[GRASS-SVN] r40580 - grass-addons/vector/v.rast.stats2
svn_grass at osgeo.org
Wed Jan 20 09:43:44 EST 2010
Author: dassau
Date: 2010-01-20 09:43:43 -0500 (Wed, 20 Jan 2010)
New Revision: 40580
grass-addons/vector/v.rast.stats2/description.html
small fix in description
Modified: grass-addons/vector/v.rast.stats2/description.html
--- grass-addons/vector/v.rast.stats2/description.html 2010-01-20 14:33:10 UTC (rev 40579)
+++ grass-addons/vector/v.rast.stats2/description.html 2010-01-20 14:43:43 UTC (rev 40580)
@@ -8,8 +8,8 @@
New columns are generated in the attribute table if not already present.
<p>
Nine columns are generated (n, min, max, range, mean, stddev, variance,
-coeff_var, sum) according to the output of <em>r.univar2.zonal</em>. Column n
-complies column <em>non_null_cells</em> from <em>r.univar2.zonal</em> and all
+coeff_var, sum) according to the output of <em>r.univar.zonal</em>. Column n
+complies column <em>non_null_cells</em> from <em>r.univar.zonal</em> and all
univariate statistics are based on <em>non_null_cells</em>. If the <B>-e</B>
extended statistics flag is given the 1st quartile, median, 3rd quartile,
and given percentile are also calculated.
@@ -35,7 +35,7 @@
The script changes temporarily to the resolution of the given raster map.
<p>
At the moment not all univariate statistics calculated by
-<em>r.univar2.zonal</em> are added to the vector attribute table. It is
+<em>r.univar.zonal</em> are added to the vector attribute table. It is
currently limited to the values used in the GRASS module
<em>v.rast.stats</em>.
<p>
@@ -68,7 +68,7 @@
<EM>
<A HREF="r.univar.html">r.univar</A>,
-<A HREF="r.univar2.zonal.html">r.univar2.zonal</A>,
+<A HREF="r.univar2.zonal.html">r.univar.zonal</A>,
<A HREF="v.univar.html">v.univar</A>,
<A HREF="v.rast.stats.html">v.rast.stats</A>,
<a HREF="v.what.rast.html">v.what.rast</a>,
