[GRASS-SVN] r40687 - in grass/branches/develbranch_6/scripts:
r.in.wms r.mask r.plane r.regression.line r.univar.sh
svn_grass at osgeo.org
Tue Jan 26 23:31:23 EST 2010
Author: hamish
Date: 2010-01-26 23:31:22 -0500 (Tue, 26 Jan 2010)
New Revision: 40687
grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp
grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
grass/branches/develbranch_6/scripts/r.in.wms/wms.download
grass/branches/develbranch_6/scripts/r.mask/r.mask
grass/branches/develbranch_6/scripts/r.plane/r.plane
grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line
grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh
rename TMP variable to avoid namespace collision on MS Windows (trac #890)
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.gdalwarp 2010-01-27 04:31:22 UTC (rev 40687)
@@ -83,8 +83,8 @@
g.message -d "[r.in.gdalwarp]"
#### setup temporary file
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
g.message -e "Unable to create temporary files"
exit 1
fi
@@ -96,7 +96,7 @@
exitprocedure()
g.message -e 'User break!'
- rm -f "${TMP}"*
+ rm -f "${TEMPFILE}"*
exit 1
trap "exitprocedure" 2 3 15
@@ -118,7 +118,7 @@
warpimport () {
FILE="$1"
MAP=$2
- WARPFILE="${TMP}warped.geotiff"
+ WARPFILE="${TEMPFILE}warped.geotiff"
TMPMAPNAME=${2}_tmp
# Warp it and convert it to geotiff with alpha band to be sure we get nulls:
@@ -129,7 +129,7 @@
if [ $? -ne 0 ] ; then
g.message -e message="`basename $0`: gdalwarp failure."
- rm -f "${TMP}"*
exit 1
fi
@@ -137,7 +137,7 @@
r.in.gdal $FLAGS input="$WARPFILE" output="$TMPMAPNAME" --quiet
g.message -e message="`basename $0`: r.in.gdal failure."
- rm -f "${TMP}"*
exit 1
fi
@@ -237,7 +237,7 @@
r.in.gdal -o $FLAGS input="$FILE" output="$MAP" --quiet
- rm -f "${TMP}"*
exit 1
fi
@@ -427,4 +427,4 @@
fi
# Clean up:
-rm -f "${TMP}"*
+rm -f "${TEMPFILE}"*
Modified: grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms
--- grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.in.wms/r.in.wms 2010-01-27 04:31:22 UTC (rev 40687)
@@ -199,8 +199,8 @@
fi
exit 1
fi
@@ -283,7 +283,7 @@
# is this bogus? won't PATH revert on exit anyway?
PATH="$prevPATH"
export PATH
- \rm -f "${TMP}"*
+ \rm -f "${TEMPFILE}"*
exit 1
@@ -331,7 +331,7 @@
listLayers() {
- CAPABILITIES_FILE="${TMP}capabilities.xml"
+ CAPABILITIES_FILE="${TEMPFILE}capabilities.xml"
STRING="service=WMS&request=GetCapabilities&${GIS_OPT_WMSQUERY}";
g.message -d message="POST-data: [$STRING]"
@@ -354,7 +354,7 @@
if [ ! -e "$CAPABILITIES_FILE" ] ; then
g.message -e "Downloading XML file"
- \rm "$TMP"
+ \rm "$TEMPFILE"
exit 1
fi
@@ -382,13 +382,13 @@
- \rm "$TMP"
+ \rm "$TEMPFILE"
exit 1
fi
if [ `wc -c < "$CAPABILITIES_FILE"` -eq 0 ] ; then
g.message -e "Downloaded XML file was empty"
- \rm -f "$CAPABILITIES_FILE" "$TMP"
+ \rm -f "$CAPABILITIES_FILE" "$TEMPFILE"
exit 1
fi
@@ -402,7 +402,7 @@
-e "s/.*Layer\\/Abstract=/ |/" \
-e "s/.*Layer\\/Style\\/Name=/ STYLE: /" \
-e "s/.*Layer\\/Style\\/Title=/ Style title: /" \
- > "${TMP}capabilities.txt"
+ > "${TEMPFILE}capabilities.txt"
else : # xml2 is not available
g.message -w "The 'xml2' program was not found. Proceeding with internal XML parsing which may not be as reliable."
