[GRASS-SVN] r42711 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 7 14:31:59 EDT 2010
Author: martinl
Date: 2010-07-07 18:31:59 +0000 (Wed, 07 Jul 2010)
New Revision: 42711
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: various fixes
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-07 09:04:49 UTC (rev 42710)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-07 18:31:59 UTC (rev 42711)
@@ -151,12 +151,24 @@
self.data.append(item)
def RemoveItem(self, item):
- """!Remove item from model"""
+ """!Remove item from model
+ @return list of related items
+ relList = list()
if isinstance(item, ModelAction):
self.actions.remove(item)
+ for data in self.data:
+ for rel in data.GetRelations(direction = 'to'):
+ relList.append(rel)
+ relList.append(data)
+ self.data.remove(data)
elif isinstance(item, ModelData):
self.data.remove(item)
+ return relList
def FindAction(self, id):
"""!Find action by id"""
for action in self.actions:
@@ -1333,8 +1345,8 @@
self.DefineLoop(loop)
# load variables
- self.variablePanel.OnReload()
- self.actionPanel.OnReload()
+ self.variablePanel.Update()
+ self.actionPanel.Update()
self.SetStatusText('', 0)
self.canvas.Refresh(True)
@@ -1447,10 +1459,12 @@
for shape in diagram.GetShapeList():
if not shape.Selected():
continue
- self.parent.GetModel().RemoveItem(shape)
+ remList = self.parent.GetModel().RemoveItem(shape)
shape.Select(False)
diagram.RemoveShape(shape)
+ for item in remList:
+ diagram.RemoveShape(item)
self.Refresh()
class ModelAction(ogl.RectangleShape):
@@ -2094,6 +2108,7 @@
"""!Remove shape
self.frame.GetCanvas().RemoveSelected()
+ self.frame.actionPanel.Update()
class ModelSearchDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY, title = _("Add new GRASS module to the model"),
@@ -3192,7 +3207,8 @@
wx.LC_VRULES, **kwargs):
"""!List of model variables"""
self.parent = parent
+ self.frame = parent.parent
wx.ListCtrl.__init__(self, parent, id = id, style = style, **kwargs)
listmix.ListCtrlAutoWidthMixin.__init__(self)
listmix.TextEditMixin.__init__(self)
@@ -3210,7 +3226,9 @@
self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit)
self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit)
self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick)
+ self.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
+ self.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
def OnBeginEdit(self, event):
"""!Editing of item started"""
event.Allow()
@@ -3222,7 +3240,7 @@
def OnColClick(self, event):
"""!Click on column header (order by)"""
event.Skip()
class VariablePanel(wx.Panel):
**kwargs):
@@ -3264,10 +3282,6 @@
self.desc.Bind(wx.EVT_TEXT, self.OnText)
self.btnAdd.Bind(wx.EVT_BUTTON, self.OnAdd)
- # list
- self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
- self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
self._layout()
def _layout(self):
@@ -3346,34 +3360,6 @@
self.desc.SetValue('')
self.UpdateModelVariables()
- def OnRightUp(self, event):
- """!Mouse right button up"""
- if not hasattr(self, "popupID1"):
- self.popupID1 = wx.NewId()
- self.popupID2 = wx.NewId()
- self.popupID3 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.list.OnRemove, id = self.popupID1)
- self.Bind(wx.EVT_MENU, self.list.OnRemoveAll, id = self.popupID2)
- self.Bind(wx.EVT_MENU, self.OnReload, id = self.popupID3)
- # generate popup-menu
- menu = wx.Menu()
- menu.Append(self.popupID1, _("Delete selected"))
- menu.Append(self.popupID2, _("Delete all"))
- if self.list.GetFirstSelected() == -1:
- menu.Enable(self.popupID1, False)
- menu.Enable(self.popupID2, False)
- menu.AppendSeparator()
- menu.Append(self.popupID3, _("Reload"))
- self.PopupMenu(menu)
- menu.Destroy()
- def OnReload(self, event = None):
- """!Reload list of variables"""
