[GRASS-SVN] r40706 - in grass/trunk: general/g.mlist general/g.mremove include include/Make lib/gis
Wed Jan 27 17:58:17 EST 2010
Author: glynn
Date: 2010-01-27 17:58:16 -0500 (Wed, 27 Jan 2010)
New Revision: 40706
Added:
   grass/trunk/lib/gis/ls_filter.c
Removed:
   grass/trunk/general/g.mlist/global.h
   grass/trunk/general/g.mlist/wc2regex.c
   grass/trunk/general/g.mremove/global.h
   grass/trunk/general/g.mremove/wc2regex.c
   grass/trunk/general/g.mlist/Makefile
   grass/trunk/general/g.mlist/main.c
   grass/trunk/general/g.mremove/Makefile
   grass/trunk/general/g.mremove/check_reclass.c
   grass/trunk/general/g.mremove/main.c
   grass/trunk/include/Make/Grass.make
   grass/trunk/include/gisdefs.h
   grass/trunk/lib/gis/Makefile
Move regex/glob G__ls() filters into lib/gis
More accurate emulation of glob patterns
Modified: grass/trunk/general/g.mlist/Makefile
--- grass/trunk/general/g.mlist/Makefile	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mlist/Makefile	2010-01-27 22:58:16 UTC (rev 40706)
@@ -2,8 +2,7 @@
 PGM = g.mlist
-EXTRA_INC = $(REGEXINCPATH)
-LIBES = $(MANAGELIB) $(GISLIB) $(REGEXLIBPATH) $(REGEXLIB)
+LIBES = $(MANAGELIB) $(GISLIB)
 DEPENDENCIES = $(MANAGEDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Deleted: grass/trunk/general/g.mlist/global.h
--- grass/trunk/general/g.mlist/global.h	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mlist/global.h	2010-01-27 22:58:16 UTC (rev 40706)
@@ -1,7 +0,0 @@
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/list.h>
-/* wc2regex.c */
-char *wc2regex(const char *);
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mlist/main.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -9,7 +9,7 @@
  * PURPOSE:      Lists available GRASS data base files of the
  *               user-specified data type to standard output
- * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,10 +20,10 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include <string.h>
-#include <regex.h>
-#include <grass/spawn.h>
+#include <grass/gis.h>
-#include "global.h"
+#include <grass/glocale.h>
+#include <grass/spawn.h>
 static int any = 0;
@@ -31,7 +31,6 @@
 		      const char *, const char *,
 		      int, int, int);
 static int parse(const char *);
-static int ls_filter(const char *, void *);
 int main(int argc, char *argv[])
@@ -54,10 +53,9 @@
 	struct Flag *full;
     } flag;
     int i, n, all, num_types;
-    char *pattern = NULL, *exclude = NULL;
+    void *filter = NULL, *exclude = NULL;
     const char *mapset;
     char separator[2], *buf;
-    regex_t regex, regex_ex;
     G_gisinit(argv[0]);
@@ -157,24 +155,16 @@
     if (opt.pattern->answer) {
 	if (flag.regex->answer || flag.extended->answer)
-	    pattern = G_store(opt.pattern->answer);
+	    filter = G_ls_regex_filter(opt.pattern->answer, 0, (int) flag.extended->answer);
 	else
-	    pattern = wc2regex(opt.pattern->answer);
-	if (regcomp(&regex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
-	    G_fatal_error(_("Unable to compile regular expression %s"), pattern);
-	G_set_ls_filter(ls_filter, &regex);
+	    filter = G_ls_glob_filter(opt.pattern->answer, 0);
     if (opt.exclude->answer) {
-	    exclude = G_store(opt.exclude->answer);
+	    exclude = G_ls_regex_filter(opt.pattern->answer, 1, (int) flag.extended->answer);
