[GRASS-SVN] r42707 - grass-addons/raster/r.ipso
svn_grass at osgeo.org
Wed Jul 7 02:21:48 EDT 2010
Author: epifanio
Date: 2010-07-07 06:21:48 +0000 (Wed, 07 Jul 2010)
New Revision: 42707
grass-addons/raster/r.ipso/r.ipso.py
added comments in the code and a print out the percentile values
Modified: grass-addons/raster/r.ipso/r.ipso.py
--- grass-addons/raster/r.ipso/r.ipso.py 2010-07-06 03:46:40 UTC (rev 42706)
+++ grass-addons/raster/r.ipso/r.ipso.py 2010-07-07 06:21:48 UTC (rev 42707)
@@ -56,10 +56,13 @@
def main():
stats = grass.read_command('r.stats', input = options['map'], fs = 'space', nv = '*', nsteps = '255', flags = 'inc').split('\n')[:-1]
+ # res = cellsize
res = float(grass.read_command('g.region', rast = options['map'], flags = 'm').strip().split('\n')[4].split('=')[1])
zn = np.zeros((len(stats),6),float)
kl = np.zeros((len(stats),2),float)
prc = np.zeros((9,2),float)
for i in range(len(stats)):
if i == 0:
zn[i,0], zn[i, 1] = map(float, stats[i].split(' '))
@@ -67,13 +70,18 @@
if i != 0:
zn[i,2] = zn[i,1] + zn[i-1,2]
totcell = sum(zn[:,1])
+ print "Tot. cells", totcell
zn[i,3] = 1 - (zn[i,2] / sum(zn[:,1]))
zn[i,4] = zn[i,3] * (((res**2)/1000000)*sum(zn[:,1]))
zn[i,5] = ((zn[i,0] - min(zn[:,0])) / (max(zn[:,0]) - min(zn[:,0])) )
kl[i,0] = zn[i,0]
kl[i,1] = 1 - (zn[i,2] / totcell)
+ # quantiles
prc[0,0] , prc[0,1] = findint(kl,0.025) , 0.025
prc[1,0] , prc[1,1] = findint(kl,0.05) , 0.05
prc[2,0] , prc[2,1] = findint(kl,0.1) , 0.1
@@ -83,13 +91,30 @@
prc[6,0] , prc[6,1] = findint(kl,0.9) , 0.9
prc[7,0] , prc[7,1] = findint(kl,0.95) , 0.95
prc[8,0] , prc[8,1] = findint(kl,0.975) , 0.975
+ # Managing flag & plot
if flags['a']:
plotImage(zn[:,3], zn[:,5],options['image']+'_Ipsometric.png','-','A(i) / A','Z(i) / Zmax','Ipsometric Curve')
if flags['b']:
plotImage(zn[:,4], zn[:,0],options['image']+'_Ipsographic.png','-','A [km^2]','Z [m.slm]','Ipsographic Curve')
- print prc
+ print "==========================="
+ print "Ipsometric | quantiles"
+ print '%.0f' %findint(kl,0.025) , "|", 0.025
+ print '%.0f' %findint(kl,0.05) , "|", 0.05
+ print '%.0f' %findint(kl,0.1) , "|", 0.1
+ print '%.0f' %findint(kl,0.25) , "|", 0.25
+ print '%.0f' %findint(kl,0.5) , "|", 0.5
+ print '%.0f' %findint(kl,0.75) , "|", 0.75
+ print '%.0f' %findint(kl,0.7) , "|", 0.7
+ print '%.0f' %findint(kl,0.9) , "|", 0.9
+ print '%.0f' %findint(kl,0.975) , "|", 0.975
+ print '\n'
+ print 'Done!'
+ #print prc
def findint(kl,f):
Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
z1 , z2 , f1 , f2 = kl[float(Xf[0])][0] , kl[float(Xf[0]-1)][0] , kl[float(Xf[0])][1] , kl[float(Xf[0]-1)][1]
@@ -112,3 +137,4 @@
sys.exit(main())
