[GRASS-SVN] r40744 - grass-addons/postscript/ps.output
Sat Jan 30 10:50:20 EST 2010
Author: ejtizado
Date: 2010-01-30 10:50:19 -0500 (Sat, 30 Jan 2010)
New Revision: 40744
   grass-addons/postscript/ps.output/Makefile
   grass-addons/postscript/ps.output/cat_val.c
   grass-addons/postscript/ps.output/colors.c
   grass-addons/postscript/ps.output/description.html
   grass-addons/postscript/ps.output/draws.h
   grass-addons/postscript/ps.output/eps.c
   grass-addons/postscript/ps.output/fonts.c
   grass-addons/postscript/ps.output/frames.c
   grass-addons/postscript/ps.output/frames.h
   grass-addons/postscript/ps.output/grids.h
   grass-addons/postscript/ps.output/input.c
   grass-addons/postscript/ps.output/legends.c
   grass-addons/postscript/ps.output/legends.h
   grass-addons/postscript/ps.output/lines.c
   grass-addons/postscript/ps.output/lines.h
   grass-addons/postscript/ps.output/load_raster.c
   grass-addons/postscript/ps.output/local_proto.h
   grass-addons/postscript/ps.output/main.c
   grass-addons/postscript/ps.output/notes.h
   grass-addons/postscript/ps.output/palettes.c
   grass-addons/postscript/ps.output/palettes.h
   grass-addons/postscript/ps.output/papers.c
   grass-addons/postscript/ps.output/papers.h
   grass-addons/postscript/ps.output/proj_geo.c
   grass-addons/postscript/ps.output/ps3_map.c
   grass-addons/postscript/ps.output/ps_info.h
   grass-addons/postscript/ps.output/r_draw.c
   grass-addons/postscript/ps.output/r_font.c
   grass-addons/postscript/ps.output/r_frame.c
   grass-addons/postscript/ps.output/r_grid.c
   grass-addons/postscript/ps.output/r_line.c
   grass-addons/postscript/ps.output/r_maparea.c
   grass-addons/postscript/ps.output/r_note.c
   grass-addons/postscript/ps.output/r_palette.c
   grass-addons/postscript/ps.output/r_paper.c
   grass-addons/postscript/ps.output/r_raster.c
   grass-addons/postscript/ps.output/r_rlegend.c
   grass-addons/postscript/ps.output/r_scalebar.c
   grass-addons/postscript/ps.output/r_vareas.c
   grass-addons/postscript/ps.output/r_vlegend.c
   grass-addons/postscript/ps.output/r_vlines.c
   grass-addons/postscript/ps.output/r_vpoints.c
   grass-addons/postscript/ps.output/raster.c
   grass-addons/postscript/ps.output/raster.h
   grass-addons/postscript/ps.output/rlegend.h
   grass-addons/postscript/ps.output/scalebar.h
   grass-addons/postscript/ps.output/scanners.c
   grass-addons/postscript/ps.output/set_draw.c
   grass-addons/postscript/ps.output/set_geogrid.c
   grass-addons/postscript/ps.output/set_grid.c
   grass-addons/postscript/ps.output/set_mask.c
   grass-addons/postscript/ps.output/set_note.c
   grass-addons/postscript/ps.output/set_outline.c
   grass-addons/postscript/ps.output/set_ps.c
   grass-addons/postscript/ps.output/set_raster.c
   grass-addons/postscript/ps.output/set_rlegend.c
   grass-addons/postscript/ps.output/set_scalebar.c
   grass-addons/postscript/ps.output/set_vector.c
   grass-addons/postscript/ps.output/set_vlegend.c
   grass-addons/postscript/ps.output/start_map.c
   grass-addons/postscript/ps.output/symbol.c
   grass-addons/postscript/ps.output/val_list.c
   grass-addons/postscript/ps.output/vareas.h
   grass-addons/postscript/ps.output/vector.c
   grass-addons/postscript/ps.output/vector.h
   grass-addons/postscript/ps.output/vlegend.h
   grass-addons/postscript/ps.output/vlines.h
   grass-addons/postscript/ps.output/vpoints.h
Update of ps.out
Modified: grass-addons/postscript/ps.output/Makefile
--- grass-addons/postscript/ps.output/Makefile	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/Makefile	2010-01-30 15:50:19 UTC (rev 40744)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM=ps.output
+PGM=ps.out
 LIBES     = $(VECTLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(DATETIMELIB) $(IMAGERYLIB) $(GMATHLIB)
 DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(DATETIDEP) $(IMAGERYDEP) $(GMATHDEP) \
@@ -11,4 +11,9 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd
+default: cmd patt
+patt:
+	$(MKDIR) $(ETC)/paint/patterns/
+	$(INSTALL_DATA) patterns/*.eps $(ETC)/paint/patterns/
Modified: grass-addons/postscript/ps.output/cat_val.c
--- grass-addons/postscript/ps.output/cat_val.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/cat_val.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -13,8 +13,10 @@
 #include <grass/glocale.h>
 #include "vector.h"
+static char catval_str[128];
 /* LOAD CAT_VAL */
-int load_catval_array(VECTOR *vector, const char *colname, dbCatValArray *cvarr)
+int load_catval_array(VECTOR * vector, const char *colname, dbCatValArray * cvarr)
     int n_records;
     struct field_info *Fi;
@@ -23,19 +25,19 @@
     db_CatValArray_init(cvarr);
     Fi = Vect_get_field(&(vector->Map), vector->layer);
-    if (Fi == NULL) {
-        G_fatal_error(_("Unable to get layer info for vector map"));
+    if (Fi == NULL)
+	G_fatal_error(_("Unable to get layer info for vector map"));
     driver = db_start_driver_open_database(Fi->driver, Fi->database);
     if (driver == NULL)
-        G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
-                      Fi->database, Fi->driver);
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
     n_records = db_select_CatValArray(driver, Fi->table, Fi->key, colname, NULL, cvarr);
     if (n_records < 0)
-        G_fatal_error(_("Unable to select data from table"));
+	G_fatal_error(_("Unable to select data from table"));
     db_close_database_shutdown_driver(driver);
@@ -46,7 +48,7 @@
 /* GET CAT_VAL */
 /* return a double number from a dbCatValArray */
-int get_number(dbCatValArray *cvarr, int cat, double *d)
+void get_number(dbCatValArray * cvarr, int cat, double *d)
     int ret, int_val;
     dbCatVal *cv = NULL;
@@ -55,51 +57,78 @@
     if (cvarr->ctype == DB_C_TYPE_INT)
-        ret = db_CatValArray_get_value_int(cvarr, cat, &int_val);
-        if (ret != DB_OK) {
-            G_warning(_("No record for category [%d]"), cat);
-        else
-            *d = (double)int_val;
+	ret = db_CatValArray_get_value_int(cvarr, cat, &int_val);
+	if (ret != DB_OK)
+	    G_warning(_("No record for category [%d]"), cat);
+	else
+	    *d = (double)int_val;
     else if (cvarr->ctype == DB_C_TYPE_DOUBLE)
-        ret = db_CatValArray_get_value_double(cvarr, cat, d);
+	ret = db_CatValArray_get_value_double(cvarr, cat, d);
+	if (ret != DB_OK)
     else if (cvarr->ctype == DB_C_TYPE_STRING)
-        ret = db_CatValArray_get_value(cvarr, cat, &cv);
-        else
-            *d = atof(db_get_string(cv->val.s));
+	ret = db_CatValArray_get_value(cvarr, cat, &cv);
+	if (ret != DB_OK)
+	else
+	    *d = atof(db_get_string(cv->val.s));
-    return 1;
 /* return a string from a dbCatValArray */
-char * get_string(dbCatValArray *cvarr, int cat)
+char *get_string(dbCatValArray * cvarr, int cat, int dec)
-    int ret;
+    int ret, int_val;
+    double double_val;
-    char *str = NULL;
+    char buf[10], *str = NULL;
-        else
-            str = db_get_string(cv->val.s);
+	if (ret != DB_OK)
+	else
+	    str = db_get_string(cv->val.s);
-    else {
-        G_warning(_("It is not a string field [%d]"), cat);
+    else if (cvarr->ctype == DB_C_TYPE_INT)
+	if (ret != DB_OK)
+	else
+	    sprintf(catval_str, "%d", int_val);
+	    str = catval_str;
+    else if (cvarr->ctype == DB_C_TYPE_DOUBLE)
+	ret = db_CatValArray_get_value_double(cvarr, cat, &double_val);
+	if (ret != DB_OK)
+	else
+	    sprintf(buf, "%%0.%df", dec);
+	    sprintf(catval_str, buf, double_val);
+	    str = catval_str;
     return str;
Modified: grass-addons/postscript/ps.output/colors.c
--- grass-addons/postscript/ps.output/colors.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/colors.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,17 +16,17 @@
 #include "local_proto.h"
-void unset_color(PSCOLOR *color)
+void unset_color(PSCOLOR * color)
     color->none = 1;
     color->r = color->g = color->b = 0.;
-int set_color_name(PSCOLOR *color, char *name)
+int set_color_name(PSCOLOR * color, char *name)
     int R, G, B;
-    if (strcmp(name, "none") == 0)
+    if (*name == 0 || strcmp(name, "none") == 0)
         unset_color(color);
         return 1;
@@ -46,36 +46,69 @@
     return 0;
-void set_color_rgb(PSCOLOR *color, int r, int g, int b)
+void set_color_rgb(PSCOLOR * color, int r, int g, int b)
     color->none = 0;
+    color->a = 1.;
     color->r = (double)r / 255.;
     color->g = (double)g / 255.;
     color->b = (double)b / 255.;
-/* PostScript shortcut */
+void set_color_pscolor(PSCOLOR * color, PSCOLOR * pscolor)
+    color->none = pscolor->none;
-void set_ps_color(PSCOLOR *color)
+    color->a = pscolor->a;
+    color->r = pscolor->r;
+    color->g = pscolor->g;
+    color->b = pscolor->b;
+long color_to_long(PSCOLOR * color)
-    if (!color->none)
-        fprintf(PS.fp, "%.3f %.3f %.3f C ",
-                color->r, color->g, color->b);
+    return (16711680 * color->r + 65280 * color->g + 255 * color->b);
-int set_ps_grey(PSCOLOR *color)
+int long_to_color(long ln, PSCOLOR * color)
-    if (!color->none)
-        fprintf(PS.fp, "%.3f %.3f %.3f CG ",
+    color->none = 0;
+    color->r = (double)((ln & 16711680) >> 16) / 255.;
+    color->g = (double)((ln & 65280) >> 8) / 255.;
+    color->b = (double)(ln & 255) / 255.;
+       fprintf(PS.fp, "%.3f %.3f %.3f ",
+       (double)((ln & 16711680) >> 16)/255.,
+       (double)((ln & 65280) >> 8)/255.,
+       (double)(ln & 255)/255.);
     return 0;
-void set_ps_rgb(int R, int G, int B)
+/* PostScript shortcut */
+int set_ps_color(PSCOLOR * color)
-            (double)R/255., (double)G/255., (double)B/255.);
+    if (!color->none)
+	fprintf(PS.fp, "%.3f %.3f %.3f C ", color->r, color->g, color->b);
+	if ((PS.flag & 1) && color->a > 0.)
+	    fprintf(PS.fp, "%.2f O ", color->a);
+    return 0;
+int set_ps_grey(PSCOLOR * color)
+    if (!color->none)
+	fprintf(PS.fp, "%.3f %.3f %.3f CG ", color->r, color->g, color->b);
+    return 0;
Modified: grass-addons/postscript/ps.output/description.html
--- grass-addons/postscript/ps.output/description.html	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/description.html	2010-01-30 15:50:19 UTC (rev 40744)
@@ -1,45 +1,51 @@
 <H2>DESCRIPTION</H2>
-<EM>ps.output</EM> is a cartographic mapping program for producing high quality
-hardcopy maps in PostScript-3 format. Output can include a raster map, any
+<EM>ps.out</EM> is a cartographic mapping program for producing high quality
+hardcopy maps in PostScript-3 format. Output can include a combination of two raster maps, any
 number of vector overlays, notes, decorations, and other spatial data.
 <P>
 A file of mapping instructions that describes the various spatial and textual
-information to be printed must be prepared prior to running <EM>ps.output</EM>.
+information to be printed must be prepared prior to running <EM>ps.out</EM>.
+Then, the better use is writing a script file as:
+<PRE>
+ps.out [flags] output=FILE << EOF
+(ps.out commands)
+EOF
+</PRE>
+<P>
+The hash character ('<tt>#</tt>') may be used at the beginning of a line
+to indicate that the line is a comment. Blank lines will also be ignored.
 <H2>NOTES</H2>
 <P>
 The order of commands is generally unimportant but may affect how some layers
-are drawn. For example to plot <B>vpoints</B> above <B>vareas</B> list the
-<B>vpoints</B> entry first. Raster maps are always drawn first, and only a
-single raster map and an optional background may be used
-(or 3 if part of a RGB group).
+are drawn. <EM>ps.out</EM> first draw the masked areas, lines, points, and labels,
+second the unmasked areas and lines, and finally the grids, unmasked points and unmasked labels.
+Raster maps are always drawn first, and only a raster map command may be used.
 <P>
-The hash character ('<tt>#</tt>') may be used at the beginning of a line
-to indicate that the line is a comment. Blank lines will also be ignored.
-<P>
 Be aware that some mapping instructions require the <i>end</i> command
 and some do not. Any instruction that allows subcommands will require
-it, any instruction that does not allow subcommands will not.
+it.
 <P>
-The resolution and extent of raster maps plotted with <EM>ps.output</EM> are controlled by the current region settings via the <a href="g.region.html">g.region</a> module. The output filesize is largely a function of the region resolution, so special care should be taken if working with large raster datasets.
+The resolution and extent of raster maps plotted with <EM>ps.out</EM> are controlled by the current region settings via the <a href="g.region.html">g.region</a> module. The output filesize is largely a function of the region resolution, so special care should be taken if working with large raster datasets.
 For example if the desired output is Letter sized paper at 300dpi, with 1" margins and the raster filling the entire page, the usable area on the page will be 6.5" x 9", which at 300 dots/inch is equivalent to a region of 1950 columns x 2700 rows (see "<tt>g.region -p</tt>"). Any higher resolution settings will make the output file larger, but with a consumer printer you probably won't be able to resolve any better detail in the hardcopy.
 <P>
 The user can specify negative or greater than 100 percentage values for positioning several map decorations and embedded EPS-files, to move them outside the current map box region (for example to position a caption, barscale, or legend above or below the map box).
 <P>
-One "pixel" is 1/72 of an inch or 127/360 (~ 0.35) of a millimetre.
+One "pixel" is 1/72 of an inch or 127/360 (aprox. 0.35) of a millimetre.
 <P>
-For users wanting to use special characters (such as accented characters) it is important to note that <em>ps.output</em> uses <tt>ISO-8859-1</tt> encoding. This means that your instructions file will have to be encoded in this encoding. If you normally work in a different encoding environment (such as <tt>UTF-8</tt>), you have to transform your file to the <tt>ISO-8859-1</tt> encoding, for example by using the <tt>iconv</tt> utility:
+For users wanting to use special characters (such as accented characters) it is important to note that <em>ps.out</em> uses <tt>ISO-8859-1</tt> encoding. This means that your instructions file will have to be encoded in this encoding. If you normally work in a different encoding environment (such as <tt>UTF-8</tt>), you have to transform your file to the <tt>ISO-8859-1</tt> encoding, for example by using the <tt>iconv</tt> utility:
 </P>
 <DIV class="code"><PRE>
 iconv -f UTF-8 -t ISO_8859-1 utf_file > iso_file
 </PRE></DIV>
@@ -50,51 +56,54 @@
 <H2>MAPPING INSTRUCTIONS</H2>
 The mapping instructions allow the user to specify various spatial data to be plotted. These instructions are normally prepared in a regular text file using a system editor. Except <em>scale</em>, all instructions are multiple line followed by a subsection of one or more additional instructions and are terminated with an <i>end</i> instruction.
 <P>
+<H3>Instruction keywords:</H3>
-<h3>Instruction keywords:</h3>
 <a href="#draw">draw</a>&nbsp;<BR>
-<a href="#geogrid">geogrid</a>&nbsp; ERROR IN SOUTH HEMISPHERE<BR>
+<a href="#geogrid">geogrid</a>&nbsp; ERROR IN SOUTH HEMISPHERE?<BR>
 <a href="#grid">grid</a>&nbsp;<BR>
 <a href="#maparea">maparea</a>&nbsp;<BR>
 <a href="#note">note</a>&nbsp;<BR>
-<a href="#palette">palette</a>&nbsp; CHECK<BR>
+<a href="#palette">palette</a>&nbsp;<BR>
 <a href="#paper">paper</a>&nbsp;<BR>
 <a href="#raster">raster</a>&nbsp;<BR>
 <a href="#rlegend">rlegend</a>&nbsp;<BR>
 <a href="#scale">scale</a>&nbsp;<BR>
 <a href="#scalebar">scalebar</a>&nbsp;<BR>
 <a href="#vareas">vareas</a>&nbsp;<BR>
+<a href="#vlabels">vlabel</a>&nbsp;<BR>
 <a href="#vlines">vlines</a>&nbsp;<BR>
 <a href="#vpoints">vpoints</a>&nbsp;<BR>
 <a href="#vlegend">vlegend</a>&nbsp;<BR>
-<h3>Convention in description of instructions:</h3>
+<h3>Convention in description of some instructions:</h3>
 <DL>
-<DT><B>#</B> <EM>number</EM>
-<P>
-<DT><B>#-</B> <EM>dimension</EM> name (number with units)
-<DD> Acceptable units are <em>mm</em> (millimeters), <em>cm</em> (centimeters), and <em>inch</em> (inches).
+<DT><B>#</B> <EM>number without dimension</EM>
+<DD>The number is considered in points.
 </DD><P>
+<DT><B>#-</B> <EM>number with dimension</EM>
+<DD> Acceptable units are <em>mm</em> (millimeters), <em>cm</em> (centimeters), <em>inch</em> (inches), and <em>%</em> (percent of map dimensions).
+</DD><P>
 <DT><B>CAT</B> <EM>List of categories</EM> e.g. 1,3,5-7
 <P>
 <DT><B>SQL</B> <EM>SQL where statement</EM> like: vlastnik = 'Cimrman'
 <P>
 <DT><b>T</b> <em>Text</em>
 <P>
-<DT><b>R</b> <em>Raster</em> file or group name if first character is ':'
+<DT><b>R</b> <em>Raster</em> file or group name if the first character is ':'
 <P>
-<DT><b>V</b> <em>Vector</em> file
+<DT><b>V</b> <em>Vector</em> file name if equal to '(none)' then don't draw but there is present in vlegend.
 <P>
 <DT><b>color</b> <em>Color</em> name
-<DD>The color may be either a standard <a name="NAMED_COLORS">GRASS color</a>, a <tt>R:G:B</tt> triplet (e.g '<tt>255:0:0</tt>'), or <tt>none</tt>.
-The following colors names are accepted by <EM>ps.output</EM>:
-<tt>aqua, black, blue, brown, cyan, gray, grey, green, indigo, magenta, orange, purple, red, violet, white, yellow</tt>.
-</DD><P>
+<DD>The color may be either a standard <a name="NAMED_COLORS">GRASS color</a>, a <tt>R:G:B</tt> triplet (e.g '<tt>255:0:0</tt>'), or <tt>none</tt>. In all cases could be follow by <em>$alpha</em> to set the opacity (if use -g flag).
+ The following colors names are accepted by <EM>ps.out</EM>: <tt>aqua, black, blue, brown, cyan, gray, grey, green, indigo, magenta, orange, purple, red, violet, white, yellow</tt>.
+<P>
+<DT><b>COOR</b> <em>Coordinates</em> as pair of <b>east north</b>
+<P>
+</DD>
 <DT><B>font</B> command:
 <PRE>
@@ -148,54 +157,52 @@
 end
 </PRE>
-<DT><b>COOR</b> <em>Coordinates</em> as pair of <b>east north</b>
-<P>
+</DL>
-</DL>
 <P>
 <H2>COMPOSE THE MAP</H2>
+<a name="paper"><h3>paper</h3></a> Specifies paper size, margins and orientation.
-<h3>paper</h3>
-<a name="paper"></a>
-Specifies paper size, margins and orientation.
-<PRE>
+<P><PRE>
 USAGE
-<B>paper</B> [paper type], default: A4
+<B>paper</B> [paper type]: default A4
     <B>height</B> [#-]
     <B>width</B>  [#-]
-    <B>left</B>   [#-], default 0.5inch
-    <B>right</B>  [#-], default 0.5inch
-    <B>bottom</B> [#-], default 1.0inch
-    <B>top</B>    [#-], default 1.0inch
-    <B>landscape</B> [y|N], default N
+    <B>left</B>   [#-]: default 0.5inch
+    <B>right</B>  [#-]: default 0.5inch
+    <B>bottom</B> [#-]: default 1.0inch
+    <B>top</B>    [#-]: default 1.0inch
+    <B>landscape</B> [y|N]: default N
+    <B>draw</B>   (draw)
+    <B>font</B>   (font): set the default font
 <B>end</B>
 </PRE>
-<P>
-Paper types: A0-6, B0-6, Executive, Folio, Ledger, Legal, Letter, Tabloid.<BR>
+<UL>
+<LI><em>paper types</em>: A0-6, B0-6, Executive, Folio, Ledger, Legal, Letter, Tabloid.</LI>
+<LI><em>left</em> and <em>top</em>: They are referenced to upper-left margin of the paper and they specify the position of the map area (i.e. grids growth outside this limits).
+<LI><em>draw</em>: This paints the features before any part of map. Usefull to draw logos, watermarks...</LI>
+</UL>
-<PRE>
+<P><PRE>
 <i>EXAMPLE</i>
 paper A4
     left 2cm
     top 4cm
     landscape y
+    font
+        name Univers
+        size 8
+    end
 end
 </PRE>
-<P>
+This example set the size of paper to landscape A4 and Univers 8 point as defualt font.
-<h3>scale</h3>
-Selects a scale for the output map.
+<P>
+<a name="scale"><h3>scale</h3></a>. Selects a scale for the output map.
 <PRE>
 USAGE
@@ -213,10 +220,11 @@
 This example would set the scale of the map to 1 unit = 25000 units.
-<h3>maparea</h3>
+<a name="maparea"><h3>maparea</h3></a>
+Position of the map area on the page.<BR>
+The upper left corner of the map will be positioned <EM>left</EM> units from the left edge of the page and <EM>top</EM> units from the top of the page. If <EM>width</EM> and <EM>height</EM> are present, the map will be rescaled, if necessary, to fit.
+<P>
-Positions the map area on the page.
 <PRE>
 USAGE
 <B>maparea</B>
@@ -226,32 +234,30 @@
     <B>height</B> [#-]
     <B>border</B> [#-]
     <B>color</B>  [color]
+    <B>fcolor</B> [color]
  <B>end</B>
 </PRE>
-The upper left corner of the map will be positioned <EM>left</EM> units from the left edge of the page and <EM>top</EM> units from the top of the page. If <EM>width</EM> and <EM>height</EM> are present, the map will be rescaled, if necessary, to fit.
-<P>
+<UL>
+<LI><em>border</em> and <em>color</em>: To control the which and color of the line is drawn around the map area.</LI>
+<LI><em>fcolor</em>: Fill map-area with color (or none), e.g. aqua to sea color.
+</LI>
-<em>border</em> and <em>color</em> controls the which and color of the line is drawn around the map area.
-<P>
-<PRE>
+<P><PRE>
 <i>EXAMPLE</i>
 maparea
-	left 2cm
-	top 3.5cm
-	border 1mm
-	color black
+    left 2cm
+    top 3.5cm
+    border 1mm
+    color black
+    fcolor none
 end
 </PRE>
 This example positions the upper left corner of the map 2.0 cm from the left edge and 3.5 cm from the top edge of the map. And draw a black border of 1 mm of width around the map area.
-<h3>palette</h3>
 <H2>ADDING COMPONENTS</H2>
 <h3>grid</h3>
@@ -266,14 +272,17 @@
     <B>cross</B>  [#]
     <B>font</B>   [font]
-    <B>format</B> [#], number (0-2) or 'in', 'out' or 'iho'
-    <B>round</B>  [#]
+    <B>format</B> ['in', 'out', '+out' or 'iho']
+    <B>cutoff</B> [#]
  <B>end</B>
 </PRE>
+<table border=1 cellspacing=10>
+<td>
+<I>EXAMPLE</I>
 <PRE>
-<I>EXAMPLE</I>
 grid
+    format in
     major 1000
         width .1mm
         color gray
@@ -290,10 +299,16 @@
         color white
     end
     fcolor black
-    format 0
-    round 3
+    cutoff 3
 end
 </PRE>
+</td>
+<td></td>
+<td><image src="ps.out_in.jpg"><br><br>format: in</td>
+<td><image src="ps.out_out.jpg"><br><br>format: out</td>
+<td><image src="ps.out_iho.jpg"><br><br>format: iho</td>
+<td><image src="ps.out_can.jpg"><br><br>format: can</td>
+</table>
 This example would overlay a gray grid with a spacing of 10000 meters (for a metered database, like UTM) onto the output map.  Alternate grid lines would be numbered with white numbers on black boxes.
@@ -308,7 +323,7 @@
     <B>minor</B>  [#] (line)
     <B>font</B>   [font]
-    <B>format</B> [#], number (0-1) or 'in' or 'out'
+    <B>format</B> ['in' or 'out' or '+out']
  <B>end</B>
 </PRE>
@@ -344,8 +359,8 @@
 <B>scalebar</B>   [scalebar type]
     <B>length</B> [#]
     <B>units</B>  [code T]
-    <B>major</B>  [# #], divisions and seperation text label
-    <B>minor</B>  [# #], divisions and seperation text label
+    <B>major</B>  [# #], divisions and label separation
+    <B>minor</B>  [# #], divisions and label separation
     <B>frame</B>  [frame]
     <B>font</B>   [font]
     <B>height</B> [#-]
@@ -389,6 +404,7 @@
     <B>font</B> [font]
     <B>angle</B> [#] in degrees
+    <B>width</B> [#-]
  <B>end</B>
 </PRE>
@@ -420,7 +436,45 @@
 </PRE>
+<a name="palette"><h3>palette</h3></a>
+<a name="draw"><h3>draw</h3></a>
+<PRE>
+USAGE
+<B>draw</B> [free]
+    <b>direct</B> (T)
+    <B>color</B> (color)
+    <B>fcolor</B> (fill color)
+    <B>linewidth</B> line_width
+    <B>linedash</B> line_width
+    <B>font</B> name size [extend]
+    <B>[l,r,c,x,v,]text</B> east north label or -1 angle label
+    <B>textc</B> east north label
+    <B>labels</B> filename
+    <B>moveto</B> east north
+    <B>lineto</B> east north
+    <B>endline</B>
+    <B>line</B> east1 north1 east2 north2
+    <B>rectangle</B> east1 north1 east2 north2 [fillcolor]
+    <B>circle</B> east north radius
+    <B>arc</B> east1, noth1, diameter, east2, north2
+    <B>border</B> width
+    <B>psfile</B> scale east north filename
+    <B>maplimits</B>
+    <b>north</B> east north radius
+    <B>compass</B> east north radius
+    <B>rute</B> east north label
+<B>end</B>
+</PRE>
 <h2>ADDING RASTER MAPS</h2>
 <a name="raster"><H3>raster</H3></a>
@@ -428,12 +482,12 @@
 <PRE>
 <I>USAGE</I>
-<B>raster</B> [R|R R R], required: one raster, one group name (:name) or three raster (RGB)
+<B>raster</B> [R|R R R], required: one raster, one group name (:name) or three raster (R G B)
     <B>grey</B>      [y|N]. Output in shades of grey.
     <B>maskcolor</B> [color]. Color to be used for mask.
     <B>maskcell</B>  [R (R)]. Raster used as mask and optionally a raster for background.
     <B>outline</B>   [line]. Specifications of outline.
-    <B>setcolor</B>  [cat color]. Overrides the color of cat
+    <B>setcolor</B>  [CAT color]. Overrides the color of cat
 end
 </PRE>
@@ -456,39 +510,56 @@
 <a name="vareas"><H3>vareas</H3></a>
+Draw a vector of areas with optional pattern. Fill or pattern color can be fixed or reed from database.
+A line vector could be drawn as an area when lwidth is not zero (positive or negative).
+If label = "" not block title.
 <PRE>
 USAGE
-<B>vareas</B> [V]. Vector map name
-    <b>width</b>  [#-], default 0 (positive or negative, permit draw a line as area).
+<B>vareas</B> [V]
+    <b>lwidth</b> [#-], default: 0 (area).
+    <b>line</b>   (line)
+    <b>fcolor</b> (color | RGBCOL$alpha [IDCOL])
+    <b>pat</b>    [TXT]. Pattern EPS file.
+    <b>pscale</b> [#]. Pattern scale.
+    <b>pwidth</b> [#]. Pattern line width.
+    <b>island</b> [Y|n]. Draw island as normal areas (fill as normal area then hide it).
     <b>layer</b>  [#], default: 1. Layer number used with cats/where option
     <b>cats</b>   [CAT]
-    <b>where</b>  [SQL].
-    <b>line</b>   (line)
-    <b>fcolor</b> (color) ([T]). Fill color and, optionally RGB column name (also apply to pattern).
-    <b>pat</b>    [T]. Pattern EPS file.
-    <b>scale</b>  [#]
-    <b>pwidth</b> [#]
-    <b>masked</b> [y|N]. Masked by raster mask
-    <b>label</b>  [T]. For description in vlegend
-    <b>lpos</b>   [#]. Position vector is plotted in legend
+    <b>where</b>  [SQL]
+    <b>masked</b> [y|N]. Masked or not by raster mask
+    <b>label</b>  [TXT]. For description or title in vlegend
+    <b>lpos</b>   [# #]. Position where vector is plotted in legend and block
+    <b>setrule</b> [ID.CAT[:ID] TXT]. Set a label for the CAT.
 <b>end</b>
 </PRE>
 <a name="vlines"><H3>vlines</H3></a>
+Perhaps offset dont run well in Lat/Lon
 <PRE>
 USAGE
-<B>vlines</B> [V]. Vector map name
+<B>vlines</B> [V].
     <b>type</b>   [line|boundary], default: line
+    <b>rgbcol</b> [T]. Column name with line color data
+    <b>hline</b>  (line)
+    <b>offset</b> [#-]. hline offset, default: 0.
     <b>cats</b>   [CAT]
     <b>where</b>  [SQL]
-    <b>rgbcol</b> [T]. Column name with line color data
-    <b>hline</b>  [# (line)], default: 0; and enter line command. Offset dimen from midline
 <b>end</b>
 </PRE>
@@ -511,22 +582,33 @@
 <a name="vpoints"><H3>vpoints</H3></a>
+Draw a vector of points with a symbol.<br>
+A line vector could be drawn as a lines ...
 <PRE>
 USAGE
-<B>vpoints</B> [V]. Vector map name
-    <b>type</b>   [point|centroid], default: point
+<B>vpoints</B> [V].
+    <b>type</b>   [point|centroid|line|boundary], default: point
+    <b>symbol</b> [T]. Symbol standard or EPS file.
+    <b>fcolor</b> (color). Fillcolor
+    <b>size</b>   [# | SIZECOL #]. Size or size column (and legend size).
+    <b>scale</b>  [#- #-]. Scale and bias to rescale sizecol.
+    <b>rotate</b> [# | ROTATECOL]. Rotate or rotate column.
+    <b>dist</b>   [#-]. Distance between symbol on the cline
+    <b>offset</b> [#-]. Vertical offset of the symbol
+    <b>cline</B> (line). Conection line of the symbols
     <b>cats</b>   [CAT]
     <b>where</b>  [SQL]
-    <b>symbol</b> [T]. Symbol standard or EPS file.
-    <b>fcolor</b> (color). Fillcolor
-    <b>size</b>   [# ([T])]. Size and optionally size column.
-    <b>scale</b>  [#]. Scale
-    <b>rotate</b> [# ([T])]. Rotate and optionally rotate column.
+    <b>setrule</b> [SIZE.CAT[:ID] TXT]. Set a label for the CAT.
 <b>end</b>
 </PRE>
@@ -545,6 +627,33 @@
 end
 </PRE>
+<a name="vlabels"><H3>vlabels</H3></a>
+<PRE>
+USAGE
+<B>vlabels</B> [V].
+    <b>labelcol</b> [T]
+    <b>font</b>  (font)
+    <b>decimals</b> [#]
+    <b>circled</b> [Y|n]
+    <b>layer</b>  [#]
+    <b>cats</b>   [CAT]
+    <b>label</b>  [T]
+    <b>lpos</b>   [#]
+<b>end</b>
+</PRE>
+<PRE>
+<i>EXAMPLE</i>
+vlabels railroads
+    labelcol cat
+    masked n
+end
+</PRE>
 <h2>ADDING LEGENDS</h2>
 <a name="rlegend"><H3>rlegend</H3></a>
@@ -557,11 +666,12 @@
     <b>frame</b>
     <b>font</b>
     <b>cols</b>
-    <b>width</b>
+    <b>swidth</b>
     <b>height</b>
     <b>tick</b>
     <b>order</b>
     <b>whiteframe</b>
+    <b>gradient</b>
 <b>end</b>
 </PRE>
@@ -601,13 +711,13 @@
 <PRE>
 USAGE
-<B>vlegend</B>
-    <b>title</b> (first char point to center)
+<B>vlegend</B> [T] Title of legend
     <b>frame</b>
+    <b>title_font</b>
     <b>font</b>
     <b>cols</b>
-    <b>width</b>
-    <b>order</b>
+    <b>swidth</b>
+    <b>dy</b>
 <b>end</b>
 </PRE>
@@ -629,12 +739,29 @@
         name Univers
         size 9
     end
-#   cols 1
-#   width 1cm
 end
 </PRE>
+<a name="vlabel"><h3>vlabel</h3></a>
+<PRE>
+USAGE
+<B>vlabel</B> [code T]
+    <B>font</B> [font]
+    <B>labelcol</B> [T]
+    <B>decimals</B> [#]
+    <b>layer</b>  [#], default: 1. Layer number used with cats/where option
+    <b>cats</b>   [CAT]
+    <b>masked</b> [y|N]. Masked by raster mask
+    <b>label</b>  [T]. For description in vlegend
+    <b>lpos</b>   [#]. Position vector is plotted in legend
+<B>end</B>
+</PRE>
 <H2>AUTHOR</H2>
 E. Jorge Tizado  (ej.tizado unileon es)<br>
Modified: grass-addons/postscript/ps.output/draws.h
--- grass-addons/postscript/ps.output/draws.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/draws.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,8 +17,9 @@
 typedef struct
-    char * key[MAX_DRAWS];
-    char * data[MAX_DRAWS];
+    int flag[MAX_DRAWS];	/* paper (watermark), free or none (clip to map) */
+    char *key[MAX_DRAWS];
+    char *data[MAX_DRAWS];
 } PSDRAW;
Modified: grass-addons/postscript/ps.output/eps.c
--- grass-addons/postscript/ps.output/eps.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/eps.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -22,23 +22,27 @@
     int v1, v2, v3, v4;
     /* test if file is realy eps and find bbox */
-    if ((fp = fopen(eps, "r")) == NULL) {
-	    fprintf(stderr, "can't open eps file <%s>\n", eps);
+    if ((fp = fopen(eps, "r")) == NULL)
+	fprintf(stderr, "can't open eps file <%s>\n", eps);
 	return (0);
     /* test if first row contains '%!PS-Adobe-m.n EPSF-m.n' string */
     fgets(buf, 200, fp);
-    if (sscanf(buf, "%%!PS-Adobe-%d.%d EPSF-%d.%d", &v1, &v2, &v3, &v4) < 4) {
-    	fprintf(stderr, "file <%s> is not in EPS format\n", eps);
-	    fclose(fp);
+    if (sscanf(buf, "%%!PS-Adobe-%d.%d EPSF-%d.%d", &v1, &v2, &v3, &v4) < 4)
+	fprintf(stderr, "file <%s> is not in EPS format\n", eps);
+	fclose(fp);
 	return (0);
     /* looking for bbox */
-    while (fgets(buf, 200, fp) != NULL) {
-	    if (sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", llx, lly, urx, ury) == 4) {
-	        fclose(fp);
-	        return (1);
+    while (fgets(buf, 200, fp) != NULL)
+	if (sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", llx, lly, urx, ury) == 4)
+	    fclose(fp);
+	    return (1);
     fprintf(stderr, "Bounding box in eps file <%s> was not found\n", eps);
     fclose(fp);
@@ -49,8 +53,7 @@
  * rotate is in degrees
 int eps_trans(double llx, double lly, double urx, double ury,
-	      double x, double y, double scale, double rotate,
-	      double *xt, double *yt)
+	      double x, double y, double scale, double rotate, double *xt, double *yt)
     double xc, yc, angle;
@@ -83,8 +86,7 @@
 /* draw EPS file saved by eps_save */
-int eps_draw_saved(FILE * fp, char *name, double x, double y, double scale,
-		   double rotate)
+int eps_draw_saved(FILE * fp, char *name, double x, double y, double scale, double rotate)
     fprintf(PS.fp, "\nBeginEPSF\n");
     fprintf(PS.fp, "%.5f %.5f translate\n", x, y);
@@ -102,8 +104,7 @@
 /* write EPS file into PS file */
-int eps_draw(FILE * fp, char *eps, double x, double y, double scale,
-	     double rotate)
+int eps_draw(FILE * fp, char *eps, double x, double y, double scale, double rotate)
     char buf[1024];
     FILE *epsfp;
@@ -138,9 +139,9 @@
 	return (0);
     fprintf(fp, "\n/%s {\n", name);
-    while (fgets(buf, 1024, epsfp) != NULL) {
-	if (strncmp(buf, "%!PS-Adobe", 10) == 0 ||
-	    strncmp(buf, "%%BoundingBox", 13) == 0)
+    while (fgets(buf, 1024, epsfp) != NULL)
+	if (strncmp(buf, "%!PS-Adobe", 10) == 0 || strncmp(buf, "%%BoundingBox", 13) == 0)
 	    continue;
 	fprintf(fp, "%s", buf);
Modified: grass-addons/postscript/ps.output/fonts.c
--- grass-addons/postscript/ps.output/fonts.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/fonts.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -14,22 +14,20 @@
 #include "fonts.h"
-double set_ps_font_nocolor(PSFONT *font)
+double set_ps_font_nocolor(PSFONT * font)
     if (font->extend == 1. || font->extend <= 0.)
-        fprintf(PS.fp, "(%s) FN %.1f FS\n",
-                font->name, font->size);
+	fprintf(PS.fp, "(%s) FN %.1f FS\n", font->name, font->size);
     else
-        fprintf(PS.fp, "(%s) FN %.1f %.2f FE\n",
-                font->name, font->size, font->extend);
+	fprintf(PS.fp, "(%s) FN %.1f %.2f FE\n", font->name, font->size, font->extend);
     return font->size;
-double set_ps_font(PSFONT *font)
+double set_ps_font(PSFONT * font)
     set_ps_color(&(font->color));
     set_ps_font_nocolor(font);
Modified: grass-addons/postscript/ps.output/frames.c
--- grass-addons/postscript/ps.output/frames.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/frames.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -14,24 +14,27 @@
 /* Postscipt variables: -- */
-void set_box_orig(PSFRAME *box)
+void set_box_orig(PSFRAME * box)
-	double x, y;
+    double x, y;
-	if (box->x <= 0.0) {
-        box->x = PS.map_x - PS.map_w * (box->x/100.);
+    if (box->x <= 0.0)
+	box->x = PS.map_x - PS.map_w * (box->x / 100.);
-    else {
-        box->x = 0 + box->x;
+       else {
+       box->x = 0 + box->x;
+    if (box->y <= 0.0)
+	box->y = PS.map_y - PS.map_h * (box->y / 100.);
-	if (box->y <= 0.0) {
-        box->y = PS.map_y - PS.map_h * (box->y/100.);
+    else
+	box->y = PS.page.height - box->y;
-    else {
-		box->y = PS.page.height - box->y;
 /* Postscript variables: mg hg chg wd cwd  */
@@ -39,121 +42,108 @@
     /* Margin "mg" */
     if (box->margin < 0.)
-        box->margin = 0.;
+	box->margin = 0.;
     fprintf(PS.fp, "/mg %.4f def\n", box->margin);
     /* Height "hg" and content height "chg" */
-    if (height > 0.) {
-        fprintf(PS.fp, "/hg %.4f def\n", height); /* height */
-        fprintf(PS.fp, "/chg hg mg 2 mul sub def\n"); /* content height */
+    if (height > 0.)
+	fprintf(PS.fp, "/hg %.4f def\n", height);	/* height */
+	fprintf(PS.fp, "/chg hg mg 2 mul sub def\n");	/* content height */
     /* Width "wd" and content width "cwd" */
-    if (width > 0.) {
-        fprintf(PS.fp, "/wd %.4f def\n", width);  /* width */
-        fprintf(PS.fp, "/cwd wd mg 2 mul sub def\n"); /* content width */
+    if (width > 0.)
+	fprintf(PS.fp, "/wd %.4f def\n", width);	/* width */
+	fprintf(PS.fp, "/cwd wd mg 2 mul sub def\n");	/* content width */
-/* Draw the box with outer border */
-void set_box_draw(PSFRAME *box)
+/* Draw the box with outer border: xo yo */
+void set_box_draw(PSFRAME * box)
     /* Re-location */
     if (box->xref == RIGHT)
-        fprintf(PS.fp, "/xo %.4f wd sub def\n",
-                box->x + box->xset);
+	fprintf(PS.fp, "/xo %.4f wd sub def\n", box->x + box->xset);
     else if (box->xref == CENTER)
-        fprintf(PS.fp, "/xo %.4f wd 2 div sub def\n",
+	fprintf(PS.fp, "/xo %.4f wd 2 div sub def\n", box->x + box->xset);
     else
-        fprintf(PS.fp, "/xo %.4f def\n",
+	fprintf(PS.fp, "/xo %.4f def\n", box->x + box->xset);
     if (box->yref == LOWER)
-        fprintf(PS.fp, "/yo %.4f hg add def\n",
-                box->y + box->yset);
+	fprintf(PS.fp, "/yo %.4f hg add def\n", box->y + box->yset);
     else if (box->yref == CENTER)
-        fprintf(PS.fp, "/yo %.4f hg 2 div add def\n",
+	fprintf(PS.fp, "/yo %.4f hg 2 div add def\n", box->y + box->yset);
     else
-        fprintf(PS.fp, "/yo %.4f def\n",
+	fprintf(PS.fp, "/yo %.4f def\n", box->y + box->yset);
-    /* Draw the border, if set */
-    if (box->border > 0.)
-        set_ps_color(&(box->color));
-        fprintf(PS.fp, "%.4f LW xo yo wd hg neg RO\n",
-                box->border);
     /* Make color background, if set */
     if (!box->fcolor.none)
-        set_ps_color(&(box->fcolor));
-        fprintf(PS.fp, "xo yo wd hg neg RF\n");
+	set_ps_color(&(box->fcolor));
+	fprintf(PS.fp, "xo yo wd hg neg RF\n");
+    /* Draw the border, if set */
+    if (box->border > 0.)
+	set_ps_color(&(box->color));
+	fprintf(PS.fp, "%.4f LW xo yo wd hg neg RO\n", box->border);
 /* Postscript auto size with ARh y ARw */
-void set_box_auto(PSFRAME *box, PSFONT *font, double factor)
+void set_box_auto(PSFRAME * box, PSFONT * font, double factor)
     if (factor <= 0.)
-        factor = 0.5; /* standard row height by fontsize */
+	factor = 0.5;		/* standard row height by fontsize */
     /* Initialize */
-        box->margin = 0.4 * font->size;
+	box->margin = 0.4 * font->size;
-    /* Margins "mg" */
+    /* Margins "mg", 'mgx', 'mgy' */
     fprintf(PS.fp, "/mg %.8f def\n", box->margin);
+    fprintf(PS.fp, "/mgx mg def /mgy mg def\n");
     /* Height "hg", content height "chg", and interline "dy" */
-    fprintf(PS.fp, "/dy %.4f def\n", factor * font->size); /* standard row sep */
+    fprintf(PS.fp, "/dy %.4f def\n", factor * font->size);	/* standard row sep */
     fprintf(PS.fp, "/chg dy neg ARh {add dy add} forall def\n"); /* content height */
-    fprintf(PS.fp, "/hg chg mg 2 mul add def\n"); /* height */
+    fprintf(PS.fp, "/hg chg mg 2 mul add def\n");	/* height */
     /* Width "wd", content width "cwd", and intercolum "dx" */
-    fprintf(PS.fp, "/dx mg def\n"); /* standard col sep */
-    fprintf(PS.fp, "/cwd dx neg ARw {add dx add} forall def\n"); /* content width */
-    fprintf(PS.fp, "/wd cwd mg 2 mul add def\n"); /* width */
+    fprintf(PS.fp, "/dx mg def\n");	/* standard col sep */
+    fprintf(PS.fp, "/cwd dx neg ARw {add dx add} forall def\n");	/* content width */
+    fprintf(PS.fp, "/wd cwd mg 2 mul add def\n");	/* width */
-/* Postscript space for a top title  */
-void set_box_readjust_title(PSFRAME *box, const char *title)
-    fprintf(PS.fp, "(%s) SWH ", title);
-    fprintf(PS.fp, "mg add dup hg add /hg XD mg add /mgy XD "); /* adjust height */
-    fprintf(PS.fp, "pop\n"); /* TODO: adjust width */
+/* INNER ONLY ADJUST */
 /* Readjust the size of a box with new margins */
-void set_box_readjust(PSFRAME *box,
-                      double left, double top,
-                      double width, double height)
+void set_inner_readjust(double left, double top, double width, double height)
-    if (left > 0.) {
-        if (width >= 0.)
-            width += left;
-        else
-            width = left;
-        fprintf(PS.fp, "/mgx mg %.4f add def\n", left);
+    if (left > 0.)
+	if (width >= 0.)
+	    width += left;
+	else
+	    width = left;
+	fprintf(PS.fp, "/mgx mg %.4f add def\n", left);
-    if (top > 0.) {
-        if (height >= 0.)
-            height += top;
-        else
-            height = top;
-        fprintf(PS.fp, "/mgy mg %.4f add def\n", top);
+    if (top > 0.)
+	if (height >= 0.)
+	    height += top;
+	else
+	    height = top;
+	fprintf(PS.fp, "/mgy mg %.4f add def\n", top);
-        fprintf(PS.fp, "/hg hg %.4f add def\n", height);
+    if (height > 0.)
+	fprintf(PS.fp, "/hg hg %.4f add def\n", height);
-    if (width > 0.) {
-        fprintf(PS.fp, "/wd wd %.4f add def\n", width);
+    if (width > 0.)
+	fprintf(PS.fp, "/wd wd %.4f add def\n", width);
Modified: grass-addons/postscript/ps.output/frames.h
--- grass-addons/postscript/ps.output/frames.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/frames.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,14 +16,18 @@
 typedef struct
-    double x, y;          /* left-top corner */
-    double xset, yset;    /* x and y offset */
-    int xref, yref;       /* reference point */
-    double border;        /* outer border width */
-    PSCOLOR color;        /* border color */
-    PSCOLOR fcolor;       /* fill color */
-    double margin;        /* inner margin */
+    double x, y;		/* left-top corner */
+    double xset, yset;		/* x and y offset */
+    int xref, yref;		/* reference point */
+    double border;		/* outer border width */
+    PSCOLOR color;		/* border color */
+    PSCOLOR fcolor;		/* fill color */
+    double margin;		/* inner margin */
     double rotate;
 } PSFRAME;
 #endif
Modified: grass-addons/postscript/ps.output/grids.h
--- grass-addons/postscript/ps.output/grids.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/grids.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,18 +17,20 @@
 typedef struct
-    int sep;         /* major separation between lines */
+    int sep;			/* major separation between lines */
     PSLINE line;
     PSFONT font;
     PSCOLOR fcolor;
+    int lsides;			/* label, default 2 sides, else 4 */
-    int msep;        /* minor separation between lines */
+    int msep;			/* minor separation between lines */
     PSLINE mline;
-    int format;      /* formats: 0 inner, 1 outer, ... */
-    int round;       /* digits to cut if zero */
-    double cross;    /* length of crosses */
+    int format;			/* border formats: 0 inner, 1 outer, ... */
+    int trim;			/* digits of labels to cutoff if zero */
+    double cross;		/* length of not LL crosses */
+    int msubdiv;
 } GRID;
 #endif
Modified: grass-addons/postscript/ps.output/input.c
--- grass-addons/postscript/ps.output/input.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/input.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,32 +19,33 @@
 int input(int level, char *buf)
     int i;
-    char command[10], empty[3];
+    char command[20], empty[3];
     if (level && isatty(fileno(inputfd)))
-    	fprintf(stdout, "enter 'end' when done, 'exit' to quit\n");
+	fprintf(stdout, "enter 'end' when done, 'exit' to quit\n");
     do
-        if (level && isatty(fileno(inputfd)))
-            fprintf(stdout, "%s ", level == 1 ? ">" : ">>");
-        if (!G_getl2(buf, 1024, inputfd))
-            if (inputfd != stdin) {
-                fclose(inputfd);
-                inputfd = stdin;
-            return 0;
-        if (sscanf(buf, "%5s %1s", command, empty) == 1)
-            if (strcmp(command, "end") == 0)
-                return 0;
-            if (strcmp(command, "exit") == 0)
-                exit(0);
+	if (level && isatty(fileno(inputfd)))
+	    fprintf(stdout, "%s ", level == 1 ? ">" : ">>");
+	if (!G_getl2(buf, 1024, inputfd))
+	    if (inputfd != stdin)
+		fclose(inputfd);
+		inputfd = stdin;
+	    return 0;
+	if (sscanf(buf, "%5s %1s", command, empty) == 1)
+	    if (strcmp(command, "end") == 0)
+		return 0;
+	    if (strcmp(command, "exit") == 0)
+		exit(0);
     while (*buf == '#');
@@ -57,18 +58,21 @@
     char *key, *data;
     key = buf;
-    while (*key && *key <= ' ') key++;
+    while (*key && *key <= ' ')
+	key++;
-    if (*key == 0) {
-        *k = *d = key;
-        return 0;
+    if (*key == 0)
+	*k = *d = key;
+	return 0;
     data = key;
-    while (*data && *data > ' ') data++;
+    while (*data && *data > ' ')
+	data++;
     if (*data)
-        *data++ = 0;
+	*data++ = 0;
     *k = key;
     *d = data;
@@ -84,9 +88,9 @@
     sprintf(msg, "%s%s%s : %s", a, *b ? " " : "", b, c);
     if (isatty(0))
-        fprintf(stderr, "%s\n", msg);
+	fprintf(stderr, "%s\n", msg);
     else
-        G_fatal_error(msg);
+	G_fatal_error(msg);
     exit(0);
Modified: grass-addons/postscript/ps.output/legends.c
--- grass-addons/postscript/ps.output/legends.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/legends.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -13,51 +13,51 @@
-void set_legend_adjust(LEGEND *legend, double height)
+void set_legend_adjust(LEGEND * legend, double height)
-	/* Initialize */
+    /* Initialize */
     if (legend->box.margin < 0.)
