[GRASS-SVN] r42701 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Sun Jul 4 17:31:18 EDT 2010
Author: martinl
Date: 2010-07-04 21:31:18 +0000 (Sun, 04 Jul 2010)
New Revision: 42701
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/xml/grass-gxm.dtd
wxGUI/modeler: list of actions as a tab
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-04 15:46:59 UTC (rev 42700)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-04 21:31:18 UTC (rev 42701)
@@ -18,12 +18,14 @@
- PreferencesDialog
- PropertiesDialog
- ModelParamDialog
+ - ModelListCtrl
- VariablePanel
- ValiableListCtrl
- ModelLoop
- ModelLoopDialog
- - ModelActionList
+ - ActionPanel
+ - ActionListCtrl
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -250,7 +252,10 @@
y = loop['pos'][1],
width = loop['size'][0],
height = loop['size'][1],
- text = loop['text'])
+ text = loop['text'],
+ actions = loop['actions'],
+ id = loop['id'])
self.loops.append(loopItem)
def IsValid(self):
@@ -457,10 +462,13 @@
self.variablePanel = VariablePanel(parent = self)
+ self.actionPanel = ActionPanel(parent = self)
self.goutput = goutput.GMConsole(parent = self, pageid = 2,
notebook = self.notebook)
self.notebook.AddPage(self.canvas, text=_('Model'))
+ self.notebook.AddPage(self.actionPanel, text=_('Actions'))
self.notebook.AddPage(self.variablePanel, text=_('Variables'))
self.notebook.AddPage(self.goutput, text=_('Command output'))
wx.CallAfter(self.notebook.SetSelection, 0)
@@ -1303,8 +1311,12 @@
self.canvas.diagram.AddShape(loop)
loop.Show(True)
+ # connect action in the loop
+ self.DefineLoop(loop)
# load variables
self.variablePanel.OnReload()
+ self.actionPanel.OnReload()
self.SetStatusText('', 0)
self.canvas.Refresh(True)
@@ -1340,17 +1352,35 @@
return True
- def DefineLoop(self, loop, actions):
+ def DefineLoop(self, loop):
"""!Define loop with given list of actions"""
parent = loop
+ actions = loop.GetActions()
+ if not actions:
+ return
+ minId = None
for action in self.model.GetActions():
- if action.GetId() not in actions:
+ aId = action.GetId()
+ if aId not in actions:
continue
+ if aId < minId or minId is None:
+ minId = aId
rel = ModelRelation(parent, action)
self.AddLine(rel)
parent = action
+ loop.SetId(minId)
+ for action in self.model.GetActions():
+ if aId >= minId:
+ action.SetId(aId + 1)
+ try:
+ idx = actions.index(aId)
+ actions[idx] = aId + 1
+ except ValueError:
+ pass
# close loop
rel = ModelRelation(action, loop)
self.AddLine(rel)
@@ -1926,9 +1956,8 @@
### shape.SetPropDialog(dlg)
dlg.CentreOnParent()
if dlg.ShowModal() == wx.ID_OK:
- actions = dlg.GetActions()
- if actions:
- self.frame.DefineLoop(shape, actions)
+ shape.SetActions(dlg.GetActions())
+ self.frame.DefineLoop(shape)
dlg.Destroy()
@@ -1950,6 +1979,7 @@
self.popupID1 = wx.NewId()
self.popupID2 = wx.NewId()
self.popupID3 = wx.NewId()
+ self.popupID4 = wx.NewId()
# record coordinates
self.x = x
@@ -1991,10 +2021,18 @@
popupMenu.AppendSeparator()
popupMenu.Append(self.popupID2, text=_('Properties'))
self.frame.Bind(wx.EVT_MENU, self.OnProperties, id = self.popupID2)
+ if isinstance(shape, ModelAction):
+ popupMenu.Append(self.popupID4, text=_('Change ID'))
+ self.frame.Bind(wx.EVT_MENU, self.OnChangeId, id = self.popupID3)
self.frame.PopupMenu(popupMenu)
popupMenu.Destroy()
+ def OnChangeId(self, event):
+ """!Change action id"""
+ pass
def OnDisable(self, event):
"""!Disable action"""
action = self.GetShape()
@@ -2427,11 +2465,19 @@
"""!Process model loops"""
for node in self.root.findall('loop'):
pos, size = self._getDim(node)
- text = self._filterValue(self._getNodeText(node, 'value')).strip()
