[GRASS-SVN] r42695 - in grass/trunk: imagery/i.maxlik imagery/i.pca
imagery/i.rectify imagery/i.smap include lib/g3d lib/raster
lib/rst/interp_float raster/r.buffer raster/r.carve
raster/r.horizon raster/r.in.xyz raster/r.info
raster/r.mapcalc raster/r.param.scale raster/r.random
raster/r.reclass raster/r.recode raster/r.resamp.filter
raster/r.resamp.interp raster/r.resamp.stats
raster/r.slope.aspect raster/r.sun raster/r.sunmask
raster/r.support raster/r.topidx raster/r.watershed/front
raster/simwe/simlib raster3d/r3.in.ascii raster3d/r3.info
raster3d/r3.to.rast vector/v.to.rast vector/v.vol.rst
svn_grass at osgeo.org
Fri Jul 2 11:45:16 EDT 2010
Author: glynn
Date: 2010-07-02 15:45:16 +0000 (Fri, 02 Jul 2010)
New Revision: 42695
grass/trunk/imagery/i.maxlik/hist.c
grass/trunk/imagery/i.pca/support.c
grass/trunk/imagery/i.rectify/exec.c
grass/trunk/imagery/i.smap/history.c
grass/trunk/include/raster.h
grass/trunk/include/rasterdefs.h
grass/trunk/lib/g3d/g3dhistory.c
grass/trunk/lib/raster/history.c
grass/trunk/lib/rst/interp_float/output2d.c
grass/trunk/lib/rst/interp_float/resout2d.c
grass/trunk/raster/r.buffer/main.c
grass/trunk/raster/r.carve/support.c
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.in.xyz/main.c
grass/trunk/raster/r.info/main.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.param.scale/close_down.c
grass/trunk/raster/r.random/support.c
grass/trunk/raster/r.reclass/reclass.c
grass/trunk/raster/r.recode/recode.c
grass/trunk/raster/r.resamp.filter/main.c
grass/trunk/raster/r.resamp.interp/main.c
grass/trunk/raster/r.resamp.stats/main.c
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.sun/main.c
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.support/main.c
grass/trunk/raster/r.topidx/file_io.c
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/simwe/simlib/output.c
grass/trunk/raster3d/r3.in.ascii/main.c
grass/trunk/raster3d/r3.info/r3.info.main.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/vector/v.to.rast/support.c
grass/trunk/vector/v.vol.rst/main.c
Re-write raster history implementation
All fields are dynamically allocated: no limits on line count or line lengths
Provide/use set/get functions instead of direct structure access
Modified: grass/trunk/imagery/i.maxlik/hist.c
--- grass/trunk/imagery/i.maxlik/hist.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/imagery/i.maxlik/hist.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -5,8 +5,8 @@
struct History hist;
if (Rast_read_history(name, G_mapset(), &hist) >= 0) {
- sprintf(hist.datsrc_1, "Group/subgroup: %s/%s", group, subgroup);
- sprintf(hist.datsrc_2, "Signature file: %s", sigfile);
+ Rast_format_history(&hist, HIST_DATSRC_1, "Group/subgroup: %s/%s", group, subgroup);
+ Rast_format_history(&hist, HIST_DATSRC_2, "Signature file: %s", sigfile);
Rast_write_history(name, &hist);
Modified: grass/trunk/imagery/i.pca/support.c
--- grass/trunk/imagery/i.pca/support.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/imagery/i.pca/support.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -38,7 +38,7 @@
double eigval_total = 0.0;
Rast_short_history(outname, "raster", &hist);
- sprintf(hist.edhist[0], "Eigen values, (vectors), and [percent importance]:");
+ Rast_append_history(&hist, "Eigen values, (vectors), and [percent importance]:");
if(first_map)
G_message(_("Eigen values, (vectors), and [percent importance]:"));
@@ -63,14 +63,13 @@
sprintf(tmpa, "[%5.2f%%]", eigval[i] * 100/eigval_total);
strcat(tmpeigen, tmpa);
- sprintf(hist.edhist[i + 1], tmpeigen);
+ Rast_append_history(&hist, tmpeigen);
/* write eigen values to screen */
if(first_map)
G_message("%s", tmpeigen);
- hist.edlinecnt = i + 1;
Rast_command_history(&hist);
/* only write to stderr the first time (this fn runs for every output map) */
Modified: grass/trunk/imagery/i.rectify/exec.c
--- grass/trunk/imagery/i.rectify/exec.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/imagery/i.rectify/exec.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -87,11 +87,10 @@
/* Write out History Structure History */
- sprintf(hist.title, "%s", result);
- sprintf(hist.datsrc_1, "%s", name);
- sprintf(hist.edhist[0], "Created from: i.rectify");
- sprintf(hist.edhist[1], "Transformation order = %d", order);
- hist.edlinecnt = 2;
+ Rast_set_history(&hist, HIST_TITLE, result);
+ Rast_set_history(&hist, HIST_DATSRC_1, name);
+ Rast_append_history(&hist, "Created from: i.rectify");
+ Rast_append_format_history(&hist, "Transformation order = %d", order);
Rast_write_history(result, &hist);
select_current_env();
Modified: grass/trunk/imagery/i.smap/history.c
--- grass/trunk/imagery/i.smap/history.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/imagery/i.smap/history.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -6,8 +6,8 @@
- sprintf(hist.datsrc_2, "Sigset file: %s", sigfile);
+ Rast_format_history(&hist, HIST_DATSRC_2, "Sigset file: %s", sigfile);
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/include/raster.h 2010-07-02 15:45:16 UTC (rev 42695)
@@ -10,10 +10,6 @@
#define FCELL_TYPE 1
#define DCELL_TYPE 2
-/* History */
-#define RECORD_LEN 80
-#define MAXEDLINES 50
/* for G_get_raster_sample(), INTERP_TYPE */
#define UNKNOWN 0
#define NEAREST 1 /* nearest neighbor interpolation */
@@ -153,18 +149,25 @@
/* label, and quant rules are never reordered. Olga apr,95 */
+enum History_field
+ HIST_MAPID,
+ HIST_TITLE,
+ HIST_MAPSET,
+ HIST_CREATOR,
+ HIST_MAPTYPE,
+ HIST_DATSRC_1,
+ HIST_DATSRC_2,
+ HIST_KEYWRD,
+ HIST_NUM_FIELDS,
struct History
- char mapid[RECORD_LEN];
- char title[RECORD_LEN];
- char mapset[RECORD_LEN];
- char creator[RECORD_LEN];
- char maptype[RECORD_LEN];
- char datsrc_1[RECORD_LEN];
- char datsrc_2[RECORD_LEN];
- char keywrd[RECORD_LEN];
- int edlinecnt;
- char edhist[MAXEDLINES][RECORD_LEN];
+ char *fields[HIST_NUM_FIELDS];
+ int nlines;
+ char **lines;
struct Cell_stats
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/include/rasterdefs.h 2010-07-02 15:45:16 UTC (rev 42695)
@@ -338,10 +338,23 @@
void Rast_zero_histogram(struct Histogram *);
/* history.c */
+int Rast__read_history(struct History *, FILE *);
int Rast_read_history(const char *, const char *, struct History *);
+void Rast__write_history(struct History *, FILE *);
void Rast_write_history(const char *, struct History *);
void Rast_short_history(const char *, const char *, struct History *);
int Rast_command_history(struct History *);
+void Rast_append_history(struct History *, const char *);
+void Rast_append_format_history(struct History *, const char *, ...)
+ __attribute__ ((format(printf, 2, 3)));
+const char *Rast_get_history(struct History *, int);
+void Rast_set_history(struct History *, int, const char *);
+void Rast_format_history(struct History *, int, const char *, ...)
