[GRASS-SVN] r40627 - grass/trunk/lib/gpde
svn_grass at osgeo.org
Sat Jan 23 08:47:04 EST 2010
Author: huhabla
Date: 2010-01-23 08:47:02 -0500 (Sat, 23 Jan 2010)
New Revision: 40627
grass/trunk/lib/gpde/N_arrays.c
grass/trunk/lib/gpde/N_gwflow.c
grass/trunk/lib/gpde/N_heatflow.h
Location support.
Small cleanup.
Modified: grass/trunk/lib/gpde/N_arrays.c
--- grass/trunk/lib/gpde/N_arrays.c 2010-01-23 01:11:50 UTC (rev 40626)
+++ grass/trunk/lib/gpde/N_arrays.c 2010-01-23 13:47:02 UTC (rev 40627)
@@ -169,7 +169,7 @@
* \brief Write the value of the N_array_2d struct at position col, row to value
- * The value must be from the same type as the array. Otherwise you will risk data losses.
+ * The value must be of the same type as the array. Otherwise you will risk data losses.
* \param data N_array_2d *
* \param col int
Modified: grass/trunk/lib/gpde/N_gwflow.c
--- grass/trunk/lib/gpde/N_gwflow.c 2010-01-23 01:11:50 UTC (rev 40626)
+++ grass/trunk/lib/gpde/N_gwflow.c 2010-01-23 13:47:02 UTC (rev 40627)
@@ -433,9 +433,9 @@
if(fabs(sum) < 0.0000000001)
- G_message("The total sum of the water budget: %g\n", sum);
+ G_message(_("The total sum of the water budget: %g\n"), sum);
else
- G_warning("The total sum of the water budget is significant larger then 0: %g\n", sum);
+ G_warning(_("The total sum of the water budget is significant larger then 0: %g\n"), sum);
return;
@@ -712,9 +712,9 @@
else
return;
Modified: grass/trunk/lib/gpde/N_heatflow.h
--- grass/trunk/lib/gpde/N_heatflow.h 2010-01-23 01:11:50 UTC (rev 40626)
+++ grass/trunk/lib/gpde/N_heatflow.h 2010-01-23 13:47:02 UTC (rev 40627)
@@ -53,10 +53,10 @@
} N_heatflow_data2d;
-extern N_les_row_entries *N_callback_heatflow_3d(void *heatdata,
+extern N_data_star *N_callback_heatflow_3d(void *heatdata,
N_geom_data * geom,
int depth, int row, int col);
-extern N_les_row_entries *N_callback_heatflow_2d(void *heatdata,
+extern N_data_star *N_callback_heatflow_2d(void *heatdata,
N_geom_data * geom, int row,
int col);
extern N_heatflow_data3d *N_alloc_heatflow_data3d(int depths, int rows,