 	else
-	    exclude = wc2regex(opt.exclude->answer);
-	if (regcomp(&regex_ex, exclude, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
-	    G_fatal_error(_("Unable to compile regular expression %s"), exclude);
-	G_set_ls_exclude_filter(ls_filter, &regex_ex);
+	    exclude = G_ls_glob_filter(opt.pattern->answer, 1);
     if (strcmp(opt.separator->answer, "newline") == 0)
@@ -235,15 +225,11 @@
     if (!flag.pretty->answer && any)
 	fprintf(stdout, "\n");
-    if (pattern) {
-	G_free(pattern);
-	regfree(&regex);
+    if (filter)
+	G_free_ls_filter(filter);
-    if (exclude) {
-	G_free(exclude);
-	regfree(&regex_ex);
+    if (exclude)
+	G_free_ls_filter(exclude);
     exit(EXIT_SUCCESS);
@@ -315,8 +301,3 @@
     return n;
-static int ls_filter(const char *filename, void *closure)
-    return filename[0] != '.' &&
-	regexec((regex_t *) closure, filename, 0, NULL, 0) == 0;
Deleted: grass/trunk/general/g.mlist/wc2regex.c
--- grass/trunk/general/g.mlist/wc2regex.c	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mlist/wc2regex.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -1,46 +0,0 @@
-char *wc2regex(const char *wc)
-    int i, j;
-    char *regex;
-    for (i = 0, j = 2; wc[i]; i++, j++) {
-	switch (wc[i]) {
-	case '.':
-	case '*':
-	    j++;
-	    break;
-    regex = (char *)G_malloc(j + 1);
-    j = 0;
-    regex[j++] = '^';
-    for (i = 0; wc[i]; i++) {
-	switch (wc[i]) {
-	case '.':
-	    regex[j++] = '\\';
-	    break;
-	case '*':
-	    regex[j++] = '.';
-	    break;
-	case '?':
-	    regex[j++] = '.';
-	    continue;
-	case '{':
-	    regex[j++] = '(';
-	    continue;
-	case '}':
-	    regex[j++] = ')';
-	    continue;
-	case ',':
-	    regex[j++] = '|';
-	    continue;
-	regex[j++] = wc[i];
-    regex[j++] = '$';
-    regex[j] = 0;
-    return regex;
Modified: grass/trunk/general/g.mremove/Makefile
--- grass/trunk/general/g.mremove/Makefile	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mremove/Makefile	2010-01-27 22:58:16 UTC (rev 40706)
@@ -2,9 +2,9 @@
 PGM = g.mremove
-LIBES = $(MANAGELIB) $(RASTERLIB) $(GISLIB) $(REGEXLIBPATH) $(REGEXLIB)
+LIBES = $(MANAGELIB) $(RASTERLIB) $(GISLIB)
 DEPENDENCIES = $(MANAGEDEP) $(RASTERDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC) $(REGEXINCPATH)
+EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/general/g.mremove/check_reclass.c
--- grass/trunk/general/g.mremove/check_reclass.c	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mremove/check_reclass.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -1,9 +1,10 @@
 #include <string.h>
+#include <grass/list.h>
 #include <grass/raster.h>
 int check_reclass(const char *name, const char *mapset, int force)
     char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
Deleted: grass/trunk/general/g.mremove/global.h
--- grass/trunk/general/g.mremove/global.h	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mremove/global.h	2010-01-27 22:58:16 UTC (rev 40706)
@@ -1,9 +0,0 @@
-/* wc2regex.c */
-/* check_reclass.c */
-int check_reclass(const char *, const char *, int);
Modified: grass/trunk/general/g.mremove/main.c
--- grass/trunk/general/g.mremove/main.c	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mremove/main.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -17,7 +17,7 @@