+ __attribute__ ((format(printf, 3, 4)));
+void Rast_clear_history(struct History *);
+void Rast_free_history(struct History *);
+int Rast_history_length(struct History *);
+const char *Rast_history_line(struct History *, int);
/* init.c */
void Rast_init(void);
Modified: grass/trunk/lib/g3d/g3dhistory.c
--- grass/trunk/lib/g3d/g3dhistory.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/lib/g3d/g3dhistory.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -32,6 +32,7 @@
#include <stdlib.h>
#include <grass/glocale.h>
#include "G3d_intern.h"
+#include <grass/raster.h>
/*simple error message */
void SimpleErrorMessage(FILE * fd, const char *name, const char *mapset)
@@ -61,74 +62,20 @@
int G3d_readHistory(const char *name, const char *mapset, struct History *hist)
-/* This function is adapted from Rast_read_history */
- FILE *fd;
+ FILE *fp;
- G_zero(hist, sizeof(struct History));
+ G_zero(&hist, sizeof(struct History));
- fd = G_fopen_old_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name, mapset);
- if (!fd)
+ fp = G_fopen_old_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name, mapset);
+ if (!fp)
return -2;
- if (!G_getl(hist->mapid, sizeof(hist->mapid), fd)) {
- SimpleErrorMessage(fd, name, mapset);
- return -1;
- G_ascii_check(hist->mapid);
+ if (Rast__read_history(hist, fp) == 0)
+ return 0;
- if (!G_getl(hist->title, sizeof(hist->title), fd)) {
- return -1;
- G_ascii_check(hist->title);
- if (!G_getl(hist->mapset, sizeof(hist->mapset), fd)) {
- return -1;
- G_ascii_check(hist->mapset);
- if (!G_getl(hist->creator, sizeof(hist->creator), fd)) {
- return -1;
- G_ascii_check(hist->creator);
- if (!G_getl(hist->maptype, sizeof(hist->maptype), fd)) {
- return -1;
- G_ascii_check(hist->maptype);
- if (!G_getl(hist->datsrc_1, sizeof(hist->datsrc_1), fd)) {
- return -1;
- G_ascii_check(hist->datsrc_1);
- if (!G_getl(hist->datsrc_2, sizeof(hist->datsrc_2), fd)) {
- return -1;
- G_ascii_check(hist->datsrc_2);
- if (!G_getl(hist->keywrd, sizeof(hist->keywrd), fd)) {
- return -1;
- G_ascii_check(hist->keywrd);
- hist->edlinecnt = 0;
- while ((hist->edlinecnt < MAXEDLINES) &&
- (G_getl
- (hist->edhist[hist->edlinecnt], sizeof(hist->edhist[0]), fd))) {
- G_ascii_check(hist->edhist[hist->edlinecnt]);
- hist->edlinecnt++;
- fclose(fd);
- return 0;
+ SimpleErrorMessage(fp, name, mapset);
+ return -1;
@@ -150,25 +97,10 @@
int G3d_writeHistory(const char *name, struct History *hist)
/* This function is adapted from Rast_write_history */
- FILE *fd;
- int i;
- fd = G_fopen_new_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name);
- if (!fd)
+ FILE *fp = G_fopen_new_misc(G3D_DIRECTORY, G3D_HISTORY_ELEMENT, name);
+ if (!fp)
return -1;
- fprintf(fd, "%s\n", hist->mapid);
- fprintf(fd, "%s\n", hist->title);
- fprintf(fd, "%s\n", hist->mapset);
- fprintf(fd, "%s\n", hist->creator);
- fprintf(fd, "%s\n", hist->maptype);
- fprintf(fd, "%s\n", hist->datsrc_1);
- fprintf(fd, "%s\n", hist->datsrc_2);
- fprintf(fd, "%s\n", hist->keywrd);
- for (i = 0; i < hist->edlinecnt; i++)
- fprintf(fd, "%s\n", hist->edhist[i]);
- fclose(fd);
+ Rast__write_history(hist, fp);
return 0;
Modified: grass/trunk/lib/raster/history.c
--- grass/trunk/lib/raster/history.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/lib/raster/history.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -11,13 +11,63 @@
* \author Original author CERL
+#include <stdarg.h>
#include <string.h>
#include <grass/gis.h>
-static void print_history_error(const char *, const char *, FILE *);
+void Rast_append_history(struct History *hist, const char *str)
+ hist->lines = G_realloc(hist->lines, (hist->nlines + 1) * sizeof(char *));
+ hist->lines[hist->nlines++] = G_store(str);
+void Rast_append_format_history(struct History *hist, const char *fmt, ...)
+ va_list ap;
+ char *str;
+ va_start(ap, fmt);
+ G_vasprintf(&str, fmt, ap);
+ va_end(ap);
+ hist->lines[hist->nlines++] = str;
+int Rast__read_history(struct History *hist, FILE *fp)
+ int i;
+ for (i = 0; i < HIST_NUM_FIELDS; i++) {
+ char buf[4096];
+ if (!G_getl(buf, sizeof(buf), fp)) {
+ fclose(fp);
+ return -1;
+ G_ascii_check(buf);
+ hist->fields[i] = G_store(buf);
+ hist->nlines = 0;
+ for (;;) {
+ char buf[4096];
+ break;
+ Rast_append_history(hist, buf);
+ fclose(fp);
+ return 0;
* \brief Read raster history file
@@ -37,85 +87,38 @@
int Rast_read_history(const char *name, const char *mapset,
- FILE *fd;
+ FILE *fp;
- fd = G_fopen_old("hist", name, mapset);
- if (!fd) {
- print_history_error(name, mapset, fd);
- return -1;
+ fp = G_fopen_old("hist", name, mapset);
+ if (!fp) {
+ G_warning(_("Unable to get history information for <%s@%s>"),
+ name, mapset);
return -1;
- return -1;
+ return 0;
- return -1;
+ name, mapset);
+ return -1;
- return -1;
+void Rast__write_history(struct History *hist, FILE *fp)
+ int i;
- return -1;
+ fprintf(fp, "%s\n", hist->fields[i] ? hist->fields[i] : "");
- return -1;
+ for (i = 0; i < hist->nlines; i++)
+ fprintf(fp, "%s\n", hist->lines[i]);
- return -1;
- return -1;
- (G_getl
- fclose(fd);
- return 0;
+ fclose(fp);
-static void print_history_error(const char *name, const char *mapset, FILE *fp)
- if (fp)
- fclose(fp);
- G_warning(_("Unable to get history information for <%s@%s>"),
- name, mapset);
* \brief Write raster history file
@@ -135,28 +138,37 @@
void Rast_write_history(const char *name, struct History *hist)
- FILE *fp;
- int i;
- fp = G_fopen_new("hist", name);
+ FILE *fp = G_fopen_new("hist", name);
if (!fp)
G_fatal_error(_("Unable to write history information for <%s>"), name);
- fprintf(fp, "%s\n", hist->mapid);
- fprintf(fp, "%s\n", hist->title);
- fprintf(fp, "%s\n", hist->mapset);
- fprintf(fp, "%s\n", hist->creator);
- fprintf(fp, "%s\n", hist->maptype);
- fprintf(fp, "%s\n", hist->datsrc_1);
- fprintf(fp, "%s\n", hist->datsrc_2);
- fprintf(fp, "%s\n", hist->keywrd);
- fprintf(fp, "%s\n", hist->edhist[i]);
+const char *Rast_get_history(struct History *hist, int field)
+ return hist->fields[field];
- fclose(fp);
+void Rast_set_history(struct History *hist, int field, const char *str)
+ if (hist->fields[field])
+ G_free(hist->fields[field]);
+ hist->fields[field] = str ? G_store(str) : NULL;
+void Rast_format_history(struct History *hist, int field, const char *fmt, ...)