@@ -421,21 +421,21 @@
-e "s/<Title>\(.*\)<\/Title>/\t --\1 /" \
-e "s/<\/Title>//" \
-e "s/<\/*.*\/*\/*>//" \
fi
- if [ `wc -l < "${TMP}capabilities.txt"` -eq 0 ] ; then
+ if [ `wc -l < "${TEMPFILE}capabilities.txt"` -eq 0 ] ; then
g.message message=""
g.message -e "Parsing XML file"
g.message message="------------------------"
cat "$CAPABILITIES_FILE"
else
- cat "${TMP}capabilities.txt"
+ cat "${TEMPFILE}capabilities.txt"
fi
if [ -e "$CAPABILITIES_FILE" ] ; then
- \rm -f "${TMP}capabilities.txt" "$TMP"
+ \rm -f "${TEMPFILE}capabilities.txt" "$TEMPFILE"
if [ -n "$GIS_OPT_CAP_FILE" ] ; then
mv "$CAPABILITIES_FILE" "$GIS_OPT_CAP_FILE"
@@ -555,7 +555,7 @@
g.message "#################################"
cat "$FILES"
- \rm -f "${TMP}"*
exit 1
fi
@@ -592,6 +592,6 @@
g.message -v message="Map <${GIS_OPT_OUTPUT}> written"
# Clean up:
-\rm -f "${TMP}"*
+\rm -f "${TEMPFILE}"*
exit
Modified: grass/branches/develbranch_6/scripts/r.in.wms/wms.download
--- grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.in.wms/wms.download 2010-01-27 04:31:22 UTC (rev 40687)
@@ -64,8 +64,8 @@
g.message -d "[wms.download]"
exit 1
fi
@@ -92,7 +92,7 @@
exitprocedure()
- rm -f "${TMP}"*
exit 1
@@ -212,5 +212,5 @@
GetTiles
# Clean up:
-rm -f "${TMP}"*
Modified: grass/branches/develbranch_6/scripts/r.mask/r.mask
--- grass/branches/develbranch_6/scripts/r.mask/r.mask 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.mask/r.mask 2010-01-27 04:31:22 UTC (rev 40687)
@@ -58,11 +58,11 @@
fi
# temp file
-TMP="r_mask_$$"
+TEMPRAST="r_mask_$$"
cleanup()
- g.remove --q rast=$TMP
+ g.remove --q rast=$TEMPRAST
# what to do in case of user break:
@@ -113,9 +113,9 @@
fi
if [ "$GIS_FLAG_I" -eq 1 ]; then
- g.rename --q rast=MASK,$TMP
- r.mapcalc "MASK=if(isnull($TMP),1,null())"
+ g.rename --q rast=MASK,$TEMPRAST
+ r.mapcalc "MASK=if(isnull($TEMPRAST),1,null())"
g.message "Inverted MASK created. All subsequent raster operations"
else
g.message "MASK created. All subsequent raster operations"
Modified: grass/branches/develbranch_6/scripts/r.plane/r.plane
--- grass/branches/develbranch_6/scripts/r.plane/r.plane 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.plane/r.plane 2010-01-27 04:31:22 UTC (rev 40687)
@@ -86,14 +86,14 @@
fi
g.message -e "unable to create temporary files"
exit 1
fi
#### trap ctrl-c so that we can clean up tmp
-trap 'rm -f "$TMP"*' 2 3 15
+trap 'rm -f "$TEMPFILE"*' 2 3 15
# setting environment, so that awk works properly in all languages
unset LC_ALL
@@ -180,7 +180,7 @@
### now the actual algorithm in awk (stored in a temporary file) ###
-cat > "$TMP" << EOF
+cat > "$TEMPFILE" << EOF
if (NR==1) {
@@ -246,13 +246,13 @@
### execute awk and remove temporary file ###
-awk -f "$TMP" -v east=$e west=$w north=$n south=$s ea=$ea no=$no typeflag=$typeflag \
- nsres=$nsres ewres=$ewres dip=$dip az=$az el=$el "$TMP" > "$TMP".2
+awk -f "$TEMPFILE" -v east=$e west=$w north=$n south=$s ea=$ea no=$no typeflag=$typeflag \
+ nsres=$nsres ewres=$ewres dip=$dip az=$az el=$el "$TEMPFILE" > "$TEMPFILE".2
-rm -f "$TMP"
+rm -f "$TEMPFILE"
g.message "Running r.in.ascii, please stand by.."