-        legend->box.margin = 0.4 * legend->font.size;
+	legend->box.margin = 0.4 * legend->font.size;
     if (legend->width < 0.)
-        legend->width = 2.4 * legend->font.size;
+	legend->width = 2.4 * legend->font.size;
     /* Margins "mg", "mgx" and "mgy" */
-    fprintf(PS.fp, "/mg %.5f def\n", legend->box.margin); /* inner box margin */
-    fprintf(PS.fp, "/mgx mg def\n"); /* to RESET and COL */
-    fprintf(PS.fp, "/mgy mg def\n"); /* to RESET and ROW */
+    fprintf(PS.fp, "/mg %.5f def\n", legend->box.margin);	/* inner box margin */
+    fprintf(PS.fp, "/mgx mg def\n");	/* to RESET and COL */
+    fprintf(PS.fp, "/mgy mg def\n");	/* to RESET and ROW */
     /* Symbol width "syw" and adding to all width columns */
-    fprintf(PS.fp, "/syw %.5f def\n", legend->width); /* symbol width */
-    fprintf(PS.fp, "0 1 ARw length 1 sub {ARw exch dup ARw exch get syw add put} for\n");
-    /* fprintf(PS.fp, "0 1 ARw length -- {ARw exch 2 copy get syw add put} for\n"); */
+    fprintf(PS.fp, "/syw %.5f def\n", legend->width);	/* symbol width */
+    fprintf(PS.fp, "0 1 ARw length -- {ARw exch dup ARw exch get syw add put} for\n");
     if (height > 0.)
-        fprintf(PS.fp, "/hg %.5f def\n", height); /* height */
-        fprintf(PS.fp, "/dy ARh length 1 eq {0} {chg ARh {sub} forall ARh length 1 sub div} ifelse def\n"); /* rowsep */
+	fprintf(PS.fp, "/hg %.5f def\n", height);	/* height */
+	fprintf(PS.fp, "/dy ARh length 1 eq {0} {chg ARh {sub} forall ARh length -- div} ifelse def\n");	/* rowsep */
     else
-        fprintf(PS.fp, "/dy %.5f def\n", .5 * legend->font.size); /* standard row sep */
-        fprintf(PS.fp, "/chg dy neg ARh {add dy add} forall def\n"); /* content height */
+	fprintf(PS.fp, "/dy %.5f def\n", .5 * legend->font.size);	/* standard row sep */
+	fprintf(PS.fp, "/chg dy neg ARh {add dy add} forall def\n");	/* content height */
     /* Width "wd", content width "cwd", and colspan "dx" */
-    if (legend->span < 0.) { /* auto-adjust */
-        fprintf(PS.fp, "/wd %.5f def ", -(PS.map_w * legend->span)); /* width */
-        fprintf(PS.fp, "/dx ARw length 1 eq {0} {cwd ARw {sub} forall ARw length 1 sub div} ifelse def\n"); /* colspan */
+    if (legend->xspan < 0.)
+    {				/* auto-adjust */
+	fprintf(PS.fp, "/wd %.5f def ", -(PS.map_w * legend->xspan));	/* width */
+	fprintf(PS.fp, "/dx ARw length 1 eq {0} {cwd ARw {sub} forall ARw length -- div} ifelse def\n");	/* colspan */
-    else {
-        if (legend->span == 0.)
-            legend->span = legend->box.margin;
-        fprintf(PS.fp, "/dx %.4f def\n", legend->span); /* colspan */
+    else
+	if (legend->xspan == 0.)
+	    legend->xspan = legend->box.margin;
+	fprintf(PS.fp, "/dx %.4f def\n", legend->xspan);	/* colspan */
Modified: grass-addons/postscript/ps.output/legends.h
--- grass-addons/postscript/ps.output/legends.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/legends.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,17 +16,23 @@
 #include "fonts.h"
 #include "frames.h"
+#define TITLE_LEN   60
 typedef struct
-    PSFRAME box;        /* frame box */
-    PSFONT font;        /* legend font */
+    PSFRAME box;		/* frame box */
-	int cols;           /* column number */
-    double span;        /* column separation */
-    double width;       /* symbol width  */
+    char title[TITLE_LEN];	/* text title */
+    PSFONT title_font;		/* title font */
-    char title[51];     /* text title */
-    PSFONT title_font;  /* title font */
+    PSFONT font;		/* legend font */
+    int cols;			/* number of columns */
+    double width;		/* symbol width  */
+    double xspan;		/* separation between columns */
+    double yspan;		/* separation between rows */
 } LEGEND;
 #endif
Modified: grass-addons/postscript/ps.output/lines.c
--- grass-addons/postscript/ps.output/lines.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/lines.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,35 +19,35 @@
 int set_ps_linewidth(double width)
     if (width > 0.)
-        fprintf(PS.fp, "%.3f LW ", width);
+	fprintf(PS.fp, "%.3f LW ", width);
     return 0;
-int set_ps_line(PSLINE *line)
+int set_ps_line(PSLINE * line)
     set_ps_color(&(line->color));
     set_ps_linewidth(line->width);
-    fprintf(PS.fp, "[%s] 0 LD ", line->dash);
+    fprintf(PS.fp, "[%s] %d LD ", line->dash, line->odash);
     if (line->cap > 0)
-        fprintf(PS.fp, "%d LC ", line->cap);
+	fprintf(PS.fp, "%d LC ", line->cap);
     if (line->join > 0)
-        fprintf(PS.fp, "%d LJ ", line->join);
+	fprintf(PS.fp, "%d LJ ", line->join);
     fprintf(PS.fp, "\n");
     return 0;
-int set_ps_line_no_color(PSLINE *line)
+int set_ps_line_no_color(PSLINE * line)
     if (line->cap > 0)
     if (line->join > 0)
     return 0;
Modified: grass-addons/postscript/ps.output/lines.h
--- grass-addons/postscript/ps.output/lines.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/lines.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -27,11 +27,12 @@
 typedef struct
-    double width;   /* width of line */
-    PSCOLOR color;  /* color of line */
-    int cap;        /* linecap style */
-    int join;       /* linejoin style */
-    char *dash;     /* dash ps format */
+    double width;		/* width of line */
+    PSCOLOR color;		/* color of line */
+    int cap;			/* linecap style */
+    int join;			/* linejoin style */
+    char *dash;			/* dash ps format */
+    int odash;			/* offset dash */
 } PSLINE;
 #endif
Modified: grass-addons/postscript/ps.output/load_raster.c
--- grass-addons/postscript/ps.output/load_raster.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/load_raster.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -46,40 +46,43 @@
     I_init_group_ref(&ref);
     /* get group info */
-    if (I_get_group_ref(PS.rst.title, &ref) == 0) {
-        G_fatal_error(_("Can't get group information"));
+    if (I_get_group_ref(PS.rst.title, &ref) == 0)
+	G_fatal_error(_("Can't get group information"));
     G_message(_("Reading map group <%s> ..."), name);
     /* get filenames for R, G, and B */
     I_init_ref_color_nums(&ref);
-    PS.rst.name[0]   = G_store(ref.file[ref.red.n].name);
+    PS.rst.name[0] = G_store(ref.file[ref.red.n].name);
     PS.rst.mapset[0] = G_store(ref.file[ref.red.n].mapset);
-    PS.rst.name[1]   = G_store(ref.file[ref.grn.n].name);
+    PS.rst.name[1] = G_store(ref.file[ref.grn.n].name);
     PS.rst.mapset[1] = G_store(ref.file[ref.grn.n].mapset);
-    PS.rst.name[2]   = G_store(ref.file[ref.blu.n].name);
+    PS.rst.name[2] = G_store(ref.file[ref.blu.n].name);
     PS.rst.mapset[2] = G_store(ref.file[ref.blu.n].mapset);
     /* check load colors */
     for (i = 0; i < 3; i++)
-        if (G_read_colors(PS.rst.name[i], PS.rst.mapset[i], &(PS.rst.colors[i])) == -1) {
-            sprintf(fullname, "%s in %s", PS.rst.name[i], PS.rst.mapset[i]);
-            error(fullname, "", "can't load color table");
-            return 0;
+	if (G_read_colors(PS.rst.name[i], PS.rst.mapset[i], &(PS.rst.colors[i])) == -1)
+	    sprintf(fullname, "%s in %s", PS.rst.name[i], PS.rst.mapset[i]);
+	    error(fullname, "", "can't load color table");
+	    return 0;
     /* check open raster maps */
-        if ((PS.rst.fd[i] = G_open_cell_old(PS.rst.name[i], PS.rst.mapset[i])) < 0) {
-            error(fullname, "", "can't open raster map");
-            G_free_colors(&(PS.rst.colors[i]));
-            return 0;
+	if ((PS.rst.fd[i] = G_open_cell_old(PS.rst.name[i], PS.rst.mapset[i])) < 0)
+	    error(fullname, "", "can't open raster map");
+	    G_free_colors(&(PS.rst.colors[i]));
+	    return 0;
     I_free_group_ref(&ref);
@@ -93,26 +96,30 @@
     char fullname[100];
     /* close raster cell, if any */
-    if (PS.rst.fd[slot] >= 0) {
-        G_close_cell(PS.rst.fd[slot]);
-        G_free(PS.rst.name[slot]);
-        G_free(PS.rst.mapset[slot]);
-        G_free_colors(&(PS.rst.colors[slot]));
-        PS.rst.fd[slot] = -1;
+    if (PS.rst.fd[slot] >= 0)
+	G_close_cell(PS.rst.fd[slot]);
+	G_free(PS.rst.name[slot]);
+	G_free(PS.rst.mapset[slot]);
+	G_free_colors(&(PS.rst.colors[slot]));
+	PS.rst.fd[slot] = -1;
     /* get mapset */
     ptr = strchr(name, '@');
-    if (ptr) {
-        *ptr = '\0';
-        mapset = ptr + 1;
+    if (ptr)
+	*ptr = '\0';
+	mapset = ptr + 1;
-    else {
-        mapset = G_find_file2("cell", name, "");
-        if (!mapset) {
-            error(name, "", "not found");
-            return 0;
+    else
+	mapset = G_find_file2("cell", name, "");
+	if (!mapset)
+	    error(name, "", "not found");
+	    return 0;
     /* store data of cell */
@@ -123,17 +130,19 @@
     G_message(_("  Reading raster map <%s> ..."), fullname);
     /* load colors */
-    if (G_read_colors(name, mapset, &PS.rst.colors[slot]) == -1) {
-		return 0;
+    if (G_read_colors(name, mapset, &PS.rst.colors[slot]) == -1)
+	return 0;
     G_get_color_range(&(PS.rst.min), &(PS.rst.max), &(PS.rst.colors[slot]));
     /* open raster map */
-    if ((PS.rst.fd[slot] = G_open_cell_old(name, mapset)) < 0) {
-		G_free_colors(&PS.rst.colors[slot]);
-    	return 0;
+    if ((PS.rst.fd[slot] = G_open_cell_old(name, mapset)) < 0)
+	G_free_colors(&PS.rst.colors[slot]);
+	return 0;
     return 1;
Modified: grass-addons/postscript/ps.output/local_proto.h
--- grass-addons/postscript/ps.output/local_proto.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/local_proto.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -9,30 +9,33 @@
 #define POINTS 1
 #define LINES  2
 #define AREAS  3
+#define LABELS 4
 #define DEF_FONT "Helvetica"
 /* cat_val.c */
 #ifdef DBMIN_H
 int load_catval_array(VECTOR *, const char *, dbCatValArray *);
-int get_number(dbCatValArray *, int, double *);
-char * get_string(dbCatValArray *, int);
+void get_number(dbCatValArray *, int, double *);
+char *get_string(dbCatValArray *, int, int);
 #endif
 /* colors.c */
 #ifdef _PSCOLOR_H_
 int set_color_name(PSCOLOR *, char *);
 void set_color_rgb(PSCOLOR *, int, int, int);
+void set_color_pscolor(PSCOLOR *, PSCOLOR *);
 void unset_color(PSCOLOR *);
-void set_ps_color(PSCOLOR *);
+int set_ps_color(PSCOLOR *);
 int set_ps_grey(PSCOLOR *);
-void set_ps_rgb(int, int, int);
+long color_to_long(PSCOLOR *);
+int long_to_color(long, PSCOLOR *);
 #endif
 /* eps.c */
 int eps_bbox(char *, double *, double *, double *, double *);
-int eps_trans(double, double, double, double, double, double,
-              double, double, double *, double *);
+int eps_trans(double, double, double, double, double, double, double, double, double *, double *);
 #ifdef _STDIO_H
 int eps_save(FILE *, char *, char *);
 int eps_draw_saved(FILE *, char *, double, double, double, double);
@@ -46,15 +49,20 @@
 double set_ps_font_nocolor(PSFONT *);
 #endif
+/* format.c */
+void format_northing(double, char *, int);
+void format_easting(double, char *, int);
+void format_iho(double, char *);
 /* frames.c */
 #ifdef _PSFRAME_H_
 void set_box_orig(PSFRAME *);
 void set_box_size(PSFRAME *, double, double);
 void set_box_draw(PSFRAME *);
 void set_box_auto(PSFRAME *, PSFONT *, double);
-void set_box_readjust_title(PSFRAME *, const char *);
-void set_box_readjust(PSFRAME *, double, double, double, double);
 #endif
+void set_inner_readjust_title(const char *);
+void set_inner_readjust(double, double, double, double);
 /* input.c */
 int input(int, char *);
@@ -90,11 +98,15 @@
 int find_limits(double *, double *, double *, double *, struct pj_info *, struct pj_info *);
 #endif
+/* r_block.c */
+int read_block(int);
 /* r_draw.c */
 int read_draw(char *);
 /* r_font.c */
 int get_font(char *);
 #ifdef _PSFONT_H_
 int default_font(PSFONT *);
 int read_font(char *, PSFONT *);
@@ -135,6 +147,9 @@
 /* r_vareas.c */
 int r_vareas(char *);
+/* r_vlabels.c */
+int read_vlabels(char *);
 /* r_vlegend.c */
 int read_vlegend(char *);
@@ -154,18 +169,20 @@
 int scan_percent(char *, double *, double, double);
 int scan_ref(char *, int *, int *);
 int scan_yesno(char *, char *);
+int scan_dimen(char *, double *);
+int scan_second(char *, double *);
 #ifdef _PSCOLOR_H_
 int scan_color(char *, PSCOLOR *);
 #endif
-int scan_dimen(char *, double *);
-int scan_second(char *, double *);
 /* set_draw.c */
-int set_draw(char *, char*);
+int set_draw(char *, char *);
 /* set_geogrid.c */
 int set_lines_geogrid(void);
 int set_numbers_geogrid(void);
 #ifdef _PSLINE_H_
 int set_geogrid_lines(PSLINE *, int);
 #endif
@@ -175,17 +192,20 @@
 /* set_grid.c */
 int set_lines_grid(void);
 int set_numbers_grid(void);
 #ifdef _PSLINE_H_
 int set_grid_lines(char, PSLINE *, int);
 #endif
 int set_grid_inner_numbers(void);
-int set_grid_outer_numbers(void);
-int set_grid_iho_numbers(void);
-int set_grid_fine_border(double, double);
-int set_grid_minor_border(double, double, double);
-int set_grid_major_border(double, double);
-int set_grid_corners(double, double);
+int set_grid_outer_numbers(int);
+int set_grid_iho_numbers(double, double);
+int set_grid_can_numbers(double, double);
+void set_grid_minordiv_border(int, double, double);
+void set_grid_minor_border(double, double, double);
+void set_grid_major_border(double, double);
+void set_grid_corners(double, double);
 /* set_mask.c */
 int set_mask(void);
@@ -195,11 +215,14 @@
 /* set_ps.c */
 void set_ps_rect(double, double, double, double);
+void set_ps_brd(double);
+void set_ps_brd2(double, double);
 int set_ps_where(char, double, double);
-int set_xy_where(char *, double, double, char*);
+int set_xy_where(char *, double, double, char *);
+int set_ps_symbol_eps(int, char *);
 #ifdef _VECTOR_H_
 int set_ps_pattern(int, char *, VAREAS *);
-int set_ps_symbol_eps(int, VPOINTS *, char *);
 #endif
 /* set_raster.c */
@@ -212,7 +235,7 @@
 /* set_rlegend.c */
 int set_rlegend_cats(void);
 int set_rlegend_gradient(void);
-static double nice_step(double, int, int*);
+static double nice_step(double, int, int *);
 /* set_scalebar.c */
 char *strnumber(double);
@@ -220,11 +243,31 @@
 /* set_vector.c */
 int set_vector(int, int);
 #ifdef GRASS_VECT_H
-int set_vareas(VECTOR, VAREAS *);
-int set_vpoints(VECTOR, VPOINTS *);
-int set_vlines(VECTOR, VLINES *, int);
+/* set_vareas.c */
+int set_vareas(VECTOR *, VAREAS *);
+int set_vareas_line(VECTOR *, VAREAS *);
+/* set_vlabels.c */
+int set_vlabels(VECTOR *, VLABELS *);
+/* set_vlegend.c */
+int set_vlegend(void);
+int set_vlegend_simple(int, const int *, int);
+int set_vlegend_multi(int, VECTOR *);
+void make_vareas(VECTOR *, int);
+void make_vlines(VECTOR *, int);
+void make_vpoints(VECTOR *, int);
+void set_vlegend_ps(int, int, int);
+/* set_vlines.c */
+int set_vlines(VECTOR *, VLINES *, int);
 int vector_line(struct line_pnts *);
+/* set_vpoints.c */
+int set_vpoints(VECTOR *, VPOINTS *);
+int set_vpoints_line(VECTOR *, VPOINTS *);
 #endif
 /* start_map.c */
@@ -244,5 +287,15 @@
 /* vector.c */
 int vector_new(void);
-int where_moveto(double, double);
-int where_lineto(double, double);
+int default_vector(int);
+#ifdef _VECTOR_H_
+int vector_item_new(VECTOR *, double, long);
+int vector_rule_find(VECTOR *, double);
+int vector_rule_new(VECTOR *, char *, char *, double);
+#endif
+/* vlegend.c */
+int vlegend_block_new(void);
+void vlegend_block_adjust(int, const char *);
+void vlegend_block_reload(int);
Modified: grass-addons/postscript/ps.output/main.c
--- grass-addons/postscript/ps.output/main.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/main.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -33,7 +33,7 @@
     struct Option *input_file;
     struct Option *output_file;
     struct GModule *module;
-    struct Flag *draft;
+    struct Flag *draft, *eps, *ghost, *style;
     G_gisinit(argv[0]);
@@ -58,11 +58,22 @@
     draft = G_define_flag();
     draft->key = 'd';
-    draft->description =
-            _("Create a 1x1cm grid on paper to easy place and drawing");
+    draft->description = _("draf: Create a 1x1cm grid on paper to easy place and drawing");
+    eps = G_define_flag();
+    eps->key = 'e';
+    eps->description = _("eps: Create a EPS file to easy include in ps.out (no stand-alone)");
+    ghost = G_define_flag();
+    ghost->key = 'g';
+    ghost->description = _("ghostscript: Use the extended PostScript of Ghostscript (for transparent colors");
+    style = G_define_flag();
+    style->key = 's';
+    style->description = _("special: Special number style: lower");
     if (G_parser(argc, argv))
-        exit(EXIT_FAILURE);
+	exit(EXIT_FAILURE);
     inputfd = stdin;
     signal(SIGINT, exit);
@@ -70,19 +81,18 @@
     setbuf(stderr, NULL);
     if (!isatty(0))
-        G_disable_interactive();
+	G_disable_interactive();
     if (output_file->answer)
-        if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
-            G_fatal_error("%s - %s: %s", G_program_name(),
-                          output_file->answer, strerror(errno));
+	if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
+	    G_fatal_error("%s - %s: %s", G_program_name(), output_file->answer, strerror(errno));
     else
-        G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
-                  output_file->key, output_file->description);
+	G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
+		  output_file->key, output_file->description);
     /* get current mapset */
@@ -91,30 +101,39 @@
     /* set current window */
     G_get_set_window(&PS.map);
     if (G_set_window(&PS.map) == -1)
-        G_fatal_error(_("Current region cannot be set."));
+	G_fatal_error(_("Current region cannot be set."));
     set_paper("A4");
+    unset_color(&(PS.page.fcolor));	/* no paper color */
     Palette = NULL;
+    /* Set the level of Postscript */
+    PS.level = (eps->answer ? 0 : 3);
+    PS.flag |= (ghost->answer ? 1 : 0);
+    PS.flag |= (style->answer ? 2 : 0);
     /* initialize default ps_info */
-    PS.level = 3;
     PS.draft = draft->answer ? 1 : 0;
     PS.scale = 0;
     PS.map_top = -1.;
     PS.map_x = PS.map_y = -1.;
     PS.map_w = PS.map_h = -1.;
-    unset_color(&(PS.fcolor)); /* no background color in maparea */
-    PS.do_border   = 0;     /* no border */
-    PS.rst.files   = 0;     /* no rast files */
-    PS.need_mask   = 0;     /* select storage in PS_raster_plot */
-    PS.do_rlegend  = 0;     /* no rlegend */
-    PS.vct_files   = 0;     /* no include files */
-    PS.vct = NULL;          /* no vector files */
-    PS.do_vlegend  = 0;     /* no vlegend */
-	PS.grid.sep    = 0;     /* no grid */
-    PS.geogrid.sep = 0;     /* no geogrid */
-    PS.sbar.segments = 0;   /* no scalebar */
-    PS.n_notes     = 0;     /* no notes */
-    PS.n_draws     = 0;     /* no plots */
+    unset_color(&(PS.fcolor));	/* no background color in maparea */
+    PS.do_border = 0;		/* no border */
+    PS.rst.files = 0;		/* no rast files */
+    PS.need_mask = 0;		/* select storage in PS_raster_plot */
+    PS.do_rlegend = 0;		/* no rlegend */
+    PS.vct_files = 0;		/* no include files */
+    PS.vct = NULL;		/* no vector files */
+    PS.do_vlegend = 0;		/* no vlegend */
+    PS.grid.sep = 0;		/* no grid */
+    PS.geogrid.sep = 0;		/* no geogrid */
+    PS.sbar.segments = 0;	/* no scalebar */
+    PS.n_notes = 0;		/* no notes */
+    PS.n_draws = 0;		/* no plots */
+    /* default font */
+    strcpy(PS.font.name, "Helvetica");
+    PS.font.size = 10.;
+    PS.font.extend = 1.;
+    set_color_rgb(&(PS.font.color), 0, 0, 0);
     /* process options */
     char buf[1024];
@@ -122,133 +141,171 @@
     while (input(1, buf))
-	    char *key;
-	    char *data;
+	char *key;
+	char *data;
-        if (!key_data(buf, &key, &data)) {
-            continue;
-        /* General information */
-        if (KEY("paper")) {
-            read_paper(data);
-            continue;
-        if (KEY("palette")) {
-            read_palette();
-            continue;
-        if (KEY("maparea")) {
-            read_maparea();
-            continue;
-        if (KEY("scale")) {
-            if (sscanf(data, "1:%d", &(PS.scale)) != 1) {
-                error(key, data, "illegal scale request");
-            continue;
+	if (!key_data(buf, &key, &data))
+	    continue;
+	/* General information */
+	if (KEY("paper"))
+	    read_paper(data);
+	    continue;
+	if (KEY("palette"))
+	    read_palette();
+	    continue;
+	if (KEY("maparea"))
+	    read_maparea();
+	    continue;
+	if (KEY("scale"))
+	    if (sscanf(data, "1:%d", &(PS.scale)) != 1)
+		error(key, data, "illegal scale request");
+	    continue;
-        /* Raster map related information */
-        if (KEY("cell") || KEY("rast") || KEY("raster") || KEY("rgb")) {
-            if (PS.rst.files != 0) {
-                error(key, data, "only one raster command");
-                continue;
-            read_raster(data);
-            continue;
-        if (KEY("rlegend")) {
-            if (PS.do_rlegend != 0) {
-                error(key, data, "only one rlegend command");
-			read_rlegend(data);
-			continue;
+	/* Raster map related information */
+	if (KEY("cell") || KEY("rast") || KEY("raster") || KEY("rgb"))
+	    if (PS.rst.files != 0)
+		error(key, data, "only one raster command");
+		continue;
+	    read_raster(data);
+	    continue;
+	if (KEY("rlegend"))
+	    if (PS.do_rlegend != 0)
+		error(key, data, "only one rlegend command");
+	    read_rlegend(data);
+	    continue;
-        /* Vector map related information */
-        if (KEY("vlines") || KEY("vline")) {
-            G_strip(data);
-            if (*data == 0) {
-                error(key, data, "vlines need vector map");
-            read_vlines(data);
-            continue;
-        if (KEY("vareas") || KEY("varea")) {
-            G_strip(data);
-            if (*data == 0) {
-                error(key, data, "vareas need vector map");
-            read_vareas(data);
-            continue;
-        if (KEY("vpoints") || KEY("vpoint")) {
-            G_strip(data);
-            if (*data == 0) {
-                error(key, data, "vpoints need vector map");
-            read_vpoints(data);
-            continue;
-        if (KEY("vlegend")) {
-            if (PS.do_vlegend != 0) {
-                error(key, data, "only one vlegend command");
-            read_vlegend(data);
-			continue;
+	/* Vector map related information */
+	if (KEY("vlines") || KEY("vline"))
+	    G_strip(data);
+	    if (*data == 0)
+		error(key, data, "vlines need vector map");
+	    read_vlines(data);
+	    continue;
+	if (KEY("vareas") || KEY("varea"))
+	    G_strip(data);
+	    if (*data == 0)
+		error(key, data, "vareas need vector map");
+	    read_vareas(data);
+	    continue;
+	if (KEY("vpoints") || KEY("vpoint"))
+	    G_strip(data);
+	    if (*data == 0)
+		error(key, data, "vpoints need vector map");
+	    read_vpoints(data);
+	    continue;
+	if (KEY("vlabels") || KEY("vlabel"))
+	    G_strip(data);
+	    if (*data == 0)
+		error(key, data, "vlabels need vector map");
+	    read_vlabels(data);
+	    continue;
+	if (KEY("vlegend"))
+	    if (PS.do_vlegend != 0)
+		error(key, data, "only one vlegend command");
+	    read_vlegend(data);
+	    continue;
-        /* Grid and scalebar related */
-        if (KEY("grid")) {
-            read_grid(&(PS.grid), 0);
-            continue;
-        if (KEY("geogrid")) {
-            if (G_projection() == PROJECTION_XY) {
-                error(key, data, "geogrid is not available for XY projection");
-            else if (G_projection() == PROJECTION_LL) {
-                error(key, data, "grid just uses LL projection");
-            read_grid(&(PS.geogrid), 1);
-            continue;
-        if (KEY("scalebar")) {
-            if (G_projection() == PROJECTION_LL) {
-                error(key, data, "scalebar is not appropriate for this projection");
-            if (sscanf(data, "%c", &(PS.sbar.type)) != 1)
-                PS.sbar.type = 'I'; /* default new style scalebar */
-            read_scalebar();
-            continue;
+	/* Grid and scalebar related */
+	if (KEY("grid"))
+	    read_grid(&(PS.grid), 1);
+	    continue;
+	if (KEY("geogrid"))
+	    if (G_projection() == PROJECTION_XY)
+		error(key, data, "geogrid is not available for XY projection");
+	    else if (G_projection() == PROJECTION_LL)
+		error(key, data, "grid just uses LL projection");
+	    read_grid(&(PS.geogrid), 0);
+	    continue;
+	if (KEY("scalebar"))
+	    if (G_projection() == PROJECTION_LL)
+		error(key, data, "scalebar is not appropriate for this projection");
+	    if (sscanf(data, "%c", &(PS.sbar.type)) != 1)
+		PS.sbar.type = 'I';	/* default new style scalebar */
+	    read_scalebar();
+	    continue;
-        /* Addons related data */
-        if (KEY("note")) {
-            if (PS.n_notes >= MAX_NOTES) {
-                G_warning("Only %d notes by map", MAX_NOTES);
-                continue;
-            read_note(data);
-            continue;
-        if (KEY("draw")) {
-            if (PS.n_draws >= MAX_DRAWS) {
-                G_warning("Only %d draw commands by map", MAX_DRAWS);
-                continue;
-            read_draw(data);
-            continue;
-        /* oops, no valid command */
-	    if (*key)
-	        error(key, "", "illegal request");
+	/* Addons related data */
+	if (KEY("note"))
+	    if (PS.n_notes >= MAX_NOTES)
+		G_warning("Only %d notes by map", MAX_NOTES);
+		continue;
+	    read_note(data);
+	    continue;
+	if (KEY("draw"))
+	    if (PS.n_draws >= MAX_DRAWS)
+		G_warning("Only %d draw commands by map", MAX_DRAWS);
+		continue;
+	    read_draw(data);
+	    continue;
+	/* oops, no valid command */
+	if (*key)
+	    error(key, "", "illegal request");
     /* last minute adjust */
-    if (PS.grid.format == 2) { /* IHO */
-        PS.brd.width = 2.3 * MM_TO_POINT; /* 12.5 */
-        /* PS.do_border = 0; */
+    if (PS.grid.format >= 2)
+    {				/* IHO */
+	PS.brd.width = 2. * MM_TO_POINT;	/* 12.7 */
     /* Well, go on the map */
@@ -256,5 +313,3 @@
     G_message(_("PostScript file '%s' finished!"), output_file->answer);
     exit(EXIT_SUCCESS);
Modified: grass-addons/postscript/ps.output/notes.h
--- grass-addons/postscript/ps.output/notes.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/notes.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,12 +17,13 @@
 typedef struct
-	PSFRAME box;
+    PSFRAME box;
     PSFONT font;
-	char text[1024];
+    char text[1024];
     double angle;
+    double width;
 } NOTES;
Modified: grass-addons/postscript/ps.output/palettes.c
--- grass-addons/postscript/ps.output/palettes.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/palettes.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -30,7 +30,7 @@
     return i;
-int PS_str_to_color(char *name, PSCOLOR *color)
+int PS_str_to_color(char *name, PSCOLOR * color)
     int i;
@@ -47,6 +47,16 @@
     return 0;
+void PL_set_name(int k, char *name, int i)
+    if (Palette[k].h < 0.)    Palette[k].h += 360.;
+    if (Palette[k].h >= 360.) Palette[k].h -= 360.;
+    sprintf(Palette[k].name, "%s%d", name, i);
 /* pure colors: color-wheel */
 int pure_color(char *name, int div)
@@ -56,21 +66,44 @@
     /* alloc memory */
     k = palette_new(div);
-    step = 360./div;
+    step = 360. / div;
     for (i = 0; i < div; i++, k++)
-        Palette[k].h = (double)i * step;
+        Palette[k].h = (double)i *step;
         Palette[k].s = 1.;
         Palette[k].v = 1.;
-        sprintf(Palette[k].name, "%s%d", name, i);
+        sprintf(Palette[k].name, "%s%d", name, i+1);
     return 1;
+/* gray color: white to black */
+int gray(char *name, int div)
+    int i, k;
+    double step;
+    /* alloc memory */
+    k = palette_new(div);
+    step = (div > 1) ? (1. / (double)(div - 1)) : 0.;
+    for (i = 0; i < div; i++, k++)
+        Palette[k].h = 0.;
+        Palette[k].s = 0.;
+        Palette[k].v = (double)i * step; /* ((double)i * step) ^ (1.5) */
+    return 1;
 /* monochrome color: white to color */
-int monochrome(char *name, PSCOLOR *rgb, int div)
+int monochrome(char *name, PSCOLOR * rgb, int div)
     int i, k;
     double step;
@@ -86,141 +119,151 @@
     /* alloc memory */
-    if (div > 1) {
-        step = 1./(double)(div-1);
         Palette[k].h = hsv.h;
         Palette[k].s = (double)i * step;
-        Palette[k].v = 1.;
+        Palette[k].v = 1. + (double)i * step * (hsv.v - 1.); /* if pure v = 1. */
     return 1;
-/* gradient */
-int gradient(char *name, PSCOLOR *A, PSCOLOR *B, int div, int pure)
+/* complementary or contrast color */
+int complementary(char *name, PSCOLOR * rgb, int div, double sector)
     int i, k;
-    double hstep, sstep, vstep;
-    PALETTE pal_A, pal_B;
+    double step;
+    PALETTE hsv;
-    RGB_HSV(A, &pal_A);
-    RGB_HSV(B, &pal_B);
+    RGB_HSV(rgb, &hsv);
-    if (pal_A.h == pal_B.h)
-        return 0;
-    if (pal_B.h < pal_A.h) {
-        i = pal_A.h;
-        pal_A.h = pal_B.h;
-        pal_B.h = i;
     /* alloc memory */
+    step = (div > 1) ? (sector / (double)(div - 1)) : 0.;
-    hstep = (pal_B.h - pal_A.h)/(div-1.);
-    sstep = (pal_B.s - pal_A.s)/(div-1.);
-    vstep = (pal_B.v - pal_A.v)/(div-1.);
+    hsv.h += 180.;
+    if (div > 1)
+        hsv.h -= (sector/2.);
-        Palette[k].h = pal_A.h + (double)i * hstep;
-        Palette[k].s = pure ? 1. : pal_A.s + (double)i * sstep;
-        Palette[k].v = pure ? 1. : pal_A.v + (double)i * vstep;
+        Palette[k].h = hsv.h + (double)i * step;
+        Palette[k].s = hsv.s;
+        Palette[k].v = hsv.v;
     return 1;
 /* analogous or similar color */
-int analogous(char *name, PSCOLOR *rgb, int div)
+int analogous(char *name, PSCOLOR * rgb, int div, double sector)
     int i, k;
-    double h, step;
+    double step;
     PALETTE hsv;
     RGB_HSV(rgb, &hsv);
     /* alloc memory */
-    if (div > 1) {
-        hsv.h -= 40.;
-        step = 80./(double)(div-1);
+    if (div > 1)
-        Palette[k].h = hsv.h + (double)i * step;
+        Palette[k].h = hsv.h + (double)i *step;
-        Palette[k].s = hsv.s;
-        Palette[k].v = hsv.v;
     return 1;
-/* complementary or contrast color */
-int complementary(char *name, PSCOLOR *rgb, int div)
+/* gradient */
+int gradient(char *name, PSCOLOR * A, PSCOLOR * B, int div, int pure)
     int i, k;
-    double step;
-    PALETTE hsv;
+    double h_step, s_step, v_step;
+    PALETTE pal_A, pal_B;
-    RGB_HSV(rgb, &hsv);
+    RGB_HSV(A, &pal_A);
+    RGB_HSV(B, &pal_B);
+    if (pal_A.h == pal_B.h || div < 2)
+        return 0;
     /* alloc memory */
-    if (div > 1) {
-        hsv.h += 140.;
-    else {
-        hsv.h += 180.;
+    if (pal_A.h < pal_B.h)
+        pal_A.h += 360;
+    h_step = (pal_B.h - pal_A.h) / (div - 1.);
+    s_step = (pal_B.s - pal_A.s) / (div - 1.);
+    v_step = (pal_B.v - pal_A.v) / (div - 1.);
-        if (Palette[k].h < 0.)
-            Palette[k].h += 360.;
-        if (Palette[k].h >= 360.)
-            Palette[k].h -= 360.;
+        Palette[k].h = pal_A.h + (double)i * h_step;
+        Palette[k].s = pure ? 1. : pal_A.s + (double)i * s_step;
+        Palette[k].v = pure ? 1. : pal_A.v + (double)i * v_step;
     return 1;
-/* gray color */
-int gray(char *name, int div)
+/* diverging */
+int diverging(char *name, PSCOLOR * A, PSCOLOR * B, int div)
     int i, k;
-    double step;
+    double h_step, v_step, tmp;
+        return 0;
     /* alloc memory */
-    if (div > 1) {
-    for (i = 0; i < div; i++, k++)
+        pal_A.h += 360;
+    div -= 1;
+    h_step = (pal_B.h - pal_A.h) / div;
+    v_step = (pal_B.v - pal_A.v) / div;
+    for (i = 0; i < (div+1); i++, k++)
-        Palette[k].h = 0.;
-        Palette[k].s = 0.;
-        Palette[k].v = (double)i * step;
+        tmp = (2. * i / div - 1.);
+        Palette[k].s = tmp * tmp;
+        Palette[k].v = pal_A.v + (double)i * v_step;
     return 1;
@@ -232,98 +275,107 @@
 /* r, g, b values are from 0 to 1
- * h = [0,360], s = [0,1], v = [0,1]
-void RGB_HSV(PSCOLOR *col, PALETTE *pal)
+   h = [0,360], s = [0,1], v = [0,1]
+void RGB_HSV(PSCOLOR * col, PALETTE * pal)
-    double min, max;
+    double min, max, delta;
+    int r_max = 1, b_max = 0;
-    if (col->r == col->g && col->g == col->b)
+    min = max = col->r;
+    if(min > col->g)
-        pal->h = pal->s = 0.;   /* achromatic, gray */
-        pal->v = col->b;
+        if(col->b < col->g)
+            min = col->b;
+        else
+            min = col->g;
+            if(col->b > col->r)
+                max = col->b;
+                b_max = 1;
+                r_max = 0;
+    else
+        if(col->b > col->g)
+            max = col->b;
+            b_max = 1;
+            r_max = 0;
+        else
+            max = col->g;
+            r_max = 0;
+            if(col->b < col->r)
+                min = col->b;
+    pal->v = max;
+    if( max == 0 || (delta = max - min) == 0)
+        pal->s = pal->h = 0;
         return;
-    else if (col->r > col->g && col->r > col->b)
+    pal->s = delta / max;
+    if (r_max == 1)
-        max = col->r;
-        min = (col->g < col->b) ? col->g : col->b;
-        pal->h = (col->g - col->b)/(max - min);
+        pal->h = ( col->g - col->b ) / delta;
-    else if (col->g > col->b && col->g > col->r)
+    else if (b_max == 1)
-        max = col->g;
-        min = (col->r < col->b) ? col->r : col->b;
-        pal->h = 2. + (col->b - col->r)/(max - min);
+        pal->h = 4 + ( col->r - col->g ) / delta;
     else
-        max = col->b;
-        min = (col->g < col->r) ? col->g : col->r;
-        pal->h = 4. + (col->r - col->g)/(max - min);
+        pal->h = 2 + ( col->b - col->r ) / delta;
-    /* hue */
     pal->h *= 60.;
-    if (pal->h < 0.) pal->h += 360.;
-    /* saturation */
-    pal->s = (max - min) / max;
-    /* value */
-    pal->v = max;
+    if (pal->h < 0)
+        pal->h += 360.;
     return;
-void HSV_RGB(PALETTE *pal, PSCOLOR *col)
+void HSV_RGB(PALETTE * pal, PSCOLOR * col)
-    if (pal->s == 0) {
+    if (pal->s == 0)
         col->r = col->g = col->b = pal->v;
         return;
+    double f, p, q, t;
     int i;
-    double f, p, q, t;
-    i = floor(pal->h/60.);
-    f = pal->h/60. - (double)i;
-    p = pal->v * ( 1. - pal->s );
-    q = pal->v * ( 1. - pal->s * f );
-    t = pal->v * ( 1. - pal->s * ( 1. - f ) );
+//     f = modf(pal->h * 60, &t);
+//     i = ((int) t) % 60;
+    i = floor(pal->h / 60.);
+    f = pal->h / 60. - (double)i;
+    p = pal->v * (1. - pal->s);
+    q = pal->v * (1. - pal->s * f);
+    t = pal->v * (1. - pal->s * (1. - f));
     switch (i)
-        case 0:
-            col->r = pal->v;
-            col->g = t;
-            col->b = p;
-            break;
-        case 1:
-            col->r = q;
-            col->g = pal->v;
-            col->b = p;
-            break;
-        case 2:
-            col->r = p;
-            col->g = pal->v;
-            col->b = t;
-            break;
-        case 3:
-            col->r = p;
-            col->g = q;
-            col->b = pal->v;
-            break;
-        case 4:
-            col->r = t;
-            col->g = p;
-            col->b = pal->v;
-            break;
-        default: /* 5 */
-            col->r = pal->v;
-            col->g = p;
-            col->b = q;
-            break;
+    case 0: col->r = pal->v; col->g = t;      col->b = p;      break;
+    case 1: col->r = q;      col->g = pal->v; col->b = p;      break;
+    case 2: col->r = p;      col->g = pal->v; col->b = t;      break;
+    case 3: col->r = p;      col->g = q;      col->b = pal->v; break;
+    case 4: col->r = t;      col->g = p;      col->b = pal->v; break;
+    case 5: col->r = pal->v; col->g = p;      col->b = q;      break;
+    default:
+        col->none = 1;
Modified: grass-addons/postscript/ps.output/palettes.h
--- grass-addons/postscript/ps.output/palettes.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/palettes.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,11 +19,11 @@
 #ifdef MAIN
-    PALETTE *Palette;
-    int ncolors;
+PALETTE *Palette;
+int ncolors;
 #else
-    extern PALETTE *Palette;
-    extern int ncolors;
+extern PALETTE *Palette;
+extern int ncolors;
 #endif
Modified: grass-addons/postscript/ps.output/papers.c
--- grass-addons/postscript/ps.output/papers.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/papers.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,27 +16,47 @@
 PAPER papers[] = {
-        {"B0",        2920, 4127, 36., 36., 72., 72.},
-        {"B1",        2064, 2920, 36., 36., 72., 72.},
-        {"B2",        1460, 2064, 36., 36., 72., 72.},
-        {"B3",        1032, 1460, 36., 36., 72., 72.},
-        {"B4",         729, 1032, 36., 36., 72., 72.},
-        {"B5",         516,  729, 36., 36., 72., 72.},
-        {"B6",         363,  516, 36., 36., 72., 72.},
-        {"A6",         297,  420, 36., 36., 72., 72.},
-        {"A5",         420,  595, 36., 36., 72., 72.},
-        {"A4",         595,  842, 36., 36., 72., 72.},
-        {"A3",         842, 1191, 36., 36., 72., 72.},
-        {"A2",        1191, 1684, 36., 36., 72., 72.},
-        {"A1",        1684, 2384, 36., 36., 72., 72.},
-        {"A0",        2384, 3370, 36., 36., 72., 72.},
-        {"Legal",      612, 1008, 36., 36., 72., 72.},
-        {"Ledger",    1224,  792, 36., 36., 72., 72.},
-        {"Letter",     612,  792, 36., 36., 72., 72.},
-        {"Tabloid",    792, 1224, 36., 36., 72., 72.},
-        {"Executive",  522,  756, 36., 36., 72., 72.},
-        {"Folio",      595,  935, 36., 36., 72., 72.},
-        {NULL,           0,    0,  0.,  0.,  0.,  0.}
+    {"B0", 2920, 4127, 36., 36., 72., 72.}
+    {"B1", 2064, 2920, 36., 36., 72., 72.}
+    {"B2", 1460, 2064, 36., 36., 72., 72.}
+    {"B3", 1032, 1460, 36., 36., 72., 72.}
+    {"B4", 729, 1032, 36., 36., 72., 72.}
+    {"B5", 516, 729, 36., 36., 72., 72.}
+    {"B6", 363, 516, 36., 36., 72., 72.}
+    {"A6", 297, 420, 36., 36., 72., 72.}
+    {"A5", 420, 595, 36., 36., 72., 72.}
+    {"A4", 595, 842, 36., 36., 72., 72.}
+    {"A3", 842, 1191, 36., 36., 72., 72.}
+    {"A2", 1191, 1684, 36., 36., 72., 72.}
+    {"A1", 1684, 2384, 36., 36., 72., 72.}
+    {"A0", 2384, 3370, 36., 36., 72., 72.}
+    {"Legal", 612, 1008, 36., 36., 72., 72.}
+    {"Ledger", 1224, 792, 36., 36., 72., 72.}
+    {"Letter", 612, 792, 36., 36., 72., 72.}
+    {"Tabloid", 792, 1224, 36., 36., 72., 72.}
+    {"Executive", 522, 756, 36., 36., 72., 72.}
+    {"Folio", 595, 935, 36., 36., 72., 72.}
+    {NULL, 0, 0, 0., 0., 0., 0.}
 int set_paper(char *name)
@@ -45,16 +65,16 @@
     for (i = 0; papers[i].name != NULL; i++)
-        if (strcmp(papers[i].name, name) == 0)
-            PS.page.width  = papers[i].width;
-            PS.page.height = papers[i].height;
-            PS.page.left   = papers[i].left;
-            PS.page.right  = papers[i].right;
-            PS.page.top    = papers[i].top;
-            PS.page.bot    = papers[i].bot;
-            return 1;
+	if (strcmp(papers[i].name, name) == 0)
+	    PS.page.width = papers[i].width;
+	    PS.page.height = papers[i].height;
+	    PS.page.left = papers[i].left;
+	    PS.page.right = papers[i].right;
+	    PS.page.top = papers[i].top;
+	    PS.page.bot = papers[i].bot;
+	    return 1;
     return 0;
Modified: grass-addons/postscript/ps.output/papers.h
--- grass-addons/postscript/ps.output/papers.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/papers.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -11,11 +11,15 @@
  *             for details.