  * PURPOSE:      lets users remove GRASS database files
@@ -27,11 +27,14 @@
 #include <stdlib.h>
 #include <unistd.h>
-#include <regex.h>
+/* check_reclass.c */
+int check_reclass(const char *, const char *, int);
     struct GModule *module;
@@ -48,7 +51,7 @@
     char *buf, *buf2;
     int num_files, rast, result = EXIT_SUCCESS;
     int i, j, n;
-    regex_t regex;
+    void *filter;
     G_gisinit(argv[0]);
@@ -122,19 +125,18 @@
 	    rast = !G_strcasecmp(list[n].alias, "rast");
 	    for (i = 0; (name = opt[n]->answers[i]); i++) {
 		if (!flag.regex->answer && !flag.extended->answer)
-		    name = wc2regex(name);
-		if (regcomp(&regex, name,
-			    (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
-		    G_fatal_error(
-				  _("Unable to compile regular expression %s"),
+		    filter = G_ls_glob_filter(name, 0);
+		else
+		    filter = G_ls_regex_filter(name, 0,
+					       (int) flag.extended->answer);
+		if (!filter)
+		    G_fatal_error(_("Unable to compile pattern <%s>"),
 				  name);
-		if (!flag.regex->answer && !flag.extended->answer)
-		    G_free(name);
 		files = G__ls(path, &num_files);
-		regfree(&regex);
 		for (j = 0; j < num_files; j++) {
 		    if (!flag.force->answer) {
 			fprintf(stdout, "%s/%s@%s\n", list[n].alias, files[j],
@@ -160,8 +162,3 @@
     exit(result);
Deleted: grass/trunk/general/g.mremove/wc2regex.c
--- grass/trunk/general/g.mremove/wc2regex.c	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/general/g.mremove/wc2regex.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -1,46 +0,0 @@
-    int i, j;
-    char *regex;
-	switch (wc[i]) {
-	case '.':
-	case '*':
-	    j++;
-	    break;
-    j = 0;
-    regex[j++] = '^';
-	switch (wc[i]) {
-	case '.':
-	    break;
-	case '*':
-	    regex[j++] = '.';
-	    break;
-	case '?':
-	    regex[j++] = '.';
-	    continue;
-	case '{':
-	    regex[j++] = '(';
-	    continue;
-	case '}':
-	    regex[j++] = ')';
-	    continue;
-	case ',':
-	    regex[j++] = '|';
-	    continue;
-    regex[j++] = '$';
-    regex[j] = 0;
-    return regex;
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/include/Make/Grass.make	2010-01-27 22:58:16 UTC (rev 40706)
@@ -190,7 +190,7 @@
 DSPFDEPS         = $(GISLIB)
 FORMDEPS         = $(DBMILIB) $(GISLIB)
 G3DDEPS          = $(RASTERLIB) $(GISLIB) $(XDRLIB)
-GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(INTLLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
+GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(INTLLIB) $(REGEXLIBPATH) $(REGEXLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
 GMATHDEPS        = $(GISLIB) $(FFTWLIB) $(LAPACKLIB) $(BLASLIB) $(CCMATHLIB)
 GPDEDEPS         = $(G3DLIB) $(RASTERLIB) $(GISLIB) $(GMATHLIB) $(MATHLIB)
 GPROJDEPS        = $(GISLIB) $(GDALLIBS) $(PROJLIB) $(MATHLIB)
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/include/gisdefs.h	2010-01-27 22:58:16 UTC (rev 40706)
@@ -366,6 +366,13 @@
 void G_ls(const char *, FILE *);
 void G_ls_format(char **, int, int, FILE *);
+/* ls_filter.c */
+#ifdef HAVE_REGEX_H
+void *G_ls_regex_filter(const char *, int, int);
+void *G_ls_glob_filter(const char *, int);
+void G_free_ls_filter(void *);
+#endif
 /* mach_name.c */
 const char *G__machine_name(void);
Modified: grass/trunk/lib/gis/Makefile
