[GRASS-SVN] r40566 -
grass/branches/develbranch_6/vector/lidar/v.outlier
svn_grass at osgeo.org
Wed Jan 20 03:29:41 EST 2010
Author: mmetz
Date: 2010-01-20 03:29:39 -0500 (Wed, 20 Jan 2010)
New Revision: 40566
grass/branches/develbranch_6/vector/lidar/v.outlier/main.c
grass/branches/develbranch_6/vector/lidar/v.outlier/outlier.c
fixing aux table and bug in P_Outlier(), backport from trunk r39785
Modified: grass/branches/develbranch_6/vector/lidar/v.outlier/main.c
--- grass/branches/develbranch_6/vector/lidar/v.outlier/main.c 2010-01-20 08:25:43 UTC (rev 40565)
+++ grass/branches/develbranch_6/vector/lidar/v.outlier/main.c 2010-01-20 08:29:39 UTC (rev 40566)
@@ -134,7 +134,8 @@
Thres_Outlier = atof(Thres_O_opt->answer);
/* Setting auxiliar table's name */
- sprintf(table_name, "%s_aux", out_opt->answer);
+ /* sprintf(table_name, "%s_aux", out_opt->answer); */
+ sprintf(table_name, "Auxiliar_outlier_table");
/* Checking vector names */
Vect_check_input_output_name(in_opt->answer, out_opt->answer,
@@ -188,13 +189,19 @@
G_fatal_error(_("No database connection for driver <%s> is defined. Run db.connect."),
dvr);
+ /* Something went wrong in a previous v.outlier execution */
+ if (db_table_exists(dvr, db, table_name)) {
+ if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
+ G_fatal_error(_("Old auxiliar table could not be dropped"));
/* Setting regions and boxes */
G_get_set_window(&original_reg);
G_get_set_window(&elaboration_reg);
Vect_region_box(&elaboration_reg, &overlap_box);
Vect_region_box(&elaboration_reg, &general_box);
- /* Fixxing parameters of the elaboration region */
+ /* Fixing parameters of the elaboration region */
/*! Each original_region will be divided into several subregions. These
* subregion will be overlapped by its neibourgh subregions. This overlapping
* is calculated as OVERLAP_PASS times the east-west resolution. */
@@ -355,7 +362,7 @@
Vect_close(&Qgis);
- G_done_msg("");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
} /*!END MAIN */
Modified: grass/branches/develbranch_6/vector/lidar/v.outlier/outlier.c
--- grass/branches/develbranch_6/vector/lidar/v.outlier/outlier.c 2010-01-20 08:25:43 UTC (rev 40565)
+++ grass/branches/develbranch_6/vector/lidar/v.outlier/outlier.c 2010-01-20 08:29:39 UTC (rev 40566)
@@ -14,7 +14,7 @@
int num_points, dbDriver * driver)
int i;
- double interpolation, weight, residual, eta, csi, *gradient;
+ double interpolation, weight, residual, eta, csi, gradient[2];
extern int nsplx, nsply;
extern double passoN, passoE;
