 UTC (rev 40560)
@@ -90,7 +90,8 @@
row, col, /* counters */
irows, icols, /* original rows, cols */
orows, ocols, have_colors, /* Input map has a colour table */
- overwrite; /* Overwrite */
+ overwrite, /* Overwrite */
+ curr_proj; /* output projection (see gis.h) */
void *obuffer, /* buffer that holds one output row */
*obufptr; /* column ptr in output buffer */
@@ -103,6 +104,7 @@
row_idx, /* row index in input matrix */
onorth, osouth, /* save original border coords */
oeast, owest, inorth, isouth, ieast, iwest;
+ char north_str[30], south_str[30], east_str[30], west_str[30];
struct Colors colr; /* Input map colour table */
struct History history;
@@ -117,7 +119,9 @@
struct GModule *module;
struct Flag *list, /* list files in source location */
- *nocrop; /* don't crop output map */
+ *nocrop, /* don't crop output map */
+ *print_bounds, /* print output bounds and exit */
+ *gprint_bounds; /* same but print shell style */
struct Option *imapset, /* name of input mapset */
*inmap, /* name of input layer */
@@ -196,6 +200,17 @@
nocrop->key = 'n';
nocrop->description = _("Do not perform region cropping optimization");
+ print_bounds = G_define_flag();
+ print_bounds->key = 'p';
+ print_bounds->description =
+ _("Print input map's bounds in the current projection and exit");
+ gprint_bounds = G_define_flag();
+ gprint_bounds->key = 'g';
+ gprint_bounds->description =
+ _("Print bounds and exit (shell style)");
/* The parser checks if the map already exists in current mapset,
we switch out the check and do it
in the module after the parser */
@@ -204,6 +219,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* get the method */
for (method = 0; (ipolname = menu[method].name); method++)
if (strcmp(ipolname, interpol->answer) == 0)
@@ -227,6 +243,10 @@
G_get_window(&outcellhd);
+ if(gprint_bounds->answer && !print_bounds->answer)
+ print_bounds->answer = gprint_bounds->answer;
+ curr_proj = G_projection();
/* Get projection info for output mapset */
if ((out_proj_info = G_get_projinfo()) == NULL)
G_fatal_error(_("Unable to get projection info of output raster map"));
@@ -307,6 +327,35 @@
orows = outcellhd.rows;
ocols = outcellhd.cols;
+ if (print_bounds->answer) {
+ G_message(_("Input map <%s@%s> in location <%s>:"),
+ inmap->answer, setname, inlocation->answer);
+ G_format_northing(onorth, north_str, curr_proj);
+ G_format_northing(osouth, south_str, curr_proj);
+ G_format_easting(oeast, east_str, curr_proj);
+ G_format_easting(owest, west_str, curr_proj);
+ if(gprint_bounds->answer) {
+ fprintf(stdout, "n=%s s=%s w=%s e=%s\n",
+ north_str, south_str, west_str, east_str);
+ else {
+ fprintf(stdout, "Source cols: %d\n", icols);
+ fprintf(stdout, "Source rows: %d\n", irows);
+ fprintf(stdout, "Local north: %s\n", north_str);
+ fprintf(stdout, "Local south: %s\n", south_str);
+ fprintf(stdout, "Local west: %s\n", west_str);
+ fprintf(stdout, "Local east: %s\n", east_str);
+ /* somehow approximate local ewres, nsres ?? (use 'g.region -m' on lat/lon side) */
+ exit(EXIT_SUCCESS);
/* Cut non-overlapping parts of input map */
if (!nocrop->answer)
bordwalk(&outcellhd, &incellhd, &oproj, &iproj);