+ va_list ap;
+ G_vasprintf(&hist->fields[field], fmt, ap);
+ va_end(ap);
* \brief Initialize history structure
@@ -175,16 +187,16 @@
void Rast_short_history(const char *name, const char *type,
- strncpy(hist->mapid, G_date(), RECORD_LEN);
- strncpy(hist->title, name, RECORD_LEN);
- strncpy(hist->mapset, G_mapset(), RECORD_LEN);
- strncpy(hist->creator, G_whoami(), RECORD_LEN);
- strncpy(hist->maptype, type, RECORD_LEN);
- sprintf(hist->keywrd, _("generated by %s"), G_program_name());
- strcpy(hist->datsrc_1, "");
- strcpy(hist->datsrc_2, "");
+ G_zero(hist, sizeof(struct History));
+ Rast_set_history(hist, HIST_MAPID, G_date());
+ Rast_set_history(hist, HIST_TITLE, name);
+ Rast_set_history(hist, HIST_MAPSET, G_mapset());
+ Rast_set_history(hist, HIST_CREATOR, G_whoami());
+ Rast_set_history(hist, HIST_MAPTYPE, type);
+ Rast_format_history(hist, HIST_KEYWRD, _("generated by %s"), G_program_name());
+ Rast_set_history(hist, HIST_DATSRC_1, "");
+ Rast_set_history(hist, HIST_DATSRC_2, "");
+ hist->nlines = 0;
@@ -222,43 +234,68 @@
int Rast_command_history(struct History *hist)
- int j, cmdlen;
char *cmdlin;
+ int cmdlen;
cmdlin = G_recreate_command();
cmdlen = strlen(cmdlin);
- if (hist->edlinecnt > MAXEDLINES - 2) {
- G_warning(_("Not enough room in history file to record command line"));
- return 1;
+ if (hist->nlines > 0) /* add a blank line if preceding history exists */
+ Rast_append_history(hist, "");
- if (hist->edlinecnt > 0) { /* add a blank line if preceding history exists */
- strcpy(hist->edhist[hist->edlinecnt], "");
- if (cmdlen < 70) { /* ie if it will fit on a single line */
- sprintf(hist->edhist[hist->edlinecnt], G_recreate_command());
+ if (cmdlen < 70) /* ie if it will fit on a single line */
+ Rast_append_history(hist, cmdlin);
else { /* multi-line required */
- j = 0; /* j is the current position in the command line string */
- while ((cmdlen - j) > 70) {
- strncpy(hist->edhist[hist->edlinecnt], &cmdlin[j], 68);
- hist->edhist[hist->edlinecnt][68] = '\0';
- strcat(hist->edhist[hist->edlinecnt], "\\");
- j += 68;
- G_warning(_("Not enough room in history file for command line (truncated)"));
- return 2;
+ int j; /* j is the current position in the command line string */
+ for (j = 0; cmdlen - j > 70; j += 68) {
+ char buf[80];
+ memcpy(buf, &cmdlin[j], 68);
+ buf[68] = '\\';
+ buf[69] = '\0';
- if ((cmdlen - j) > 0) { /* ie anything left */
- strcpy(hist->edhist[hist->edlinecnt], &cmdlin[j]);
+ if (cmdlen - j > 0) /* ie anything left */
+ Rast_append_history(hist, &cmdlin[j]);
return 0;
+void Rast_clear_history(struct History *hist)
+ int i;
+ G_free(hist->lines[i]);
+ if (hist->lines)
+ G_free(hist->lines);
+ hist->nlines = 0;
+void Rast_free_history(struct History *hist)
+ int i;
+ if (hist->fields[i]) {
+ G_free(hist->fields[i]);
+ hist->fields[i] = NULL;
+ Rast_clear_history(hist);
+int Rast_history_length(struct History *hist)
+ return hist->nlines;
+const char *Rast_history_line(struct History *hist, int line)
+ if (line < 0 || line >= hist->nlines)
+ return "";
+ return hist->lines[line];
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/lib/rst/interp_float/output2d.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -25,7 +25,27 @@
#define MULT 100000
+static void do_history(const char *name, int vect, const char *input,
+ const struct interp_params *params)
+ struct History hist;
+ Rast_short_history(name, "raster", &hist);
+ if (params->elev)
+ Rast_append_format_history(&hist, "The elevation map is %s",
+ params->elev);
+ Rast_format_history(&hist, HIST_DATSRC_1, "%s %s",
+ vect ? "vector map" : "site file",
+ input);
+ Rast_command_history(&hist);
+ Rast_write_history(name, &hist);
+ if (params->ts)
+ G_write_raster_timestamp(name, params->ts);
+ Rast_free_history(&hist);
int IL_output_2d(struct interp_params *params, struct Cell_head *cellhd, /* current region */
double zmin, double zmax, /* min,max input z-values */
double zminac, double zmaxac, double c1min, double c1max, /* min,max interpolated values */
@@ -45,7 +65,7 @@
double zstep;
FCELL data1, data2;
struct Colors colors;
- struct History hist, hist1, hist2, hist3, hist4, hist5;
char *type;
const char *mapset = NULL;
int cond1, cond2;
@@ -312,22 +332,7 @@
Rast_write_colors(params->slope, mapset, &colors);
Rast_quantize_fp_map_range(params->slope, mapset, 0., 90., 0, 90);
- type = "raster";
- Rast_short_history(params->slope, type, &hist1);
- if (params->elev != NULL)
- sprintf(hist1.edhist[0], "The elevation map is %s",
- params->elev);
- if (vect)
- sprintf(hist1.datsrc_1, "vector map %s", input);
- else
- sprintf(hist1.datsrc_1, "site file %s", input);
- hist1.edlinecnt = 1;
- Rast_command_history(&hist1);
- Rast_write_history(params->slope, &hist1);
- if (params->ts)
- G_write_raster_timestamp(params->slope, params->ts);
+ do_history(params->slope, vect, input, params);
/* colortable for aspect */
@@ -396,21 +401,7 @@
Rast_write_colors(params->aspect, mapset, &colors);
Rast_quantize_fp_map_range(params->aspect, mapset, 0., 360., 0, 360);
- type = "raster";
- Rast_short_history(params->aspect, type, &hist2);
- sprintf(hist2.edhist[0], "The elevation map is %s",
- params->elev);
- if (vect)
- sprintf(hist2.datsrc_1, "vector map %s", input);
- else
- sprintf(hist2.datsrc_1, "site file %s", input);
- hist2.edlinecnt = 1;
- Rast_command_history(&hist2);
- Rast_write_history(params->aspect, &hist2);
- if (params->ts)
- G_write_raster_timestamp(params->aspect, params->ts);
+ do_history(params->aspect, vect, input, params);
/* colortable for curvatures */
@@ -462,21 +453,7 @@
(CELL) (dat1 * MULT),
(CELL) (dat2 * MULT));
- type = "raster";
- Rast_short_history(params->pcurv, type, &hist3);
- sprintf(hist3.edhist[0], "The elevation map is %s",
- params->elev);
- if (vect)
- sprintf(hist3.datsrc_1, "vector map %s", input);
- else
- sprintf(hist3.datsrc_1, "site file %s", input);
- hist3.edlinecnt = 1;
- Rast_command_history(&hist3);
- Rast_write_history(params->pcurv, &hist3);
- if (params->ts)
- G_write_raster_timestamp(params->pcurv, params->ts);
+ do_history(params->pcurv, vect, input, params);
if (params->tcurv != NULL) {
@@ -490,21 +467,7 @@
- type = "raster";
- Rast_short_history(params->tcurv, type, &hist4);
- sprintf(hist4.edhist[0], "The elevation map is %s",
- params->elev);
- if (vect)
- sprintf(hist4.datsrc_1, "vector map %s", input);
- else
- sprintf(hist4.datsrc_1, "site file %s", input);
- hist4.edlinecnt = 1;
- Rast_command_history(&hist4);
- Rast_write_history(params->tcurv, &hist4);
- if (params->ts)
- G_write_raster_timestamp(params->tcurv, params->ts);
+ do_history(params->tcurv, vect, input, params);
if (params->mcurv != NULL) {
@@ -518,21 +481,7 @@
- type = "raster";
- Rast_short_history(params->mcurv, type, &hist5);
- sprintf(hist5.edhist[0], "The elevation map is %s",
- params->elev);
- if (vect)
- sprintf(hist5.datsrc_1, "vector map %s", input);
- else
- sprintf(hist5.datsrc_1, "site file %s", input);
- hist5.edlinecnt = 1;
- Rast_command_history(&hist5);
- Rast_write_history(params->mcurv, &hist5);
- if (params->ts)
- G_write_raster_timestamp(params->mcurv, params->ts);
+ do_history(params->mcurv, vect, input, params);
@@ -555,23 +504,28 @@
if (dtens) {
if (params->rsm == -1)
- sprintf(hist.edhist[0], "giventension=%f, smoothing att=%d",
- params->fi * 1000. / dnorm, params->smatt);
+ &hist, "giventension=%f, smoothing att=%d",
+ params->fi * 1000. / dnorm, params->smatt);
else
- sprintf(hist.edhist[0], "giventension=%f, smoothing=%f",
- params->fi * 1000. / dnorm, params->rsm);