+#include "colors.h"
 typedef struct
     char *name;
     int width, height;
     double left, right, top, bot;
+    PSCOLOR fcolor;
 } PAPER;
 #endif
Modified: grass-addons/postscript/ps.output/proj_geo.c
--- grass-addons/postscript/ps.output/proj_geo.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/proj_geo.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -24,20 +24,20 @@
     /* Get projection info for output mapset */
     if ((out_proj_info = G_get_projinfo()) == NULL)
-        G_fatal_error(_("Unable to get projection info of output raster map"));
+	G_fatal_error(_("Unable to get projection info of output raster map"));
     if ((out_unit_info = G_get_projunits()) == NULL)
-        G_fatal_error(_("Unable to get projection units of output raster map"));
+	G_fatal_error(_("Unable to get projection units of output raster map"));
     if (pj_get_kv(oproj, out_proj_info, out_unit_info) < 0)
-        G_fatal_error(_("Unable to get projection key values of output raster map"));
+	G_fatal_error(_("Unable to get projection key values of output raster map"));
     G_free_key_value(out_proj_info);
     G_free_key_value(out_unit_info);
     /* In Info */
     if (GPJ_get_equivalent_latlong(iproj, oproj) < 0)
-        G_fatal_error(_("Unable to set up lat/long projection"));
+	G_fatal_error(_("Unable to set up lat/long projection"));
     return;
@@ -46,42 +46,39 @@
 int find_limits(double *north, double *south,
-                double *east, double *west,
-                struct pj_info *ll_proj,
-                struct pj_info *xy_proj)
+		double *east, double *west, struct pj_info *ll_proj, struct pj_info *xy_proj)
     int x, y;
     double d, z;
     /* West */
     if (PS.map.west < 500000)
-        G_plot_where_en(10.*PS.map_x, 10.*PS.map_top, west, &d);
+	G_plot_where_en(10. * PS.map_x, 10. * PS.map_top, west, &d);
     else
-        G_plot_where_en(10.*PS.map_x, 10.*PS.map_y, west, &d);
-    pj_do_proj(west, &d, xy_proj, ll_proj);                            /* UTM > LL */
+	G_plot_where_en(10. * PS.map_x, 10. * PS.map_y, west, &d);
+    pj_do_proj(west, &d, xy_proj, ll_proj);	/* UTM > LL */
     /* East */
-        G_plot_where_en(10.*PS.map_right, 10.*PS.map_top, east, &d);
+	G_plot_where_en(10. * PS.map_right, 10. * PS.map_top, east, &d);
     else
-        G_plot_where_en(10.*PS.map_right, 10.*PS.map_y, east, &d);
-    pj_do_proj(east, &d, xy_proj, ll_proj);                            /* UTM > LL */
+	G_plot_where_en(10. * PS.map_right, 10. * PS.map_y, east, &d);
+    pj_do_proj(east, &d, xy_proj, ll_proj);	/* UTM > LL */
     /* d previous */
     z = (6. * PS.map.zone - 183.);
-    pj_do_proj(&z, &d, ll_proj, xy_proj);                              /* LL > UTM */
-    G_plot_where_xy(z, d, &x, &y);                                  /* UTM > XY */
+    pj_do_proj(&z, &d, ll_proj, xy_proj);	/* LL > UTM */
+    G_plot_where_xy(z, d, &x, &y);	/* UTM > XY */
     /* North */
-    G_plot_where_en(x, 10.*PS.map_top, &d, north);                  /* XY > UTM */
-    pj_do_proj(&d, north, xy_proj, ll_proj);                           /* UTM > LL */
+    G_plot_where_en(x, 10. * PS.map_top, &d, north);	/* XY > UTM */
+    pj_do_proj(&d, north, xy_proj, ll_proj);	/* UTM > LL */
     /* South */
-    z = (double)x/10.;
+    z = (double)x / 10.;
     if ((z - PS.map_x) > (PS.map_right - z))
-        G_plot_where_en(10.*PS.map_x, 10.*PS.map_y, &d, south);     /* XY > UTM */
+	G_plot_where_en(10. * PS.map_x, 10. * PS.map_y, &d, south);	/* XY > UTM */
     else
-        G_plot_where_en(10.*PS.map_right, 10.*PS.map_y, &d, south); /* XY > UTM */
-    pj_do_proj(&d, south, xy_proj, ll_proj);                           /* UTM > LL */
+	G_plot_where_en(10. * PS.map_right, 10. * PS.map_y, &d, south);	/* XY > UTM */
+    pj_do_proj(&d, south, xy_proj, ll_proj);	/* UTM > LL */
Modified: grass-addons/postscript/ps.output/ps3_map.c
--- grass-addons/postscript/ps.output/ps3_map.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/ps3_map.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -22,149 +22,158 @@
 int PS3_map(void)
-    int i;
+    int i, j;
     double d;
     /* PostScript header */
-    fprintf(PS.fp, "%%!PS-Adobe-3.0\n");
-    fprintf(PS.fp, "%%%%BoundingBox: 0 0 %d %d\n",
-            (int)(PS.page.width),
-            (int)(PS.page.height));
-    fprintf(PS.fp, "%%%%Title: \n");
-    fprintf(PS.fp, "%%%%Creator: \n");
-    fprintf(PS.fp, "%%%%CreationDate: %s\n", G_date());
-    fprintf(PS.fp, "%%%%Programming: E. Jorge Tizado, Spain 2009\n");
-    fprintf(PS.fp, "%%%%EndComments\n\n");
-    fprintf(PS.fp, "%%%%BeginProlog\n");
-    fprintf(PS.fp, "/D {bind def} bind def\n");
-    fprintf(PS.fp, "/XD {exch def} D\n");
-    /* STRING MANIPULATION */
-    fprintf(PS.fp, "/str 20 string def\n");
-    fprintf(PS.fp, "/to_s {str cvs} D\n");
-    /* (a) (b) -> (ab) */
-    fprintf(PS.fp, "/adds { "
-            "exch dup length "
-            "2 index length add string dup dup 4 2 roll copy length "
-            "4 -1 roll putinterval} D\n");
-    /* Orden alfabetico */
-    fprintf(PS.fp, "/++ {1 add} D\n");
-    fprintf(PS.fp, "/-- {1 sub} D\n");
-    fprintf(PS.fp, "/mm {360 mul 127 div} D\n");
-    fprintf(PS.fp, "/inch {72 mul} D\n");
+    fprintf(PS.fp, "%%!PS-Adobe-3.0 %s\n", PS.level == 0 ? "EPS 1.2" : "");
+    fprintf(PS.fp, "%%%%BoundingBox: 0 0 %d %d\n", (int)(PS.page.width), (int)(PS.page.height));
+    fprintf(PS.fp,
+        "%%%%Title: \n"
+        "%%%%Creator: \n"
+        "%%%%CreationDate: %s\n"
+        "%%%%Programming: E. Jorge Tizado, Spain 2009\n"
+        "%%%%EndComments\n\n", G_date());
+    /* BEGIN NO EMBEBED EPS file */
+    if (PS.level > 0)
+	fprintf(PS.fp, "%%%%BeginProlog\n");
+	fprintf(PS.fp, "/D {bind def} bind def\n");
+	fprintf(PS.fp, "/XD {exch def} D\n");
+	fprintf(PS.fp, "/str 20 string def\n");
+	fprintf(PS.fp, "/i2s {str cvs} D\n");
+	fprintf(PS.fp, "/c2s {/charcode exch def /thechar ( ) dup 0 charcode put def thechar} D\n");
+        fprintf(PS.fp, "/adds { exch dup length 2 index length add string dup dup 4 2 roll copy length " "4 -1 roll putinterval} D\n");
+	fprintf(PS.fp,
+		"/FN { % (FontName) FN -\n"
+		"    dup (-ISOLatin1) adds dup /F0 exch cvn def exch cvn\n"
+		"    currentdict F0 known {pop pop}\n"
+		"    {findfont dup length dict begin {1 index /FID ne {def} {pop pop} ifelse } forall\n"
+		"        /Encoding ISOLatin1Encoding def\n"
+		"        /FontName 0 index def\n" "        currentdict end definefont pop} ifelse} D\n");
+	fprintf(PS.fp, "/FS {/FS0 exch def F0 findfont FS0 scalefont setfont} D\n");
+    fprintf(PS.fp, "/FE {F0 findfont 3 1 roll 1 index dup /FS0 exch def mul 0 0 4 -1 roll 0 0 6 packedarray makefont setfont} D\n");
+	fprintf(PS.fp, "/FA {currentfont [1 0 0 1.25 0 0] makefont setfont} D\n");
+    fprintf(PS.fp, "/FR {currentfont [1 0 0 .707 0 %d] makefont setfont} D\n", ((PS.flag & 2) ? 0: 2));
+	fprintf(PS.fp, "/++ {1 add} D\n");
+	fprintf(PS.fp, "/-- {1 sub} D\n");
+	fprintf(PS.fp, "/mm {360 mul 127 div} D\n");
+	fprintf(PS.fp, "/inch {72 mul} D\n");
     fprintf(PS.fp, "/B {4 1 roll 2 copy 5 index 5 index 8 1 roll newpath moveto lineto lineto lineto closepath} D\n");
-    fprintf(PS.fp, "/C {setrgbcolor} D\n");
-    fprintf(PS.fp, "/cLW {currentlinewidth} D\n");
-    fprintf(PS.fp, "/cP {currentpoint} D\n");
-    fprintf(PS.fp, "/CP {closepath} D\n");
-    fprintf(PS.fp, "/CS {closepath stroke} D\n");
-    fprintf(PS.fp, "/F {gsave fill grestore} D\n");
-    fprintf(PS.fp, "/G {setgray} D\n");
-    fprintf(PS.fp, "/GET {get aload pop} D\n");
-    fprintf(PS.fp, "/CG {0.11 mul exch 0.59 mul add exch 0.30 mul add setgray} D\n");
-    fprintf(PS.fp, "/GS {gsave} D\n");
-    fprintf(PS.fp, "/GR {grestore} D\n");
-    fprintf(PS.fp, "/LC {setlinecap} D\n");
-    fprintf(PS.fp, "/LD {setdash} D\n");
-    fprintf(PS.fp, "/LJ {setlinejoin} D\n");
-    fprintf(PS.fp, "/L {lineto} D\n");
-    fprintf(PS.fp, "/LS {lineto stroke} D\n");
-    fprintf(PS.fp, "/LR {rlineto} D\n");
-    fprintf(PS.fp, "/LRS {rlineto stroke} D\n");
-    fprintf(PS.fp, "/LW {setlinewidth} D\n");
-    fprintf(PS.fp, "/M {moveto} D\n");
-    fprintf(PS.fp, "/ML {moveto lineto stroke} D\n");
-    fprintf(PS.fp, "/MR {rmoveto} D\n");
-    fprintf(PS.fp, "/MS {moveto show} D\n");
-    fprintf(PS.fp, "/NM {newpath moveto} D\n");
-    fprintf(PS.fp, "/NP {newpath} D\n");
-    fprintf(PS.fp, "/RE {rectstroke} D\n");
-    fprintf(PS.fp, "/Re {currentpoint 4 2 roll rectstroke} D\n");   /* stack: w h */
-    fprintf(PS.fp, "/RES {gsave newpath false charpath flattenpath pathbbox grestore} D\n"); /* llx lly urx ury of a string: stack string */
-    fprintf(PS.fp, "/RF {rectfill} D\n");
-    fprintf(PS.fp, "/Rf {currentpoint 4 2 roll rectfill} D\n");   /* stack: w h */
-    fprintf(PS.fp, "/RC {rectclip} D\n");
-    fprintf(PS.fp, "/ROT {rotate} D\n");
-    fprintf(PS.fp, "/S {stroke} D\n");
-    fprintf(PS.fp, "/SC {scale} D\n");
-    fprintf(PS.fp, "/SHL {show} D\n");
-    fprintf(PS.fp, "/SHR {dup stringwidth pop neg 0 rmoveto show} D\n");
-    fprintf(PS.fp, "/SHC {dup stringwidth pop 2 div neg 0 rmoveto show} D\n");
-    fprintf(PS.fp, "/SHCC {dup SWH 2 div neg exch 2 div neg exch rmoveto show} D\n");
+	fprintf(PS.fp, "/C {setrgbcolor} D\n");
+	fprintf(PS.fp, "/cLW {currentlinewidth} D\n");
+	fprintf(PS.fp, "/cP {currentpoint} D\n");
+	fprintf(PS.fp, "/CP {closepath} D\n");
+	fprintf(PS.fp, "/CS {closepath stroke} D\n");
+	fprintf(PS.fp, "/F {gsave fill grestore} D\n");
+	fprintf(PS.fp, "/G {setgray} D\n");
+	fprintf(PS.fp, "/GET {get aload pop} D\n");
+	fprintf(PS.fp, "/CG {0.11 mul exch 0.59 mul add exch 0.30 mul add setgray} D\n");
+	fprintf(PS.fp, "/GS {gsave} D\n");
+	fprintf(PS.fp, "/GR {grestore} D\n");
+	fprintf(PS.fp, "/LC {setlinecap} D\n");
+	fprintf(PS.fp, "/LD {setdash} D\n");
+	fprintf(PS.fp, "/LJ {setlinejoin} D\n");
+	fprintf(PS.fp, "/L {lineto} D\n");
+	fprintf(PS.fp, "/LS {lineto stroke} D\n");
+	fprintf(PS.fp, "/LR {rlineto} D\n");
+	fprintf(PS.fp, "/LRS {rlineto stroke} D\n");
+	fprintf(PS.fp, "/LW {setlinewidth} D\n");
+	fprintf(PS.fp, "/M {moveto} D\n");
+	fprintf(PS.fp, "/ML {moveto lineto stroke} D\n");
+	fprintf(PS.fp, "/MR {rmoveto} D\n");
+	fprintf(PS.fp, "/MS {moveto show} D\n");
+	fprintf(PS.fp, "/NM {newpath moveto} D\n");
+	fprintf(PS.fp, "/NP {newpath} D\n");
+    fprintf(PS.fp, "/O {%s} D\n", ((PS.flag & 1) ? ".setopacityalpha" : "pop"));
+	fprintf(PS.fp, "/RE {rectstroke} D\n");
+    fprintf(PS.fp, "/Re {currentpoint 4 2 roll rectstroke} D\n");
+    fprintf(PS.fp, "/RES {gsave newpath false charpath flattenpath pathbbox grestore} D\n");
+	fprintf(PS.fp, "/RF {rectfill} D\n");
+    fprintf(PS.fp, "/Rf {currentpoint 4 2 roll rectfill} D\n");
+	fprintf(PS.fp, "/RC {rectclip} D\n");
+	fprintf(PS.fp, "/ROT {rotate} D\n");
+	fprintf(PS.fp, "/S {stroke} D\n");
+	fprintf(PS.fp, "/SC {scale} D\n");
     fprintf(PS.fp, "/SW {stringwidth pop} D\n");
-    /* w h of a string: stack string */
-    fprintf(PS.fp, "/SWH {gsave newpath 0 0 moveto false charpath flattenpath pathbbox "
-                   "4 2 roll pop pop grestore} D\n");
-    /* max string width of an array of string: stack array */
-    fprintf(PS.fp, "/SWx {0 exch {stringwidth pop dup 2 index gt {exch} if pop} forall} def\n");
-    fprintf(PS.fp, "/TR {translate} D\n");
-    fprintf(PS.fp, /* borde exterior del rectangulo: x y w h RO */
-            "/RO {gsave dup cLW exch 0 lt {neg} if add exch cLW add exch "
-            "cLW -2 div dup 2 index 0 lt {neg} if TR RE grestore} D\n");
-    /* stack none */
-    fprintf(PS.fp, "/RESET {/x xo mgx add def /y yo mgy sub def /col 0 def /row 0 def} def\n");
-    /* stack number of col/row 0...n-1 */
-    fprintf(PS.fp, "/COL {/col XD xo mgx add 0 1 col -- {ARw exch get dx add add} for /x XD} def\n");
-    fprintf(PS.fp, "/ROW {/row XD yo mgy sub 0 1 row -- {ARh exch get dy add sub} for /y XD} def\n");
-    /* set fontname with re-encoding */
-    fprintf(PS.fp,
-            "/FN { % (FontName) FN -\n"
-            "    dup (-ISOLatin1) adds dup /F0 exch cvn def exch cvn\n"
-            "    currentdict F0 known {pop pop}\n"
-            "    {findfont dup length dict begin {1 index /FID ne {def} {pop pop} ifelse } forall\n"
-            "        /Encoding ISOLatin1Encoding def\n"
-            "        /FontName 0 index def\n"
-            "        currentdict end definefont pop} ifelse} D\n");
-    /* set fontsize */
-    fprintf(PS.fp, "/FS {/F0S exch def F0 findfont F0S scalefont setfont} D\n");
-    fprintf(PS.fp, "/FE {F0 findfont 3 1 roll 1 index mul 0 0 4 -1 roll 0 0 6 packedarray makefont setfont} D\n");
-    /* trying transparency compatibility */
-    /* fprintf(PS.fp, "/pdfmark where {pop} {userdict /pdfmark /cleartomark load put} ifelse\n"); */
-    /* end */
-    fprintf(PS.fp, "%%%%EndProlog\n");
-    /* Page specifications */
-    fprintf(PS.fp, "<< /PageSize [%d %d] >> setpagedevice\n",
-            (int)(PS.page.width), (int)(PS.page.height));
+    fprintf(PS.fp, "/SWH {gsave newpath 0 0 moveto false charpath flattenpath pathbbox " "4 2 roll pop pop grestore} D\n");
+	fprintf(PS.fp, "/SHL {show} D\n");
+	fprintf(PS.fp, "/SHR {dup SW neg 0 rmoveto show} D\n");
+	fprintf(PS.fp, "/SHC {dup SW -2 div 0 rmoveto show} D\n");
+	fprintf(PS.fp, "/SHLC {dup SWH -2 div 0 exch rmoveto pop show} D\n");
+	fprintf(PS.fp, "/SHRC {dup SWH -2 div exch neg exch rmoveto show} D\n");
+	fprintf(PS.fp, "/SHCC {dup SWH -2 div exch 2 div neg exch rmoveto show} D\n");
+    fprintf(PS.fp, "/SHS {(:) anchorsearch {pop exch 0 rmoveto SHR} {(.) anchorsearch {pop exch 2 div 0 rmoveto SHC} {exch pop SHL} ifelse} ifelse} D\n");
+    fprintf(PS.fp, "/COOR {(º) search {GS SHL SHL FR SHL GR} {dup length /n XD {c2s GS n 4 lt n 5 gt or {FR} if show cP GR M n -- /n XD} forall} ifelse} D\n");
+	fprintf(PS.fp, "/SVC {{c2s GS SHC GR 0 FS0 neg MR} forall} D\n");
+    fprintf(PS.fp, "/SWx {0 exch {SW 2 copy lt {exch} if pop} forall} D\n");
+	fprintf(PS.fp, "/TR {translate} D\n");
+    fprintf(PS.fp, "/TSEL {(:) anchorsearch {pop SHR} {(.) anchorsearch {pop SHC} {SHL} ifelse} ifelse} D\n");
+    fprintf(PS.fp, "/TXT {(|) search {GS TSEL GR pop 0 FS0 -1.2 mul rmoveto TXT} {TSEL} ifelse} D\n");
+    fprintf(PS.fp, "/TCIR {SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add cP 3 -1 roll 0 360 NP arc CP S} D\n");
+    fprintf(PS.fp, "/RO {GS dup cLW exch 0 lt {neg} if add exch cLW add exch cLW -2 div dup 2 index 0 lt {neg} if TR RE GR} D\n");
+	fprintf(PS.fp, "/RESET {/x xo mgx add def /y yo mgy sub def /col 0 def /row 0 def} def\n");
+    fprintf(PS.fp, "/READJUST {SWH mg add dup hg add /hg XD mg add /mgy XD mgx 2 mul add dup wd gt {/wd XD} {pop} ifelse} def\n");
+	fprintf(PS.fp, "/COL {/col XD xo mgx add 0 1 col -- {ARw exch get dx add add} for /x XD} def\n");
+	fprintf(PS.fp, "/ROW {/row XD yo mgy sub 0 1 row -- {ARh exch get dy add sub} for /y XD} def\n");
+	/* end */
+	fprintf(PS.fp, "%%%%EndProlog\n");
+	/* Page specifications */
+	fprintf(PS.fp, "<< /PageSize [%d %d] >> setpagedevice\n", (int)(PS.page.width), (int)(PS.page.height));
+    /* END NO EPS file */
     /* Prepare the map */
     start_map();
-    if (PS.draft) /* print a reticule as watermark of page */
+    if (!PS.page.fcolor.none)
-        fprintf(PS.fp, ".5 LW 0.9 G\n");
-        fprintf(PS.fp, "0 28.35 %d {0 M 0 %d LR S} for\n",
-        fprintf(PS.fp, "%d -28.35 0 {0 exch M %d 0 LR S} for\n",
-                (int)(PS.page.height), (int)(PS.page.width));
+	set_ps_color(&(PS.page.fcolor));
+	fprintf(PS.fp, "0 0 %d %d RF\n", (int)(PS.page.width), (int)(PS.page.height));
-    /* CLIP the MAP AREA */
-    fprintf(PS.fp, "gsave ");
-    fprintf(PS.fp, "%.4f %.4f %.4f %.4f rectclip\n",
-            PS.map_x, PS.map_y, PS.map_w, PS.map_h);
+    if (PS.draft) /* print a reticule as watermark on page */
+	fprintf(PS.fp, "GS .5 LW 0.9 G /Helvetica findfont 7 scalefont setfont\n");
+    fprintf(PS.fp, "0 0 10 mm %d {0 M GS 0.5 G 1 1 MR dup i2s show ++ GR 0 %d LRS} for pop\n",
+		(int)(PS.page.width), (int)(PS.page.height));
+    fprintf(PS.fp, "0 %d -10 mm 0 {0 exch M GS 0.5 G 1 1 MR dup i2s show ++ GR %d 0 LRS} for pop\n",
+		(int)(PS.page.height), (int)(PS.page.width));
+	fprintf(PS.fp, "[1 2] 0 LD \n");
+    fprintf(PS.fp, "5 mm 10 mm %d {0 M 0 %d LRS} for\n",
+    fprintf(PS.fp, "%d 5 mm sub -10 mm 0 {0 exch M %d 0 LRS} for\n",
+	fprintf(PS.fp, "GR\n");
+    /* PAPER CUSTOM DRAWS */
+    if (PS.n_draws > 0)
+	for (i = 0; i < PS.n_draws; i++)
+	    if (PS.draw.flag[i] == 2)
+		set_draw(PS.draw.key[i], PS.draw.data[i]);
+    /* CLIP to MAP AREA */
+    fprintf(PS.fp, "gsave 0 0 0 C ");
+    fprintf(PS.fp, "%.4f %.4f %.4f %.4f rectclip\n", PS.map_x, PS.map_y, PS.map_w, PS.map_h);
     if (!PS.fcolor.none)
-        set_ps_color(&(PS.fcolor));
-        fprintf(PS.fp, "%.4f %.4f %.4f %.4f RF\n",
+	set_ps_color(&(PS.fcolor));
+	fprintf(PS.fp, "%.4f %.4f %.4f %.4f RF\n", PS.map_x, PS.map_y, PS.map_w, PS.map_h);
     /* needed by uncolored patterns */
-    fprintf(PS.fp, "[/Pattern /DeviceRGB] setcolorspace NP\n");
+    fprintf(PS.fp, "[/Pattern /DeviceRGB] setcolorspace\n");
     /* RASTER */
-        set_raster();
-        /* outline, if requested */
-        if (PS.rst.outline.width > 0.)
-            if (!G_raster_map_is_fp(PS.rst.name[0], PS.rst.mapset[0]))
-                set_outline();
-            else
-                G_warning("Outline is not to float maps!, ignored");
+	set_raster();
+	/* outline, if requested */
+	if (PS.rst.outline.width > 0.)
+	    if (!G_raster_map_is_fp(PS.rst.name[0], PS.rst.mapset[0]))
+		set_outline();
+	    else
+		G_warning("Outline is not to float maps!, ignored");
     /* VECTOR (masked) */
     if (PS.vct_files != 0)
@@ -172,99 +181,126 @@
         set_vector(MASKED, AREAS);
         set_vector(MASKED, LINES);
         set_vector(MASKED, POINTS);
+        set_vector(MASKED, LABELS);
-    /* LABELS (masked) */
-//     set_labels(MASKED);
     /* RASTER MASK */
     if (PS.need_mask && PS.rst.do_mask)
-    	set_mask();
+	set_mask();
     /* VECTOR-LINES/AREAS under grids (unmasked) */
-        set_vector(UNMASKED, AREAS);
-        set_vector(UNMASKED, LINES);
+	set_vector(UNMASKED, AREAS);
+	set_vector(UNMASKED, LINES);
     /* CLIPED CUSTOM DRAWS */
     if (PS.n_draws > 0)
-        fprintf(PS.fp, "0 0 0 C "); /* default color */
-        for (i = 0; i < PS.n_draws; i++)
-            set_draw(PS.draw.key[i], PS.draw.data[i]);
+	/* fprintf(PS.fp, "0 0 0 C "); /* default color */
+	    if (PS.draw.flag[i] == 0)
     /* GRIDS LINES INSIDE OF BORDER  */
     if (PS.grid.sep > 0)
-        set_lines_grid();
+	set_lines_grid();
     if (PS.geogrid.sep > 0)
-        set_lines_geogrid();
+	set_lines_geogrid();
-    /* VECTOR-POINTS on grids (unmasked) */
+    /* VECTOR-POINTS/LABELS on grids (unmasked) */
-        set_vector(UNMASKED, POINTS);
+	set_vector(UNMASKED, POINTS);
+	set_vector(UNMASKED, LABELS);
     /* no more work in the map area */
     fprintf(PS.fp, "grestore\n");
     /* BORDER */
     if (PS.do_border && PS.brd.width > 0 && !PS.brd.color.none)
-        set_ps_line(&(PS.brd));
-        set_ps_rect(PS.map_x, PS.map_y, PS.map_w, PS.map_h);
+	set_ps_line(&(PS.brd));
+	set_ps_rect(PS.map_x, PS.map_y, PS.map_w, PS.map_h);
     /* GRID NUMBER, OUTSIDE OF BORDER */
-        set_numbers_geogrid();
+	set_numbers_geogrid();
-        set_numbers_grid();
+	set_numbers_grid();
     /* LEGENDS */
     if (PS.do_rlegend)
-        if (G_raster_map_is_fp(PS.rl.name, PS.rl.mapset) ||
-            PS.rl.do_gradient)
-            set_rlegend_gradient();
-        else
-            set_rlegend_cats();
+	if (G_raster_map_is_fp(PS.rl.name, PS.rl.mapset) || PS.rl.do_gradient)
+	    set_rlegend_gradient();
+	else
+	    set_rlegend_cats();
     if (PS.do_vlegend)
-        set_vlegend();
+	set_vlegend();
     /* NOTES */
     for (i = 0; i < PS.n_notes; i++)
-        set_note(i);
+	set_note(i);
     /* SCALEBAR */
-    if (PS.sbar.segments > 0 && PS.sbar.length > 0) {
-        set_scalebar();
+    if (PS.sbar.segments > 0 && PS.sbar.length > 0)
+	set_scalebar();
+    /* FREE CUSTOM DRAWS */
+	    if (PS.draw.flag[i] == 1)
     /* END */
-    fprintf(PS.fp, "showpage\n");
-    fprintf(PS.fp, "%%%%Trailer\n");
-    fprintf(PS.fp, "%%%%EOF\n");
-    fclose(PS.fp);
+    /* BEGIN NO EPS file */
+    if (PS.level > 0)
+	fprintf(PS.fp, "showpage\n");
+	fprintf(PS.fp, "%%%%Trailer\n");
+	fprintf(PS.fp, "%%%%EOF\n");
+	fclose(PS.fp);
     /* FREE ALLOCATED POINTERS */
     for (i = 0; i < PS.vct_files; i++)
-        G_free(PS.vct[i].data);
+	G_free(PS.vct[i].data);
+	G_free(PS.vct[i].item);
+	   for (j=0; j < PS.vct[i].n_rule; j++)
+	   G_free(PS.vct[i].rule->val_list);
+	G_free(PS.vct[i].rule);
     G_free(PS.vct);
-    if (Palette != NULL)
-        G_free(Palette);
+    G_free(Palette);
+       if (Palette != NULL) {
+       G_free(Palette);
     return 0;
Modified: grass-addons/postscript/ps.output/ps_info.h
--- grass-addons/postscript/ps.output/ps_info.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/ps_info.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -31,12 +31,14 @@
 struct PS3_info
     FILE *fp;
-    int level;              /* PostScript level */
-    int draft;              /* Grid of 1x1 cm */
-    char *mapset;           /* current mapset */
-    struct Cell_head map;   /* current region */
+    int level;			/* PostScript level: 0 = EPS */
+    int flag;			/* 1 = GhostScript, 2 = Upper numbers */
+    int draft;			/* Grid of 1x1 cm */
+    char *mapset;		/* current mapset */
+    struct Cell_head map;	/* current region */
-    int scale;              /* 1 : scale of the map */
+    int scale;			/* 1 : scale of the map */
+    PSFONT font;		/* default font of map */
     /* rasters */
     RASTER rst;
@@ -59,8 +61,8 @@
     SCALEBAR sbar;
     /* notes */
-    NOTES note[MAX_NOTES];      /* notes */
-    int n_notes;                /* number of notes */
+    NOTES note[MAX_NOTES];	/* notes */
+    int n_notes;		/* number of notes */
     /* draw commands */
     PSDRAW draw;
@@ -70,20 +72,18 @@
     PAPER page;
     /* dimension and location of the map */
+    double x, y;
     double map_x, map_y, map_w, map_h;
-    double map_top, map_right; /* to check outside */
+    double map_top, map_right;
-    /* current point to draw */
-    double x, y;
 #endif
 #ifdef MAIN
-    struct PS3_info PS;
-    int sec_draw;   /* used in PS_plot */
+struct PS3_info PS;
+int sec_draw;			/* used in PS_plot */
 #else
-    extern struct PS3_info PS;
-    extern int sec_draw;
+extern struct PS3_info PS;
+extern int sec_draw;
 #endif
Modified: grass-addons/postscript/ps.output/r_draw.c
--- grass-addons/postscript/ps.output/r_draw.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_draw.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -23,24 +23,32 @@
     char buf[1024];
     char *key, *data;
+    int type = 0;
     G_debug(1, "Reading draw settings ..");
+    if (strcmp(name, "free") == 0)
+	type = 1;
+    if (strcmp(name, "paper") == 0)
+	type = 2;
     while (input(2, buf))
-			continue;
+	    continue;
-        PS.draw.key[PS.n_draws]  = G_store(key);
-        PS.draw.data[PS.n_draws] = G_store(data);
-        ++PS.n_draws;
-        if (PS.n_draws == MAX_DRAWS)
-            error(key, data, "many draw commands sub-request");
+	/* TODO: permit command with ';' separation */
+	PS.draw.flag[PS.n_draws] = type;
+	PS.draw.key[PS.n_draws] = G_store(key);
+	PS.draw.data[PS.n_draws] = G_store(data);
+	++PS.n_draws;
+	if (PS.n_draws == MAX_DRAWS)
+	    error(key, data, "many draw commands sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_font.c
--- grass-addons/postscript/ps.output/r_font.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_font.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -11,6 +11,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "fonts.h"
+#include "ps_info.h"
 #include "local_proto.h"
 #define KEY(x) (strcmp(key,x)==0)
@@ -22,80 +23,89 @@
 int get_font(char *data)
     char *dp;
     G_strip(data);
     /* replace spaces with dashes and make sure each
-    ** word begins with a capital letter.
+     ** word begins with a capital letter.
     dp = data;
     if (*dp >= 'a' && *dp <= 'z')
-        *dp = *dp - 'a' + 'A';
-    while (*dp) {
-        if (*dp == ' ') {
-            *dp++ = '-';
-            if (*dp >= 'a' && *dp <= 'z')
-        else
-            dp++;
+	*dp = *dp - 'a' + 'A';
+    while (*dp)
+	if (*dp == ' ')
+	    *dp++ = '-';
+	    if (*dp >= 'a' && *dp <= 'z')
+	else
+	    dp++;
     return 0;
-int default_font(PSFONT *font)
+int default_font(PSFONT * font)
-    strcpy(font->name, "Helvetica");
-    font->size = 10.;
-    font->extend = 1.;
-    set_color_rgb(&(font->color), 0, 0, 0);
+    strcpy(font->name, PS.font.name);
+    font->size = PS.font.size;
+    font->extend = PS.font.extend;
+    set_color_pscolor(&(font->color), &(PS.font.color));
-int read_font(char *arg, PSFONT *font)
+int read_font(char *arg, PSFONT * font)
-	char buf[1024];
-	char *key, *data;
+    char buf[1024];
+    char *key, *data;
     G_debug(1, "Reading font settings ..");
-	/* init values */
+    /* init values */
     default_font(font);
-	while (input(3, buf))
+    while (input(3, buf))
-	        continue;
-        if (KEY("name")) {
-            get_font(data);
-            strcpy(font->name, data);
-            continue;
-        if (KEY("size")) {
-            if (scan_dimen(data, &(font->size)) != 1) {
-                font->size = 10.;
-                error(key, data, "illegal size request (font)");
-            continue;
-        if (KEY("extend")) {
-            if (scan_dimen(data, &(font->extend)) != 1) {
-                error(key, data, "illegal extent request (font)");
-            continue;
-        if (KEY("color")) {
-            if (!scan_color(data, &(font->color))) {
-                error(key, data, "illegal color request (font)");
-            continue;
-        error(key, data, "illegal font sub-request");
+	    continue;
+	if (KEY("name"))
+	    get_font(data);
+	    strcpy(font->name, data);
+	    continue;
+	if (KEY("size"))
+	    if (scan_dimen(data, &(font->size)) != 1)
+		font->size = 10.;
+		error(key, data, "illegal size request (font)");
+	    continue;
+	if (KEY("extend"))
+	    if (scan_dimen(data, &(font->extend)) != 1)
+		font->extend = 1.;
+		error(key, data, "illegal extent request (font)");
+	    continue;
+	if (KEY("color"))
+	    if (!scan_color(data, &(font->color)))
+		error(key, data, "illegal color request (font)");
+	    continue;
+	error(key, data, "illegal font sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_frame.c
--- grass-addons/postscript/ps.output/r_frame.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_frame.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,7 +17,7 @@
-int default_frame(PSFRAME *box, int refx, int refy)
+int default_frame(PSFRAME * box, int refx, int refy)
     box->x = (refx == RIGHT ? -100. : 0.0);
     box->y = 0.0;
@@ -33,7 +33,7 @@
     return 0;
-int read_frame(PSFRAME *box)
+int read_frame(PSFRAME * box)
     char buf[1024];
     char *key, *data;
@@ -47,65 +47,84 @@
-	        continue;
-        if (KEY("where")) {
-            char xx[50], yy[50];
-            if (sscanf(data, "%s %s", xx, yy) != 2) {
-                error(key, data, "illegal box where request");
-            else {
-				if (scan_dimen(xx, &(box->x)) == 2)
-					box->x *= -1;
-				if (scan_dimen(yy, &(box->y)) == 2)
-					box->y *= -1;
-                continue;
-        if (KEY("offset")) {
-            if (sscanf(data, "%lf %lf", &(box->xset), &(box->yset)) != 2) {
-                error(key, data, "illegal box offset request");
-            continue;
-        if (KEY("ref")) {
-			if (!scan_ref(data, &(box->xref), &(box->yref))) {
-                error(key, data, "illegal box ref request");
-            continue;
-        if (KEY("border")) {
-			if (scan_dimen(data, &(box->border)) != 1) {
-				box->border = -1;
-            continue;
-            if (!scan_color(data, &(box->color))) {
-                error(key, data, "illegal box color request");
-            continue;
-        if (KEY("fcolor")) {
-            if (!scan_color(data, &(box->fcolor))) {
-                error(key, data, "illegal box fcolor request");
-            continue;
-        if (KEY("margin")) {
-            if (scan_dimen(data, &(box->margin)) != 1) {
-                error(key, data, "illegal box margin request");
-            continue;
-        if (KEY("rotate")) {
-            if (scan_dimen(data, &(box->rotate)) != 1) {
-                error(key, data, "illegal box rotate request");
-            continue;
-        error(key, data, "illegal box sub-request");
+	    continue;
+	if (KEY("where"))
+	    char xx[50], yy[50];
+	    if (sscanf(data, "%s %s", xx, yy) != 2)
+		error(key, data, "illegal box where request");
+	    else
+		if (scan_dimen(xx, &(box->x)) == 2)
+		    box->x *= -1;
+		if (scan_dimen(yy, &(box->y)) == 2)
+		    box->y *= -1;
+		continue;
+	if (KEY("offset"))
+	    if (sscanf(data, "%lf %lf", &(box->xset), &(box->yset)) != 2)
+		error(key, data, "illegal box offset request");
+	    continue;
+	if (KEY("ref"))
+	    if (!scan_ref(data, &(box->xref), &(box->yref)))
+		error(key, data, "illegal box ref request");
+	    continue;
+	if (KEY("border"))
+	    if (scan_dimen(data, &(box->border)) != 1)
+		box->border = -1;
+	    continue;
+	if (KEY("color"))
+	    if (!scan_color(data, &(box->color)))
+		error(key, data, "illegal box color request");
+	    continue;
+	if (KEY("fcolor"))
+	    if (!scan_color(data, &(box->fcolor)))
+		error(key, data, "illegal box fcolor request");
+	    continue;
+	if (KEY("margin"))
+	    if (scan_dimen(data, &(box->margin)) != 1)
+		error(key, data, "illegal box margin request");
+	    continue;
+	if (KEY("rotate"))
+	    if (scan_dimen(data, &(box->rotate)) != 1)
+		error(key, data, "illegal box rotate request");
+	    continue;
+	error(key, data, "illegal box sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_grid.c
--- grass-addons/postscript/ps.output/r_grid.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_grid.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -26,105 +26,149 @@
     G_debug(1, "Reading grid settings ..");
     /* default values */
-    grid->sep   = 0;
-    grid->msep  = 0;
+    grid->sep = 0;
+    grid->msep = 0;
     default_font(&(grid->font));
+    grid->lsides = 0;
     default_psline(&(grid->line));
     default_psline(&(grid->mline));
     set_color_rgb(&(grid->fcolor), 255, 255, 255);
-    grid->format = 0;  /* inner labels */
-    grid->round  = -1; /* no round */
-    grid->cross  = 0.;
+    grid->format = 0;		/* inner labels */
+    grid->trim = -1;		/* no round */
+    grid->cross = 0.;
+    grid->msubdiv = -1;
-			continue;
-        if (KEY("major") || KEY("line")) {
-            char str[50];
-            if (sscanf(data, "%s", str) != 1) {
-                error(key, data, "illegal major request (grid)");
-            if (G_projection() == PROJECTION_LL || type == 1) {
-                double seconds;
-                scan_second(str, &seconds);
-                grid->sep = (int)seconds;
-            else {
-                grid->sep = atoi(str); /* units, usually meters */
-            if (grid->sep <= 0) {
-            read_psline("", &(grid->line));
-            continue;
-        if (KEY("minor")) {
-            char str[50];
-                error(key, data, "illegal minor request (grid)");
-                double seconds;
-                grid->msep = (int)seconds;
-            else {
-                grid->msep = atoi(str); /* units, usually meters */
-            if (grid->msep <= 0) {
-            read_psline("", &(grid->mline));
-            continue;
-        if (KEY("format")) {
-            G_strip(data);
-            if (strncmp(data,"in",2)==0) {
-                grid->format = 0;
-            else if (strncmp(data,"out",3)==0) {
-                grid->format = 1;
-            else if (strncmp(data,"iho",3)==0) {
-                grid->format = 2;
-            else
-                grid->format = atoi(data);
-            continue;
-        if (KEY("round")) {
-            G_strip(data);
-            grid->round = atoi(data);
-            continue;
-        if (KEY("font")) {
-			read_font(data, &(grid->font));
-			continue;
-            if (!scan_color(data, &(grid->fcolor))) {
-                error(key, data, "illegal fcolor request (grid)");
-			continue;
-        if (KEY("cross")) {
-            grid->cross = atof(data);
-            continue;
-        error(key, data, "illegal request (grid)");
+	    continue;
+	if (KEY("major") || KEY("line"))
+	    char str[50];
+	    if (sscanf(data, "%s", str) != 1)
+		error(key, data, "illegal major request (grid)");
+	    if (G_projection() == PROJECTION_LL || type == 0)
+		double seconds;
+		scan_second(str, &seconds);
+		grid->sep = (int)seconds;
+	    else
+		grid->sep = atoi(str);	/* units, usually meters */
+	    if (grid->sep <= 0)
+	    read_psline("", &(grid->line));
+	    continue;
+	if (KEY("minor"))
+	    char str[50];
+		error(key, data, "illegal minor request (grid)");
+		double seconds;
+		grid->msep = (int)seconds;
+	    else
+		grid->msep = atoi(str);	/* units, usually meters */
+	    read_psline("", &(grid->mline));
+	    continue;
+	if (KEY("subminor"))
+	    G_strip(data);
+	    grid->msubdiv = atoi(data);
+	    continue;
+	if (KEY("format"))
+	    G_strip(data);
+	    if (strncmp(data, "in", 2) == 0)
+		grid->format = 0;
+	    else if (strncmp(data, "out", 3) == 0)
+		grid->format = 1;
+	    else if (strncmp(data, "+out", 4) == 0)
+		grid->format = 1;
+		grid->lsides = 4;
+	    else if (strcmp(data, "iho") == 0)
+		grid->format = 2;
+	    else if (strcmp(data, "can") == 0)
+		grid->format = 3;
+	    else
+		grid->format = atoi(data);
+	    continue;
+	if (KEY("trim"))
+	    G_strip(data);
+	    grid->trim = atoi(data);
+	    continue;
+	if (KEY("font"))
+	    read_font(data, &(grid->font));
+	    continue;
+	    if (!scan_color(data, &(grid->fcolor)))
+		error(key, data, "illegal fcolor request (grid)");
+	    continue;
+	if (KEY("cross"))
+	    grid->cross = atof(data);
+	    continue;
+	error(key, data, "illegal request (grid)");
     /* swap major and minor if ... */
     if (grid->sep < grid->msep)
-        int tmp;
-        tmp = grid->msep;
-        grid->msep = grid->sep;
-        grid->sep = tmp;
+	int tmp;
+	tmp = grid->msep;
+	grid->msep = grid->sep;
+	grid->sep = tmp;
+    /* draw minor? .... */
+    if (grid->mline.width <= 0. || grid->msep == 0)
+	grid->msep = 0;		/* dont draw minor grid */
     return 0;
Modified: grass-addons/postscript/ps.output/r_line.c
--- grass-addons/postscript/ps.output/r_line.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_line.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,21 +17,22 @@
-int default_psline(PSLINE *line)
+int default_psline(PSLINE * line)
     line->width = 1.;
     set_color_rgb(&(line->color), 0, 0, 0);
     line->dash = G_store("");
+    line->odash = 0;
     line->cap = line->join = -1;
     return 0;
-int read_psline(char *arg, PSLINE *line)
+int read_psline(char *arg, PSLINE * line)
     char buf[1024];
     char *key, *data;
-    char i, dash[21];
+    char i, dash[31];
     G_debug(1, "Reading line settings ..");
@@ -39,85 +40,116 @@
     default_psline(line);
     /* inline argument: width */
-    if (arg[0] != 0) {
-        if (scan_dimen(arg, &(line->width)) != 1) {
-            line->width = 1.;
-            error("ERROR:", arg, "illegal line width request");
-        return 0;
+    if (arg[0] != 0)
+	if (scan_dimen(arg, &(line->width)) != 1)
+	    line->width = 1.;
+	    error("ERROR:", arg, "illegal line width request");
+	return 0;
-	        continue;
-        if (KEY("width")) {
-			if (scan_dimen(data, &(line->width)) != 1) {
-				line->width = -1.;
-                error(key, data, "illegal line width request");
-            continue;
-            if (!scan_color(data, &(line->color))) {
-                error(key, data, "illegal line color request");
-            continue;
-        if (KEY("style")) {
-            G_strip(data);
-            if (strncmp(data, "solid", 5) == 0) {
-                line->dash = G_store("");
-                continue;
-            else if (strncmp(data, "dashed", 5) == 0) {
-                line->dash = G_store("3 2");
-                continue;
-            else if (strncmp(data, "dotted", 3) == 0) {
-                line->dash = G_store("1");
-                continue;
-            else if (strncmp(data, "dashdotted", 5) == 0) {
-                line->dash = G_store("4 2 1 2");
-                continue;
-            char * dp;
-            for (i = 0, dp = data; *dp && i < 20; dp++) {
-                if (*dp < '0' || *dp > '9')
-                    break;
-                dash[i++] = *dp;
-                dash[i++] = ' ';
-            if (i == 0) {
-                error(key, data, "illegal line style");
-                continue;
-            dash[--i] = 0;
-            line->dash = G_store(dash);
-            continue;
-        if (KEY("cap")) {
-            G_strip(data);
-            if (strncmp(data, "butt", 4) == 0) {
-                line->cap = LINECAP_BUTT;
-                continue;
-            else if (strncmp(data, "round", 5) == 0) {
-                line->cap = LINECAP_ROUND;
-                continue;
-            else if (strncmp(data, "extended_butt", 3) == 0) {
-                line->cap = LINECAP_EXTBUTT;
-                continue;
-            else
-                error(key, data, "illegal line cap");
-            continue;
-        error(key, data, "illegal line sub-request");
+	    continue;
+	if (KEY("width"))
+	    if (scan_dimen(data, &(line->width)) != 1)
+		line->width = -1.;
+		error(key, data, "illegal line width request");
+	    continue;
+	if (KEY("color"))
+	    if (!scan_color(data, &(line->color)))
+		error(key, data, "illegal line color request");
+	    continue;
+	if (KEY("style"))
+	    char str[50];
+	    int x, o;
+	    x = sscanf(data, "%s %s", str, &o);
+	    if (x != 1 && x != 2)
+		error(key, data, "illegal line style request");
+		continue;
+	    if (x == 2)
+		line->odash = o;
+	    G_strip(str);
+	    if (strncmp(str, "solid", 5) == 0)
+		line->dash = G_store("");
+		continue;
+	    else if (strncmp(str, "dashed", 5) == 0)
+		line->dash = G_store("3 2");
+		continue;
+	    else if (strncmp(str, "dotted", 3) == 0)
+		line->dash = G_store("1");
+		continue;
+	    else if (strncmp(str, "dashdotted", 5) == 0)
+		line->dash = G_store("4 2 1 2");
+		continue;
+	    char *dp;
+	    for (i = 0, dp = str; *dp && i < 20; dp++)
+		if (*dp < '0' || *dp > '9')
+		    break;
+		dash[i++] = *dp;
+		dash[i++] = ' ';
+	    if (i == 0)
+		error(key, str, "illegal line style");
+		continue;
+	    dash[--i] = 0;
+	    line->dash = G_store(dash);
+	    continue;
+	if (KEY("cap"))
+	    G_strip(data);
+	    if (strncmp(data, "butt", 2) == 0)
+		line->cap = LINECAP_BUTT;
+		continue;
+	    else if (strncmp(data, "round", 2) == 0)
+		line->cap = LINECAP_ROUND;
+		continue;
+	    else if (strncmp(data, "extended_butt", 2) == 0)
+		line->cap = LINECAP_EXTBUTT;
+		continue;
+	    else
+		error(key, data, "illegal line cap");
+	    continue;
+	error(key, data, "illegal line sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_maparea.c
--- grass-addons/postscript/ps.output/r_maparea.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_maparea.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -32,59 +32,74 @@
-            continue;
-            if(scan_dimen(data, &(point)) != 1) {
-                error(key, data, "illegal border width request (maparea)");
-            PS.brd.width = point;
-            PS.do_border = 1;
-            continue;
-            if(!scan_color(data, &(PS.brd.color))) {
-                error(key, data, "illegal border color request (maparea)");
-            continue;
-            if(!scan_color(data, &(PS.fcolor))) {
-                error(key, data, "illegal fcolor request (maparea)");
-            continue;
-                error(key, data, "illegal map width request (maparea)");
-            PS.map_w = point;
-            continue;
-        if (KEY("height")) {
-                error(key, data, "illegal map height request (maparea)");
-            PS.map_h = point;
-            continue;
-        if (KEY("top")) {
-            if (scan_dimen(data, &(point)) != 1) {
-                error(key, data, "illegal map top request (maparea)");
-            PS.map_top = point;
-            continue;
-            continue;
-        if (KEY("left")) {
-                error(key, data, "illegal map left request (maparea)");
-            PS.map_x = point;
-            continue;
-	    error(key, data, "illegal maparea sub-request");
+	    continue;
+	    if (scan_dimen(data, &(point)) != 1)
+		error(key, data, "illegal border width request (maparea)");
+	    PS.brd.width = point;
+	    PS.do_border = 1;
+	    continue;
+	if (KEY("color"))
+	    if (!scan_color(data, &(PS.brd.color)))
+		error(key, data, "illegal border color request (maparea)");
+	    continue;
+	    if (!scan_color(data, &(PS.fcolor)))
+		error(key, data, "illegal fcolor request (maparea)");
+	    continue;
+	if (KEY("width"))
+		error(key, data, "illegal map width request (maparea)");
+	    PS.map_w = point;
+	    continue;
+	if (KEY("height"))
+		error(key, data, "illegal map height request (maparea)");
+	    PS.map_h = point;
+	    continue;
+	if (KEY("top"))
+		error(key, data, "illegal map top request (maparea)");
+	    PS.map_top = point;
+	    continue;
+	    continue;
+	if (KEY("left"))
+		error(key, data, "illegal map left request (maparea)");
+	    PS.map_x = point;
+	    continue;
+	error(key, data, "illegal maparea sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_note.c
--- grass-addons/postscript/ps.output/r_note.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_note.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -28,54 +28,71 @@
     PS.note[PS.n_notes].text[0] = 0;
-    PS.note[PS.n_notes].angle   = 0.;
+    PS.note[PS.n_notes].width = 0.;
+    PS.note[PS.n_notes].angle = 0.;
     default_font(&(PS.note[PS.n_notes].font));
     default_frame(&(PS.note[PS.n_notes].box), LEFT, UPPER);
     /* inline argument */
-    if (*name != 0) {
-        strncpy(PS.note[PS.n_notes].text, name, 1024);
-        PS.note[PS.n_notes].text[1023] = 0;
+    if (*name != 0)
+	strncpy(PS.note[PS.n_notes].text, name, 1024);
+	PS.note[PS.n_notes].text[1023] = 0;
-			continue;
-		if (KEY("frame")) {
-			read_frame(&(PS.note[PS.n_notes].box));
-			continue;
-			read_font(data, &(PS.note[PS.n_notes].font));
-			continue;
-		if (KEY("text")) {
-			if (sscanf(data, "%s", PS.note[PS.n_notes].text) != 1) {
-				PS.note[PS.n_notes].text[0] = 0;
-				error(key, data, "illegal note sub-request");
-			else {
-                strncpy(PS.note[PS.n_notes].text, data, 1024);
-			continue;
-        if (KEY("angle")) {
-            if (sscanf(data, "%lf", &(PS.note[PS.n_notes].angle)) != 1) {
-                error(key, data, "illegal angle sub-request");
-            continue;
+	    continue;
+	if (KEY("frame"))
+	    read_frame(&(PS.note[PS.n_notes].box));
+	    continue;
+	if (KEY("font"))
+	    read_font(data, &(PS.note[PS.n_notes].font));
+	    continue;
+	if (KEY("text"))
+	    if (sscanf(data, "%s", PS.note[PS.n_notes].text) != 1)
+		PS.note[PS.n_notes].text[0] = 0;
+	    else
+		strncpy(PS.note[PS.n_notes].text, data, 1024);