-r.in.ascii `echo $typeflag` i="$TMP".2 o=$name
+r.in.ascii `echo $typeflag` i="$TEMPFILE".2 o=$name
r.support $name hist="$PROG name=$name dip=$dip azimuth=$az easting=$ea \\"
r.support $name hist="northing=$no elevation=$el type=$type"
@@ -263,5 +263,5 @@
aspect=$az degrees ccw from north."
#echo "$dat, user: $user"
-rm -f "$TMP".2
+rm -f "$TEMPFILE".2
Modified: grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line
--- grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line 2010-01-27 04:31:22 UTC (rev 40687)
@@ -86,8 +86,8 @@
exit 1
fi
exit 1
fi
@@ -96,13 +96,13 @@
#calculate regression equation
if [ $GIS_FLAG_S -eq 1 ] ; then
# slower but accurate
- r.stats -n1 input=$GIS_OPT_MAP1,$GIS_OPT_MAP2 | sed 's+$+ 1+g' > "$TMP"
+ r.stats -n1 input=$GIS_OPT_MAP1,$GIS_OPT_MAP2 | sed 's+$+ 1+g' > "$TEMPFILE"
else
# count "identical" pixels
- r.stats -cnA input=$GIS_OPT_MAP1,$GIS_OPT_MAP2 > "$TMP"
+ r.stats -cnA input=$GIS_OPT_MAP1,$GIS_OPT_MAP2 > "$TEMPFILE"
fi
-if [ ! -s "$TMP" ] ; then
+if [ ! -s "$TEMPFILE" ] ; then
g.message -e "One or both input maps only contain no data (NULL) pixels in the current region"
exit 1
fi
@@ -115,16 +115,16 @@
mediaX=sumX/tot;sumsqX=sumsqX/tot;varX=sumsqX-(mediaX^2);sdX=varX^0.5;\
mediaY=sumY/tot;sumsqY=sumsqY/tot;varY=sumsqY-(mediaY^2);sdY=varY^0.5;\
A=mediaY - B*mediaX; F= R^2/(1-R^2/tot-2);\
-print A, B, R, tot, F, mediaX, sdX, mediaY, sdY}' "$TMP" > "$TMP"b
+print A, B, R, tot, F, mediaX, sdX, mediaY, sdY}' "$TEMPFILE" > "$TEMPFILE"b
-echo "a b R N F medX sdX medY sdY" | tr -s ' ' '\n' > "$TMP"d
-cat "$TMP"b | tr -s ' ' '\n' > "$TMP"e
+echo "a b R N F medX sdX medY sdY" | tr -s ' ' '\n' > "$TEMPFILE"d
+cat "$TEMPFILE"b | tr -s ' ' '\n' > "$TEMPFILE"e
#send output to screen or text file
if [ -z "$GIS_OPT_OUTPUT" ]
then
if [ $GIS_FLAG_G -eq 1 ] ; then
- paste -d'=' "$TMP"d "$TMP"e
+ paste -d'=' "$TEMPFILE"d "$TEMPFILE"e
else
echo "y = a + b*x"
echo " a: offset"
@@ -134,24 +134,24 @@
echo " medX, medY: Means"
echo " sdX, sdY: Standard deviations"
- RESULTADO=`cat "$TMP"b`
+ RESULTADO=`cat "$TEMPFILE"b`
echo ${RESULTADO}
fi
else
- paste -d'=' "$TMP"d "$TMP"e >> "$TMP"c
+ paste -d'=' "$TEMPFILE"d "$TEMPFILE"e >> "$TEMPFILE"c
else
- echo "y = a + b*x" > "$TMP"c
- echo " a: offset" >> "$TMP"c
- echo " b: gain" >> "$TMP"c
- echo " R: sumXY - sumX*sumY/tot" >> "$TMP"c
- echo " N: number of elements" >> "$TMP"c
- echo " medX, medY: Means" >> "$TMP"c
- echo " sdX, sdY: Standard deviations" >> "$TMP"c
- echo "a b R N F medX sdX medY sdY" >> "$TMP"c
- cat "$TMP"b >> "$TMP"c
+ echo "y = a + b*x" > "$TEMPFILE"c
+ echo " a: offset" >> "$TEMPFILE"c
+ echo " b: gain" >> "$TEMPFILE"c
+ echo " R: sumXY - sumX*sumY/tot" >> "$TEMPFILE"c
+ echo " N: number of elements" >> "$TEMPFILE"c
+ echo " medX, medY: Means" >> "$TEMPFILE"c
+ echo " sdX, sdY: Standard deviations" >> "$TEMPFILE"c
+ echo "a b R N F medX sdX medY sdY" >> "$TEMPFILE"c
+ cat "$TEMPFILE"b >> "$TEMPFILE"c
fi
- mv "$TMP"c "$GIS_OPT_OUTPUT"
+ mv "$TEMPFILE"c "$GIS_OPT_OUTPUT"
cat "$GIS_OPT_OUTPUT"
fi
-rm -f "$TMP" "$TMP"b "$TMP"c "$TMP"d "$TMP"e
+rm -f "$TEMPFILE" "$TEMPFILE"b "$TEMPFILE"c "$TEMPFILE"d "$TEMPFILE"e
Modified: grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh
--- grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh 2010-01-27 04:15:08 UTC (rev 40686)
+++ grass/branches/develbranch_6/scripts/r.univar.sh/r.univar.sh 2010-01-27 04:31:22 UTC (rev 40687)
@@ -65,8 +65,8 @@
COVER="$GIS_OPT_MAP"
exit 1
fi
@@ -74,7 +74,7 @@
cleanup()
- \rm -f "$TMP" "$TMP.sort"
+ \rm -f "$TEMPFILE" "$TEMPFILE.sort"
@@ -89,10 +89,10 @@
g.message "Calculation for map $COVER (ignoring NULL cells)..."