+ &hist, "giventension=%f, smoothing=%f",
+ params->fi * 1000. / dnorm, params->rsm);
else {
- sprintf(hist.edhist[0], "tension=%f, smoothing att=%d",
+ &hist, "tension=%f, smoothing att=%d",
else
- sprintf(hist.edhist[0], "tension=%f, smoothing=%f",
- params->fi, params->rsm);
+ &hist, "tension=%f, smoothing=%f",
+ params->fi, params->rsm);
- sprintf(hist.edhist[1], "dnorm=%f, dmin=%f, zmult=%f",
- dnorm, params->dmin, params->zmult);
+ &hist, "dnorm=%f, dmin=%f, zmult=%f",
+ dnorm, params->dmin, params->zmult);
* sprintf(hist.edhist[2], "segmax=%d, npmin=%d, errtotal=%f",
* params->kmax,params->kmin,ertot);
@@ -581,29 +535,30 @@
* params->kmax, params->kmin, sqrt (ertot) / n_points);
- sprintf(hist.edhist[2], "segmax=%d, npmin=%d, rmsdevi=%f",
- params->kmax, params->kmin, sqrt(ertot / n_points));
+ &hist, "segmax=%d, npmin=%d, rmsdevi=%f",
+ params->kmax, params->kmin, sqrt(ertot / n_points));
- sprintf(hist.edhist[3], "zmin_data=%f, zmax_data=%f", zmin, zmax);
- sprintf(hist.edhist[4], "zmin_int=%f, zmax_int=%f", zminac, zmaxac);
+ &hist, "zmin_data=%f, zmax_data=%f", zmin, zmax);
+ &hist, "zmin_int=%f, zmax_int=%f", zminac, zmaxac);
- if ((params->theta) && (params->scalex)) {
- sprintf(hist.edhist[5], "theta=%f, scalex=%f", params->theta,
- params->scalex);
- hist.edlinecnt = 6;
- else
- hist.edlinecnt = 5;
+ if ((params->theta) && (params->scalex))
+ &hist, "theta=%f, scalex=%f", params->theta,
+ params->scalex);
- if (vect)
- sprintf(hist.datsrc_1, "vector map %s", input);
- else
- sprintf(hist.datsrc_1, "site file %s", input);
+ input);
Rast_write_history(params->elev, &hist);
if (params->ts)
G_write_raster_timestamp(params->elev, params->ts);
Modified: grass/trunk/lib/rst/interp_float/resout2d.c
--- grass/trunk/lib/rst/interp_float/resout2d.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/lib/rst/interp_float/resout2d.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -25,6 +25,23 @@
/* output cell maps for elevation, aspect, slope and curvatures */
+static void do_history(const char *name, const char *input,
+ if (params->elev)
+ params->elev);
+ Rast_format_history(&hist, HIST_DATSRC_1, "raster map %s", input);
int IL_resample_output_2d(struct interp_params *params, double zmin, double zmax, /* min,max input z-values */
double zminac, double zmaxac, /* min,max interpolated values */
double c1min, double c1max, double c2min, double c2max, double gmin, double gmax, double ertot, /* total interplating func. error */
@@ -46,9 +63,9 @@
float dat1, dat2;
struct Colors colors, colors2;
double value1, value2;
struct _Color_Rule_ *rule;
- const char *maps, *type;
+ const char *maps;
int cond1, cond2;
CELL val1, val2;
@@ -282,16 +299,7 @@
Rast_write_colors(params->slope, maps, &colors);
- type = "raster";
- params->elev);
- sprintf(hist1.datsrc_1, "raster map %s", input);
+ do_history(params->slope, input, params);
@@ -322,16 +330,7 @@
Rast_write_colors(params->aspect, maps, &colors);
- type = "raster";
- params->elev);
- sprintf(hist2.datsrc_1, "raster map %s", input);
+ do_history(params->aspect, input, params);
@@ -386,16 +385,7 @@
dat1, dat2,
- type = "raster";
- params->elev);
- sprintf(hist3.datsrc_1, "raster map %s", input);
+ do_history(params->pcurv, input, params);
@@ -410,16 +400,7 @@
dat1, dat2, (CELL) (dat1 * MULT),
- type = "raster";
- params->elev);
- sprintf(hist4.datsrc_1, "raster map %s", input);
+ do_history(params->tcurv, input, params);
@@ -435,45 +416,42 @@
- type = "raster";
- params->elev);
- sprintf(hist5.datsrc_1, "raster map %s", input);
+ do_history(params->mcurv, input, params);
if (params->elev != NULL) {
- maps = G_find_file("cell", params->elev, "");
- if (maps == NULL) {
+ if (!G_find_file2("cell", params->elev, "")) {
G_warning(_("Raster map <%s> not found"), params->elev);
return -1;
Rast_short_history(params->elev, "raster", &hist);
if (smooth != NULL)
- sprintf(hist.edhist[0], "tension=%f, smoothing=%s",
- params->fi * 1000. / (*dnorm), smooth);
+ &hist, "tension=%f, smoothing=%s",
+ params->fi * 1000. / (*dnorm), smooth);
else
- sprintf(hist.edhist[0], "tension=%f",
- params->fi * 1000. / (*dnorm));
- sprintf(hist.edhist[1], "dnorm=%f, zmult=%f", *dnorm, params->zmult);
- sprintf(hist.edhist[2], "KMAX=%d, KMIN=%d, errtotal=%f", params->kmax,
- params->kmin, sqrt(ertot / n_points));
+ &hist, "tension=%f", params->fi * 1000. / (*dnorm));
- sprintf(hist.datsrc_1, "raster map %s", input);
+ &hist, "dnorm=%f, zmult=%f", *dnorm, params->zmult);
+ &hist, "KMAX=%d, KMIN=%d, errtotal=%f", params->kmax,
+ params->kmin, sqrt(ertot / n_points));
/* change region to initial region */
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.buffer/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -163,12 +163,9 @@
/* write map history (meta data) */
Rast_short_history(output, "raster", &hist);
- sprintf(hist.datsrc_1, "%s", input);
- if (strlen(opt3->answer) < (RECORD_LEN - 14)) {
- sprintf(hist.edhist[0], "Buffer distance%s:", ndist > 1 ? "s" : "");
- sprintf(hist.edhist[1], " %s %s", opt3->answer, units);
+ Rast_set_history(&hist, HIST_DATSRC_1, input);
+ Rast_append_format_history(&hist, "Buffer distance%s:", ndist > 1 ? "s" : "");
+ Rast_append_format_history(&hist, " %s %s", opt3->answer, units);
Rast_write_history(output, &hist);
Modified: grass/trunk/raster/r.carve/support.c
--- grass/trunk/raster/r.carve/support.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.carve/support.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -35,11 +35,10 @@
/* write command line to history */
Rast_short_history(parm->outrast->answer, "raster", &hist);
- sprintf(hist.edhist[0], "%s version %.2f", G_program_name(), APP_VERSION);
- sprintf(hist.edhist[1], "stream width: %.2f", parm->swidth * 2);
- sprintf(hist.datsrc_1, "raster elevation file: %s", parm->inrast->answer);
- sprintf(hist.datsrc_2, "vector stream file: %s", parm->invect->answer);
+ Rast_append_format_history(&hist, "%s version %.2f", G_program_name(), APP_VERSION);
+ Rast_append_format_history(&hist, "stream width: %.2f", parm->swidth * 2);
+ Rast_format_history(&hist, HIST_DATSRC_1, "raster elevation file: %s", parm->inrast->answer);
+ Rast_format_history(&hist, HIST_DATSRC_2, "vector stream file: %s", parm->invect->answer);
Rast_write_history(parm->outrast->answer, &hist);
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.horizon/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -1243,14 +1243,12 @@
Rast_command_history(&history);
/* insert a blank line */
- history.edhist[history.edlinecnt][0] = '\0';
- history.edlinecnt++;
+ Rast_append_history(&history, "");
- sprintf(msg_buff,
- "Horizon view from azimuth angle %.2f degrees CCW from East",
- angle * rad2deg);
- strcpy(history.edhist[history.edlinecnt], msg_buff);
+ &history,
+ "Horizon view from azimuth angle %.2f degrees CCW from East",
+ angle * rad2deg);
Rast_write_history(shad_filename, &history);
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.in.xyz/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -1052,8 +1052,7 @@
Rast_short_history(outmap, "raster", &history);
- strncpy(history.datsrc_1, infile, RECORD_LEN);
- history.datsrc_1[RECORD_LEN - 1] = '\0'; /* strncpy() doesn't null terminate if maxfill */
+ Rast_set_history(&history, HIST_DATSRC_1, infile);
Rast_write_history(outmap, &history);
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.info/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -151,14 +151,14 @@
divider('+');
compose_line(out, "Layer: %-29.29s Date: %s", name,
- hist_ok ? hist.mapid : "??");
+ hist_ok ? Rast_get_history(&hist, HIST_MAPID) : "??");
compose_line(out, "Mapset: %-29.29s Login of Creator: %s",
- mapset, hist_ok ? hist.creator : "??");
+ mapset, hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??");
compose_line(out, "Location: %s", G_location());
compose_line(out, "DataBase: %s", G_gisdbase());
compose_line(out, "Title: %s ( %s )",
cats_ok ? cats.title : "??",
- hist_ok ? hist.title : "??");
+ hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
/*This shows the TimeStamp */
if (time_ok && (first_time_ok || second_time_ok)) {
@@ -177,7 +177,7 @@
compose_line(out,
" Type of Map: %-20.20s Number of Categories: %-9s",
- hist_ok ? hist.maptype : "??", cats_ok ? tmp1 : "??");
+ hist_ok ? Rast_get_history(&hist, HIST_MAPTYPE) : "??", cats_ok ? tmp1 : "??");
compose_line(out, " Data Type: %s",
(data_type == CELL_TYPE ? "CELL" :
@@ -249,23 +249,23 @@
printline("");
if (hist_ok) {
- if (hist.datsrc_1[0] != '\0' || hist.datsrc_2[0] != '\0') {
+ if (Rast_get_history(&hist, HIST_DATSRC_1)[0] != '\0' ||
+ Rast_get_history(&hist, HIST_DATSRC_2)[0] != '\0') {
printline(" Data Source:");
- compose_line(out, " %s", hist.datsrc_1);
- compose_line(out, " %s", hist.datsrc_2);
+ compose_line(out, " %s", Rast_get_history(&hist, HIST_DATSRC_1));
+ compose_line(out, " %s", Rast_get_history(&hist, HIST_DATSRC_2));
printline("");
printline(" Data Description:");
- compose_line(out, " %s", hist.keywrd);
+ compose_line(out, " %s", Rast_get_history(&hist, HIST_KEYWRD));
printline("");
- if (hist.edlinecnt) {
+ if (Rast_history_length(&hist)) {
printline(" Comments: ");
- for (i = 0; i < hist.edlinecnt; i++) {
- compose_line(out, " %s", hist.edhist[i]);
+ for (i = 0; i < Rast_history_length(&hist); i++)
+ compose_line(out, " %s", Rast_history_line(&hist, i));
printline("");
@@ -373,7 +373,7 @@
if (mflag->answer) {
fprintf(out, "title=%s (%s)\n", cats_ok ? cats.title :
- "??", hist_ok ? hist.title : "??");
+ "??", hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??");
if (timestampflag->answer) {
@@ -398,14 +398,14 @@
if (hflag->answer) {
if (hist_ok) {
fprintf(out, "Data Source:\n");
- fprintf(out, " %s\n", hist.datsrc_1);
- fprintf(out, " %s\n", hist.datsrc_2);
+ fprintf(out, " %s\n", Rast_get_history(&hist, HIST_DATSRC_1));
+ fprintf(out, " %s\n", Rast_get_history(&hist, HIST_DATSRC_2));
fprintf(out, "Data Description:\n");
- fprintf(out, " %s\n", hist.keywrd);
+ fprintf(out, " %s\n", Rast_get_history(&hist, HIST_KEYWRD));
fprintf(out, "Comments:\n");
- fprintf(out, " %s\n", hist.edhist[i]);
+ fprintf(out, " %s\n", Rast_history_line(&hist, i));
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.mapcalc/map.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -707,16 +707,18 @@
void create_history(const char *dst, expression * e)
- static int WIDTH = RECORD_LEN - 12;
+ int RECORD_LEN = 80;
+ int WIDTH = RECORD_LEN - 12;
char *expr = format_expression(e);
char *p = expr;
int len = strlen(expr);
int i;
- Rast_short_history((char *)dst, "raster", &hist);
+ Rast_short_history(dst, "raster", &hist);
- for (i = 0; i < MAXEDLINES; i++) {
+ for (i = 0; ; i++) {
+ char buf[RECORD_LEN];
int n;
if (!len)
@@ -733,17 +735,16 @@
else
n = len;
- memcpy(hist.edhist[i], p, n);
- hist.edhist[i][n] = '\0';
+ memcpy(buf, p, n);
+ buf[n] = '\0';
+ Rast_append_history(&hist, buf);
p += n;
len -= n;
- hist.edlinecnt = i;
+ Rast_write_history(dst, &hist);
- Rast_write_history((char *)dst, &hist);
G_free(expr);
Modified: grass/trunk/raster/r.param.scale/close_down.c
--- grass/trunk/raster/r.param.scale/close_down.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.param.scale/close_down.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -15,7 +15,7 @@
void close_down(void)
struct History history;
- char map_title[RECORD_LEN], map_type[32];
+ char map_title[80], map_type[32];
/* Close connection with existing input raster. */
Rast_unopen(fd_in);
@@ -26,8 +26,7 @@
/* write out map metadata */
Rast_short_history(rast_out_name, "raster", &history);
- strncpy(history.datsrc_1, rast_in_name, RECORD_LEN-1);
- history.datsrc_1[RECORD_LEN-1] = '\0';
+ Rast_set_history(&history, HIST_DATSRC_1, rast_in_name);
switch (mparam) {
@@ -39,78 +38,85 @@
strcpy(map_type, "Magnitude of maximum gradient");
Rast_write_units(rast_out_name, "degrees");
- strcpy(history.edhist[0],
+ &history,
"Slope is given for steepest slope angle and measured in degrees.");
- history.edlinecnt = 1;
break;
case ASPECT:
strcpy(map_type, "Direction of maximum gradient");
+ &history,
"Flow direction (aspect): W=0, E=180, N=+90, S=-90 degrees");
break;
case PROFC:
strcpy(map_type, "Profile curvature");
+ &history,
"Curvature intersecting with the plane defined by the Z axis and");
- strcpy(history.edhist[1],
+ &history,
"maximum gradient direction. Positive values describe convex profile");
- strcpy(history.edhist[2], "curvature, negative values concave profile.");
- history.edlinecnt = 3;
+ &history,
+ "curvature, negative values concave profile.");
break;
case PLANC:
strcpy(map_type, "Plan curvature");
+ &history,
"Plan curvature is the horizontal curvature, intersecting with");
+ &history,
"the XY plane.");
- history.edlinecnt = 2;
break;
case LONGC:
strcpy(map_type, "Longitudinal curvature");
+ &history,
"Longitudinal curvature is the profile curvature intersecting with the");
+ &history,
"plane defined by the surfacenormal and maximum gradient direction.");
break;
case CROSC:
strcpy(map_type, "Cross-sectional curvature");
+ &history,
"Cross-sectional curvature is the tangential curvature intersecting");
+ &history,
"with the plane defined by the surface normal and a tangent to the");
+ &history,
"contour - perpendicular to maximum gradient direction.");
break;
case MINIC:
strcpy(map_type, "Minimum curvature");
+ &history,
"Measured in direction perpendicular to the direction of of maximum curvature.");
break;
case MAXIC:
strcpy(map_type, "Maximum curvature");
+ &history,
"The maximum curvature is measured in any direction");
break;
case FEATURE:
strcpy(map_type, "Morphometric features");
+ &history,
"Morphometric features: peaks, ridges, passes, channels, pits and planes");
break;
default:
Modified: grass/trunk/raster/r.random/support.c
--- grass/trunk/raster/r.random/support.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.random/support.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -38,15 +38,17 @@
/* write history for output raster */
if (Rast_read_history(theState->outraster, G_mapset(), &hist) >= 0) {
Rast_short_history(theState->outraster, "raster", &hist);
- sprintf(hist.datsrc_1, "Based on map <%s>", inraster);
+ Rast_format_history(&hist, HIST_DATSRC_1, "Based on map <%s>", inraster);
if (percent)
- "Random points over %.2f percent of the base map <%s>",
- percentage, inraster);
+ &hist, HIST_DATSRC_2,
+ "Random points over %.2f percent of the base map <%s>",
+ percentage, inraster);
else
- "%ld random points on the base map <%s>",
- theState->nRand, theState->inraster);
+ "%ld random points on the base map <%s>",
+ theState->nRand, theState->inraster);
Rast_write_history(theState->outraster, &hist);
Modified: grass/trunk/raster/r.reclass/reclass.c
--- grass/trunk/raster/r.reclass/reclass.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.reclass/reclass.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -246,8 +246,9 @@
Rast_free_cats(cats);
Rast_short_history(new_name, "reclass", &hist);
- strcpy(hist.datsrc_1, "Reclassified map based on:");
- sprintf(hist.datsrc_2, " Map [%s] in mapset [%s]", new.name, new.mapset);
+ Rast_set_history(&hist, HIST_DATSRC_1, "Reclassified map based on:");
+ Rast_format_history(&hist, HIST_DATSRC_2, " Map [%s] in mapset [%s]",
+ new.name, new.mapset);
Rast_write_history(new_name, &hist);
new_range(new_name, &new);
Modified: grass/trunk/raster/r.recode/recode.c
--- grass/trunk/raster/r.recode/recode.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.recode/recode.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -57,18 +57,14 @@
/* writing history file */
Rast_short_history(result, "raster", &hist);
- sprintf(hist.edhist[0], "recode of raster map %s", name);
+ Rast_append_format_history(&hist, "recode of raster map %s", name);
/* if there are more rules than history lines allocated, write only
MAXEDLINES-1 rules , and "...." as a last rule */
- for (i = 0; (i < nrules) && (i < MAXEDLINES - 2); i++)
- sprintf(hist.edhist[i + 1], "%s", rules[i]);
- if (nrules > MAXEDLINES - 1) {
- sprintf(hist.edhist[MAXEDLINES - 1], "...");
- hist.edlinecnt = MAXEDLINES;
- else
- hist.edlinecnt = nrules + 1;
- sprintf(hist.datsrc_1, "raster map %s", name);
+ for (i = 0; i < nrules && i < 50; i++)
+ Rast_append_history(&hist, rules[i]);
+ if (nrules > 50)
+ Rast_append_history(&hist, "...");
+ Rast_format_history(&hist, HIST_DATSRC_1, "raster map %s", name);
return 0;
Modified: grass/trunk/raster/r.resamp.filter/main.c
--- grass/trunk/raster/r.resamp.filter/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.resamp.filter/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -541,12 +541,12 @@
char buf_nsres[100], buf_ewres[100];
Rast_short_history(parm.rastout->answer, "raster", &history);
- strncpy(history.datsrc_1, parm.rastin->answer, RECORD_LEN);
+ Rast_set_history(&history, HIST_DATSRC_1, parm.rastin->answer);
G_format_resolution(src_w.ns_res, buf_nsres, src_w.proj);
G_format_resolution(src_w.ew_res, buf_ewres, src_w.proj);
- sprintf(history.datsrc_2, "Source map NS res: %s EW res: %s", buf_nsres,
- buf_ewres);
+ Rast_format_history(&history, HIST_DATSRC_2,
+ "Source map NS res: %s EW res: %s",
+ buf_nsres, buf_ewres);
Rast_write_history(parm.rastout->answer, &history);
Modified: grass/trunk/raster/r.resamp.interp/main.c
--- grass/trunk/raster/r.resamp.interp/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.resamp.interp/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -299,12 +299,12 @@
Rast_put_cell_title(rastout->answer, title);
Rast_short_history(rastout->answer, "raster", &history);
- strncpy(history.datsrc_1, rastin->answer, RECORD_LEN);
+ Rast_set_history(&history, HIST_DATSRC_1, rastin->answer);
- buf_ewres);
Rast_write_history(rastout->answer, &history);
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.resamp.stats/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -366,12 +366,12 @@
Rast_put_cell_title(parm.rastout->answer, title);
- buf_ewres);
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.slope.aspect/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -1041,11 +1041,10 @@
Rast_short_history(aspect_name, "raster", &hist);
- sprintf(hist.edhist[0], "aspect map elev = %s", elev_name);
- sprintf(hist.edhist[1], "zfactor = %.2f", zfactor);
- sprintf(hist.edhist[2], "min_slp_allowed = %f", min_slp_allowed);
- sprintf(hist.datsrc_1, "raster elevation file %s", elev_name);
- hist.edlinecnt = 3;
+ Rast_append_format_history(&hist, "aspect map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "zfactor = %.2f", zfactor);
+ Rast_append_format_history(&hist, "min_slp_allowed = %f", min_slp_allowed);
+ Rast_format_history(&hist, HIST_DATSRC_1, "raster elevation file %s", elev_name);
Rast_write_history(aspect_name, &hist);
G_message(_("Aspect raster map <%s> complete"), aspect_name);
@@ -1150,12 +1149,11 @@
Rast_short_history(slope_name, "raster", &hist);
- sprintf(hist.edhist[0], "slope map elev = %s", elev_name);
- sprintf(hist.edhist[1], "zfactor = %.2f format = %s", zfactor,
+ Rast_append_format_history(&hist, "slope map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "zfactor = %.2f format = %s", zfactor,
parm.slope_fmt->answer);
Rast_write_history(slope_name, &hist);
G_message(_("Slope raster map <%s> complete"), slope_name);
@@ -1223,11 +1221,10 @@
Rast_short_history(pcurv_name, "raster", &hist);
- sprintf(hist.edhist[0], "profile curve map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "profile curve map elev = %s", elev_name);
Rast_write_history(pcurv_name, &hist);
G_message(_("Profile curve raster map <%s> complete"), pcurv_name);
@@ -1250,11 +1247,10 @@
Rast_short_history(tcurv_name, "raster", &hist);
- sprintf(hist.edhist[0], "tangential curve map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "tangential curve map elev = %s", elev_name);
Rast_write_history(tcurv_name, &hist);
G_message(_("Tangential curve raster map <%s> complete"), tcurv_name);
@@ -1275,11 +1271,10 @@
Rast_short_history(dx_name, "raster", &hist);
- sprintf(hist.edhist[0], "E-W slope map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "E-W slope map elev = %s", elev_name);
Rast_write_history(dx_name, &hist);
G_message(_("E-W slope raster map <%s> complete"), dx_name);
@@ -1300,11 +1295,10 @@
Rast_short_history(dy_name, "raster", &hist);
- sprintf(hist.edhist[0], "N-S slope map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "N-S slope map elev = %s", elev_name);
Rast_write_history(dy_name, &hist);
G_message(_("N-S slope raster map <%s> complete"), dy_name);
@@ -1325,11 +1319,10 @@
Rast_short_history(dxx_name, "raster", &hist);
- sprintf(hist.edhist[0], "DXX map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "DXX map elev = %s", elev_name);
Rast_write_history(dxx_name, &hist);
G_message(_("Dxx raster map <%s> complete"), dxx_name);
@@ -1350,11 +1343,10 @@
Rast_short_history(dyy_name, "raster", &hist);
- sprintf(hist.edhist[0], "DYY map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "DYY map elev = %s", elev_name);
Rast_write_history(dyy_name, &hist);
G_message(_("Dyy raster map <%s> complete"), dyy_name);
@@ -1375,11 +1367,10 @@
Rast_short_history(dxy_name, "raster", &hist);
- sprintf(hist.edhist[0], "DXY map elev = %s", elev_name);
+ Rast_append_format_history(&hist, "DXY map elev = %s", elev_name);
Rast_write_history(dxy_name, &hist);
G_message(_("Dxy raster map <%s> complete"), dxy_name);
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.sun/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -1938,88 +1938,99 @@
G_fatal_error
("Failed to init map history: no output maps requested!");
- sprintf(hist.edhist[1], " Day [1-365]: %d",
- day);
+ &hist,
+ &hist,
+ " Day [1-365]: %d",
+ day);
- if (ttime != NULL) {
- sprintf(hist.edhist[hist.edlinecnt],
- " Local (solar) time (decimal hr.): %.4f", timo);
- hist.edlinecnt++;
+ if (ttime != NULL)
+ &hist,
+ " Local (solar) time (decimal hr.): %.4f", timo);
- " Solar constant (W/m^2): 1367");
- sprintf(hist.edhist[hist.edlinecnt + 1],
- " Extraterrestrial irradiance (W/m^2): %f",
- sunRadVar.G_norm_extra);
- sprintf(hist.edhist[hist.edlinecnt + 2],
- " Declination (rad): %f", -declination);
- hist.edlinecnt += 3;
+ &hist,
+ " Solar constant (W/m^2): 1367");
+ &hist,
+ " Extraterrestrial irradiance (W/m^2): %f",
+ sunRadVar.G_norm_extra);
+ &hist,
+ " Declination (rad): %f", -declination);
- " Latitude min-max(deg): %.4f - %.4f",
- lat_min, lat_max);
- hist.edlinecnt++;
+ &hist,
+ " Latitude min-max(deg): %.4f - %.4f",
+ lat_min, lat_max);
- " Sunrise time (hr.): %.2f",
- sunGeom.sunrise_time);
- " Sunset time (hr.): %.2f",
- sunGeom.sunset_time);
- " Daylight time (hr.): %.2f",