- self.list.Populate(self.parent.GetModel().GetVariables())
def UpdateModelVariables(self):
"""!Update model variables"""
variables = dict()
@@ -3387,6 +3373,10 @@
self.parent.GetModel().SetVariables(variables)
self.parent.ModelChanged()
+ def Update(self):
+ """!Reload list of variables"""
+ self.list.OnReload(None)
class VariableListCtrl(ModelListCtrl):
def __init__(self, parent, columns, **kwargs):
@@ -3459,6 +3449,14 @@
def OnRemoveAll(self, event):
"""!Remove all variable(s) from the model"""
+ dlg = wx.MessageBox(parent=self,
+ message=_("Do you want to delete all variables from "
+ "the model?"),
+ caption=_("Delete variables"),
+ style=wx.YES_NO | wx.CENTRE)
+ if dlg != wx.YES:
+ return
self.DeleteAllItems()
self.itemDataMap = dict()
@@ -3477,6 +3475,34 @@
self.parent.UpdateModelVariables()
+ def OnReload(self, event):
+ self.Populate(self.parent.parent.GetModel().GetVariables())
+ def OnRightUp(self, event):
+ """!Mouse right button up"""
+ if not hasattr(self, "popupID1"):
+ self.popupID1 = wx.NewId()
+ self.popupID2 = wx.NewId()
+ self.popupID3 = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID1)
+ self.Bind(wx.EVT_MENU, self.OnRemoveAll, id = self.popupID2)
+ self.Bind(wx.EVT_MENU, self.OnReload, id = self.popupID3)
+ # generate popup-menu
+ menu = wx.Menu()
+ menu.Append(self.popupID1, _("Delete selected"))
+ menu.Append(self.popupID2, _("Delete all"))
+ if self.GetFirstSelected() == -1:
+ menu.Enable(self.popupID1, False)
+ menu.Enable(self.popupID2, False)
+ menu.AppendSeparator()
+ menu.Append(self.popupID3, _("Reload"))
+ self.PopupMenu(menu)
+ menu.Destroy()
class ModelLoop(ogl.RectangleShape):
def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, actions = []):
"""!Defines a loop"""
@@ -3621,9 +3647,9 @@
self.SetSizer(mainSizer)
mainSizer.Fit(self)
- """!Reload list of actions"""
- self.list.Populate(self.parent.GetModel().GetActions())
+ def Update(self):
class ActionListCtrl(ModelListCtrl):
@@ -3679,18 +3705,42 @@
i += 1
def OnRemove(self, event):
- """!Remove selected variable(s) from the model"""
+ """!Remove selected action(s) from the model"""
+ model = self.frame.GetModel()
+ canvas = self.frame.GetCanvas()
item = self.GetFirstSelected()
while item != -1:
self.DeleteItem(item)
del self.itemDataMap[item]
+ aId = self.GetItem(item, 0).GetText()
+ action = model.GetAction(int(aId))
+ if not action:
+ item = self.GetFirstSelected()
+ continue
+ print aId, action
+ model.RemoveItem(action)
+ canvas.GetDiagram().RemoveShape(action)
+ self.frame.ModelChanged()
- self.parent.UpdateModelVariables()
+ canvas.Refresh()
event.Skip()
+ deleteDialog = wx.MessageBox(parent=self,
+ message=_("Selected data records (%d) will permanently deleted "
+ "from table. Do you want to delete them?") % \
+ (len(self.listOfSQLStatements)),
+ caption=_("Delete records"),
+ if deleteDialog != wx.YES:
+ return False
@@ -3704,11 +3754,57 @@
self.itemDataMap[itemIndex][columnIndex] = event.GetText()
aId = int(self.GetItem(itemIndex, 0).GetText())
- action = self.parent.parent.GetModel().GetAction(aId)
+ action = self.frame.GetModel().GetAction(aId)
if not action:
event.Veto()
if columnIndex == 0:
+ action.SetId(int(event.GetText()))
+ def OnReload(self, event = None):
+ """!Reload list of actions"""
+ self.Populate(self.frame.GetModel().GetActions())
+ self.popupID4 = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnNormalize, id = self.popupID4)
+ menu = wx.Menu()
+ menu.Append(self.popupID4, _("Normalize"))
+ menu.Destroy()
+ def OnNormalize(self, event):
+ """!Update id of actions"""
+ aId = 1
+ for action in model.GetActions():
action.SetId(aId)
+ aId += 1
+ self.OnReload(None)
+ self.frame.GetCanvas().Refresh()
def main():
app = wx.PySimpleApp()