+	    continue;
+	if (KEY("width"))
+	    if (scan_dimen(data, &(PS.note[PS.n_notes].width)) != 1)
+		error(key, data, "illegal width sub-request");
+	    continue;
+	if (KEY("angle"))
+	    if (sscanf(data, "%lf", &(PS.note[PS.n_notes].angle)) != 1)
+		error(key, data, "illegal angle sub-request");
+	    continue;
+	error(key, data, "illegal note sub-request");
-	++PS.n_notes;
+    ++PS.n_notes;
     return 0;
Modified: grass-addons/postscript/ps.output/r_palette.c
--- grass-addons/postscript/ps.output/r_palette.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_palette.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -35,76 +35,112 @@
-			continue;
+	    continue;
+	if (KEY("wheel", 2))
+	    if (sscanf(data, "%d %s", &i, name) != 2 || i < 2)
+            error(key, data, "illegal wheel sub-request (palette)");
+	    pure_color(name, i);
+	    continue;
+	if (KEY("monochrome", 4))
+	    char color_name[50];
+	    if (sscanf(data, "%s %d %s", color_name, &i, name) != 3)
+            error(key, data, "illegal monochrome sub-request (palette)");
+	    if (i < 1 || !scan_color(color_name, &color))
+	    monochrome(name, &color, i);
+	    continue;
+	if (KEY("complementary", 4))
+            error(key, data, "illegal complementary sub-request (palette)");
+	    complementary(name, &color, i, 90.);
+	    continue;
+    if (KEY("analogous", 3))
+            error(key, data, "illegal analogous sub-request (palette)");
-        if (KEY("wheel", 2)) {
-            if (sscanf(data, "%d %s", &i, name) != 2 || i < 2) {
-                error(key, data, "illegal wheel sub-request (palette)");
-            pure_color(name, i);
-            continue;
-        if (KEY("monochrome", 4)) {
-            char color_name[50];
-            if (sscanf(data, "%s %d %s", color_name, &i, name) != 3) {
-                error(key, data, "illegal monochrome sub-request (palette)");
-            if (i < 1 || !scan_color(color_name, &color)) {
-            monochrome(name, &color, i);
-            continue;
+        analogous(name, &color, i, 90.);
+        continue;
+    if (KEY("pure_gradient", 4))
+        char A_name[50], B_name[50];
+        if (sscanf(data, "%s %s %d %s", A_name, B_name, &i, name) != 4)
+            error(key, data, "illegal pure_gradient sub-request (palette)");
-        if (KEY("complementary", 4)) {
-                error(key, data, "illegal complementary sub-request (palette)");
-            complementary(name, &color, i);
-            continue;
+        if (i < 3 || !scan_color(A_name, &color) || !scan_color(B_name, &colorb))
-        if (KEY("analogous", 3)) {
-                error(key, data, "illegal analogous sub-request (palette)");
-            analogous(name, &color, i);
-            continue;
+        gradient(name, &color, &colorb, i, 1);
+        continue;
+	if (KEY("gradient", 4))
+            error(key, data, "illegal gradient sub-request (palette)");
+	    gradient(name, &color, &colorb, i, 0);
+	    continue;
+    if (KEY("diverging", 4))
+            error(key, data, "illegal xxx diverging sub-request (palette)");
-        if (KEY("pure_gradient", 4)) {
-            char A_name[50], B_name[50];
-            if (sscanf(data, "%s %s %d %s", A_name, B_name, &i, name) != 4) {
-                error(key, data, "illegal gradient sub-request (palette)");
-            if (i < 3 || !scan_color(A_name, &color) || !scan_color(B_name, &colorb)) {
-            gradient(name, &color, &colorb, i, 1);
-            continue;
+            error(key, data, "illegal yyy diverging sub-request (palette)");
-        if (KEY("gradient", 4)) {
-            gradient(name, &color, &colorb, i, 0);
-            continue;
-        error(key, data, "illegal palette sub-request");
+        diverging(name, &color, &colorb, i);
+        continue;
+	error(key, data, "illegal zzz palette sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_paper.c
--- grass-addons/postscript/ps.output/r_paper.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_paper.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -25,76 +25,111 @@
     G_debug(1, "Reading paper settings ..");
-        set_paper(arg);
+    if (arg[0] != 0)
+	set_paper(arg);
     do_landscape = 0;
+    /* init values */
+    unset_color(&(PS.page.fcolor));	/* no paper color */
-            continue;
-                error(key, data, "illegal paper width request");
-            PS.page.width = (int)(point);
-            continue;
-            PS.page.height = (int)(point);
-            continue;
-            PS.page.left = point;
-            continue;
-        if (KEY("right")) {
-            PS.page.right = point;
-            continue;
-        if (KEY("top")) {
-            PS.page.top = point;
-            continue;
-        if (KEY("bottom")) {
-            PS.page.bot = point;
-            continue;
-        if (KEY("landscape")) {
-            do_landscape = scan_yesno(key, data);
-            continue;
-        error(key, data, "illegal paper sub-request");
+	    continue;
+	if (KEY("color"))
+	    if (!scan_color(data, &(PS.page.fcolor)))
+	    continue;
+	if (KEY("width"))
+		error(key, data, "illegal paper width request");
+	    PS.page.width = (int)(point);
+	    continue;
+	    PS.page.height = (int)(point);
+	    continue;
+	if (KEY("left"))
+	    PS.page.left = point;
+	    continue;
+	if (KEY("right"))
+	    PS.page.right = point;
+	    continue;
+	if (KEY("top"))
+	    PS.page.top = point;
+	    continue;
+	if (KEY("bottom"))
+	    PS.page.bot = point;
+	    continue;
+	if (KEY("landscape"))
+	    do_landscape = scan_yesno(key, data);
+	    continue;
+	if (KEY("font"))
+	    read_font(data, &(PS.font));
+	    continue;
+	if (KEY("draw"))
+	    read_draw("paper");
+	    continue;
+	error(key, data, "illegal paper sub-request");
     if (do_landscape != 0)
-        int tmp;
-        tmp = PS.page.width;
-        PS.page.width = PS.page.height;
-        PS.page.height = tmp;
+	int tmp;
+	tmp = PS.page.width;
+	PS.page.width = PS.page.height;
+	PS.page.height = tmp;
-    G_debug(1, "Setting paper: %.1f %.1f : %d %d\n",
-            PS.page.left, PS.page.top,
-            PS.page.width, PS.page.height);
+    G_debug(1, "Setting paper: %.1f %.1f : %d %d\n", PS.page.left, PS.page.top, PS.page.width, PS.page.height);
     return 0;
Modified: grass-addons/postscript/ps.output/r_raster.c
--- grass-addons/postscript/ps.output/r_raster.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_raster.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -27,7 +27,7 @@
     G_debug(1, "Reading raster settings ..");
-    PS.rst.do_rgb  = 0;
+    PS.rst.do_rgb = 0;
     PS.rst.do_grey = 0;
     PS.rst.do_mask = 0;
     default_psline(&(PS.rst.outline));
@@ -36,104 +36,125 @@
     ret = sscanf(arg, "%s %s %s", name[0], name[1], name[2]);
-    if (ret != 1 && ret != 3) {
-        error(key, data, "illegal raster request");
+    if (ret != 1 && ret != 3)
+	error(key, data, "illegal raster request");
-    if (ret == 3) {
-        PS.rst.files = load_rgb(name[0], name[1], name[2]);
-        PS.rst.do_rgb = 1;
+    if (ret == 3)
+	PS.rst.files = load_rgb(name[0], name[1], name[2]);
+	PS.rst.do_rgb = 1;
-    else {
-        if (name[0][0] == ':') {
-            PS.rst.files = load_group(name[0] + 1);
-        else {
-            PS.rst.files = load_cell(0, name[0]);
-            PS.rst.fd[1] = PS.rst.fd[2] = -1;
+    else
+	if (name[0][0] == ':')
+	    PS.rst.files = load_group(name[0] + 1);
+	else
+	    PS.rst.files = load_cell(0, name[0]);
+	    PS.rst.fd[1] = PS.rst.fd[2] = -1;
     /* process options */
-		if (!key_data(buf, &key, &data)) {
-			continue;
-       if (KEY("grey") || KEY("gray")) {
-            PS.rst.do_grey = scan_yesno(key, data);
-            continue;
-        if (KEY("maskcolor")) {
-            if (!scan_color(data, &(PS.rst.mask_color))) {
-                error(key, data, "illegal raster mask color request");
-            continue;
-        if (KEY("maskcell")) {
-            if (PS.rst.do_rgb) {
-                error(key, data, "illegal maskcell with rgb/group raster");
-            ret = sscanf(data, "%s %s", name[1], name[2]);
-            if (ret != 1 && ret != 2) {
-                error(key, data, "illegal maskcell raster request");
-            PS.rst.do_mask = 1;
-            load_cell(1, name[1]); /* slot 1: mask */
-            if (ret == 2)
-                load_cell(2, name[2]); /* slot 2: background */
-            continue;
-        if (KEY("outline")) {
-                error(key, data, "illegal outline with rgb raster");
-            read_psline(data, &(PS.rst.outline));
-            continue;
-        if (KEY("setcolor")) {
-            int i, count, R, G, B;
-            PSCOLOR color;
-            DCELL *val_list, dmin, dmax;
-            char colorbuf[100], catsbuf[100];
-            /* set color inline */
-            if (PS.rst.fd[0] < 0 || PS.rst.do_rgb) {
-                error(key, data, "setcolor is not for RGB raster");
-            if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2)
-                if (!scan_color(colorbuf, &color)) {
-                    error(key, data, "illegal setcolor request");
-                    continue;
-                R = (int)(255.*color.r);
-                G = (int)(255.*color.g);
-                B = (int)(255.*color.b);
-                if (strncmp(catsbuf, "null", 4) == 0) {
-                    G_set_null_value_color(R, G, B, &(PS.rst.colors[0]));
-                    continue;
-                if (strncmp(catsbuf, "default", 7) == 0) {
-                    G_set_default_color(R, G, B, &(PS.rst.colors[0]));
-                    continue;
-                if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
-                    error(key, data, "illegal value list");
-                    continue;
-                for (i = 0; i < count; i += 2)
-                    dmin = val_list[i];
-                    dmax = val_list[i + 1];
-                    G_add_d_raster_color_rule(&dmin, R, G, B,
-                                              &dmax, R, G, B, &(PS.rst.colors[0]));
-                G_free(val_list);
-            continue;
-		error(key, data, "illegal raster sub-request");
+	if (!key_data(buf, &key, &data))
+	    continue;
+	if (KEY("grey") || KEY("gray"))
+	    PS.rst.do_grey = scan_yesno(key, data);
+	    continue;
+	if (KEY("maskcolor"))
+	    if (!scan_color(data, &(PS.rst.mask_color)))
+		error(key, data, "illegal raster mask color request");
+	    continue;
+	if (KEY("maskcell"))
+	    if (PS.rst.do_rgb)
+		error(key, data, "illegal maskcell with rgb/group raster");
+	    ret = sscanf(data, "%s %s", name[1], name[2]);
+	    if (ret != 1 && ret != 2)
+		error(key, data, "illegal maskcell raster request");
+	    PS.rst.do_mask = 1;
+	    load_cell(1, name[1]);	/* slot 1: mask */
+	    if (ret == 2)
+		load_cell(2, name[2]);	/* slot 2: background */
+	    continue;
+	if (KEY("outline"))
+		error(key, data, "illegal outline with rgb raster");
+	    read_psline(data, &(PS.rst.outline));
+	    continue;
+	if (KEY("setcolor"))
+	    int i, count, R, G, B;
+	    PSCOLOR color;
+	    DCELL *val_list, dmin, dmax;
+	    char colorbuf[100], catsbuf[100];
+	    /* set color inline */
+	    if (PS.rst.fd[0] < 0 || PS.rst.do_rgb)
+		error(key, data, "setcolor is not for RGB raster");
+	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2)
+		if (!scan_color(colorbuf, &color))
+		    error(key, data, "illegal setcolor request");
+		    continue;
+		R = (int)(255. * color.r);
+		G = (int)(255. * color.g);
+		B = (int)(255. * color.b);
+		if (strncmp(catsbuf, "null", 4) == 0)
+		    G_set_null_value_color(R, G, B, &(PS.rst.colors[0]));
+		    continue;
+		if (strncmp(catsbuf, "default", 7) == 0)
+		    G_set_default_color(R, G, B, &(PS.rst.colors[0]));
+		    continue;
+		if ((count = parse_val_list(catsbuf, &val_list)) < 0)
+		    /* G_free(val_list); */
+		    error(key, data, "illegal value list");
+		    continue;
+		for (i = 0; i < count; i += 2)
+		    dmin = val_list[i];
+		    dmax = val_list[i + 1];
+		    G_add_d_raster_color_rule(&dmin, R, G, B, &dmax, R, G, B, &(PS.rst.colors[0]));
+		G_free(val_list);
+	    continue;
+	error(key, data, "illegal raster sub-request");
     return 0;
Modified: grass-addons/postscript/ps.output/r_rlegend.c
--- grass-addons/postscript/ps.output/r_rlegend.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_rlegend.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -10,10 +10,10 @@
 #include <stdlib.h>
 #include <string.h>
-#include "raster.h"
-// #include "rlegend.h"
+#include "raster.h"
+#include "rlegend.h"
@@ -26,129 +26,158 @@
     G_debug(1, "Reading rlegend settings ..");
-    PS.rl.name[0]      = 0;
-	PS.rl.height       = 0.;
-    PS.rl.do_gradient  = FALSE;
-    PS.rl.do_nodata    = FALSE;
-	PS.rl.tickbar      = 3;
-	PS.rl.whiteframe   = 1;
+    PS.rl.name[0] = 0;
+    PS.rl.height = 0.;
+    PS.rl.do_gradient = FALSE;
+    PS.rl.do_nodata = FALSE;
+    PS.rl.tickbar = 3;
+    PS.rl.whiteframe = 1;
     PS.rl.custom_range = FALSE;
     PS.rl.cat_order[0] = 0;
     default_font(&(PS.rl.legend.font));
     default_frame(&(PS.rl.legend.box), LEFT, LOWER);
     PS.rl.legend.width = -1.0;
-    PS.rl.legend.cols  = 1;
-    PS.rl.legend.span  = 4.;
+    PS.rl.legend.cols = 1;
+    PS.rl.legend.xspan = 4.;
     default_font(&(PS.rl.legend.title_font));
-    PS.rl.legend.title[0] = 0;
+    G_strip(arg);
+    strncpy(PS.rl.legend.title, arg, TITLE_LEN);
-	        continue;
-        if (KEY("title")) {
-            G_strip(data);
-            strncpy(PS.rl.legend.title, data, 50);
-            read_font("", &(PS.rl.legend.title_font));
-            continue;
-            G_strip(data);
-            read_font(data, &(PS.rl.legend.font));
-            continue;
-          read_frame(&(PS.rl.legend.box));
-          continue;
-            if(scan_dimen(data, &(PS.rl.legend.width)) != 1) {
-                PS.rl.legend.width = -1.;
-                error(key, data, "illegal width request (rlegend)");
-            continue;
-        if (KEY("cols")) {
-            int n;
-            n = sscanf(data, "%d %lf", &(PS.rl.legend.cols), &(PS.rl.legend.span));
-            if (n == 1 || n == 2) {
-                if (PS.rl.legend.cols < 0) PS.rl.legend.cols = 1;
-                if (n == 1) PS.rl.legend.span = -1.;
-            else
-                error(key, data, "illegal cols/span request (rlegend)");
-            continue;
-	        if (scan_dimen(data, &(PS.rl.height)) != 1) {
-			    error(key, data, "illegal height request (rlegend)");
-		    continue;
+	    continue;
+	if (KEY("title"))
+	    G_strip(data);
+	    read_font(data, &(PS.rl.legend.title_font));
+	    continue;
+	if (KEY("font"))
+	    G_strip(data);
+	    read_font(data, &(PS.rl.legend.font));
+	    continue;
+	if (KEY("frame"))
+	    read_frame(&(PS.rl.legend.box));
+	    continue;
+    if (KEY("swidth"))
+	    if (scan_dimen(data, &(PS.rl.legend.width)) != 1)
+		PS.rl.legend.width = -1.;
+		error(key, data, "illegal width request (rlegend)");
-	    if (KEY("raster")) {
-            G_strip(data);
-            mapset = G_find_file("cell", data, "");
-            if (PS.rl.mapset == NULL) {
-                    error(key, data, "illegal raster request (rlegend)");
-            strcpy(PS.rl.name, data);
-            strcpy(PS.rl.mapset, mapset);
-            continue;
+	    continue;
+	if (KEY("cols"))
+	    int n;
+	    n = sscanf(data, "%d %lf", &(PS.rl.legend.cols), &(PS.rl.legend.xspan));
+	    if (n == 1 || n == 2)
+		if (PS.rl.legend.cols < 0)
+		if (n == 1)
+		    PS.rl.legend.xspan = -1.;
-	    if (KEY("range")) {
-	        if (sscanf(data, "%lf %lf", &(PS.rl.min), &(PS.rl.max)) != 2) {
-			    PS.rl.custom_range = FALSE;
-                error(key, data, "illegal range request (rlegend)");
-	        else {
-                double tmpD;
-			    PS.rl.custom_range = TRUE;
-			    if (PS.rl.min > PS.rl.max) {
-			        tmpD = PS.rl.min;
-			        PS.rl.min = PS.rl.max;
-		            PS.rl.max = tmpD;
-			    continue;
+	    else
+		error(key, data, "illegal cols/span request (rlegend)");
+	    continue;
+	    if (scan_dimen(data, &(PS.rl.height)) != 1)
+		error(key, data, "illegal height request (rlegend)");
-        if (KEY("nodata")) {
-            PS.rl.do_nodata = scan_yesno(key, data);
-            continue;
-        if (KEY("gradient")) {
-            PS.rl.do_gradient = scan_yesno(key, data);
-            continue;
-        if (KEY("tick")) {
-            if (scan_dimen(data, &dimen) != 1) {
-                error(key, data, "illegal tickbar request (rlegend)");
-		    PS.rl.tickbar = (int)(dimen);
-		    continue;
+	    continue;
+	if (KEY("raster"))
+	    G_strip(data);
+	    mapset = G_find_file("cell", data, "");
+	    if (PS.rl.mapset == NULL)
+		error(key, data, "illegal raster request (rlegend)");
-	    if (KEY("whiteframe")) {
-                error(key, data, "illegal whiteframe request (rlegend)");
-            PS.rl.whiteframe = (int)(dimen);
-		    continue;
+	    strcpy(PS.rl.name, data);
+	    strcpy(PS.rl.mapset, mapset);
+	    continue;
+	if (KEY("range"))
+	    if (sscanf(data, "%lf %lf", &(PS.rl.min), &(PS.rl.max)) != 2)
+		PS.rl.custom_range = FALSE;
+		error(key, data, "illegal range request (rlegend)");
-        if (KEY("order")) {
-            G_strip(data);
-            strncpy(PS.rl.cat_order, data, 510);
-            PS.rl.cat_order[510] = 0;
-            continue;
-        error(key, data, "illegal rlegend sub-request");
+	    else
+		double tmpD;
+		PS.rl.custom_range = TRUE;
+		if (PS.rl.min > PS.rl.max)
+		    tmpD = PS.rl.min;
+		    PS.rl.min = PS.rl.max;
+		    PS.rl.max = tmpD;
+		continue;
+	if (KEY("nodata"))
+	    PS.rl.do_nodata = scan_yesno(key, data);
+	    continue;
+	if (KEY("gradient"))
+	    PS.rl.do_gradient = scan_yesno(key, data);
+	    continue;
+	if (KEY("tick"))
+	    if (scan_dimen(data, &dimen) != 1)
+		error(key, data, "illegal tickbar request (rlegend)");
+	    PS.rl.tickbar = (int)(dimen);
+	    continue;
+	if (KEY("whiteframe"))
+		error(key, data, "illegal whiteframe request (rlegend)");
+	    PS.rl.whiteframe = (int)(dimen);
+	    continue;
+	if (KEY("order"))
+	    G_strip(data);
+	    strncpy(PS.rl.cat_order, data, MAX_CATS);
+	    //            PS.rl.cat_order[510] = 0;
+	    continue;
+	error(key, data, "illegal rlegend sub-request");
     /* end check */
-    if (!PS.rl.name) {
-        PS.do_rlegend = 0;
-        error(key, data, "rlegend need 'raster' option sub-request");
+    if (!PS.rl.name)
+	PS.do_rlegend = 0;
+	error(key, data, "rlegend need 'raster' option sub-request");
     PS.do_rlegend = 1;
Modified: grass-addons/postscript/ps.output/r_scalebar.c
--- grass-addons/postscript/ps.output/r_scalebar.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_scalebar.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,7 +16,7 @@
 #ifndef ABS
-    #define ABS(x) (x > 0 ? x : -x)
+#define ABS(x) (x > 0 ? x : -x)
 #endif
@@ -28,14 +28,14 @@
     G_debug(1, "Reading scalebar settings ..");
-    PS.sbar.ucode    = SB_UNITS_AUTO;
+    PS.sbar.ucode = SB_UNITS_AUTO;
     PS.sbar.units[0] = 0;
-    PS.sbar.length   = -1.;
-    PS.sbar.height   = 4.;      /* default height in points */
-    PS.sbar.labels   = 1;       /* label each segment */
-    PS.sbar.segments = 4;		/* four segments */
-    PS.sbar.sublabs  = 1;       /* label pre-segment */
-    PS.sbar.subsegs  = 1;       /* division pre-segment */
+    PS.sbar.length = -1.;
+    PS.sbar.height = 4.;	/* default height in points */
+    PS.sbar.labels = 1;		/* label each segment */
+    PS.sbar.segments = 4;	/* four segments */
+    PS.sbar.sublabs = 1;	/* label pre-segment */
+    PS.sbar.subsegs = 1;	/* division pre-segment */
     default_font(&(PS.sbar.font));
     default_frame(&(PS.sbar.box), LEFT, UPPER);
     set_color_rgb(&(PS.sbar.fcolor), 255, 255, 255);
@@ -43,119 +43,143 @@
-	        continue;
-            read_frame(&(PS.sbar.box));
-            continue;
-            read_font(data, &(PS.sbar.font));
-            continue;
-            if (!scan_color(data, &(PS.sbar.fcolor))) {
-                error(key, data, "illegal fcolor request (scalebar)");
-            continue;
-            if (scan_dimen(data, &(PS.sbar.height)) != 1) {
-                error(key, data, "illegal height request (scalebar)");
-            continue;
-	    if (KEY("length")) {
-            if (scan_dimen(data, &(PS.sbar.length)) != 1) {
-                error(key, data, "illegal length request (scalebar)");
-            continue;
+	    continue;
+	if (KEY("frame"))
+	    read_frame(&(PS.sbar.box));
+	    continue;
+	if (KEY("font"))
+	    read_font(data, &(PS.sbar.font));
+	    continue;
+	    if (!scan_color(data, &(PS.sbar.fcolor)))
+		error(key, data, "illegal fcolor request (scalebar)");
-        if (KEY("major") || KEY("segments")) {
-            int i, j;
-            switch (sscanf(data, "%d %d", &i, &j))
-                case 1:
-                    PS.sbar.segments = ABS(i);
-                    break;
-                case 2:
-                    PS.sbar.labels = (j == 0 ? ABS(i)+1 : ABS(j));
-                    break;
-                default:
-                    error(key, data, "illegal segment request (scalebar)");
-                    break;
-            continue;
-            int i, j;
-                case 1:
-                    PS.sbar.subsegs = ABS(i);
-                    break;
-                case 2:
-                    PS.sbar.sublabs = (j == 0 ? ABS(i)+1 : ABS(j));
-                    break;
-                default:
-                    error(key, data, "illegal minor request (scalebar)");
-                    break;
-            continue;
-        if (KEY("units")) {
-            int ret;
-            char stra[50], strb[50];
-	        G_strip(data);
-            ret = sscanf(data, "%s %s", stra, strb);
-                error(key, data, "illegal units request (scalebar)");
-	        if (strcmp(stra, "auto") == 0) {
-                PS.sbar.units[0] = 0;
-    		    continue;
-	        else if (G_projection() == PROJECTION_XY) {
-	            error(key, data, "Earth units not available in simple XY location");
-	        else if (strcmp(stra, "meters") == 0 || strcmp(stra, "m") == 0) {
-                strcpy(PS.sbar.units, "meters");
-                PS.sbar.ucode = SB_UNITS_METERS;
-	        else if (strcmp(stra, "kilometers") == 0 || strcmp(stra, "km") == 0) {
-                strcpy(PS.sbar.units, "kilometers");
-                PS.sbar.ucode = SB_UNITS_KM;
-	        else if (strcmp(stra, "feet") == 0 || strcmp(stra, "ft") == 0) {
-                strcpy(PS.sbar.units, "feet");
-                PS.sbar.ucode = SB_UNITS_FEET;
-	        else if (strcmp(stra, "miles") == 0 || strcmp(stra, "mil") == 0) {
-                strcpy(PS.sbar.units, "miles");
-		        PS.sbar.ucode = SB_UNITS_MILES;
-	        else if (strcmp(stra, "nautmiles") == 0 || strcmp(stra, "nm") == 0) {
-                strcpy(PS.sbar.units, "nautical miles");
-                PS.sbar.ucode = SB_UNITS_NMILES;
-	        else {
-            if (ret == 2)
-                strcpy(PS.sbar.units, strb);
-            continue;
+	    continue;
+	    if (scan_dimen(data, &(PS.sbar.height)) != 1)
+		error(key, data, "illegal height request (scalebar)");
-        error(key, data, "illegal sub-request (scalebar)");
+	    continue;
+	if (KEY("length"))
+	    if (scan_dimen(data, &(PS.sbar.length)) != 1)
+		error(key, data, "illegal length request (scalebar)");
+	    continue;
+	if (KEY("major") || KEY("segments"))
+	    int i, j;
+	    switch (sscanf(data, "%d %d", &i, &j))
+	    case 1:
+		PS.sbar.segments = ABS(i);
+		break;
+	    case 2:
+		PS.sbar.labels = (j == 0 ? ABS(i) + 1 : ABS(j));
+		break;
+	    default:
+		error(key, data, "illegal segment request (scalebar)");
+		break;
+	    continue;
+	if (KEY("minor"))
+	    int i, j;
+	    case 1:
+		PS.sbar.subsegs = ABS(i);
+		break;
+	    case 2:
+		PS.sbar.sublabs = (j == 0 ? ABS(i) + 1 : ABS(j));
+		break;
+	    default:
+		error(key, data, "illegal minor request (scalebar)");
+		break;
+	    continue;
+	if (KEY("units"))
+	    int ret;
+	    char stra[50], strb[50];
+	    G_strip(data);
+	    ret = sscanf(data, "%s %s", stra, strb);
+		error(key, data, "illegal units request (scalebar)");
+	    if (strcmp(stra, "auto") == 0)
+		PS.sbar.units[0] = 0;
+		continue;
+	    else if (G_projection() == PROJECTION_XY)
+		error(key, data, "Earth units not available in simple XY location");
+	    else if (strcmp(stra, "meters") == 0 || strcmp(stra, "m") == 0)
+		strcpy(PS.sbar.units, "meters");
+		PS.sbar.ucode = SB_UNITS_METERS;
+	    else if (strcmp(stra, "kilometers") == 0 || strcmp(stra, "km") == 0)
+		strcpy(PS.sbar.units, "kilometers");
+		PS.sbar.ucode = SB_UNITS_KM;
+	    else if (strcmp(stra, "feet") == 0 || strcmp(stra, "ft") == 0)
+		strcpy(PS.sbar.units, "feet");
+		PS.sbar.ucode = SB_UNITS_FEET;
+	    else if (strcmp(stra, "miles") == 0 || strcmp(stra, "mil") == 0)
+		strcpy(PS.sbar.units, "miles");
+		PS.sbar.ucode = SB_UNITS_MILES;
+	    else if (strcmp(stra, "nautmiles") == 0 || strcmp(stra, "nm") == 0)
+		strcpy(PS.sbar.units, "nautical miles");
+		PS.sbar.ucode = SB_UNITS_NMILES;
+	    else
+	    if (ret == 2)
+		strcpy(PS.sbar.units, strb);
+	    continue;
+	error(key, data, "illegal sub-request (scalebar)");
     if (PS.sbar.type == 'I')
     return 0;
Modified: grass-addons/postscript/ps.output/r_vareas.c
--- grass-addons/postscript/ps.output/r_vareas.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_vareas.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -23,137 +23,204 @@
     int i;
     char buf[1024];
     char *key, *data, *mapset;
-    VAREAS *vector = NULL;
+    VAREAS * vector = NULL;
-    G_debug(1, "Reading vlines settings ..");
+    G_debug(1, "Reading vareas settings ..");
-    i = vector_new();   /* G_realloc */
+    i = vector_new();		/* G_realloc */
+    default_vector(i);
-    mapset = G_find_file("vector", name, "");
-    if (mapset == NULL) {
-        error("ERROR:", name, "Can't find vector map");
-    PS.vct[i].name   = G_store(name);
-    PS.vct[i].mapset = G_store(mapset);
-    PS.vct[i].data   = G_malloc(sizeof(VAREAS));
+    if (strcmp(name, "(none)") != 0)
+        mapset = G_find_vector(name, "");
+	if (mapset == NULL)
+	    error("ERROR:", name, "Can't find vector map");
+	PS.vct[i].name = G_store(name);
+	PS.vct[i].mapset = G_store(mapset);
+	PS.vct[i].data = G_malloc(sizeof(VAREAS));
-    Vect_set_open_level(2);     /* level 2: topology */
-    Vect_set_fatal_error(GV_FATAL_PRINT);
+        Vect_set_open_level(2);	/* level 2: topology */
+	Vect_set_fatal_error(GV_FATAL_PRINT);
-    if (2 > Vect_open_old(&(PS.vct[i].Map), name, mapset))
-        sprintf(buf, "%s in %s", name, mapset);
-        error("ERROR:", buf, "can't open vector map");
-        return 0;
+	if (2 > Vect_open_old(&(PS.vct[i].Map), name, mapset))
+	    sprintf(buf, "%s in %s", name, mapset);
+	    error("ERROR:", buf, "can't open vector map");
+	    return 0;
+	PS.vct[i].type = AREAS;
-    /* generic default values */
-    PS.vct[i].type   = AREAS;
-    PS.vct[i].id     = i;
-    PS.vct[i].layer  = 1;
-    PS.vct[i].cats   = NULL;
-    PS.vct[i].where  = NULL;
-    PS.vct[i].masked = 0;
-    PS.vct[i].label  = G_store(name);
-    PS.vct[i].lpos   = 0;
     /* specific default values */
-    vector = (VAREAS *)PS.vct[i].data;
+    vector = (VAREAS *) PS.vct[i].data;
     unset_color(&(vector->fcolor));
-    vector->width    = 0.;
-    vector->type_pat = 1;   /* colored pattern */
-    vector->pat      = NULL;
-    vector->pwidth   = 1.;
-    vector->scale    = 1.;
-    vector->rgbcol   = NULL;
+    vector->width = 0;
+    vector->type_pat = 1;	/* colored pattern */
+    vector->name_pat = NULL;
+    vector->lw_pat = 1.;
+    vector->sc_pat = 1.;
+    vector->island = 1;
+    vector->rgbcol = NULL;
+    vector->idcol  = NULL;
-            continue;
-            G_strip(data);
-            scan_dimen(data, &(vector->width));
-            continue;
-        if (KEY("line")) {
-            read_psline(data, &(vector->line));
-            continue;
-            int ret = sscanf(data, "%s %s", stra, strb);
-                error(key, data, "illegal fcolor (vareas)");
+	    continue;
+	if (KEY("lwidth"))
+	    G_strip(data);
+            if (scan_dimen(data, &(vector->width)) != 1)
+                error(key, data, "illegal 'lwidth' width (vareas)");
+	    continue;
+	if (KEY("line"))
+	    read_psline(data, &(vector->line));
+	    continue;
+	    int ret = sscanf(data, "%s %[^\n]", stra, strb);
+            if (ret == 1 || ret == 2)
+                if (!scan_color(stra, &(vector->fcolor)))
+                    double alpha;
+                    if (ret == 2)
+                        vector->idcol = G_store(strb);
+                    ret = sscanf(stra, "%[^$]$%lf", strb, &alpha);
+                    vector->rgbcol = G_store(strb);
+                    vector->fcolor.a = (ret == 2) ? alpha : 1.;
+                    G_message(" >>> Request fcolor from column '%s' (vareas)", vector->rgbcol);
+                    vector->type_pat = 2;	/* uncolored pattern */
-            if (!scan_color(stra, &(vector->fcolor))) {
+            else
+                error(key, data, "illegal data in 'fcolor' (vareas)");
-            if (ret == 2) {
-                vector->rgbcol = G_store(strb);
-                G_warning("Request fcolor from database '%s' (vareas)",
-                          vector->rgbcol);
-                vector->type_pat = 2;   /* uncolored pattern */
+	    continue;
+	if (KEY("pat"))
+	    G_chop(data);
+	    vector->name_pat = G_store(data);
+	    continue;
+	if (KEY("pscale"))
+	    G_chop(data);
+	    vector->sc_pat = atof(data);
+	    continue;
+	if (KEY("pwidth"))
+	    if (scan_dimen(data, &(vector->lw_pat)) != 1)
+		error(key, data, "illegal pattern width (vareas)");
+	    continue;
+	if (KEY("island"))
+	    vector->island = scan_yesno(key, data);
+	    continue;
+	/* common options of all vectors */
+	if (KEY("layer"))
+	    G_strip(data);
+	    PS.vct[i].layer = atoi(data);
+	    if (PS.vct[i].layer < 1)
+		PS.vct[i].layer = 1;
+	    continue;
+	if (KEY("cats") || KEY("cat"))
+	    G_strip(data);
+	    PS.vct[i].cats = G_store(data);
+	    continue;
+	if (KEY("where"))
+	    G_strip(data);
+	    PS.vct[i].where = G_store(data);
+	    continue;
+	if (KEY("masked"))
+	    PS.vct[i].masked = scan_yesno(key, data);
+	    if (PS.vct[i].masked)
+		PS.need_mask = 1;
+	    continue;
+	if (KEY("label"))
+	    G_strip(data);
+	    PS.vct[i].label = G_store(data);
+	    continue;
+	if (KEY("legend") || KEY("lpos"))
+	    int k;
+	    if (sscanf(data, "%d", &k) == 1)
+		PS.vct[i].lpos = k;
+	    else
+		read_block(i);
+	    continue;
+	if (KEY("setrule"))
+            double val;
+            char str[128], catsbuf[128], labelbuf[128];
+            if (sscanf(data, "%s %[^\n]", str, labelbuf) > 0)
+                if (sscanf(str, "%[^:]:%lf", catsbuf, &val) == 1)
+                    val = 0.;
+                vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, val);
+            else
+                error(key, data, "illegal 'setrule' request (vareas)");
             continue;
-        if (KEY("pat")) {
-            G_chop(data);
-            vector->pat = G_store(data);
-            continue;
-        if (KEY("scale")) {
-            G_chop(data);
-            vector->scale = atof(data);
-            continue;
-        if (KEY("pwidth")) {
-            if (scan_dimen(data, &(vector->pwidth)) != 1) {
-                error(key, data, "illegal pattern width (vareas)");
-            continue;
-        /* common options of all vectors */
-        if (KEY("layer")) {
-            G_strip(data);
-            PS.vct[i].layer = atoi(data);
-            if (PS.vct[i].layer < 1)
-            continue;
-        if (KEY("cats") || KEY("cat")) {
-            G_strip(data);
-            PS.vct[i].cats = G_store(data);
-            continue;
-            G_strip(data);
-            PS.vct[i].where = G_store(data);
-            continue;
-        if (KEY("masked")) {
-            PS.vct[i].masked = scan_yesno(key, data);
-            if (PS.vct[i].masked)
-                PS.need_mask = 1;
-            continue;
-        if (KEY("label")) {
-            G_strip(data);
-            PS.vct[i].label = G_store(data);
-            if (PS.vct[i].lpos == 0)
-                PS.vct[i].lpos = 1;
-            continue;
-        if (KEY("lpos")) {
-            G_strip(data);
-            PS.vct[i].lpos = atoi(data);
-            continue;
-        error(key, "", "illegal request (vareas)");
+	error(key, "", "illegal request (vareas)");
+    /* default label */
+    if (PS.vct[i].label == NULL)
+	sprintf(buf, "%s (%s)", PS.vct[i].name, PS.vct[i].mapset);
+	PS.vct[i].label = G_store(buf);
+    if (vector->rgbcol == NULL)
+        vector_item_new(&(PS.vct[i]), 0, color_to_long(&(vector->fcolor)));
+       int x, y;
+       for (x = 0; x < PS.vct[i].n_rule; x++)
+       printf("::: RULE %d :::", x+1);
+       for (y = 0; y < PS.vct[i].rule[x].count; y += 2)
+       printf(" %f-%f (%f): %s\n",
+       PS.vct[i].rule[x].val_list[y], PS.vct[i].rule[x].val_list[y+1],
+       PS.vct[i].rule[x].value, PS.vct[i].rule[x].label);
     return 1;
Modified: grass-addons/postscript/ps.output/r_vlegend.c
--- grass-addons/postscript/ps.output/r_vlegend.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_vlegend.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,7 +16,6 @@
 int read_vlegend(char *arg)
     char buf[1024];
@@ -26,62 +25,76 @@
     G_debug(1, "Reading vlegend settings ..");
-	PS.vl.legend.cols  = 1;
-	PS.vl.legend.span  = 10.;
-	PS.vl.legend.width = -1.;
+    G_strip(arg);
+    strncpy(PS.vl.legend.title, arg, TITLE_LEN);
+    default_font(&(PS.vl.legend.title_font));
     default_font(&(PS.vl.legend.font));
     default_frame(&(PS.vl.legend.box), LEFT, LOWER);
-    PS.vl.legend.title[0] = 0;
-    default_font(&(PS.vl.legend.title_font));
-    PS.vl.order[0] = 0;
+    PS.vl.legend.cols = 1;
+    PS.vl.legend.width = -1;
+    PS.vl.legend.xspan = -1;
+    PS.vl.legend.yspan = -1;
-            continue;
-            G_strip(data);
-            strncpy(PS.vl.legend.title, data, 50);
-            read_font("", &(PS.vl.legend.title_font));
-            continue;
-          read_font(data, &(PS.vl.legend.font));
-          continue;
-          read_frame(&(PS.vl.legend.box));
-          continue;
-            int n;
-            n = sscanf(data, "%d %lf", &(PS.vl.legend.cols), &(PS.vl.legend.span));
-                if (PS.vl.legend.cols < 0) PS.vl.legend.cols = 1;
-                if (n == 1) PS.vl.legend.span = -1.;
+	    continue;
+	if (KEY("title") || KEY("title_font"))
+	    G_strip(data);
+	    read_font(data, &(PS.vl.legend.title_font));
+	    continue;
+	if (KEY("font"))
+	    read_font(data, &(PS.vl.legend.font));
+	    continue;
+	if (KEY("frame"))
+	    read_frame(&(PS.vl.legend.box));
+	    continue;
+        if (KEY("cols"))
+            int n = sscanf(data, "%d %lf",
+                           &(PS.vl.legend.cols), &(PS.vl.legend.xspan));
+                if (PS.vl.legend.cols <= 0)
+                if (n == 1)
+                    PS.vl.legend.xspan = -1.;
             else
-                error(key, data, "illegal cols/span request (vlegend)");
+                error(key, data, "illegal cols/xspan request (vlegend)");
             continue;
-            if(scan_dimen(data, &(PS.vl.legend.width)) != 1) {
+            if (scan_dimen(data, &(PS.vl.legend.width)) != 1)
-                error(key, data, "illegal width request (vlegend)");
+                error(key, data, "illegal swidth request (vlegend)");
             continue;
-            G_strip(data);
-            strncpy(PS.vl.order, data, 510);
-            PS.vl.order[510] = 0;
+        if (KEY("interline") || KEY("dy"))
+            if (scan_dimen(data, &(PS.vl.legend.yspan)) != 1)
+                error(key, data, "illegal interline request (vlegend)");
             continue;
-        error(key, data, "illegal vlegend sub-request");
+	error(key, data, "illegal vlegend sub-request");
-    PS.do_vlegend = PS.vct_files;
+    PS.do_vlegend = 1;
     return 0;
Modified: grass-addons/postscript/ps.output/r_vlines.c
--- grass-addons/postscript/ps.output/r_vlines.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_vlines.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -28,121 +28,176 @@
-    PS.vct[i].data   = G_malloc(sizeof(VLINES));
+	PS.vct[i].data = G_malloc(sizeof(VLINES));
-        return 0;
+	    return 0;
+	PS.vct[i].type = LINES;
-    PS.vct[i].type   = LINES;
-    PS.vct[i].id     = i;
-    PS.vct[i].label  = NULL;
-    vector = (VLINES *)PS.vct[i].data;
-    vector->type        = GV_LINE;
+    vector = (VLINES *) PS.vct[i].data;
+    vector->type = GV_LINE;
     default_psline(&(vector->line));
     default_psline(&(vector->hline));
     vector->hline.width = 0.;
-    vector->offset      = 0.;
+    vector->offset = 0.;
-            continue;
-        if (KEY("type")) {
-            G_strip(data);
-            if (strcmp(data, "boundary") == 0)
-                vector->type = GV_BOUNDARY;
-            /* else default GV_LINE */
-            continue;
-        if (KEY("rgbcol")) {
-            G_strip(data);
-            vector->rgbcol = G_store(data);
-            G_warning("Request line color from database '%s' (vlines)",
-                      vector->rgbcol);
-            continue;
-            continue;
-        if (KEY("hline")) {
-            if (scan_dimen(data, &(vector->offset)) == 0) {
-            read_psline("", &(vector->hline));
-            if (vector->hline.width > 0 && vector->offset == 0.) {
-                vector->hline.width =
-                        vector->line.width +
-                        2. * vector->hline.width;
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-                PS.need_mask = 1;
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-        error(key, "", "illegal request (vlines)");
+	    continue;
+	if (KEY("type"))
+	    G_strip(data);
+	    if (data[0] == 'b')
+		vector->type = GV_BOUNDARY;
+	    else
+	    continue;
+	if (KEY("line"))
+	    continue;
+        if (KEY("rgbcol"))
+            double alpha;
+		error(key, data, "illegal fcolor (vlines)");
+	    if (ret == 2)
+	    vector->line.color.a = (ret == 2) ? alpha : 1.;
+	    G_warning("Request rgbcol from '%s' database column (vlines)", vector->rgbcol);
+	    continue;
+	if (KEY("hline"))
+	    read_psline(data, &(vector->hline));
+	    continue;
+	    if (scan_dimen(data, &(vector->offset)) == 0)
+	    continue;
+	if (KEY("layer"))
+	    G_strip(data);
+	    continue;
+	    G_strip(data);
+	    continue;
+	if (KEY("where"))
+	    G_strip(data);
+	    continue;
+		PS.need_mask = 1;
+	    continue;
+	if (KEY("label"))
+	    G_strip(data);
+	    continue;
+	    int k;
+	    else
+		read_block(i);
+	    continue;
+	    char catsbuf[128], labelbuf[128];
+            if (sscanf(data, "%s %[^\n]", catsbuf, labelbuf) != 2)
+                error(key, data, "illegal setrule request (vlines)");;
+            vector_rule_new(&(PS.vct[i]), catsbuf, labelbuf, 0);
+	    continue;
+	error(key, "", "illegal request (vlines)");
+    /* final adjust of hline width */
+    if (vector->hline.width > 0. && vector->offset == 0.)
+	vector->hline.width = vector->line.width + 2. * vector->hline.width;
+       vector_item_new(&(PS.vct[i]), 0, color_to_long(&(vector->line.color)));
     return 1;
Modified: grass-addons/postscript/ps.output/r_vpoints.c
--- grass-addons/postscript/ps.output/r_vpoints.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/r_vpoints.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -26,144 +26,253 @@
     VPOINTS *vector;
+    G_debug(1, "Reading vpoints settings ..");
-    PS.vct[i].data   = G_malloc(sizeof(VPOINTS));
+	PS.vct[i].data = G_malloc(sizeof(VPOINTS));
-        return 0;
+	    return 0;
+	PS.vct[i].type = POINTS;
-    PS.vct[i].type   = POINTS;
-    PS.vct[i].id     = i;
-    vector            = (VPOINTS *)PS.vct[i].data;
-    vector->type      = GV_POINT;
-    vector->symbol    = G_store("basic/circle");
-    vector->size      = 1.0;
-    vector->sizecol   = NULL;
+    vector = (VPOINTS *) PS.vct[i].data;
+    vector->type = GV_POINT;
+    vector->symbol = G_store("basic/circle");
+    vector->size    = 1.0;
+    vector->sizecol = NULL;
     vector->rotate    = 0.0;
     vector->rotatecol = NULL;
-    vector->scale     = 1.0;
+    vector->scale = 1.0;
+    vector->bias  = 0.0;
+    vector->distance = 0.;
+    vector->voffset = 0.;
+    default_psline(&(vector->cline));
-            continue;
+	    continue;
+	if (KEY("type"))
+	    G_strip(data);
+	    switch (data[0])
+	    case 'c':
+		vector->type = GV_CENTROID;
+		break;
+	    case 'l':
+		break;
+	    case 'b':
+		break;
+	    default:
+		break;
+	    continue;
+	if (KEY("symbol"))
+	    vector->symbol = G_store(data);
+	    continue;
+	if (KEY("line"))
+	    continue;
+	    if (!scan_color(data, &(vector->fcolor)))
+		error(key, data, "illegal fcolor request (vpoints)");
+	    continue;
+	if (KEY("size"))
+	    switch (sscanf(data, "%s %s", stra, strb))
+	    case 1:
+            if (atof(stra) != 0.)
+                vector->size = atof(stra);
+            else
+                vector->sizecol = G_store(stra);
+            break;
+	    case 2:
+            vector->size = atof(strb);
+            break;
+	    default:
+            error(key, data, "illegal scale request (vpoints)");
+	    if (vector->sizecol != NULL)
+            G_warning("Request size from '%s' column (vpoints)", vector->sizecol);
+	    continue;
+	if (KEY("scale"))
+        case 1:
+            scan_dimen(stra, &(vector->scale));
+            vector->bias = 0.;
+            break;
+        case 2:
+            scan_dimen(strb, &(vector->bias));
+            break;
+        default:
+            error(key, data, "illegal scale [bias] request (vpoints)");
+            break;
-            G_strip(data);
-            if (strcmp(data, "centroid"))
-                vector->type = GV_CENTROID;
-            /* else default GV_POINT */
-            continue;
+	    continue;
+        if (scan_dimen(data, &(vector->voffset)) != 1)
+            error(key, data, "illegal voffset request (vpoints)");
-        if (KEY("symbol")) {
-            vector->symbol = G_store(data);
-            continue;
-            continue;
-            if (!scan_color(data, &(vector->fcolor))) {
-                error(key, data, "illegal fcolor request (vpoints)");
-            continue;
-                error(key, data, "illegal size request (vpoints)");
-            vector->size = atof(stra);
-            if (ret == 2)
-                vector->sizecol = G_store(strb);
-            continue;
-            if (scan_dimen(data, &(vector->scale)) != 1) {
-                error(key, data, "illegal scale request (vpoints)");
-            continue;
-                error(key, data, "illegal rotate request (vpoints)");
-            vector->rotate = atof(stra);
-            if (ret == 2)
-                vector->rotatecol = G_store(strb);
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-                PS.need_mask = 1;
-            continue;
-            G_strip(data);
-            continue;
-            G_strip(data);
-            continue;
-        error(key, "", "illegal request (vpoints)");
+        continue;
+	    if (atof(data) != 0.)