- sunGeom.sunset_time - sunGeom.sunrise_time);
+ &hist,
+ " Sunrise time (hr.): %.2f",
+ sunGeom.sunrise_time);
+ &hist,
+ " Sunset time (hr.): %.2f",
+ sunGeom.sunset_time);
+ &hist,
+ " Daylight time (hr.): %.2f",
+ sunGeom.sunset_time - sunGeom.sunrise_time);
else {
- " Sunrise time min-max (hr.): %.2f - %.2f",
- sunrise_min, sunrise_max);
- " Sunset time min-max (hr.): %.2f - %.2f",
- sunset_min, sunset_max);
- " Time step (hr.): %.4f", step);
+ &hist,
+ " Sunrise time min-max (hr.): %.2f - %.2f",
+ sunrise_min, sunrise_max);
+ &hist,
+ " Sunset time min-max (hr.): %.2f - %.2f",
+ sunset_min, sunset_max);
+ &hist,
+ " Time step (hr.): %.4f", step);
if (incidout != NULL || ttime != NULL) {
- " Solar altitude (deg): %.4f",
- sunVarGeom.solarAltitude * rad2deg);
- " Solar azimuth (deg): %.4f",
- sunVarGeom.solarAzimuth * rad2deg);
- hist.edlinecnt += 2;
+ &hist,
+ " Solar altitude (deg): %.4f",
+ sunVarGeom.solarAltitude * rad2deg);
+ &hist,
+ " Solar azimuth (deg): %.4f",
+ sunVarGeom.solarAzimuth * rad2deg);
if (linkein == NULL)
- " Linke turbidity factor: %.1f",
- sunRadVar.linke);
+ &hist,
+ " Linke turbidity factor: %.1f",
+ sunRadVar.linke);
else
- " Linke turbidity factor min-max: %.1f-%.1f",
- linke_min, linke_max);
- hist.edlinecnt++;
+ &hist,
+ " Linke turbidity factor min-max: %.1f-%.1f",
+ linke_min, linke_max);
if (albedo == NULL)
- " Ground albedo: %.3f",
- sunRadVar.alb);
+ &hist,
+ " Ground albedo: %.3f",
+ sunRadVar.alb);
else
- " Ground albedo min-max: %.3f-%.3f",
- albedo_min, albedo_max);
- hist.edlinecnt++;
+ &hist,
+ " Ground albedo min-max: %.3f-%.3f",
+ albedo_min, albedo_max);
- hist.edlinecnt++;
+ &hist,
/* don't call Rast_write_history() until after Rast_close() or it just gets overwritten */
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.sunmask/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -530,11 +530,9 @@
- sprintf(hist.edhist[0], "%s", *argv);
- sprintf(hist.datsrc_1, "raster elevation file %s", name);
- /* bug: long lines are truncated */
- sprintf(hist.datsrc_2, "%s", G_recreate_command());
+ Rast_append_history(&hist, argv[0]);
+ Rast_format_history(&hist, HIST_DATSRC_1, "raster elevation file %s", name);
+ Rast_set_history(&hist, HIST_DATSRC_2, G_recreate_command());
Rast_write_history(outname, &hist);
G_done_msg(" ");
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.support/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -45,7 +45,7 @@
struct Flag *stats_flag, *null_flag, *del_flag;
int is_reclass; /* Is raster reclass? */
const char *infile;
- char title[MAX_TITLE_LEN + 1], datasrc[RECORD_LEN + 1];
+ char title[MAX_TITLE_LEN + 1];
/* Initialize GIS engine */
@@ -167,75 +167,54 @@
Rast_read_history(raster->answer, "", &hist);
- fprintf(fp, "%s\n", hist.edhist[i]);
+ fprintf(fp, "%s\n", Rast_history_line(&hist, i));
fclose(fp);
if (load_opt->answer) {
FILE *fp = fopen(load_opt->answer, "r");
- int i;
if (!fp)
G_fatal_error(_("Unable to open input file <%s>"), load_opt->answer);
- for (i = 0; ; i++) {
- if (i >= MAXEDLINES) {
- G_warning(_("Not enough room in history file"));
+ Rast_clear_history(&hist);
+ for (;;) {
+ char buf[80];
+ if (!G_getl2(buf, sizeof(buf), fp))
break;
- if (!G_getl2(hist.edhist[i], RECORD_LEN - 2, fp))
- break;
fclose(fp);
Rast_write_history(raster->answer, &hist);
if (history_opt->answer) {
- if (hist.edlinecnt >= MAXEDLINES)
- G_fatal_error(_("Not enough room in history file"));
/* two less than defined as if only one less a newline gets appended in the hist file. bug? */
/* Should be RECORD_LEN, but r.info truncates at > 71 chars */
if (strlen(history_opt->answer) > 71) {
int i;
for (i = 0; i < strlen(history_opt->answer); i += 71) {
- char *tmp = &history_opt->answer[i];
+ char buf[72];
- strncpy(hist.edhist[hist.edlinecnt], tmp, 71);
+ strncpy(buf, &history_opt->answer[i], sizeof(buf)-1);
+ buf[sizeof(buf)-1] = '\0';
- /* strncpy doesn't null terminate oversized input */
- hist.edhist[hist.edlinecnt][RECORD_LEN - 2] = '\0';
- hist.edlinecnt++;
- G_debug(3, "new history line= [%s] (%d chars)",
- hist.edhist[hist.edlinecnt],
- strlen(hist.edhist[hist.edlinecnt]));
- else {
- strncpy(hist.edhist[hist.edlinecnt], history_opt->answer,
- RECORD_LEN - 2);
+ else
+ Rast_append_history(&hist, history_opt->answer);
- hist.edlinecnt++;
@@ -248,32 +227,15 @@
if (datasrc1_opt->answer || datasrc2_opt->answer || datadesc_opt->answer) {
- if (datasrc1_opt->answer) {
- strncpy(datasrc, datasrc1_opt->answer, RECORD_LEN);
- datasrc[RECORD_LEN] = '\0'; /* strncpy doesn't null terminate oversized input */
- G_strip(datasrc);
- G_debug(3, "map datasrc1= [%s] (%d chars)", datasrc,
- strlen(datasrc));
- strncpy(hist.datsrc_1, datasrc, RECORD_LEN);
- if (datasrc2_opt->answer) {
- strncpy(datasrc, datasrc2_opt->answer, RECORD_LEN);
- G_strip(datasrc);
- G_debug(3, "map datasrc2= [%s] (%d chars)", datasrc,
- strlen(datasrc));
- strncpy(hist.datsrc_2, datasrc, RECORD_LEN);
+ if (datasrc1_opt->answer)
+ Rast_set_history(&hist, HIST_DATSRC_1, datasrc1_opt->answer);
- if (datadesc_opt->answer) {
- strncpy(datasrc, datadesc_opt->answer, RECORD_LEN);
- G_strip(datasrc);
- G_debug(3, "map datadesc= [%s] (%d chars)", datasrc,
- strlen(datasrc));
- strncpy(hist.keywrd, datasrc, RECORD_LEN);
+ if (datasrc2_opt->answer)
+ Rast_set_history(&hist, HIST_DATSRC_2, datasrc2_opt->answer);
+ if (datadesc_opt->answer)
+ Rast_set_history(&hist, HIST_KEYWRD, datadesc_opt->answer);
Modified: grass/trunk/raster/r.topidx/file_io.c
--- grass/trunk/raster/r.topidx/file_io.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.topidx/file_io.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -85,7 +85,6 @@
Rast_close(fd);
Rast_short_history(oname, "raster", &history);
- strncpy(history.datsrc_1, iname, RECORD_LEN);
+ Rast_set_history(&history, HIST_DATSRC_1, iname);
Rast_write_history(oname, &history);
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/r.watershed/front/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -347,13 +347,11 @@
Rast_put_cell_title(map_name, title);
Rast_short_history(map_name, "raster", &history);
- strncpy(history.datsrc_1, source_name, RECORD_LEN);
- sprintf(history.edhist[0],
- "Processing mode: %s", sfd ? "SFD (D8)" : "MFD");
- sprintf(history.edhist[1],
- "Memory mode: %s", mode ? "Segmented" : "All in RAM");
+ Rast_set_history(&history, HIST_DATSRC_1, source_name);
+ &history, "Processing mode: %s", sfd ? "SFD (D8)" : "MFD");
+ &history, "Memory mode: %s", mode ? "Segmented" : "All in RAM");
Rast_write_history(map_name, &history);
Modified: grass/trunk/raster/simwe/simlib/output.c
--- grass/trunk/raster/simwe/simlib/output.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster/simwe/simlib/output.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -430,8 +430,8 @@
type = "raster";
Rast_short_history(erdep0, type, &hist1);
- sprintf(hist1.edhist[0], "The sediment flux file is %s", flux0);
+ &hist1, "The sediment flux file is %s", flux0);
Rast_write_history(erdep0, &hist1);
else {
@@ -446,8 +446,8 @@
type = "raster";
Rast_short_history(erdep, type, &hist1);
- sprintf(hist1.edhist[0], "The sediment flux file is %s", flux);
+ &hist1, "The sediment flux file is %s", flux);
Rast_write_history(erdep, &hist1);
@@ -470,22 +470,24 @@
/* fprintf (stdout, "\n history initiated\n");
fflush(stdout); */
- "init.walk=%d, maxwalk=%d, remaining walkers=%d", nwalk,
- maxwa, nwalka);
- sprintf(hist.edhist[1], "duration (sec.)=%d, time-serie iteration=%d",
- timesec, tt);
+ &hist, "init.walk=%d, maxwalk=%d, remaining walkers=%d",
+ nwalk, maxwa, nwalka);
