[GRASS-SVN] r40692 - in grass/branches/releasebranch_6_4: lib/init
mswindows
svn_grass at osgeo.org
Wed Jan 27 03:10:43 EST 2010
Author: hamish
Date: 2010-01-27 03:10:39 -0500 (Wed, 27 Jan 2010)
New Revision: 40692
grass/branches/releasebranch_6_4/lib/init/init.bat
grass/branches/releasebranch_6_4/lib/init/init.sh
grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi
another attempt at an improved MSys dos prompt (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/lib/init/init.bat
--- grass/branches/releasebranch_6_4/lib/init/init.bat 2010-01-27 08:07:34 UTC (rev 40691)
+++ grass/branches/releasebranch_6_4/lib/init/init.bat 2010-01-27 08:10:39 UTC (rev 40692)
@@ -45,9 +45,11 @@
set GRASS_PAGER=more
if "%GRASS_WISH%"=="" set GRASS_WISH=wish.exe
if "%GRASS_SH%"=="" set GRASS_SH=c:\msys\1.0\bin\sh.exe
rem Should do something with "assoc .html" and ftype here but would require
rem a new g.manual.bat too so leaving it like this for now...
if "%GRASS_HTML_BROWSER%"=="" set GRASS_HTML_BROWSER=%SYSTEMDRIVE%/PROGRA~1/INTERN~1/IEXPLORE.EXE
if "%GRASS_PROJSHARE%"=="" set GRASS_PROJSHARE=CONFIG_PROJSHARE
rem Add python scripts to the PATHEXT variable
Modified: grass/branches/releasebranch_6_4/lib/init/init.sh
--- grass/branches/releasebranch_6_4/lib/init/init.sh 2010-01-27 08:07:34 UTC (rev 40691)
+++ grass/branches/releasebranch_6_4/lib/init/init.sh 2010-01-27 08:10:39 UTC (rev 40692)
@@ -975,16 +975,19 @@
+ if [ "$MINGW" ] ; then
+ GRASS_BASE_VERSION=`echo "$GRASS_VERSION" | cut -f1,2 -d.`
+ PS1="GRASS $GRASS_BASE_VERSION> "
+ export PS1
- PS1="GRASS $GRASS_VERSION ($LOCATION_NAME):\w > "
- export PS1
- if [ "$MINGW" ] ; then
# "$ETC/run" doesn't work at all???
- "$SHELL"
+ "$SHELL"
rm -rf "$LOCATION/.tmp"/* # remove gis.m session files from .tmp
else
- "$ETC/run" "$SHELL"
+ PS1="GRASS $GRASS_VERSION ($LOCATION_NAME):\w > "
+ export PS1
+ "$ETC/run" "$SHELL"
EXIT_VAL=$?
fi
Modified: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi 2010-01-27 08:07:34 UTC (rev 40691)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi 2010-01-27 08:10:39 UTC (rev 40692)
@@ -663,8 +663,6 @@
FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
FileWrite $0 '$\r$\n'
- FileWrite $0 'export PS1="GRASS 6.4> "$\r$\n'
- FileWrite $0 '$\r$\n'
FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
FileClose $0
done_create_grass_command:
