[GRASS-SVN] r40689 - in grass/branches/develbranch_6/scripts:
v.colors v.db.dropcol v.db.renamecol v.db.univar
svn_grass at osgeo.org
Tue Jan 26 23:48:44 EST 2010
Author: hamish
Date: 2010-01-26 23:48:40 -0500 (Tue, 26 Jan 2010)
New Revision: 40689
grass/branches/develbranch_6/scripts/v.colors/v.colors
grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar
rename TMP variable to avoid namespace collision on MS Windows (trac #890)
Modified: grass/branches/develbranch_6/scripts/v.colors/v.colors
--- grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-01-27 04:38:47 UTC (rev 40688)
+++ grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-01-27 04:48:40 UTC (rev 40689)
@@ -117,8 +117,8 @@
cleanup()
- if [ -n "$TMP" ] ; then
- \rm "$TMP" "${TMP}_vcol.sql"
+ if [ -n "$TEMPFILE" ] ; then
+ \rm "$TEMPFILE" "${TEMPFILE}_vcol.sql"
fi
eval `g.findfile elem=windows file="tmp_vcolors.$$" | grep '^name='`
if [ -n "$name" ] ; then
@@ -278,8 +278,8 @@
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "${TMP}" ] ; then
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
g.message -e "Unable to create temporary file"
cleanup
exit 1
@@ -295,21 +295,21 @@
#g.message message="LINE=[$LINE]"
VALUE=`echo $LINE | cut -f1 -d'|'`
COLR=`echo $LINE | cut -f2 -d'|'`
- echo "UPDATE $TABLE SET $GIS_OPT_RGB_COLUMN = '$COLR' WHERE $GIS_OPT_COLUMN = $VALUE;" >> "${TMP}_vcol.sql"
+ echo "UPDATE $TABLE SET $GIS_OPT_RGB_COLUMN = '$COLR' WHERE $GIS_OPT_COLUMN = $VALUE;" >> "${TEMPFILE}_vcol.sql"
done )
-if [ ! -e "${TMP}_vcol.sql" ] ; then
+if [ ! -e "${TEMPFILE}_vcol.sql" ] ; then
g.message -e "No values found in color range"
cleanup
exit 1
fi
# apply SQL commands to update the table with values
-NUM_RULES=`wc -l < "${TMP}_vcol.sql"`
+NUM_RULES=`wc -l < "${TEMPFILE}_vcol.sql"`
g.message "Writing $NUM_RULES colors ..."
-#less "$TMP"
-db.execute input="${TMP}_vcol.sql"
+#less "$TEMPFILE"
+db.execute input="${TEMPFILE}_vcol.sql"
if [ $? -ne 0 ] ; then
g.message -e "Processing SQL transaction"
cleanup
Modified: grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol
--- grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2010-01-27 04:38:47 UTC (rev 40688)
+++ grass/branches/develbranch_6/scripts/v.db.dropcol/v.db.dropcol 2010-01-27 04:48:40 UTC (rev 40689)
@@ -67,15 +67,15 @@
PROG=`basename $0`
#### setup temporary file
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
g.message -e 'Unable to create temporary files'
exit 1
fi
cleanup()
- \rm -f "$TMP" "$TMP.coltypes" "$TMP.colnames" "$TMP.coldesc"
+ \rm -f "$TEMPFILE" "$TEMPFILE.coltypes" "$TEMPFILE.colnames" "$TEMPFILE.coldesc"
# what to do in case of user break:
@@ -127,12 +127,12 @@
if [ "$driver" = "sqlite" ] ; then
#echo "Using special trick for SQLite"
# http://www.sqlite.org/faq.html#q13
- v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep -v "|${col}$" > "$TMP.coldesc"
+ v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep -v "|${col}$" > "$TEMPFILE.coldesc"
# need to revert order:
- cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
- cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
- COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n' ',' | sed 's+,$++g'`
- COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
+ cat "$TEMPFILE.coldesc" | cut -d'|' -f1 > "$TEMPFILE.coltypes"
+ cat "$TEMPFILE.coldesc" | cut -d'|' -f2 > "$TEMPFILE.colnames"
+ COLDEF=`paste -d' ' "$TEMPFILE.colnames" "$TEMPFILE.coltypes" | tr '\n' ',' | sed 's+,$++g'`
+ COLNAMES=`cat "$TEMPFILE.colnames" | tr '\n' ',' | sed 's+,$++g'`
echo "BEGIN TRANSACTION;
CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
@@ -140,8 +140,8 @@
CREATE TABLE ${table}(${COLDEF});
INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
DROP TABLE ${table}_backup;
-COMMIT;" > "$TMP"
- db.execute input="$TMP"
+COMMIT;" > "$TEMPFILE"
+ db.execute input="$TEMPFILE"
if [ $? -eq 1 ] ; then
g.message -e 'Cannot continue (problem deleting column)'
cleanup
Modified: grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol
--- grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2010-01-27 04:38:47 UTC (rev 40688)
+++ grass/branches/develbranch_6/scripts/v.db.renamecol/v.db.renamecol 2010-01-27 04:48:40 UTC (rev 40689)
@@ -63,33 +63,20 @@
PROG=`basename $0`
-#### setup temporary file
- g.message -e 'Unable to create temporary files'
- exit 1
-fi
-cleanup()
exitprocedure()
- g.message -e 'User break!'
- cleanup
- exit 1
+ g.message -e 'User break!'