g.message "Reading raster map..."
-r.stats -1n input=$COVER > "$TMP"
+r.stats -1n input=$COVER > "$TEMPFILE"
#check if map contains only NULL's in current region
-LINES=`wc -l "$TMP" | awk '{print $1}'`
+LINES=`wc -l "$TEMPFILE" | awk '{print $1}'`
if [ "$LINES" -eq 0 ] ; then
g.message -e "Map $COVER contains only NULL data in current region."
cleanup
@@ -101,7 +101,7 @@
# calculate statistics
g.message "Calculating statistics..."
-cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
+cat "$TEMPFILE" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
function abs(x){return x < 0 ? -x : x}
NR == 1{min = $1 ; max = $1}
{sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++}
@@ -124,14 +124,14 @@
if [ $GIS_FLAG_E -eq 1 ] ; then
#preparations:
- cat "$TMP" | sort -n > "$TMP.sort"
- NUMBER=`cat "$TMP.sort" | wc -l | awk '{print $1}'`
+ cat "$TEMPFILE" | sort -n > "$TEMPFILE.sort"
+ NUMBER=`cat "$TEMPFILE.sort" | wc -l | awk '{print $1}'`
ODDEVEN=`echo $NUMBER | awk '{print $1%2}'`
# 0.25 quartile
QUARTILE=0.25
QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2 + 0.5}'`
- QELEMENT=`head -n $QPOS "$TMP.sort" | tail -n 1`
+ QELEMENT=`head -n $QPOS "$TEMPFILE.sort" | tail -n 1`
echo "1st Quartile: $QELEMENT"
#Calculate median
@@ -141,13 +141,13 @@
EVENMEDIANNUMBER=`expr $NUMBER / 2`
EVENMEDIANNUMBERPLUSONE=`expr $EVENMEDIANNUMBER + 1`
# select two numbers
- SELECTEDNUMBERS=`cat "$TMP.sort" | head -n "$EVENMEDIANNUMBERPLUSONE" | tail -n 2`
+ SELECTEDNUMBERS=`cat "$TEMPFILE.sort" | head -n "$EVENMEDIANNUMBERPLUSONE" | tail -n 2`
RESULTEVENMEDIAN=`echo $SELECTEDNUMBERS | awk '{printf "%f", ($1 + $2)/2.0}'`
echo "Median (even N): $RESULTEVENMEDIAN"
else
# odd
ODDMEDIANNUMBER=`echo $NUMBER | awk '{printf "%d", int($1/2+.5)}'`
- RESULTODDMEDIAN=`cat "$TMP.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
+ RESULTODDMEDIAN=`cat "$TEMPFILE.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
echo "Median (odd N): $RESULTODDMEDIAN"
fi
@@ -155,13 +155,13 @@
# 0.75 quartile
QUARTILE=0.75
echo "3rd Quartile: $QELEMENT"
# XX percentile
QUARTILE=$GIS_OPT_PERCENTILE
QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2/100. + 0.5}'`
- QELEMENT=`head -n $QPOS "$TMP.sort" | tail -1`
+ QELEMENT=`head -n $QPOS "$TEMPFILE.sort" | tail -1`
echo "${GIS_OPT_PERCENTILE} Percentile: $QELEMENT"
fi