+ text = self._filterValue(self._getNodeText(node, 'condition')).strip()
+ aid = list()
+ for anode in node.findall('loop-action'):
+ try:
+ aid.append(int(anode.text))
+ pass
- self.loops.append({ 'pos' : pos,
- 'size': size,
- 'text' : text })
+ self.loops.append({ 'pos' : pos,
+ 'size' : size,
+ 'text' : text,
+ 'id' : int(node.get('id', -1)),
+ 'actions' : aid })
class WriteModelFile:
"""!Generic class for writing model file"""
@@ -2617,16 +2663,19 @@
def _loops(self):
"""!Write loops"""
for loop in self.loops:
- self.fd.write('%s<loop pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, loop.GetX(), loop.GetY(),
+ self.fd.write('%s<loop id="%d" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, loop.GetId(), loop.GetX(), loop.GetY(),
loop.GetWidth(), loop.GetHeight()))
text = loop.GetText()
+ self.indent += 4
if text:
- self.indent += 4
- self.fd.write('%s<value>%s</value>\n' %
+ self.fd.write('%s<condition>%s</condition>\n' %
(' ' * self.indent, self._filterValue(text)))
- self.indent -= 4
+ for action in loop.GetActions():
+ self.fd.write('%s<loop-action>%d</loop-action>\n' %
+ (' ' * self.indent, action))
+ self.indent -= 4
self.fd.write('%s</loop>\n' % (' ' * self.indent))
class PreferencesDialog(PreferencesBaseDialog):
@@ -3115,10 +3164,51 @@
return errList
+class ModelListCtrl(wx.ListCtrl,
+ listmix.ListCtrlAutoWidthMixin,
+ listmix.TextEditMixin,
+ listmix.ColumnSorterMixin):
+ def __init__(self, parent, columns, id = wx.ID_ANY,
+ style = wx.LC_REPORT | wx.BORDER_NONE |
+ wx.LC_SORT_ASCENDING |wx.LC_HRULES |
+ wx.LC_VRULES, **kwargs):
+ """!List of model variables"""
+ self.parent = parent
+ wx.ListCtrl.__init__(self, parent, id = id, style = style, **kwargs)
+ listmix.ListCtrlAutoWidthMixin.__init__(self)
+ listmix.TextEditMixin.__init__(self)
+ listmix.ColumnSorterMixin.__init__(self, 4)
+ i = 0
+ for col in columns:
+ self.InsertColumn(i, col)
+ self.SetColumnWidth(i, wx.LIST_AUTOSIZE_USEHEADER)
+ i += 1
+ self.itemDataMap = {} # requested by sorter
+ self.itemCount = 0
+ self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit)
+ self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit)
+ self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick)
+ def OnBeginEdit(self, event):
+ """!Editing of item started"""
+ event.Allow()
+ def OnEndEdit(self, event):
+ """!Finish editing of item"""
+ pass
+ def OnColClick(self, event):
+ """!Click on column header (order by)"""
+ event.Skip()
class VariablePanel(wx.Panel):
def __init__(self, parent, id = wx.ID_ANY,
- data = dict(), **kwargs):
- """!Manage model variables dialog
+ **kwargs):
+ """!Manage model variables panel
@@ -3126,14 +3216,11 @@
self.listBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label=" %s " % _("List of variables - right-click to delete"))
- self.list = VariableListCtrl(parent = self, id = wx.ID_ANY,
- style = wx.LC_REPORT | wx.BORDER_NONE |
- wx.LC_SORT_ASCENDING |wx.LC_HRULES |
- wx.LC_VRULES)
- if data:
- self.list.Populate(data)
+ self.list = VariableListCtrl(parent = self,
+ columns = [_("Name"), _("Data type"),
+ _("Default value"), _("Description")])
# add new category
self.addBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
label = " %s " % _("Add new variable"))
@@ -3215,11 +3302,7 @@
self.SetSizer(mainSizer)
mainSizer.Fit(self)
- self.SetAutoLayout(True)
- # set min size for dialog
- self.SetMinSize(self.GetBestSize())
def OnText(self, event):
"""!Text entered"""
if self.name.GetValue():
@@ -3287,33 +3370,11 @@
self.parent.GetModel().SetVariables(variables)
self.parent.ModelChanged()
-class VariableListCtrl(wx.ListCtrl,
- listmix.ListCtrlAutoWidthMixin,
- listmix.TextEditMixin,
- listmix.ColumnSorterMixin):
- def __init__(self, parent, id = wx.ID_ANY, **kwargs):
+class VariableListCtrl(ModelListCtrl):
+ def __init__(self, parent, columns, **kwargs):
- self.parent = parent
+ ModelListCtrl.__init__(self, parent, columns, **kwargs)
- wx.ListCtrl.__init__(self, parent, id = id, **kwargs)
- listmix.ListCtrlAutoWidthMixin.__init__(self)
- listmix.TextEditMixin.__init__(self)
- listmix.ColumnSorterMixin.__init__(self, 4)
- self.InsertColumn(0, _("Name"))
- self.InsertColumn(1, _("Data type"))
- self.InsertColumn(2, _("Default value"))
- self.InsertColumn(3, _("Description"))
- for i in range(0, self.GetColumnCount()):
- self.SetColumnWidth(i, wx.LIST_AUTOSIZE_USEHEADER)
- self.itemDataMap = {} # requested by sorter
- self.itemCount = 0
- self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit)
- self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit)
- self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick)
def GetListCtrl(self):
"""!Used by ColumnSorterMixin"""
return self
@@ -3377,18 +3438,14 @@
self.parent.UpdateModelVariables()
event.Skip()
def OnRemoveAll(self, event):
"""!Remove all variable(s) from the model"""
self.DeleteAllItems()
self.itemDataMap = dict()
- def OnBeginEdit(self, event):
- """!Editing of item started"""
- event.Allow()
itemIndex = event.GetIndex()
@@ -3401,13 +3458,9 @@
self.itemDataMap[itemIndex][columnIndex] = event.GetText()
- def OnColClick(self, event):
- """!Click on column header (order by)"""
- event.Skip()
class ModelLoop(ogl.RectangleShape):
- def __init__(self, parent, x, y, width = None, height = None, text = None):
+ def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, actions = []):
"""!Defines a loop"""
self.text = text
@@ -3415,6 +3468,8 @@
width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
if not height:
height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
+ self.actions = actions
+ self.id = id
if self.parent.GetCanvas():
ogl.RectangleShape.__init__(self, width, height)
@@ -3424,14 +3479,28 @@
self.SetY(y)
self.SetPen(wx.BLACK_PEN)
self.SetCornerRadius(100)
- if text:
- self.AddText(text)
+ self.AddText('(' + str(self.id) + ') ' + text)
+ def GetId(self):
+ """!Get loop id"""
+ return self.id
def GetText(self):
"""!Get loop text"""
return self.text
+ def GetActions(self):
+ """!Get actions (id)"""
+ return self.actions
+ def SetId(self, id):
+ """!Set loop id"""
+ self.id = id
+ def SetActions(self, actions):
+ """!Set actions (id)"""
class ModelLoopDialog(wx.Dialog):
"""!Loop properties dialog"""
def __init__(self, parent, shape, id = wx.ID_ANY, title = _("Loop properties"),
@@ -3449,9 +3518,12 @@
value = shape.GetText())
self.listBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label=" %s " % _("List of actions in loop"))
- self.actionList = ModelActionList(parent = self.panel)
- self.actionList.LoadData(self.parent.GetModel())
+ self.actionList = ActionListCtrl(parent = self.panel,
+ columns = [_("ID"), _("Name"),
+ _("Command")])
+ self.actionList.Populate(self.parent.GetModel().GetActions())
self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
self.btnOk.SetDefault()
@@ -3500,31 +3572,125 @@
return ids
-class ModelActionList(wx.ListCtrl,
- listmix.CheckListCtrlMixin):
- def __init__(self, parent):
- """!List control of model actions
+class ActionPanel(wx.Panel):
+ def __init__(self, parent, id = wx.ID_ANY,
+ **kwargs):
+ """!Manage model actions
- wx.ListCtrl.__init__(self, parent, id = wx.ID_ANY,
- style = wx.LC_REPORT)