+		vector->rotate = atof(data);
+	    else
+		vector->rotatecol = G_store(data);
+		G_warning("Request rotate from '%s' column (vpoints)", vector->rotatecol);
+	    continue;
+	if (KEY("dist"))
+	    if (scan_dimen(data, &(vector->distance)) != 1)
+		error(key, data, "illegal dist request (vpoints)");
+	    continue;
+	if (KEY("cline"))
+	    read_psline(data, &(vector->cline));
+	    continue;
+	if (KEY("layer"))
+	    G_strip(data);
+	    continue;
+	    G_strip(data);
+	    continue;
+	if (KEY("where"))
+	    G_strip(data);
+	    continue;
+		PS.need_mask = 1;
+	    continue;
+	if (KEY("label"))
+	    G_strip(data);
+	    continue;
+	    int k;
+	    else
+		read_block(i);
+	    continue;
+	    double val;
+                val = atof(catsbuf) * vector->scale;
+	    else
+            error(key, data, "illegal setrule request (vpoints)");
+	    continue;
+	error(key, "", "illegal request (vpoints)");
+    if (vector->sizecol == NULL)
+        vector_item_new(&(PS.vct[i]), 0, (long)(vector->size * 1000.));
     return 1;
Modified: grass-addons/postscript/ps.output/raster.c
--- grass-addons/postscript/ps.output/raster.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/raster.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,13 +19,14 @@
     for (i = 0; i < 3; i++)
-        if (PS.rst.fd[i] >= 0) {
-    	    G_close_cell(PS.rst.fd[i]);
-	        G_free(PS.rst.name[i]);
-	        G_free(PS.rst.mapset[i]);
-	        G_free_colors(&(PS.rst.colors[i]));
-	        PS.rst.fd[i] = -1;
+	if (PS.rst.fd[i] >= 0)
+	    G_close_cell(PS.rst.fd[i]);
+	    G_free(PS.rst.name[i]);
+	    G_free(PS.rst.mapset[i]);
+	    G_free_colors(&(PS.rst.colors[i]));
+	    PS.rst.fd[i] = -1;
     return 1;
Modified: grass-addons/postscript/ps.output/raster.h
--- grass-addons/postscript/ps.output/raster.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/raster.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -22,7 +22,7 @@
     struct Categories cats;
     struct Colors colors[3];
-    CELL min, max;  /* to get color table, in gradient */
+    CELL min, max;		/* to get color table, in gradient */
     int fd[3];
     char *name[3], *mapset[3];
Modified: grass-addons/postscript/ps.output/rlegend.h
--- grass-addons/postscript/ps.output/rlegend.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/rlegend.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -14,23 +14,28 @@
 #include <stdio.h>
 #include "legends.h"
+#define MAX_CATS    512
 typedef struct
     char name[128];
     char mapset[128];
-	LEGEND legend;
+    LEGEND legend;
     /* category rlegend */
-    int do_nodata;          /* show no data categoty */
-    char cat_order[512];    /* category custom order */
+    int do_nodata;		/* show no data categoty */
+    char cat_order[MAX_CATS];	/* category custom order */
     /* gradient rlegend */
-    int do_gradient;        /* forze gradient when no float */
-    double height;          /* Next only for float raster */
-	int custom_range;
+    double height;
+    int custom_range;
     double min, max;
     int tickbar;
-	int whiteframe;
+    int whiteframe;
+    int do_gradient;		/* forze gradient when no float */
 } RLEGEND;
 #endif
Modified: grass-addons/postscript/ps.output/scalebar.h
--- grass-addons/postscript/ps.output/scalebar.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/scalebar.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -33,8 +33,8 @@
     PSFONT font;
     PSCOLOR fcolor;
-    int labels, segments;   /* normal segments */
-    int sublabs, subsegs;   /* first segment subdivisions */
+    int labels, segments;	/* normal segments */
+    int sublabs, subsegs;	/* first segment subdivisions */
     int ucode;
     char units[50];
Modified: grass-addons/postscript/ps.output/scanners.c
--- grass-addons/postscript/ps.output/scanners.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/scanners.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -10,14 +10,14 @@
 int scan_easting(char *buf, double *f)
     if (scan_percent(buf, f, PS.map.west, PS.map.east))
-	    return 1;
+	return 1;
     return G_scan_easting(buf, f, PS.map.proj);
 int scan_northing(char *buf, double *f)
     if (scan_percent(buf, f, PS.map.south, PS.map.north))
-	    return 1;
+	return 1;
     return G_scan_northing(buf, f, PS.map.proj);
@@ -27,11 +27,11 @@
     *percent = 0;
     if (sscanf(buf, "%lf%2s", f, percent) != 2)
-	    return 0;
+	return 0;
     if (strcmp(percent, "%") != 0)
-	    return 0;
+	return 0;
     *f = min + (max - min) * (*f / 100.0);
-        return 1;
+    return 1;
 /* scan references */
@@ -41,28 +41,22 @@
     *xref = *yref = CENTER;
     if (sscanf(buf, "%9s %9s", refx, refy) != 2)
-        return 0;
+	return 0;
-    if(strcmp(refx, "LEFT") == 0 || strcmp(refx, "left") == 0)
-        *xref = LEFT;
-    else if(strcmp(refx, "CENTER") == 0 || strcmp(refx, "center") == 0)
-        *xref = CENTER;
-    else if(strcmp(refx, "RIGHT") == 0 || strcmp(refx, "right") == 0)
-        *xref = RIGHT;
-    else
-        return 0;
-    if(strcmp(refy, "UPPER") == 0 || strcmp(refy, "upper") == 0)
-        *yref = UPPER;
-    else if(strcmp(refy, "CENTER") == 0 || strcmp(refy, "center") == 0)
-        *yref = CENTER;
-    else if(strcmp(refy, "LOWER") == 0 || strcmp(refy, "lower") == 0)
-        *yref = LOWER;
-    else
-        return 0;
+    if (strcmp(refx, "LEFT") == 0 || strcmp(refx, "left") == 0)
+	*xref = LEFT;
+    else if (strcmp(refx, "CENTER") == 0 || strcmp(refx, "center") == 0)
+	*xref = CENTER;
+    else if (strcmp(refx, "RIGHT") == 0 || strcmp(refx, "right") == 0)
+	*xref = RIGHT;
+    if (strcmp(refy, "UPPER") == 0 || strcmp(refy, "upper") == 0)
+	*yref = UPPER;
+    else if (strcmp(refy, "CENTER") == 0 || strcmp(refy, "center") == 0)
+	*yref = CENTER;
+    else if (strcmp(refy, "LOWER") == 0 || strcmp(refy, "lower") == 0)
+	*yref = LOWER;
     return 1;
@@ -72,20 +66,28 @@
     char buf;
     if (sscanf(data, "%c", &buf) != 1)
-        return 1;
-    if (buf == 'y' || buf == 'Y')
-        return 1;
-    if (buf == 'n' || buf == 'N')
-        return 0;
+	return 1;
+    if (buf == 'y' || buf == 'Y' || buf == 't' || buf == 'T')
+	return 1;
+    if (buf == 'n' || buf == 'N' || buf == 'f' || buf == 'F')
+	return 0;
     error(key, data, "illegal yes/no option");
     return 0;
-int scan_color(char *data, PSCOLOR *color)
+int scan_color(char *data, PSCOLOR * color)
-    if (set_color_name(color, data)) {
-        return 1;
+    int ret;
+    char name[20];
+    double alpha;
+    ret = sscanf(data, "%[^$]$%lf", name, &alpha);
+    if (set_color_name(color, name))
+	color->a = (ret == 2) ? alpha : 1.;
+	return 1;
     return 0;
@@ -100,24 +102,28 @@
     ret = sscanf(data, "%lf%c", d, &unit);
     if (ret == 1)
-        unit = ' ';
-    else if (ret != 2) {
-        *d = 0.;
-        return 0;
+	unit = ' ';
+    else if (ret != 2)
+	*d = 0.;
+	return 0;
     switch (unit)
-        /* metric to points */
-        case 'i': *d *= INCH_TO_POINT;
-            break;
-        case 'm': *d *= MM_TO_POINT;
-            break;
-        case 'c': *d *= CM_TO_POINT;
-            break;
-        /* special : percent*/
-        case '%':
-            return 2;
+	/* metric to points */
+    case 'i':
+	*d *= INCH_TO_POINT;
+	break;
+    case 'm':
+	*d *= MM_TO_POINT;
+	break;
+    case 'c':
+	*d *= CM_TO_POINT;
+	break;
+	/* special : percent */
+    case '%':
+	return 2;
     return (*d < 0 ? -1 : 1);
@@ -132,16 +138,17 @@
     if (ret == 1)
-        unit = ' ';
-    else if (ret != 2 || *d < 0.) {
-        *d = 0.;
-        return 0;
+	unit = ' ';
+    else if (ret != 2 || *d < 0.)
+	*d = 0.;
+	return 0;
     if (unit == '\'' || unit == 'm')
-        *d *= 60.;
+	*d *= 60.;
     else if (unit == 'º' || unit == 'd')
-        *d *= 3600.;
+	*d *= 3600.;
     return 1;
Modified: grass-addons/postscript/ps.output/set_draw.c
--- grass-addons/postscript/ps.output/set_draw.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_draw.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -22,218 +22,316 @@
 void label_in_file(char *);
-int set_draw(char * key, char *data)
+static PSCOLOR fcolor;
+int set_draw(char *key, char *data)
-    char label[100], buf[256];
-    int i;
-    double d, lw, e1, e2, n1, n2;
+    char h, label[100], buf[256];
+    char e1[20], n1[20], e2[20], n2[20];
+    int i, x, y, dg, mg;
+    double east, north, lw, d, sg;
     PSCOLOR color;
     if (KEY("direct"))
-        fprintf(PS.fp, " %s ", data);
+	fprintf(PS.fp, " %s ", data);
     else if (KEY("color"))
-        set_color_name(&color, data);
+        if (!scan_color(data, &color))
+            error(key, data, "color: color");
         set_ps_color(&color);
+    else if (KEY("fcolor"))
+	scan_color(data, &fcolor);
+    else if (KEY("linewidth"))
+        if (sscanf(data, "%s", label) != 1 ||
+            scan_dimen(label, &lw) != 1)
+	    error(key, data, "linewidth: width");
+	fprintf(PS.fp, "%.1f LW ", lw);
+    else if (KEY("linedash"))
+	if (sscanf(data, "%[^\n]", label) != 1)
+            fprintf(PS.fp, "[] 0 LD ");
+        else
+            fprintf(PS.fp, "[%s] 0 LD ", label);
     else if (KEY("font"))
-        i = sscanf(data, "%s %s %lf", label, buf, &d);
-        if (i != 2 && i != 3)
+	i = sscanf(data, "%s %s %lf", label, buf, &d);
+	if ((i != 2 && i != 3) || (scan_dimen(buf, &lw) != 1))
+	    error(key, data, "font: name, size, and [extend]");
+	fprintf(PS.fp, "(%s) FN %.1f ", label, lw);
+	if (i == 2)
+	    fprintf(PS.fp, "FS ");
+	else
+	    fprintf(PS.fp, "%.2f FE ", d);
+    /* Drawing text */
+    else if (KEY("text") ||
+             KEY("ltext") ||
+             KEY("ctext") ||
+             KEY("rtext") ||
+             KEY("xtext") ||
+             KEY("vtext"))
+	if (sscanf(data, "%s %s %[^\n]", e1, n1, label) != 3)
+	    error(key, data, "text: east, north and text");
+	if (atoi(e1) < 0)
-            error(key, data, "font need 2 or 3 parameters (name, size, and [extend])");
+	    fprintf(PS.fp, "GS %s ROT (%s) ", n1, label);
-        if (scan_dimen(buf, &lw) != 1) {
-            error(key, data, "size not valid (font)");
+	else
+	    sprintf(buf, "M (%s) ", label);
+	    set_on_paper("GS", e1, n1, buf);
+        switch (*key)
+        case 'x':
+            strcpy(buf, "SHCC");
+            break;
+        case 'c':
+            strcpy(buf, "SHC");
+            break;
+        case 'r':
+            strcpy(buf, "SHR");
+            break;
+        case 'v':
+            strcpy(buf, "SVC");
+            break;
+        default:
+            strcpy(buf, "TXT");
+            break;
-        fprintf(PS.fp, "(%s) FN %.1f ", label, lw);
-        if (i == 2 )
-            fprintf(PS.fp, "FS ");
-        else
-            fprintf(PS.fp, "%.2f FE ", d);
+        fprintf(PS.fp, "%s GR\n", buf);
-    else if (KEY("text"))
+    else if (KEY("-text"))
-        if (sscanf(data, "%lf %lf %[^\n]", &e1, &n1, label) != 3) {
-            error(key, data, "text need 3 parameters (east, north and text)");
-        set_xy_where("", e1, n1, "M ");
-        fprintf(PS.fp, "(%s) SHCC\n", label);
+	fprintf(PS.fp, " (%s) SHL ", data);
+    else if (KEY("textc"))
+            error(key, data, "ctext: east, north, and text");
+	sprintf(buf, "M GS (%s) dup SHCC GR "
+                "SWH 2 copy gt {pop} {exch pop} ifelse 2 div 2 add "
+                "cP 3 -1 roll 0 360 NP arc CP S\n", label);
+	set_on_paper("", e1, n1, buf);
+    else if (KEY("labels") ||
+             KEY("label"))
+	if (sscanf(data, "%s", label) != 1)
+	    error(key, data, "labels: filename");
+	label_in_file(label);
+    /* Drawing paths */
     else if (KEY("moveto"))
-        if (sscanf(data, "%s %lf %lf", label, &e1, &n1) != 3) {
-            error(key, data, "moveto need 3 parameters");
-        if (scan_dimen(label, &lw) != 1) {
-            error(key, data, "width not valid (line)");
-        fprintf(PS.fp, "%.1f LW", lw);
+	if (sscanf(data, "%s %s", e1, n1) != 2)
+	    error(key, data, "moveto: east and north");
+	set_on_paper("", e1, n1, "M ");
-    else if (KEY("lineto"))
+    else if (KEY("lineto") ||
+             KEY("ruteto"))
-        if (sscanf(data, "%lf %lf", &e1, &n1) != 2) {
-            error(key, data, "lineto need 2 parameters (east and north)");
-        set_xy_where("", e1, n1, "L ");
+	switch (sscanf(data, "%s %s %[^\n]", e1, n1, buf))
+	case 2:
+	    set_on_paper("", e1, n1, "L ");
+	    break;
+	case 3:
+	    set_on_paper("cP exch 2 copy", e1, n1, "L GS cP 2 copy 8 2 roll");
+	    fprintf(PS.fp,
+		    " 4 -1 roll add 2 div 3 1 roll add 2 div exch M"
+		    " 4 1 roll sub 3 1 roll exch sub atan ROT 0 2 MR (%s) SHC S GR\n", buf);
+	    break;
+	default:
+	    error(key, data, "lineto: east, north, and [text]");
-    else if (KEY("endto"))
+    else if (KEY("endline"))
-            error(key, data, "endto need 2 parameters");
-        set_xy_where("", e1, n1, "LS\n");
+        fprintf(PS.fp, " S");
     else if (KEY("line"))
-        if (sscanf(data, "%s %lf %lf %lf %lf", label, &e1, &n1, &e2, &n2) != 5) {
-            error(key, data, "line need 5 parameters");
-        set_xy_where("", e1, n1, "M");
-        set_xy_where("", e2, n2, "LS\n");
+	if (sscanf(data, "%s %s %s %s", e1, n1, e2, n2) != 4)
+            error(key, data, "line: east/north east/north");
+	set_on_paper("", e1, n1, "M");
+	/* if e2 < 0 polares angulo y longitud */
+	set_on_paper("", e2, n2, "LS\n");
-    else if (KEY("rect") || KEY("rectangle"))
+    else if (KEY("border"))
-            error(key, data, "rectangle need 5 parameters");
-            error(key, data, "width not valid (rectangle)");
-        set_xy_where("", e1, n1, "");
-        set_xy_where("", e2, n2, "B S\n");
+            scan_dimen(label, &d) != 1)
+            error(key, data, "border: width");
+        set_ps_brd(d);
-    else if (KEY("circ") || KEY("circle"))
+    else if (KEY("rect") ||
+             KEY("rectangle"))
-        if (sscanf(data, "%s %lf %lf %lf", label, &e1, &n1, &d) != 4) {
-            error(key, data, "circle need 4 parameters");
-            error(key, data, "width not valid (circle)");
-        d *= (MT_TO_POINT / (double)PS.scale);
-        fprintf(PS.fp, "%.1f 0 360 arc S\n", d);
+	switch (sscanf(data, "%s %s %s %s %s", e1, n1, e2, n2, buf))
+	case 4:
+	    set_on_paper("", e1, n1, "");
+	    set_on_paper("", e2, n2, "B S\n");
+	    break;
+	case 5:
+	    scan_color(buf, &color);
+	    set_on_paper("", e2, n2, "B GS ");
+	    set_ps_color(&color);
+	    fprintf(PS.fp, "fill GR S\n");
+	    break;
+	default:
+	    error(key, data, "rectangle: east/north and east/north [fill color])");
-    else if (KEY("arc"))
+    else if (KEY("circ") ||
+             KEY("circle"))
-        if (sscanf(data, "%s %lf %lf %lf %lf %lf", label, &e1, &n1, &d, &e2, &n2) != 6) {
-            error(key, data, "arc need 6 parameters");
-        fprintf(PS.fp, "%.1f %.1f %.1f arc S\n", d, e2, n2);
+	if (sscanf(data, "%s %s %lf", e1, n1, &d) != 3)
+	    error(key, data, "circle: x, y and radius");
+	sprintf(buf, "%.1f 0 360 arc S\n", d * (MT_TO_POINT / (double)PS.scale));
-    else if (KEY("psfile"))
+    else if (KEY("arc"))
-        FILE *fp;
-        if ((fp = fopen(data, "r")) != NULL)
-            G_message("Reading PostScript include file <%s> ...", data);
-            fprintf(PS.fp, "\n");
-            while (fgets(buf, 256, fp) != NULL)
-                fprintf(PS.fp, "%s", buf);
-            fclose(fp);
+	if (sscanf(data, "%s %s %lf %s %s", e1, n1, &d, e2, n2) != 5)
+	    error(key, data, "arc need 5 parameters");
+	sprintf(buf, "%.1f", d * (MT_TO_POINT / (double)PS.scale));
+	set_on_paper(buf, e2, n2, "arc S\n");
-    else if (KEY("limit") || KEY("limits"))
+    /* Include files */
+    else if (KEY("psfile") ||
+             KEY("epsfile"))
-        fprintf(PS.fp, "%.1f %.1f M ", PS.map_right, PS.map_top);
-        G_format_northing(PS.map.north, label, PS.map.proj);
-        fprintf(PS.fp, "GS (%s) dup SWH ++ neg dup MR pop SHR GR\n", label);
-        G_format_easting(PS.map.east, label, PS.map.proj);
-        fprintf(PS.fp, "GS (%s) dup SWH ++ dup neg 3 1 roll add neg MR 270 ROT SHR GR\n", label);
-        fprintf(PS.fp, "%.1f %.1f M ", PS.map_x, PS.map_y);
-        G_format_easting(PS.map.west, label, PS.map.proj);
-        fprintf(PS.fp, "GS (%s) dup SWH ++ dup MR pop 90 ROT SHL GR\n", label);
-        G_format_northing(PS.map.south, label, PS.map.proj);
-        fprintf(PS.fp, "GS (%s) dup SWH ++ 1 MR pop SHL GR\n", label);
+	if (sscanf(data, "%lf %s %s %s", &d, e1, n1, label) != 4)
+	    error(key, data, "psfile: scale, east, north, and filename");
+	set_on_paper("GS", e1, n1, "TR ");
+	fprintf(PS.fp, "%.2f dup scale ", d);
+	FILE *fp;
+	if ((fp = fopen(label, "r")) != NULL)
+	    G_message("Reading PostScript file <%s> ...", label);
+	    fprintf(PS.fp, "\n");
+	       while (fgets(buf, 256, fp) != NULL)
+	       fprintf(PS.fp, "%s", buf);
+		if (strcmp(buf, "showpage\n") == 0)
+		    continue;
+	    fclose(fp);
+	fprintf(PS.fp, "GR\n");
-    else if (KEY("compass") || KEY("rose"))
+    /* Drawing complements */
+    else if (KEY("maplimit") ||
+             KEY("maplimits"))
-        char h;
-        int dg, mn;
-        double conv, sec;
+	    d = 0.;
+	else
+	    scan_dimen(label, &d);
-        if (sscanf(data, "%lf %lf %lf", &e1, &n1, &d) != 3) {
-            error(key, data, "compass roses need 3 parameters");
-        set_xy_where(".25 LW", e1, n1, "M ");
-        /* exterior */
-        fprintf(PS.fp, "GS 90 ROT ");
-        fprintf(PS.fp, "%.1f 0 90 270 {GS ROT dup 0 LR [1] 0 LD S GR} for ", d);
-        fprintf(PS.fp,
-                " 0 -1 -359 {/i XD GS i ROT dup 0 MR i 10 mod 0 eq "
-                        "{-9 0 LR i neg to_s dup SW 2 div 10 exch MR GS 270 ROT show GR} "
-                        "{i 5 mod 0 eq {-6} {-3} ifelse 0 LR} ifelse S GR} for ");
-        fprintf(PS.fp, " pop GR\n");
-        /* convergence, only for testing the command must have an angle parameter */
-        conv = 0.0;
-        if (PS.map.proj != PROJECTION_LL)
-            struct pj_info ll_proj, xy_proj;
+	fprintf(PS.fp, "%.1f %.1f add %.1f %.1f add M ", PS.map_right, d, PS.map_top, d);
+	format_northing(PS.map.north, buf, PS.map.proj);
+	fprintf(PS.fp, "GS (%s) dup SWH ++ neg dup MR pop SHR GR\n", buf);
+	format_easting(PS.map.east, buf, PS.map.proj);
+	fprintf(PS.fp, "GS (%s) dup SWH ++ dup neg 3 1 roll add neg MR 270 ROT SHR GR\n", buf);
-            init_proj(&ll_proj, &xy_proj);
-            e2 = e1; n2 = n1;
-            pj_do_proj(&e2, &n2, &xy_proj, &ll_proj);
-            n2 = 90.;
-            pj_do_proj(&e2, &n2, &ll_proj, &xy_proj);
-            conv = -1.*atan2(e2-e1, n2-n1)*180./PI;
-        /* interior */
-        fprintf(PS.fp, "GS %.3f ROT F0S .8 mul FS ", conv+90.);
-        fprintf(PS.fp, "%.1f 0 90 270 {GS ROT dup 0 LR S GR} for ", .60*d);
-        fprintf(PS.fp,
-                        "{6 0 LR i 30 mod 0 eq "
-                        "{i neg to_s dup SW 2 div 1 exch MR GS 270 ROT show GR} if} "
-                        "{i 5 mod 0 eq {3} {1.5} ifelse 0 LR} ifelse S GR} for ");
-        G_lon_parts(conv, &dg, &mn, &sec, &h);
-        fprintf(PS.fp, " 2 div 1 MR F0S 1.25 mul FS (%dº %d' %0.f'' %c) SHC GR\n", dg, mn, sec, h);
+	fprintf(PS.fp, "%.1f %.1f sub %.1f %.1f sub M ", PS.map_x, d, PS.map_y, d);
+	format_northing(PS.map.south, buf, PS.map.proj);
+	fprintf(PS.fp, "GS (%s) dup SWH ++ 1 MR pop SHL GR\n", buf);
+	format_easting(PS.map.west, buf, PS.map.proj);
+	fprintf(PS.fp, "GS (%s) dup SWH ++ dup MR pop 90 ROT SHL GR\n", buf);
-    else if (KEY("rute"))
+    else if (KEY("northarrow") ||
+             KEY("north"))
-        if (sscanf(data, "%s %lf %lf %[^\n]", label, &e1, &n1, buf) != 4) {
-            error(key, data, "rute need 4 parameters");
-            error(key, data, "width not valid (rune)");
-        fprintf(PS.fp, "%.1f LW ", lw);
-        set_xy_where("cP exch 2 copy", e1, n1, "L cP 2 copy 8 2 roll");
-        fprintf(PS.fp,
-                " 4 -1 roll add 2 div 3 1 roll add 2 div exch M"
-                        " 4 1 roll sub 3 1 roll exch sub atan GS ROT 0 1 MR (%s) SHC GR S\n", buf);
+	switch (sscanf(data, "%s %s %s", e1, n1, buf))
+	case 2:
+	    sprintf(buf, "M 5 dup neg dup 3 mul LR dup dup LR dup neg LR CP cP S M 0 2 MR (N) SHC\n");
+	    set_on_paper("NP .2 mm LW", e1, n1, buf);
+	    break;
+	case 3:
+	    sprintf(buf, "M GS "
+		    "/rl {67.5 sin mul exch 67.5 cos mul exch rlineto} D "
+		    "0 90 360 {ROT GS 8 8 rl -8 16 rl 0 -24 rl fill GR GS -8 8 rl 8 16 rl S GR} for "
+		    "45 ROT 0 90 360 {ROT GS 8 8 rl -8 8 rl 0 -16 rl fill GR GS -8 8 rl 8 8 rl S GR} for -45 ROT "
+		    "GS 0 24 MR (N) SHC GR GS 0 -24 MR (S) dup SWH neg 0 exch MR pop SHC GR GS -24 0 MR (W) SHRC GR GS 24 0 MR (E) SHLC GR "
+		    "GR\n");
+	    set_on_paper(".2 mm LW", e1, n1, buf);
+	    break;
+	default:
+	    error(key, data, "northarrow: x, y and radius");
-    else if (KEY("labels") || KEY("label"))
+    else if (KEY("declination"))
-        if (sscanf(data, "%s", label) != 1) {
-            error(key, data, "labels need 1 parameters (filename)");
-        label_in_file(label);
+    else if (KEY("compass") ||
+             KEY("rose"))
+	char h;
+	int dg, mn;
+	double conv, sec;
+	if (sscanf(data, "%lf %lf %lf %lf", east, north, &d, &conv) != 4)
+	    error(key, data, "compass: x, y, radius and magnetic declination");
+	d *= (MT_TO_POINT / (double)PS.scale);
+	set_xy_where(".25 LW", east, north, "M ");
+	/* exterior */
+	fprintf(PS.fp, "GS 90 ROT %.2f ", d);
+	fprintf(PS.fp, "0 90 270 {GS ROT dup 0 LR [1] 0 LD S GR} for ");
+	fprintf(PS.fp,
+		"0 -1 -359 {/i XD GS i ROT dup 0 MR i 10 mod 0 eq "
+		"{-9 0 LR i neg i2s dup SW 2 div 10 exch MR 270 ROT show} "
+		"{i 5 mod 0 eq {-6} {-3} ifelse 0 LR} ifelse S GR} for ");
+	fprintf(PS.fp, "pop GR\n");
+	format_northing(-conv, buf, PROJECTION_LL);
+	/* interior */
+	fprintf(PS.fp, "GS %.3f ROT FR %.2f ", conv + 90., .60 * d);
+	fprintf(PS.fp, "0 90 270 {GS ROT dup 0 LR [] 0 LD S GR} for ");
+	fprintf(PS.fp,
+		"0 -1 -359 {/i XD GS i ROT dup 0 MR i 30 mod 0 eq "
+		"{6 0 LR i neg i2s dup SW 2 div 1 exch MR 270 ROT show} "
+		"{i 5 mod 0 eq {3} {1.5} ifelse 0 LR} ifelse S GR} for ");
+	fprintf(PS.fp, "2 div 1 MR (%s) SHC GR\n", buf);
+    /* Oops ending */
     else
-        error(key, data, "not found\n");
+	error(key, data, "not found\n");
-    return 1;
+    return 0;
@@ -249,99 +347,162 @@
     frame.xref = CENTER;
     frame.yref = CENTER;
-    if (*name) {
-        in = fopen(name, "r");
-        if (in == NULL) {
-            G_message("Labels file <%s> can't open", name);
-            return;
+    if (*name)
+	in = fopen(name, "r");
+	if (in == NULL)
+	    G_message("Labels file <%s> can't open", name);
+	    return;
     while (fgets(buf, sizeof(buf), in))
-        *code = 0;
-        *data = 0;
-        if (sscanf(buf, "%[^:]:%[^\n]", code, data) < 1)
-            continue;
+	*code = 0;
+	*data = 0;
+	if (sscanf(buf, "%[^:]:%[^\n]", code, data) < 1)
+	    continue;
-        G_strip(data);
-        if (CODE("text")) {
+	G_strip(data);
+	if (CODE("text"))
-            G_plot_where_xy(frame.x, frame.y, &x, &y);
-            frame.x = ((double)x) / 10.;
-            frame.y = ((double)y) / 10.;
-            set_ps_font(&font);
-            fprintf(PS.fp, "GS\n");
-            fprintf(PS.fp, "/ARo [(%s)] def\n", data);
-            fprintf(PS.fp, "/ARw 1 array def ARw 0 ARo SWx put ");
-            fprintf(PS.fp, "/ARh [2.0] def\n");
-            set_box_auto(&frame, &font, 0.25);
-            set_box_readjust_title(&frame, data);
-            set_box_draw(&frame);
-            fprintf(PS.fp, "GR\n");
-            fprintf(PS.fp, "(%s) xo wd 2 div add yo hg 2 div sub M SHCC\n", data);
-        /* Option to modify the text */
-        else if (CODE("east")) {
-            frame.x = atof(data);
-        else if (CODE("north")) {
-            frame.y = atof(data);
-        else if (CODE("xoffset")) {
-            frame.xset = atof(data);
-        else if (CODE("yoffset")) {
-            frame.yset = atof(data);
-        else if (CODE("ref")) {
-            scan_ref(data, &(frame.xref), &(frame.yref));
-        else if (CODE("font")) {
-            get_font(data);
-            strcpy(font.name, data);
-        else if (CODE("fontsize")) {
-            if (scan_dimen(data, &(font.size)) != 1)
-                font.size = 10.;
-        else if (CODE("size")) {
-            n = atof(data);
-            font.size = (n * MT_TO_POINT)/PS.scale;
-        else if (CODE("color")) {
-            if (!scan_color(data, &(font.color))) {
-                set_color_rgb(&(font.color), 0, 0, 0);
-        else if (CODE("space")) {
-        else if (CODE("rotation")) {
-            frame.rotate = atof(data);
-        else if (CODE("width")) {
-            if (scan_dimen(data, &(frame.border)) != 1) {
-                frame.border = -1;
-        else if (CODE("hcolor")) {
-        else if (CODE("hwidth")) {
-        else if (CODE("background")) {
-            if (!scan_color(data, &(frame.fcolor))) {
-                unset_color(&(frame.fcolor));
-        else if (CODE("border")) {
-            if (!scan_color(data, &(frame.color))) {
-                unset_color(&(frame.color));
-        else if (CODE("opaque")) {
+	    G_plot_where_xy(frame.x, frame.y, &x, &y);
+	    frame.x = ((double)x) / 10.;
+	    frame.y = ((double)y) / 10.;
+	    if (strcmp(font.name, "Standard") != 0)
+		set_ps_font(&font);
+	    fprintf(PS.fp, "GS\n");
+	    fprintf(PS.fp, "/ARo [(%s)] def\n", data);
+            fprintf(PS.fp, "/ARw [ARo SWx] def ");
+            fprintf(PS.fp, "/ARh [FS0] def\n");
+	    set_box_auto(&frame, &font, 0.25);
+            fprintf(PS.fp, "(%s) READJUST ", data);
+	    set_box_draw(&frame);
+	    fprintf(PS.fp, "(%s) xo wd 2 div add yo hg 2 div sub M SHCC\n", data);
+	/* Option to modify the text */
+	else if (CODE("east"))
+	    frame.x = atof(data);
+	else if (CODE("north"))
+	    frame.y = atof(data);
+	else if (CODE("xoffset"))
+	    frame.xset = atof(data);
+	else if (CODE("yoffset"))
+	    frame.yset = atof(data);
+	else if (CODE("ref"))
+	    scan_ref(data, &(frame.xref), &(frame.yref));
+	else if (CODE("font"))
+	    get_font(data);
+	    strcpy(font.name, data);
+	else if (CODE("fontsize"))
+	    if (scan_dimen(data, &(font.size)) != 1)
+		font.size = 10.;
+	else if (CODE("size"))
+	    n = atof(data);
+	    font.size = (n * MT_TO_POINT) / PS.scale;
+	else if (CODE("color"))
+	    if (!scan_color(data, &(font.color)))
+		set_color_rgb(&(font.color), 0, 0, 0);
+	else if (CODE("space"))
+	else if (CODE("rotation"))
+	    frame.rotate = atof(data);
+	else if (CODE("width"))
+	    if (scan_dimen(data, &(frame.border)) != 1)
+		frame.border = -1;
+	else if (CODE("hcolor"))
+	else if (CODE("hwidth"))
+	else if (CODE("background"))
+	    if (!scan_color(data, &(frame.fcolor)))
+		unset_color(&(frame.fcolor));
+	else if (CODE("border"))
+	    if (!scan_color(data, &(frame.color)))
+		unset_color(&(frame.color));
+	else if (CODE("opaque"))
     fclose(in);
     return;
+int set_on_paper(char *pre, char *c_x, char *c_y, char *post)
+    char xunit, yunit;
+    int xret, yret, x, y;
+    double dx, dy;
+    xret = sscanf(c_x, "%lf%c", &dx, &xunit);
+    yret = sscanf(c_y, "%lf%c", &dy, &yunit);
+    /* east | north */
+    if (xret == 1 && yret == 1)
+	G_plot_where_xy(dx, dy, &x, &y);
+	dx = ((double)x) / 10.;
+	dy = ((double)y) / 10.;
+    /* x | y */
+    else if (xret == 2 && yret == 2)
+	xret = scan_dimen(c_x, &dx);
+	yret = scan_dimen(c_y, &dy);
+	/* percent */
+	if (xret == 2)
+	    dx *= (PS.page.width / 100.);
+	if (yret == 2)
+	    dy *= (PS.page.height / 100.);
+	if (xret < 0)
+	    dx = (PS.page.width + dx);
+	if (yret < 0)
+	    dy = (PS.page.height + dy);
+        /* margen inferior */
+        dy = PS.page.height - dy;
+    fprintf(PS.fp, "%s %.1f %.1f %s", pre, dx, dy, post);
+    return xret;
Modified: grass-addons/postscript/ps.output/set_geogrid.c
--- grass-addons/postscript/ps.output/set_geogrid.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_geogrid.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -38,13 +38,13 @@
     struct pj_info ll_proj, proj;
     if (PS.geogrid.sep <= 0 || PS.geogrid.line.color.none)
-        return 0;
+	return 0;
     /* set color and set line width */
     set_ps_line(line);
-    sep = (double)grid_sep/3600.;   /* to degrees */
+    sep = (double)grid_sep / 3600.;	/* to degrees */
     /* preparing projections */
     init_proj(&ll_proj, &proj);
@@ -55,34 +55,34 @@
     /* latitude lines */
     for (nmin = n_min; nmin >= south; nmin -= sep)
-        for (emin = e_min; emin >= west; emin -= sep)
-            e = emin;
-            n = nmin;
-            pj_do_proj(&e, &n, &ll_proj, &proj);    /* LL to PROJ */
-            set_ps_where('M', e, n);                /* PROJ to XY */
-            e = emin - sep;
-            n = nmin;
-            set_ps_where('L', e, n);
-            fprintf(PS.fp, "S\n");
+	for (emin = e_min; emin >= west; emin -= sep)
+	    e = emin;
+	    n = nmin;
+	    pj_do_proj(&e, &n, &ll_proj, &proj);	/* LL to PROJ */
+	    set_ps_where('M', e, n);	/* PROJ to XY */
+	    e = emin - sep;
+	    n = nmin;
+	    set_ps_where('L', e, n);
+	    fprintf(PS.fp, "S\n");
     /* longitude lines */
-        for (nmin = n_min; nmin >= south; nmin -= sep)
-            e = emin;
-            n = nmin;
-            e = emin;
-            n = nmin - sep;
+	for (nmin = n_min; nmin >= south; nmin -= sep)
+	    e = emin;
+	    n = nmin;
+	    e = emin;
+	    n = nmin - sep;
@@ -101,9 +101,9 @@
     if (PS.geogrid.sep <= 0)
-        return 1;
+	return 1;
-    grid_sep = (double)PS.geogrid.sep/3600.;   /* to degrees */
+    grid_sep = (double)PS.geogrid.sep / 3600.;	/* to degrees */
@@ -117,20 +117,20 @@
     nmin = floor(north / grid_sep) * grid_sep;
     for (; nmin > south; nmin -= grid_sep)
-        e = east;
-        n = nmin;
-        e = PS.map.east;
-        pj_do_proj(&e, &n, &proj, &ll_proj);
-        n = nmin;
-        if (n > PS.map.north || n < PS.map.south)
-            continue;
-        G_plot_where_xy(PS.map.east, n, &x, &y);
-        dx = ((double)x) / 10.;
-        dy = ((double)y) / 10.;
-        G_format_northing(nmin, label, PROJECTION_LL);
-        fprintf(PS.fp, "[(%s) %.1f %.1f]\n", label, dx, dy);
+	e = east;
+	n = nmin;
+	e = PS.map.east;
+	pj_do_proj(&e, &n, &proj, &ll_proj);
+	n = nmin;
+	if (n > PS.map.north || n < PS.map.south)
+	    continue;
+	G_plot_where_xy(PS.map.east, n, &x, &y);
+	format_northing(nmin, label, PROJECTION_LL);
+	fprintf(PS.fp, "[(%s) %.1f %.1f]\n", label, dx, dy);
     fprintf(PS.fp, "] def\n");
@@ -139,32 +139,32 @@
     emin = floor(east / grid_sep) * grid_sep;
     for (; emin > west; emin -= grid_sep)
-        n = south;
-        e = emin;
-        n = PS.map.south;
-        e = emin;
-        if (e > PS.map.east || e < PS.map.west)
-            continue;
-        G_plot_where_xy(e, PS.map.south, &x, &y);
-        G_format_easting(emin, label, PROJECTION_LL);
+	n = south;
+	e = emin;
+	n = PS.map.south;
+	e = emin;
+	if (e > PS.map.east || e < PS.map.west)
+	    continue;
+	G_plot_where_xy(e, PS.map.south, &x, &y);
+	format_easting(emin, label, PROJECTION_LL);
     /* select format */
     switch (PS.geogrid.format)
-        case 0:
-            set_geogrid_inner_numbers();
-            break;
-        case 1:
-            set_geogrid_outer_numbers();
-            break;
+    case 0:
+	set_geogrid_inner_numbers();
+	break;
+    case 1:
+	set_geogrid_outer_numbers();
+	break;
     return 1;
@@ -173,69 +173,50 @@
 /* geogrid with inner numbers */
 int set_geogrid_inner_numbers(void)
+    fprintf(PS.fp, "GS ");
     set_ps_font(&(PS.geogrid.font));
     fprintf(PS.fp, "/m %.3f def \n", 0.2 * PS.geogrid.font.size);
     /* vertical numbers */
-    fprintf(PS.fp,
-            "0 1 GRR length -- {GRR exch GET M dup ");
+    fprintf(PS.fp, "0 1 GRR length -- {GRR exch GET M dup ");
     set_ps_color(&(PS.geogrid.fcolor));
     if (PS.geogrid.fcolor.none)
-        fprintf(PS.fp,
-                "SW .5 add neg .5 MR ");
+	fprintf(PS.fp, "SW .5 add neg .5 MR ");
     else
-        fprintf(PS.fp,
-                "SWH m 2 mul add 1 index m 1 add add neg "
-                "exch dup -2 div 0 exch MR Rf ++ neg m MR ");
+	fprintf(PS.fp, "SWH m 2 mul add 1 index m 1 add add neg " "exch dup -2 div 0 exch MR Rf ++ neg m MR ");
     set_ps_color(&(PS.geogrid.font.color));
-    fprintf(PS.fp,
-            "show} for\n");
+    fprintf(PS.fp, "%s} for\n", (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     /* horizontal numbers */
-    fprintf(PS.fp,
-            "0 1 GRB length -- {GRB exch GET M dup ");
+    fprintf(PS.fp, "0 1 GRB length -- {GRB exch GET M dup ");
-        fprintf(PS.fp,
-                "pop -.5 .5 MR ");
+	fprintf(PS.fp, "pop -.5 .5 MR ");
     else
-        fprintf(PS.fp,
-                "SWH m 2 mul add exch m 1 add add 1 index -2 div 0 MR "
-                "1 index exch Rf m sub 1 MR ");
+	fprintf(PS.fp, "SWH m 2 mul add exch m 1 add add 1 index -2 div 0 MR " "1 index exch Rf m sub 1 MR ");
-    fprintf(PS.fp,
-            "GS 90 ROT show GR} for\n");
+    fprintf(PS.fp, "GS 90 ROT %s GR} for\n", (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     return 0;
 /* geogrid with outer numbers */
 int set_geogrid_outer_numbers(void)
-    fprintf(PS.fp, "/m %.3f def \n", 0.2 * PS.geogrid.font.size);
     fprintf(PS.fp,
-            "0 1 GRR length -- {GRR exch get aload pop M dup ");
-    set_ps_color(&(PS.geogrid.fcolor));
-    fprintf(PS.fp,
-            "SW 2 div %.2f exch MR ", PS.brd.width+1.);
-    set_ps_color(&(PS.geogrid.font.color));
-    fprintf(PS.fp,
-            "GS 270 ROT show GR} for\n");
+	    "0 1 GRR length -- {GRR exch GET M dup "
+	    "SW 2 div %.2f exch MR GS 270 ROT %s GR} for ", PS.brd.width + 1., (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     fprintf(PS.fp,
-            "0 1 GRB length -- {GRB exch get aload pop M dup ");
-    fprintf(PS.fp,
-            "SWH %.2f add neg exch -2 div exch MR ", PS.brd.width+1.);
-    fprintf(PS.fp,
-            "show} for\n");
+	    "0 1 GRB length -- {GRB exch GET M dup "
+	    "SWH %.2f add neg exch -2 div exch MR %s} for ", PS.brd.width + 1., (PS.geogrid.trim < 0 ? "COOR" : "SHL"));
     return 0;
Modified: grass-addons/postscript/ps.output/set_grid.c
--- grass-addons/postscript/ps.output/set_grid.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_grid.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -24,37 +24,45 @@
     fprintf(PS.fp, "/XY {get aload pop exch pop} D\n");
-    set_grid_lines('m', &(PS.grid.mline), PS.grid.msep);
+    if (PS.grid.msep > 0)
+	set_grid_lines('m', &(PS.grid.mline), PS.grid.msep);
     set_grid_lines('M', &(PS.grid.line), PS.grid.sep);
 int set_grid_lines(char code, PSLINE * line, int grid_sep)
     char label[50], h;
-    int i, x, y, zero;
-    double sep, north, west, dx, dy;
+    int i, x, y, zero, d, m;
+    double sep, north, west, dx, dy, s;
     if (grid_sep <= 0)
-        return 0;
+	return 0;
-    /* detect max trailer zeros if format zero and not LL */
+    /* detect trailer zeros if format zero and not LL */
     zero = 1;
     if (PS.map.proj == PROJECTION_LL)
-        sep = (double)grid_sep / 3600.;
+	/* break iho */
     else
-        sep = (double)grid_sep;
-        if (PS.grid.format < 3 && PS.grid.round > 0) {
-            while (PS.grid.sep % zero == 0) zero *= 10;
-            if (zero > 1)
-                zero /= 10;
-                for (i=0, x=1; i < PS.grid.round; i++)  x *= 10;
-                if (zero > x) zero = x;
+	sep = (double)grid_sep;
+	if (PS.grid.format < 2 && PS.grid.trim > 0)
+	    while (PS.grid.sep % zero == 0)
+		zero *= 10;
+	    if (zero > 1)
+		zero /= 10;
+		for (i = 0, x = 1; i < PS.grid.trim; i++)
+		    x *= 10;
+		if (zero > x)
+		    zero = x;
@@ -62,10 +70,17 @@
     north = floor(PS.map.north / sep) * sep;
     for (; north >= PS.map.south; north -= sep)
-        G_plot_where_xy(PS.map.east, north, &x, &y);
-        G_format_northing(north/zero, label, PS.map.proj);
-        fprintf(PS.fp, "[(%s) %.1f]\n", label, dy);
+	G_plot_where_xy(PS.map.east, north, &x, &y);
+	if (PS.grid.format == 2)
+	    format_iho(north, label);
+	else
+	    format_easting(north / zero, label, PS.map.proj);
+	fprintf(PS.fp, "[(%s) %.2f]\n", label, dy);
@@ -74,41 +89,48 @@
     west = ceil(PS.map.west / sep) * sep;
     for (; west < PS.map.east; west += sep)
-        G_plot_where_xy(west, PS.map.south, &x, &y);
-        G_format_easting(west/zero, label, PS.map.proj);
-        fprintf(PS.fp, "[(%s) %.1f]\n", label, dx);
+	G_plot_where_xy(west, PS.map.south, &x, &y);
+	    format_iho(west, label);
+	else
+	    format_easting(west / zero, label, PS.map.proj);
+	fprintf(PS.fp, "[(%s) %.2f]\n", label, dx);
     if (line->color.none != 1)
-        set_ps_line(line);
-        if (PS.grid.cross <= 0.) /* draw lines */
-            fprintf(PS.fp,
-                "VGR%c 0 1 2 index length -- {1 index exch XY "
-                "%.1f exch dup %.1f exch M LS} for pop\n", code, PS.map_x, PS.map_right);
-            fprintf(PS.fp,
-                "HGR%c 0 1 2 index length -- {1 index exch XY "
-                "%.1f 1 index %.1f M LS} for pop\n", code, PS.map_y, PS.map_top);
-        else /* draw crosses */
-            G_plot_where_xy(PS.map.east, PS.map.north, &x, &y);
-            G_plot_where_xy(PS.map.east - PS.grid.cross, PS.map.north, &x, &y);
-            dy = ((double)x) / 10.;
+	set_ps_line(line);
+	if (PS.grid.cross <= 0.)
