[GRASS-SVN] r40615 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Jan 22 04:51:23 EST 2010
Author: huhabla
Date: 2010-01-22 04:51:23 -0500 (Fri, 22 Jan 2010)
New Revision: 40615
grass/trunk/lib/gis/parser_wps.c
Disabled experimental features
Enabled plain text file input
Added resolution parameter
Added link to manual page at grass.osgeo.org
Modified: grass/trunk/lib/gis/parser_wps.c
--- grass/trunk/lib/gis/parser_wps.c 2010-01-22 05:34:00 UTC (rev 40614)
+++ grass/trunk/lib/gis/parser_wps.c 2010-01-22 09:51:23 UTC (rev 40615)
@@ -20,6 +20,7 @@
static void wps_print_data_inputs_end(void);
static void wps_print_process_outputs_begin(void);
static void wps_print_process_outputs_end(void);
+static void wps_print_bounding_box_data(void);
static void wps_print_mimetype_text_plain(void);
static void wps_print_mimetype_raster_tiff(void);
static void wps_print_mimetype_raster_png(void);
@@ -155,6 +156,19 @@
wps_print_process_description_begin(store, status, identifier, title, abstract, keywords, num_keywords);
wps_print_data_inputs_begin();
+ /* We have two default options, which define the resolution of the created mapset */
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "resolution_ns", "Resolution of the mapset in north-south direction in [m] or [°]",
+ "This parameter defines the north-south resolution of the mapset in meter or degrees, which should be used ot process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
+ "float", 0, NULL, 0, "25", TYPE_OTHER);
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, "resolution_ew", "Resolution of the mapset in east-west direction in [m] or [°]",
+ "This parameter defines the east-west resolution of the mapset in meters or degrees, which should be used ot process the input and output raster data. To enable this setting, you need to specify north-south and east-west resolution.",
+ /* Print the bounding box element with all the coordinate reference systems, which are supported by grass*/
+ /* Currently Disabled! A list of all proj4 supported EPSG coordinate reference systems must be implemented*/
+ if(1 == 0)
+ wps_print_bounding_box_data();
/* We parse only the inputs at the beginning */
if (st->n_opts) {
opt = &st->first_option;
@@ -189,6 +203,10 @@
data_type = TYPE_VECTOR;
+ if(strcmp(token, "file") == 0)
+ data_type = TYPE_PLAIN_TEXT;
s = strtok(NULL, ",");
G_free(token);
@@ -243,15 +261,15 @@
num_keywords = i;
- if(data_type == TYPE_RASTER || data_type == TYPE_VECTOR)
+ if(data_type == TYPE_RASTER || data_type == TYPE_VECTOR || data_type == TYPE_PLAIN_TEXT)
/* 2048 is the maximum size of the map in mega bytes */
- wps_print_complex_input(min, max, identifier, title, abstract, 2048, data_type);
+ wps_print_complex_input(min, max, identifier, title, NULL, 2048, data_type);
else
/* The keyword array is missused for options, type means the type of the value (integer, float ... )*/
- wps_print_literal_input_output(WPS_INPUT, min, max, identifier, title, abstract, type, 0, keywords, num_keywords, value, TYPE_OTHER);
+ wps_print_literal_input_output(WPS_INPUT, min, max, identifier, title, NULL, type, 0, keywords, num_keywords, value, TYPE_OTHER);
opt = opt->next_opt;
@@ -276,7 +294,7 @@
abstract = flag->description;
const char *val[] = {"true","false"};
- wps_print_literal_input_output(WPS_INPUT, 0, 1, ident, title, abstract, "boolean", 0, val, 2, "false", TYPE_OTHER);
+ wps_print_literal_input_output(WPS_INPUT, 0, 1, ident, title, NULL, "boolean", 0, val, 2, "false", TYPE_OTHER);
flag = flag->next_flag;
@@ -320,6 +338,10 @@
G_free(token);
@@ -334,10 +356,10 @@
abstract = opt->description;
- /* Only raster and vector output is supported by option */
+ /* Only file, raster and vector output is supported by option */
- wps_print_complex_output(identifier, title, abstract, data_type);
+ wps_print_complex_output(identifier, title, NULL, data_type);
found_output = 1;
@@ -404,8 +426,9 @@
if(abstract)
fprintf(stdout,"\t\t<ows:Abstract>\n");
- G__usage_html();
- fprintf(stdout, "\n\t\t</ows:Abstract>\n");
+ fprintf(stdout, "\t\t\tThe manual page of this module is available here:\n");
+ fprintf(stdout, "\t\t\thttp://grass.osgeo.org/grass70/manuals/html70_user/%s.html\n", identifier);
+ fprintf(stdout, "\t\t</ows:Abstract>\n");
for(i = 0; i < num_keywords; i++)
@@ -499,15 +522,21 @@
if(type == TYPE_RASTER)
wps_print_mimetype_raster_tiff();
- wps_print_mimetype_raster_png();
- wps_print_mimetype_raster_grass_ascii();
- wps_print_mimetype_raster_grass_binary();
+ /* These mime types are currently not meaningful */
+ if(1 == 0) {
+ wps_print_mimetype_raster_png();
+ wps_print_mimetype_raster_grass_ascii();
+ wps_print_mimetype_raster_grass_binary();
else if(type == TYPE_VECTOR)
wps_print_mimetype_vector_gml310();
- wps_print_mimetype_vector_grass_ascii();
- wps_print_mimetype_vector_grass_binary();
+ if(1 == 0) {
+ wps_print_mimetype_vector_grass_ascii();
+ wps_print_mimetype_vector_grass_binary();
else if(type == TYPE_PLAIN_TEXT)
@@ -694,3 +723,26 @@
fprintf(stdout,"\t\t\t\t\t\t\t<MimeType>application/grass-vector-binary</MimeType>\n");
fprintf(stdout,"\t\t\t\t\t\t</Format>\n");
+/* Bounding box data input. Do not use! Under construction. A list of coordinate reference systems must be created.*/
+ int i;
+ fprintf(stdout,"\t\t\t<Input minOccurs=\"0\" maxOccurs=\"1\">\n");
+ wps_print_ident_title_abstract("BoundingBox", "Bounding box to process data",
+ "The bounding box is uesed to create the reference coordinate system in grass, as well as the lower left and upper right corner of the processing area.");
+ fprintf(stdout,"\t\t\t\t<BoundingBoxData>\n");
+ /* A meaningful default boundingbox should be chosen*/
+ fprintf(stdout,"\t\t\t\t\t<Default>\n");
+ fprintf(stdout,"\t\t\t\t\t\t<CRS>urn:ogc:def:crs,crs:EPSG:6.3:32760</CRS>\n");
+ fprintf(stdout,"\t\t\t\t\t</Default>\n");
+ /* A list of all proj4 supported EPSG coordinate systems should be created */
+ fprintf(stdout,"\t\t\t\t\t<Supported>\n");
+ for(i = 0; i < 1; i++)
+ fprintf(stdout,"\t\t\t\t\t</Supported>\n");
+ fprintf(stdout,"\t\t\t\t</BoundingBoxData>\n");
+ fprintf(stdout,"\t\t\t</Input>\n");
\ No newline at end of file