--- grass/trunk/lib/gis/Makefile	2010-01-27 22:52:58 UTC (rev 40705)
+++ grass/trunk/lib/gis/Makefile	2010-01-27 22:58:16 UTC (rev 40706)
@@ -2,7 +2,7 @@
 LIB = GIS
-EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
+EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH) $(REGEXINCPATH)
 DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections
Added: grass/trunk/lib/gis/ls_filter.c
--- grass/trunk/lib/gis/ls_filter.c	                        (rev 0)
+++ grass/trunk/lib/gis/ls_filter.c	2010-01-27 22:58:16 UTC (rev 40706)
@@ -0,0 +1,195 @@
+ * \file gis/ls_filter.c
+ * \brief GIS Library - Filename filter functions
+ * (C) 2010 by Glynn Clements and the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author Glynn Clements
+#include <grass/config.h>
+#include <regex.h>
+struct buffer
+    char *buf;
+    size_t len;
+    size_t alloc;
+static void init(struct buffer *buf)
+    buf->buf = NULL;
+    buf->len = 0;
+    buf->alloc = 0;
+static void add(struct buffer *buf, char c)
+    if (buf->len >= buf->alloc) {
+	buf->alloc += 50;
+	buf->buf = G_realloc(buf->buf, buf->alloc);
+    buf->buf[buf->len++] = c;
+static void fini(struct buffer *buf)
+    G_free(buf->buf);
+static const char *do_set(struct buffer *buf, const char *p)
+    add(buf, '[');
+    if (*p == '!') {
+	add(buf, '^');
+	p++;
+    if (*p == ']') {
+	add(buf, ']');
+	p++;
+    for (; *p && *p != ']'; p++)
+	add(buf, *p);
+    if (!*p)
+	return NULL;
+    add(buf, ']');
+    return p;
+static int wc2regex(struct buffer *buf, const char *pat)
+    const char *p;
+    int in_brace = 0;
+    init(buf);
+    add(buf, '^');
+    for (p = pat; p && *p; p++) {
+	switch (*p) {
+	case '\\':
+	case '.':
+	case '|':
+	case '(':
+	case ')':
+	case '+':
+	    add(buf, '\\');
+	    add(buf, *p);
+	    break;
+	case '*':
+	    add(buf, '.');
+	    add(buf, '*');
+	    break;
+	case '?':
+	    add(buf, '.');
+	    break;
+	case '{':
+	    if (in_brace)
+		return 0;
+	    in_brace = 1;
+	    add(buf, '(');
+	    break;
+	case '}':
+	    if (!in_brace)
+		return 0;
+	    in_brace = 0;
+	    add(buf, ')');
+	    break;
+	case ',':
+	    if (in_brace)
+		add(buf, '|');
+	    else
+		add(buf, ',');
+	    break;
+	case '[':
+	    p = do_set(buf, p);
+	    break;
+	default:
+	    add(buf, *p);
+	    break;
+    if (!p)
+	return 0;
+    if (in_brace)
+	return 0;
+    add(buf, '$');
+    add(buf, '\0');
+    return 1;
+static int re_filter(const char *filename, void *closure)
+    regex_t *regex = closure;
+    return filename[0] != '.' &&
+	regexec(regex, filename, 0, NULL, 0) == 0;
+void *G_ls_regex_filter(const char *pat, int exclude, int extended)
+    regex_t *regex = G_malloc(sizeof(regex_t));
+    if (regcomp(regex, pat, (extended ? REG_EXTENDED : 0) | REG_NOSUB) != 0) {
+	G_free(regex);
+	return NULL;
+    if (exclude)
+	G_set_ls_exclude_filter(re_filter, regex);
+    else
+	G_set_ls_filter(re_filter, regex);
+    return regex;
+void *G_ls_glob_filter(const char *pat, int exclude)
+    struct buffer buf;
+    regex_t *regex;
+    init(&buf);
+    if (!wc2regex(&buf, pat)) {
+	fini(&buf);
+	return NULL;
+    regex = G_ls_regex_filter(buf.buf, exclude, 1);
+    fini(&buf);
+    return regex;
+void G_free_ls_filter(void *regex)
+    if (!regex)
+	return;
+    regfree(regex);
+    G_free(regex);
+#endif
