[GRASS-SVN] r40660 - grass-addons/raster/r.stream.extract
svn_grass at osgeo.org
Tue Jan 26 04:59:56 EST 2010
Author: mmetz
Date: 2010-01-26 04:59:48 -0500 (Tue, 26 Jan 2010)
New Revision: 40660
grass-addons/raster/r.stream.extract/do_astar.c
grass-addons/raster/r.stream.extract/streams.c
fix diagonal flow bias and make stream extraction more generic
Modified: grass-addons/raster/r.stream.extract/do_astar.c
--- grass-addons/raster/r.stream.extract/do_astar.c 2010-01-26 09:00:22 UTC (rev 40659)
+++ grass-addons/raster/r.stream.extract/do_astar.c 2010-01-26 09:59:48 UTC (rev 40660)
@@ -104,8 +104,8 @@
get_slope2(ele_val, ele_nbr[ct_dir],
dist_to_nbr[ct_dir]);
+ /* avoid diagonal flow direction bias */
if (!is_in_list) {
- /* avoid diagonal flow direction bias */
if (ct_dir > 3 && slope[ct_dir] > 0) {
if (slope[nbr_ew[ct_dir]] > 0) {
/* slope to ew nbr > slope to center */
@@ -289,8 +289,8 @@
double get_slope2(CELL ele, CELL up_ele, double dist)
- if (ele == up_ele)
- return 0.5 / dist;
+ if (ele >= up_ele)
+ return 0.0;
else
return (double)(up_ele - ele) / dist;
Modified: grass-addons/raster/r.stream.extract/streams.c
--- grass-addons/raster/r.stream.extract/streams.c 2010-01-26 09:00:22 UTC (rev 40659)
+++ grass-addons/raster/r.stream.extract/streams.c 2010-01-26 09:59:48 UTC (rev 40660)
@@ -643,16 +643,8 @@
continue;
- /* honour A * path
- * mfd_cells == 0: fine, SFD along A * path
- * mfd_cells == 1 && astar_not_set == 0: fine, SFD along A * path
- * mfd_cells > 0 && astar_not_set == 1: A * path not included, add to mfd_cells
- /* MFD, A * path not included, add to mfd_cells */
- if (mfd_cells > 0 && astar_not_set == 1) {
- mfd_cells++;
- /* get main drainage direction */
+ /* set main drainage direction to A* path if possible */
+ if (mfd_cells > 0 && max_side != np_side) {
nindex = INDEX(dr, dc);
if (fabs(acc[nindex]) >= max_acc) {
max_acc = fabs(acc[nindex]);
@@ -661,7 +653,7 @@
max_side = np_side;
- else if (mfd_cells == 0) {
+ if (mfd_cells == 0) {
flat = 0;
max_side = np_side;
@@ -699,8 +691,8 @@
- if (is_swale < 1 && flat == 0 && fabs(value) >= threshold &&
- stream_cells < 1 && swale_cells < 1) {
+ if (is_swale < 1 && fabs(value) >= threshold && stream_cells < 1 &&
+ swale_cells < 1 && !flat) {
G_debug(2, "start new stream");
is_swale = stream[thisindex] = ++stream_no;
/* add stream node */