+	{			/* draw lines */
+	    fprintf(PS.fp,
+		    "VGR%c 0 1 2 index length -- {1 index exch XY "
+		    "%.2f exch dup %.2f exch M LS} for pop\n", code, PS.map_x, PS.map_right);
+	    fprintf(PS.fp,
+		    "HGR%c 0 1 2 index length -- {1 index exch XY "
+		    "%.2f 1 index %.2f M LS} for pop\n", code, PS.map_y, PS.map_top);
+	else
+	{			/* draw crosses */
-            fprintf(PS.fp,
-                    "2 index M 0 90 270 {GS ROT 0 %.1f LRS GR} for} "
-                    "for pop pop} for pop\n", code, code, dx-dy);
+	    G_plot_where_xy(PS.map.east, PS.map.north, &x, &y);
+	    G_plot_where_xy(PS.map.east - PS.grid.cross, PS.map.north, &x, &y);
+	    dy = ((double)x) / 10.;
+	    fprintf(PS.fp,
+		    "2 index M 0 90 270 {GS ROT 0 %.2f LRS GR} for} " "for pop pop} for pop\n", code, code, dx - dy);
-    /* draw crosses como rotate una longitud desde el punto central*/
+    /* draw crosses como rotate una longitud desde el punto central */
     return 0;
@@ -118,26 +140,61 @@
 int set_numbers_grid(void)
-    /* make fine border */
     set_ps_color(&(PS.grid.fcolor));
-    set_ps_brd(.2*MM_TO_POINT, 0.);
     /* make numbers */
     switch (PS.grid.format)
-        case 0:
-            set_grid_inner_numbers();
-            break;
-        case 1:
-            set_grid_minor_border(0., PS.brd.width, PS.brd.width);
-            set_grid_outer_numbers();
-            break;
-        case 2:
-            set_grid_fine_border (0.2*MM_TO_POINT, 0.8*MM_TO_POINT);
-            set_grid_minor_border(1.0*MM_TO_POINT, 1.2*MM_TO_POINT, 0.2*MM_TO_POINT);
-            set_grid_major_border(2.2*MM_TO_POINT, 9.5*MM_TO_POINT);
-            set_grid_iho_numbers();
-            break;
+    case 0:
+	set_ps_brd2(.2 * MM_TO_POINT, 0.);
+	set_grid_inner_numbers();
+	break;
+    case 1:
+	    if (PS.grid.msubdiv >= 0)
+		double mrga = 0.4 * PS.brd.width - .2 * MM_TO_POINT;
+		double mrgb = 0.6 * PS.brd.width - .2 * MM_TO_POINT;
+		set_grid_minordiv_border(PS.grid.msubdiv, .2 * MM_TO_POINT, mrga);
+		set_grid_minor_border(.2 * MM_TO_POINT + mrga, mrgb, mrgb);
+	    else
+		set_grid_minor_border(.2 * MM_TO_POINT, PS.brd.width - .2 * MM_TO_POINT, PS.brd.width);
+	set_grid_outer_numbers(2);
+	break;
+    case 2:
+	    fprintf(PS.fp, "0.2 mm LW ");
+	    set_grid_minordiv_border(PS.grid.msubdiv, 0.2 * MM_TO_POINT, 0.4 * MM_TO_POINT);
+	    set_grid_minor_border(0.8 * MM_TO_POINT, 1.0 * MM_TO_POINT, 0.2 * MM_TO_POINT);
+	    fprintf(PS.fp, "0.8 mm LW ");
+	    set_grid_major_border(2.0 * MM_TO_POINT, 9.9 * MM_TO_POINT);
+	    set_grid_iho_numbers(2.0 * MM_TO_POINT, 9.9 * MM_TO_POINT);
+	else
+	    set_grid_major_border(0.2 * MM_TO_POINT, 11.7 * MM_TO_POINT);
+	    set_grid_iho_numbers(0.2 * MM_TO_POINT, 11.7 * MM_TO_POINT);
+	break;
+    case 3:
+	fprintf(PS.fp, "0.005 inch LW ");
+	set_grid_minordiv_border(PS.grid.msubdiv, 0.005 * INCH_TO_POINT, 0.035 * INCH_TO_POINT);
+	    set_grid_minor_border(0.045 * INCH_TO_POINT, 0.025 * INCH_TO_POINT, 0.025 * INCH_TO_POINT);
+	set_ps_brd(15.605 * MM_TO_POINT);
+	set_ps_brd2(0.025 * INCH_TO_POINT, 17.3322 * MM_TO_POINT);
+	set_grid_can_numbers(0.075 * INCH_TO_POINT, 13.7 * MM_TO_POINT);
+	break;
     return 1;
@@ -152,32 +209,32 @@
     set_ps_font(&(PS.grid.font));
-    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.1f exch M ", PS.map_x);
-    if (PS.grid.fcolor.none) {
-        fprintf(PS.fp, ".5 .5 MR ");
+    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_x);
+    if (PS.grid.fcolor.none)
+	fprintf(PS.fp, ".2 mm .2 mm MR ");
-    else  {
-        fprintf(PS.fp,
-                "dup SWH m 2 mul add exch m 1 add add exch "
-                "dup 2 div neg 0 exch MR GS ");
-        set_ps_color(&(PS.grid.fcolor));
-        fprintf(PS.fp, "Rf GR 1 m MR ");
+    else
+	fprintf(PS.fp, "dup SWH m 2 mul add exch m 1 add add exch " "dup 2 div neg 0 exch MR GS ");
+	set_ps_color(&(PS.grid.fcolor));
+	fprintf(PS.fp, "Rf GR 1 m MR ");
-    fprintf(PS.fp, "show} for\n");
+    fprintf(PS.fp, "%s} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
-    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.1f M ", PS.map_top);
-        fprintf(PS.fp, "dup SW .5 add neg -.5 exch MR ");
+    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_top);
+	fprintf(PS.fp, "dup SW .5 add neg -.5 exch MR ");
-    else  {
-        fprintf(PS.fp,
-                "dup SWH m 2 mul add exch m 1 add add "
-                "1 index 2 div 1 index neg MR exch neg exch GS ");
-        fprintf(PS.fp, "Rf GR m neg m MR ");
+    else
+	fprintf(PS.fp, "dup SWH m 2 mul add exch m 1 add add " "1 index 2 div 1 index neg MR exch neg exch GS ");
+	fprintf(PS.fp, "Rf GR m neg m MR ");
-    fprintf(PS.fp, "GS 90 ROT show GR} for\n");
+    fprintf(PS.fp, "GS 90 ROT %s GR} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
     return 0;
@@ -185,177 +242,226 @@
 /* FORMAT 1: outer numbers */
-int set_grid_outer_numbers(void)
+int set_grid_outer_numbers(int M)
-    fprintf(PS.fp, "dup SW -2 div -%.2f exch MR ", PS.brd.width+1.);
+    fprintf(PS.fp, "dup SW -2 div -%.2f exch MR ", PS.brd.width + M);
-    fprintf(PS.fp, "dup SW -2 div %.2f MR ", PS.brd.width+1.);
+    fprintf(PS.fp, "dup SW -2 div %.2f MR ", PS.brd.width + M);
+    if (PS.grid.lsides == 4)
+	/* right vertical numbers */
+	fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_right);
+	fprintf(PS.fp, "dup SW 2 div %.2f exch MR ", PS.brd.width + M);
+	fprintf(PS.fp, "GS 270 ROT %s GR} for\n", (PS.grid.trim < 0 ? "COOR" : "SHL"));
+	/* bottom horizontal numbers */
+	fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_y);
+	fprintf(PS.fp, "dup SWH %.2f add neg exch -2 div exch MR ", PS.brd.width + M);
     return 0;
 /* FORMAT 2: I.H.O. numbers */
-int set_grid_iho_numbers(void)
+int set_grid_iho_numbers(double A, double B)
-//     fprintf(PS.fp, "GS\n");
-//     fprintf(PS.fp, "/m %.3f def \n", 0.2 * PS.grid.font.size);
-//     set_ps_font(&(PS.grid.font));
-//     /* vertical numbers */
-//     fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch get aload pop %.1f exch M ", PS.map_x);
-//     fprintf(PS.fp, "dup SW -2 div -%.2f exch MR ", PS.brd.width+1.);
-//     fprintf(PS.fp, "GS 90 ROT show GR} for\n");
-//     /* horizontal numbers */
-//     fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch get aload pop %.1f M ", PS.map_top);
-//     fprintf(PS.fp, "dup SW -2 div %.2f MR ", PS.brd.width+1.);
-//     fprintf(PS.fp, "show} for\n");
-//     fprintf(PS.fp, "GR\n");
+    set_ps_font(&(PS.grid.font));
+    /* vertical numbers */
+    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_x - A - B / 2.);
+    fprintf(PS.fp, " (|) search pop exch pop ");
+    fprintf(PS.fp, "GS 0 1.25 MR SHC GR GS FR dup SWH exch pop 1.25 add neg 0 exch MR SHC GR} for\n");
+    fprintf(PS.fp, "0 1 VGRM length -- {VGRM exch GET %.2f exch M ", PS.map_right + A + B / 2.);
+    /* horizontal numbers */
+    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_top + A + B / 2.);
+    fprintf(PS.fp, "GS -1.25 0 MR SHRC GR GS FR 1.25 0 MR SHLC GR} for\n");
+    fprintf(PS.fp, "0 1 HGRM length -- {HGRM exch GET %.2f M ", PS.map_y - A - B / 2.);
     return 0;
+/* FORMAT 3: Canadian numbers */
+int set_grid_can_numbers(double A, double B)
+    fprintf(PS.fp, "dup SWH 2 div neg exch 2 div neg exch MR COOR} for\n");
+    return 0;
  * BORDER TYPES OF THE GRATICULE
-int set_grid_fine_border(double margin, double width)
+void set_grid_minordiv_border(int div, double margin, double width)
-    int div;
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_top + margin, PS.map_w, width);
-    div = (PS.map.proj == PROJECTION_LL) ? 6 : 10;
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x, PS.map_y - margin, PS.map_w, -width);
-    set_ps_brd(.2*MM_TO_POINT, margin+width);
-    set_grid_corners(margin, width);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_x - margin - width, PS.map_y, width, PS.map_h);
-    fprintf(PS.fp,
-            "1 1 VGRm length -- {dup VGRm exch XY exch -- VGRm exch XY "
-            "1 index sub %d div exch "
-            "%d {dup %.1f exch M %.2f 0 LR dup %.1f exch M %.2f 0 LR S "
-            "1 index add} repeat pop pop} for ",
-            div, div, PS.map_x-margin, -width, PS.map_right+margin, width);
+    fprintf(PS.fp, "%.2f %.2f %.2f %.2f RO\n", PS.map_right + margin, PS.map_y, width, PS.map_h);
-    fprintf(PS.fp,
-            "1 1 HGRm length -- {dup HGRm exch XY exch -- HGRm exch XY "
-            "%d {dup %.1f M 0 %.2f LR dup %.1f M 0 %.2f LR S "
-            div, div, PS.map_y-margin, -width, PS.map_top+margin, width);
+    if (div > 0)
+	fprintf(PS.fp,
+		"1 1 VGRm length -- {dup VGRm exch XY exch -- VGRm exch XY "
+		"1 index sub %d div exch %d ++ {"
+		"dup %.2f exch M %.2f 0 LR dup %.2f exch M %.2f 0 LR S "
+		"1 index add} repeat pop pop} for ", div, div, PS.map_x - margin, -width, PS.map_right + margin, width);
-    fprintf(PS.fp,
-            "VGRm 0 XY VGRm 1 XY 1 index sub neg "
-            "%d div exch {dup %.1f gt {exit} "
-            "{dup %.1f exch M %.2f 0 LR dup %.1f exch M %.2f 0 LR S 1 index add} ifelse} loop ",
-            div, PS.map_top, PS.map_x-margin, -width, PS.map_right+margin, width);
+	fprintf(PS.fp,
+		"1 1 HGRm length -- {dup HGRm exch XY exch -- HGRm exch XY "
+		"dup %.2f M 0 %.2f LR dup %.2f M 0 %.2f LR S "
+		"1 index add} repeat pop pop} for ", div, div, PS.map_y - margin, -width, PS.map_top + margin, width);
+    if (div > 1)
+	fprintf(PS.fp,
+		"VGRm 0 XY VGRm 1 XY 1 index sub neg %d div exch {"
+		"1 index add dup %.2f gt {exit} {"
+		"} ifelse} loop ", div, PS.map_top, PS.map_x - margin, -width, PS.map_right + margin, width);
-    fprintf(PS.fp,
-            "/i VGRm length -- def "
-            "VGRm i XY VGRm i -- XY "
-            "1 index sub neg %d div exch {dup %.1f lt {exit} "
-            div, PS.map_y, PS.map_x-margin, -width, PS.map_right+margin, width);
+	fprintf(PS.fp,
+		"/i VGRm length -- def VGRm i XY VGRm i -- XY 1 index sub neg %d div exch {"
+		"1 index add dup %.2f lt {exit} {"
+		"} ifelse} loop ", div, PS.map_y, PS.map_x - margin, -width, PS.map_right + margin, width);
-    fprintf(PS.fp,
-            "HGRm 0 XY HGRm 1 XY 1 index sub neg "
-            "%d div exch {dup %.1f lt {exit} "
-            "{dup %.1f M 0 %.2f LR dup %.1f M 0 %.2f LR S 1 index add} ifelse} loop ",
-            div, PS.map_x, PS.map_y-margin, -width, PS.map_top+margin, width);
-    fprintf(PS.fp,
-            "/i HGRm length -- def "
-            "HGRm i XY HGRm i -- XY "
-            "1 index sub neg %d div exch {dup %.1f gt {exit} "
-            "{dup %.1f M 0 %.2f LR dup %.1f M 0 %.2f LR S} ifelse 1 index add} loop\n",
-            div, PS.map_right, PS.map_y-margin, -width, PS.map_top+margin, width);
+	fprintf(PS.fp,
+		"HGRm 0 XY HGRm 1 XY 1 index sub neg %d div exch {"
+		"} ifelse} loop ", div, PS.map_x, PS.map_y - margin, -width, PS.map_top + margin, width);
+	fprintf(PS.fp,
+		"/i HGRm length -- def HGRm i XY HGRm i -- XY 1 index sub neg %d div exch {"
+		"} ifelse} loop\n", div, PS.map_right, PS.map_y - margin, -width, PS.map_top + margin, width);
-int set_grid_minor_border(double margin, double width, double midline)
+void set_grid_minor_border(double margin, double width, double midline)
     double dist;
-    dist = margin + width/2. + .1*MM_TO_POINT;
+    set_ps_brd(margin + width);
+    set_grid_corners(0, margin + width);
+    dist = margin + width / 2.;
-    fprintf(PS.fp, ".2 mm LW ");
     fprintf(PS.fp,
-            "0 1 VGRm length -- {VGRm exch XY dup "
-            "%.1f exch M %.2f 0 LR %.1f exch M %.2f 0 LRS} for\n",
-            PS.map_x-margin, -width, PS.map_right+margin, width);
+	    "0 1 VGRm length -- {VGRm exch XY dup "
+	    "%.2f exch M %.2f 0 LR %.2f exch M %.2f 0 LRS} for\n",
+	    PS.map_x - margin, -width, PS.map_right + margin, width);
     fprintf(PS.fp,
-            "0 1 HGRm length -- {HGRm exch XY dup "
-            "%.1f M %.2f 0 exch LR %.1f M %.2f 0 exch LRS} for\n",
-            PS.map_y-margin, -width, PS.map_top+margin, width);
+	    "0 1 HGRm length -- {HGRm exch XY dup "
+	    "%.2f M %.2f 0 exch LR %.2f M %.2f 0 exch LRS} for\n",
+	    PS.map_y - margin, -width, PS.map_top + margin, width);
+    if (midline > 0)
+	fprintf(PS.fp, "GS %.2f LW ", midline);
-    fprintf(PS.fp, "%.1f LW ", midline);
+	fprintf(PS.fp,
+		"1 2 VGRm length -- {/i XD VGRm i XY VGRm i -- XY 2 copy "
+		"%.2f exch M cP pop exch LS %.2f exch M cP pop exch LS} for\n", PS.map_x - dist, PS.map_right + dist);
-    fprintf(PS.fp,
-            "1 2 VGRm length -- {/i XD VGRm i XY VGRm i -- XY 2 copy "
-            "%.1f exch M cP pop exch LS %.1f exch M cP pop exch LS} for\n",
-            PS.map_x-dist, PS.map_right+dist);
+	fprintf(PS.fp,
+		"1 2 HGRm length -- {/i XD HGRm i XY HGRm i -- XY 2 copy "
+		"%.2f M cP exch pop LS %.2f M cP exch pop LS} for\n", PS.map_y - dist, PS.map_top + dist);
-    fprintf(PS.fp,
-            "1 2 HGRm length -- {/i XD HGRm i XY HGRm i -- XY 2 copy "
-            "%.1f M cP exch pop LS %.1f M cP exch pop LS} for\n",
-            PS.map_y-dist, PS.map_top+dist);
+	fprintf(PS.fp,
+		"VGRm length 2 mod 0 ne {VGRm dup length -- XY %.2f 2 copy "
+		"%.2f exch M cP pop exch LS %.2f exch M cP pop exch LS} if\n",
+		PS.map_y, PS.map_x - dist, PS.map_right + dist);
-    fprintf(PS.fp,
-            "VGRm length 2 mod 0 ne {VGRm dup length -- XY %.1f 2 copy "
-                    "%.1f exch M cP pop exch LS %.1f exch M cP pop exch LS} if\n",
-                    PS.map_y, PS.map_x-dist, PS.map_right+dist);
+	fprintf(PS.fp,
+		"HGRm length 2 mod 0 ne {HGRm dup length -- XY %.2f 2 copy "
+		"%.2f M cP exch pop LS %.2f M cP exch pop LS} if\n", PS.map_right, PS.map_y - dist, PS.map_top + dist);
-    fprintf(PS.fp,
-            "HGRm length 2 mod 0 ne {HGRm dup length -- XY %.1f 2 copy "
-            "%.1f M cP exch pop LS %.1f M cP exch pop LS} if\n",
-            PS.map_right, PS.map_y-dist, PS.map_top+dist);
-int set_grid_major_border(double margin, double width)
+void set_grid_major_border(double margin, double width)
-    set_ps_brd(.8*MM_TO_POINT, margin+width);
     fprintf(PS.fp,
-            "0 1 VGRM length -- {VGRM exch XY dup "
-            "%.1f exch M %.2f 0 LR %.1f exch M %.2f 0 LR S} for\n",
+	    "0 1 VGRM length -- {VGRM exch XY dup "
+	    "%.2f exch M %.2f 0 LR %.2f exch M %.2f 0 LR S} for\n",
     fprintf(PS.fp,
-            "0 1 HGRM length -- {HGRM exch XY dup "
-            "%.1f M %.2f 0 exch LR %.1f M %.2f 0 exch LR S} for\n",
+	    "0 1 HGRM length -- {HGRM exch XY dup "
+	    "%.2f M %.2f 0 exch LR %.2f M %.2f 0 exch LR S} for\n",
-int set_grid_corners(double margin, double width)
+void set_grid_corners(double margin, double width)
-    fprintf(PS.fp, "%.1f %.1f M %.2f 0 LRS ", PS.map_x-margin, PS.map_y, -width);
-    fprintf(PS.fp, "%.1f %.1f M 0 %.2f LRS ", PS.map_x, PS.map_y-margin, -width);
+    fprintf(PS.fp, "%.2f cLW 2 div sub %.2f cLW 2 div sub M "
+	    "%.2f dup 0 LR neg 0 exch LRS ", PS.map_x - margin - width, PS.map_y - margin, width);
-    fprintf(PS.fp, "%.1f %.1f M %.2f 0 LRS ", PS.map_x-margin, PS.map_top, -width);
-    fprintf(PS.fp, "%.1f %.1f M 0 %.2f LRS ", PS.map_x, PS.map_top+margin, width);
+    fprintf(PS.fp, "%.2f cLW 2 div sub %.2f cLW 2 div add M "
+	    "%.2f dup 0 LR 0 exch LRS ", PS.map_x - margin - width, PS.map_top + margin, width);
-    fprintf(PS.fp, "%.1f %.1f M %.2f 0 LRS ", PS.map_right+margin, PS.map_y, width);
-    fprintf(PS.fp, "%.1f %.1f M 0 %.2f LRS ", PS.map_right, PS.map_y-margin, -width);
+    fprintf(PS.fp, "%.2f cLW 2 div add %.2f cLW 2 div sub M "
+	    "%.2f neg dup 0 LR 0 exch LRS ", PS.map_right + margin + width, PS.map_y - margin, width);
-    fprintf(PS.fp, "%.1f %.1f M %.2f 0 LRS ", PS.map_right+margin, PS.map_top, width);
-    fprintf(PS.fp, "%.1f %.1f M 0 %.2f LRS ", PS.map_right, PS.map_top+margin, width);
+    fprintf(PS.fp, "%.2f cLW 2 div add %.2f cLW 2 div add M "
+	    "%.2f dup neg 0 LR 0 exch LRS ", PS.map_right + margin + width, PS.map_top + margin, width);
Modified: grass-addons/postscript/ps.output/set_mask.c
--- grass-addons/postscript/ps.output/set_mask.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_mask.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -24,49 +24,49 @@
     static int bit[] = { 128, 64, 32, 16, 8, 4, 2, 1 };
-    if (PS.rst.fd[1] < 0) /* there is no mask */
-        G_warning(_("Any raster mask to read, don't mask!"));
-        if (PS.need_mask)
-            PS.need_mask = 0;
-        return 0;
+    if (PS.rst.fd[1] < 0)
+    {				/* there is no mask */
+	G_warning(_("Any raster mask to read, don't mask!"));
+	if (PS.need_mask)
+	    PS.need_mask = 0;
+	return 0;
     fprintf(PS.fp, "currentfile /ASCIIHexDecode filter /ReusableStreamDecode filter\n");
     /* storing the bytes of the mask */
     map_type = G_get_raster_map_type(PS.rst.fd[1]);
-    cbuf     = G_allocate_raster_buf(map_type);
+    cbuf = G_allocate_raster_buf(map_type);
     for (br = 0, row = 0; row < PS.map.rows; row++)
-        G_get_raster_row(PS.rst.fd[1], cbuf, row, map_type);
-        cptr = cbuf;
-        i = byte = 0;
-        for (col = 0; col < PS.map.cols; col++)
-            if (G_is_null_value(cptr, map_type))
-                byte |= bit[i];
-            ++i;
-            if (i == 8)
-                fprintf(PS.fp, "%02x", byte);
-                i = byte = 0;
-            if (br++ == 45)
-                br = 0;
-            cptr = G_incr_void_ptr(cptr, G_raster_size(map_type));
-        if (i)
-            while (i < 8)
-                byte |= bit[i++];
+	G_get_raster_row(PS.rst.fd[1], cbuf, row, map_type);
+	cptr = cbuf;
+	i = byte = 0;
+	for (col = 0; col < PS.map.cols; col++)
+	    if (G_is_null_value(cptr, map_type))
+		byte |= bit[i];
+	    ++i;
+	    if (i == 8)
+		fprintf(PS.fp, "%02x", byte);
+		i = byte = 0;
+	    if (br++ == 45)
+		br = 0;
+	    cptr = G_incr_void_ptr(cptr, G_raster_size(map_type));
+	if (i)
+	    while (i < 8)
+		byte |= bit[i++];
     fprintf(PS.fp, "\n> /maskstream exch def\n");
Modified: grass-addons/postscript/ps.output/set_note.c
--- grass-addons/postscript/ps.output/set_note.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_note.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -20,87 +20,115 @@
 int set_note(int i)
-	int rows, type;
+    int rows, type;
     double x, y, dy, fontsize;
-	char *chr, *str, txt[1024];
+    char *chr, *str, txt[1024];
-    rows = 0;
+    rows = 0;			/* useful to decide if write it */
     fontsize = set_ps_font(&(PS.note[i].font));
-    if (strncmp(PS.note[i].text, ":file", 5) == 0) {
-        str = PS.note[i].text + 6;
-        rows = note_in_file(str);
-        type = -1;
+    if (strncmp(PS.note[i].text, ":file", 5) == 0)
+	str = PS.note[i].text + 6;
+	rows = note_in_file(str);
+	type = -1;
     else if (strncmp(PS.note[i].text, ":maplim", 7) == 0)
-        char label[50];
-        /* get north, south, east and west strings */
-        fprintf(PS.fp, "/ARo [\n");
-        fprintf(PS.fp, "(North: %s)\n", label);
-        fprintf(PS.fp, "(West: %s)\n", label);
-        fprintf(PS.fp, "(East: %s)\n", label);
-        fprintf(PS.fp, "(South: %s)\n", label);
-        fprintf(PS.fp, "] def\n");
-        rows = 4;
-        type = 0;
+	char label[50];
+	/* get north, south, east and west strings */
+	fprintf(PS.fp, "/ARo [\n");
+	G_format_northing(PS.map.north, label, PS.map.proj);
+	fprintf(PS.fp, "(North: %s)\n", label);
+	G_format_easting(PS.map.west, label, PS.map.proj);
+	fprintf(PS.fp, "(West: %s)\n", label);
+	G_format_easting(PS.map.east, label, PS.map.proj);
+	fprintf(PS.fp, "(East: %s)\n", label);
+	G_format_northing(PS.map.south, label, PS.map.proj);
+	fprintf(PS.fp, "(South: %s)\n", label);
+	fprintf(PS.fp, "] def\n");
+	rows = 4;
+	type = 0;
     else if (strncmp(PS.note[i].text, ":dimen", 6) == 0)
-            fprintf(PS.fp, "(Map Area)");
-            fprintf(PS.fp, "(Position: %.1f mm x %.1f mm)\n",
-                    POINT_TO_MM * PS.map_x,
-                    POINT_TO_MM * PS.map_y);
-            fprintf(PS.fp, "(Dimension: %.1f mm x %.1f mm)\n",
-                    POINT_TO_MM * PS.map_w,
-                    POINT_TO_MM * PS.map_h);
-            rows = 3;
-            type = 1;
+	fprintf(PS.fp, "(Map Area)");
+	fprintf(PS.fp, "(Position: %.1f mm x %.1f mm)\n", POINT_TO_MM * PS.map_x, POINT_TO_MM * PS.map_y);
+	fprintf(PS.fp, "(Dimension: %.1f mm x %.1f mm)\n", POINT_TO_MM * PS.map_w, POINT_TO_MM * PS.map_h);
+	rows = 3;
+	type = 1;
     else if (strncmp(PS.note[i].text, ":scale", 6) == 0)
-        str = PS.note[i].text + 7;
-        fprintf(PS.fp, "/ARo [(%s 1 : %d)] def\n", str, PS.scale);
-        rows = 1;
-        type = 2;
+	str = PS.note[i].text + 7;
+	fprintf(PS.fp, "/ARo [(%s 1 : %d)] def\n", str, PS.scale);
+	rows = 1;
+	type = 2;
-    else { /* free line of text with "|" to cut lines */
-        chr = str = PS.note[i].text;
-        while (*chr) {
-            while (*str && *str != '|' ) str++;
-            *str++ = '\0';
-            fprintf(PS.fp, "(%s)\n", chr);
-            chr = str;
-            ++rows;
-        type = 4;
+    else
+    {				/* free line of text with "|" to cut lines */
+	chr = str = PS.note[i].text;
+	while (*chr)
+	    while (*str && *str != '|')
+		str++;
+	    *str++ = '\0';
+	    fprintf(PS.fp, "(%s)\n", chr);
+	    chr = str;
+	    ++rows;
+	type = 4;
-    if (rows > 0 ) {
-        fprintf(PS.fp, "/ARw 1 array def ARw 0 ARo SWx put\n"); /* cols */
-        fprintf(PS.fp, "/ARh ARo length array def "); /* rows */
-        fprintf(PS.fp, "0 1 ARo length 1 sub {ARh exch %.2f put} for\n", fontsize);
-        set_box_orig(&(PS.note[i].box));
-        set_box_auto(&(PS.note[i].box), &(PS.note[i].font), 0.25);
-        set_box_draw(&(PS.note[i].box));
-        set_ps_color(&(PS.note[i].font.color));
-        fprintf(PS.fp, "/mgx mg def /mgy mg def RESET 0 COL\n");
-        fprintf(PS.fp, "0 1 ARo length 1 sub {dup ROW ARo exch get x y ARh row get sub M ");
-        if (type == 0)
-            fprintf(PS.fp, "GS dup SW ARw 0 get exch sub 0 32 4 -1 roll widthshow GR} for\n");
-        else if (type == 2)
-            fprintf(PS.fp, "GS dup SWH exch pop 0 MR %.2f ROT show GR} for\n", PS.note[i].angle);
-        else
+    if (rows > 0)
+	/* Define ARw */
+	if (PS.note[i].width > 0.)
+            x = PS.note[i].box.margin;
+            if (x < 0.)
+                x = 0.4 * PS.note[i].font.size;
+            fprintf(PS.fp, "/ARw [%.3f] def\n", PS.note[i].width - 2 * x);
+	else
+            fprintf(PS.fp, "/ARw [ARo SWx] def\n");
+            //fprintf(PS.fp, "/ARw 1 array def ARw 0 ARo SWx put\n");
+	/* Define ARh: todas de igual altura */
+	fprintf(PS.fp, "/ARh ARo length array def ");
+	fprintf(PS.fp, "0 1 ARo length -- {ARh exch %.2f put} for\n", fontsize);
+	/* Make de frame */
+	set_box_orig(&(PS.note[i].box));
+	set_box_auto(&(PS.note[i].box), &(PS.note[i].font), 0.25);
+	set_box_draw(&(PS.note[i].box));
+	set_ps_color(&(PS.note[i].font.color));
+	/* Draw the content */
+	fprintf(PS.fp, "RESET ");
+	fprintf(PS.fp, "0 1 ARo length 1 sub {dup ROW ARo exch get x y ARh row get sub M ");
+	switch (type)
+	case 0:
+	    fprintf(PS.fp, "GS dup SW ARw 0 get exch sub 0 32 4 -1 roll widthshow GR");
+	    break;
+	case 2:
+	    fprintf(PS.fp, "GS dup SWH exch pop 0 MR %.2f ROT show GR", PS.note[i].angle);
+	    break;
+	default:
+	    fprintf(PS.fp, "(.) anchorsearch {GS pop %.3f 2 div 0 MR SHC GR} {SHL} ifelse", PS.note[i].width);
+	    break;
+	fprintf(PS.fp, "} for\n");
     return 0;
@@ -108,27 +136,27 @@
 int note_in_file(char *name)
-	FILE *in = NULL;
-	char buf[1024];
-	int r = 0;
+    FILE *in = NULL;
+    char buf[1024];
+    int r = 0;
-    in = NULL;
-	if (*name) {
-		if (in == NULL) {
-			G_message(_("Comment file <%s> can't open"), name);
-			return 0;
+    if (*name)
+	if (in == NULL)
+	    G_message(_("Comment file <%s> can't open"), name);
+	    return 0;
-    while (fgets(buf, sizeof(buf), in)) { /* TODO don't read end-of-line */
-		fprintf(PS.fp, "(%s)\n", buf);
-		++r;
+    while (fgets(buf, sizeof(buf), in))
+    {				/* TODO don't read end-of-line */
+	fprintf(PS.fp, "(%s)\n", buf);
+	++r;
+    fclose(in);
-	fclose(in);
-	return r;
+    return r;
Modified: grass-addons/postscript/ps.output/set_outline.c
--- grass-addons/postscript/ps.output/set_outline.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_outline.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -23,49 +23,50 @@
     RASTER_MAP_TYPE map_type;
     /* let user know what's happenning */
-    G_message(_("Reading raster map <%s in %s> ..."),
-              PS.rst.name[0], PS.rst.mapset[0]);
+    G_message(_("Reading raster map <%s in %s> ..."), PS.rst.name[0], PS.rst.mapset[0]);
     /* set the outline color and width */
     set_ps_line(&(PS.rst.outline));
-    fprintf(PS.fp, "GS 1 setlinejoin\n");  /* lines with linejoin = round */
+    fprintf(PS.fp, "GS 1 setlinejoin\n");	/* lines with linejoin = round */
     /* buffers of the image */
     map_type = G_get_raster_map_type(PS.rst.fd[0]);
-    rbuf     = G_allocate_raster_buf(map_type);
-    nbuf     = G_allocate_raster_buf(map_type);
-    for (row = 0; row < PS.map.rows-1; row++)
+    rbuf = G_allocate_raster_buf(map_type);
+    nbuf = G_allocate_raster_buf(map_type);
+    for (row = 0; row < PS.map.rows - 1; row++)
-        nrow = G_row_to_northing((double)row, &(PS.map));
-        n_rw = G_row_to_northing((double)row+1, &(PS.map));
-        /* load buffers */
-        G_get_raster_row(PS.rst.fd[0], rbuf, row, map_type);
-        G_get_raster_row(PS.rst.fd[0], nbuf, row+1, map_type);
-        /* set pointers */
-        rptr = rbuf;
-        nptr = nbuf;
-        for (col = 0; col < PS.map.cols-1; col++)
-            erow = G_col_to_easting((double)col+1, &(PS.map));
-            e_rw = G_col_to_easting((double)col, &(PS.map));
-            /* check right outline */
-            next = G_incr_void_ptr(rptr, G_raster_size(map_type));
-            if (G_raster_cmp(rptr, next, map_type) != 0) {
-                set_ps_where('M', erow, nrow);
-                set_ps_where('L', erow, n_rw);
-            /* check bottom outline */
-            if (G_raster_cmp(rptr, nptr, map_type) != 0) {
-                set_ps_where('M', e_rw, n_rw);
-            /* next column */
-            rptr = G_incr_void_ptr(rptr, G_raster_size(map_type));
-            nptr = G_incr_void_ptr(nptr, G_raster_size(map_type));
+	nrow = G_row_to_northing((double)row, &(PS.map));
+	n_rw = G_row_to_northing((double)row + 1, &(PS.map));
+	/* load buffers */
+	G_get_raster_row(PS.rst.fd[0], rbuf, row, map_type);
+	G_get_raster_row(PS.rst.fd[0], nbuf, row + 1, map_type);
+	/* set pointers */
+	rptr = rbuf;
+	nptr = nbuf;
+	for (col = 0; col < PS.map.cols - 1; col++)
+	    erow = G_col_to_easting((double)col + 1, &(PS.map));
+	    e_rw = G_col_to_easting((double)col, &(PS.map));
+	    /* check right outline */
+	    next = G_incr_void_ptr(rptr, G_raster_size(map_type));
+	    if (G_raster_cmp(rptr, next, map_type) != 0)
+		set_ps_where('M', erow, nrow);
+		set_ps_where('L', erow, n_rw);
+	    /* check bottom outline */
+	    if (G_raster_cmp(rptr, nptr, map_type) != 0)
+		set_ps_where('M', e_rw, n_rw);
+	    /* next column */
+	    rptr = G_incr_void_ptr(rptr, G_raster_size(map_type));
+	    nptr = G_incr_void_ptr(nptr, G_raster_size(map_type));
     G_free(rbuf);
     G_free(nbuf);
Modified: grass-addons/postscript/ps.output/set_ps.c
--- grass-addons/postscript/ps.output/set_ps.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_ps.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -17,16 +17,22 @@
 void set_ps_rect(double x, double y, double w, double h)
+    fprintf(PS.fp, "%.3f %.3f %.3f %.3f RO\n", x, y, w, h);
+    return;
+void set_ps_brd(double margin)
-            x, y, w, h);
+	    PS.map_x - margin, PS.map_y - margin, PS.map_w + 2. * margin, PS.map_h + 2. * margin);
+    return;
-void set_ps_brd(double width, double margin)
+void set_ps_brd2(double lwidth, double margin)
     fprintf(PS.fp, "%.3f LW %.3f %.3f %.3f %.3f RO\n",
-            width,
-            PS.map_x-margin, PS.map_y-margin,
-            PS.map_w+2.*margin, PS.map_h+2.*margin);
+	    lwidth, PS.map_x - margin, PS.map_y - margin, PS.map_w + 2. * margin, PS.map_h + 2. * margin);
+    return;
 /* GEOGRAPHIC */
@@ -72,9 +78,8 @@
-    if (dx < PS.map_x || dx > PS.map_right ||
-        dy < PS.map_y || dy > PS.map_top)
-        return 1;
+    if (dx < PS.map_x || dx > PS.map_right || dy < PS.map_y || dy > PS.map_top)
+	return 1;
     return 0;
@@ -82,34 +87,35 @@
 /* PATTERNS */
 /* store a pattern for posterior reference by number */
-int set_ps_pattern(int code, char *eps, VAREAS *va)
+int set_ps_pattern(int code, char *eps, VAREAS * va)
     FILE *fp;
     char buf[1024];
     int ret = 0;
     double llx, lly, urx, ury;
-    if ((fp = fopen(eps, "r")) == NULL) {
-        G_message("File <%s> not found!\n", eps);
-        return 0;
+    if ((fp = fopen(eps, "r")) == NULL)
+	G_message("File <%s> not found!\n", eps);
+	return 0;
     /* find the bounding box in EPS */
     llx = lly = urx = ury = 0.;
     while (fgets(buf, 128, fp) != NULL && ret != 4)
-        ret =  sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf",
-                      &llx, &lly, &urx, &ury);
+	ret = sscanf(buf, "%%%%BoundingBox: %lf %lf %lf %lf", &llx, &lly, &urx, &ury);
-    if (llx == 0. && lly == 0. && urx == 0. && ury == 0.) {
-        fclose(fp);
-        error("ERROR:", "", "Bounding box in <%s> was not found\n", eps);
+    if (llx == 0. && lly == 0. && urx == 0. && ury == 0.)
+	fclose(fp);
+	error("ERROR:", "", "Bounding box in <%s> was not found\n", eps);
-    llx *= va->scale;
-    lly *= va->scale;
-    urx *= va->scale;
-    ury *= va->scale;
+    llx *= va->sc_pat;
+    lly *= va->sc_pat;
+    urx *= va->sc_pat;
+    ury *= va->sc_pat;
     fprintf(PS.fp, "/PATTERN%d\n", code);
     fprintf(PS.fp, "<< /PatternType 1\n   /PaintType %d\n   /TilingType 1\n", va->type_pat);
@@ -117,13 +123,16 @@
     fprintf(PS.fp, "   /XStep %.4f\n   /YStep %.4f\n", (urx - llx), (ury - lly));
     fprintf(PS.fp, "   /PaintProc\n");
     fprintf(PS.fp, "   { begin\n");
-    fprintf(PS.fp, "     %.4f %.4f scale\n", va->scale, va->scale);
+    fprintf(PS.fp, "     %.4f dup scale\n", va->sc_pat);
     if (va->type_pat == 1)
-        fprintf(PS.fp, "     %.3f %.3f %.3f C\n",
-                va->fcolor.r, va->fcolor.g, va->fcolor.b);
-    fprintf(PS.fp, "     [] 0 LD %.4f LW\n", va->pwidth);
+	fprintf(PS.fp, "     ");
+	set_ps_color(&(va->fcolor));
+    fprintf(PS.fp, "     [] 0 LD %.4f LW\n", va->lw_pat);
     while (fgets(buf, 1024, fp) != NULL)
-        fprintf(PS.fp, "     %s", buf);
+	fprintf(PS.fp, "     %s", buf);
     fprintf(PS.fp, "     end }\n");
     fprintf(PS.fp, ">> matrix makepattern def\n");
@@ -132,33 +141,28 @@
 /* SYMBOLS */
-/* store a standard symbol >>>> use symbol_save in symbol.c */
-// int set_ps_symbol_std(int code, VPOINTS *vp, SYMBOL * sym)
 /* store a eps symbol */
-int set_ps_symbol_eps(int code, VPOINTS *vp, char *eps)
+int set_ps_symbol_eps(int code, char *eps)
     FILE *fp;
     char buf[1024];
-        return 0;
+	return 0;
     fprintf(PS.fp, "/SYMBOL%d {\n", code);
-        if (strncmp(buf, "%!PS-Adobe", 10) == 0 ||
-            strncmp(buf, "%%BoundingBox", 13) == 0)
-            continue;
+	if (strncmp(buf, "%!PS-Adobe", 10) == 0 || strncmp(buf, "%%BoundingBox", 13) == 0)
+	    continue;
     fprintf(PS.fp, "\n} def\n");
     fclose(fp);
     return 1;
Modified: grass-addons/postscript/ps.output/set_raster.c
--- grass-addons/postscript/ps.output/set_raster.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_raster.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -20,8 +20,8 @@
 /* the PS file can be reduced to half if don't use ASCIIHexDecode filter and writing
-directly with %c, not with %02X, but the PS file is less friendly and this is not important
-when after all the PS file is transformed to PDF */
+   directly with %c, not with %02X, but the PS file is less friendly and this is not important
+   when after all the PS file is transformed to PDF */
 int set_raster(void)
@@ -30,68 +30,68 @@
     /* starting */
     if (PS.need_mask && PS.rst.do_mask)
-        fprintf(PS.fp, "currentfile /ASCIIHexDecode filter /ReusableStreamDecode filter\n");
+	fprintf(PS.fp, "currentfile /ASCIIHexDecode filter /ReusableStreamDecode filter\n");
     else
-        /* Map Dictionary when no mask needed, no reusable stream */
-        fprintf(PS.fp, "/Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
-        fprintf(PS.fp, "%.2f %.2f translate\n", PS.map_x, PS.map_y);
-        fprintf(PS.fp, "%.1f %.1f scale\n", PS.map_w, PS.map_h);
-        fprintf(PS.fp, "<< /ImageType 1\n");
-        fprintf(PS.fp, "   /Width %d\n", PS.map.cols);
-        fprintf(PS.fp, "   /Height %d\n", PS.map.rows);
-        fprintf(PS.fp, "   /BitsPerComponent 8\n");
-        /* fprintf(PS.fp, "   /Interpolate true\n"); */
-        fprintf(PS.fp, "   /Decode [%s]\n", PS.rst.do_grey ? "0 1" : "0 1 0 1 0 1");
-        fprintf(PS.fp, "   /ImageMatrix [%d 0 0 %d 0 %d]\n", PS.map.cols, -PS.map.rows, PS.map.rows);
-        fprintf(PS.fp, "   /DataSource currentfile /ASCIIHexDecode filter\n");
-        fprintf(PS.fp, ">> ");
-        fprintf(PS.fp, "image\n");
+	/* Map Dictionary when no mask needed, no reusable stream */
+	fprintf(PS.fp, "/Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
+	fprintf(PS.fp, "%.2f %.2f translate\n", PS.map_x, PS.map_y);
+	fprintf(PS.fp, "%.1f %.1f scale\n", PS.map_w, PS.map_h);
+	fprintf(PS.fp, "<< /ImageType 1\n");
+	fprintf(PS.fp, "   /Width %d\n", PS.map.cols);
+	fprintf(PS.fp, "   /Height %d\n", PS.map.rows);
+	fprintf(PS.fp, "   /BitsPerComponent 8\n");
+	/* fprintf(PS.fp, "   /Interpolate true\n"); */
+	fprintf(PS.fp, "   /Decode [%s]\n", PS.rst.do_grey ? "0 1" : "0 1 0 1 0 1");
+	fprintf(PS.fp, "   /ImageMatrix [%d 0 0 %d 0 %d]\n", PS.map.cols, -PS.map.rows, PS.map.rows);
+	fprintf(PS.fp, "   /DataSource currentfile /ASCIIHexDecode filter\n");
+	fprintf(PS.fp, ">> ");
+	fprintf(PS.fp, "image\n");
     /* split loading stream for some better speed */
     if (PS.rst.do_rgb)
-        set_raster_rgb();
+	set_raster_rgb();
     else if (PS.rst.do_mask)
-        if (PS.rst.fd[2] < 0)
-            set_raster_maskcolor();
-        else
-            set_raster_maskcell();
+	if (PS.rst.fd[2] < 0)
+	    set_raster_maskcolor();
+	else
+	    set_raster_maskcell();
     else
-        set_raster_cell();
+	set_raster_cell();
     /* ending */
-        fprintf(PS.fp, "\n> ");
-        fprintf(PS.fp, "/mapstream exch def\n");
-        /* Map Dictionary when mask needed, reusable stream */
-        fprintf(PS.fp, "/MapDictionary \n");
-        fprintf(PS.fp, "   /DataSource mapstream\n");
-        fprintf(PS.fp, ">> store\n");
-        fprintf(PS.fp, "gsave\n");
-        fprintf(PS.fp, "  /Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
-        fprintf(PS.fp, "  %.2f %.2f translate\n", PS.map_x, PS.map_y);
-        fprintf(PS.fp, "  %.1f %.1f scale\n", PS.map_w, PS.map_h);
-        fprintf(PS.fp, "  mapstream resetfile\n");
-        fprintf(PS.fp, "  MapDictionary image\n");
+	fprintf(PS.fp, "\n> ");
+	fprintf(PS.fp, "/mapstream exch def\n");
+	/* Map Dictionary when mask needed, reusable stream */
+	fprintf(PS.fp, "/MapDictionary \n");
+	fprintf(PS.fp, "   /DataSource mapstream\n");
+	fprintf(PS.fp, ">> store\n");
+	fprintf(PS.fp, "gsave\n");
+	fprintf(PS.fp, "  /Device%s setcolorspace\n", PS.rst.do_grey ? "Gray" : "RGB");
+	fprintf(PS.fp, "  %.2f %.2f translate\n", PS.map_x, PS.map_y);
+	fprintf(PS.fp, "  %.1f %.1f scale\n", PS.map_w, PS.map_h);
+	fprintf(PS.fp, "  mapstream resetfile\n");
+	fprintf(PS.fp, "  MapDictionary image\n");
     else
-        fprintf(PS.fp, ">\n");
+	fprintf(PS.fp, ">\n");
@@ -107,33 +107,35 @@
     /* storing the bytes of the image */
-        G_get_raster_row(PS.rst.fd[0], cbuf, row, map_type);
-        cptr = cbuf;
-            /* get the map colors */
-            G_get_raster_color(cptr, &R, &G, &B, &(PS.rst.colors[0]), map_type);
-            /* processing data to the postscript file */
-            if (PS.rst.do_grey) {
-                fprintf(PS.fp, "%02X", (int)NTSC(R,G,B));
-            else {
-                fprintf(PS.fp, "%02X%02X%02X", R,G,B);
-            if (br++ == 15) {
-                br = 0;
+	G_get_raster_row(PS.rst.fd[0], cbuf, row, map_type);
+	cptr = cbuf;
+	    /* get the map colors */
+	    G_get_raster_color(cptr, &R, &G, &B, &(PS.rst.colors[0]), map_type);
+	    /* processing data to the postscript file */
+	    if (PS.rst.do_grey)
+		fprintf(PS.fp, "%02X", (int)NTSC(R, G, B));
+	    else
+		fprintf(PS.fp, "%02X%02X%02X", R, G, B);
+	    if (br++ == 15)
+		br = 0;
     G_free(cbuf);
@@ -153,45 +155,50 @@
     G_message(_("Reading raster maps in group <%s> ..."), PS.rst.title);
-    for (i = 0; i < 3; i++) {
-        map_type[i] = G_get_raster_map_type(PS.rst.fd[i]);
-        cbuf[i] = G_allocate_raster_buf(map_type[i]);
+    for (i = 0; i < 3; i++)
+	map_type[i] = G_get_raster_map_type(PS.rst.fd[i]);
+	cbuf[i] = G_allocate_raster_buf(map_type[i]);
-            G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]);
-            cptr[i] = cbuf[i];
-            G_get_raster_color(cptr[0], &(R[0]), &(G[0]), &(B[0]), &(PS.rst.colors[0]), map_type[0]);
-            G_get_raster_color(cptr[1], &(R[1]), &(G[1]), &(B[1]), &(PS.rst.colors[1]), map_type[1]);
-            G_get_raster_color(cptr[2], &(R[2]), &(G[2]), &(B[2]), &(PS.rst.colors[2]), map_type[2]);
-                fprintf(PS.fp, "%02X", (int)NTSC(R[0],G[1],B[2]));
-            else {
-                fprintf(PS.fp, "%02X%02X%02X", R[0], G[1], B[2]);
-            if (br++ == 15) {
-                br = 0;
-            /* pointer to next column */
-            cptr[0] = G_incr_void_ptr(cptr[0], G_raster_size(map_type[0]));
-            cptr[1] = G_incr_void_ptr(cptr[1], G_raster_size(map_type[1]));
-            cptr[2] = G_incr_void_ptr(cptr[2], G_raster_size(map_type[2]));
+	    G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]);
+	    cptr[i] = cbuf[i];
+	    G_get_raster_color(cptr[0], &(R[0]), &(G[0]), &(B[0]), &(PS.rst.colors[0]), map_type[0]);
+	    G_get_raster_color(cptr[1], &(R[1]), &(G[1]), &(B[1]), &(PS.rst.colors[1]), map_type[1]);
+	    G_get_raster_color(cptr[2], &(R[2]), &(G[2]), &(B[2]), &(PS.rst.colors[2]), map_type[2]);
+		fprintf(PS.fp, "%02X", (int)NTSC(R[0], G[1], B[2]));
+	    else
+		fprintf(PS.fp, "%02X%02X%02X", R[0], G[1], B[2]);
+	    if (br++ == 15)
+		br = 0;
+	    /* pointer to next column */
+	    cptr[0] = G_incr_void_ptr(cptr[0], G_raster_size(map_type[0]));
+	    cptr[1] = G_incr_void_ptr(cptr[1], G_raster_size(map_type[1]));
+	    cptr[2] = G_incr_void_ptr(cptr[2], G_raster_size(map_type[2]));
-        G_free(cbuf[i]);
-        G_close_cell(PS.rst.fd[i]);
-        G_free_colors(&(PS.rst.colors[i]));
-        PS.rst.fd[i] = -1;
+	G_free(cbuf[i]);
+	G_close_cell(PS.rst.fd[i]);
+	G_free_colors(&(PS.rst.colors[i]));
+	PS.rst.fd[i] = -1;
     return 3;
@@ -207,76 +214,85 @@
     void *cbuf[3], *cptr[3];
     RASTER_MAP_TYPE map_type[3];
-    red   = (1. - PS.rst.mask_color.r);
+    red = (1. - PS.rst.mask_color.r);
     green = (1. - PS.rst.mask_color.g);
-    blue  = (1. - PS.rst.mask_color.b);
-    R[1]  = (int)(255. * PS.rst.mask_color.r);
-    G[1]  = (int)(255. * PS.rst.mask_color.g);
-    B[1]  = (int)(255. * PS.rst.mask_color.b);
+    blue = (1. - PS.rst.mask_color.b);
+    R[1] = (int)(255. * PS.rst.mask_color.r);
+    G[1] = (int)(255. * PS.rst.mask_color.g);
+    B[1] = (int)(255. * PS.rst.mask_color.b);
     G_message(_("Reading raster map <%s in %s> ... %d rows"), PS.rst.name[0], PS.rst.mapset[0], PS.map.rows);
     G_message(_("... mask raster <%s in %s>"), PS.rst.name[1], PS.rst.mapset[1]);
     G_message(_("... background raster <%s in %s>"), PS.rst.name[2], PS.rst.mapset[2]);
-   /* storing the bytes of the image */
-   for (br = 0, row = 0; row < PS.map.rows; row++)
-           /* G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]); */
-           G_get_raster_row_nomask(PS.rst.fd[i], cbuf[i], row, map_type[i]);
-            /* select color by mask */
-            if (G_is_null_value(cptr[1], map_type[1])) {
-                if (PS.rst.mask_color.none) {
-                    r = R[2];
-                    g = G[2];
-                    b = B[2];
-                else {
-                    f = (double)GREY(R[2],G[2],B[2]);
-                    r = (int)(f*red   + (double)R[1]);
-                    g = (int)(f*green + (double)G[1]);
-                    b = (int)(f*blue  + (double)B[1]);
-            else {
-                r = R[0];
-                g = G[0];
-                b = B[0];
-                fprintf(PS.fp, "%02X", (int)NTSC(r,g,b));
-            else {
-                fprintf(PS.fp, "%02X%02X%02X", r, g, b);
-            if (br++ == 15) {
-                br = 0;
-   G_free(cbuf[0]);
-   G_free(cbuf[1]);
-   G_free(cbuf[2]);
+    /* storing the bytes of the image */
+    for (br = 0, row = 0; row < PS.map.rows; row++)
+	    /* G_get_raster_row(PS.rst.fd[i], cbuf[i], row, map_type[i]); */
+	    G_get_raster_row_nomask(PS.rst.fd[i], cbuf[i], row, map_type[i]);
+	    /* select color by mask */
+	    if (G_is_null_value(cptr[1], map_type[1]))
+		if (PS.rst.mask_color.none)
+		    r = R[2];
+		    g = G[2];
+		    b = B[2];
+		else
+		    f = (double)GREY(R[2], G[2], B[2]);
+		    r = (int)(f * red + (double)R[1]);
+		    g = (int)(f * green + (double)G[1]);
+		    b = (int)(f * blue + (double)B[1]);
+	    else
+		r = R[0];
+		g = G[0];
+		b = B[0];
+		fprintf(PS.fp, "%02X", (int)NTSC(r, g, b));
+	    else
+		fprintf(PS.fp, "%02X%02X%02X", r, g, b);
+	    if (br++ == 15)
+		br = 0;
+    G_free(cbuf[0]);
+    G_free(cbuf[1]);
+    G_free(cbuf[2]);
-   return 3;
+    return 3;
@@ -288,13 +304,15 @@
     void *cbuf[2], *cptr[2];
     RASTER_MAP_TYPE map_type[2];
-        r = g = b = 255.;
+	r = g = b = 255.;
-    else {
-        r = (int)(255. * PS.rst.mask_color.r);
-        g = (int)(255. * PS.rst.mask_color.g);
-        b = (int)(255. * PS.rst.mask_color.b);
+    else
+	r = (int)(255. * PS.rst.mask_color.r);
+	g = (int)(255. * PS.rst.mask_color.g);
+	b = (int)(255. * PS.rst.mask_color.b);
@@ -302,46 +320,50 @@
     G_message(_("... raster to mask <%s in %s>"), PS.rst.name[1], PS.rst.mapset[1]);
-    for (i = 0; i < 2; i++) {
+    for (i = 0; i < 2; i++)
-            G_get_raster_color(cptr[0], &R, &G, &B, &(PS.rst.colors[0]), map_type[0]);
-                R = r;
-                G = g;
-                B = b;
-            else {
-                fprintf(PS.fp, "%02X%02X%02X", R, G, B);
-            if (br++ == 15) {
-                br = 0;
+	    G_get_raster_color(cptr[0], &R, &G, &B, &(PS.rst.colors[0]), map_type[0]);
+		R = r;
+		G = g;
+		B = b;
+	    else
+	    if (br++ == 15)
+		br = 0;
     G_free(cbuf[0]);
     G_free(cbuf[1]);
     return 2;
Modified: grass-addons/postscript/ps.output/set_rlegend.c
--- grass-addons/postscript/ps.output/set_rlegend.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_rlegend.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -22,141 +22,160 @@
     int i, j, k, n, R, G, B;
     char *label;
     int num_cats, rows, cols;
-	double fontsize, fwidth;
+    double fontsize, fwidth;
     DCELL dmin, dmax, val;
     /* Let user know what's happenning */
-    G_message(_("Raster legend with category <%s in %s>..."),
-              PS.rl.name, PS.rl.mapset);
+    G_message(_("Raster legend with category <%s in %s>..."), PS.rl.name, PS.rl.mapset);
-    if (G_read_cats(PS.rl.name, PS.rl.mapset, &(PS.rst.cats)) == -1) {
-		G_warning(_("Category file for <%s> not available"), PS.rl.name);
-		return 1;
+    /* Load the categories */
+    if (G_read_raster_cats(PS.rl.name, PS.rl.mapset, &(PS.rst.cats)) != 0)
+	G_warning(_("Category file for <%s> not available"), PS.rl.name);
+	return 1;
+    /* Reload colors if raster in rlegend is not the same as raster command.