+ exit 1
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
error()
- g.message -e 'Cannot continue (problem renaming column)'
- cleanup
- exit 1
+ g.message -e 'Cannot continue (problem renaming column)'
+ exit 1
### setup enviro vars ###
@@ -105,7 +92,6 @@
table="`v.db.connect -g map="$GIS_OPT_MAP" fs=";" | grep -w "^$GIS_OPT_LAYER" | cut -f2 -d';'`"
if [ -z "$table" ] ; then
g.message -e 'There is no table connected to the input vector map! Cannot rename any column'
- cleanup
exit 1
fi
@@ -122,7 +108,6 @@
if [ "$NAMELEN" -gt 11 ] ; then
g.message -e "Column name <$newcol> too long. The DBF driver supports column names\
not longer than 10 characters"
- cleanup
exit 1
fi
fi
@@ -130,16 +115,14 @@
if [ "$oldcol" = "$keycol" ] ; then
g.message -e "Cannot rename column <$oldcol> as it is needed to keep table <$table>\
connected to the input vector map"
- cleanup
exit 1
fi
# old col there?
v.info --quiet -c map="$GIS_OPT_MAP" layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep "|${oldcol}$" 2>&1 >/dev/null
- g.message -e "Column <$oldcol> not found in table"
- cleanup
- exit 1
+ g.message -e "Column <$oldcol> not found in table"
+ exit 1
fi
# describe old col
@@ -160,8 +143,6 @@
echo "ALTER TABLE $table RENAME $oldcol TO $newcol" | db.execute database="${database}" driver=${driver} || error
fi
-# cleanup
-cleanup
# write cmd history:
v.support map="${GIS_OPT_MAP}" cmdhist="${CMDLINE}"
Modified: grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar
--- grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar 2010-01-27 04:38:47 UTC (rev 40688)
+++ grass/branches/develbranch_6/scripts/v.db.univar/v.db.univar 2010-01-27 04:48:40 UTC (rev 40689)
@@ -77,15 +77,15 @@
export LC_NUMERIC
g.message -e "Unable to create temporary files"
exit 1
fi
cleanup()
- \rm -f "$TMP" "$TMP.sort"
+ \rm -f "$TEMPFILE" "$TEMPFILE.sort"
@@ -115,9 +115,9 @@
fi
if [ -z "$GIS_OPT_WHERE" ] ; then
- db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
+ db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TEMPFILE"
else
- db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
+ db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TEMPFILE"
fi
@@ -130,7 +130,7 @@
#echo ""
#check if map contains only NULL's in current region
-LINES=`wc -l "$TMP" | awk '{print $1}'`
+LINES=`wc -l "$TEMPFILE" | awk '{print $1}'`
if [ "$LINES" -eq 0 ] ; then
g.message -e "Table $GIS_OPT_TABLE contains no data."
cleanup
@@ -139,7 +139,7 @@
# calculate statistics
g.message "Calculating statistics..."
-cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
+cat "$TEMPFILE" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
function abs(x){return x < 0 ? -x : x}
(NF>0) {
sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++;
@@ -167,14 +167,14 @@
if [ $GIS_FLAG_E -eq 1 ] ; then
#preparations:
- cat "$TMP" | sort -n > "$TMP.sort"
- NUMBER=`cat "$TMP.sort" | wc -l | awk '{print $1}'`
+ cat "$TEMPFILE" | sort -n > "$TEMPFILE.sort"
+ NUMBER=`cat "$TEMPFILE.sort" | wc -l | awk '{print $1}'`
ODDEVEN=`echo $NUMBER | awk '{print $1%2}'`
# 0.25 quartile
QUARTILE=0.25
QPOS=`echo $NUMBER $QUARTILE | awk '{printf "%d", $1 * $2 + 0.5}'`
- QELEMENT=`head -n $QPOS "$TMP.sort" | tail -n 1`
+ QELEMENT=`head -n $QPOS "$TEMPFILE.sort" | tail -n 1`
echo "1st Quartile: $QELEMENT"
#Calculate median
@@ -184,13 +184,13 @@
EVENMEDIANNUMBER=`expr $NUMBER / 2`
EVENMEDIANNUMBERPLUSONE=`expr $EVENMEDIANNUMBER + 1`
# select two numbers
- SELECTEDNUMBERS=`cat "$TMP.sort" | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
+ SELECTEDNUMBERS=`cat "$TEMPFILE.sort" | head -n $EVENMEDIANNUMBERPLUSONE | tail -n 2`
RESULTEVENMEDIAN=`echo $SELECTEDNUMBERS | awk '{printf "%f", ($1 + $2)/2.0}'`
echo "Median (even N): $RESULTEVENMEDIAN"
else
# odd
ODDMEDIANNUMBER=`echo $NUMBER | awk '{printf "%d", int($1/2+.5)}'`
- RESULTODDMEDIAN=`cat "$TMP.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
+ RESULTODDMEDIAN=`cat "$TEMPFILE.sort" | head -n $ODDMEDIANNUMBER | tail -n 1 | awk '{printf "%f", $1}'`
echo "Median (odd N): $RESULTODDMEDIAN"
fi
@@ -198,13 +198,13 @@
# 0.75 quartile
QUARTILE=0.75
echo "3rd Quartile: $QELEMENT"
# 0.90 percentile
QUARTILE=0.9
echo "90th Percentile: $QELEMENT"
fi