+ &hist, "duration (sec.)=%d, time-serie iteration=%d",
+ timesec, tt);
+ &hist, "written walkers=%d, deltap=%f, mean vel.=%f",
+ lwwfin, deltap, vmean);
+ &hist, "mean source (si)=%e, mean infil=%e",
+ si0, infmean);
- sprintf(hist.edhist[2], "written walkers=%d, deltap=%f, mean vel.=%f",
- lwwfin, deltap, vmean);
+ Rast_format_history(&hist, HIST_DATSRC_1, "input files: %s %s %s",
+ elevin, dxin, dyin);
+ Rast_format_history(&hist, HIST_DATSRC_2, "input files: %s %s %s",
+ rain, infil, manin);
- sprintf(hist.edhist[3], "mean source (si)=%e, mean infil=%e", si0,
- infmean);
- sprintf(hist.datsrc_1, "input files: %s %s %s", elevin, dxin, dyin);
- sprintf(hist.datsrc_2, "input files: %s %s %s", rain, infil, manin);
- hist.edlinecnt = 4;
if (ts == 1)
@@ -508,22 +510,24 @@
fflush(stdout); */
- "init.walkers=%d, maxwalk=%d, rem. walkers=%d", nwalk, maxwa,
- nwalka);
- timesec, tt);
+ &hist,"init.walkers=%d, maxwalk=%d, rem. walkers=%d",
+ timesec, tt);
+ si0, infmean);
- infmean);
if (ts == 1)
@@ -546,23 +550,23 @@
fflush(stdout); */
- maxwa, nwalka);
- timesec, tt);
+ timesec, tt);
+ &hist, "mean source (si)=%f", si0);
+ wdepth, dxin, dyin);
+ Rast_format_history(&hist, HIST_DATSRC_2, "input files: %s %s %s %s",
+ manin, detin, tranin, tauin);
- sprintf(hist.edhist[3], "mean source (si)=%f", si0);
- sprintf(hist.datsrc_1, "input files: %s %s %s", wdepth, dxin, dyin);
- sprintf(hist.datsrc_2, "input files: %s %s %s %s", manin, detin,
- tranin, tauin);
if (ts == 1)
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster3d/r3.in.ascii/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -277,8 +277,7 @@
/* write input name to map history */
G3d_readHistory(output, G_mapset(), &history);
- strncpy(history.datsrc_1, input, RECORD_LEN);
+ Rast_set_history(&history, HIST_DATSRC_1, input);
G3d_writeHistory(output, &history);
map = NULL;
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -151,17 +151,15 @@
&& !timestampflag->answer && !hflag->answer) {
divider('+');
- if (G_asprintf
- (&line, "Layer: %-29.29s Date: %s", name,
- hist_ok ? hist.mapid : "??") > 0)
+ if (G_asprintf(&line, "Layer: %-29.29s Date: %s", name,
+ hist_ok ? Rast_get_history(&hist, HIST_MAPID) : "??") > 0)
printline(line);
else
G_fatal_error(_("Cannot allocate memory for string"));
- if (G_asprintf
- (&line, "Mapset: %-29.29s Login of Creator: %s", mapset,
- hist_ok ? hist.creator : "??") > 0)
+ if (G_asprintf(&line, "Mapset: %-29.29s Login of Creator: %s", mapset,
+ hist_ok ? Rast_get_history(&hist, HIST_CREATOR) : "??") > 0)
printline(line);
else
@@ -177,9 +175,8 @@
else
- if (G_asprintf
- (&line, "Title: %s ( %s )", cats_ok ? cats.title : "??",
- hist_ok ? hist.title : "??") > 0)
+ if (G_asprintf(&line, "Title: %s ( %s )", cats_ok ? cats.title : "??",
+ hist_ok ? Rast_get_history(&hist, HIST_TITLE) : "??") > 0)
printline(line);
else
@@ -210,8 +207,7 @@
format_double((double)cats.num, tmp1);
- if (G_asprintf
- (&line, " Type of Map: %-20.20s Number of Categories: %-9s",
+ if (G_asprintf(&line, " Type of Map: %-20.20s Number of Categories: %-9s",
"3d cell", cats_ok ? tmp1 : "??") > 0)
printline(line);
else
@@ -303,12 +299,12 @@
if (hist_ok) {
- if (G_asprintf(&line, " %s", hist.datsrc_1) > 0)
+ if (G_asprintf(&line, " %s", Rast_get_history(&hist, HIST_DATSRC_1)) > 0)
printline(line);
else
- if (G_asprintf(&line, " %s", hist.datsrc_2) > 0)
+ if (G_asprintf(&line, " %s", Rast_get_history(&hist, HIST_DATSRC_2)) > 0)
printline(line);
else
@@ -316,20 +312,20 @@
printline("");
- if (G_asprintf(&line, " %s", hist.keywrd) > 0)
+ if (G_asprintf(&line, " %s", Rast_get_history(&hist, HIST_KEYWRD)) > 0)
printline(line);
else
printline("");
- if (G_asprintf(&line, " %s", hist.edhist[i]) > 0)
+ if (G_asprintf(&line, " %s", Rast_history_line(&hist, i)) > 0)
printline(line);
else
@@ -383,22 +379,22 @@
} /*Datatype */
else if (tflag->answer) {
fprintf(out, "datatype=\"%s\"\n",
- (data_type ==
- FCELL_TYPE ? "float" : (data_type ==
- DCELL_TYPE ? "double" : "??")));
+ data_type == FCELL_TYPE ? "float" :
+ data_type == DCELL_TYPE ? "double" :
} /*History output */
else if (hflag->answer) {
if (hist_ok) {
else {
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -328,26 +328,24 @@
G_debug(4, "Raster map %d Filename: %s", i + 1, RasterFileName);
Rast_short_history(RasterFileName, "raster", &history);
- sprintf(history.datsrc_1, "3D Raster map:");
- strncpy(history.datsrc_2, param.input->answer, RECORD_LEN);
- history.datsrc_2[RECORD_LEN - 1] = '\0'; /* strncpy() doesn't null terminate if maxfill */
+ Rast_set_history(&history, HIST_DATSRC_1, "3D Raster map:");
+ Rast_set_history(&history, HIST_DATSRC_2, param.input->answer);
- sprintf(history.edhist[0], "Level %d of %d", i + 1, region.depths);
- sprintf(history.edhist[1], "Level z-range: %f to %f",
+ Rast_append_format_history(&history, "Level %d of %d", i + 1, region.depths);
+ Rast_append_format_history(&history, "Level z-range: %f to %f",
region.bottom + (i * region.tb_res),
region.bottom + (i + 1 * region.tb_res));
- sprintf(history.edhist[3], "Input map full z-range: %f to %f",
+ Rast_append_format_history(&history, "Input map full z-range: %f to %f",
inputmap_bounds.bottom, inputmap_bounds.top);
- sprintf(history.edhist[4], "Input map z-resolution: %f",
+ Rast_append_format_history(&history, "Input map z-resolution: %f",
inputmap_bounds.tb_res);
- history.edlinecnt = 5;
if (!param.res->answer) {
- sprintf(history.edhist[6], "GIS region full z-range: %f to %f",
+ Rast_append_format_history(&history, "GIS region full z-range: %f to %f",
region.bottom, region.top);
- sprintf(history.edhist[7], "GIS region z-resolution: %f",
+ Rast_append_format_history(&history, "GIS region z-resolution: %f",
region.tb_res);
- history.edlinecnt = 8;
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/vector/v.to.rast/support.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -26,11 +26,11 @@
if (Rast_read_history(raster_name, G_mapset(), &hist) < 0)
return -1;
- strcpy(hist.title, raster_name);
+ Rast_set_history(&hist, HIST_TITLE, raster_name);
/* store information from digit file into history */
- sprintf(hist.datsrc_1, "Vector Map: %s", vector_name);
- sprintf(hist.datsrc_2, "Original scale from vector map: 1:%ld", scale); /* 4.0 */
+ Rast_format_history(&hist, HIST_DATSRC_1, "Vector Map: %s", vector_name);
+ Rast_format_history(&hist, HIST_DATSRC_2, "Original scale from vector map: 1:%ld", scale); /* 4.0 */
/* store command line options */
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2010-07-02 15:41:54 UTC (rev 42694)
+++ grass/trunk/vector/v.vol.rst/main.c 2010-07-02 15:45:16 UTC (rev 42695)
@@ -843,17 +843,17 @@
if ((cellout != NULL)) {
Rast_short_history(cellout, "raster", &hist);
/* TODO: next lines need to be verified! */
- sprintf(hist.edhist[0], "tension=%f, smoothing=%f", fi,
- rsm);
- "dnorm=%f, dmin=%f, wmult=%f, zmult=%f", dnorm,
- atof(parm.dmin1->answer), wmult, zmult);
- sprintf(hist.edhist[2], "segmax=%d, npmin=%d, npmax=%d, rmsdevi=%f",
- KMAX, npmin, KMAXPOINTS, sqrt(ertot / KMAX2));
- sprintf(hist.edhist[3], "wmin_data=%f, wmax_data=%f",
- wmin, wmax);
+ &hist, "tension=%f, smoothing=%f", fi, rsm);
+ &hist, "dnorm=%f, dmin=%f, wmult=%f, zmult=%f", dnorm,
+ atof(parm.dmin1->answer), wmult, zmult);
+ &hist, "segmax=%d, npmin=%d, npmax=%d, rmsdevi=%f",
+ KMAX, npmin, KMAXPOINTS, sqrt(ertot / KMAX2));
+ &hist, "wmin_data=%f, wmax_data=%f", wmin, wmax);
/* ? sprintf (hist.edhist[4], "wmin_int=%f, wmax_int=%f", wminac, wmaxac); */
Rast_write_history(cellout, &hist);