+       If the same, don't touch to not overwrite setcolor command */
+    if (strcmp(PS.rl.name, PS.rst.name[0]) != 0)
+	G_warning("Using color table of %s in %s", PS.rl.name, PS.rl.mapset);
+	if (G_read_colors(PS.rl.name, PS.rl.mapset, &PS.rst.colors[0]) == -1)
+	    G_warning("Can't load color table of %s in %s", PS.rl.name, PS.rl.mapset);
+	    return 1;
+	PS.rst.do_grey = 0;	/* Null grey because is not the same map as raster */
     /* Sort categories by user (min value) */
-    CELL * ip = (CELL *) G_malloc(sizeof( CELL) * PS.rst.cats.ncats);
+    CELL *ip = (CELL *) G_malloc(sizeof(CELL) * PS.rst.cats.ncats);
     for (i = 0; i < PS.rst.cats.ncats; i++)
-        G_get_ith_d_raster_cat(&(PS.rst.cats), i, &dmin, &dmax);
-        ip[i] = (CELL)dmin;
+	G_get_ith_d_raster_cat(&(PS.rst.cats), i, &dmin, &dmax);
+	ip[i] = (CELL) dmin;
     sort_list(PS.rl.cat_order, PS.rst.cats.ncats, &ip);
     /* How many categories to show */
     G_debug(3, "colortable: %d categories", num_cats);
     num_cats = PS.rst.cats.ncats;
-    if (num_cats <= 0) {
-		G_warning(_("Your cats/ file is invalid. A cats/ file with "
-			    "categories and labels is required for 'colortable' when using "
-			    "CELL rasters. No colortable will be assigned to this output "
-		    	"postscript file."));
-		return 1;
-    } else if (num_cats > 100) {
-        G_warning(_("Your cats/ file has %d cats (limit to 100)!"), num_cats);
+    if (num_cats <= 0)
+	G_warning(_("Your cats/ file is invalid. A cats/ file with "
+		    "categories and labels is required for 'colortable' when using "
+		    "CELL rasters. No colortable will be assigned to this output " "postscript file."));
+	return 1;
+    else if (num_cats > 100)
+	G_warning(_("Your cats/ file has %d cats (limit to 100)!"), num_cats);
     if (PS.rl.do_nodata)
-        ++num_cats; /* slot for no_data */
+	++num_cats;		/* slot for no_data */
-	/* define number of rows */
-    if (num_cats < PS.rl.legend.cols) {
-        PS.rl.legend.cols = num_cats;
-        rows = 1;
+    /* define number of rows */
+    if (num_cats < PS.rl.legend.cols)
+	PS.rl.legend.cols = num_cats;
+	rows = 1;
-    else {
-        rows = (int)num_cats / PS.rl.legend.cols;
-        if (num_cats % PS.rl.legend.cols) ++rows;
+    else
+	rows = (int)num_cats / PS.rl.legend.cols;
+	if (num_cats % PS.rl.legend.cols)
+	    ++rows;
     cols = PS.rl.legend.cols;
     if (!PS.rl.do_nodata)
     /* set font */
     fontsize = set_ps_font(&(PS.rl.legend.font));
     /* Array of data */
     fprintf(PS.fp, "/ARh %d array def\n", rows);
-    fprintf(PS.fp, "0 1 %d {ARh exch %.2f put} for\n", rows-1, fontsize);
+    fprintf(PS.fp, "0 1 %d {ARh exch %.2f put} for\n", rows - 1, fontsize);
     fprintf(PS.fp, "/ARw %d array def\n", cols);
     i = PS.rl.do_nodata ? 0 : 1;
     for (n = 0; n < cols; n++)
-        fprintf(PS.fp, "/AR%d [\n", n);
-        for (j = 0; j < rows && i < num_cats; j++, i++)
-            /* labels */
-			if (i == 0) {
-				fprintf(PS.fp, "(%s) ", "no data");
-                G_get_null_value_color(&R, &G, &B, &(PS.rst.colors[0]));
-				dmin = dmax = 0.;
-			else {
-				label = G_get_ith_d_raster_cat(&(PS.rst.cats), ip[i-1], &dmin, &dmax);
-				fprintf(PS.fp, "(%s) ", label);
-			/* colors */
-			fprintf(PS.fp, "[");
-			if (dmin == dmax) {
-                G_get_d_raster_color(&dmin, &R, &G, &B, &(PS.rst.colors[0]));
-                fprintf(PS.fp, "%.3f %.3f %.3f", R/255., G/255., B/255.);
-			else {
-				for (k = 0; k < 5; k++) {
-					val = dmin + (double)k *(dmax - dmin) / 5;
-                    G_get_d_raster_color(&val, &R, &G, &B, &(PS.rst.colors[0]));
-					fprintf(PS.fp, "%.3f %.3f %.3f ", R/255., G/255., B/255.);
-			fprintf(PS.fp, "]\n");
+	fprintf(PS.fp, "/AR%d [\n", n);
+	for (j = 0; j < rows && i < num_cats; j++, i++)
+	    /* labels */
+	    if (i == 0)
+		fprintf(PS.fp, "(%s) ", "no data");
+		G_get_null_value_color(&R, &G, &B, &(PS.rst.colors[0]));
+		dmin = dmax = 0.;
+	    else
+		label = G_get_ith_d_raster_cat(&(PS.rst.cats), ip[i - 1], &dmin, &dmax);
+		fprintf(PS.fp, "(%s) ", label);
+	    /* colors */
+	    fprintf(PS.fp, "[");
+	    if (dmin == dmax)
+		G_get_d_raster_color(&dmin, &R, &G, &B, &(PS.rst.colors[0]));
+		fprintf(PS.fp, "%.3f %.3f %.3f", R / 255., G / 255., B / 255.);
+	    else
+		for (k = 0; k < 5; k++)
+		    val = dmin + (double)k *(dmax - dmin) / 5;
+		    G_get_d_raster_color(&val, &R, &G, &B, &(PS.rst.colors[0]));
+		    fprintf(PS.fp, "%.3f %.3f %.3f ", R / 255., G / 255., B / 255.);
-        fprintf(PS.fp, "/mx 0 def 0 2 AR%d length -- {", n);
-        fprintf(PS.fp, "AR%d exch get SW /t XD t mx gt {/mx t def} if} for\n", n);
-        fprintf(PS.fp, "ARw %d mx put\n", n);
+	    fprintf(PS.fp, "]\n");
+	fprintf(PS.fp, "/mx 0 def 0 2 AR%d length -- {", n);
+	fprintf(PS.fp, "AR%d exch get SW /t XD t mx gt {/mx t def} if} for\n", n);
+	fprintf(PS.fp, "ARw %d mx put\n", n);
     G_free(ip);
-	/** Adjust - Legend Box */
+    /* Adjust Legend Box */
     set_box_orig(&(PS.rl.legend.box));
     set_legend_adjust(&(PS.rl.legend), -1.);
     if (PS.rl.legend.title[0])
-        set_box_readjust_title(&(PS.rl.legend.box),
-                                 PS.rl.legend.title);
+	fprintf(PS.fp, "(%s) READJUST ", PS.rl.legend.title);
     set_box_draw(&(PS.rl.legend.box));
-	fwidth = .5;
+    fwidth = .5;		/* basic linewidth */
     /* Make the raster legend */
     fprintf(PS.fp, "RESET %.5f LW\n", fwidth);
-    fprintf(PS.fp, "/xw syw %.2f mul def ", 0.8);    /* symbol-width */
-    fprintf(PS.fp, "/yh %.2f def ", -fontsize);      /* symbol-height */
-    fprintf(PS.fp, "/t yh %d div def\n", 5);   /* gradient symbol-height, if any */
+    fprintf(PS.fp, "/xw syw %.2f mul def ", 0.8);	/* symbol-width */
+    fprintf(PS.fp, "/yh %.2f def ", -fontsize);	/* symbol-height */
+    fprintf(PS.fp, "/t yh %d div def\n", 5);	/* gradient symbol-height, if any */
-        fprintf(PS.fp, "%d COL 0 ROW\n", n);
-        fprintf(PS.fp, "0 2 AR%d length -- {/i XD\n", n);
-        fprintf(PS.fp, "x y -- xw yh\nAR%d i ++ get aload length 3 eq ", n);
-        fprintf(PS.fp, "{%c 4 copy RF} ", PS.rst.do_grey ? 'G' : 'C');
-        fprintf(PS.fp, "{/z y def %d {C /z t add def x z xw t neg RF} repeat} ", 5);
-        fprintf(PS.fp, "ifelse\n0 0 0 C RE\n");
-        set_ps_color(&(PS.rl.legend.font.color));
-        fprintf(PS.fp, "AR%d i get x syw add y ARh row get sub MS row 1 add ROW} for\n", n);
+	fprintf(PS.fp, "%d COL 0 ROW\n", n);
+	fprintf(PS.fp, "0 2 AR%d length -- {/i XD\n", n);
+	fprintf(PS.fp, "x y -- xw yh\nAR%d i ++ get aload length 3 eq ", n);
+	fprintf(PS.fp, "{%s 4 copy RF} ", PS.rst.do_grey ? "CG" : "C");
+	fprintf(PS.fp, "{/z y def %d {C /z t add def x z xw t neg RF} repeat} ", 5);
+	fprintf(PS.fp, "ifelse\n0 0 0 C RE\n");
+	set_ps_color(&(PS.rl.legend.font.color));
+	fprintf(PS.fp, "AR%d i get x syw add y ARh row get sub MS row 1 add ROW} for\n", n);
     /* Make the title of legend */
     if (PS.rl.legend.title[0] != 0)
-        set_ps_font(&(PS.rl.legend.title_font));
-        fprintf(PS.fp, "RESET\n");
-        if (PS.rl.legend.title[0] == '.')
-            fprintf(PS.fp, "(%s) x cwd 2 div add yo mgy mg sub sub M SHC\n",
-                    PS.rl.legend.title+1);
-        else
-            fprintf(PS.fp, "(%s) x yo mgy mg sub sub MS\n",
+	set_ps_font(&(PS.rl.legend.title_font));
+	fprintf(PS.fp, "xo mgx add yo mgy mg sub sub M wd mgx 2 mul sub (%s) SHS\n", PS.rl.legend.title);
     return 0;
@@ -165,154 +184,157 @@
 int set_rlegend_gradient(void)
-	int i, k, rows, nlines, dec;
-	int R, G, B;
-	DCELL dmin, dmax, val;
-	double fontsize, step, fwidth;
-	struct Colors colors;
-	struct FPRange range;
-	char *units[GNAME_MAX];
+    int i, k, rows, nlines, dec;
+    int R, G, B;
+    DCELL dmin, dmax, val;
+    double fontsize, step, fwidth;
+    struct Colors colors;
+    struct FPRange range;
+    char *units[GNAME_MAX];
     char format[50];
-	/* let user know what's happenning */
-	G_message(_("Raster legend with gradient <%s in %s> ..."),
+    /* let user know what's happenning */
+    G_message(_("Raster legend with gradient <%s in %s> ..."), PS.rl.name, PS.rl.mapset);
-	/* Get color range */
-	if (G_read_fp_range(PS.rl.name, PS.rl.mapset, &range) == -1) {
-		G_warning(_("Range information not available (run r.support)"));
-		return 1;
+    /* Get color range */
+    if (G_read_fp_range(PS.rl.name, PS.rl.mapset, &range) == -1)
+	G_warning(_("Range information not available (run r.support)"));
+	return 1;
     /* range and check */
-    if (PS.rl.custom_range) {
-		dmin = PS.rl.min;
-		dmax = PS.rl.max;
-    else {
-        G_get_fp_range_min_max(&range, &dmin, &dmax);
-        PS.rl.min = dmin;
-        PS.rl.max = dmax;
+    if (PS.rl.custom_range)
+	dmin = PS.rl.min;
+	dmax = PS.rl.max;
+    else
+	G_get_fp_range_min_max(&range, &dmin, &dmax);
+	PS.rl.min = dmin;
+	PS.rl.max = dmax;
-		G_warning(_("It is not a range of values (max = min)"));
-		return 1;
+    if (dmin == dmax)
+	G_warning(_("It is not a range of values (max = min)"));
+	return 1;
     /* color table */
-	if (G_read_colors(PS.rl.name, PS.rl.mapset, &colors) == -1) {
-		G_warning(_("Unable to read colors for rlegend"));
+    if (G_read_colors(PS.rl.name, PS.rl.mapset, &colors) == -1)
+	G_warning(_("Unable to read colors for rlegend"));
-	/* units label */
-	if (G_read_raster_units(PS.rl.name, PS.rl.mapset, (char *)units) != 0) {
-        units[0] = 0;
+    /* units label */
+    if (G_read_raster_units(PS.rl.name, PS.rl.mapset, (char *)units) != 0)
+	units[0] = 0;
-	/* initialize */
+    /* initialize */
     /* set standard height */
-	if (PS.rl.height <= 0.) {
-		PS.rl.height = 15. * fontsize;
-		rows = 10; /* = PS.rl.height / 1.5*fontsize */
-	else
-		rows = (int)(PS.rl.height/(1.5 * fontsize));
+    if (PS.rl.height <= 0.)
+	PS.rl.height = 15. * fontsize;
+	rows = 10;		/* = PS.rl.height / 1.5*fontsize */
+    else
+	rows = (int)(PS.rl.height / (1.5 * fontsize));
-	/* Nice step and first value as ps_fctltbl */
-	step = nice_step(dmax - dmin, rows, &dec);
-	val = step * (int)(dmin/step);
-	if (val < dmin) val += step;
+    /* Nice step and first value as ps_fctltbl */
+    step = nice_step(dmax - dmin, rows, &dec);
+    val = step * (int)(dmin / step);
+    if (val < dmin)
+	val += step;
     /* Array of strings and widths */
     sprintf(format, "(%%.%df) %%.8f\n", dec);
     fprintf(PS.fp, "/AR0 [\n");
-	while (val <= dmax)
-		fprintf(PS.fp, format, val, (dmax-val)/(dmax-dmin));
-		val += step;
+    while (val <= dmax)
+	fprintf(PS.fp, format, val, (dmax - val) / (dmax - dmin));
+	val += step;
     fprintf(PS.fp, "/ARh 1 array def ARh 0 %.2f put\n", fontsize);
     fprintf(PS.fp, "/ARw 1 array def "
-            "/mx 0 def 0 2 AR0 length 1 sub {"
-            "AR0 exch get SW /t XD t mx gt {/mx t def} if } for "
-            "ARw 0 mx put\n");
+	    "/mx 0 def 0 2 AR0 length 1 sub {" "AR0 exch get SW /t XD t mx gt {/mx t def} if } for " "ARw 0 mx put\n");
-    PS.rl.legend.span = 0.; /* needed for auto adjust */
+    PS.rl.legend.xspan = 0.;	/* needed for auto adjust */
 	/** Adjust - box legend */
-	set_legend_adjust(&(PS.rl.legend), PS.rl.height);
+    set_legend_adjust(&(PS.rl.legend), PS.rl.height);
     if (units[0] != 0)
-        set_box_readjust(&(PS.rl.legend.box), -1., -1., -1., 0.8*fontsize);
+	set_inner_readjust(-1., -1., -1., 0.8 * fontsize);
-	fwidth = .5;
+    fwidth = .5;
-	nlines = (int)(PS.rl.height * 2.5); /* = 2.5 * 72 = 180 ppp */
-	step = (dmax - dmin) / nlines;
+    nlines = (int)(PS.rl.height * 2.5);	/* = 2.5 * 72 = 180 ppp */
+    step = (dmax - dmin) / nlines;
-	/* Draw the labels */
+    /* Draw the labels */
     fprintf(PS.fp, "RESET %.3f LW /ch chg %.3f sub def\n", fwidth, fwidth);
-    fprintf(PS.fp, "/x x syw add def /y y %.3f sub def\n", fwidth/2.);
-	fprintf(PS.fp, "0 2 AR0 length -- {/i XD\n");
-	fprintf(PS.fp, "x y ch AR0 i ++ get mul\n");
-	if (PS.rl.tickbar) {
-        fprintf(PS.fp, "GS ");
-        fprintf(PS.fp, "3 copy sub ");
-		fprintf(PS.fp, "NM -1 0 MR -%d 0 LR CS GR\n", PS.rl.tickbar); /* length of tickbar */
+    fprintf(PS.fp, "/x x syw %s add def ", (PS.rl.tickbar ? "++" : "2 add"));
+    fprintf(PS.fp, "/y y %.3f sub def\n", fwidth / 2.);
+    fprintf(PS.fp, "0 2 AR0 length -- {/i XD\n");
+    fprintf(PS.fp, "x y ch AR0 i ++ get mul\n");
+    if (PS.rl.tickbar)
+	fprintf(PS.fp, "3 copy sub ");
+	fprintf(PS.fp, "NM -1 0 MR -%d 0 LR CS GR\n", PS.rl.tickbar);	/* length of tickbar */
     /* Ajusta los extremos que no salgan de la barra */
-//     fprintf(PS.fp, "%.3f add ", 0.25*fontsize);
-    // fprintf(PS.fp, "1.0 AR0 i ++ get sub %.3f mul add ", 0.67*fontsize);
-    fprintf(PS.fp, "%.3f ", 0.6*fontsize); /* aprox part upper tickbar */
-	fprintf(PS.fp, "2 copy lt {add} {2 div add dup ch gt {pop ch} if} ifelse ");
+    fprintf(PS.fp, "%.3f ", 0.6 * fontsize);	/* aprox part upper tickbar */
+    fprintf(PS.fp, "2 copy lt {2 div add}" " {2 div add dup ch gt {pop ch} if} ifelse ");
+    fprintf(PS.fp, "sub M AR0 i get show} for\n");
-	fprintf(PS.fp, "sub M AR0 i get show} for\n");
     /* Prepare the border and stroke area */
-	fprintf(PS.fp, "/dy chg %d div def ", nlines); /* dy: linewidth */
-	fprintf(PS.fp, "/dx syw %d sub def\n", PS.rl.tickbar); /* dx: barwidth, here, here */
-	fprintf(PS.fp, "x y dx chg neg "); /* to rectstroke */
+    fprintf(PS.fp, "RESET\n");
+    fprintf(PS.fp, "/dy chg %d div def ", nlines);	/* dy: linewidth */
+    fprintf(PS.fp, "/dx syw %d sub def\n", PS.rl.tickbar);	/* dx: barwidth, here, here */
+    fprintf(PS.fp, "x y dx chg neg ");	/* to rectstroke */
-	/* draw the colorbar and frame */
-	fprintf(PS.fp, "dy 1.1 mul LW x y chg sub\n"); /* stack x and y */
-	fprintf(PS.fp, "[\n");
-	for (val = dmin; val <= dmax; val += step)
-		G_get_d_raster_color(&val, &R, &G, &B, &colors);
-            fprintf(PS.fp, "[%.3f]\n", (0.30*(double)R+0.59*(double)G+0.11*(double)B)/255.);
-        else
-            fprintf(PS.fp, "[%.3f %.3f %.3f]\n", R/255., G/255., B/255.);
+    /* draw the colorbar and frame */
+    fprintf(PS.fp, "dy 1.1 mul LW x y chg sub\n");	/* stack x and y */
+    fprintf(PS.fp, "[\n");
+    for (val = dmin; val <= dmax; val += step)
+	G_get_d_raster_color(&val, &R, &G, &B, &colors);
+	    fprintf(PS.fp, "[%.3f]\n", (0.30 * (double)R + 0.59 * (double)G + 0.11 * (double)B) / 255.);
+	else
+	    fprintf(PS.fp, "[%.3f %.3f %.3f]\n", R / 255., G / 255., B / 255.);
-	fprintf(PS.fp, "] {aload pop %c 2 copy M dx 0 LR stroke dy add} forall\n",
-            PS.rst.do_grey ? 'G' : 'C');
+    fprintf(PS.fp, "] {aload pop %c 2 copy M dx 0 LR stroke dy add} forall\n", PS.rst.do_grey ? 'G' : 'C');
     fprintf(PS.fp, "pop pop\n");
     fprintf(PS.fp, "GS 4 copy RC\n");
-    if (PS.rl.whiteframe > 0.) /* white border: print on colors */
-        fprintf(PS.fp, "4 copy 1 1 1 C %d LW RE\n", PS.rl.whiteframe);
+    if (PS.rl.whiteframe > 0.)	/* white border: print on colors */
+	fprintf(PS.fp, "4 copy 1 1 1 C %d LW RE\n", PS.rl.whiteframe);
     fprintf(PS.fp, "GR ");
     fprintf(PS.fp, "%.5f LW RO\n", fwidth);
-	/* print units label, if present */
-	if (units[0]) {
-        fprintf(PS.fp, "%.1f FS ", 0.8*fontsize);
-        fprintf(PS.fp, "RESET (%s) dup SW ", units);
-        fprintf(PS.fp, "x cwd add exch sub y chg %.1f add sub MS\n", fontsize);
+    /* print units label, if present */
+    if (units[0])
+	fprintf(PS.fp, "%.1f FS ", 0.8 * fontsize);
+	fprintf(PS.fp, "RESET (%s) dup SW ", units);
+	fprintf(PS.fp, "x cwd add exch sub y chg %.1f add sub MS\n", fontsize);
-	G_free_colors(&colors);
+    G_free_colors(&colors);
-	return 0;
+    return 0;
 /* Extract from function ps_fcolortable
@@ -320,35 +342,40 @@
 static double nice_step(double diff, int cuts, int *cur_dec)
-	int i, cur_step, dec;
-	double nice_steps[4] = { 1.0, 2.0, 2.5, 5.0 };	/* nice steps */
-	double step, ex, cur_d, cur_ex;
+    int i, cur_step, dec;
+    double nice_steps[4] = { 1.0, 2.0, 2.5, 5.0 };	/* nice steps */
+    double step, ex, cur_d, cur_ex;
-	step = diff / cuts;
+    step = diff / cuts;
-	for (i = 0; i < 4; i++) {
-        dec = 0;
-        /* smalest n for which nice step >= raw step */
-		if (nice_steps[i] <= step) {
-			ex = 1;
-			while (nice_steps[i] * ex < step)
-				ex *= 10;
-		else {
-			ex = 0.1;
-			while (nice_steps[i] * ex > step) {
-                ++dec;
-				ex *= 0.1;
-			ex *= 10;
-		if (i == 0 || (nice_steps[i] * ex - step) < cur_d) {
-			cur_step = i;
-			cur_d = nice_steps[i] * ex - step;
-			cur_ex = ex;
-            *cur_dec = dec;
+    for (i = 0; i < 4; i++)
+	dec = 0;
+	/* smalest n for which nice step >= raw step */
+	if (nice_steps[i] <= step)
+	    ex = 1;
+	    while (nice_steps[i] * ex < step)
+		ex *= 10;
+	else
+	    ex = 0.1;
+	    while (nice_steps[i] * ex > step)
+		++dec;
+		ex *= 0.1;
+	    ex *= 10;
+	if (i == 0 || (nice_steps[i] * ex - step) < cur_d)
+	    cur_step = i;
+	    cur_d = nice_steps[i] * ex - step;
+	    cur_ex = ex;
+	    *cur_dec = dec;
-	return nice_steps[cur_step] * cur_ex;
+    return nice_steps[cur_step] * cur_ex;
Modified: grass-addons/postscript/ps.output/set_scalebar.c
--- grass-addons/postscript/ps.output/set_scalebar.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_scalebar.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -6,7 +6,7 @@
 #include "local_proto.h"
 #include "conversion.h"
-char * strnumber(double num);
+char *strnumber(double num);
 int set_scalebar(void)
@@ -15,209 +15,207 @@
     double width, segment;
     if (PS.sbar.length <= 0 || PS.sbar.segments <= 0)
-        return 1;
+	return 1;
+    fprintf(PS.fp, "GS [] 0 LD\n");
     /* width of scalebar in points */
     width = PS.sbar.length;
     switch (PS.sbar.ucode)
-        case SB_UNITS_KM:
-            width *= KILOMETERS_TO_METERS;
-            break;
-        case SB_UNITS_FEET:
-            width *= FEET_TO_METERS;
-            break;
-        case SB_UNITS_MILES:
-            width *= MILES_TO_METERS;
-            break;
-        case SB_UNITS_NMILES:
-            width *= NAUT_MILES_TO_METERS;
-            break;
-        default:
-            width *= G_database_units_to_meters_factor();
-            break;
+    case SB_UNITS_KM:
+	width *= KILOMETERS_TO_METERS;
+	break;
+    case SB_UNITS_FEET:
+	width *= FEET_TO_METERS;
+	break;
+    case SB_UNITS_MILES:
+	width *= MILES_TO_METERS;
+	break;
+    case SB_UNITS_NMILES:
+	width *= NAUT_MILES_TO_METERS;
+	break;
+    default:
+	width *= G_database_units_to_meters_factor();
+	break;
     width *= (1000. * MM_TO_POINT / (double)PS.scale);
-    if (PS.sbar.subsegs > 0 && PS.sbar.type != 'I') {
-        segment = width/(double)PS.sbar.segments;
-        width += segment;
+    if (PS.sbar.subsegs > 0 && PS.sbar.type != 'I')
+	segment = width / (double)PS.sbar.segments;
+	width += segment;
     /* adjust to min size */
     set_ps_font(&(PS.sbar.font));
     set_box_orig(&(PS.sbar.box));
-    set_box_size(&(PS.sbar.box),
-                   width + 2.*PS.sbar.box.margin, /* cwd real width */
-                   PS.sbar.height + 2.*PS.sbar.box.margin);
+    set_box_size(&(PS.sbar.box), width + 2. * PS.sbar.box.margin,	/* cwd real width */
+		 PS.sbar.height + 2. * PS.sbar.box.margin);
     /* labels of the scalebar */
     fprintf(PS.fp, "/AR0 [");
     segment = (PS.sbar.length / PS.sbar.segments);
-    for (i = 0; i <= PS.sbar.segments; i += PS.sbar.labels )
+    for (i = 0; i <= PS.sbar.segments; i += PS.sbar.labels)
-        fprintf(PS.fp, "(%s)", strnumber(i*segment));
+	fprintf(PS.fp, "(%s)", strnumber(i * segment));
     /* sublabels of the scalebar */
     if (PS.sbar.type != 'I')
-        fprintf(PS.fp, "/AR1 [(0)");
-        segment = (PS.sbar.length/PS.sbar.segments)/PS.sbar.subsegs;
-        for (i = PS.sbar.sublabs; i <= PS.sbar.subsegs; i += PS.sbar.sublabs )
+	fprintf(PS.fp, "/AR1 [(0)");
+	segment = (PS.sbar.length / PS.sbar.segments) / PS.sbar.subsegs;
+	for (i = PS.sbar.sublabs; i <= PS.sbar.subsegs; i += PS.sbar.sublabs)
     /* The text in PS.sbar.units used to calculate size of text */
-    if (PS.sbar.type == 'I') {
-        fprintf(PS.fp,
-                "/mgy mg def (%s) SWH 2 add /chg XD "
-                "chg mg 2 mul add /hg XD 2 add wd add /wd XD\n",
-                PS.sbar.units);
+    if (PS.sbar.type == 'I')
+	fprintf(PS.fp,
+		"/mgy mg def (%s) SWH 2 add /chg XD " "chg mg 2 mul add /hg XD 2 add wd add /wd XD\n", PS.sbar.units);
-    else if (PS.sbar.type == 's' || PS.sbar.type == 'S') {
-        fprintf(PS.fp,
-                "AR0 dup length -- get SWH "
-                "mg add /mgy XD 2 div dup mg add /mgr XD wd add (%s) SW 2 add add /wd XD "
-                "/hg mgy 2 add mg add chg add def\n",
-                PS.sbar.units);
+    else if (PS.sbar.type == 's' || PS.sbar.type == 'S')
+	fprintf(PS.fp,
+		"AR0 dup length -- get SWH "
+		"mg add /mgy XD 2 div dup mg add /mgr XD wd add (%s) SW 2 add add /wd XD "
+		"/hg mgy 2 add mg add chg add def\n", PS.sbar.units);
-    else {
-        fprintf(PS.fp,
-                "mg add /mgy XD 2 div dup mg add /mgr XD wd add /wd XD "
-                "/hg mgy 2 mul ++ chg add def\n");
+    else
+	fprintf(PS.fp,
+		"mg add /mgy XD 2 div dup mg add /mgr XD wd add /wd XD " "/hg mgy 2 mul ++ chg add def\n");
     /* prepare the scalebar */
-    if (PS.sbar.subsegs == 0 || PS.sbar.type == 'I') {
-        fprintf(PS.fp,
-                "/dx cwd %d div def "
-                "/mgx mg def\n", PS.sbar.segments);
+    if (PS.sbar.subsegs == 0 || PS.sbar.type == 'I')
+	fprintf(PS.fp, "/dx cwd %d div def " "/mgx mg def\n", PS.sbar.segments);
-    else {
-        fprintf(PS.fp,
-                "/dx cwd %d div def\n"
-                "AR1 dup length -- get SW 2 div dup "
-                "mg add dx add /mgx XD wd add /wd XD\n",
-                PS.sbar.segments+1);
+    else
+	fprintf(PS.fp,
+		"/dx cwd %d div def\n"
+		"AR1 dup length -- get SW 2 div dup " "mg add dx add /mgx XD wd add /wd XD\n", PS.sbar.segments + 1);
     /* do the scalebar */
     set_box_draw(&(PS.sbar.box));
     switch (PS.sbar.type)
-        case 'I':
-            fprintf(PS.fp, "/RBAR {{x exch dx mul add y dx dy RF} for} D\n");
-            fprintf(PS.fp, "/RTXT {{/i XD x i dx mul add y M AR0 i get SHR} for} D\n");
-            fprintf(PS.fp, "/mgy mg def RESET /dy chg neg def\n");
-            set_ps_color(&(PS.sbar.font.color));
-            fprintf(PS.fp, "1 LW x y cwd dy RE\n");
-            fprintf(PS.fp, "1 2 %d RBAR\n", PS.sbar.segments-1);
-            set_ps_color(&(PS.sbar.fcolor));
-            fprintf(PS.fp, "0 2 %d RBAR\n", PS.sbar.segments-1);
-            fprintf(PS.fp, "/y y dy 1 add add def ");
-            fprintf(PS.fp, "2 2 %d RTXT ", PS.sbar.segments);
-            fprintf(PS.fp, "1 2 %d RTXT ", PS.sbar.segments);
-            fprintf(PS.fp, "(%s) x cwd 2 add add y MS\n", PS.sbar.units);
-            break;
-        case 'f':
-        case 'F':
-            fprintf(PS.fp,"/RBAR ");
-            if (PS.sbar.type == 'F')
-                fprintf(PS.fp, "{ {x exch dx mul add y chg 2 div sub dx 3 index RF} for pop} D\n");
-            else
-                fprintf(PS.fp, "{ {x exch dx mul add y dx 3 index RF} for pop} D\n");
-            fprintf(PS.fp,
-                    "/RTXT {1 2 index length -- "
-                    "{dup x exch dx mul i mul add y 1 add M"
-                    " 1 index exch get SHC} for pop} D\n");
-            fprintf(PS.fp, "RESET /dy chg neg def\n");
-            fprintf(PS.fp, "x %s y cwd dy 4 copy RF ", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
-            fprintf(PS.fp, ".5 LW RE\n");
-            if (PS.sbar.type == 'F') {
-                fprintf(PS.fp, "dy 2 div neg 0 2 %d RBAR ", PS.sbar.segments-1);
-                fprintf(PS.fp, "dy 2 div 1 2 %d RBAR\n", PS.sbar.segments-1);
-            else {
-                fprintf(PS.fp, "dy 0 2 %d RBAR ", PS.sbar.segments-1);
-            fprintf(PS.fp, "/i %d def AR0 0 RTXT ", PS.sbar.labels);
-            if (PS.sbar.subsegs > 0)
-                fprintf(PS.fp, "/dx dx %d div neg def ", PS.sbar.subsegs);
-                    fprintf(PS.fp, "dy 2 div 0 2 %d RBAR ", PS.sbar.subsegs-1);
-                    fprintf(PS.fp, "dy 2 neg div 1 2 %d RBAR ", PS.sbar.subsegs-1);
-                else {
-                    fprintf(PS.fp, "dy 1 2 %d RBAR ", PS.sbar.subsegs-1);
-                fprintf(PS.fp, "/i %d def AR1 1 RTXT\n", PS.sbar.sublabs);
-            fprintf(PS.fp,
-                    "xo wd add mgr sub yo hg sub mg add M (%s) SHR\n",
-                    PS.sbar.units);
-            break;
-        case 's':
-        case 'S':
-        default:
-            fprintf(PS.fp,
-                    "/RBAR { {x exch dx mul add y M dup 0 exch LRS} for pop} D\n"
-                    "{dup x exch dx mul i mul add y dy add ++ M"
-            fprintf(PS.fp, "RESET /dy chg 2 div def /y y dy sub def .5 LW\n");
-            if (PS.sbar.type == 'S') {
-                fprintf(PS.fp, "x %s y cwd dy neg 4 copy RF ",
-                        (PS.sbar.subsegs > 0 ? "dx sub" : ""));
-                fprintf(PS.fp, "RE\n", PS.sbar.segments);
-            else {
-                fprintf(PS.fp, "GS 2 LC x %s y dy sub M cwd 0 LRS GR\n",
-            fprintf(PS.fp, "dy neg 0 1 %d RBAR\n", PS.sbar.segments);
-            fprintf(PS.fp, "dy 0 %d %d RBAR\n", PS.sbar.labels, PS.sbar.segments);
-                fprintf(PS.fp, "dy neg 1 1 %d RBAR ", PS.sbar.subsegs);
-                fprintf(PS.fp, "dy 0 %d %d RBAR ", PS.sbar.sublabs, PS.sbar.subsegs);
-            fprintf(PS.fp,
-                    "xo wd add mg sub y dy add ++ M (%s) SHR\n",
-                    PS.sbar.units);
-            break;
+    case 'I':
+	fprintf(PS.fp, "/RBAR {{x exch dx mul add y dx dy RF} for} D\n");
+        fprintf(PS.fp, "/RTXT {{dup x exch dx mul add -- y M AR0 exch get SHR} for} D\n");
+        fprintf(PS.fp, "/mgy mg def RESET /dy chg neg def\n");
+	set_ps_color(&(PS.sbar.font.color));
+	fprintf(PS.fp, "1 LW x y cwd dy RE\n");
+	fprintf(PS.fp, "1 2 %d RBAR\n", PS.sbar.segments - 1);
+	set_ps_color(&(PS.sbar.fcolor));
+	fprintf(PS.fp, "0 2 %d RBAR\n", PS.sbar.segments - 1);
+	fprintf(PS.fp, "/y y dy 1 add add def ");
+	fprintf(PS.fp, "2 2 %d RTXT ", PS.sbar.segments);
+	fprintf(PS.fp, "1 2 %d RTXT ", PS.sbar.segments);
+	fprintf(PS.fp, "(%s) x cwd 2 add add y MS\n", PS.sbar.units);
+	break;
+    case 'f':
+    case 'F':
+	fprintf(PS.fp, "/RBAR ");
+	if (PS.sbar.type == 'F')
+	    fprintf(PS.fp, "{ {x exch dx mul add y chg 2 div sub dx 3 index RF} for pop} D\n");
+	else
+	    fprintf(PS.fp, "{ {x exch dx mul add y dx 3 index RF} for pop} D\n");
+	fprintf(PS.fp,
+		"/RTXT {1 2 index length -- "
+		"{dup x exch dx mul i mul add y 1 add M" " 1 index exch get SHC} for pop} D\n");
+	fprintf(PS.fp, "RESET /dy chg neg def\n");
+	fprintf(PS.fp, "x %s y cwd dy 4 copy RF ", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	fprintf(PS.fp, ".5 LW RE\n");
+	    fprintf(PS.fp, "dy 2 div neg 0 2 %d RBAR ", PS.sbar.segments - 1);
+	    fprintf(PS.fp, "dy 2 div 1 2 %d RBAR\n", PS.sbar.segments - 1);
+	else
+	    fprintf(PS.fp, "dy 0 2 %d RBAR ", PS.sbar.segments - 1);
+	fprintf(PS.fp, "/i %d def AR0 0 RTXT ", PS.sbar.labels);
+	if (PS.sbar.subsegs > 0)
+	    fprintf(PS.fp, "/dx dx %d div neg def ", PS.sbar.subsegs);
+		fprintf(PS.fp, "dy 2 div 0 2 %d RBAR ", PS.sbar.subsegs - 1);
+		fprintf(PS.fp, "dy 2 neg div 1 2 %d RBAR ", PS.sbar.subsegs - 1);
+	    else
+		fprintf(PS.fp, "dy 1 2 %d RBAR ", PS.sbar.subsegs - 1);
+	    fprintf(PS.fp, "/i %d def AR1 1 RTXT\n", PS.sbar.sublabs);
+	fprintf(PS.fp, "xo wd add mgr sub yo hg sub mg add M (%s) SHR\n", PS.sbar.units);
+	break;
+    case 's':
+    case 'S':
+    default:
+	fprintf(PS.fp,
+		"/RBAR { {x exch dx mul add y M dup 0 exch LRS} for pop} D\n"
+		"{dup x exch dx mul i mul add y dy add ++ M" " 1 index exch get SHC} for pop} D\n");
+	fprintf(PS.fp, "RESET /dy chg 2 div def /y y dy sub def .5 LW\n");
+	if (PS.sbar.type == 'S')
+	    fprintf(PS.fp, "x %s y cwd dy neg 4 copy RF ", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	    fprintf(PS.fp, "RE\n", PS.sbar.segments);
+	else
+	    fprintf(PS.fp, "GS 2 LC x %s y dy sub M cwd 0 LRS GR\n", (PS.sbar.subsegs > 0 ? "dx sub" : ""));
+	fprintf(PS.fp, "dy neg 0 1 %d RBAR\n", PS.sbar.segments);
+	fprintf(PS.fp, "dy 0 %d %d RBAR\n", PS.sbar.labels, PS.sbar.segments);
+	    fprintf(PS.fp, "dy neg 1 1 %d RBAR ", PS.sbar.subsegs);
+	    fprintf(PS.fp, "dy 0 %d %d RBAR ", PS.sbar.sublabs, PS.sbar.subsegs);
+	fprintf(PS.fp, "xo wd add mg sub y dy add ++ M (%s) SHR\n", PS.sbar.units);
+	break;
+    fprintf(PS.fp, "GR\n");
     return 0;
     static char text[50];
     if (num == 0)
-        sprintf(text, "0");
+	sprintf(text, "0");
     else if (num == (int)num)
-        sprintf(text, "%.0f", num);
+	sprintf(text, "%.0f", num);
     else if ((num * 10.) == (int)(num * 10))
-        sprintf(text, "%.1f", num);
+	sprintf(text, "%.1f", num);
     else if ((num * 100.) == (int)(num * 100))
-        sprintf(text, "%.2f", num);
+	sprintf(text, "%.2f", num);
     else
-        sprintf(text, "%.3f", num);
+	sprintf(text, "%.3f", num);
     return text;
Modified: grass-addons/postscript/ps.output/set_vector.c
--- grass-addons/postscript/ps.output/set_vector.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_vector.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -25,470 +25,75 @@
     int i;
     char buf[1024];
-    for (i = PS.vct_files -1; i >= 0; i--)
+    for (i = PS.vct_files - 1; i >= 0; i--)
-        if (masked && !PS.vct[i].masked) {
-            continue;
-        if (!masked && PS.vct[i].masked) {
-            continue;
-        if (PS.vct[i].type != type) {
-            continue;
-        /* select the type of output */
-        if (PS.vct[i].type == LINES)
-            VLINES * vl = (VLINES *)PS.vct[i].data;
-            if (vl->hline.width > 0 && !(vl->hline.color.none))
-                set_vlines(PS.vct[i], vl, DRAW_HLINE);
-                Vect_rewind(&(PS.vct[i].Map));
-            set_vlines(PS.vct[i], vl, DRAW_LINE);
-        else if (PS.vct[i].type == AREAS)
-            VAREAS * va = (VAREAS *)PS.vct[i].data;
-            if (va->pat != NULL)
-                set_ps_pattern(PS.vct[i].id, va->pat, va);
-            if (va->width != 0.)
-                set_vline_areas(PS.vct[i], va);
-            else
-                set_vareas(PS.vct[i], va);
-        else if (PS.vct[i].type == POINTS)
-            SYMBOL *symb;
-            VPOINTS * vp = (VPOINTS *)PS.vct[i].data;
-            symb = S_read(vp->symbol);
-            if (symb != NULL)
-                symbol_save(PS.vct[i].id, vp, symb);
-            else
-                set_ps_symbol_eps(PS.vct[i].id, vp, vp->symbol);
-            set_vpoints(PS.vct[i], vp);
+	if (masked && !PS.vct[i].masked)
+	    continue;
+        if (!masked && PS.vct[i].masked)
+	    continue;
+        if (PS.vct[i].type != type)
+	    continue;
+        /* select the type of output, NONE: no draw anything */
+	if (PS.vct[i].type == AREAS)
+	    VAREAS *va = (VAREAS *) PS.vct[i].data;
-    return 0;
-/* TO DRAW LINES */
-int vector_line(struct line_pnts *lpoints)
-    if (lpoints->n_points > 0)
-        register int i;
-        where_moveto(lpoints->x[0], lpoints->y[0]);
-        for (i = 1; i <= lpoints->n_points - 1; i++)
+	    if (va->name_pat != NULL)
+            set_ps_pattern(PS.vct[i].id, va->name_pat, va);
+	    if (va->width != 0.)
-            where_lineto(lpoints->x[i], lpoints->y[i]);
+            set_vareas_line(&(PS.vct[i]), va);
-    return 0;
-/* TO DRAW AREAS */
-int vector_area(struct line_pnts *lpoints, double sep)
-        struct line_pnts *opoints;
-        opoints = Vect_new_line_struct();
-        register int i;
-        for (i = 1; i < lpoints->n_points; i++)
+	    else
+            set_vareas(&(PS.vct[i]), va);
-        Vect_line_parallel(lpoints, sep, 0.01, 0, opoints);
-        Vect_line_reverse(opoints);
-        for (i = 0; i < opoints->n_points; i++)
-            where_lineto(opoints->x[i], opoints->y[i]);
-        where_lineto(lpoints->x[0], lpoints->y[0]);
-    return 0;
+	else if (PS.vct[i].type == LABELS)
+	    VLABELS *vl = (VLABELS *) PS.vct[i].data;
-/** Process a vector of lines */
-int set_vlines(VECTOR vec, VLINES *vl, int flag)
-    int ret, cat;
-    int ln, nlines, pt, npoints;
-    struct line_cats *lcats;
-    struct line_pnts *lpoints;
+	    set_vlabels(&(PS.vct[i]), vl);
+	else if (PS.vct[i].type == LINES)
+	    VLINES *vl = (VLINES *) PS.vct[i].data;
+	    if (vl->hline.width > 0 && !(vl->hline.color.none))
+		set_vlines(&(PS.vct[i]), vl, DRAW_HLINE);
+		Vect_rewind(&(PS.vct[i].Map));
+	    set_vlines(&(PS.vct[i]), vl, DRAW_LINE);
+	else if (PS.vct[i].type == POINTS)
+	    SYMBOL *symb;
+	    VPOINTS *vp = (VPOINTS *) PS.vct[i].data;
-    nlines = Vect_get_num_lines(&(vec.Map));
-    /* Create vector array, if required */
-    if (vec.cats != NULL)
-        vec.Varray = Vect_new_varray(nlines);
-        ret = Vect_set_varray_from_cat_string(&(vec.Map), vec.layer,
-                        vec.cats, vl->type, 1, vec.Varray);
+	    symb = S_read(vp->symbol);
+	    if (symb != NULL)
+		symbol_save(PS.vct[i].id, vp, symb);
+	    else
+		set_ps_symbol_eps(PS.vct[i].id, vp->symbol);
+	    if (vp->distance > 0.)
+		set_vpoints_line(&(PS.vct[i]), vp);
+	    else
+		set_vpoints(&(PS.vct[i]), vp);
-    else if (vec.where != NULL)
-        ret = Vect_set_varray_from_db(&(vec.Map), vec.layer,
-                        vec.where, vl->type, 1, vec.Varray);
-    else
-        vec.Varray = NULL;
-    /* memory for coordinates */
-    lcats   = Vect_new_cats_struct();
-    lpoints = Vect_new_line_struct();
-    /* process only vectors in current window */
-    Vect_set_constraint_region(&(vec.Map),
-            PS.map.north, PS.map.south,
-            PS.map.east,  PS.map.west,
-            PORT_DOUBLE_MAX, -PORT_DOUBLE_MAX);
-    /* load attributes if fcolor is named */
-    dbCatValArray cv_rgb;
-    if (flag == DRAW_LINE)
-        if (vl->rgbcol != NULL)
-            load_catval_array(&(vec.Map), vl->rgbcol, &cv_rgb);
-    /* read and plot lines */
-    for (ln = 1; ln <= nlines; ln++)
-        ret = Vect_read_line(&(vec.Map), lpoints, lcats, ln);
-        if (ret < 0)
-            continue;
-        if (!(ret & GV_LINES) || !(ret & vl->type))
-            continue;
-        if (vec.Varray != NULL && vec.Varray->c[ln] == 0)
-            continue;
-        /* Oops the line is correct, I can draw it */
-        /* How I can draw it? */
-        if (flag == DRAW_HLINE)
-            if (vl->offset != 0.)