- listmix.CheckListCtrlMixin.__init__(self)
+ wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
- def LoadData(self, data):
- """!Load data into list"""
- self.InsertColumn(0, _('Id'))
- self.InsertColumn(1, _('Action'))
- self.InsertColumn(2, _('Command'))
+ self.listBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label=" %s " % _("List of actions - right-click to delete"))
- for action in data.GetActions():
- index = self.InsertStringItem(sys.maxint, action.GetName())
- self.SetStringItem(index, 0, str(action.GetId()))
- self.SetStringItem(index, 1, action.GetName())
- self.SetStringItem(index, 2, action.GetLog())
+ self.list = ActionListCtrl(parent = self,
+ _("Type"), _("Command")])
+ self._layout()
+ def _layout(self):
+ """!Layout dialog"""
+ listSizer = wx.StaticBoxSizer(self.listBox, wx.VERTICAL)
+ listSizer.Add(item = self.list, proportion = 1,
+ flag = wx.EXPAND)
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ mainSizer.Add(item = listSizer, proportion = 1,
+ flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
+ self.SetSizer(mainSizer)
+ mainSizer.Fit(self)
+ def OnReload(self, event = None):
+ """!Reload list of actions"""
+ self.list.Populate(self.parent.GetModel().GetActions())
+class ActionListCtrl(ModelListCtrl):
+ """!List of model actions"""
+ self.SetColumnWidth(1, 100)
+ self.SetColumnWidth(2, 65)
+ def GetListCtrl(self):
+ """!Used by ColumnSorterMixin"""
+ return self
+ def GetData(self):
+ """!Get list data"""
+ return self.itemDataMap
+ def Populate(self, data):
+ """!Populate the list"""
+ self.itemDataMap = dict()
+ i = 0
+ for action in data:
+ if self.GetColumnCount() == 4:
+ self.itemDataMap[i] = [str(action.GetId()),
+ action.GetName(),
+ "module",
+ action.GetLog()]
+ else:
+ action.GetName(),
+ action.GetLog()]
+ i += 1
+ self.itemCount = len(self.itemDataMap.keys())
+ self.DeleteAllItems()
+ i = 0
+ for aid, name, atype, desc in self.itemDataMap.itervalues():
+ index = self.InsertStringItem(sys.maxint, aid)
+ self.SetStringItem(index, 0, aid)
+ self.SetStringItem(index, 1, name)
+ self.SetStringItem(index, 2, atype)
+ self.SetStringItem(index, 3, desc)
+ self.SetItemData(index, i)
+ i += 1
+ else:
+ for aid, name, desc in self.itemDataMap.itervalues():
+ self.SetStringItem(index, 2, desc)
+ i += 1
+ def OnRemove(self, event):
+ """!Remove selected variable(s) from the model"""
+ item = self.GetFirstSelected()
+ while item != -1:
+ self.DeleteItem(item)
+ del self.itemDataMap[item]
+ self.parent.UpdateModelVariables()
+ event.Skip()
+ def OnRemoveAll(self, event):
+ """!Remove all variable(s) from the model"""
+ itemIndex = event.GetIndex()
+ columnIndex = event.GetColumn()
+ nameOld = self.GetItem(itemIndex, 0).GetText()
+ if columnIndex == 0: # TODO
+ event.Veto()
+ self.itemDataMap[itemIndex][columnIndex] = event.GetText()
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
Modified: grass/trunk/gui/wxpython/xml/grass-gxm.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-07-04 15:46:59 UTC (rev 42700)
+++ grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-07-04 21:31:18 UTC (rev 42701)
@@ -14,7 +14,7 @@
<!ELEMENT grass-gxm (gxm)>
-<!ELEMENT gxm (action*, data*, properties?, variables?)>
+<!ELEMENT gxm (action*, data*, loop*, properties?, variables?)>
<!-- an action defines action properties (usually GRASS modules)
@@ -94,3 +94,8 @@
<!ELEMENT variable (description?, value?)>
<!ATTLIST variable name CDATA #REQUIRED>
<!ATTLIST variable type (integer | float | string) #REQUIRED>
+<!-- a loop describes model loops
+<!ELEMENT loop (condition)>
+<!ELEMENT condition (#PCDATA)>