-                double dis;
-                struct line_pnts *opoints = Vect_new_line_struct();
-                dis = vl->offset * POINT_TO_MM / 1000. * PS.scale;
-                Vect_line_parallel(lpoints, dis, 0.1, 0, opoints);
-                vector_line(opoints);
-            else
-                vector_line(lpoints);
-            set_ps_line(&(vl->hline));
-        else
-            Vect_cat_get(lcats, 1, &cat);
-            /* dynamic colors */
-                PSCOLOR color;
-                set_color_name(&color, get_string(&cv_rgb, cat));
-                set_ps_color(&color);
-            else
-                set_ps_color(&(vl->line.color));
-            set_ps_line_no_color(&(vl->line));
-        /* paint now */
-        fprintf(PS.fp, "S\n");
-    fprintf(PS.fp, "GR\n");
     return 0;
-/** Process a vector of areas */
-int set_vareas(VECTOR vec, VAREAS *va)
-    int k, ret, cat;
-    int area, nareas, island, nislands, centroid;
-    BOUND_BOX box;
-    nareas = Vect_get_num_areas(&(vec.Map));
-        vec.Varray = Vect_new_varray(nareas);
-        Vect_set_varray_from_cat_string(&(vec.Map),
-                                          vec.layer, vec.cats, GV_AREA, 1, vec.Varray);
-        Vect_set_varray_from_db(&(vec.Map),
-                                  vec.layer, vec.where, GV_AREA, 1, vec.Varray);
-    else
-    /* memory for categories and coordinates */
-    dbCatValArray rgb;
-    if (va->rgbcol != NULL)
-        load_catval_array(&(vec.Map), va->rgbcol, &rgb);
-    /* read and plot vectors */
-    for (area = 1; area <= nareas; area++)
-        if (vec.Varray != NULL && vec.Varray->c[area] == 0) {
-            continue;
-        centroid = Vect_get_area_centroid(&(vec.Map), area);
-        if (centroid < 1)  /* area is an island */
-            continue;
-        /* check if in window */
-        Vect_get_area_box(&(vec.Map), area, &box);
-        if (box.N < PS.map.south || box.S > PS.map.north ||
-            box.E < PS.map.west  || box.W > PS.map.east)
-            continue;
-        /* Oops is a correct area, I can draw it */
-        if (Vect_get_area_points(&(vec.Map), area, lpoints) < 0)
-            break;
-        /* main area */
-        fprintf(PS.fp, "NP ");
-        fprintf(PS.fp, "CP\n");
-        /* islands */
-        nislands = Vect_get_area_num_isles(&(vec.Map), area);
-        for (island = 0; island < nislands; island++)
-            k = Vect_get_area_isle(&(vec.Map), area, island);
-            if (Vect_get_isle_points(&(vec.Map), k, lpoints) < 0)
-                return -1; /* ? break; */
-        /* set the fill */
-        if (!va->fcolor.none || va->rgbcol != NULL)
-            double r = va->fcolor.r;
-            double g = va->fcolor.g;
-            double b = va->fcolor.b;
-            /* set the color */
-            if (va->rgbcol != NULL) /* dynamic fcolor */
-                int R, G, B;
-                cat = Vect_get_area_cat(&(vec.Map), area, vec.layer);
-                if (G_str_to_color(get_string(&rgb, cat), &R, &G, &B) == 1)
-                    r = (double)R/255.;
-                    g = (double)G/255.;
-                    b = (double)B/255.;
-            fprintf(PS.fp, "%.3f %.3f %.3f ", r, g, b);
-            /* set the type of fill */
-                fprintf(PS.fp, "PATTERN%d setpattern F ", vec.id);
-            else
-                fprintf(PS.fp, "C F ");
-        /* set the line style */
-        if (va->line.width > 0 && !va->line.color.none)
-            set_ps_line(&(va->line));
-    return 0;
-int set_vpoints(VECTOR vec, VPOINTS * vp)
-    int ret, cat;
-    int  x, y, pt, npoints;
-    double size, rotate;
-    npoints = Vect_get_num_lines(&(vec.Map));
-        vec.Varray = Vect_new_varray(npoints);
-        Vect_set_varray_from_cat_string(&(vec.Map), vec.layer,
-                    vec.cats, vp->type, 1, vec.Varray);
-        Vect_set_varray_from_db(&(vec.Map), vec.layer,
-                    vec.where, vp->type, 1, vec.Varray);
-    else
-    /* load attributes if any */
-    dbCatValArray cv_size, cv_rot;
-    if (vp->sizecol != NULL)
-        load_catval_array(&(vec.Map), vp->sizecol, &cv_size);
-    if (vp->rotatecol != NULL)
-        load_catval_array(&(vec.Map), vp->rotatecol, &cv_rot);
-    for (pt = 1; pt <= npoints; pt++)
-        ret = Vect_read_line(&(vec.Map), lpoints, lcats, pt);
-        if (ret < 0)
-            continue;
-        if (!(ret & GV_POINTS) || !(ret & vp->type))
-            continue;
-        if (vec.Varray != NULL && vec.Varray->c[pt] == 0)
-            continue;
-        /* Is it inside area? */
-        G_plot_where_xy(lpoints->x[0], lpoints->y[0], &x, &y);
-        PS.x = (double)x / 10.;
-        PS.y = (double)y / 10.;
-        if (PS.x < PS.map_x || PS.x > PS.map_right ||
-            PS.y < PS.map_y || PS.y > PS.map_top)
-            continue;
-        /* Oops the point is correct, I can draw it */
-        fprintf(PS.fp, "%.4f %.4f TR ", PS.x, PS.y);
-        /* symbol size */
-        if (vp->sizecol == NULL) {
-            size = vp->size;
-        else {
-            get_number(&cv_size, cat, &size);
-            size *= vp->scale;
-        if (size > 0.)
-            fprintf(PS.fp, "%.3f dup SC ", size);
-        /* symbol rotate */
-        if (vp->rotatecol == NULL) {
-            rotate = vp->rotate;
-        else {
-            get_number(&cv_rot, cat, &rotate);
-        if (rotate > 0.)
-            fprintf(PS.fp, "%.3f ROT ", rotate);
-        /* symbol line */
-        if (size == 0.)
-            size = 1.; /* avoid division by zero */
-        fprintf(PS.fp, "%.3f LW SYMBOL%d ", (vp->line.width)/size, vec.id);
-    return 0;
-/** Process a vector of lines as area */
-int set_vline_areas(VECTOR vec, VAREAS *va)
-    int ret, cat;
-    double width;
-                vec.cats, GV_LINE, 1, vec.Varray);
-                                        vec.where, GV_LINE, 1, vec.Varray);
-    else
-        if (ret < 0)
-            continue;
-        if (!(ret & GV_LINE))
-            continue;
-            continue;
-        vector_area(lpoints, va->width * POINT_TO_MM / 1000. * PS.scale);
-        if (!va->fcolor.none)
-            else
-    return 0;
Modified: grass-addons/postscript/ps.output/set_vlegend.c
--- grass-addons/postscript/ps.output/set_vlegend.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/set_vlegend.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -1,179 +1,575 @@
-/* Function: vect_legend
- ** Author: Paul W. Carlson April 1992
- ** Modified by: Radim Blazek Jan 2000 area, label added
- ** Modified by: Morten Hulden Mar 2004, support for legend in columns added
- ** Modified by: E. Jorge Tizado Feb 2009, improve postscript code
+ * File: set_vlegend.c AUTHOR: E. Jorge Tizado, Spain 2009 COPYRIGHT:
+ * (c) 2009 E. Jorge Tizado, and the GRASS Development Team This program
+ * is free software under the GNU General Public License (>=v2). Read the
+ * file COPYING that comes with GRASS for details.
 #include "vlegend.h"
 #include "ps_info.h"
+#include "vector.h"
-int set_vlegend(void)
+int cmpitems(const void *i1, const void *i2)
-    int n, i, j, k, l, rows, cols, st, items, nopos;
-    double x, y, fontsize, sc;
+    if (((ITEMS *) i1)->rule < ((ITEMS *) i2)->rule)
+	return -1;
+    else if (((ITEMS *) i1)->rule > ((ITEMS *) i2)->rule)
+	return 1;
+    else
+	return 0;
-    /* Sort categories by user (min value) - In preparation */
-    CELL * ip = (CELL *) G_malloc(sizeof( CELL) * PS.vct_files);
-    for (items = 0, i = 0; i < PS.vct_files; i++)
+int set_vlegend()
+    int i, j, n_vct;
+    G_debug(1, "Placing vlegend ...");
+    /* How many vectors to draw? */
+    for (n_vct = 0, i = 0; i < PS.vct_files; i++)
-        if (PS.vct[i].lpos > 0) {
-            /* ip[items++] = PS.vct[i].id; */
-            ip[items++] = i;
+	if (PS.vct[i].lpos >= 0)
+	    ++n_vct;
-    if (items == 0)
-        return 0;
+    if (n_vct == 0)
+	return 1;
-    if (PS.vl.order[0] != 0)
-        sort_list(PS.vl.order, rows, &ip);
+    /* Reorder as defined by the user */
+    int *ip = (int *)G_malloc(n_vct * sizeof(int));
-    if (items < PS.vl.legend.cols) PS.vl.legend.cols = items;
-    rows = (int)items / PS.vl.legend.cols;	/* lines per column */
-    if (items % PS.vl.legend.cols) ++rows;
-    cols = PS.vl.legend.cols;
+    for (i = 0; i < n_vct; i++)
+	ip[i] = -1;
+    for (i = 0; i < PS.vct_files; i++)
+	if (PS.vct[i].lpos > 0)
+	    j = PS.vct[i].lpos - 1;
+	    if (j < n_vct && ip[j] < 0)
+		ip[j] = i;
+		PS.vct[i].lpos = -1;
+	    else
+		PS.vct[i].lpos = 0;
+	if (PS.vct[i].lpos == 0)
+	    j = 0;
+	    while (j < n_vct && ip[j] >= 0)
+		j++;
+	    if (j < n_vct)
+		ip[j] = i;
-    /* set font */
-    fontsize = set_ps_font(&(PS.vl.legend.font));
+    /* Use default values to undefined variables */
+    if (PS.vl.legend.box.margin < 0.)
+	PS.vl.legend.box.margin = 0.4 * PS.vl.legend.font.size;
-    /* Array of data */
-    fprintf(PS.fp, "/ARh %d array def\n", rows);
+    if (PS.vl.legend.width <= 0)
+        PS.vl.legend.width = 2.4 * PS.vl.legend.font.size;
-    fprintf(PS.fp, "/ARw %d array def\n", cols);
-    for (i = 0, n = 0; n < cols; n++)
+    if (PS.vl.legend.xspan <= 0)
+	PS.vl.legend.xspan = PS.vl.legend.box.margin;
+    if (PS.vl.legend.yspan <= 0)
+	PS.vl.legend.yspan = .5 * PS.vl.legend.font.size;
+    /* Define 'mg', 'hg', 'wd', 'dxx', 'dyy', 'syw', 'roh', and 'cow' */
+    fprintf(PS.fp, "/mg %.5f def\n", PS.vl.legend.box.margin);
+    fprintf(PS.fp, "/hg mg 2 mul def /wd mg 2 mul def\n");
+    fprintf(PS.fp, "/dxx %.2f def\n", PS.vl.legend.xspan);
+    fprintf(PS.fp, "/dyy %.2f def\n", PS.vl.legend.yspan);
+    fprintf(PS.fp, "/syw %.4f def\n", PS.vl.legend.width);
+    fprintf(PS.fp, "/roh %.2f def\n", PS.vl.legend.font.size);
+    fprintf(PS.fp, "/cow 0 def\n");
+    /* Con join puede haber menos elementos que vectores y hay que ponerlos a cero */
+    fprintf(PS.fp, "%d {0} repeat %d array astore /BKh XD\n", n_vct, n_vct);
+    fprintf(PS.fp, "%d {0} repeat %d array astore /BKw XD\n", n_vct, n_vct);
+    fprintf(PS.fp, "%d {0} repeat %d array astore /BKt XD\n", n_vct, n_vct);
+    /* Prepare the content of legend by vector */
+    int K, n;
-        for (j = 0; j < rows && i < items; j++, i++)
+	j = ip[i];
+        qsort(PS.vct[j].item, PS.vct[j].n_item, sizeof(ITEMS), cmpitems);
+        if (PS.vct[j].yspan <= 0)
+	    PS.vct[j].yspan = PS.vl.legend.yspan;
+    set_ps_font(&(PS.vl.legend.font));
+    for (K = 0, i = 0; i < n_vct; i++, K++)
+        j = ip[i];
+        /* if (PS.vct[j].n_item == 1) continue; con K-- */
+        if (PS.vct[j].n_item == 1)
-            k = ip[i];
-            /* label of de vector file */
-            if (PS.vct[k].label == NULL) {
-                fprintf(PS.fp, "( %s (%s))", PS.vct[k].name, PS.vct[k].mapset);
-            else {
-                fprintf(PS.fp, "( %s)", PS.vct[k].label);
-            /* vector data */
-            fprintf(PS.fp, " %d [", PS.vct[k].type);
-            if (PS.vct[k].type == AREAS)
+            n = 0;
+            while ((i+n) < n_vct && PS.vct[ip[i+n]].n_item == 1)
-                VAREAS * va = (VAREAS *)PS.vct[k].data;
-                if (!va->line.color.none && va->line.width > 0)
-                    fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.8f 1 ",
-                            va->line.color.r,
-                            va->line.color.g,
-                            va->line.color.b,
-                            va->line.dash,
-                            va->line.width);
-                else {
-                    fprintf(PS.fp, "0 "); /* no line */
-                if (!va->fcolor.none || va->pat != NULL)
-                        fprintf(PS.fp, "PATTERN%d 1 1", PS.vct[k].id);
-                    else
-                        fprintf(PS.fp, "%.3f %.3f %.3f 0 1",
-                            va->fcolor.r,
-                            va->fcolor.g,
-                            va->fcolor.b);
-                else {
-                    fprintf(PS.fp, "0"); /* no fill area */
+                ++n;
-            else if (PS.vct[k].type == LINES)
-                fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.8f",
-                        vl->line.color.r,
-                        vl->line.color.g,
-                        vl->line.color.b,
-                        vl->line.dash,
-                        vl->line.width);
-                if (vl->hline.width <= 0)
-                    fprintf(PS.fp, " 1");
-                else
-                    fprintf(PS.fp, " %.3f %.3f %.3f [%s] %.8f",
-                            vl->hline.color.r,
-                            vl->hline.color.g,
-                            vl->hline.color.b,
-                            vl->hline.dash,
-                            vl->hline.width);
-                    fprintf(PS.fp, " 2");
-            else if (PS.vct[k].type == POINTS)
-                VPOINTS * vp = (VPOINTS *)PS.vct[k].data;
-                fprintf(PS.fp, "(SYMBOL%d) ", PS.vct[k].id);
-                /* if vp->size == 0 => no draw? */
-                fprintf(PS.fp, " %.4f", vp->line.width / vp->size);
-                fprintf(PS.fp, " %.3f", vp->rotate);
-                fprintf(PS.fp, " %.3f dup", vp->size);
-                fprintf(PS.fp, " %.3f", .45*fontsize);
+            set_vlegend_simple(K, ip + i, n);
+            i += (n-1);
-        fprintf(PS.fp, "] def\n");
-        fprintf(PS.fp, "/mx 0 def 0 3 AR%d length -- { ", n);
-        fprintf(PS.fp, "AR%d exch get SW /t XD t mx gt {/mx t def} if } for\n", n);
+        else
+            set_vlegend_multi(K, &(PS.vct[j]));
+    n_vct = K;
     G_free(ip);
+    /* Prepare the title of the legend */
+    if (!PS.vl.legend.title || PS.vl.legend.title[0] == 0)
+	fprintf(PS.fp, "/mgy 0 def\n");
+    else
+	fprintf(PS.fp, "GS ");
+	set_ps_font(&(PS.vl.legend.title_font));
+	fprintf(PS.fp, "(%s) SWH ", PS.vl.legend.title);
+	fprintf(PS.fp, "mg add dup /mgy XD hg add /hg XD ");
+	fprintf(PS.fp, "mg 2 mul add wd 2 copy lt {exch} if pop /wd XD ");
+    /* Prepare and draw the frame of the legend */
+    fprintf(PS.fp, "hg BKh {add dyy add} forall dyy sub BKt {add} forall /hg XD\n");
+    fprintf(PS.fp, "wd BKw {mg 2 mul add 2 copy lt {exch} if pop} forall /wd XD\n");
     set_box_orig(&(PS.vl.legend.box));
-    set_legend_adjust(&(PS.vl.legend), -1.);
-    if (PS.vl.legend.title[0])
-        set_box_readjust_title(&(PS.vl.legend.box),
-                                 PS.vl.legend.title);
     set_box_draw(&(PS.vl.legend.box));
-    /* Make the vector legend */
-    fprintf(PS.fp, "/xw syw %.2f mul def ", 0.9);    /* symbol-width */
-    for (n = 0; n < cols; n++)
+    /* Draw the title of the legend */
+    if (PS.vl.legend.title && PS.vl.legend.title[0] != 0)
-                "0 3 AR%d length 1 sub {/i XD\n"
-                "ARh row get neg /rh XD\n"
-                "AR%d i 1 add get /tipe XD\n"
-                "AR%d i 2 add get aload pop\n", n, n, n, n);
-        fprintf(PS.fp,  "tipe %d eq {", POINTS);
-        fprintf(PS.fp,  "GS rh sub 2 div neg y add x xw 2 div add exch "
-                "TR SC ROT LW cvx cvn exec GR} if\n");
-        fprintf(PS.fp,  "tipe %d eq {", LINES);
-        fprintf(PS.fp,  "{LW 0 LD C x xw add y rh 0.65 mul add dup x exch ML} "
-                "repeat} if\n");
-        fprintf(PS.fp,  "tipe %d eq {[] 0 LD ", AREAS);
-        fprintf(PS.fp,  "x y -- x xw add y rh add -- B "
-                "0 ne {0 eq {C} {setpattern} ifelse F} if "
-                "0 ne {LW 0 LD C} if S} if\n", 0.2, 0.1, 0.6, 0.8);
-        set_ps_color(&(PS.vl.legend.font.color));
-        fprintf(PS.fp, "AR%d i get x syw add y ARh row get sub MS row ++ ROW} for\n", n);
+	fprintf(PS.fp, "xo mg add yo mgy sub M wd mg 2 mul sub (%s) SHS\n", PS.vl.legend.title);
-	fprintf(PS.fp, "[] 0 setdash\n");
-    /* Make the title of legend */
-    if (PS.vl.legend.title[0] != 0)
+    /* Draw the vectors of the legend */
+    fprintf(PS.fp,
+	    "/VLEGEND {"
+	    "dup 0 get /dy XD\n"
+	    "dup 1 get dup length 0 eq {pop} {x y dy add MS} ifelse y roh sub /y XD /yt y def\n"
+	    "dup 2 exch length 2 sub getinterval {"
+            "dup 0 3 2 index length -- {"
+            "3 getinterval aload pop /code XD aload pop\n");
+    fprintf(PS.fp,
+	    "code %d eq {"
+	    "GS 0 ne {LW 0 LD C x syw add 0 roh sub 2 div neg y add dup x exch ML [] 0 LD} if "
+            "x syw 2 div add 0.65 roh mul 2 div y add TR SC ROT LW cvx cvn exec GR} if\n", POINTS);
+    fprintf(PS.fp,
+            "code %d eq {"
+//            "GS {LW 0 LD C roh .35 mul /z XD x y z add M syw .3 mul z neg syw .6 mul z syw .9 mul 0 rcurveto S} repeat GR} if\n", LINES);
+            "GS {LW 0 LD C x syw add y roh 0.35 mul add dup x exch ML} repeat GR} if\n", LINES);
+    fprintf(PS.fp,
+            "code %d eq {"
+            "GS [] 0 LD x y -- x syw .9 mul add y roh add -- B "
+            "GS 0 ne {0 eq {C} {setpattern} ifelse fill} if GR 0 ne {LW 0 LD C S} if GR} if\n", AREAS);
+    set_ps_color(&(PS.vl.legend.font.color));
+    fprintf(PS.fp,
+	    "x syw add y MS\n"
+            "y roh dy add sub /y XD dup} for pop pop\n" "x cow dxx add add /x XD yt /y XD} forall} D\n");
+    fprintf(PS.fp, "yo mgy mg add sub /yo XD\n");
-        set_ps_font(&(PS.vl.legend.title_font));
-        if (PS.vl.legend.title[0] == '.')
-                    PS.vl.legend.title+1);
-        else
+        /* caja del elemento *
+        fprintf(PS.fp, "GS .2 LW [1] 0 LD ");
+        fprintf(PS.fp, "xo mg add yo BKw %d get BKh %d get BKt %d get add neg RE GR\n", i, i, i);
+	fprintf(PS.fp, "/x xo mg add def ");
+	fprintf(PS.fp, "/y yo BKt %d get sub def\n", i);
+	fprintf(PS.fp, "BK%d VLEGEND\n", i);
+	fprintf(PS.fp, "yo BKh %i get BKt %d get dyy add add sub /yo XD\n", i, i);
-    return 0;
+    return 1;
+void make_vareas(VECTOR * vec, int rows)
+    int i, item;
+    VAREAS *va = (VAREAS *) vec->data;
+    /* Set the title of the vector */
+    fprintf(PS.fp, "(");
+    if (va->rgbcol != NULL)
+	fprintf(PS.fp, "%s", vec->label);
+    fprintf(PS.fp, ")\n");
+    /* Iterate by items */
+    for (item = 0, i = 0; i < vec->n_item; i++, item++)
+	if (item == rows)
+	    item = 0;
+	    fprintf(PS.fp, "][\n");
+	/* set the label of the item */
+	if (va->rgbcol == NULL)
+	    fprintf(PS.fp, "( %s)", vec->label);
+	else
+            int id = vec->item[i].rule;
+	    if (id == -1)
+		fprintf(PS.fp, "( )");
+	    else
+		fprintf(PS.fp, "( %s)", vec->rule[id].label);
+	    long_to_color(vec->item[i].data, &(va->fcolor));
+	/* set the specific data of the item */
+	fprintf(PS.fp, " [");
+	if (va->line.color.none || va->line.width <= 0)
+	    fprintf(PS.fp, "0 ");
+	else
+	    fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.3f 1 ",
+                    va->line.color.r, va->line.color.g, va->line.color.b,
+                    va->line.dash, va->line.width);
+	if (va->fcolor.none && va->name_pat == NULL)
+	    fprintf(PS.fp, "0");
+	else
+	    if (va->name_pat == NULL || va->type_pat == 2)
+                        va->fcolor.r, va->fcolor.g, va->fcolor.b);
+		fprintf(PS.fp, "PATTERN%d 1 1", vec->id);
+	    else
+		fprintf(PS.fp, "0 1");
+	fprintf(PS.fp, "] %d\n", vec->type);
+void make_vlines(VECTOR * vec, int rows)
+    int i, item;
+    VLINES *vl = (VLINES *) vec->data;
+    if (vl->rgbcol != NULL)
+	if (item == rows)
+	    item = 0;
+	if (vl->rgbcol == NULL)
+	else
+	    if (id == -1)
+	    else
+	    long_to_color(vec->item[i].data, &(vl->line.color));
+	fprintf(PS.fp, "%.3f %.3f %.3f [%s] %.4f",
+		vl->line.color.r, vl->line.color.g, vl->line.color.b, vl->line.dash, vl->line.width);
+	if (vl->hline.width <= 0)
+	    fprintf(PS.fp, " 1");
+	else
+	    fprintf(PS.fp, " %.3f %.3f %.3f [%s] %.4f",
+		    vl->hline.color.r, vl->hline.color.g, vl->hline.color.b, vl->hline.dash, vl->hline.width);
+	    fprintf(PS.fp, " 2");
+void make_vpoints(VECTOR * vec, int rows)
+    int i, item;
+    VPOINTS *vp = (VPOINTS *) vec->data;
+    if (vp->sizecol != NULL && vec->n_rule > 0)
+	/* if vp->size == 0 => no draw? */
+	if (item == rows)
+	    item = 0;
+	if (vp->sizecol == NULL || vec->n_rule == 0)
+	else
+	    if (id == -1)
+		vp->size = (double)(vec->item[i].data / 1000.);
+                fprintf(PS.fp, "( %.3f)", vp->size);
+	    else
+		vp->size = vec->rule[id].value;
+	fprintf(PS.fp, "(SYMBOL%d)", vec->id);
+// 	fprintf(PS.fp, " %.4f", vp->line.width / vp->size);	/* div! 0 */
+    if (vp->size == 0.)
+        fprintf(PS.fp, " %.4f", vp->line.width);
+    else
+        fprintf(PS.fp, " %.4f", vp->line.width / vp->size);
+	fprintf(PS.fp, " %.3f", vp->rotate);
+	fprintf(PS.fp, " %.3f dup", vp->size);
+	if (vp->distance != 0.)
+		    vp->cline.color.r, vp->cline.color.g, vp->cline.color.b, vp->cline.dash, vp->cline.width);
+	else
+	    fprintf(PS.fp, " 0");
+/* Join vector legend with simple line */
+int set_vlegend_simple(int i, const int * ip, int items)
+    int x, rows, cols, item;
+    cols = (items > PS.vl.legend.cols) ? PS.vl.legend.cols : items;
+    rows = items / cols;
+    if ((items % cols))
+	++rows;
+    fprintf(PS.fp, "/BK%d [\n%.4f ()\n[\n", i, PS.vl.legend.yspan);
+    for (item = 0, x = 0; x < items; x++, item++)
+	VECTOR *vec = &(PS.vct[ip[x]]);
+	if (item == rows)
+	    item = 0;
+	switch (vec->type)
+	case AREAS:
+		else
+		else
+		    else
+	    break;
+	case LINES:
+                        vl->line.dash, vl->line.width);
+		else
+                            vl->hline.dash, vl->hline.width);
+	    break;
+	case POINTS:
+		fprintf(PS.fp, " %.4f", vp->line.width / vp->size);	/* div! 0 */
+                            vp->cline.dash, vp->cline.width);
+		else
+	    break;
+    fprintf(PS.fp, "]\n] def\n");
+    /* Evaluate result */
+    set_vlegend_ps(i, rows, cols);
+    return 1;
+/* Make a vector legend with multiline rules */
+int set_vlegend_multi(int i, VECTOR * vec)
+    int rows, cols, items;
+    items = vec->n_item;
+    cols = (items > vec->cols) ? vec->cols : items;
+	++rows;
+    /* Make de legend */
+    fprintf(PS.fp, "/BK%d [\n%.4f ", i, vec->yspan);
+    case AREAS:
+	make_vareas(vec, rows);
+	break;
+    case LINES:
+	make_vlines(vec, rows);
+	break;
+    case POINTS:
+	make_vpoints(vec, rows);
+	break;
+    fprintf(PS.fp, "] def\n");
+    return 1;
+/* Post-evaluation of postscript block legend */
+void set_vlegend_ps(int i, int rows, int cols)
+    fprintf(PS.fp, "BK%d aload length 2 sub {"
+            "aload length 3 idiv"
+            "{pop pop SW syw add cow 2 copy lt {pop} {exch /cow XD} ifelse pop}"
+            "repeat} repeat exch /dy XD\n", i);
+    fprintf(PS.fp, "BKh %d roh dy add %d mul dy sub put\n", i, rows);
+    fprintf(PS.fp, "BKw %d cow dxx add %d mul dxx sub put\n", i, cols);
+    fprintf(PS.fp, "dup length 0 eq {BKt %d 0 put} ", i);
+    fprintf(PS.fp, "{SWH BKt %d 3 -1 roll dy add put ", i);
+    fprintf(PS.fp, "BKw %d get 2 copy gt {pop BKw %d 3 -1 roll put} {pop pop} ifelse} ifelse\n", i, i);
Modified: grass-addons/postscript/ps.output/start_map.c
--- grass-addons/postscript/ps.output/start_map.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/start_map.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -24,23 +24,27 @@
     double fact, d_ns, ns, d_ew, ew;
     /* default position */
-    if (PS.map_x < 0) {
-        PS.map_x = PS.page.left + PS.brd.width;
+    if (PS.map_x < 0)
+	PS.map_x = PS.page.left + PS.brd.width;
-    if (PS.map_top < 0) {
-        PS.map_top = PS.page.top + PS.brd.width;
+    if (PS.map_top < 0)
+	PS.map_top = PS.page.top + PS.brd.width;
     /* maximun space to print from position */
-    width  = PS.page.width - PS.map_x - (PS.page.right + PS.brd.width);
+    width = PS.page.width - PS.map_x - (PS.page.right + PS.brd.width);
     height = PS.page.height - PS.map_top - (PS.page.bot + PS.brd.width);
     /* default size */
-    if (PS.map_w < 0 || PS.map_w > width) {
-        PS.map_w = width;
+    if (PS.map_w < 0 || PS.map_w > width)
+	PS.map_w = width;
-    if (PS.map_h < 0 || PS.map_h > height) {
-        PS.map_h = height;
+    if (PS.map_h < 0 || PS.map_h > height)
+	PS.map_h = height;
     /* distance calculation, throught center of map */
@@ -48,43 +52,43 @@
     if (PS.map.proj == PROJECTION_LL)
-        ns = (PS.map.north + PS.map.south)/2.;
-        d_ew = G_distance(PS.map.east, ns, PS.map.west, ns);
+	ns = (PS.map.north + PS.map.south) / 2.;
+	d_ew = G_distance(PS.map.east, ns, PS.map.west, ns);
-        ew = (PS.map.east + PS.map.west)/2.;
-        d_ns = G_distance(ew, PS.map.north, ew, PS.map.south);
+	ew = (PS.map.east + PS.map.west) / 2.;
+	d_ns = G_distance(ew, PS.map.north, ew, PS.map.south);
     else
-        d_ew = (PS.map.east - PS.map.west);
-        d_ns = (PS.map.north - PS.map.south);
+	d_ew = (PS.map.east - PS.map.west);
+	d_ns = (PS.map.north - PS.map.south);
     /* to define the scale */
     if (PS.scale > 0)
-        fact = MT_TO_POINT / (double)PS.scale;
-        ew = fact * d_ew;
-        ns = fact * d_ns;
-        if (ew <= PS.map_w && ns <= PS.map_h)
-            PS.map_w = ew;
-            PS.map_h = ns;
-        else
-            PS.scale = 0;   /* forze readjust scale */
+	fact = MT_TO_POINT / (double)PS.scale;
+	ew = fact * d_ew;
+	ns = fact * d_ns;
+	if (ew <= PS.map_w && ns <= PS.map_h)
+	    PS.map_w = ew;
+	    PS.map_h = ns;
+	else
+	    PS.scale = 0;	/* forze readjust scale */
     /* auto scale */
     if (PS.scale <= 0)
-        ew = d_ew / PS.map_w;
-        ns = d_ns / PS.map_h;
-        fact = (ew > ns) ? ew : ns;
-        PS.scale = (int)(MT_TO_POINT * fact);
+	ew = d_ew / PS.map_w;
+	ns = d_ns / PS.map_h;
+	fact = (ew > ns) ? ew : ns;
+	PS.scale = (int)(MT_TO_POINT * fact);
-        fact = 1000. * MM_TO_POINT / (double)PS.scale;
-        PS.map_w = fact * d_ew;
-        PS.map_h = fact * d_ns;
+	fact = 1000. * MM_TO_POINT / (double)PS.scale;
+	PS.map_w = fact * d_ew;
+	PS.map_h = fact * d_ns;
     G_message(_("Scale set to  1 : %d"), PS.scale);
@@ -94,11 +98,10 @@
     /* to complete */
     PS.map_right = PS.map_x + PS.map_w;
-    PS.map_top   = PS.map_y + PS.map_h;
+    PS.map_top = PS.map_y + PS.map_h;
     G_setup_plot(10. * (PS.map_y + PS.map_h), 10. * PS.map_y,
-                 10. * PS.map_x, 10. * (PS.map_x + PS.map_w),
-                 move_local, cont_local);
+		 10. * PS.map_x, 10. * (PS.map_x + PS.map_w), move_local, cont_local);
     return 0;
@@ -106,12 +109,11 @@
 /* Needed by G_setup_plot */
 int move_local(int x, int y)
-    fprintf(PS.fp, "%.1f %.1f M\n", (double)x/10., (double)y/10.);
+    fprintf(PS.fp, "%.1f %.1f M\n", (double)x / 10., (double)y / 10.);
     return 0;
 int cont_local(int x, int y)
-    fprintf(PS.fp, "%.1f %.1f L ", (double)x/10., (double)y/10.);
+    fprintf(PS.fp, "%.1f %.1f L ", (double)x / 10., (double)y / 10.);
     return 0;
Modified: grass-addons/postscript/ps.output/symbol.c
--- grass-addons/postscript/ps.output/symbol.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/symbol.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,44 +19,40 @@
     for (k = 0; k < chain->count; k++)
-        elem = chain->elem[k];
-        switch (elem->type)
-            case S_LINE:
-                for (l = 0; l < elem->coor.line.count; l++)
-                    if (k == 0 && l == 0)
-                        mvcmd = "M";
-                    else
-                        mvcmd = "L";
-                    fprintf(PS.fp, "%.4f %.4f %s\n",
-                        s * elem->coor.line.x[l],
-                        s * elem->coor.line.y[l], mvcmd);
-                break;
-            case S_ARC:
-                if (elem->coor.arc.clock)
-                    mvcmd = "arcn";
-                    else
-                    mvcmd = "arc";
-                fprintf(PS.fp, "%.4f %.4f %.4f %.4f %.4f %s\n",
-                    s * elem->coor.arc.x,
-                    s * elem->coor.arc.y,
-                    s * elem->coor.arc.r,
-                    elem->coor.arc.a1, elem->coor.arc.a2, mvcmd);
-                break;
+	elem = chain->elem[k];
+	switch (elem->type)
+	case S_LINE:
+	    for (l = 0; l < elem->coor.line.count; l++)
+		if (k == 0 && l == 0)
+		    mvcmd = "M";
+		else
+		    mvcmd = "L";
+		fprintf(PS.fp, "%.4f %.4f %s\n", s * elem->coor.line.x[l], s * elem->coor.line.y[l], mvcmd);
+	    break;
+	case S_ARC:
+	    if (elem->coor.arc.clock)
+		mvcmd = "arcn";
+	    else
+		mvcmd = "arc";
+	    fprintf(PS.fp, "%.4f %.4f %.4f %.4f %.4f %s\n",
+		    s * elem->coor.arc.x,
+		    s * elem->coor.arc.y, s * elem->coor.arc.r, elem->coor.arc.a1, elem->coor.arc.a2, mvcmd);
+	    break;
     return 0;
 /* store symbol in PS file, scaled to final size and drawn with final colors */
-int symbol_save(int code, VPOINTS *vp, SYMBOL * Symb)
+int symbol_save(int code, VPOINTS * vp, SYMBOL * Symb)
     SYMBPART *part;
     SYMBCHAIN *chain;
-    int i,j, points;
+    int i, j, points;
     double s, xo[4], yo[4];
     points = 4;
@@ -76,67 +72,60 @@
     s *= Symb->scale;
     for (i = 0; i < Symb->count; i++)
-        part = Symb->part[i];
-        switch (part->type)
-        case S_POLYGON:
-            fprintf(PS.fp, "NP\n");	/* Start ring */
-            for (j = 0; j < part->count; j++) {	/* RINGS */
-                chain = part->chain[j];
-                draw_chain(chain, s);
-                fprintf(PS.fp, "CP\n");	/* Close one ring */
-            /* Fill */
-            if (part->fcolor.color == S_COL_DEFAULT && !vp->fcolor.none)
-                set_ps_color(&(vp->fcolor));
-                fprintf(PS.fp, "F\n");	/* Fill polygon */
-            else if (part->fcolor.color == S_COL_DEFINED)
-                fprintf(PS.fp, "%.3f %.3f %.3f C ",
-                        part->fcolor.fr,
-                        part->fcolor.fg,
-                        part->fcolor.fb);
-            /* Outline */
-            if (part->color.color == S_COL_DEFAULT && !vp->line.color.none)
-                set_ps_color(&(vp->line.color));
-                fprintf(PS.fp, "S\n");	/* Draw boundary */
-            else if (part->color.color == S_COL_DEFINED)
-                        part->color.fr,
-                        part->color.fg,
-                        part->color.fb);
-            break;
-        case S_STRING:	/* string has 1 chain */
-            if (part->color.color != S_COL_NONE)
-                chain = part->chain[0];
-                /* Color */
-                else {
-                            part->color.fr,
-                            part->color.fg,
-                            part->color.fb);
-            break;
+	part = Symb->part[i];
+	switch (part->type)
+	case S_POLYGON:
+	    fprintf(PS.fp, "NP\n");	/* Start ring */
+	    for (j = 0; j < part->count; j++)
+	    {			/* RINGS */
+		chain = part->chain[j];
+		draw_chain(chain, s);
+		fprintf(PS.fp, "CP\n");	/* Close one ring */
+	    /* Fill */
+	    if (part->fcolor.color == S_COL_DEFAULT && !vp->fcolor.none)
+		set_ps_color(&(vp->fcolor));
+		fprintf(PS.fp, "F\n");	/* Fill polygon */
+	    else if (part->fcolor.color == S_COL_DEFINED)
+		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->fcolor.fr, part->fcolor.fg, part->fcolor.fb);
+	    /* Outline */
+	    if (part->color.color == S_COL_DEFAULT && !vp->line.color.none)
+		set_ps_color(&(vp->line.color));
+		fprintf(PS.fp, "S\n");	/* Draw boundary */
+	    else if (part->color.color == S_COL_DEFINED)
+		fprintf(PS.fp, "%.3f %.3f %.3f C ", part->color.fr, part->color.fg, part->color.fb);
+	    break;
+	case S_STRING:		/* string has 1 chain */
+	    if (part->color.color != S_COL_NONE)
+		chain = part->chain[0];
+		/* Color */
+		else
+	    break;
     fprintf(PS.fp, "} def\n");
Modified: grass-addons/postscript/ps.output/val_list.c
--- grass-addons/postscript/ps.output/val_list.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/val_list.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -11,36 +11,38 @@
 /* Sort categories by user */
-int sort_list(char *order, int items, CELL **item)
+int sort_list(char *order, int items, CELL ** item)
     int i, j, k, count, tmp;
     CELL *ip, val;
     DCELL *vlist;
     /* initial order */
-    ip = (CELL *)G_malloc(sizeof(CELL) * items);
+    ip = (CELL *) G_malloc(sizeof(CELL) * items);
     for (i = 0; i < items; i++)
-        ip[i] = i;
+	ip[i] = i;
     /* if any to order */
-    if (order[0] != 0 &&
-       (count = parse_val_list(order, &vlist)) > 0)
+    if (order[0] != 0 && (count = parse_val_list(order, &vlist)) > 0)
-        for (i = 0, j = 0; j < count; j += 2)
-            for (val = vlist[j]; val <= vlist[j+1]; val++)
-                for (k = i; k < items; k++)
-                    if ((*item)[k] == val)
-                        tmp = ip[k]; ip[k] = ip[i]; ip[i] = tmp;
-                        (*item)[k] = (*item)[i]; i++;
-                        break;
+	for (i = 0, j = 0; j < count; j += 2)
+	    for (val = vlist[j]; val <= vlist[j + 1]; val++)
+		for (k = i; k < items; k++)
+		    if ((*item)[k] == val)
+			tmp = ip[k];
+			ip[k] = ip[i];
+			ip[i] = tmp;
+			(*item)[k] = (*item)[i];
+			i++;
+			break;
     G_free(*item);
@@ -71,7 +73,7 @@
 #include <grass/gis.h>
-int parse_val_list(char *buf, DCELL **list)
+int parse_val_list(char *buf, DCELL ** list)
     int count;
     DCELL a, b;
@@ -81,36 +83,37 @@
     lp = (DCELL *) G_malloc(sizeof(DCELL));
     while (*buf)
-        while (*buf == ' ' || *buf == '\t' ||
-               *buf == ',' || *buf == '\n')
-            buf++;
-        if (sscanf(buf, "%lf-%lf", &a, &b) == 2)
-            if (a > b) {
-                DCELL t;
-                t = a;
-                a = b;
-                b = t;
-            lp = (DCELL *) G_realloc(lp, (count + 2) * sizeof(DCELL));
-            lp[count++] = a;
-            lp[count++] = b;
-        else if (sscanf(buf, "%lf", &a) == 1)
-            lp[count++] = a;
-            lp[count++] = a;
-        else
-            G_free(lp);
-            return -1;
-        while (*buf && (*buf != ','))
-            buf++;
+	while (*buf == ' ' || *buf == '\t' || *buf == ',' || *buf == '\n')
+	    buf++;
+	if (sscanf(buf, "%lf-%lf", &a, &b) == 2)
+	    if (a > b)
+		DCELL t;
+		t = a;
+		a = b;
+		b = t;
+	    lp = (DCELL *) G_realloc(lp, (count + 2) * sizeof(DCELL));
+	    lp[count++] = a;
+	    lp[count++] = b;
+	else if (sscanf(buf, "%lf", &a) == 1)
+	    lp[count++] = a;
+	    lp[count++] = a;
+	else
+	    G_free(lp);
+	    return -1;
+	while (*buf && (*buf != ','))
+	    buf++;
     *list = lp;
     return count;
Modified: grass-addons/postscript/ps.output/vareas.h
--- grass-addons/postscript/ps.output/vareas.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vareas.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -20,15 +20,18 @@
     PSLINE line;
     PSCOLOR fcolor;
-    char *rgbcol;       /* if set, fcolor for legends */
-    int type_pat;       /* private: 1 colored pattern, 2 uncolored pattern */
-    char *pat;          /* name of pattern */
-    double pwidth;      /* pattern width */
-    double scale;       /* pattern scale */
+    char *rgbcol;		/* if set, fcolor for legend */
+    char *idcol;		/* if set, id rule for legend */
-    double width;       /* width of area */
+    char *name_pat;		/* name of pattern */
+    double lw_pat;		/* pattern linewidth */
+    double sc_pat;		/* pattern scale */
+    int type_pat;		/* private: 1 colored pattern, 2 uncolored pattern */
+    double width;		/* width of area */
+    int island;			/* draw island */
 } VAREAS;
 #endif
Modified: grass-addons/postscript/ps.output/vector.c
--- grass-addons/postscript/ps.output/vector.c	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vector.c	2010-01-30 15:50:19 UTC (rev 40744)
@@ -15,39 +15,95 @@
     PS.vct = (VECTOR *) G_realloc(PS.vct, PS.vct_files * sizeof(VECTOR));
     PS.vct[i].type = NONE;
+    PS.vct[i].n_item = 0;
+    PS.vct[i].item = NULL;
     return i;
-/* GEOGRAPHIC */
-/* geographic coordinates to paper coordinates */
-/* Siempre lo pone para permitir correcto cerrado de paths */
-int where_moveto(double east, double north)
+/* default values for a vector */
+int default_vector(int i)
-    int x, y;
-    double dx, dy;
+    PS.vct[i].id = i;
-    G_plot_where_xy(east, north, &x, &y);
+    PS.vct[i].layer = 1;
+    PS.vct[i].cats = NULL;
+    PS.vct[i].where = NULL;
+    PS.vct[i].masked = 0;
+    PS.vct[i].label = NULL;
-    dx = ((double)x) / 10.;
-    dy = ((double)y) / 10.;
+    PS.vct[i].cols = 1;
+    PS.vct[i].yspan = -1;
-    fprintf(PS.fp, "%.1f %.1f M ", dx, dy);
-    return 0;
+    PS.vct[i].n_rule = 0;
+    PS.vct[i].rule = NULL;
-int where_lineto(double east, double north)
+/* find the rule by value */
+int vector_rule_find(VECTOR * vct, double value)
-    int x, y;
-    double dx, dy;
+    int i, j;
+    for (i = 0; i < vct->n_rule; i++)
+	for (j = 0; j < vct->rule[i].count; j++)
+            if (value >= vct->rule[i].val_list[j] &&
+                value <= vct->rule[i].val_list[j + 1])
+		return i;
+    return -1;
-    dx = (double)x / 10.;
-    dy = (double)y / 10.;
+/* allocate memory space for a new legend item */
+int vector_item_new(VECTOR * vct, double value, long data)
+    int i, k, rule;
-    fprintf(PS.fp, "%.1f %.1f L ", dx, dy);
+    rule = vector_rule_find(vct, value);
-    return 0;
+    /* Check if already exist */
+    for (k = 0; k < vct->n_item; k++)
+        if (vct->item[k].rule == -1)
+	    if (vct->item[k].data == data)
+		return k;
+	else
+            if (vct->item[k].rule == rule)
+		return k;
+    i = vct->n_item;
+    ++(vct->n_item);
+    vct->item = (ITEMS *) G_realloc(vct->item, vct->n_item * sizeof(ITEMS));
+    vct->item[i].rule = rule;
+    vct->item[i].data = data;
+    return i;
+/* allocate memory space for a new vector rule */
+int vector_rule_new(VECTOR * vct, char *catsbuf, char *label, double value)
+    int k, i = vct->n_rule;
+    ++(vct->n_rule);
+    vct->rule = (RULES *) G_realloc(vct->rule, vct->n_rule * sizeof(RULES));
+    vct->rule[i].id = i;
+    vct->rule[i].value = value;
+    vct->rule[i].label = (label == NULL) ? NULL : G_store(label);
+    vct->rule[i].count = parse_val_list(catsbuf, &(vct->rule[i].val_list));
+    return i;
Modified: grass-addons/postscript/ps.output/vector.h
--- grass-addons/postscript/ps.output/vector.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vector.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -16,30 +16,63 @@
 #include "vareas.h"
 #include "vlines.h"
 #include "vpoints.h"
+#include "vlabels.h"
+#include "vlegend.h"
 typedef struct
+    int id;			/* rule identification */
+    int count;			/* number of ranges in val_list */
+    DCELL *val_list;		/* rule of numeric pertenence */
+    float value;		/* associate value */
+    char *label;		/* associated label */
+} RULES;
+typedef struct
+    int rule;			/* identification/order of the item */
+    long data;			/* data associate to the item */
+} ITEMS;
+typedef struct
     struct Map_info Map;
     VARRAY *Varray;
-    char *name;         /* in Map_info also */
-    char *mapset;       /* in Map_info also */
+    char *name;			/* in Map_info also, 'none' to don't draw */
+    char *mapset;		/* in Map_info also */
-    int layer;          /* category layer */
+    int layer;			/* category layer */
     char *cats;			/* list of categories */
     char *where;		/* SQL where condition (without WHERE key word) */
-    char masked;
+    char masked;		/* masked or not by raster map */
     int id;
-    int type;           /* POINTS, LINES, AREAS */
-    void *data;         /* VPOINTS, VLINES, VAREAS */
+    int type;			/* POINTS, LINES, AREAS, LABELS */
+    void *data;			/* VPOINTS, VLINES, VAREAS, VLABELS */
-    char *label;        /* label in legend */
-    int lpos;           /* position in legend */
+    /* legend management */
+    char *label;		/* label */
+    int lpos;			/* position */
+    int cols;			/* number of columns */
+    double width;		/* symbol width  */
+    double xspan;		/* separation between columns */
+    double yspan;		/* separation between rows */
+    int n_item;
+    ITEMS *item;		/* items make by the vector */
+    int n_rule;
+    RULES *rule;		/* rules to group items */
 } VECTOR;
 #endif
Modified: grass-addons/postscript/ps.output/vlegend.h
--- grass-addons/postscript/ps.output/vlegend.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vlegend.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -14,12 +14,11 @@
 #include <stdio.h>
 #include "legends.h"
 typedef struct
-	LEGEND legend;
+    LEGEND legend;
-    char order[512];    /* category custom order */
 } VLEGEND;
 #endif
Modified: grass-addons/postscript/ps.output/vlines.h
--- grass-addons/postscript/ps.output/vlines.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vlines.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -19,14 +19,15 @@
 typedef struct
-    int type;           /* line or boundary */
+    int type;			/* line or boundary */
     PSLINE line;
     PSLINE hline;
-    char *rgbcol;       /* line color from database */
+    char *rgbcol;		/* line color from database */
-    double offset;      /* offset parallel line */
+    double offset;		/* offset parallel line */
 } VLINES;
Modified: grass-addons/postscript/ps.output/vpoints.h
--- grass-addons/postscript/ps.output/vpoints.h	2010-01-29 21:38:43 UTC (rev 40743)
+++ grass-addons/postscript/ps.output/vpoints.h	2010-01-30 15:50:19 UTC (rev 40744)
@@ -18,20 +18,22 @@
 typedef struct
-    int type;           /* centroid or point */
+    int type;			/* centroid, point, boundary or line */
     char *symbol;
-    double scale;
     PSLINE line;
     PSCOLOR fcolor;
-    double size;
-    char * sizecol;
+    double size, scale, bias;   /* standard size, scale and bias to draw */
+    char *sizecol;		/* size from database or rule */
-    double rotate;
-    char * rotatecol;
+    double rotate;		/* standard rotate */
+    char *rotatecol;		/* rotate from database */
+    PSLINE cline;		/* conection line */
+    double distance;		/* distance between symbols on the conection line */
+    double voffset;		/* vertical offset of the symbol */
 } VPOINTS;
 #endif
